I am happy Manjaro user for a week, but the problem appeared spontaneously.
After I shut down my laptop with App launcher or Kshutdown, the next boot my Manjaro KDE is beautiful zombie. It looks like it boots normally, even KDE GUI is responding. But system will not execute anything, nothing happens. Not Firefox or KSysGuard. Not any console command. Not to reboot or shut down from App launcher. I try to Ctrl+Alt+F2
and sudo reboot -f
, but it hangs forever too.
I have nothing to do, except to hard reboot my laptop manually. And after that, system boots properly and everything works fine until next shut down.
I have tried to switch to kernel 5.4 and back to 5.9.
I set Settings - Startup - Session - Start with an empty session
. Nothing helps.
After shut down I have zombie boot. After hard reboot I have normal boot.
Info
Generated on 2020-12-03 12:05:1606986333
#################### cat /var/log/Calamares.log ########################
#################### systemd-analyze blame ########################
20.018s pamac-mirrorlist.service
2.245s systemd-random-seed.service
1.091s upower.service
893ms tlp.service
850ms lvm2-monitor.service
799ms systemd-timesyncd.service
753ms systemd-logind.service
730ms dev-sda1.device
403ms systemd-udevd.service
384ms systemd-journald.service
362ms polkit.service
236ms avahi-daemon.service
223ms NetworkManager.service
135ms systemd-udev-trigger.service
114ms ModemManager.service
113ms udisks2.service
108ms user@1000.service
80ms systemd-journal-flush.service
77ms modprobe@drm.service
65ms systemd-tmpfiles-clean.service
40ms dev-disk-by\x2duuid-1c035312\x2d8349\x2d4225\x2d9744\x2d79fff163f918.swap
36ms systemd-tmpfiles-setup.service
30ms systemd-modules-load.service
29ms systemd-sysctl.service
28ms NetworkManager-wait-online.service
28ms systemd-tmpfiles-setup-dev.service
27ms dev-hugepages.mount
26ms dev-mqueue.mount
25ms sys-kernel-debug.mount
24ms systemd-backlight@backlight:acpi_video0.service
23ms sys-kernel-tracing.mount
23ms bluetooth.service
22ms kmod-static-nodes.service
22ms systemd-remount-fs.service
21ms wpa_supplicant.service
19ms systemd-update-utmp.service
16ms systemd-rfkill.service
16ms systemd-user-sessions.service
15ms user-runtime-dir@1000.service
14ms sys-kernel-config.mount
9ms sys-fs-fuse-connections.mount
7ms rtkit-daemon.service
4ms tmp.mount
#################### inxi -Fxzc0 ########################
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.20.3 Distro: Manjaro Linux
Machine: Type: Laptop System: CLEVO product: W240EU/W250EUQ/W270EUQ v: N/A serial: <filter>
Mobo: CLEVO model: W240EU/W250EUQ/W270EUQ v: V3.0 serial: <filter>
BIOS: American Megatrends v: 4.6.5 date: 05/09/2013
CPU: Info: Dual Core model: Intel Core i3-3120M bits: 64 type: MT MCP arch: Ivy Bridge
rev: 9 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19962
Speed: 2494 MHz min/max: 1200/2500 MHz Core speeds (MHz): 1: 2495 2: 2494 3: 2494
4: 2495
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: CLEVO/KAPOK driver: i915
v: kernel bus ID: 00:02.0
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus ID: 1-4:5
Display: x11 server: X.Org 1.20.9 driver: intel s-res: 3286x1080
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.2.3
direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Realtek RTL8723AE PCIe Wireless Network Adapter driver: rtl8723ae v: kernel
port: e000 bus ID: 02:00.0
IF: wlp2s0 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK
driver: r8169 v: kernel port: d000 bus ID: 03:00.2
IF: enp3s0f2 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 119.24 GiB used: 10.93 GiB (9.2%)
ID-1: /dev/sda model: SATA SSD size: 119.24 GiB
Partition: ID-1: / size: 108.77 GiB used: 10.93 GiB (10.0%) fs: ext4 dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 8.22 GiB used: 0 KiB (0.0%) dev: /dev/sda2
Sensors: System Temperatures: cpu: 61.0 C mobo: N/A
Info: Processes: 170 Uptime: 53m Memory: 3.74 GiB used: 1.18 GiB (31.5%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1065 Client: KDE Plasma v: 5.20.3 inxi: 3.1.08
part 1/2
journalctl -b -0 (normal boot?)
-- Logs begin at Sat 2020-11-28 15:11:57 MSK, end at Thu 2020-12-03 12:07:26 MSK. --
дек 03 11:13:40 _hostname_ kernel: microcode: microcode updated early to revision 0x21, date = 2019-02-13
дек 03 11:13:40 _hostname_ kernel: Linux version 5.9.11-3-MANJARO (builduser@development) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Sat Nov 28 09:08:57 UTC 2020
дек 03 11:13:40 _hostname_ kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=7c307857-9eea-4659-a814-d37ae3ee26a3 rw quiet resume=UUID=1c035312-8349-4225-9744-79fff163f918 udev.log_priority=3
дек 03 11:13:40 _hostname_ kernel: KERNEL supported cpus:
дек 03 11:13:40 _hostname_ kernel: Intel GenuineIntel
дек 03 11:13:40 _hostname_ kernel: AMD AuthenticAMD
дек 03 11:13:40 _hostname_ kernel: Hygon HygonGenuine
дек 03 11:13:40 _hostname_ kernel: Centaur CentaurHauls
дек 03 11:13:40 _hostname_ kernel: zhaoxin Shanghai
дек 03 11:13:40 _hostname_ kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
дек 03 11:13:40 _hostname_ kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
дек 03 11:13:40 _hostname_ kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
дек 03 11:13:40 _hostname_ kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
дек 03 11:13:40 _hostname_ kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
дек 03 11:13:40 _hostname_ kernel: BIOS-provided physical RAM map:
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x0000000040005000-0x00000000d9861fff] usable
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000d9862000-0x00000000d9f5ffff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000d9f60000-0x00000000d9feafff] usable
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000d9feb000-0x00000000da087fff] ACPI NVS
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000da088000-0x00000000da6b6fff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000da6b7000-0x00000000da6b7fff] usable
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000da6b8000-0x00000000da6fafff] ACPI NVS
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000da6fb000-0x00000000dadb0fff] usable
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000dadb1000-0x00000000daff2fff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000daff3000-0x00000000daffffff] usable
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000db800000-0x00000000df9fffff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
дек 03 11:13:40 _hostname_ kernel: BIOS-e820: [mem 0x0000000100000000-0x000000011f5fffff] usable
дек 03 11:13:40 _hostname_ kernel: NX (Execute Disable) protection: active
дек 03 11:13:40 _hostname_ kernel: SMBIOS 2.7 present.
дек 03 11:13:40 _hostname_ kernel: DMI: CLEVO CO. W240EU/W250EUQ/W270EUQ /W240EU/W250EUQ/W270EUQ , BIOS 4.6.5 05/09/2013
дек 03 11:13:40 _hostname_ kernel: tsc: Fast TSC calibration using PIT
дек 03 11:13:40 _hostname_ kernel: tsc: Detected 2494.430 MHz processor
дек 03 11:13:40 _hostname_ kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
дек 03 11:13:40 _hostname_ kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
дек 03 11:13:40 _hostname_ kernel: last_pfn = 0x11f600 max_arch_pfn = 0x400000000
дек 03 11:13:40 _hostname_ kernel: MTRR default type: uncachable
дек 03 11:13:40 _hostname_ kernel: MTRR fixed ranges enabled:
дек 03 11:13:40 _hostname_ kernel: 00000-9FFFF write-back
дек 03 11:13:40 _hostname_ kernel: A0000-BFFFF uncachable
дек 03 11:13:40 _hostname_ kernel: C0000-CFFFF write-protect
дек 03 11:13:40 _hostname_ kernel: D0000-E7FFF uncachable
дек 03 11:13:40 _hostname_ kernel: E8000-FFFFF write-protect
дек 03 11:13:40 _hostname_ kernel: MTRR variable ranges enabled:
дек 03 11:13:40 _hostname_ kernel: 0 base 000000000 mask F00000000 write-back
дек 03 11:13:40 _hostname_ kernel: 1 base 100000000 mask FE0000000 write-back
дек 03 11:13:40 _hostname_ kernel: 2 base 0E0000000 mask FE0000000 uncachable
дек 03 11:13:40 _hostname_ kernel: 3 base 0DC000000 mask FFC000000 uncachable
дек 03 11:13:40 _hostname_ kernel: 4 base 0DB800000 mask FFF800000 uncachable
дек 03 11:13:40 _hostname_ kernel: 5 base 11F800000 mask FFF800000 uncachable
дек 03 11:13:40 _hostname_ kernel: 6 base 11F600000 mask FFFE00000 uncachable
дек 03 11:13:40 _hostname_ kernel: 7 disabled
дек 03 11:13:40 _hostname_ kernel: 8 disabled
дек 03 11:13:40 _hostname_ kernel: 9 disabled
дек 03 11:13:40 _hostname_ kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
дек 03 11:13:40 _hostname_ kernel: total RAM covered: 4014M
дек 03 11:13:40 _hostname_ kernel: Found optimal setting for mtrr clean up
дек 03 11:13:40 _hostname_ kernel: gran_size: 64K chunk_size: 128M num_reg: 8 lose cover RAM: 0G
дек 03 11:13:40 _hostname_ kernel: e820: update [mem 0xdb800000-0xffffffff] usable ==> reserved
дек 03 11:13:40 _hostname_ kernel: last_pfn = 0xdb000 max_arch_pfn = 0x400000000
дек 03 11:13:40 _hostname_ kernel: found SMP MP-table at [mem 0x000fd770-0x000fd77f]
дек 03 11:13:40 _hostname_ kernel: check: Scanning 1 areas for low memory corruption
дек 03 11:13:40 _hostname_ kernel: RAMDISK: [mem 0x36637000-0x37312fff]
дек 03 11:13:40 _hostname_ kernel: ACPI: Early table checksum verification disabled
дек 03 11:13:40 _hostname_ kernel: ACPI: RSDP 0x00000000000F0490 000024 (v02 Intel )
дек 03 11:13:40 _hostname_ kernel: ACPI: XSDT 0x00000000DA078078 000074 (v01 Intel CHIEF 01072009 AMI 00010013)
дек 03 11:13:40 _hostname_ kernel: ACPI: FACP 0x00000000DA081740 00010C (v05 Intel CHIEF 01072009 AMI 00010013)
дек 03 11:13:40 _hostname_ kernel: ACPI: DSDT 0x00000000DA078188 0095B1 (v02 Intel CHIEF 00000023 INTL 20051117)
дек 03 11:13:40 _hostname_ kernel: ACPI: FACS 0x00000000DA086080 000040
дек 03 11:13:40 _hostname_ kernel: ACPI: APIC 0x00000000DA081850 000072 (v03 Intel CHIEF 01072009 AMI 00010013)
дек 03 11:13:40 _hostname_ kernel: ACPI: FPDT 0x00000000DA0818C8 000044 (v01 Intel CHIEF 01072009 AMI 00010013)
дек 03 11:13:40 _hostname_ kernel: ACPI: MCFG 0x00000000DA081910 00003C (v01 Intel CHIEF 01072009 MSFT 00000097)
дек 03 11:13:40 _hostname_ kernel: ACPI: SSDT 0x00000000DA081950 000F92 (v01 TrmRef PtidDevc 00001000 INTL 20091112)
дек 03 11:13:40 _hostname_ kernel: ACPI: SSDT 0x00000000DA0828E8 0002E7 (v01 Intel_ AoacTabl 00001000 INTL 20091112)
дек 03 11:13:40 _hostname_ kernel: ACPI: HPET 0x00000000DA082BD0 000038 (v01 Intel CHIEF 01072009 AMI. 00000005)
дек 03 11:13:40 _hostname_ kernel: ACPI: SSDT 0x00000000DA082C08 000315 (v01 SataRe SataTabl 00001000 INTL 20091112)
дек 03 11:13:40 _hostname_ kernel: ACPI: SSDT 0x00000000DA082F20 000926 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
дек 03 11:13:40 _hostname_ kernel: ACPI: SSDT 0x00000000DA083848 000B22 (v01 PmRef CpuPm 00003000 INTL 20051117)
дек 03 11:13:40 _hostname_ kernel: ACPI: Local APIC address 0xfee00000
дек 03 11:13:40 _hostname_ kernel: No NUMA configuration found
дек 03 11:13:40 _hostname_ kernel: Faking a node at [mem 0x0000000000000000-0x000000011f5fffff]
дек 03 11:13:40 _hostname_ kernel: NODE_DATA(0) allocated [mem 0x11f5fa000-0x11f5fdfff]
дек 03 11:13:40 _hostname_ kernel: Zone ranges:
дек 03 11:13:40 _hostname_ kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
дек 03 11:13:40 _hostname_ kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
дек 03 11:13:40 _hostname_ kernel: Normal [mem 0x0000000100000000-0x000000011f5fffff]
дек 03 11:13:40 _hostname_ kernel: Device empty
дек 03 11:13:40 _hostname_ kernel: Movable zone start for each node
дек 03 11:13:40 _hostname_ kernel: Early memory node ranges
дек 03 11:13:40 _hostname_ kernel: node 0: [mem 0x0000000000001000-0x000000000009cfff]
дек 03 11:13:40 _hostname_ kernel: node 0: [mem 0x0000000000100000-0x000000001fffffff]
дек 03 11:13:40 _hostname_ kernel: node 0: [mem 0x0000000020200000-0x0000000040003fff]
дек 03 11:13:40 _hostname_ kernel: node 0: [mem 0x0000000040005000-0x00000000d9861fff]
дек 03 11:13:40 _hostname_ kernel: node 0: [mem 0x00000000d9f60000-0x00000000d9feafff]
дек 03 11:13:40 _hostname_ kernel: node 0: [mem 0x00000000da6b7000-0x00000000da6b7fff]
дек 03 11:13:40 _hostname_ kernel: node 0: [mem 0x00000000da6fb000-0x00000000dadb0fff]
дек 03 11:13:40 _hostname_ kernel: node 0: [mem 0x00000000daff3000-0x00000000daffffff]
дек 03 11:13:40 _hostname_ kernel: node 0: [mem 0x0000000100000000-0x000000011f5fffff]
дек 03 11:13:40 _hostname_ kernel: Zeroed struct page in unavailable ranges: 27828 pages
дек 03 11:13:40 _hostname_ kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000011f5fffff]
дек 03 11:13:40 _hostname_ kernel: On node 0 totalpages: 1020748
дек 03 11:13:40 _hostname_ kernel: DMA zone: 64 pages used for memmap
дек 03 11:13:40 _hostname_ kernel: DMA zone: 21 pages reserved
дек 03 11:13:40 _hostname_ kernel: DMA zone: 3996 pages, LIFO batch:0
дек 03 11:13:40 _hostname_ kernel: DMA32 zone: 13879 pages used for memmap
дек 03 11:13:40 _hostname_ kernel: DMA32 zone: 888240 pages, LIFO batch:63
дек 03 11:13:40 _hostname_ kernel: Normal zone: 2008 pages used for memmap
дек 03 11:13:40 _hostname_ kernel: Normal zone: 128512 pages, LIFO batch:31
дек 03 11:13:40 _hostname_ kernel: Reserving Intel graphics memory at [mem 0xdba00000-0xdf9fffff]
дек 03 11:13:40 _hostname_ kernel: ACPI: PM-Timer IO Port: 0x408
дек 03 11:13:40 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
дек 03 11:13:40 _hostname_ kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
дек 03 11:13:40 _hostname_ kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
дек 03 11:13:40 _hostname_ kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
дек 03 11:13:40 _hostname_ kernel: ACPI: IRQ0 used by override.
дек 03 11:13:40 _hostname_ kernel: ACPI: IRQ9 used by override.
дек 03 11:13:40 _hostname_ kernel: Using ACPI (MADT) for SMP configuration information
дек 03 11:13:40 _hostname_ kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
дек 03 11:13:40 _hostname_ kernel: TSC deadline timer available
дек 03 11:13:40 _hostname_ kernel: smpboot: Allowing 4 CPUs, 0 hotplug CPUs
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x20000000-0x201fffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x40004000-0x40004fff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xd9862000-0xd9f5ffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xd9feb000-0xda087fff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xda088000-0xda6b6fff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xda6b8000-0xda6fafff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xdadb1000-0xdaff2fff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xdb000000-0xdb7fffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xdb800000-0xdf9fffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xdfa00000-0xf7ffffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
дек 03 11:13:40 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
дек 03 11:13:40 _hostname_ kernel: [mem 0xdfa00000-0xf7ffffff] available for PCI devices
дек 03 11:13:40 _hostname_ kernel: Booting paravirtualized kernel on bare hardware
дек 03 11:13:40 _hostname_ kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
дек 03 11:13:40 _hostname_ kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
дек 03 11:13:40 _hostname_ kernel: percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
дек 03 11:13:40 _hostname_ kernel: pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
дек 03 11:13:40 _hostname_ kernel: pcpu-alloc: [0] 0 1 2 3
дек 03 11:13:40 _hostname_ kernel: Built 1 zonelists, mobility grouping on. Total pages: 1004776
дек 03 11:13:40 _hostname_ kernel: Policy zone: Normal
дек 03 11:13:40 _hostname_ kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=7c307857-9eea-4659-a814-d37ae3ee26a3 rw quiet resume=UUID=1c035312-8349-4225-9744-79fff163f918 udev.log_priority=3
дек 03 11:13:40 _hostname_ kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
дек 03 11:13:40 _hostname_ kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
дек 03 11:13:40 _hostname_ kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
дек 03 11:13:40 _hostname_ kernel: Memory: 3898088K/4082992K available (14339K kernel code, 1529K rwdata, 4760K rodata, 1664K init, 2888K bss, 184644K reserved, 0K cma-reserved)
дек 03 11:13:40 _hostname_ kernel: random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
дек 03 11:13:40 _hostname_ kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
дек 03 11:13:40 _hostname_ kernel: Kernel/User page tables isolation: enabled
дек 03 11:13:40 _hostname_ kernel: ftrace: allocating 41080 entries in 161 pages
дек 03 11:13:40 _hostname_ kernel: ftrace: allocated 161 pages with 3 groups
дек 03 11:13:40 _hostname_ kernel: rcu: Preemptible hierarchical RCU implementation.
дек 03 11:13:40 _hostname_ kernel: rcu: RCU dyntick-idle grace-period acceleration is enabled.
дек 03 11:13:40 _hostname_ kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
дек 03 11:13:40 _hostname_ kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
дек 03 11:13:40 _hostname_ kernel: Trampoline variant of Tasks RCU enabled.
дек 03 11:13:40 _hostname_ kernel: Rude variant of Tasks RCU enabled.
дек 03 11:13:40 _hostname_ kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
дек 03 11:13:40 _hostname_ kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
дек 03 11:13:40 _hostname_ kernel: NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
дек 03 11:13:40 _hostname_ kernel: Console: colour dummy device 80x25
дек 03 11:13:40 _hostname_ kernel: printk: console [tty0] enabled
дек 03 11:13:40 _hostname_ kernel: ACPI: Core revision 20200717
дек 03 11:13:40 _hostname_ kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
дек 03 11:13:40 _hostname_ kernel: APIC: Switch to symmetric I/O mode setup
дек 03 11:13:40 _hostname_ kernel: x2apic: IRQ remapping doesn't support X2APIC mode
дек 03 11:13:40 _hostname_ kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
дек 03 11:13:40 _hostname_ kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x23f4ac0ca2a, max_idle_ns: 440795324191 ns
дек 03 11:13:40 _hostname_ kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4990.72 BogoMIPS (lpj=8314766)
дек 03 11:13:40 _hostname_ kernel: pid_max: default: 32768 minimum: 301
дек 03 11:13:40 _hostname_ kernel: LSM: Security Framework initializing
дек 03 11:13:40 _hostname_ kernel: Yama: becoming mindful.
дек 03 11:13:40 _hostname_ kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
дек 03 11:13:40 _hostname_ kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
дек 03 11:13:40 _hostname_ kernel: mce: CPU0: Thermal monitoring enabled (TM1)
дек 03 11:13:40 _hostname_ kernel: process: using mwait in idle threads
дек 03 11:13:40 _hostname_ kernel: Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
дек 03 11:13:40 _hostname_ kernel: Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
дек 03 11:13:40 _hostname_ kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
дек 03 11:13:40 _hostname_ kernel: Spectre V2 : Mitigation: Full generic retpoline
дек 03 11:13:40 _hostname_ kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
дек 03 11:13:40 _hostname_ kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
дек 03 11:13:40 _hostname_ kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
дек 03 11:13:40 _hostname_ kernel: Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
дек 03 11:13:40 _hostname_ kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
дек 03 11:13:40 _hostname_ kernel: MDS: Mitigation: Clear CPU buffers
дек 03 11:13:40 _hostname_ kernel: Freeing SMP alternatives memory: 32K
дек 03 11:13:40 _hostname_ kernel: smpboot: CPU0: Intel(R) Core(TM) i3-3120M CPU @ 2.50GHz (family: 0x6, model: 0x3a, stepping: 0x9)
дек 03 11:13:40 _hostname_ kernel: Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
дек 03 11:13:40 _hostname_ kernel: ... version: 3
дек 03 11:13:40 _hostname_ kernel: ... bit width: 48
дек 03 11:13:40 _hostname_ kernel: ... generic registers: 4
дек 03 11:13:40 _hostname_ kernel: ... value mask: 0000ffffffffffff
дек 03 11:13:40 _hostname_ kernel: ... max period: 00007fffffffffff
дек 03 11:13:40 _hostname_ kernel: ... fixed-purpose events: 3
дек 03 11:13:40 _hostname_ kernel: ... event mask: 000000070000000f
дек 03 11:13:40 _hostname_ kernel: rcu: Hierarchical SRCU implementation.
дек 03 11:13:40 _hostname_ kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
дек 03 11:13:40 _hostname_ kernel: smp: Bringing up secondary CPUs ...
дек 03 11:13:40 _hostname_ kernel: x86: Booting SMP configuration:
дек 03 11:13:40 _hostname_ kernel: .... node #0, CPUs: #1 #2
дек 03 11:13:40 _hostname_ kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
дек 03 11:13:40 _hostname_ kernel: #3
дек 03 11:13:40 _hostname_ kernel: smp: Brought up 1 node, 4 CPUs
дек 03 11:13:40 _hostname_ kernel: smpboot: Max logical packages: 1
дек 03 11:13:40 _hostname_ kernel: smpboot: Total of 4 processors activated (19963.91 BogoMIPS)
дек 03 11:13:40 _hostname_ kernel: devtmpfs: initialized
дек 03 11:13:40 _hostname_ kernel: x86/mm: Memory block size: 128MB
дек 03 11:13:40 _hostname_ kernel: PM: Registering ACPI NVS region [mem 0xd9feb000-0xda087fff] (643072 bytes)
дек 03 11:13:40 _hostname_ kernel: PM: Registering ACPI NVS region [mem 0xda6b8000-0xda6fafff] (274432 bytes)
дек 03 11:13:40 _hostname_ kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
дек 03 11:13:40 _hostname_ kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
дек 03 11:13:40 _hostname_ kernel: pinctrl core: initialized pinctrl subsystem
дек 03 11:13:40 _hostname_ kernel: PM: RTC time: 08:13:37, date: 2020-12-03
дек 03 11:13:40 _hostname_ kernel: NET: Registered protocol family 16
дек 03 11:13:40 _hostname_ kernel: DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
дек 03 11:13:40 _hostname_ kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
дек 03 11:13:40 _hostname_ kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
дек 03 11:13:40 _hostname_ kernel: audit: initializing netlink subsys (disabled)
дек 03 11:13:40 _hostname_ kernel: audit: type=2000 audit(1606983217.026:1): state=initialized audit_enabled=0 res=1
дек 03 11:13:40 _hostname_ kernel: thermal_sys: Registered thermal governor 'fair_share'
дек 03 11:13:40 _hostname_ kernel: thermal_sys: Registered thermal governor 'bang_bang'
дек 03 11:13:40 _hostname_ kernel: thermal_sys: Registered thermal governor 'step_wise'
дек 03 11:13:40 _hostname_ kernel: thermal_sys: Registered thermal governor 'user_space'
дек 03 11:13:40 _hostname_ kernel: thermal_sys: Registered thermal governor 'power_allocator'
дек 03 11:13:40 _hostname_ kernel: cpuidle: using governor ladder
дек 03 11:13:40 _hostname_ kernel: cpuidle: using governor menu
дек 03 11:13:40 _hostname_ kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
дек 03 11:13:40 _hostname_ kernel: ACPI: bus type PCI registered
дек 03 11:13:40 _hostname_ kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
дек 03 11:13:40 _hostname_ kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
дек 03 11:13:40 _hostname_ kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
дек 03 11:13:40 _hostname_ kernel: PCI: Using configuration type 1 for base access
дек 03 11:13:40 _hostname_ kernel: core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
дек 03 11:13:40 _hostname_ kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
дек 03 11:13:40 _hostname_ kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
дек 03 11:13:40 _hostname_ kernel: ACPI: Added _OSI(Module Device)
дек 03 11:13:40 _hostname_ kernel: ACPI: Added _OSI(Processor Device)
дек 03 11:13:40 _hostname_ kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
дек 03 11:13:40 _hostname_ kernel: ACPI: Added _OSI(Processor Aggregator Device)
дек 03 11:13:40 _hostname_ kernel: ACPI: Added _OSI(Linux-Dell-Video)
дек 03 11:13:40 _hostname_ kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
дек 03 11:13:40 _hostname_ kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
дек 03 11:13:40 _hostname_ kernel: ACPI: 6 ACPI AML tables successfully acquired and loaded
дек 03 11:13:40 _hostname_ kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
дек 03 11:13:40 _hostname_ kernel: ACPI: Dynamic OEM Table Load:
дек 03 11:13:40 _hostname_ kernel: ACPI: SSDT 0xFFFF9E3EDA057000 00083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
дек 03 11:13:40 _hostname_ kernel: ACPI: SSDT 0xFFFF9E3EDA059C00 000303 (v01 PmRef ApIst 00003000 INTL 20051117)
дек 03 11:13:40 _hostname_ kernel: ACPI: SSDT 0xFFFF9E3EDA224A00 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
дек 03 11:13:40 _hostname_ kernel: ACPI: EC: EC started
дек 03 11:13:40 _hostname_ kernel: ACPI: EC: interrupt blocked
дек 03 11:13:40 _hostname_ kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
дек 03 11:13:40 _hostname_ kernel: ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC used to handle transactions
дек 03 11:13:40 _hostname_ kernel: ACPI: Interpreter enabled
дек 03 11:13:40 _hostname_ kernel: ACPI: (supports S0 S3 S4 S5)
дек 03 11:13:40 _hostname_ kernel: ACPI: Using IOAPIC for interrupt routing
дек 03 11:13:40 _hostname_ kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
дек 03 11:13:40 _hostname_ kernel: ACPI: Enabled 16 GPEs in block 00 to 3F
дек 03 11:13:40 _hostname_ kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
дек 03 11:13:40 _hostname_ kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
дек 03 11:13:40 _hostname_ kernel: acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
дек 03 11:13:40 _hostname_ kernel: acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
дек 03 11:13:40 _hostname_ kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
дек 03 11:13:40 _hostname_ kernel: PCI host bridge to bus 0000:00
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff window]
дек 03 11:13:40 _hostname_ kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:14.0: reg 0x10: [mem 0xf7e00000-0xf7e0ffff 64bit]
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:16.0: reg 0x10: [mem 0xf7e1a000-0xf7e1a00f 64bit]
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1a.0: reg 0x10: [mem 0xf7e18000-0xf7e183ff]
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xf7e10000-0xf7e13fff 64bit]
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1c.2: [8086:1e14] type 01 class 0x060400
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1c.3: [8086:1e16] type 01 class 0x060400
дек 03 11:13:40 _hostname_ kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xf7e17000-0xf7e173ff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.0: [8086:1e59] type 00 class 0x060100
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.2: reg 0x10: [io 0xf0b0-0xf0b7]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.2: reg 0x14: [io 0xf0a0-0xf0a3]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.2: reg 0x18: [io 0xf090-0xf097]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.2: reg 0x1c: [io 0xf080-0xf083]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xf7e16000-0xf7e167ff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.2: PME# supported from D3hot
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xf7e15000-0xf7e150ff 64bit]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1c.0: PCI bridge to [bus 01]
дек 03 11:13:41 _hostname_ kernel: pci 0000:02:00.0: [10ec:8723] type 00 class 0x028000
дек 03 11:13:41 _hostname_ kernel: pci 0000:02:00.0: reg 0x10: [io 0xe000-0xe0ff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:02:00.0: reg 0x18: [mem 0xf7d00000-0xf7d03fff 64bit]
дек 03 11:13:41 _hostname_ kernel: pci 0000:02:00.0: supports D1 D2
дек 03 11:13:41 _hostname_ kernel: pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1c.2: PCI bridge to [bus 02]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.0: [10ec:5289] type 00 class 0xff0000
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.0: reg 0x10: [mem 0xf7c00000-0xf7c0ffff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.0: supports D1 D2
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.2: [10ec:8168] type 00 class 0x020000
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.2: reg 0x10: [io 0xd000-0xd0ff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.2: reg 0x18: [mem 0xf0004000-0xf0004fff 64bit pref]
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.2: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.2: supports D1 D2
дек 03 11:13:41 _hostname_ kernel: pci 0000:03:00.2: PME# supported from D0 D1 D2 D3hot D3cold
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1c.3: PCI bridge to [bus 03]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1c.3: bridge window [mem 0xf7c00000-0xf7cfffff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:1c.3: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
дек 03 11:13:41 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
дек 03 11:13:41 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
дек 03 11:13:41 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 10 11 12 14 15)
дек 03 11:13:41 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
дек 03 11:13:41 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
дек 03 11:13:41 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
дек 03 11:13:41 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 10 11 12 14 15)
дек 03 11:13:41 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 *4 5 6 10 11 12 14 15)
дек 03 11:13:41 _hostname_ kernel: ACPI: EC: interrupt unblocked
дек 03 11:13:41 _hostname_ kernel: ACPI: EC: event unblocked
дек 03 11:13:41 _hostname_ kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
дек 03 11:13:41 _hostname_ kernel: ACPI: EC: GPE=0x17
дек 03 11:13:41 _hostname_ kernel: ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC initialization complete
дек 03 11:13:41 _hostname_ kernel: ACPI: \_SB_.PCI0.LPCB.EC__: EC: Used to handle transactions and events
дек 03 11:13:41 _hostname_ kernel: iommu: Default domain type: Translated
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:02.0: vgaarb: bridge control possible
дек 03 11:13:41 _hostname_ kernel: vgaarb: loaded
дек 03 11:13:41 _hostname_ kernel: SCSI subsystem initialized
дек 03 11:13:41 _hostname_ kernel: libata version 3.00 loaded.
дек 03 11:13:41 _hostname_ kernel: ACPI: bus type USB registered
дек 03 11:13:41 _hostname_ kernel: usbcore: registered new interface driver usbfs
дек 03 11:13:41 _hostname_ kernel: usbcore: registered new interface driver hub
дек 03 11:13:41 _hostname_ kernel: usbcore: registered new device driver usb
дек 03 11:13:41 _hostname_ kernel: pps_core: LinuxPPS API ver. 1 registered
дек 03 11:13:41 _hostname_ kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
дек 03 11:13:41 _hostname_ kernel: PTP clock support registered
дек 03 11:13:41 _hostname_ kernel: EDAC MC: Ver: 3.0.0
дек 03 11:13:41 _hostname_ kernel: NetLabel: Initializing
дек 03 11:13:41 _hostname_ kernel: NetLabel: domain hash size = 128
дек 03 11:13:41 _hostname_ kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
дек 03 11:13:41 _hostname_ kernel: NetLabel: unlabeled traffic allowed by default
дек 03 11:13:41 _hostname_ kernel: PCI: Using ACPI for IRQ routing
дек 03 11:13:41 _hostname_ kernel: PCI: pci_cache_line_size set to 64 bytes
дек 03 11:13:41 _hostname_ kernel: e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
дек 03 11:13:41 _hostname_ kernel: e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
дек 03 11:13:41 _hostname_ kernel: e820: reserve RAM buffer [mem 0xd9862000-0xdbffffff]
дек 03 11:13:41 _hostname_ kernel: e820: reserve RAM buffer [mem 0xd9feb000-0xdbffffff]
дек 03 11:13:41 _hostname_ kernel: e820: reserve RAM buffer [mem 0xda6b8000-0xdbffffff]
дек 03 11:13:41 _hostname_ kernel: e820: reserve RAM buffer [mem 0xdadb1000-0xdbffffff]
дек 03 11:13:41 _hostname_ kernel: e820: reserve RAM buffer [mem 0xdb000000-0xdbffffff]
дек 03 11:13:41 _hostname_ kernel: e820: reserve RAM buffer [mem 0x11f600000-0x11fffffff]
дек 03 11:13:41 _hostname_ kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
дек 03 11:13:41 _hostname_ kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
дек 03 11:13:41 _hostname_ kernel: clocksource: Switched to clocksource tsc-early
дек 03 11:13:41 _hostname_ kernel: VFS: Disk quotas dquot_6.6.0
дек 03 11:13:41 _hostname_ kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
дек 03 11:13:41 _hostname_ kernel: pnp: PnP ACPI init
дек 03 11:13:41 _hostname_ kernel: system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
дек 03 11:13:41 _hostname_ kernel: system 00:01: [io 0x0680-0x069f] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:01: [io 0x1000-0x100f] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:01: [io 0xffff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:01: [io 0x0400-0x0453] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:01: [io 0x0458-0x047f] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:01: [io 0x0500-0x057f] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:01: [io 0x164e-0x164f] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:01: [io 0x3322-0x3323] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
дек 03 11:13:41 _hostname_ kernel: pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
дек 03 11:13:41 _hostname_ kernel: system 00:03: [io 0x0454-0x0457] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
дек 03 11:13:41 _hostname_ kernel: pnp 00:04: Plug and Play ACPI device, IDs PNP0303 (active)
дек 03 11:13:41 _hostname_ kernel: pnp 00:05: Plug and Play ACPI device, IDs ETD0403 PNP0f13 (active)
дек 03 11:13:41 _hostname_ kernel: system 00:06: [io 0x04d0-0x04d1] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xfed90000-0xfed93fff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xff000000-0xffffffff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: [mem 0xdfa00000-0xdfa00fff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
дек 03 11:13:41 _hostname_ kernel: system 00:08: [mem 0x20000000-0x201fffff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:08: [mem 0x40004000-0x40004fff] has been reserved
дек 03 11:13:41 _hostname_ kernel: system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
дек 03 11:13:41 _hostname_ kernel: pnp: PnP ACPI: found 9 devices
дек 03 11:13:41 _hostname_ kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
дек 03 11:13:41 _hostname_ kernel: NET: Registered protocol family 2
дек 03 11:13:41 _hostname_ kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
дек 03 11:13:41 _hostname_ kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
дек 03 11:13:41 _hostname_ kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
дек 03 11:13:41 _hostname_ kernel: TCP: Hash tables configured (established 32768 bind 32768)
дек 03 11:13:41 _hostname_ kernel: MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
дек 03 11:13:41 _hostname_ kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
дек 03 11:13:41 _hostname_ kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
дек 03 11:13:41 _hostname_ kernel: NET: Registered protocol family 1
дек 03 11:13:41 _hostname_ kernel: NET: Registered protocol family 44
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff window]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
дек 03 11:13:41 _hostname_ kernel: pci_bus 0000:03: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
дек 03 11:13:41 _hostname_ kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
дек 03 11:13:41 _hostname_ kernel: pci 0000:02:00.0: CLS mismatch (64 != 32), using 64 bytes
дек 03 11:13:41 _hostname_ kernel: Trying to unpack rootfs image as initramfs...
дек 03 11:13:41 _hostname_ kernel: Freeing initrd memory: 13168K
дек 03 11:13:41 _hostname_ kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
дек 03 11:13:41 _hostname_ kernel: software IO TLB: mapped [mem 0xd5862000-0xd9862000] (64MB)
дек 03 11:13:41 _hostname_ kernel: check: Scanning for low memory corruption every 60 seconds
дек 03 11:13:41 _hostname_ kernel: Initialise system trusted keyrings
дек 03 11:13:41 _hostname_ kernel: Key type blacklist registered
дек 03 11:13:41 _hostname_ kernel: workingset: timestamp_bits=41 max_order=20 bucket_order=0
дек 03 11:13:41 _hostname_ kernel: zbud: loaded
дек 03 11:13:41 _hostname_ kernel: Key type asymmetric registered
дек 03 11:13:41 _hostname_ kernel: Asymmetric key parser 'x509' registered
дек 03 11:13:41 _hostname_ kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
дек 03 11:13:41 _hostname_ kernel: io scheduler mq-deadline registered
дек 03 11:13:41 _hostname_ kernel: io scheduler kyber registered
дек 03 11:13:41 _hostname_ kernel: io scheduler bfq registered
дек 03 11:13:41 _hostname_ kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
дек 03 11:13:41 _hostname_ kernel: vesafb: mode is 1366x768x32, linelength=5504, pages=0
дек 03 11:13:41 _hostname_ kernel: vesafb: scrolling: redraw
дек 03 11:13:41 _hostname_ kernel: vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
дек 03 11:13:41 _hostname_ kernel: vesafb: framebuffer at 0xe0000000, mapped to 0x(____ptrval____), using 4160k, total 4160k
дек 03 11:13:41 _hostname_ kernel: fbcon: Deferring console take-over
дек 03 11:13:41 _hostname_ kernel: fb0: VESA VGA frame buffer device
дек 03 11:13:41 _hostname_ kernel: intel_idle: MWAIT substates: 0x21120
дек 03 11:13:41 _hostname_ kernel: intel_idle: v0.5.1 model 0x3A
дек 03 11:13:41 _hostname_ kernel: intel_idle: Local APIC timer is reliable in all C-states
дек 03 11:13:41 _hostname_ kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
дек 03 11:13:41 _hostname_ kernel: ACPI: Power Button [PWRB]
дек 03 11:13:41 _hostname_ kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
дек 03 11:13:41 _hostname_ kernel: ACPI: Sleep Button [SLPB]
дек 03 11:13:41 _hostname_ kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
дек 03 11:13:41 _hostname_ kernel: ACPI: Lid Switch [LID0]
дек 03 11:13:41 _hostname_ kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
дек 03 11:13:41 _hostname_ kernel: ACPI: Power Button [PWRF]
дек 03 11:13:41 _hostname_ kernel: thermal LNXTHERM:00: registered as thermal_zone0
дек 03 11:13:41 _hostname_ kernel: ACPI: Thermal Zone [TZ0] (53 C)
дек 03 11:13:41 _hostname_ kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
дек 03 11:13:41 _hostname_ kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
дек 03 11:13:41 _hostname_ kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system
дек 03 11:13:41 _hostname_ kernel: ahci 0000:00:1f.2: version 3.0
дек 03 11:13:41 _hostname_ kernel: ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
дек 03 11:13:41 _hostname_ kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x15 impl SATA mode
дек 03 11:13:41 _hostname_ kernel: ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ems sxs apst
дек 03 11:13:41 _hostname_ kernel: scsi host0: ahci
дек 03 11:13:41 _hostname_ kernel: scsi host1: ahci
дек 03 11:13:41 _hostname_ kernel: scsi host2: ahci
дек 03 11:13:41 _hostname_ kernel: scsi host3: ahci
дек 03 11:13:41 _hostname_ kernel: scsi host4: ahci
дек 03 11:13:41 _hostname_ kernel: scsi host5: ahci
дек 03 11:13:41 _hostname_ kernel: ata1: SATA max UDMA/133 abar m2048@0xf7e16000 port 0xf7e16100 irq 27
дек 03 11:13:41 _hostname_ kernel: ata2: DUMMY
дек 03 11:13:41 _hostname_ kernel: ata3: SATA max UDMA/133 abar m2048@0xf7e16000 port 0xf7e16200 irq 27
дек 03 11:13:41 _hostname_ kernel: ata4: DUMMY
дек 03 11:13:41 _hostname_ kernel: ata5: SATA max UDMA/133 abar m2048@0xf7e16000 port 0xf7e16300 irq 27
дек 03 11:13:41 _hostname_ kernel: ata6: DUMMY
дек 03 11:13:41 _hostname_ kernel: usbcore: registered new interface driver usbserial_generic
дек 03 11:13:41 _hostname_ kernel: usbserial: USB Serial support registered for generic
дек 03 11:13:41 _hostname_ kernel: rtc_cmos 00:02: registered as rtc0
дек 03 11:13:41 _hostname_ kernel: rtc_cmos 00:02: setting system clock to 2020-12-03T08:13:38 UTC (1606983218)
дек 03 11:13:41 _hostname_ kernel: rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
дек 03 11:13:41 _hostname_ kernel: intel_pstate: Intel P-state driver initializing
дек 03 11:13:41 _hostname_ kernel: ledtrig-cpu: registered to indicate activity on CPUs
дек 03 11:13:41 _hostname_ kernel: ashmem: initialized
дек 03 11:13:41 _hostname_ kernel: drop_monitor: Initializing network drop monitor service
дек 03 11:13:41 _hostname_ kernel: NET: Registered protocol family 10
дек 03 11:13:41 _hostname_ kernel: Segment Routing with IPv6
дек 03 11:13:41 _hostname_ kernel: RPL Segment Routing with IPv6
дек 03 11:13:41 _hostname_ kernel: NET: Registered protocol family 17
дек 03 11:13:41 _hostname_ kernel: microcode: sig=0x306a9, pf=0x10, revision=0x21
дек 03 11:13:41 _hostname_ kernel: microcode: Microcode Update Driver: v2.2.
дек 03 11:13:41 _hostname_ kernel: IPI shorthand broadcast: enabled
дек 03 11:13:41 _hostname_ kernel: sched_clock: Marking stable (1292743347, 189071)->(1308539432, -15607014)
дек 03 11:13:41 _hostname_ kernel: registered taskstats version 1
дек 03 11:13:41 _hostname_ kernel: Loading compiled-in X.509 certificates
дек 03 11:13:41 _hostname_ kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 00c10b0ba9d05395b3960e2a8b3ae7d67466c42a'
дек 03 11:13:41 _hostname_ kernel: zswap: loaded using pool zstd/z3fold
дек 03 11:13:41 _hostname_ kernel: Key type ._fscrypt registered
дек 03 11:13:41 _hostname_ kernel: Key type .fscrypt registered
дек 03 11:13:41 _hostname_ kernel: Key type fscrypt-provisioning registered
дек 03 11:13:41 _hostname_ kernel: PM: Magic number: 0:277:219
дек 03 11:13:41 _hostname_ kernel: acpi device:3d: hash matches
дек 03 11:13:41 _hostname_ kernel: RAS: Correctable Errors collector initialized.
дек 03 11:13:41 _hostname_ kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
дек 03 11:13:41 _hostname_ kernel: ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
дек 03 11:13:41 _hostname_ kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
дек 03 11:13:41 _hostname_ kernel: ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
дек 03 11:13:41 _hostname_ kernel: ata1.00: ATA-11: SATA SSD, SBFM61.3, max UDMA/133
дек 03 11:13:41 _hostname_ kernel: ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 32), AA
дек 03 11:13:41 _hostname_ kernel: ata1.00: configured for UDMA/133
дек 03 11:13:41 _hostname_ kernel: scsi 0:0:0:0: Direct-Access ATA SATA SSD 61.3 PQ: 0 ANSI: 5
дек 03 11:13:41 _hostname_ kernel: sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
дек 03 11:13:41 _hostname_ kernel: sd 0:0:0:0: [sda] Write Protect is off
дек 03 11:13:41 _hostname_ kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
дек 03 11:13:41 _hostname_ kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
дек 03 11:13:41 _hostname_ kernel: sda: sda1 sda2
дек 03 11:13:41 _hostname_ kernel: sd 0:0:0:0: [sda] Attached SCSI disk
дек 03 11:13:41 _hostname_ kernel: ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
дек 03 11:13:41 _hostname_ kernel: ata3.00: ATAPI: Slimtype DVD A DS8A9SH, EC61, max UDMA/100
дек 03 11:13:41 _hostname_ kernel: ata3.00: configured for UDMA/100
дек 03 11:13:41 _hostname_ kernel: scsi 2:0:0:0: CD-ROM Slimtype DVD A DS8A9SH EC61 PQ: 0 ANSI: 5
дек 03 11:13:41 _hostname_ kernel: tsc: Refined TSC clocksource calibration: 2494.333 MHz
дек 03 11:13:41 _hostname_ kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23f45085418, max_idle_ns: 440795285711 ns
дек 03 11:13:41 _hostname_ kernel: ata5: SATA link down (SStatus 0 SControl 300)
дек 03 11:13:41 _hostname_ kernel: Freeing unused decrypted memory: 2040K
дек 03 11:13:41 _hostname_ kernel: Freeing unused kernel image (initmem) memory: 1664K
дек 03 11:13:41 _hostname_ kernel: Write protecting the kernel read-only data: 22528k
дек 03 11:13:41 _hostname_ kernel: Freeing unused kernel image (text/rodata gap) memory: 2044K
дек 03 11:13:41 _hostname_ kernel: Freeing unused kernel image (rodata/data gap) memory: 1384K
дек 03 11:13:41 _hostname_ kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
дек 03 11:13:41 _hostname_ kernel: x86/mm: Checking user space page tables
дек 03 11:13:41 _hostname_ kernel: Run /init as init process
дек 03 11:13:41 _hostname_ kernel: with arguments:
дек 03 11:13:41 _hostname_ kernel: /init
дек 03 11:13:41 _hostname_ kernel: with environment:
дек 03 11:13:41 _hostname_ kernel: HOME=/
дек 03 11:13:41 _hostname_ kernel: TERM=linux
дек 03 11:13:41 _hostname_ kernel: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
дек 03 11:13:41 _hostname_ kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:ELNM] at 0x60,0x64 irq 1,12
дек 03 11:13:41 _hostname_ kernel: i8042: Detected active multiplexing controller, rev 1.1
дек 03 11:13:41 _hostname_ kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
дек 03 11:13:41 _hostname_ kernel: serio: i8042 AUX0 port at 0x60,0x64 irq 12
дек 03 11:13:41 _hostname_ kernel: serio: i8042 AUX1 port at 0x60,0x64 irq 12
дек 03 11:13:41 _hostname_ kernel: serio: i8042 AUX2 port at 0x60,0x64 irq 12
дек 03 11:13:41 _hostname_ kernel: serio: i8042 AUX3 port at 0x60,0x64 irq 12
дек 03 11:13:41 _hostname_ kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
дек 03 11:13:41 _hostname_ kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
дек 03 11:13:41 _hostname_ kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
дек 03 11:13:41 _hostname_ kernel: ehci-pci: EHCI PCI platform driver
дек 03 11:13:41 _hostname_ kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x000000000000b930
дек 03 11:13:41 _hostname_ kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
дек 03 11:13:41 _hostname_ kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
дек 03 11:13:41 _hostname_ kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
дек 03 11:13:41 _hostname_ kernel: usb usb1: Product: xHCI Host Controller
дек 03 11:13:41 _hostname_ kernel: usb usb1: Manufacturer: Linux 5.9.11-3-MANJARO xhci-hcd
дек 03 11:13:41 _hostname_ kernel: usb usb1: SerialNumber: 0000:00:14.0
дек 03 11:13:41 _hostname_ kernel: hub 1-0:1.0: USB hub found
дек 03 11:13:41 _hostname_ kernel: hub 1-0:1.0: 4 ports detected
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1a.0: EHCI Host Controller
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 2
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1a.0: debug port 2
дек 03 11:13:41 _hostname_ kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
дек 03 11:13:41 _hostname_ kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
дек 03 11:13:41 _hostname_ kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
дек 03 11:13:41 _hostname_ kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
дек 03 11:13:41 _hostname_ kernel: usb usb3: Product: xHCI Host Controller
дек 03 11:13:41 _hostname_ kernel: usb usb3: Manufacturer: Linux 5.9.11-3-MANJARO xhci-hcd
дек 03 11:13:41 _hostname_ kernel: usb usb3: SerialNumber: 0000:00:14.0
дек 03 11:13:41 _hostname_ kernel: hub 3-0:1.0: USB hub found
дек 03 11:13:41 _hostname_ kernel: hub 3-0:1.0: 4 ports detected
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7e18000
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
дек 03 11:13:41 _hostname_ kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
дек 03 11:13:41 _hostname_ kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
дек 03 11:13:41 _hostname_ kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
дек 03 11:13:41 _hostname_ kernel: usb usb2: Product: EHCI Host Controller
дек 03 11:13:41 _hostname_ kernel: usb usb2: Manufacturer: Linux 5.9.11-3-MANJARO ehci_hcd
дек 03 11:13:41 _hostname_ kernel: usb usb2: SerialNumber: 0000:00:1a.0
дек 03 11:13:41 _hostname_ kernel: hub 2-0:1.0: USB hub found
дек 03 11:13:41 _hostname_ kernel: hub 2-0:1.0: 2 ports detected
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1d.0: debug port 2
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7e17000
дек 03 11:13:41 _hostname_ kernel: sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
дек 03 11:13:41 _hostname_ kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
дек 03 11:13:41 _hostname_ kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
дек 03 11:13:41 _hostname_ kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
дек 03 11:13:41 _hostname_ kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
дек 03 11:13:41 _hostname_ kernel: usb usb4: Product: EHCI Host Controller
дек 03 11:13:41 _hostname_ kernel: usb usb4: Manufacturer: Linux 5.9.11-3-MANJARO ehci_hcd
дек 03 11:13:41 _hostname_ kernel: usb usb4: SerialNumber: 0000:00:1d.0
дек 03 11:13:41 _hostname_ kernel: hub 4-0:1.0: USB hub found
дек 03 11:13:41 _hostname_ kernel: hub 4-0:1.0: 2 ports detected
дек 03 11:13:41 _hostname_ kernel: sr 2:0:0:0: Attached scsi CD-ROM sr0
дек 03 11:13:41 _hostname_ kernel: usb 1-1: new full-speed USB device number 2 using xhci_hcd
дек 03 11:13:41 _hostname_ kernel: usb 2-1: new high-speed USB device number 2 using ehci-pci
дек 03 11:13:41 _hostname_ kernel: usb 4-1: new high-speed USB device number 2 using ehci-pci
дек 03 11:13:41 _hostname_ kernel: PM: Image not found (code -22)
дек 03 11:13:41 _hostname_ kernel: usb 1-1: New USB device found, idVendor=0c45, idProduct=8073, bcdDevice= 1.31
дек 03 11:13:41 _hostname_ kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
дек 03 11:13:41 _hostname_ kernel: usb 1-1: Product: USB DEVICE
дек 03 11:13:41 _hostname_ kernel: usb 1-1: Manufacturer: SONiX
дек 03 11:13:41 _hostname_ kernel: random: fast init done
дек 03 11:13:41 _hostname_ kernel: hid: raw HID events driver (C) Jiri Kosina
дек 03 11:13:41 _hostname_ kernel: EXT4-fs (sda1): recovery complete
дек 03 11:13:41 _hostname_ kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
дек 03 11:13:41 _hostname_ kernel: usbcore: registered new interface driver usbhid
дек 03 11:13:41 _hostname_ kernel: usbhid: USB HID core driver
дек 03 11:13:41 _hostname_ kernel: input: SONiX USB DEVICE as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:0C45:8073.0001/input/input9
дек 03 11:13:41 _hostname_ kernel: usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
дек 03 11:13:41 _hostname_ kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
дек 03 11:13:41 _hostname_ kernel: hub 2-1:1.0: USB hub found
дек 03 11:13:41 _hostname_ kernel: hub 2-1:1.0: 6 ports detected
дек 03 11:13:41 _hostname_ kernel: usb 4-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
дек 03 11:13:41 _hostname_ kernel: usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
дек 03 11:13:41 _hostname_ kernel: hub 4-1:1.0: USB hub found
дек 03 11:13:41 _hostname_ kernel: hub 4-1:1.0: 6 ports detected
дек 03 11:13:41 _hostname_ kernel: hid-generic 0003:0C45:8073.0001: input,hidraw0: USB HID v1.11 Keyboard [SONiX USB DEVICE] on usb-0000:00:14.0-1/input0
дек 03 11:13:41 _hostname_ kernel: input: SONiX USB DEVICE Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:0C45:8073.0002/input/input10
дек 03 11:13:41 _hostname_ kernel: usb 1-2: new full-speed USB device number 3 using xhci_hcd
дек 03 11:13:41 _hostname_ kernel: input: SONiX USB DEVICE System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:0C45:8073.0002/input/input11
дек 03 11:13:41 _hostname_ kernel: input: SONiX USB DEVICE Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:0C45:8073.0002/input/input12
дек 03 11:13:41 _hostname_ kernel: hid-generic 0003:0C45:8073.0002: input,hidraw1: USB HID v1.11 Keyboard [SONiX USB DEVICE] on usb-0000:00:14.0-1/input1
дек 03 11:13:41 _hostname_ systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
дек 03 11:13:41 _hostname_ systemd[1]: Detected architecture x86-64.
дек 03 11:13:41 _hostname_ systemd[1]: Set hostname to <_hostname_>.
дек 03 11:13:41 _hostname_ kernel: usb 1-2: New USB device found, idVendor=09da, idProduct=3210, bcdDevice=8b.42
дек 03 11:13:41 _hostname_ kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
дек 03 11:13:41 _hostname_ kernel: usb 1-2: Product: USB Device
дек 03 11:13:41 _hostname_ kernel: usb 1-2: Manufacturer: COMPANY
дек 03 11:13:41 _hostname_ kernel: input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:09DA:3210.0003/input/input13
дек 03 11:13:41 _hostname_ kernel: hid-generic 0003:09DA:3210.0003: input,hidraw2: USB HID v1.11 Keyboard [COMPANY USB Device] on usb-0000:00:14.0-2/input0
дек 03 11:13:41 _hostname_ kernel: input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:09DA:3210.0004/input/input14
дек 03 11:13:41 _hostname_ kernel: hid-generic 0003:09DA:3210.0004: input,hidraw3: USB HID v1.11 Mouse [COMPANY USB Device] on usb-0000:00:14.0-2/input1
дек 03 11:13:41 _hostname_ kernel: input: COMPANY USB Device Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:09DA:3210.0005/input/input15
дек 03 11:13:41 _hostname_ systemd[1]: Queued start job for default target Graphical Interface.
дек 03 11:13:41 _hostname_ kernel: random: systemd: uninitialized urandom read (16 bytes read)
дек 03 11:13:41 _hostname_ systemd[1]: Created slice system-getty.slice.
дек 03 11:13:41 _hostname_ systemd[1]: Created slice system-modprobe.slice.
дек 03 11:13:41 _hostname_ systemd[1]: Created slice User and Session Slice.
дек 03 11:13:41 _hostname_ systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
дек 03 11:13:41 _hostname_ systemd[1]: Started Forward Password Requests to Wall Directory Watch.
дек 03 11:13:41 _hostname_ systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
дек 03 11:13:41 _hostname_ systemd[1]: Reached target Local Encrypted Volumes.
дек 03 11:13:41 _hostname_ systemd[1]: Reached target Login Prompts.
дек 03 11:13:41 _hostname_ systemd[1]: Reached target Paths.
дек 03 11:13:41 _hostname_ systemd[1]: Reached target Remote File Systems.
дек 03 11:13:41 _hostname_ systemd[1]: Reached target Slices.
дек 03 11:13:41 _hostname_ systemd[1]: Listening on Device-mapper event daemon FIFOs.
дек 03 11:13:41 _hostname_ systemd[1]: Listening on LVM2 metadata daemon socket.
дек 03 11:13:41 _hostname_ systemd[1]: Listening on LVM2 poll daemon socket.
дек 03 11:13:41 _hostname_ systemd[1]: Listening on Process Core Dump Socket.
дек 03 11:13:41 _hostname_ systemd[1]: Listening on Journal Audit Socket.
дек 03 11:13:41 _hostname_ systemd[1]: Listening on Journal Socket (/dev/log).
дек 03 11:13:41 _hostname_ systemd[1]: Listening on Journal Socket.
дек 03 11:13:41 _hostname_ systemd[1]: Listening on udev Control Socket.
дек 03 11:13:41 _hostname_ systemd[1]: Listening on udev Kernel Socket.
дек 03 11:13:41 _hostname_ systemd[1]: Mounting Huge Pages File System...
дек 03 11:13:41 _hostname_ systemd[1]: Mounting POSIX Message Queue File System...
дек 03 11:13:41 _hostname_ systemd[1]: Mounting Kernel Debug File System...
дек 03 11:13:41 _hostname_ systemd[1]: Mounting Kernel Trace File System...
дек 03 11:13:41 _hostname_ systemd[1]: Starting Create list of static device nodes for the current kernel...
дек 03 11:13:41 _hostname_ systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
дек 03 11:13:41 _hostname_ systemd[1]: Starting Load Kernel Module drm...
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Starting Journal Service...
дек 03 11:13:41 _hostname_ systemd[1]: Starting Load Kernel Modules...
дек 03 11:13:41 _hostname_ systemd[1]: Starting Remount Root and Kernel File Systems...
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
дек 03 11:13:41 _hostname_ kernel: Linux agpgart interface v0.103
дек 03 11:13:41 _hostname_ systemd[1]: Starting Coldplug All udev Devices...
дек 03 11:13:41 _hostname_ kernel: input: COMPANY USB Device System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:09DA:3210.0005/input/input16
дек 03 11:13:41 _hostname_ kernel: input: COMPANY USB Device Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:09DA:3210.0005/input/input17
дек 03 11:13:41 _hostname_ kernel: input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:09DA:3210.0005/input/input18
дек 03 11:13:41 _hostname_ kernel: hid-generic 0003:09DA:3210.0005: input,hiddev0,hidraw4: USB HID v1.11 Keyboard [COMPANY USB Device] on usb-0000:00:14.0-2/input2
дек 03 11:13:41 _hostname_ systemd[1]: Mounted Huge Pages File System.
дек 03 11:13:41 _hostname_ systemd[1]: Mounted POSIX Message Queue File System.
дек 03 11:13:41 _hostname_ systemd[1]: Mounted Kernel Debug File System.
дек 03 11:13:41 _hostname_ systemd[1]: Mounted Kernel Trace File System.
дек 03 11:13:41 _hostname_ systemd[1]: Finished Create list of static device nodes for the current kernel.
дек 03 11:13:41 _hostname_ kernel: EXT4-fs (sda1): re-mounted. Opts: (null)
дек 03 11:13:41 _hostname_ systemd[1]: Finished Remount Root and Kernel File Systems.
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in First Boot Wizard being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Starting Load/Save Random Seed...
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in Create System Users being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Starting Create Static Device Nodes in /dev...
дек 03 11:13:41 _hostname_ systemd[1]: Finished Load Kernel Modules.
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in FUSE Control File System being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Mounting Kernel Configuration File System...
дек 03 11:13:41 _hostname_ systemd[1]: Starting Apply Kernel Variables...
дек 03 11:13:41 _hostname_ systemd[1]: Mounted Kernel Configuration File System.
дек 03 11:13:41 _hostname_ systemd[1]: Finished Create Static Device Nodes in /dev.
дек 03 11:13:41 _hostname_ systemd[1]: Starting Rule-based Manager for Device Events and Files...
дек 03 11:13:41 _hostname_ systemd[1]: Finished Apply Kernel Variables.
дек 03 11:13:41 _hostname_ systemd[1]: modprobe@drm.service: Succeeded.
дек 03 11:13:41 _hostname_ systemd[1]: Finished Load Kernel Module drm.
дек 03 11:13:41 _hostname_ kernel: usb 1-3: new full-speed USB device number 4 using xhci_hcd
дек 03 11:13:41 _hostname_ systemd[1]: Finished Coldplug All udev Devices.
дек 03 11:13:41 _hostname_ kernel: usb 1-3: New USB device found, idVendor=0bda, idProduct=8723, bcdDevice= 2.00
дек 03 11:13:41 _hostname_ kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
дек 03 11:13:41 _hostname_ kernel: usb 1-3: Product: RT Bluetooth Radio
дек 03 11:13:41 _hostname_ kernel: usb 1-3: Manufacturer: Realtek
дек 03 11:13:41 _hostname_ kernel: usb 1-3: SerialNumber: 00e04c000001
дек 03 11:13:41 _hostname_ systemd-journald[228]: Journal started
дек 03 11:13:41 _hostname_ systemd-journald[228]: Runtime Journal (/run/log/journal/38fad117791748f7982ad1133140b439) is 8.0M, max 191.3M, 183.3M free.
дек 03 11:13:41 _hostname_ systemd-modules-load[229]: Inserted module 'crypto_user'
дек 03 11:13:41 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ systemd-random-seed[233]: Kernel entropy pool is not initialized yet, waiting until it is.
дек 03 11:13:41 _hostname_ systemd-sysctl[236]: Not setting net/ipv4/conf/all/rp_filter (explicit setting exists).
дек 03 11:13:41 _hostname_ systemd-sysctl[236]: Not setting net/ipv4/conf/default/rp_filter (explicit setting exists).
дек 03 11:13:41 _hostname_ systemd-sysctl[236]: Not setting net/ipv4/conf/all/accept_source_route (explicit setting exists).
дек 03 11:13:41 _hostname_ systemd-sysctl[236]: Not setting net/ipv4/conf/default/accept_source_route (explicit setting exists).
дек 03 11:13:41 _hostname_ systemd-sysctl[236]: Not setting net/ipv4/conf/all/promote_secondaries (explicit setting exists).
дек 03 11:13:41 _hostname_ systemd-sysctl[236]: Not setting net/ipv4/conf/default/promote_secondaries (explicit setting exists).
дек 03 11:13:41 _hostname_ systemd[1]: Started Journal Service.
дек 03 11:13:41 _hostname_ kernel: audit: type=1130 audit(1606983221.034:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ systemd[1]: Starting Flush Journal to Persistent Storage...
дек 03 11:13:41 _hostname_ systemd-journald[228]: Time spent on flushing to /var/log/journal/38fad117791748f7982ad1133140b439 is 9.202ms for 793 entries.
дек 03 11:13:41 _hostname_ systemd-journald[228]: System Journal (/var/log/journal/38fad117791748f7982ad1133140b439) is 312.1M, max 4.0G, 3.6G free.
дек 03 11:13:41 _hostname_ kernel: usb 1-4: new high-speed USB device number 5 using xhci_hcd
дек 03 11:13:41 _hostname_ systemd[1]: Finished Flush Journal to Persistent Storage.
дек 03 11:13:41 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ systemd[1]: Started Rule-based Manager for Device Events and Files.
дек 03 11:13:41 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ systemd[1]: Started LVM2 metadata daemon.
дек 03 11:13:41 _hostname_ kernel: audit: type=1130 audit(1606983221.117:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ kernel: audit: type=1130 audit(1606983221.117:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ kernel: audit: type=1130 audit(1606983221.117:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ kernel: ACPI: AC Adapter [AC] (on-line)
дек 03 11:13:41 _hostname_ kernel: usb 1-4: New USB device found, idVendor=5986, idProduct=0401, bcdDevice= 6.06
дек 03 11:13:41 _hostname_ kernel: usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
дек 03 11:13:41 _hostname_ kernel: usb 1-4: Product: BisonCam, NB Pro
дек 03 11:13:41 _hostname_ kernel: usb 1-4: Manufacturer: Bison
дек 03 11:13:41 _hostname_ mtp-probe[268]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2"
дек 03 11:13:41 _hostname_ mtp-probe[268]: bus: 1, device: 3 was not an MTP device
дек 03 11:13:41 _hostname_ kernel: battery: ACPI: Battery Slot [BAT0] (battery absent)
дек 03 11:13:41 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200717/utaddress-204)
дек 03 11:13:41 _hostname_ kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
дек 03 11:13:41 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200717/utaddress-204)
дек 03 11:13:41 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200717/utaddress-204)
дек 03 11:13:41 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200717/utaddress-204)
дек 03 11:13:41 _hostname_ kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
дек 03 11:13:41 _hostname_ kernel: libphy: Fixed MDIO Bus: probed
дек 03 11:13:41 _hostname_ systemd[1]: Found device SATA_SSD 2.
дек 03 11:13:41 _hostname_ systemd[1]: Activating swap /dev/disk/by-uuid/1c035312-8349-4225-9744-79fff163f918...
дек 03 11:13:41 _hostname_ kernel: Adding 8621268k swap on /dev/sda2. Priority:-2 extents:1 across:8621268k SSFS
дек 03 11:13:41 _hostname_ systemd[1]: Activated swap /dev/disk/by-uuid/1c035312-8349-4225-9744-79fff163f918.
дек 03 11:13:41 _hostname_ systemd[1]: Reached target Swap.
дек 03 11:13:41 _hostname_ kernel: input: PC Speaker as /devices/platform/pcspkr/input/input20
дек 03 11:13:41 _hostname_ systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
дек 03 11:13:41 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ systemd[1]: Reached target Local File Systems (Pre).
дек 03 11:13:41 _hostname_ kernel: audit: type=1130 audit(1606983221.494:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ systemd[1]: Mounting /tmp...
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Mounted /tmp.
дек 03 11:13:41 _hostname_ systemd[1]: Reached target Local File Systems.
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Starting Create Volatile Files and Directories...
дек 03 11:13:41 _hostname_ systemd[1]: Finished Create Volatile Files and Directories.
дек 03 11:13:41 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ kernel: audit: type=1130 audit(1606983221.540:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Starting Network Time Synchronization...
дек 03 11:13:41 _hostname_ systemd[1]: Condition check resulted in Update is Completed being skipped.
дек 03 11:13:41 _hostname_ systemd[1]: Starting Update UTMP about System Boot/Shutdown...
дек 03 11:13:41 _hostname_ audit[297]: SYSTEM_BOOT pid=297 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ kernel: audit: type=1127 audit(1606983221.557:8): pid=297 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ kernel: i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
дек 03 11:13:41 _hostname_ kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
дек 03 11:13:41 _hostname_ kernel: i2c i2c-0: 1/2 memory slots populated (from DMI)
дек 03 11:13:41 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ systemd[1]: Finished Update UTMP about System Boot/Shutdown.
дек 03 11:13:41 _hostname_ kernel: audit: type=1130 audit(1606983221.567:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:41 _hostname_ kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
дек 03 11:13:41 _hostname_ kernel: r8169 0000:03:00.2: can't disable ASPM; OS doesn't have ASPM control
дек 03 11:13:41 _hostname_ kernel: libphy: r8169: probed
дек 03 11:13:41 _hostname_ kernel: r8169 0000:03:00.2 eth0: RTL8411, 00:90:f5:e8:26:64, XID 488, IRQ 31
дек 03 11:13:41 _hostname_ kernel: r8169 0000:03:00.2 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
дек 03 11:13:41 _hostname_ systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
дек 03 11:13:41 _hostname_ kernel: RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
дек 03 11:13:41 _hostname_ kernel: RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
дек 03 11:13:41 _hostname_ kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
дек 03 11:13:41 _hostname_ kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
дек 03 11:13:42 _hostname_ kernel: r8169 0000:03:00.2 enp3s0f2: renamed from eth0
дек 03 11:13:42 _hostname_ kernel: iTCO_vendor_support: vendor-support=0
дек 03 11:13:42 _hostname_ kernel: cryptd: max_cpu_qlen set to 1000
дек 03 11:13:42 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ systemd[1]: Started Network Time Synchronization.
дек 03 11:13:42 _hostname_ kernel: audit: type=1130 audit(1606983222.344:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ systemd[1]: Reached target System Initialization.
дек 03 11:13:42 _hostname_ systemd[1]: Started Daily Cleanup of Temporary Directories.
дек 03 11:13:42 _hostname_ systemd[1]: Reached target System Time Set.
дек 03 11:13:42 _hostname_ systemd[1]: Reached target System Time Synchronized.
дек 03 11:13:42 _hostname_ systemd[1]: Started Daily rotation of log files.
дек 03 11:13:42 _hostname_ systemd[1]: Started Daily man-db regeneration.
дек 03 11:13:42 _hostname_ systemd[1]: Started Monthly clean packages cache.
дек 03 11:13:42 _hostname_ systemd[1]: Started Generate mirrorlist weekly.
дек 03 11:13:42 _hostname_ systemd[1]: Started pkgfile database update timer.
дек 03 11:13:42 _hostname_ systemd[1]: Started Daily verification of password and group files.
дек 03 11:13:42 _hostname_ systemd[1]: Reached target Timers.
дек 03 11:13:42 _hostname_ systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
дек 03 11:13:42 _hostname_ systemd[1]: Listening on D-Bus System Message Bus Socket.
дек 03 11:13:42 _hostname_ systemd[1]: Reached target Sockets.
дек 03 11:13:42 _hostname_ systemd[1]: Reached target Basic System.
дек 03 11:13:42 _hostname_ systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
дек 03 11:13:42 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ systemd[1]: Started Periodic Command Scheduler.
дек 03 11:13:42 _hostname_ kernel: audit: type=1130 audit(1606983222.354:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ systemd[1]: Started D-Bus System Message Bus.
дек 03 11:13:42 _hostname_ crond[407]: (CRON) STARTUP (1.5.5)
дек 03 11:13:42 _hostname_ crond[407]: (CRON) INFO (Syslog will be used instead of sendmail.)
дек 03 11:13:42 _hostname_ crond[407]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 0% if used.)
дек 03 11:13:42 _hostname_ systemd[1]: Starting Network Manager...
дек 03 11:13:42 _hostname_ avahi-daemon[406]: Found user 'avahi' (UID 974) and group 'avahi' (GID 974).
дек 03 11:13:42 _hostname_ systemd[1]: Starting Authorization Manager...
дек 03 11:13:42 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ kernel: audit: type=1130 audit(1606983222.364:12): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ crond[407]: (CRON) INFO (running with inotify support)
дек 03 11:13:42 _hostname_ kernel: audit: type=1334 audit(1606983222.437:13): prog-id=7 op=LOAD
дек 03 11:13:42 _hostname_ kernel: audit: type=1334 audit(1606983222.437:14): prog-id=8 op=LOAD
дек 03 11:13:42 _hostname_ audit: BPF prog-id=7 op=LOAD
дек 03 11:13:42 _hostname_ audit: BPF prog-id=8 op=LOAD
дек 03 11:13:42 _hostname_ avahi-daemon[406]: Successfully dropped root privileges.
дек 03 11:13:42 _hostname_ systemd[1]: Starting User Login Management...
дек 03 11:13:42 _hostname_ avahi-daemon[406]: avahi-daemon 0.8 starting up.
дек 03 11:13:42 _hostname_ NetworkManager[409]: <info> [1606983222.5300] NetworkManager (version 1.26.4-1) is starting... (for the first time)
дек 03 11:13:42 _hostname_ NetworkManager[409]: <info> [1606983222.5315] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
дек 03 11:13:42 _hostname_ polkitd[410]: Started polkitd version 0.118
дек 03 11:13:42 _hostname_ kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
дек 03 11:13:42 _hostname_ kernel: iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
дек 03 11:13:42 _hostname_ kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
дек 03 11:13:42 _hostname_ systemd[1]: Started Avahi mDNS/DNS-SD Stack.
дек 03 11:13:42 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ avahi-daemon[406]: Successfully called chroot().
дек 03 11:13:42 _hostname_ avahi-daemon[406]: Successfully dropped remaining capabilities.
дек 03 11:13:42 _hostname_ kernel: audit: type=1130 audit(1606983222.587:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ kernel: audit: type=1130 audit(1606983222.590:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ systemd[1]: Started Network Manager.
дек 03 11:13:42 _hostname_ avahi-daemon[406]: No service file found in /etc/avahi/services.
дек 03 11:13:42 _hostname_ systemd[1]: Reached target Network.
дек 03 11:13:42 _hostname_ avahi-daemon[406]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
дек 03 11:13:42 _hostname_ avahi-daemon[406]: New relevant interface lo.IPv6 for mDNS.
дек 03 11:13:42 _hostname_ avahi-daemon[406]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
дек 03 11:13:42 _hostname_ avahi-daemon[406]: New relevant interface lo.IPv4 for mDNS.
дек 03 11:13:42 _hostname_ avahi-daemon[406]: Network interface enumeration completed.
дек 03 11:13:42 _hostname_ avahi-daemon[406]: Registering new address record for ::1 on lo.*.
дек 03 11:13:42 _hostname_ avahi-daemon[406]: Registering new address record for 127.0.0.1 on lo.IPv4.
дек 03 11:13:42 _hostname_ systemd[1]: Starting Permit User Sessions...
дек 03 11:13:42 _hostname_ NetworkManager[409]: <info> [1606983222.5979] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
дек 03 11:13:42 _hostname_ NetworkManager[409]: <info> [1606983222.6073] manager[0x5625758db0c0]: monitoring kernel firmware directory '/lib/firmware'.
дек 03 11:13:42 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=409 comm="/usr/bin/NetworkManager --no-daemon ")
дек 03 11:13:42 _hostname_ systemd[1]: Finished Permit User Sessions.
дек 03 11:13:42 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ audit: BPF prog-id=9 op=LOAD
дек 03 11:13:42 _hostname_ audit: BPF prog-id=10 op=LOAD
дек 03 11:13:42 _hostname_ kernel: audit: type=1130 audit(1606983222.607:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ kernel: audit: type=1334 audit(1606983222.610:18): prog-id=9 op=LOAD
дек 03 11:13:42 _hostname_ kernel: audit: type=1334 audit(1606983222.610:19): prog-id=10 op=LOAD
дек 03 11:13:42 _hostname_ systemd[1]: Starting Hostname Service...
дек 03 11:13:42 _hostname_ kernel: psmouse serio2: synaptics: queried max coordinates: x [..5692], y [..4680]
дек 03 11:13:42 _hostname_ polkitd[410]: Loading rules from directory /etc/polkit-1/rules.d
дек 03 11:13:42 _hostname_ polkitd[410]: Loading rules from directory /usr/share/polkit-1/rules.d
дек 03 11:13:42 _hostname_ polkitd[410]: Finished loading, compiling and executing 4 rules
дек 03 11:13:42 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ systemd[1]: Started Authorization Manager.
дек 03 11:13:42 _hostname_ systemd[1]: Starting Modem Manager...
дек 03 11:13:42 _hostname_ polkitd[410]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
дек 03 11:13:42 _hostname_ ModemManager[448]: <info> ModemManager (version 1.14.8) starting in system bus...
дек 03 11:13:42 _hostname_ kernel: psmouse serio2: synaptics: Touchpad model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04731/0xa40000/0xa0000/0x0, board id: 0, fw id: 582762
дек 03 11:13:42 _hostname_ systemd[1]: Started Modem Manager.
дек 03 11:13:42 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ kernel: input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input21
дек 03 11:13:42 _hostname_ mtp-probe[466]: checking bus 1, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
дек 03 11:13:42 _hostname_ kernel: random: crng init done
дек 03 11:13:42 _hostname_ kernel: random: 7 urandom warning(s) missed due to ratelimiting
дек 03 11:13:42 _hostname_ mtp-probe[466]: bus: 1, device: 2 was not an MTP device
дек 03 11:13:42 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:42 _hostname_ systemd[1]: Finished Load/Save Random Seed.
дек 03 11:13:42 _hostname_ systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
дек 03 11:13:42 _hostname_ mtp-probe[468]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2"
дек 03 11:13:42 _hostname_ mtp-probe[467]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4"
дек 03 11:13:42 _hostname_ mtp-probe[467]: bus: 1, device: 5 was not an MTP device
дек 03 11:13:42 _hostname_ mtp-probe[468]: bus: 1, device: 3 was not an MTP device
дек 03 11:13:43 _hostname_ kernel: mousedev: PS/2 mouse device common for all mice
дек 03 11:13:43 _hostname_ kernel: checking generic (e0000000 410000) vs hw (f7800000 400000)
дек 03 11:13:43 _hostname_ kernel: checking generic (e0000000 410000) vs hw (e0000000 10000000)
дек 03 11:13:43 _hostname_ kernel: fb0: switching to inteldrmfb from VESA VGA
дек 03 11:13:43 _hostname_ kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
дек 03 11:13:43 _hostname_ kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
дек 03 11:13:43 _hostname_ kernel: rtl8723ae: Using firmware rtlwifi/rtl8723fw_B.bin
дек 03 11:13:43 _hostname_ kernel: ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
дек 03 11:13:43 _hostname_ systemd[1]: Starting Load/Save RF Kill Switch Status...
дек 03 11:13:43 _hostname_ kernel: rtlwifi: rtlwifi: wireless switch is on
дек 03 11:13:43 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:43 _hostname_ systemd[1]: Started Load/Save RF Kill Switch Status.
дек 03 11:13:43 _hostname_ kernel: rtl8723ae 0000:02:00.0 wlp2s0: renamed from wlan0
дек 03 11:13:43 _hostname_ kernel: [drm] Initialized i915 1.6.0 20200715 for 0000:00:02.0 on minor 0
дек 03 11:13:43 _hostname_ kernel: ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
дек 03 11:13:43 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event3 (Power Button)
дек 03 11:13:43 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event0 (Power Button)
дек 03 11:13:43 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event2 (Lid Switch)
дек 03 11:13:43 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event1 (Sleep Button)
дек 03 11:13:43 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event4 (AT Translated Set 2 keyboard)
дек 03 11:13:43 _hostname_ systemd-logind[412]: New seat seat0.
дек 03 11:13:43 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:43 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:43 _hostname_ systemd[1]: Started User Login Management.
дек 03 11:13:43 _hostname_ systemd[1]: Reached target Multi-User System.
дек 03 11:13:43 _hostname_ systemd[1]: Started Simple Desktop Display Manager.
дек 03 11:13:43 _hostname_ systemd[1]: Reached target Graphical Interface.
дек 03 11:13:43 _hostname_ systemd[1]: Starting TLP system startup/shutdown...
дек 03 11:13:43 _hostname_ kernel: acpi device:3f: registered as cooling_device4
дек 03 11:13:43 _hostname_ kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input24
дек 03 11:13:43 _hostname_ kernel: snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
дек 03 11:13:43 _hostname_ sddm[512]: Initializing...
дек 03 11:13:43 _hostname_ dbus-daemon[408]: [system] Successfully activated service 'org.freedesktop.hostname1'
дек 03 11:13:43 _hostname_ systemd[1]: Started Hostname Service.
дек 03 11:13:43 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.2868] hostname: hostname: using hostnamed
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.2868] hostname: hostname changed from (none) to "_hostname_"
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.2877] dns-mgr[0x562575894220]: init: dns=default,systemd-resolved rc-manager=symlink
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.2888] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0/ieee80211/phy0/rfkill0) (driver rtl8723ae)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.2898] manager[0x5625758db0c0]: rfkill: Wi-Fi hardware radio set enabled
дек 03 11:13:43 _hostname_ sddm[512]: Starting...
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.2898] manager[0x5625758db0c0]: rfkill: WWAN hardware radio set enabled
дек 03 11:13:43 _hostname_ sddm[512]: Logind interface found
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3074] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-wwan.so)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3091] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-wifi.so)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3114] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-ovs.so)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3143] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-bluetooth.so)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3291] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-team.so)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3301] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-adsl.so)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3316] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3323] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3327] manager: Networking is enabled by state file
дек 03 11:13:43 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=409 comm="/usr/bin/NetworkManager --no-daemon ")
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3348] dhcp-init: Using DHCP client 'internal'
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3354] settings: Loaded settings plugin: keyfile (internal)
дек 03 11:13:43 _hostname_ systemd[1]: Starting Network Manager Script Dispatcher Service...
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3434] device (lo): carrier: link connected
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3440] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3473] manager: (enp3s0f2): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3531] settings: (enp3s0f2): created default wired connection 'Wired connection 1'
дек 03 11:13:43 _hostname_ dbus-daemon[408]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
дек 03 11:13:43 _hostname_ systemd[1]: Started Network Manager Script Dispatcher Service.
дек 03 11:13:43 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.3549] device (enp3s0f2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
дек 03 11:13:43 _hostname_ kernel: RTL8211E Gigabit Ethernet r8169-302:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-302:00, irq=IGNORE)
дек 03 11:13:43 _hostname_ kernel: fbcon: i915drmfb (fb0) is primary device
дек 03 11:13:43 _hostname_ kernel: fbcon: Deferring console take-over
дек 03 11:13:43 _hostname_ kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
дек 03 11:13:43 _hostname_ sddm[512]: Adding new display on vt 1 ...
дек 03 11:13:43 _hostname_ sddm[512]: Loading theme configuration from ""
дек 03 11:13:43 _hostname_ sddm[512]: Display server starting...
дек 03 11:13:43 _hostname_ sddm[512]: Adding cookie to "/var/run/sddm/{b3da80f4-a44c-4dce-8782-e1a143ce9c7c}"
дек 03 11:13:43 _hostname_ systemd[1]: Created slice system-systemd\x2dbacklight.slice.
дек 03 11:13:43 _hostname_ systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
дек 03 11:13:43 _hostname_ sddm[512]: Running: /usr/bin/X -nolisten tcp -auth /var/run/sddm/{b3da80f4-a44c-4dce-8782-e1a143ce9c7c} -background none -noreset -displayfd 17 -seat seat0 vt1
part 2/2
journalctl -b -0 (normal boot?)
дек 03 11:13:43 _hostname_ systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:acpi_video0.
дек 03 11:13:43 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:43 _hostname_ avahi-daemon[406]: Server startup complete. Host name is _hostname_.local. Local service cookie is 3384889412.
дек 03 11:13:43 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: autoconfig for VT1802: line_outs=1 (0x24/0x0/0x0/0x0/0x0) type:speaker
дек 03 11:13:43 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
дек 03 11:13:43 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: hp_outs=1 (0x25/0x0/0x0/0x0/0x0)
дек 03 11:13:43 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: mono: mono_out=0x0
дек 03 11:13:43 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: inputs:
дек 03 11:13:43 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: Mic=0x2b
дек 03 11:13:43 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: Internal Mic=0x29
дек 03 11:13:43 _hostname_ kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input25
дек 03 11:13:43 _hostname_ kernel: input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input26
дек 03 11:13:43 _hostname_ kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input27
дек 03 11:13:43 _hostname_ kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input28
дек 03 11:13:43 _hostname_ systemd[1]: Condition check resulted in Save/Restore Sound Card State being skipped.
дек 03 11:13:43 _hostname_ systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
дек 03 11:13:43 _hostname_ systemd[1]: Reached target Sound Card.
дек 03 11:13:43 _hostname_ kernel: intel_rapl_common: Found RAPL domain package
дек 03 11:13:43 _hostname_ kernel: intel_rapl_common: Found RAPL domain core
дек 03 11:13:43 _hostname_ kernel: intel_rapl_common: Found RAPL domain uncore
дек 03 11:13:43 _hostname_ kernel: intel_rapl_common: RAPL package-0 domain package locked by BIOS
дек 03 11:13:43 _hostname_ kernel: r8169 0000:03:00.2 enp3s0f2: Link is Down
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.5810] device (wlp2s0): driver supports Access Point (AP) mode
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.5817] manager: (wlp2s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.5883] ovsdb: Could not connect: No such file or directory
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.5906] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
дек 03 11:13:43 _hostname_ kernel: Bluetooth: Core ver 2.22
дек 03 11:13:43 _hostname_ kernel: NET: Registered protocol family 31
дек 03 11:13:43 _hostname_ kernel: Bluetooth: HCI device and connection manager initialized
дек 03 11:13:43 _hostname_ kernel: Bluetooth: HCI socket layer initialized
дек 03 11:13:43 _hostname_ kernel: Bluetooth: L2CAP socket layer initialized
дек 03 11:13:43 _hostname_ kernel: Bluetooth: SCO socket layer initialized
дек 03 11:13:43 _hostname_ kernel: mc: Linux media interface: v0.10
дек 03 11:13:43 _hostname_ kernel: videodev: Linux video capture interface: v2.00
дек 03 11:13:43 _hostname_ NetworkManager[409]: <info> [1606983223.9830] device (wlp2s0): set-hw-addr: set MAC address to 2E:A1:8B:F6:10:DC (scanning)
дек 03 11:13:44 _hostname_ kernel: usbcore: registered new interface driver btusb
дек 03 11:13:44 _hostname_ kernel: Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=1200
дек 03 11:13:44 _hostname_ kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8723a_fw.bin
дек 03 11:13:44 _hostname_ tlp[513]: Applying power save settings...done.
дек 03 11:13:44 _hostname_ kernel: uvcvideo: Found UVC 1.00 device BisonCam, NB Pro (5986:0401)
дек 03 11:13:44 _hostname_ tlp[513]: Setting battery charge thresholds...done.
дек 03 11:13:44 _hostname_ systemd[1]: Starting Bluetooth service...
дек 03 11:13:44 _hostname_ systemd[1]: Finished TLP system startup/shutdown.
дек 03 11:13:44 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:44 _hostname_ bluetoothd[801]: Bluetooth daemon 5.55
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanType” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanInterval” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanWindow” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanType” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanInterval” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanWindow” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRLinkSupervisionTimeout” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRPageTimeout” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRMinSniffInterval” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “BRMaxSniffInterval” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEMinAdvertisementInterval” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEMaxAdvertisementInterval” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEMultiAdvertisementRotationInterval” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAutoConnect” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAutoConnect” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalSuspend” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowSuspend” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalDiscovery” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowDiscovery” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAdvMonitor” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAdvMonitor” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
дек 03 11:13:44 _hostname_ bluetoothd[801]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
дек 03 11:13:44 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:44 _hostname_ systemd[1]: Started Bluetooth service.
дек 03 11:13:44 _hostname_ systemd[1]: Reached target Bluetooth.
дек 03 11:13:44 _hostname_ systemd[1]: Startup finished in 3.190s (kernel) + 3.705s (userspace) = 6.895s.
дек 03 11:13:44 _hostname_ bluetoothd[801]: Starting SDP server
дек 03 11:13:44 _hostname_ kernel: input: BisonCam, NB Pro: BisonCam, NB as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/input/input29
дек 03 11:13:44 _hostname_ kernel: usbcore: registered new interface driver uvcvideo
дек 03 11:13:44 _hostname_ kernel: USB Video Class driver (1.1.1)
дек 03 11:13:44 _hostname_ kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
дек 03 11:13:44 _hostname_ kernel: Bluetooth: BNEP filters: protocol multicast
дек 03 11:13:44 _hostname_ kernel: Bluetooth: BNEP socket layer initialized
дек 03 11:13:44 _hostname_ bluetoothd[801]: Bluetooth management interface 1.18 initialized
дек 03 11:13:44 _hostname_ mtp-probe[809]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4"
дек 03 11:13:44 _hostname_ mtp-probe[809]: bus: 1, device: 5 was not an MTP device
дек 03 11:13:44 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event6 (SONiX USB DEVICE Consumer Control)
дек 03 11:13:44 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event12 (COMPANY USB Device System Control)
дек 03 11:13:44 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event11 (COMPANY USB Device Keyboard)
дек 03 11:13:44 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event9 (COMPANY USB Device)
дек 03 11:13:44 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event13 (COMPANY USB Device Consumer Control)
дек 03 11:13:44 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event8 (SONiX USB DEVICE Keyboard)
дек 03 11:13:44 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event7 (SONiX USB DEVICE System Control)
дек 03 11:13:44 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.5' (uid=0 pid=409 comm="/usr/bin/NetworkManager --no-daemon ")
дек 03 11:13:44 _hostname_ NetworkManager[409]: <info> [1606983224.4060] modem-manager: ModemManager available
дек 03 11:13:44 _hostname_ systemd[1]: Starting WPA supplicant...
дек 03 11:13:44 _hostname_ dbus-daemon[408]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
дек 03 11:13:44 _hostname_ wpa_supplicant[823]: Successfully initialized wpa_supplicant
дек 03 11:13:44 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:44 _hostname_ systemd[1]: Started WPA supplicant.
дек 03 11:13:44 _hostname_ NetworkManager[409]: <info> [1606983224.5131] device (wlp2s0): supplicant interface state: internal-starting -> disconnected
дек 03 11:13:44 _hostname_ NetworkManager[409]: <info> [1606983224.5134] Wi-Fi P2P device controlled by interface wlp2s0 created
дек 03 11:13:44 _hostname_ NetworkManager[409]: <info> [1606983224.5140] manager: (p2p-dev-wlp2s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
дек 03 11:13:44 _hostname_ NetworkManager[409]: <info> [1606983224.5145] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
дек 03 11:13:44 _hostname_ NetworkManager[409]: <warn> [1606983224.5154] sup-iface[7cf93e5dcd1415cb,0,wlp2s0]: call-p2p-cancel: failed with P2P cancel failed
дек 03 11:13:44 _hostname_ NetworkManager[409]: <info> [1606983224.5155] device (wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
дек 03 11:13:44 _hostname_ NetworkManager[409]: <info> [1606983224.5163] device (p2p-dev-wlp2s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
дек 03 11:13:44 _hostname_ kernel: Bluetooth: hci0: RTL: fw version 0x0e3da5b1
дек 03 11:13:44 _hostname_ kernel: NET: Registered protocol family 38
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1028] device (enp3s0f2): carrier: link connected
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1035] device (enp3s0f2): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
дек 03 11:13:45 _hostname_ kernel: r8169 0000:03:00.2 enp3s0f2: Link is Up - 100Mbps/Full - flow control rx/tx
дек 03 11:13:45 _hostname_ kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0f2: link becomes ready
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1049] policy: auto-activating connection 'Wired connection 1' (cf7b54ef-d3e1-3d1d-938d-1e1704cdf620)
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1062] device (enp3s0f2): Activation: starting connection 'Wired connection 1' (cf7b54ef-d3e1-3d1d-938d-1e1704cdf620)
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1064] device (enp3s0f2): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1073] manager: NetworkManager state is now CONNECTING
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1079] device (enp3s0f2): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1090] device (enp3s0f2): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1099] dhcp4 (enp3s0f2): activation: beginning transaction (timeout in 45 seconds)
дек 03 11:13:45 _hostname_ avahi-daemon[406]: Joining mDNS multicast group on interface enp3s0f2.IPv6 with address fe80::2775:1da5:4bee:f431.
дек 03 11:13:45 _hostname_ avahi-daemon[406]: New relevant interface enp3s0f2.IPv6 for mDNS.
дек 03 11:13:45 _hostname_ avahi-daemon[406]: Registering new address record for fe80::2775:1da5:4bee:f431 on enp3s0f2.*.
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1231] dhcp4 (enp3s0f2): option dhcp_lease_time => '86400'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1231] dhcp4 (enp3s0f2): option domain_name => 'Dlink'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1231] dhcp4 (enp3s0f2): option domain_name_servers => '192.168.1.1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1231] dhcp4 (enp3s0f2): option expiry => '1607069625'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1232] dhcp4 (enp3s0f2): option host_name => '_hostname_'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1232] dhcp4 (enp3s0f2): option ip_address => '192.168.1.72'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1232] dhcp4 (enp3s0f2): option next_server => '192.168.1.1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1232] dhcp4 (enp3s0f2): option requested_broadcast_address => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1232] dhcp4 (enp3s0f2): option requested_domain_name => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1232] dhcp4 (enp3s0f2): option requested_domain_name_servers => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1233] dhcp4 (enp3s0f2): option requested_domain_search => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1233] dhcp4 (enp3s0f2): option requested_host_name => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1233] dhcp4 (enp3s0f2): option requested_interface_mtu => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1233] dhcp4 (enp3s0f2): option requested_ms_classless_static_routes => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1233] dhcp4 (enp3s0f2): option requested_nis_domain => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1233] dhcp4 (enp3s0f2): option requested_nis_servers => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1233] dhcp4 (enp3s0f2): option requested_ntp_servers => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1234] dhcp4 (enp3s0f2): option requested_rfc3442_classless_static_routes => '1'
дек 03 11:13:45 _hostname_ avahi-daemon[406]: Joining mDNS multicast group on interface enp3s0f2.IPv4 with address 192.168.1.72.
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1234] dhcp4 (enp3s0f2): option requested_root_path => '1'
дек 03 11:13:45 _hostname_ avahi-daemon[406]: New relevant interface enp3s0f2.IPv4 for mDNS.
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1234] dhcp4 (enp3s0f2): option requested_routers => '1'
дек 03 11:13:45 _hostname_ avahi-daemon[406]: Registering new address record for 192.168.1.72 on enp3s0f2.IPv4.
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1234] dhcp4 (enp3s0f2): option requested_static_routes => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1234] dhcp4 (enp3s0f2): option requested_subnet_mask => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1234] dhcp4 (enp3s0f2): option requested_time_offset => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1235] dhcp4 (enp3s0f2): option requested_wpad => '1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1235] dhcp4 (enp3s0f2): option routers => '192.168.1.1'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1235] dhcp4 (enp3s0f2): option subnet_mask => '255.255.255.0'
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1235] dhcp4 (enp3s0f2): state changed unknown -> bound
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1254] device (enp3s0f2): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1279] device (enp3s0f2): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1284] device (enp3s0f2): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1293] manager: NetworkManager state is now CONNECTED_LOCAL
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1308] manager: NetworkManager state is now CONNECTED_SITE
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1310] policy: set 'Wired connection 1' (enp3s0f2) as default for IPv4 routing and DNS
дек 03 11:13:45 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=409 comm="/usr/bin/NetworkManager --no-daemon ")
дек 03 11:13:45 _hostname_ dbus-daemon[408]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.1382] device (enp3s0f2): Activation: successful, device activated.
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.2668] manager: NetworkManager state is now CONNECTED_GLOBAL
дек 03 11:13:45 _hostname_ ModemManager[448]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.3/0000:03:00.2': not supported by any plugin
дек 03 11:13:45 _hostname_ ModemManager[448]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
дек 03 11:13:45 _hostname_ sddm[512]: Setting default cursor
дек 03 11:13:45 _hostname_ sddm[512]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
дек 03 11:13:45 _hostname_ sddm[512]: Display server started.
дек 03 11:13:45 _hostname_ sddm[512]: Reading from "/usr/share/xsessions/plasma.desktop"
дек 03 11:13:45 _hostname_ sddm[512]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11"
дек 03 11:13:45 _hostname_ sddm-helper[847]: [PAM] Starting...
дек 03 11:13:45 _hostname_ sddm-helper[847]: [PAM] Authenticating...
дек 03 11:13:45 _hostname_ sddm-helper[847]: gkr-pam: no password is available for user
дек 03 11:13:45 _hostname_ sddm-helper[847]: pam_kwallet5(sddm-autologin:auth): (null): pam_sm_authenticate
дек 03 11:13:45 _hostname_ sddm-helper[847]: [PAM] Preparing to converse...
дек 03 11:13:45 _hostname_ sddm-helper[847]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: Couldn't get password (it is empty)
дек 03 11:13:45 _hostname_ sddm-helper[847]: [PAM] Conversation with 1 messages
дек 03 11:13:45 _hostname_ audit[847]: USER_AUTH pid=847 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="_user_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
дек 03 11:13:45 _hostname_ sddm-helper[847]: [PAM] returning.
дек 03 11:13:45 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.25' (uid=0 pid=847 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth2")
дек 03 11:13:45 _hostname_ dbus-daemon[408]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
дек 03 11:13:45 _hostname_ sddm-helper[847]: pam_systemd_home(sddm-autologin:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
дек 03 11:13:45 _hostname_ audit[847]: USER_ACCT pid=847 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="_user_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
дек 03 11:13:45 _hostname_ sddm[512]: Authenticated successfully
дек 03 11:13:45 _hostname_ audit[847]: CRED_ACQ pid=847 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="_user_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
дек 03 11:13:45 _hostname_ sddm-helper[847]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
дек 03 11:13:45 _hostname_ sddm-helper[847]: pam_unix(sddm-autologin:session): session opened for user _user_(uid=1000) by (uid=0)
дек 03 11:13:45 _hostname_ systemd[1]: Created slice User Slice of UID 1000.
дек 03 11:13:45 _hostname_ systemd[1]: Starting User Runtime Directory /run/user/1000...
дек 03 11:13:45 _hostname_ NetworkManager[409]: <info> [1606983225.9072] manager: startup complete
дек 03 11:13:45 _hostname_ systemd-logind[412]: New session 1 of user _user_.
дек 03 11:13:45 _hostname_ systemd[1]: Finished User Runtime Directory /run/user/1000.
дек 03 11:13:45 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:45 _hostname_ systemd[1]: Starting User Manager for UID 1000...
дек 03 11:13:45 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.27' (uid=0 pid=849 comm="(systemd) ")
дек 03 11:13:45 _hostname_ systemd[849]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
дек 03 11:13:45 _hostname_ audit[849]: USER_ACCT pid=849 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="_user_" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:45 _hostname_ audit[849]: CRED_ACQ pid=849 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="_user_" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
дек 03 11:13:45 _hostname_ systemd[849]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[_user_] ruser=[<unknown>] rhost=[<unknown>]
дек 03 11:13:45 _hostname_ systemd[849]: pam_unix(systemd-user:session): session opened for user _user_(uid=1000) by (uid=0)
дек 03 11:13:45 _hostname_ systemd[849]: pam_env(systemd-user:session): deprecated reading of user environment enabled
дек 03 11:13:45 _hostname_ audit[849]: USER_START pid=849 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="_user_" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:45 _hostname_ audit: BPF prog-id=11 op=LOAD
дек 03 11:13:45 _hostname_ audit: BPF prog-id=11 op=UNLOAD
дек 03 11:13:45 _hostname_ systemd[854]: Configuration file /home/_user_/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
дек 03 11:13:45 _hostname_ systemd[854]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
дек 03 11:13:45 _hostname_ systemd[854]: Configuration file /etc/xdg/autostart/klipper.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
дек 03 11:13:45 _hostname_ systemd[854]: Not generating service for XDG autostart app-at\x2dspi\x2ddbus\x2dbus-autostart.service, startup phases are not supported.
дек 03 11:13:45 _hostname_ systemd[854]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dsecrets-autostart.service, startup phases are not supported.
дек 03 11:13:45 _hostname_ systemd[854]: Not generating service for XDG autostart app-pulseaudio-autostart.service, startup phases are not supported.
дек 03 11:13:45 _hostname_ systemd[854]: Not generating service for XDG autostart app-powerdevil-autostart.service, only Type=Application is supported.
дек 03 11:13:45 _hostname_ systemd[854]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dssh-autostart.service, startup phases are not supported.
дек 03 11:13:45 _hostname_ systemd[854]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dpkcs11-autostart.service, startup phases are not supported.
дек 03 11:13:45 _hostname_ systemd[854]: Not generating service for XDG autostart app-kaccess-autostart.service, only Type=Application is supported.
дек 03 11:13:46 _hostname_ systemd[849]: Queued start job for default target Main User Target.
дек 03 11:13:46 _hostname_ systemd[849]: Reached target Paths.
дек 03 11:13:46 _hostname_ systemd[849]: Reached target Timers.
дек 03 11:13:46 _hostname_ systemd[849]: Starting D-Bus User Message Bus Socket.
дек 03 11:13:46 _hostname_ systemd[849]: Listening on GnuPG network certificate management daemon.
дек 03 11:13:46 _hostname_ systemd[849]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
дек 03 11:13:46 _hostname_ systemd[849]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
дек 03 11:13:46 _hostname_ systemd[849]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
дек 03 11:13:46 _hostname_ systemd[849]: Listening on GnuPG cryptographic agent and passphrase cache.
дек 03 11:13:46 _hostname_ systemd[849]: Listening on p11-kit server.
дек 03 11:13:46 _hostname_ systemd[849]: Listening on Multimedia System.
дек 03 11:13:46 _hostname_ systemd[849]: Listening on Sound System.
дек 03 11:13:46 _hostname_ systemd[849]: Listening on D-Bus User Message Bus Socket.
дек 03 11:13:46 _hostname_ systemd[849]: Reached target Sockets.
дек 03 11:13:46 _hostname_ systemd[849]: Reached target Basic System.
дек 03 11:13:46 _hostname_ systemd[1]: Started User Manager for UID 1000.
дек 03 11:13:46 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:46 _hostname_ systemd[849]: Starting Update XDG user dir configuration...
дек 03 11:13:46 _hostname_ systemd[1]: Started Session 1 of user _user_.
дек 03 11:13:46 _hostname_ systemd[849]: xdg-user-dirs-update.service: Succeeded.
дек 03 11:13:46 _hostname_ systemd[849]: Finished Update XDG user dir configuration.
дек 03 11:13:46 _hostname_ systemd[849]: Reached target Main User Target.
дек 03 11:13:46 _hostname_ systemd[849]: Startup finished in 98ms.
дек 03 11:13:46 _hostname_ sddm-helper[847]: pam_env(sddm-autologin:session): deprecated reading of user environment enabled
дек 03 11:13:46 _hostname_ sddm-helper[847]: gkr-pam: gnome-keyring-daemon started properly
дек 03 11:13:46 _hostname_ sddm-helper[847]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_open_session
дек 03 11:13:46 _hostname_ sddm-helper[864]: pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
дек 03 11:13:46 _hostname_ audit[847]: USER_START pid=847 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring,pam_kwallet5 acct="_user_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
дек 03 11:13:46 _hostname_ sddm-helper[847]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
дек 03 11:13:46 _hostname_ sddm-helper[866]: Adding cookie to "/home/_user_/.Xauthority"
дек 03 11:13:46 _hostname_ sddm[512]: Session started
дек 03 11:13:46 _hostname_ systemd[849]: Started D-Bus User Message Bus.
дек 03 11:13:46 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activating service name='org.kde.KSplash' requested by ':1.2' (uid=1000 pid=866 comm="/usr/bin/startplasma-x11 ")
дек 03 11:13:47 _hostname_ klauncher[892]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
дек 03 11:13:47 _hostname_ klauncher[892]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:47 _hostname_ klauncher[892]: Icon theme "Mint-X" not found.
дек 03 11:13:47 _hostname_ klauncher[892]: Icon theme "elementary" not found.
дек 03 11:13:47 _hostname_ kcminit_startup[896]: Initializing "kcm_mouse" : "kcminit_mouse"
дек 03 11:13:47 _hostname_ kcminit_startup[896]: Initializing "kcm_style" : "kcminit_style"
дек 03 11:13:47 _hostname_ NetworkManager[409]: <info> [1606983227.2177] dhcp6 (enp3s0f2): activation: beginning transaction (timeout in 45 seconds)
дек 03 11:13:47 _hostname_ avahi-daemon[406]: Leaving mDNS multicast group on interface enp3s0f2.IPv6 with address fe80::2775:1da5:4bee:f431.
дек 03 11:13:47 _hostname_ avahi-daemon[406]: Joining mDNS multicast group on interface enp3s0f2.IPv6 with address fd01::52ae:fd67:e9f4:dfe.
дек 03 11:13:47 _hostname_ avahi-daemon[406]: Registering new address record for fd01::52ae:fd67:e9f4:dfe on enp3s0f2.*.
дек 03 11:13:47 _hostname_ avahi-daemon[406]: Withdrawing address record for fe80::2775:1da5:4bee:f431 on enp3s0f2.
дек 03 11:13:47 _hostname_ NetworkManager[409]: <info> [1606983227.2244] dhcp6 (enp3s0f2): option dhcp6_domain_search => 'Dlink'
дек 03 11:13:47 _hostname_ NetworkManager[409]: <info> [1606983227.2245] dhcp6 (enp3s0f2): option dhcp6_name_servers => 'fe80::8226:89ff:fe67:c57f'
дек 03 11:13:47 _hostname_ NetworkManager[409]: <info> [1606983227.2245] dhcp6 (enp3s0f2): state changed unknown -> bound
дек 03 11:13:47 _hostname_ plasma_session[885]: org.kde.plasma.session: process job "kcminit_startup" finished with exit code 0
дек 03 11:13:47 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activating service name='ca.desrt.dconf' requested by ':1.8' (uid=1000 pid=905 comm="/usr/bin/kded5 ")
дек 03 11:13:47 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Successfully activated service 'ca.desrt.dconf'
дек 03 11:13:47 _hostname_ kwin_x11[909]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:47 _hostname_ kwin_x11[909]: Icon theme "Mint-X" not found.
дек 03 11:13:47 _hostname_ kwin_x11[909]: Icon theme "elementary" not found.
дек 03 11:13:47 _hostname_ kded5[905]: Installing the delayed initialization callback.
дек 03 11:13:47 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activating service name='org.kde.ActivityManager' requested by ':1.10' (uid=1000 pid=909 comm="/usr/bin/kwin_x11 ")
дек 03 11:13:47 _hostname_ kded5[905]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:47 _hostname_ kded5[905]: Icon theme "Mint-X" not found.
дек 03 11:13:47 _hostname_ kded5[905]: Icon theme "elementary" not found.
дек 03 11:13:47 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Successfully activated service 'org.kde.ActivityManager'
дек 03 11:13:47 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activating via systemd: service name='org.kde.kglobalaccel' unit='plasma-kglobalaccel.service' requested by ':1.12' (uid=1000 pid=932 comm="/usr/lib/kactivitymanagerd ")
дек 03 11:13:47 _hostname_ systemd[849]: Created slice background.slice.
дек 03 11:13:47 _hostname_ systemd[849]: Starting KDE Global Shortcuts Server...
дек 03 11:13:47 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Successfully activated service 'org.kde.kglobalaccel'
дек 03 11:13:47 _hostname_ systemd[849]: Started KDE Global Shortcuts Server.
дек 03 11:13:47 _hostname_ ksmserver[947]: Qt: Session management error: networkIdsList argument is NULL
дек 03 11:13:47 _hostname_ kglobalaccel5[944]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:47 _hostname_ kglobalaccel5[944]: Icon theme "Mint-X" not found.
дек 03 11:13:47 _hostname_ kglobalaccel5[944]: Icon theme "elementary" not found.
дек 03 11:13:47 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/org.kde.plasmashell.desktop" ("/usr/bin/plasmashell")
дек 03 11:13:47 _hostname_ ksmserver[947]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:47 _hostname_ ksmserver[947]: Icon theme "Mint-X" not found.
дек 03 11:13:47 _hostname_ ksmserver[947]: Icon theme "elementary" not found.
дек 03 11:13:47 _hostname_ kcminit_startup[896]: Initializing "kded_touchpad" : "kcminit_touchpad"
дек 03 11:13:47 _hostname_ kcminit_startup[896]: kcm_touchpad: Using X11 backend
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/kaccess.desktop" ("/usr/bin/kaccess")
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pam_kwallet_init.desktop" ("/usr/lib/pam_kwallet_init")
дек 03 11:13:48 _hostname_ kcminit_startup[896]: Initializing "kcm_kgamma" : "kcminit_kgamma"
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/xembedsniproxy.desktop" ("/usr/bin/xembedsniproxy")
дек 03 11:13:48 _hostname_ kaccess[954]: Xlib XKB extension major= 1 minor= 0
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/polkit-kde-authentication-agent-1.desktop" ("/usr/lib/polkit-kde-authentication-agent-1")
дек 03 11:13:48 _hostname_ kded5[905]: bluedevil: Created
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/gmenudbusmenuproxy.desktop" ("/usr/bin/gmenudbusmenuproxy")
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/org.kde.kdeconnect.daemon.desktop" ("/usr/lib/kdeconnectd")
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pulseaudio.desktop" ("/usr/bin/start-pulseaudio-x11")
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pamac-tray-plasma.desktop" ("/usr/bin/pamac-tray-plasma")
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/powerdevil.desktop" ("/usr/lib/org_kde_powerdevil")
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/msm_kde_notifier.desktop" ("/usr/bin/msm_kde_notifier")
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/geoclue-demo-agent.desktop" ("/usr/lib/geoclue-2.0/demos/agent")
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/home/_user_/.config/autostart/org.kde.yakuake.desktop" ("/usr/bin/yakuake")
дек 03 11:13:48 _hostname_ systemd[849]: Starting Sound Service...
дек 03 11:13:48 _hostname_ plasma_session[885]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/dtd-wayland.desktop" ("/usr/bin/dtd-wayland")
дек 03 11:13:48 _hostname_ NetworkManager[409]: <info> [1606983228.1932] agent-manager: agent[f3b8ddbee05bed45,:1.31/org.kde.plasma.networkmanagement/1000]: agent registered
дек 03 11:13:48 _hostname_ kwalletd5[865]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:48 _hostname_ kwalletd5[865]: Icon theme "Mint-X" not found.
дек 03 11:13:48 _hostname_ kwalletd5[865]: Icon theme "elementary" not found.
дек 03 11:13:48 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.35' (uid=1000 pid=977 comm="/usr/lib/org_kde_powerdevil ")
дек 03 11:13:48 _hostname_ audit: BPF prog-id=12 op=LOAD
дек 03 11:13:48 _hostname_ kernel: kauditd_printk_skb: 25 callbacks suppressed
дек 03 11:13:48 _hostname_ kernel: audit: type=1334 audit(1606983228.510:45): prog-id=12 op=LOAD
дек 03 11:13:48 _hostname_ audit: BPF prog-id=13 op=LOAD
дек 03 11:13:48 _hostname_ systemd[1]: Starting Daemon for power management...
дек 03 11:13:48 _hostname_ kernel: audit: type=1334 audit(1606983228.514:46): prog-id=13 op=LOAD
дек 03 11:13:48 _hostname_ sddm[865]: kwalletd5: Checking for pam module
дек 03 11:13:48 _hostname_ sddm[865]: kwalletd5: Got pam-login param
дек 03 11:13:48 _hostname_ sddm[865]: kwalletd5: Waiting for hash on 7-
дек 03 11:13:48 _hostname_ sddm[865]: kwalletd5: waitingForEnvironment on: 3
дек 03 11:13:48 _hostname_ sddm[865]: kwalletd5: client connected
дек 03 11:13:48 _hostname_ sddm[865]: kwalletd5: client disconnected
дек 03 11:13:48 _hostname_ kaccess[954]: X server XKB extension major= 1 minor= 0
дек 03 11:13:48 _hostname_ kwin_x11[909]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 682, resource id: 8388613, major code: 18 (ChangeProperty), minor code: 0
дек 03 11:13:48 _hostname_ plasmashell[952]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:48 _hostname_ plasmashell[952]: Icon theme "Mint-X" not found.
дек 03 11:13:48 _hostname_ plasmashell[952]: Icon theme "elementary" not found.
дек 03 11:13:48 _hostname_ kaccess[954]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:48 _hostname_ kaccess[954]: Icon theme "Mint-X" not found.
дек 03 11:13:48 _hostname_ kaccess[954]: Icon theme "elementary" not found.
дек 03 11:13:48 _hostname_ kded5[905]: Failed to load GeolocationProvider: "Cannot load library /usr/lib/qt/plugins/plasma-geolocation-gps.so: (libgps.so.27: cannot open shared object file: No such file or directory)"
дек 03 11:13:48 _hostname_ kded5[905]: "location"
дек 03 11:13:48 _hostname_ kdeconnectd[969]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:48 _hostname_ kdeconnectd[969]: Icon theme "Mint-X" not found.
дек 03 11:13:48 _hostname_ kdeconnectd[969]: Icon theme "elementary" not found.
дек 03 11:13:48 _hostname_ polkit-kde-authentication-agent-1[962]: New PolkitAgentListener 0x5593a79fcc00
дек 03 11:13:48 _hostname_ polkit-kde-authentication-agent-1[962]: Adding new listener PolkitQt1::Agent::Listener(0x5593a7a126f0) for 0x5593a79fcc00
дек 03 11:13:48 _hostname_ polkit-kde-authentication-agent-1[962]: Listener online
дек 03 11:13:48 _hostname_ polkitd[410]: Registered Authentication Agent for unix-session:1 (system bus name :1.39 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
дек 03 11:13:48 _hostname_ polkit-kde-authentication-agent-1[962]: Authentication agent result: true
дек 03 11:13:48 _hostname_ polkit-kde-authentication-agent-1[962]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:48 _hostname_ polkit-kde-authentication-agent-1[962]: Icon theme "Mint-X" not found.
дек 03 11:13:48 _hostname_ polkit-kde-authentication-agent-1[962]: Icon theme "elementary" not found.
дек 03 11:13:48 _hostname_ msm_kde_notifier[979]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:48 _hostname_ msm_kde_notifier[979]: Icon theme "Mint-X" not found.
дек 03 11:13:48 _hostname_ msm_kde_notifier[979]: Icon theme "elementary" not found.
дек 03 11:13:48 _hostname_ kded5[905]: kcm_touchpad: Using X11 backend
дек 03 11:13:48 _hostname_ yakuake[986]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:48 _hostname_ yakuake[986]: Icon theme "Mint-X" not found.
дек 03 11:13:48 _hostname_ yakuake[986]: Icon theme "elementary" not found.
дек 03 11:13:48 _hostname_ pamac-tray-plasma[975]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:48 _hostname_ pamac-tray-plasma[975]: Icon theme "Mint-X" not found.
дек 03 11:13:48 _hostname_ pamac-tray-plasma[975]: Icon theme "elementary" not found.
дек 03 11:13:48 _hostname_ kded5[905]: Delayed initialization.
дек 03 11:13:48 _hostname_ kded5[905]: Reloading the khotkeys configuration
дек 03 11:13:48 _hostname_ kded5[905]: Version 2 File!
дек 03 11:13:48 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.29' (uid=1000 pid=975 comm="/usr/bin/pamac-tray-plasma ")
дек 03 11:13:48 _hostname_ systemd[849]: Starting Virtual filesystem service...
дек 03 11:13:48 _hostname_ kded5[905]: true
дек 03 11:13:48 _hostname_ kded5[905]: Imported file "/usr/share/khotkeys/defaults.khotkeys"
дек 03 11:13:48 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Successfully activated service 'org.gtk.vfs.Daemon'
дек 03 11:13:48 _hostname_ systemd[849]: Started Virtual filesystem service.
дек 03 11:13:48 _hostname_ kded5[905]: Imported file "/usr/share/khotkeys/kde32b1.khotkeys"
дек 03 11:13:48 _hostname_ kded5[905]: Imported file "/usr/share/khotkeys/konqueror_gestures_kde321.khotkeys"
дек 03 11:13:48 _hostname_ kded5[905]: Imported file "/usr/share/khotkeys/konsole.khotkeys"
дек 03 11:13:48 _hostname_ kernel: fuse: init (API version 7.31)
дек 03 11:13:48 _hostname_ systemd[1]: Mounting FUSE Control File System...
дек 03 11:13:48 _hostname_ systemd[1]: Mounted FUSE Control File System.
дек 03 11:13:49 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activating service name='org.freedesktop.Notifications' requested by ':1.21' (uid=1000 pid=969 comm="/usr/lib/kdeconnectd ")
дек 03 11:13:49 _hostname_ systemd[1]: systemd-rfkill.service: Succeeded.
дек 03 11:13:49 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:49 _hostname_ kernel: audit: type=1131 audit(1606983229.110:47): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:49 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.42' (uid=1000 pid=987 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
дек 03 11:13:49 _hostname_ systemd[1]: Starting RealtimeKit Scheduling Policy Service...
дек 03 11:13:49 _hostname_ dbus-daemon[408]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
дек 03 11:13:49 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:49 _hostname_ systemd[1]: Started RealtimeKit Scheduling Policy Service.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Successfully called chroot.
дек 03 11:13:49 _hostname_ kernel: audit: type=1130 audit(1606983229.167:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Successfully dropped privileges.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Successfully limited resources.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Running.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Canary thread running.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Watchdog thread running.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Successfully made thread 987 of process 987 owned by '1000' high priority at nice level -11.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Supervising 1 threads of 1 processes of 1 users.
дек 03 11:13:49 _hostname_ kded5[905]: Registering ":1.11/StatusNotifierItem" to system tray
дек 03 11:13:49 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activating service name='org.kde.KScreen' requested by ':1.7' (uid=1000 pid=905 comm="/usr/bin/kded5 ")
дек 03 11:13:49 _hostname_ yakuake[986]: libpng warning: iCCP: known incorrect sRGB profile
дек 03 11:13:49 _hostname_ kded5[905]: bluedevil: ObexManager operational changed false
дек 03 11:13:49 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.7' (uid=1000 pid=905 comm="/usr/bin/kded5 ")
дек 03 11:13:49 _hostname_ systemd[849]: Starting Bluetooth OBEX service...
дек 03 11:13:49 _hostname_ kded5[905]: bluedevil: Bluetooth operational changed true
дек 03 11:13:49 _hostname_ kded5[905]: Registering ":1.26/StatusNotifierItem" to system tray
дек 03 11:13:49 _hostname_ kded5[905]: Registering ":1.28/StatusNotifierItem" to system tray
дек 03 11:13:49 _hostname_ kded5[905]: bluedevil: Agent registered
дек 03 11:13:49 _hostname_ kded5[905]: bluedevil: Requested default Agent
дек 03 11:13:49 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Successfully activated service 'org.kde.KScreen'
дек 03 11:13:49 _hostname_ obexd[1074]: OBEX daemon 5.55
дек 03 11:13:49 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Successfully activated service 'org.bluez.obex'
дек 03 11:13:49 _hostname_ systemd[849]: Started Bluetooth OBEX service.
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Connected output 67 to CRTC 63
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Connected output 69 to CRTC 64
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Detected XRandR 1.6
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Event Base: 89
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Event Error: 147
дек 03 11:13:49 _hostname_ kernel: Bluetooth: RFCOMM TTY layer initialized
дек 03 11:13:49 _hostname_ kernel: Bluetooth: RFCOMM socket layer initialized
дек 03 11:13:49 _hostname_ kernel: Bluetooth: RFCOMM ver 1.11
дек 03 11:13:49 _hostname_ kded5[905]: kscreen.kded: UPower not available, lid detection won't work
дек 03 11:13:49 _hostname_ kded5[905]: kscreen.kded: PowerDevil SuspendSession action not available!
дек 03 11:13:49 _hostname_ plasmashell[952]: kf.plasma.quick: Applet preload policy set to 1
дек 03 11:13:49 _hostname_ kded5[905]: Registering ":1.34/StatusNotifierItem" to system tray
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Successfully made thread 1101 of process 987 owned by '1000' RT at priority 5.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Supervising 2 threads of 1 processes of 1 users.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Successfully made thread 1107 of process 987 owned by '1000' RT at priority 5.
дек 03 11:13:49 _hostname_ rtkit-daemon[1068]: Supervising 3 threads of 1 processes of 1 users.
дек 03 11:13:49 _hostname_ systemd[849]: Started Sound Service.
дек 03 11:13:49 _hostname_ bluetoothd[801]: Endpoint registered: sender=:1.51 path=/MediaEndpoint/A2DPSink/sbc
дек 03 11:13:49 _hostname_ bluetoothd[801]: Endpoint registered: sender=:1.51 path=/MediaEndpoint/A2DPSource/sbc
дек 03 11:13:49 _hostname_ dbus-daemon[408]: [system] Successfully activated service 'org.freedesktop.UPower'
дек 03 11:13:49 _hostname_ systemd[1]: Started Daemon for power management.
дек 03 11:13:49 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:49 _hostname_ kernel: audit: type=1130 audit(1606983229.607:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: XRandR::setConfig
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Requested screen size is QSize(3286, 1080)
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Needed CRTCs: 2
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Actions to perform:
Primary Output: false
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Change Screen Size: true
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Old: QSize(1366, 768)
Intermediate: QSize(3286, 1080)
New: QSize(3286, 1080)
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Disable outputs: false
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Change outputs: true
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: (67, 69)
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Enable outputs: false
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: RRSetScreenSize
DPI: 96.0946
SizeMM: QSize(868, 285)
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: RRSetCrtcConfig (change output)
Output: 67 ( "LVDS1" )
CRTC: 63
Pos: QPoint(1920,312)
Mode: 73 KScreen::Mode(Id: "73" , Size: QSize(1366, 768) @ 59.9892 )
Rotation: 1
дек 03 11:13:49 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.35' (uid=1000 pid=977 comm="/usr/lib/org_kde_powerdevil ")
дек 03 11:13:49 _hostname_ systemd[1]: Starting Disk Manager...
дек 03 11:13:49 _hostname_ udisksd[1128]: udisks daemon version 2.9.1 starting
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Result: 0
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: XRandROutput 67 update
m_connected: 0
m_crtc XRandRCrtc(0x55668352a8c0)
CRTC: 63
MODE: 73
Connection: 0
Primary: true
Output: 69 ( "HDMI1" )
CRTC: 64
Pos: QPoint(0,0)
Mode: 358 KScreen::Mode(Id: "358" , Size: QSize(1920, 1080) @ 60 )
Rotation: 1
дек 03 11:13:49 _hostname_ kded5[905]: bluedevil: ObexManager operational changed true
дек 03 11:13:49 _hostname_ kded5[905]: bluedevil: ObexAgent registered
дек 03 11:13:49 _hostname_ dbus-daemon[408]: [system] Successfully activated service 'org.freedesktop.UDisks2'
дек 03 11:13:49 _hostname_ systemd[1]: Started Disk Manager.
дек 03 11:13:49 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:49 _hostname_ kernel: audit: type=1130 audit(1606983229.797:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:49 _hostname_ udisksd[1128]: Acquired the name org.freedesktop.UDisks2 on the system message bus
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: XRandROutput 69 update
m_connected: 0
m_crtc XRandRCrtc(0x5566835323b0)
CRTC: 64
MODE: 358
Connection: 0
Primary: false
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: XRandR::setConfig done!
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: RRScreenChangeNotify
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Window: 46137349
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Root: 310
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Rotation: "Rotate_0"
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Size ID: 65535
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Size: 3286 1080
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: SizeMM: 868 285
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: RRNotify_CrtcChange
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: CRTC: 63
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Mode: 73
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Geometry: 1920 312 1366 768
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: CRTC: 64
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Mode: 358
дек 03 11:13:49 _hostname_ kscreen_backend_launcher[1072]: kscreen.xcb.helper: Geometry: 0 0 1920 1080
дек 03 11:13:49 _hostname_ org_kde_powerdevil[977]: org.kde.powerdevil: Handle button events action could not check for screen configuration
дек 03 11:13:49 _hostname_ org_kde_powerdevil[977]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.52'
дек 03 11:13:49 _hostname_ dbus-daemon[408]: [system] Activating service name='org.kde.powerdevil.discretegpuhelper' requested by ':1.35' (uid=1000 pid=977 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
дек 03 11:13:50 _hostname_ dbus-daemon[408]: [system] Successfully activated service 'org.kde.powerdevil.discretegpuhelper'
дек 03 11:13:50 _hostname_ dbus-daemon[408]: [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.35' (uid=1000 pid=977 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
дек 03 11:13:50 _hostname_ plasmashell[952]: Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
дек 03 11:13:50 _hostname_ dbus-daemon[408]: [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
дек 03 11:13:50 _hostname_ org_kde_powerdevil[977]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
дек 03 11:13:50 _hostname_ plasmashell[952]: trying to show an empty dialog
дек 03 11:13:50 _hostname_ plasmashell[952]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
дек 03 11:13:50 _hostname_ plasmashell[952]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Breath2" is a directory. Use addDir!
дек 03 11:13:50 _hostname_ plasmashell[952]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Next" is a directory. Use addDir!
дек 03 11:13:50 _hostname_ plasmashell[952]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds" is a directory. Use addDir!
дек 03 11:13:50 _hostname_ kscreen_backend_launcher[1072]: kscreen.xrandr: Emitting configChanged()
дек 03 11:13:50 _hostname_ plasmashell[952]: Plasma Shell startup completed
дек 03 11:13:50 _hostname_ plasmashell[952]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
дек 03 11:13:50 _hostname_ plasmashell[952]: Loading Calendar plugin AstronomicalEventsPlugin(0x561aa27f5b00)
дек 03 11:13:50 _hostname_ plasmashell[952]: Loading Calendar plugin HolidaysEventsPlugin(0x561aa27f5e00)
дек 03 11:13:50 _hostname_ plasmashell[952]: Both point size and pixel size set. Using pixel size.
дек 03 11:13:50 _hostname_ plasmashell[952]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:524:9: QML Label: Binding loop detected for property "height"
дек 03 11:13:50 _hostname_ plasmashell[952]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:483:13: QML Label: Binding loop detected for property "height"
дек 03 11:13:51 _hostname_ plasmashell[952]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
дек 03 11:13:51 _hostname_ plasmashell[952]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:483:13: QML Label: Binding loop detected for property "height"
дек 03 11:13:51 _hostname_ plasmashell[952]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:524:9: QML Label: Binding loop detected for property "height"
дек 03 11:13:51 _hostname_ plasmashell[952]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:544:5: QML Label: Binding loop detected for property "height"
дек 03 11:13:51 _hostname_ plasmashell[952]: trying to show an empty dialog
дек 03 11:13:51 _hostname_ plasmashell[952]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
дек 03 11:13:51 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Successfully activated service 'org.freedesktop.Notifications'
дек 03 11:13:51 _hostname_ kded5[905]: Registering "org.kde.StatusNotifierHost-952" as system tray
дек 03 11:13:51 _hostname_ plasmashell[952]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:53:5: Unable to assign [undefined] to int
дек 03 11:13:51 _hostname_ plasmashell[952]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
дек 03 11:13:51 _hostname_ plasmashell[952]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:13:51 _hostname_ plasmashell[952]: Icon theme "Mint-X" not found.
дек 03 11:13:51 _hostname_ plasmashell[952]: Icon theme "elementary" not found.
дек 03 11:13:51 _hostname_ plasmashell[952]: KAStatsFavoritesModel::setFavorites is ignored
дек 03 11:13:51 _hostname_ plasmashell[952]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/FullRepresentation.qml:356: ReferenceError: headerSeparator is not defined
дек 03 11:13:52 _hostname_ plasmashell[952]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
дек 03 11:13:52 _hostname_ plasmashell[952]: Both point size and pixel size set. Using pixel size.
дек 03 11:13:52 _hostname_ plasmashell[952]: file:///usr/lib/qt/qml/org/kde/plasma/calendar/DaysCalendar.qml:154:9: QML ToolButton: Binding loop detected for property "implicitWidth"
дек 03 11:13:52 _hostname_ plasmashell[952]: file:///usr/lib/qt/qml/org/kde/plasma/calendar/DaysCalendar.qml:144:9: QML ToolButton: Binding loop detected for property "implicitWidth"
дек 03 11:13:52 _hostname_ plasmashell[952]: file:///usr/lib/qt/qml/org/kde/plasma/calendar/DaysCalendar.qml:135:9: QML ToolButton: Binding loop detected for property "implicitWidth"
дек 03 11:13:52 _hostname_ plasmashell[952]: trying to show an empty dialog
дек 03 11:13:52 _hostname_ plasmashell[952]: 21
дек 03 11:13:52 _hostname_ plasmashell[952]: Plasma Shell startup completed
дек 03 11:13:53 _hostname_ systemd[1]: NetworkManager-dispatcher.service: Succeeded.
дек 03 11:13:53 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:53 _hostname_ kernel: audit: type=1131 audit(1606983233.220:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:13:53 _hostname_ plasmashell[952]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ComboBox.qml:74:9: Unable to assign [undefined] to QQmlComponent*
дек 03 11:13:55 _hostname_ plasmashell[952]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:53:5: Unable to assign [undefined] to int
дек 03 11:13:55 _hostname_ plasmashell[952]: file:///usr/lib/qt/qml/org/kde/plasma/components/ModelContextMenu.qml:38:1: QML ModelContextMenu: Accessible must be attached to an Item
дек 03 11:14:09 _hostname_ plasmashell[952]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:379: Unable to assign [undefined] to QString
дек 03 11:14:09 _hostname_ kwin_x11[909]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2423, resource id: 37748908, major code: 18 (ChangeProperty), minor code: 0
дек 03 11:14:09 _hostname_ systemd[849]: Created slice app.slice.
дек 03 11:14:09 _hostname_ systemd[849]: Started Firefox - Web Browser.
дек 03 11:14:10 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.44' (uid=1000 pid=1182 comm="/usr/lib/firefox/firefox ")
дек 03 11:14:10 _hostname_ systemd[849]: Starting Accessibility services bus...
дек 03 11:14:10 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Successfully activated service 'org.a11y.Bus'
дек 03 11:14:10 _hostname_ systemd[849]: Started Accessibility services bus.
дек 03 11:14:10 _hostname_ at-spi-bus-launcher[1231]: dbus-daemon[1231]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=1072 comm="/usr/lib/kf5/kscreen_backend_launcher ")
дек 03 11:14:10 _hostname_ at-spi-bus-launcher[1231]: dbus-daemon[1231]: Successfully activated service 'org.a11y.atspi.Registry'
дек 03 11:14:10 _hostname_ at-spi-bus-launcher[1233]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
дек 03 11:14:11 _hostname_ rtkit-daemon[1068]: Supervising 3 threads of 1 processes of 1 users.
дек 03 11:14:11 _hostname_ rtkit-daemon[1068]: Successfully made thread 1275 of process 1182 owned by '1000' RT at priority 10.
дек 03 11:14:11 _hostname_ rtkit-daemon[1068]: Supervising 4 threads of 2 processes of 1 users.
дек 03 11:14:12 _hostname_ systemd-timesyncd[296]: Initial synchronization to time server 91.207.136.50:123 (2.manjaro.pool.ntp.org).
дек 03 11:14:12 _hostname_ rtkit-daemon[1068]: Supervising 4 threads of 2 processes of 1 users.
дек 03 11:14:13 _hostname_ rtkit-daemon[1068]: Supervising 4 threads of 2 processes of 1 users.
дек 03 11:14:14 _hostname_ systemd[1]: systemd-hostnamed.service: Succeeded.
дек 03 11:14:14 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:14:14 _hostname_ kernel: audit: type=1131 audit(1606983254.172:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:14:14 _hostname_ audit: BPF prog-id=10 op=UNLOAD
дек 03 11:14:14 _hostname_ audit: BPF prog-id=9 op=UNLOAD
дек 03 11:14:14 _hostname_ kernel: audit: type=1334 audit(1606983254.228:53): prog-id=10 op=UNLOAD
дек 03 11:14:14 _hostname_ kernel: audit: type=1334 audit(1606983254.228:54): prog-id=9 op=UNLOAD
дек 03 11:14:16 _hostname_ rtkit-daemon[1068]: Supervising 4 threads of 2 processes of 1 users.
дек 03 11:14:17 _hostname_ rtkit-daemon[1068]: Supervising 4 threads of 2 processes of 1 users.
дек 03 11:14:17 _hostname_ rtkit-daemon[1068]: Successfully made thread 1520 of process 1382 owned by '1000' RT at priority 10.
дек 03 11:14:17 _hostname_ rtkit-daemon[1068]: Supervising 5 threads of 3 processes of 1 users.
дек 03 11:14:26 _hostname_ rtkit-daemon[1068]: Supervising 5 threads of 3 processes of 1 users.
дек 03 11:14:31 _hostname_ rtkit-daemon[1068]: Supervising 5 threads of 3 processes of 1 users.
дек 03 11:14:39 _hostname_ rtkit-daemon[1068]: Supervising 5 threads of 3 processes of 1 users.
дек 03 11:14:40 _hostname_ rtkit-daemon[1068]: Supervising 5 threads of 3 processes of 1 users.
дек 03 11:14:40 _hostname_ rtkit-daemon[1068]: Successfully made thread 1697 of process 1543 owned by '1000' RT at priority 10.
дек 03 11:14:40 _hostname_ rtkit-daemon[1068]: Supervising 6 threads of 4 processes of 1 users.
дек 03 11:14:47 _hostname_ plasma_waitforname[884]: org.kde.knotifications: WaitForName: Service was not registered within timeout
дек 03 11:14:47 _hostname_ dbus-daemon[871]: [session uid=1000 pid=871] Activated service 'org.kde.KSplash' failed: Process org.kde.KSplash exited with status 1
дек 03 11:14:49 _hostname_ msm_kde_notifier[979]: "qt5-translations"
дек 03 11:20:36 _hostname_ NetworkManager[409]: <info> [1606983636.6399] device (wlp2s0): set-hw-addr: set MAC address to 76:0C:B2:65:0D:E4 (scanning)
дек 03 11:20:37 _hostname_ NetworkManager[409]: <info> [1606983637.0256] device (wlp2s0): supplicant interface state: disconnected -> interface_disabled
дек 03 11:20:37 _hostname_ NetworkManager[409]: <info> [1606983637.0257] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> interface_disabled
дек 03 11:20:37 _hostname_ NetworkManager[409]: <info> [1606983637.0884] device (wlp2s0): supplicant interface state: interface_disabled -> inactive
дек 03 11:20:37 _hostname_ NetworkManager[409]: <info> [1606983637.0885] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> inactive
дек 03 11:27:30 _hostname_ NetworkManager[409]: <info> [1606984050.6232] device (wlp2s0): set-hw-addr: set MAC address to 52:E6:AF:0F:4D:03 (scanning)
дек 03 11:27:31 _hostname_ NetworkManager[409]: <info> [1606984051.0067] device (wlp2s0): supplicant interface state: inactive -> interface_disabled
дек 03 11:27:31 _hostname_ NetworkManager[409]: <info> [1606984051.0068] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> interface_disabled
дек 03 11:27:31 _hostname_ NetworkManager[409]: <info> [1606984051.0693] device (wlp2s0): supplicant interface state: interface_disabled -> inactive
дек 03 11:27:31 _hostname_ NetworkManager[409]: <info> [1606984051.0694] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> inactive
дек 03 11:29:01 _hostname_ systemd[1]: Starting Cleanup of Temporary Directories...
дек 03 11:29:01 _hostname_ systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
дек 03 11:29:01 _hostname_ systemd[1]: Finished Cleanup of Temporary Directories.
дек 03 11:29:01 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:29:01 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:29:01 _hostname_ kernel: audit: type=1130 audit(1606984141.421:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:29:01 _hostname_ kernel: audit: type=1131 audit(1606984141.421:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:33:15 _hostname_ rtkit-daemon[1068]: Supervising 5 threads of 3 processes of 1 users.
дек 03 11:33:21 _hostname_ rtkit-daemon[1068]: Supervising 5 threads of 3 processes of 1 users.
дек 03 11:33:21 _hostname_ rtkit-daemon[1068]: Successfully made thread 3520 of process 1649 owned by '1000' RT at priority 10.
дек 03 11:33:21 _hostname_ rtkit-daemon[1068]: Supervising 6 threads of 4 processes of 1 users.
дек 03 11:34:24 _hostname_ NetworkManager[409]: <info> [1606984464.6318] device (wlp2s0): set-hw-addr: set MAC address to 02:9D:F7:07:1B:68 (scanning)
дек 03 11:34:25 _hostname_ NetworkManager[409]: <info> [1606984465.0163] device (wlp2s0): supplicant interface state: inactive -> interface_disabled
дек 03 11:34:25 _hostname_ NetworkManager[409]: <info> [1606984465.0163] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> interface_disabled
дек 03 11:34:25 _hostname_ NetworkManager[409]: <info> [1606984465.0871] device (wlp2s0): supplicant interface state: interface_disabled -> inactive
дек 03 11:34:25 _hostname_ NetworkManager[409]: <info> [1606984465.0871] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> inactive
дек 03 11:38:03 _hostname_ rtkit-daemon[1068]: Supervising 6 threads of 4 processes of 1 users.
дек 03 11:38:10 _hostname_ rtkit-daemon[1068]: Supervising 6 threads of 4 processes of 1 users.
дек 03 11:38:10 _hostname_ rtkit-daemon[1068]: Successfully made thread 3931 of process 3436 owned by '1000' RT at priority 10.
дек 03 11:38:10 _hostname_ rtkit-daemon[1068]: Supervising 7 threads of 5 processes of 1 users.
дек 03 11:39:24 _hostname_ systemd[1]: Starting Network Manager Wait Online...
дек 03 11:39:24 _hostname_ systemd[1]: Finished Network Manager Wait Online.
дек 03 11:39:24 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:39:24 _hostname_ systemd[1]: Reached target Network is Online.
дек 03 11:39:24 _hostname_ kernel: audit: type=1130 audit(1606984764.152:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:39:24 _hostname_ systemd[1]: Starting Generate mirrorlist...
дек 03 11:39:27 _hostname_ pacman-mirrors[4033]: ::INFO Downloading mirrors from repo.manjaro.org
дек 03 11:39:27 _hostname_ pacman-mirrors[4033]: ::INFO Using default mirror file
дек 03 11:39:27 _hostname_ pacman-mirrors[4033]: ::INFO Querying mirrors - This may take some time
дек 03 11:39:30 _hostname_ pacman-mirrors[4033]: [62B blob data]
дек 03 11:39:30 _hostname_ pacman-mirrors[4033]: [65B blob data]
дек 03 11:39:31 _hostname_ pacman-mirrors[4033]: [67B blob data]
дек 03 11:39:32 _hostname_ pacman-mirrors[4033]: [66B blob data]
дек 03 11:39:33 _hostname_ pacman-mirrors[4033]: [67B blob data]
дек 03 11:39:35 _hostname_ pacman-mirrors[4033]: [74B blob data]
дек 03 11:39:38 _hostname_ pacman-mirrors[4033]: ..... Hong_Kong : ftp://ftp.cuhk.edu.hk/pub/Linux/manjaro/
дек 03 11:39:39 _hostname_ pacman-mirrors[4033]: [74B blob data]
дек 03 11:39:41 _hostname_ pacman-mirrors[4033]: [65B blob data]
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: [58B blob data]
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: [57B blob data]
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::INFO Writing mirror list
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::Australia : https://manjaro.lucassymons.net/stable
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::Norway : http://mirror.terrahost.no/linux/manjaro/stable
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::Georgia : https://manjaro.grena.ge/stable
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::Bulgaria : https://mirrors.netix.net/manjaro/stable
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::Austria : http://mirror.easyname.at/manjaro/stable
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::South_Korea : https://mirror.d-tl.com/manjaro/stable
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::Brazil : https://manjaro.c3sl.ufpr.br/stable
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::Hong_Kong : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/stable
дек 03 11:39:43 _hostname_ pacman-mirrors[4033]: ::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
дек 03 11:39:44 _hostname_ systemd[1]: pamac-mirrorlist.service: Succeeded.
дек 03 11:39:44 _hostname_ systemd[1]: Finished Generate mirrorlist.
дек 03 11:39:44 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:39:44 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:39:44 _hostname_ kernel: audit: type=1130 audit(1606984784.171:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:39:44 _hostname_ kernel: audit: type=1131 audit(1606984784.171:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-mirrorlist comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:41:18 _hostname_ NetworkManager[409]: <info> [1606984878.6276] device (wlp2s0): set-hw-addr: set MAC address to F6:1A:7E:E7:A7:72 (scanning)
дек 03 11:41:19 _hostname_ NetworkManager[409]: <info> [1606984879.0110] device (wlp2s0): supplicant interface state: inactive -> interface_disabled
дек 03 11:41:19 _hostname_ NetworkManager[409]: <info> [1606984879.0111] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> interface_disabled
дек 03 11:41:19 _hostname_ NetworkManager[409]: <info> [1606984879.1153] device (wlp2s0): supplicant interface state: interface_disabled -> inactive
дек 03 11:41:19 _hostname_ NetworkManager[409]: <info> [1606984879.1153] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> inactive
дек 03 11:48:12 _hostname_ NetworkManager[409]: <info> [1606985292.6341] device (wlp2s0): set-hw-addr: set MAC address to 16:B8:4A:01:7E:7E (scanning)
дек 03 11:48:13 _hostname_ NetworkManager[409]: <info> [1606985293.0857] device (wlp2s0): supplicant interface state: inactive -> disconnected
дек 03 11:48:13 _hostname_ NetworkManager[409]: <info> [1606985293.0857] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
дек 03 11:48:13 _hostname_ NetworkManager[409]: <info> [1606985293.0928] device (wlp2s0): supplicant interface state: disconnected -> inactive
дек 03 11:48:13 _hostname_ NetworkManager[409]: <info> [1606985293.0928] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
дек 03 11:55:06 _hostname_ NetworkManager[409]: <info> [1606985706.9316] device (wlp2s0): set-hw-addr: set MAC address to 5A:7E:2F:58:D1:55 (scanning)
дек 03 11:55:07 _hostname_ NetworkManager[409]: <info> [1606985707.3152] device (wlp2s0): supplicant interface state: inactive -> interface_disabled
дек 03 11:55:07 _hostname_ NetworkManager[409]: <info> [1606985707.3152] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> interface_disabled
дек 03 11:55:07 _hostname_ NetworkManager[409]: <info> [1606985707.3585] device (wlp2s0): supplicant interface state: interface_disabled -> inactive
дек 03 11:55:07 _hostname_ NetworkManager[409]: <info> [1606985707.3586] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> inactive
дек 03 12:01:01 _hostname_ CROND[6024]: (root) CMD (run-parts /etc/cron.hourly)
дек 03 12:02:00 _hostname_ NetworkManager[409]: <info> [1606986120.6323] device (wlp2s0): set-hw-addr: set MAC address to 8A:BD:13:F4:36:81 (scanning)
дек 03 12:02:01 _hostname_ NetworkManager[409]: <info> [1606986121.0391] device (wlp2s0): supplicant interface state: inactive -> interface_disabled
дек 03 12:02:01 _hostname_ NetworkManager[409]: <info> [1606986121.0392] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> interface_disabled
дек 03 12:02:01 _hostname_ NetworkManager[409]: <info> [1606986121.1417] device (wlp2s0): supplicant interface state: interface_disabled -> inactive
дек 03 12:02:01 _hostname_ NetworkManager[409]: <info> [1606986121.1417] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> inactive
дек 03 12:04:03 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.269' (uid=1000 pid=6273 comm="pamac install manjaro-log-helper ")
дек 03 12:04:03 _hostname_ systemd[1]: Starting Pamac Daemon...
дек 03 12:04:03 _hostname_ dbus-daemon[408]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
дек 03 12:04:03 _hostname_ systemd[1]: Started Pamac Daemon.
дек 03 12:04:03 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 12:04:03 _hostname_ kernel: audit: type=1130 audit(1606986243.431:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 12:04:03 _hostname_ polkitd[410]: Registered Authentication Agent for unix-process:6273:302615 (system bus name :1.271 [pkttyagent], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
дек 03 12:04:10 _hostname_ audit[6285]: USER_AUTH pid=6285 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="_user_" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=_hostname_ addr=? terminal=pts/1 res=success'
дек 03 12:04:10 _hostname_ kernel: audit: type=1100 audit(1606986250.728:61): pid=6285 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="_user_" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=_hostname_ addr=? terminal=pts/1 res=success'
дек 03 12:04:10 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.272' (uid=0 pid=6285 comm="/usr/lib/polkit-1/polkit-agent-helper-1 _user_ ")
дек 03 12:04:10 _hostname_ dbus-daemon[408]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
дек 03 12:04:10 _hostname_ polkit-agent-helper-1[6285]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
дек 03 12:04:10 _hostname_ kernel: audit: type=1101 audit(1606986250.731:62): pid=6285 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="_user_" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
дек 03 12:04:10 _hostname_ audit[6285]: USER_ACCT pid=6285 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="_user_" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
дек 03 12:04:10 _hostname_ polkitd[410]: Operator of unix-process:6273:302615 successfully authenticated as unix-user:_user_ to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.269 [pamac install manjaro-log-helper] (owned by unix-user:_user_)
дек 03 12:04:33 _hostname_ polkitd[410]: Unregistered Authentication Agent for unix-process:6273:302615 (system bus name :1.271, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
дек 03 12:04:33 _hostname_ systemd[1]: pamac-daemon.service: Succeeded.
дек 03 12:04:33 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 12:04:33 _hostname_ kernel: audit: type=1131 audit(1606986273.618:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 12:05:16 _hostname_ systemd[849]: Started Manjaro Logs Helper.
дек 03 12:05:16 _hostname_ kwin_x11[909]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
дек 03 12:05:16 _hostname_ kwin_x11[909]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
дек 03 12:05:16 _hostname_ kwin_x11[909]: QPainter::begin: Paint device returned engine == 0, type: 3
дек 03 12:05:31 _hostname_ rtkit-daemon[1068]: Supervising 6 threads of 4 processes of 1 users.
дек 03 12:05:33 _hostname_ kwin_x11[909]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27307, resource id: 56623107, major code: 15 (QueryTree), minor code: 0
дек 03 12:05:34 _hostname_ kwin_x11[909]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
дек 03 12:05:34 _hostname_ kwin_x11[909]: QPainter::begin: Paint device returned engine == 0, type: 3
дек 03 12:05:34 _hostname_ plasmashell[952]: kf.service.services: Parsing "exist Exec and ('/usr/bin/yad --center --window-icon=/usr/share/icons/manjaro/maia/maia.svg --image=/usr/share/icons/manjaro/maia/32x32.png --title=Manjaro Log Helper --list --checklist --width=750 --height=655 --text=Selecting any of the boxes below (except the last two)\\nwill add that particular log to a common log file (<b>/home/_user_/manjaro-log-helper.logs</b>).\\nOnce you have selected the desired boxes, including '<i>Send logs to internet</i>',\\nclick the OK button and you will receive a URL\\nthat tells the internet address of the logs.\\n\\nNote1: personal data is automatically removed from logs before sending to internet.\\nNote2: remove personal data can be removed from the log file by selecting '<i>Remove personal data from logs</i>'.\\nNote3: a list of URLs is stored into folder <b>/home/_user_/.config/manjaro-log-helper.conf</b>.\\n --no-click --multiple --column=Select --column=Log --column=Description false journalctl -b -0 Current Boot messagges false journalctl -b -1 Previous Boot messagges false journalctl -b -2 Second previous Boot messagges false Manjaro install log Manjaro installer log false systemd-analyze blame Boot time false lspci -vnn Displaying information about PCI buses as both number and device false lspci -vt Displaying information about PCI buses as tree-like diagram false lsusb -vt Displaying information about USB buses as a tree-like diagram true inxi -Fxzc0 Hardware informations false <i>Remove personal data from logs</i> Rename personal names to generic names false <i>Send logs to internet</i> Send gathered logs to the internet (personal info always removed)' =~ Exec)" gave: syntax error
дек 03 12:05:34 _hostname_ plasmashell[952]: kf.service.services: Parsing "exist Exec and ('yad --center --window-icon=/usr/share/icons/manjaro/maia/maia.svg --image=/usr/share/icons/manjaro/maia/32x32.png --title=Manjaro Log Helper --list --checklist --width=750 --height=655 --text=Selecting any of the boxes below (except the last two)\\nwill add that particular log to a common log file (<b>/home/_user_/manjaro-log-helper.logs</b>).\\nOnce you have selected the desired boxes, including '<i>Send logs to internet</i>',\\nclick the OK button and you will receive a URL\\nthat tells the internet address of the logs.\\n\\nNote1: personal data is automatically removed from logs before sending to internet.\\nNote2: remove personal data can be removed from the log file by selecting '<i>Remove personal data from logs</i>'.\\nNote3: a list of URLs is stored into folder <b>/home/_user_/.config/manjaro-log-helper.conf</b>.\\n --no-click --multiple --column=Select --column=Log --column=Description false journalctl -b -0 Current Boot messagges false journalctl -b -1 Previous Boot messagges false journalctl -b -2 Second previous Boot messagges false Manjaro install log Manjaro installer log false systemd-analyze blame Boot time false lspci -vnn Displaying information about PCI buses as both number and device false lspci -vt Displaying information about PCI buses as tree-like diagram false lsusb -vt Displaying information about USB buses as a tree-like diagram true inxi -Fxzc0 Hardware informations false <i>Remove personal data from logs</i> Rename personal names to generic names false <i>Send logs to internet</i> Send gathered logs to the internet (personal info always removed)' =~ Exec)" gave: syntax error
дек 03 12:05:38 _hostname_ rtkit-daemon[1068]: Supervising 6 threads of 4 processes of 1 users.
дек 03 12:05:38 _hostname_ rtkit-daemon[1068]: Successfully made thread 6647 of process 3845 owned by '1000' RT at priority 10.
дек 03 12:05:38 _hostname_ rtkit-daemon[1068]: Supervising 7 threads of 5 processes of 1 users.
дек 03 12:07:19 _hostname_ kwin_x11[909]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32196, resource id: 56623111, major code: 15 (QueryTree), minor code: 0
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: Listener adapter polkit_qt_listener_initiate_authentication
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: GSimpleAsyncResult: 0x5593a7a251e0
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: polkit_qt_listener_initiate_authentication callback for 0x5593a79fcc00
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: Initiating authentication
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: Message of action: "Authentication is needed to run `/usr/bin/bash' as the super user"
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: Action description has been found
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: WinId of the dialog is 29360134 29360134
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: WinId of the shown dialog is 29360134 29360134
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: Trying again
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: REQUEST
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: Request: "Password: "
дек 03 12:07:22 _hostname_ polkit-kde-authentication-agent-1[962]: "Password: "
дек 03 12:07:23 _hostname_ kwin_x11[909]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
дек 03 12:07:23 _hostname_ kwin_x11[909]: QPainter::begin: Paint device returned engine == 0, type: 3
дек 03 12:07:26 _hostname_ polkit-kde-authentication-agent-1[962]: Dialog accepted
дек 03 12:07:26 _hostname_ audit[6845]: USER_AUTH pid=6845 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="_user_" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
дек 03 12:07:26 _hostname_ kernel: audit: type=1100 audit(1606986446.410:64): pid=6845 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="_user_" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
дек 03 12:07:26 _hostname_ kernel: audit: type=1101 audit(1606986446.410:65): pid=6845 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="_user_" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
дек 03 12:07:26 _hostname_ audit[6845]: USER_ACCT pid=6845 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="_user_" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
дек 03 12:07:26 _hostname_ dbus-daemon[408]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.301' (uid=0 pid=6845 comm="/usr/lib/polkit-1/polkit-agent-helper-1 _user_ ")
дек 03 12:07:26 _hostname_ dbus-daemon[408]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
дек 03 12:07:26 _hostname_ polkit-agent-helper-1[6845]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
дек 03 12:07:26 _hostname_ polkit-kde-authentication-agent-1[962]: COMPLETED
дек 03 12:07:26 _hostname_ polkit-kde-authentication-agent-1[962]: Completed: true
дек 03 12:07:26 _hostname_ polkit-kde-authentication-agent-1[962]: Finishing obtaining privileges
дек 03 12:07:26 _hostname_ polkit-kde-authentication-agent-1[962]: Listener adapter polkit_qt_listener_initiate_authentication_finish
дек 03 12:07:26 _hostname_ polkit-kde-authentication-agent-1[962]: polkit_qt_listener_initiate_authentication_finish callback for 0x5593a79fcc00
дек 03 12:07:26 _hostname_ polkit-kde-authentication-agent-1[962]: Finish obtain authorization: true
дек 03 12:07:26 _hostname_ polkitd[410]: Operator of unix-session:1 successfully authenticated as unix-user:_user_ to gain ONE-SHOT authorization for action org.freedesktop.policykit.exec for unix-process:6529:309901 [/bin/bash /usr/bin/mlh] (owned by unix-user:_user_)
дек 03 12:07:26 _hostname_ pkexec[6838]: pam_unix(polkit-1:session): session opened for user root(uid=0) by (uid=1000)
дек 03 12:07:26 _hostname_ audit[6838]: USER_START pid=6838 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
дек 03 12:07:26 _hostname_ pkexec[6838]: _user_: Executing command [USER=root] [TTY=unknown] [CWD=/home/_user_] [COMMAND=/usr/bin/bash -c : ; echo '#################### journalctl -b -0 ########################' >> /home/_user_/manjaro-log-helper.logs ; journalctl -b -0 >> /home/_user_/manjaro-log-helper.logs ; echo '' >> /home/_user_/manjaro-log-helper.logs ; echo '#################### journalctl -b -1 ########################' >> /home/_user_/manjaro-log-helper.logs ; journalctl -b -1 >> /home/_user_/manjaro-log-helper.logs ; echo '' >> /home/_user_/manjaro-log-helper.logs]
дек 03 12:07:26 _hostname_ kernel: audit: type=1105 audit(1606986446.440:66): pid=6838 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
part 1/2
journalctl -b -1 (zombie boot?)
-- Logs begin at Sat 2020-11-28 15:11:57 MSK, end at Thu 2020-12-03 12:07:26 MSK. --
дек 03 11:10:53 _hostname_ kernel: microcode: microcode updated early to revision 0x21, date = 2019-02-13
дек 03 11:10:53 _hostname_ kernel: Linux version 5.9.11-3-MANJARO (builduser@development) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Sat Nov 28 09:08:57 UTC 2020
дек 03 11:10:53 _hostname_ kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=7c307857-9eea-4659-a814-d37ae3ee26a3 rw quiet resume=UUID=1c035312-8349-4225-9744-79fff163f918 udev.log_priority=3
дек 03 11:10:53 _hostname_ kernel: KERNEL supported cpus:
дек 03 11:10:53 _hostname_ kernel: Intel GenuineIntel
дек 03 11:10:53 _hostname_ kernel: AMD AuthenticAMD
дек 03 11:10:53 _hostname_ kernel: Hygon HygonGenuine
дек 03 11:10:53 _hostname_ kernel: Centaur CentaurHauls
дек 03 11:10:53 _hostname_ kernel: zhaoxin Shanghai
дек 03 11:10:53 _hostname_ kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
дек 03 11:10:53 _hostname_ kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
дек 03 11:10:53 _hostname_ kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
дек 03 11:10:53 _hostname_ kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
дек 03 11:10:53 _hostname_ kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
дек 03 11:10:53 _hostname_ kernel: BIOS-provided physical RAM map:
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x0000000040005000-0x00000000d9861fff] usable
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000d9862000-0x00000000d9f5ffff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000d9f60000-0x00000000d9feafff] usable
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000d9feb000-0x00000000da087fff] ACPI NVS
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000da088000-0x00000000da6b6fff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000da6b7000-0x00000000da6b7fff] usable
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000da6b8000-0x00000000da6fafff] ACPI NVS
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000da6fb000-0x00000000dadb0fff] usable
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000dadb1000-0x00000000daff2fff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000daff3000-0x00000000daffffff] usable
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000db800000-0x00000000df9fffff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
дек 03 11:10:53 _hostname_ kernel: BIOS-e820: [mem 0x0000000100000000-0x000000011f5fffff] usable
дек 03 11:10:53 _hostname_ kernel: NX (Execute Disable) protection: active
дек 03 11:10:53 _hostname_ kernel: SMBIOS 2.7 present.
дек 03 11:10:53 _hostname_ kernel: DMI: CLEVO CO. W240EU/W250EUQ/W270EUQ /W240EU/W250EUQ/W270EUQ , BIOS 4.6.5 05/09/2013
дек 03 11:10:53 _hostname_ kernel: tsc: Fast TSC calibration using PIT
дек 03 11:10:53 _hostname_ kernel: tsc: Detected 2494.245 MHz processor
дек 03 11:10:53 _hostname_ kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
дек 03 11:10:53 _hostname_ kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
дек 03 11:10:53 _hostname_ kernel: last_pfn = 0x11f600 max_arch_pfn = 0x400000000
дек 03 11:10:53 _hostname_ kernel: MTRR default type: uncachable
дек 03 11:10:53 _hostname_ kernel: MTRR fixed ranges enabled:
дек 03 11:10:53 _hostname_ kernel: 00000-9FFFF write-back
дек 03 11:10:53 _hostname_ kernel: A0000-BFFFF uncachable
дек 03 11:10:53 _hostname_ kernel: C0000-CFFFF write-protect
дек 03 11:10:53 _hostname_ kernel: D0000-E7FFF uncachable
дек 03 11:10:53 _hostname_ kernel: E8000-FFFFF write-protect
дек 03 11:10:53 _hostname_ kernel: MTRR variable ranges enabled:
дек 03 11:10:53 _hostname_ kernel: 0 base 000000000 mask F00000000 write-back
дек 03 11:10:53 _hostname_ kernel: 1 base 100000000 mask FE0000000 write-back
дек 03 11:10:53 _hostname_ kernel: 2 base 0E0000000 mask FE0000000 uncachable
дек 03 11:10:53 _hostname_ kernel: 3 base 0DC000000 mask FFC000000 uncachable
дек 03 11:10:53 _hostname_ kernel: 4 base 0DB800000 mask FFF800000 uncachable
дек 03 11:10:53 _hostname_ kernel: 5 base 11F800000 mask FFF800000 uncachable
дек 03 11:10:53 _hostname_ kernel: 6 base 11F600000 mask FFFE00000 uncachable
дек 03 11:10:53 _hostname_ kernel: 7 disabled
дек 03 11:10:53 _hostname_ kernel: 8 disabled
дек 03 11:10:53 _hostname_ kernel: 9 disabled
дек 03 11:10:53 _hostname_ kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
дек 03 11:10:53 _hostname_ kernel: total RAM covered: 4014M
дек 03 11:10:53 _hostname_ kernel: Found optimal setting for mtrr clean up
дек 03 11:10:53 _hostname_ kernel: gran_size: 64K chunk_size: 128M num_reg: 8 lose cover RAM: 0G
дек 03 11:10:53 _hostname_ kernel: e820: update [mem 0xdb800000-0xffffffff] usable ==> reserved
дек 03 11:10:53 _hostname_ kernel: last_pfn = 0xdb000 max_arch_pfn = 0x400000000
дек 03 11:10:53 _hostname_ kernel: found SMP MP-table at [mem 0x000fd770-0x000fd77f]
дек 03 11:10:53 _hostname_ kernel: check: Scanning 1 areas for low memory corruption
дек 03 11:10:53 _hostname_ kernel: RAMDISK: [mem 0x36637000-0x37312fff]
дек 03 11:10:53 _hostname_ kernel: ACPI: Early table checksum verification disabled
дек 03 11:10:53 _hostname_ kernel: ACPI: RSDP 0x00000000000F0490 000024 (v02 Intel )
дек 03 11:10:53 _hostname_ kernel: ACPI: XSDT 0x00000000DA078078 000074 (v01 Intel CHIEF 01072009 AMI 00010013)
дек 03 11:10:53 _hostname_ kernel: ACPI: FACP 0x00000000DA081740 00010C (v05 Intel CHIEF 01072009 AMI 00010013)
дек 03 11:10:53 _hostname_ kernel: ACPI: DSDT 0x00000000DA078188 0095B1 (v02 Intel CHIEF 00000023 INTL 20051117)
дек 03 11:10:53 _hostname_ kernel: ACPI: FACS 0x00000000DA086080 000040
дек 03 11:10:53 _hostname_ kernel: ACPI: APIC 0x00000000DA081850 000072 (v03 Intel CHIEF 01072009 AMI 00010013)
дек 03 11:10:53 _hostname_ kernel: ACPI: FPDT 0x00000000DA0818C8 000044 (v01 Intel CHIEF 01072009 AMI 00010013)
дек 03 11:10:53 _hostname_ kernel: ACPI: MCFG 0x00000000DA081910 00003C (v01 Intel CHIEF 01072009 MSFT 00000097)
дек 03 11:10:53 _hostname_ kernel: ACPI: SSDT 0x00000000DA081950 000F92 (v01 TrmRef PtidDevc 00001000 INTL 20091112)
дек 03 11:10:53 _hostname_ kernel: ACPI: SSDT 0x00000000DA0828E8 0002E7 (v01 Intel_ AoacTabl 00001000 INTL 20091112)
дек 03 11:10:53 _hostname_ kernel: ACPI: HPET 0x00000000DA082BD0 000038 (v01 Intel CHIEF 01072009 AMI. 00000005)
дек 03 11:10:53 _hostname_ kernel: ACPI: SSDT 0x00000000DA082C08 000315 (v01 SataRe SataTabl 00001000 INTL 20091112)
дек 03 11:10:53 _hostname_ kernel: ACPI: SSDT 0x00000000DA082F20 000926 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
дек 03 11:10:53 _hostname_ kernel: ACPI: SSDT 0x00000000DA083848 000B22 (v01 PmRef CpuPm 00003000 INTL 20051117)
дек 03 11:10:53 _hostname_ kernel: ACPI: Local APIC address 0xfee00000
дек 03 11:10:53 _hostname_ kernel: No NUMA configuration found
дек 03 11:10:53 _hostname_ kernel: Faking a node at [mem 0x0000000000000000-0x000000011f5fffff]
дек 03 11:10:53 _hostname_ kernel: NODE_DATA(0) allocated [mem 0x11f5fa000-0x11f5fdfff]
дек 03 11:10:53 _hostname_ kernel: Zone ranges:
дек 03 11:10:53 _hostname_ kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
дек 03 11:10:53 _hostname_ kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
дек 03 11:10:53 _hostname_ kernel: Normal [mem 0x0000000100000000-0x000000011f5fffff]
дек 03 11:10:53 _hostname_ kernel: Device empty
дек 03 11:10:53 _hostname_ kernel: Movable zone start for each node
дек 03 11:10:53 _hostname_ kernel: Early memory node ranges
дек 03 11:10:53 _hostname_ kernel: node 0: [mem 0x0000000000001000-0x000000000009cfff]
дек 03 11:10:53 _hostname_ kernel: node 0: [mem 0x0000000000100000-0x000000001fffffff]
дек 03 11:10:53 _hostname_ kernel: node 0: [mem 0x0000000020200000-0x0000000040003fff]
дек 03 11:10:53 _hostname_ kernel: node 0: [mem 0x0000000040005000-0x00000000d9861fff]
дек 03 11:10:53 _hostname_ kernel: node 0: [mem 0x00000000d9f60000-0x00000000d9feafff]
дек 03 11:10:53 _hostname_ kernel: node 0: [mem 0x00000000da6b7000-0x00000000da6b7fff]
дек 03 11:10:53 _hostname_ kernel: node 0: [mem 0x00000000da6fb000-0x00000000dadb0fff]
дек 03 11:10:53 _hostname_ kernel: node 0: [mem 0x00000000daff3000-0x00000000daffffff]
дек 03 11:10:53 _hostname_ kernel: node 0: [mem 0x0000000100000000-0x000000011f5fffff]
дек 03 11:10:53 _hostname_ kernel: Zeroed struct page in unavailable ranges: 27828 pages
дек 03 11:10:53 _hostname_ kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000011f5fffff]
дек 03 11:10:53 _hostname_ kernel: On node 0 totalpages: 1020748
дек 03 11:10:53 _hostname_ kernel: DMA zone: 64 pages used for memmap
дек 03 11:10:53 _hostname_ kernel: DMA zone: 21 pages reserved
дек 03 11:10:53 _hostname_ kernel: DMA zone: 3996 pages, LIFO batch:0
дек 03 11:10:53 _hostname_ kernel: DMA32 zone: 13879 pages used for memmap
дек 03 11:10:53 _hostname_ kernel: DMA32 zone: 888240 pages, LIFO batch:63
дек 03 11:10:53 _hostname_ kernel: Normal zone: 2008 pages used for memmap
дек 03 11:10:53 _hostname_ kernel: Normal zone: 128512 pages, LIFO batch:31
дек 03 11:10:53 _hostname_ kernel: Reserving Intel graphics memory at [mem 0xdba00000-0xdf9fffff]
дек 03 11:10:53 _hostname_ kernel: ACPI: PM-Timer IO Port: 0x408
дек 03 11:10:53 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
дек 03 11:10:53 _hostname_ kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
дек 03 11:10:53 _hostname_ kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
дек 03 11:10:53 _hostname_ kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
дек 03 11:10:53 _hostname_ kernel: ACPI: IRQ0 used by override.
дек 03 11:10:53 _hostname_ kernel: ACPI: IRQ9 used by override.
дек 03 11:10:53 _hostname_ kernel: Using ACPI (MADT) for SMP configuration information
дек 03 11:10:53 _hostname_ kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
дек 03 11:10:53 _hostname_ kernel: TSC deadline timer available
дек 03 11:10:53 _hostname_ kernel: smpboot: Allowing 4 CPUs, 0 hotplug CPUs
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x20000000-0x201fffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x40004000-0x40004fff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xd9862000-0xd9f5ffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xd9feb000-0xda087fff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xda088000-0xda6b6fff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xda6b8000-0xda6fafff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xdadb1000-0xdaff2fff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xdb000000-0xdb7fffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xdb800000-0xdf9fffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xdfa00000-0xf7ffffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
дек 03 11:10:53 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
дек 03 11:10:53 _hostname_ kernel: [mem 0xdfa00000-0xf7ffffff] available for PCI devices
дек 03 11:10:53 _hostname_ kernel: Booting paravirtualized kernel on bare hardware
дек 03 11:10:53 _hostname_ kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
дек 03 11:10:53 _hostname_ kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
дек 03 11:10:53 _hostname_ kernel: percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
дек 03 11:10:53 _hostname_ kernel: pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
дек 03 11:10:53 _hostname_ kernel: pcpu-alloc: [0] 0 1 2 3
дек 03 11:10:53 _hostname_ kernel: Built 1 zonelists, mobility grouping on. Total pages: 1004776
дек 03 11:10:53 _hostname_ kernel: Policy zone: Normal
дек 03 11:10:53 _hostname_ kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=7c307857-9eea-4659-a814-d37ae3ee26a3 rw quiet resume=UUID=1c035312-8349-4225-9744-79fff163f918 udev.log_priority=3
дек 03 11:10:53 _hostname_ kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
дек 03 11:10:53 _hostname_ kernel: Memory: 3898088K/4082992K available (14339K kernel code, 1529K rwdata, 4760K rodata, 1664K init, 2888K bss, 184644K reserved, 0K cma-reserved)
дек 03 11:10:53 _hostname_ kernel: random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
дек 03 11:10:53 _hostname_ kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
дек 03 11:10:53 _hostname_ kernel: Kernel/User page tables isolation: enabled
дек 03 11:10:53 _hostname_ kernel: ftrace: allocating 41080 entries in 161 pages
дек 03 11:10:53 _hostname_ kernel: ftrace: allocated 161 pages with 3 groups
дек 03 11:10:53 _hostname_ kernel: rcu: Preemptible hierarchical RCU implementation.
дек 03 11:10:53 _hostname_ kernel: rcu: RCU dyntick-idle grace-period acceleration is enabled.
дек 03 11:10:53 _hostname_ kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
дек 03 11:10:53 _hostname_ kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
дек 03 11:10:53 _hostname_ kernel: Trampoline variant of Tasks RCU enabled.
дек 03 11:10:53 _hostname_ kernel: Rude variant of Tasks RCU enabled.
дек 03 11:10:53 _hostname_ kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
дек 03 11:10:53 _hostname_ kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
дек 03 11:10:53 _hostname_ kernel: NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
дек 03 11:10:53 _hostname_ kernel: Console: colour dummy device 80x25
дек 03 11:10:53 _hostname_ kernel: printk: console [tty0] enabled
дек 03 11:10:53 _hostname_ kernel: ACPI: Core revision 20200717
дек 03 11:10:53 _hostname_ kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
дек 03 11:10:53 _hostname_ kernel: APIC: Switch to symmetric I/O mode setup
дек 03 11:10:53 _hostname_ kernel: x2apic: IRQ remapping doesn't support X2APIC mode
дек 03 11:10:53 _hostname_ kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
дек 03 11:10:53 _hostname_ kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x23f3fd34342, max_idle_ns: 440795309589 ns
дек 03 11:10:53 _hostname_ kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4990.34 BogoMIPS (lpj=8314150)
дек 03 11:10:53 _hostname_ kernel: pid_max: default: 32768 minimum: 301
дек 03 11:10:53 _hostname_ kernel: LSM: Security Framework initializing
дек 03 11:10:53 _hostname_ kernel: Yama: becoming mindful.
дек 03 11:10:53 _hostname_ kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: mce: CPU0: Thermal monitoring enabled (TM1)
дек 03 11:10:53 _hostname_ kernel: process: using mwait in idle threads
дек 03 11:10:53 _hostname_ kernel: Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
дек 03 11:10:53 _hostname_ kernel: Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
дек 03 11:10:53 _hostname_ kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
дек 03 11:10:53 _hostname_ kernel: Spectre V2 : Mitigation: Full generic retpoline
дек 03 11:10:53 _hostname_ kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
дек 03 11:10:53 _hostname_ kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
дек 03 11:10:53 _hostname_ kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
дек 03 11:10:53 _hostname_ kernel: Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
дек 03 11:10:53 _hostname_ kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
дек 03 11:10:53 _hostname_ kernel: MDS: Mitigation: Clear CPU buffers
дек 03 11:10:53 _hostname_ kernel: Freeing SMP alternatives memory: 32K
дек 03 11:10:53 _hostname_ kernel: smpboot: CPU0: Intel(R) Core(TM) i3-3120M CPU @ 2.50GHz (family: 0x6, model: 0x3a, stepping: 0x9)
дек 03 11:10:53 _hostname_ kernel: Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
дек 03 11:10:53 _hostname_ kernel: ... version: 3
дек 03 11:10:53 _hostname_ kernel: ... bit width: 48
дек 03 11:10:53 _hostname_ kernel: ... generic registers: 4
дек 03 11:10:53 _hostname_ kernel: ... value mask: 0000ffffffffffff
дек 03 11:10:53 _hostname_ kernel: ... max period: 00007fffffffffff
дек 03 11:10:53 _hostname_ kernel: ... fixed-purpose events: 3
дек 03 11:10:53 _hostname_ kernel: ... event mask: 000000070000000f
дек 03 11:10:53 _hostname_ kernel: rcu: Hierarchical SRCU implementation.
дек 03 11:10:53 _hostname_ kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
дек 03 11:10:53 _hostname_ kernel: smp: Bringing up secondary CPUs ...
дек 03 11:10:53 _hostname_ kernel: x86: Booting SMP configuration:
дек 03 11:10:53 _hostname_ kernel: .... node #0, CPUs: #1 #2
дек 03 11:10:53 _hostname_ kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
дек 03 11:10:53 _hostname_ kernel: #3
дек 03 11:10:53 _hostname_ kernel: smp: Brought up 1 node, 4 CPUs
дек 03 11:10:53 _hostname_ kernel: smpboot: Max logical packages: 1
дек 03 11:10:53 _hostname_ kernel: smpboot: Total of 4 processors activated (19961.37 BogoMIPS)
дек 03 11:10:53 _hostname_ kernel: devtmpfs: initialized
дек 03 11:10:53 _hostname_ kernel: x86/mm: Memory block size: 128MB
дек 03 11:10:53 _hostname_ kernel: PM: Registering ACPI NVS region [mem 0xd9feb000-0xda087fff] (643072 bytes)
дек 03 11:10:53 _hostname_ kernel: PM: Registering ACPI NVS region [mem 0xda6b8000-0xda6fafff] (274432 bytes)
дек 03 11:10:53 _hostname_ kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
дек 03 11:10:53 _hostname_ kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: pinctrl core: initialized pinctrl subsystem
дек 03 11:10:53 _hostname_ kernel: PM: RTC time: 08:10:49, date: 2020-12-03
дек 03 11:10:53 _hostname_ kernel: NET: Registered protocol family 16
дек 03 11:10:53 _hostname_ kernel: DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
дек 03 11:10:53 _hostname_ kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
дек 03 11:10:53 _hostname_ kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
дек 03 11:10:53 _hostname_ kernel: audit: initializing netlink subsys (disabled)
дек 03 11:10:53 _hostname_ kernel: audit: type=2000 audit(1606983049.026:1): state=initialized audit_enabled=0 res=1
дек 03 11:10:53 _hostname_ kernel: thermal_sys: Registered thermal governor 'fair_share'
дек 03 11:10:53 _hostname_ kernel: thermal_sys: Registered thermal governor 'bang_bang'
дек 03 11:10:53 _hostname_ kernel: thermal_sys: Registered thermal governor 'step_wise'
дек 03 11:10:53 _hostname_ kernel: thermal_sys: Registered thermal governor 'user_space'
дек 03 11:10:53 _hostname_ kernel: thermal_sys: Registered thermal governor 'power_allocator'
дек 03 11:10:53 _hostname_ kernel: cpuidle: using governor ladder
дек 03 11:10:53 _hostname_ kernel: cpuidle: using governor menu
дек 03 11:10:53 _hostname_ kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
дек 03 11:10:53 _hostname_ kernel: ACPI: bus type PCI registered
дек 03 11:10:53 _hostname_ kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
дек 03 11:10:53 _hostname_ kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
дек 03 11:10:53 _hostname_ kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
дек 03 11:10:53 _hostname_ kernel: PCI: Using configuration type 1 for base access
дек 03 11:10:53 _hostname_ kernel: core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
дек 03 11:10:53 _hostname_ kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
дек 03 11:10:53 _hostname_ kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
дек 03 11:10:53 _hostname_ kernel: ACPI: Added _OSI(Module Device)
дек 03 11:10:53 _hostname_ kernel: ACPI: Added _OSI(Processor Device)
дек 03 11:10:53 _hostname_ kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
дек 03 11:10:53 _hostname_ kernel: ACPI: Added _OSI(Processor Aggregator Device)
дек 03 11:10:53 _hostname_ kernel: ACPI: Added _OSI(Linux-Dell-Video)
дек 03 11:10:53 _hostname_ kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
дек 03 11:10:53 _hostname_ kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
дек 03 11:10:53 _hostname_ kernel: ACPI: 6 ACPI AML tables successfully acquired and loaded
дек 03 11:10:53 _hostname_ kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
дек 03 11:10:53 _hostname_ kernel: ACPI: Dynamic OEM Table Load:
дек 03 11:10:53 _hostname_ kernel: ACPI: SSDT 0xFFFF97AD5A054000 00083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
дек 03 11:10:53 _hostname_ kernel: ACPI: SSDT 0xFFFF97AD5A05B800 000303 (v01 PmRef ApIst 00003000 INTL 20051117)
дек 03 11:10:53 _hostname_ kernel: ACPI: SSDT 0xFFFF97AD5A224A00 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
дек 03 11:10:53 _hostname_ kernel: ACPI: EC: EC started
дек 03 11:10:53 _hostname_ kernel: ACPI: EC: interrupt blocked
дек 03 11:10:53 _hostname_ kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
дек 03 11:10:53 _hostname_ kernel: ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC used to handle transactions
дек 03 11:10:53 _hostname_ kernel: ACPI: Interpreter enabled
дек 03 11:10:53 _hostname_ kernel: ACPI: (supports S0 S3 S4 S5)
дек 03 11:10:53 _hostname_ kernel: ACPI: Using IOAPIC for interrupt routing
дек 03 11:10:53 _hostname_ kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
дек 03 11:10:53 _hostname_ kernel: ACPI: Enabled 16 GPEs in block 00 to 3F
дек 03 11:10:53 _hostname_ kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
дек 03 11:10:53 _hostname_ kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
дек 03 11:10:53 _hostname_ kernel: acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
дек 03 11:10:53 _hostname_ kernel: acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
дек 03 11:10:53 _hostname_ kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
дек 03 11:10:53 _hostname_ kernel: PCI host bridge to bus 0000:00
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:14.0: reg 0x10: [mem 0xf7e00000-0xf7e0ffff 64bit]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:16.0: reg 0x10: [mem 0xf7e1a000-0xf7e1a00f 64bit]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1a.0: reg 0x10: [mem 0xf7e18000-0xf7e183ff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xf7e10000-0xf7e13fff 64bit]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.2: [8086:1e14] type 01 class 0x060400
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.3: [8086:1e16] type 01 class 0x060400
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xf7e17000-0xf7e173ff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.0: [8086:1e59] type 00 class 0x060100
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.2: reg 0x10: [io 0xf0b0-0xf0b7]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.2: reg 0x14: [io 0xf0a0-0xf0a3]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.2: reg 0x18: [io 0xf090-0xf097]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.2: reg 0x1c: [io 0xf080-0xf083]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xf7e16000-0xf7e167ff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.2: PME# supported from D3hot
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xf7e15000-0xf7e150ff 64bit]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.0: PCI bridge to [bus 01]
дек 03 11:10:53 _hostname_ kernel: pci 0000:02:00.0: [10ec:8723] type 00 class 0x028000
дек 03 11:10:53 _hostname_ kernel: pci 0000:02:00.0: reg 0x10: [io 0xe000-0xe0ff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:02:00.0: reg 0x18: [mem 0xf7d00000-0xf7d03fff 64bit]
дек 03 11:10:53 _hostname_ kernel: pci 0000:02:00.0: supports D1 D2
дек 03 11:10:53 _hostname_ kernel: pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.2: PCI bridge to [bus 02]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.0: [10ec:5289] type 00 class 0xff0000
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.0: reg 0x10: [mem 0xf7c00000-0xf7c0ffff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.0: supports D1 D2
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.2: [10ec:8168] type 00 class 0x020000
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.2: reg 0x10: [io 0xd000-0xd0ff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.2: reg 0x18: [mem 0xf0004000-0xf0004fff 64bit pref]
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.2: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.2: supports D1 D2
дек 03 11:10:53 _hostname_ kernel: pci 0000:03:00.2: PME# supported from D0 D1 D2 D3hot D3cold
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.3: PCI bridge to [bus 03]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.3: bridge window [mem 0xf7c00000-0xf7cfffff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:1c.3: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
дек 03 11:10:53 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
дек 03 11:10:53 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
дек 03 11:10:53 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 10 11 12 14 15)
дек 03 11:10:53 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
дек 03 11:10:53 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
дек 03 11:10:53 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
дек 03 11:10:53 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 10 11 12 14 15)
дек 03 11:10:53 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 *4 5 6 10 11 12 14 15)
дек 03 11:10:53 _hostname_ kernel: ACPI: EC: interrupt unblocked
дек 03 11:10:53 _hostname_ kernel: ACPI: EC: event unblocked
дек 03 11:10:53 _hostname_ kernel: ACPI: EC: GPE=0x17
дек 03 11:10:53 _hostname_ kernel: ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC initialization complete
дек 03 11:10:53 _hostname_ kernel: ACPI: \_SB_.PCI0.LPCB.EC__: EC: Used to handle transactions and events
дек 03 11:10:53 _hostname_ kernel: iommu: Default domain type: Translated
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:02.0: vgaarb: bridge control possible
дек 03 11:10:53 _hostname_ kernel: vgaarb: loaded
дек 03 11:10:53 _hostname_ kernel: SCSI subsystem initialized
дек 03 11:10:53 _hostname_ kernel: libata version 3.00 loaded.
дек 03 11:10:53 _hostname_ kernel: ACPI: bus type USB registered
дек 03 11:10:53 _hostname_ kernel: usbcore: registered new interface driver usbfs
дек 03 11:10:53 _hostname_ kernel: usbcore: registered new interface driver hub
дек 03 11:10:53 _hostname_ kernel: usbcore: registered new device driver usb
дек 03 11:10:53 _hostname_ kernel: pps_core: LinuxPPS API ver. 1 registered
дек 03 11:10:53 _hostname_ kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
дек 03 11:10:53 _hostname_ kernel: PTP clock support registered
дек 03 11:10:53 _hostname_ kernel: EDAC MC: Ver: 3.0.0
дек 03 11:10:53 _hostname_ kernel: NetLabel: Initializing
дек 03 11:10:53 _hostname_ kernel: NetLabel: domain hash size = 128
дек 03 11:10:53 _hostname_ kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
дек 03 11:10:53 _hostname_ kernel: NetLabel: unlabeled traffic allowed by default
дек 03 11:10:53 _hostname_ kernel: PCI: Using ACPI for IRQ routing
дек 03 11:10:53 _hostname_ kernel: PCI: pci_cache_line_size set to 64 bytes
дек 03 11:10:53 _hostname_ kernel: e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
дек 03 11:10:53 _hostname_ kernel: e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
дек 03 11:10:53 _hostname_ kernel: e820: reserve RAM buffer [mem 0xd9862000-0xdbffffff]
дек 03 11:10:53 _hostname_ kernel: e820: reserve RAM buffer [mem 0xd9feb000-0xdbffffff]
дек 03 11:10:53 _hostname_ kernel: e820: reserve RAM buffer [mem 0xda6b8000-0xdbffffff]
дек 03 11:10:53 _hostname_ kernel: e820: reserve RAM buffer [mem 0xdadb1000-0xdbffffff]
дек 03 11:10:53 _hostname_ kernel: e820: reserve RAM buffer [mem 0xdb000000-0xdbffffff]
дек 03 11:10:53 _hostname_ kernel: e820: reserve RAM buffer [mem 0x11f600000-0x11fffffff]
дек 03 11:10:53 _hostname_ kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
дек 03 11:10:53 _hostname_ kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
дек 03 11:10:53 _hostname_ kernel: clocksource: Switched to clocksource tsc-early
дек 03 11:10:53 _hostname_ kernel: VFS: Disk quotas dquot_6.6.0
дек 03 11:10:53 _hostname_ kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
дек 03 11:10:53 _hostname_ kernel: pnp: PnP ACPI init
дек 03 11:10:53 _hostname_ kernel: system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
дек 03 11:10:53 _hostname_ kernel: system 00:01: [io 0x0680-0x069f] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:01: [io 0x1000-0x100f] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:01: [io 0xffff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:01: [io 0x0400-0x0453] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:01: [io 0x0458-0x047f] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:01: [io 0x0500-0x057f] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:01: [io 0x164e-0x164f] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:01: [io 0x3322-0x3323] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
дек 03 11:10:53 _hostname_ kernel: pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
дек 03 11:10:53 _hostname_ kernel: system 00:03: [io 0x0454-0x0457] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
дек 03 11:10:53 _hostname_ kernel: pnp 00:04: Plug and Play ACPI device, IDs PNP0303 (active)
дек 03 11:10:53 _hostname_ kernel: pnp 00:05: Plug and Play ACPI device, IDs ETD0403 PNP0f13 (active)
дек 03 11:10:53 _hostname_ kernel: system 00:06: [io 0x04d0-0x04d1] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xfed90000-0xfed93fff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xff000000-0xffffffff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: [mem 0xdfa00000-0xdfa00fff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
дек 03 11:10:53 _hostname_ kernel: system 00:08: [mem 0x20000000-0x201fffff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:08: [mem 0x40004000-0x40004fff] has been reserved
дек 03 11:10:53 _hostname_ kernel: system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
дек 03 11:10:53 _hostname_ kernel: pnp: PnP ACPI: found 9 devices
дек 03 11:10:53 _hostname_ kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
дек 03 11:10:53 _hostname_ kernel: NET: Registered protocol family 2
дек 03 11:10:53 _hostname_ kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: TCP: Hash tables configured (established 32768 bind 32768)
дек 03 11:10:53 _hostname_ kernel: MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
дек 03 11:10:53 _hostname_ kernel: NET: Registered protocol family 44
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff window]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
дек 03 11:10:53 _hostname_ kernel: pci_bus 0000:03: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
дек 03 11:10:53 _hostname_ kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
дек 03 11:10:53 _hostname_ kernel: pci 0000:02:00.0: CLS mismatch (64 != 32), using 64 bytes
дек 03 11:10:53 _hostname_ kernel: Trying to unpack rootfs image as initramfs...
дек 03 11:10:53 _hostname_ kernel: Freeing initrd memory: 13168K
дек 03 11:10:53 _hostname_ kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
дек 03 11:10:53 _hostname_ kernel: software IO TLB: mapped [mem 0xd5862000-0xd9862000] (64MB)
дек 03 11:10:53 _hostname_ kernel: check: Scanning for low memory corruption every 60 seconds
дек 03 11:10:53 _hostname_ kernel: Initialise system trusted keyrings
дек 03 11:10:53 _hostname_ kernel: Key type blacklist registered
дек 03 11:10:53 _hostname_ kernel: workingset: timestamp_bits=41 max_order=20 bucket_order=0
дек 03 11:10:53 _hostname_ kernel: zbud: loaded
дек 03 11:10:53 _hostname_ kernel: Key type asymmetric registered
дек 03 11:10:53 _hostname_ kernel: Asymmetric key parser 'x509' registered
дек 03 11:10:53 _hostname_ kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
дек 03 11:10:53 _hostname_ kernel: io scheduler mq-deadline registered
дек 03 11:10:53 _hostname_ kernel: io scheduler kyber registered
дек 03 11:10:53 _hostname_ kernel: io scheduler bfq registered
дек 03 11:10:53 _hostname_ kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
дек 03 11:10:53 _hostname_ kernel: vesafb: mode is 1366x768x32, linelength=5504, pages=0
дек 03 11:10:53 _hostname_ kernel: vesafb: scrolling: redraw
дек 03 11:10:53 _hostname_ kernel: vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
дек 03 11:10:53 _hostname_ kernel: vesafb: framebuffer at 0xe0000000, mapped to 0x(____ptrval____), using 4160k, total 4160k
дек 03 11:10:53 _hostname_ kernel: fbcon: Deferring console take-over
дек 03 11:10:53 _hostname_ kernel: fb0: VESA VGA frame buffer device
дек 03 11:10:53 _hostname_ kernel: intel_idle: MWAIT substates: 0x21120
дек 03 11:10:53 _hostname_ kernel: intel_idle: v0.5.1 model 0x3A
дек 03 11:10:53 _hostname_ kernel: intel_idle: Local APIC timer is reliable in all C-states
дек 03 11:10:53 _hostname_ kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
дек 03 11:10:53 _hostname_ kernel: ACPI: Power Button [PWRB]
дек 03 11:10:53 _hostname_ kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
дек 03 11:10:53 _hostname_ kernel: ACPI: Sleep Button [SLPB]
дек 03 11:10:53 _hostname_ kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
дек 03 11:10:53 _hostname_ kernel: ACPI: Lid Switch [LID0]
дек 03 11:10:53 _hostname_ kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
дек 03 11:10:53 _hostname_ kernel: ACPI: Power Button [PWRF]
дек 03 11:10:53 _hostname_ kernel: thermal LNXTHERM:00: registered as thermal_zone0
дек 03 11:10:53 _hostname_ kernel: ACPI: Thermal Zone [TZ0] (35 C)
дек 03 11:10:53 _hostname_ kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
дек 03 11:10:53 _hostname_ kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
дек 03 11:10:53 _hostname_ kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system
дек 03 11:10:53 _hostname_ kernel: ahci 0000:00:1f.2: version 3.0
дек 03 11:10:53 _hostname_ kernel: ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
дек 03 11:10:53 _hostname_ kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x15 impl SATA mode
дек 03 11:10:53 _hostname_ kernel: ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ems sxs apst
дек 03 11:10:53 _hostname_ kernel: scsi host0: ahci
дек 03 11:10:53 _hostname_ kernel: scsi host1: ahci
дек 03 11:10:53 _hostname_ kernel: scsi host2: ahci
дек 03 11:10:53 _hostname_ kernel: scsi host3: ahci
дек 03 11:10:53 _hostname_ kernel: scsi host4: ahci
дек 03 11:10:53 _hostname_ kernel: scsi host5: ahci
дек 03 11:10:53 _hostname_ kernel: ata1: SATA max UDMA/133 abar m2048@0xf7e16000 port 0xf7e16100 irq 27
дек 03 11:10:53 _hostname_ kernel: ata2: DUMMY
дек 03 11:10:53 _hostname_ kernel: ata3: SATA max UDMA/133 abar m2048@0xf7e16000 port 0xf7e16200 irq 27
дек 03 11:10:53 _hostname_ kernel: ata4: DUMMY
дек 03 11:10:53 _hostname_ kernel: ata5: SATA max UDMA/133 abar m2048@0xf7e16000 port 0xf7e16300 irq 27
дек 03 11:10:53 _hostname_ kernel: ata6: DUMMY
дек 03 11:10:53 _hostname_ kernel: usbcore: registered new interface driver usbserial_generic
дек 03 11:10:53 _hostname_ kernel: usbserial: USB Serial support registered for generic
дек 03 11:10:53 _hostname_ kernel: rtc_cmos 00:02: registered as rtc0
дек 03 11:10:53 _hostname_ kernel: rtc_cmos 00:02: setting system clock to 2020-12-03T08:10:50 UTC (1606983050)
дек 03 11:10:53 _hostname_ kernel: rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
дек 03 11:10:53 _hostname_ kernel: intel_pstate: Intel P-state driver initializing
дек 03 11:10:53 _hostname_ kernel: ledtrig-cpu: registered to indicate activity on CPUs
дек 03 11:10:53 _hostname_ kernel: ashmem: initialized
дек 03 11:10:53 _hostname_ kernel: drop_monitor: Initializing network drop monitor service
дек 03 11:10:53 _hostname_ kernel: NET: Registered protocol family 10
дек 03 11:10:53 _hostname_ kernel: Segment Routing with IPv6
дек 03 11:10:53 _hostname_ kernel: RPL Segment Routing with IPv6
дек 03 11:10:53 _hostname_ kernel: NET: Registered protocol family 17
дек 03 11:10:53 _hostname_ kernel: microcode: sig=0x306a9, pf=0x10, revision=0x21
дек 03 11:10:53 _hostname_ kernel: microcode: Microcode Update Driver: v2.2.
дек 03 11:10:53 _hostname_ kernel: IPI shorthand broadcast: enabled
дек 03 11:10:53 _hostname_ kernel: sched_clock: Marking stable (1276861579, 188286)->(1291259085, -14209220)
дек 03 11:10:53 _hostname_ kernel: registered taskstats version 1
дек 03 11:10:53 _hostname_ kernel: Loading compiled-in X.509 certificates
дек 03 11:10:53 _hostname_ kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 00c10b0ba9d05395b3960e2a8b3ae7d67466c42a'
дек 03 11:10:53 _hostname_ kernel: zswap: loaded using pool zstd/z3fold
дек 03 11:10:53 _hostname_ kernel: Key type ._fscrypt registered
дек 03 11:10:53 _hostname_ kernel: Key type .fscrypt registered
дек 03 11:10:53 _hostname_ kernel: Key type fscrypt-provisioning registered
дек 03 11:10:53 _hostname_ kernel: PM: Magic number: 0:724:168
дек 03 11:10:53 _hostname_ kernel: acpi device:31: hash matches
дек 03 11:10:53 _hostname_ kernel: RAS: Correctable Errors collector initialized.
дек 03 11:10:53 _hostname_ kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
дек 03 11:10:53 _hostname_ kernel: ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
дек 03 11:10:53 _hostname_ kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
дек 03 11:10:53 _hostname_ kernel: ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
дек 03 11:10:53 _hostname_ kernel: ata1.00: ATA-11: SATA SSD, SBFM61.3, max UDMA/133
дек 03 11:10:53 _hostname_ kernel: ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 32), AA
дек 03 11:10:53 _hostname_ kernel: ata1.00: configured for UDMA/133
дек 03 11:10:53 _hostname_ kernel: scsi 0:0:0:0: Direct-Access ATA SATA SSD 61.3 PQ: 0 ANSI: 5
дек 03 11:10:53 _hostname_ kernel: sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
дек 03 11:10:53 _hostname_ kernel: sd 0:0:0:0: [sda] Write Protect is off
дек 03 11:10:53 _hostname_ kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
дек 03 11:10:53 _hostname_ kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
дек 03 11:10:53 _hostname_ kernel: sda: sda1 sda2
дек 03 11:10:53 _hostname_ kernel: sd 0:0:0:0: [sda] Attached SCSI disk
дек 03 11:10:53 _hostname_ kernel: ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
дек 03 11:10:53 _hostname_ kernel: ata3.00: ATAPI: Slimtype DVD A DS8A9SH, EC61, max UDMA/100
дек 03 11:10:53 _hostname_ kernel: ata3.00: configured for UDMA/100
дек 03 11:10:53 _hostname_ kernel: scsi 2:0:0:0: CD-ROM Slimtype DVD A DS8A9SH EC61 PQ: 0 ANSI: 5
дек 03 11:10:53 _hostname_ kernel: tsc: Refined TSC clocksource calibration: 2494.332 MHz
дек 03 11:10:53 _hostname_ kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23f44f92df3, max_idle_ns: 440795329494 ns
дек 03 11:10:53 _hostname_ kernel: ata5: SATA link down (SStatus 0 SControl 300)
дек 03 11:10:53 _hostname_ kernel: Freeing unused decrypted memory: 2040K
дек 03 11:10:53 _hostname_ kernel: Freeing unused kernel image (initmem) memory: 1664K
дек 03 11:10:53 _hostname_ kernel: Write protecting the kernel read-only data: 22528k
дек 03 11:10:53 _hostname_ kernel: Freeing unused kernel image (text/rodata gap) memory: 2044K
дек 03 11:10:53 _hostname_ kernel: Freeing unused kernel image (rodata/data gap) memory: 1384K
дек 03 11:10:53 _hostname_ kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
дек 03 11:10:53 _hostname_ kernel: x86/mm: Checking user space page tables
дек 03 11:10:53 _hostname_ kernel: Run /init as init process
дек 03 11:10:53 _hostname_ kernel: with arguments:
дек 03 11:10:53 _hostname_ kernel: /init
дек 03 11:10:53 _hostname_ kernel: with environment:
дек 03 11:10:53 _hostname_ kernel: HOME=/
дек 03 11:10:53 _hostname_ kernel: TERM=linux
дек 03 11:10:53 _hostname_ kernel: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
дек 03 11:10:53 _hostname_ kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:ELNM] at 0x60,0x64 irq 1,12
дек 03 11:10:53 _hostname_ kernel: i8042: Detected active multiplexing controller, rev 1.1
дек 03 11:10:53 _hostname_ kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
дек 03 11:10:53 _hostname_ kernel: serio: i8042 AUX0 port at 0x60,0x64 irq 12
дек 03 11:10:53 _hostname_ kernel: serio: i8042 AUX1 port at 0x60,0x64 irq 12
дек 03 11:10:53 _hostname_ kernel: serio: i8042 AUX2 port at 0x60,0x64 irq 12
дек 03 11:10:53 _hostname_ kernel: serio: i8042 AUX3 port at 0x60,0x64 irq 12
дек 03 11:10:53 _hostname_ kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
дек 03 11:10:53 _hostname_ kernel: ehci-pci: EHCI PCI platform driver
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1a.0: EHCI Host Controller
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1a.0: debug port 2
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7e18000
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
дек 03 11:10:53 _hostname_ kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
дек 03 11:10:53 _hostname_ kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
дек 03 11:10:53 _hostname_ kernel: usb usb1: Product: EHCI Host Controller
дек 03 11:10:53 _hostname_ kernel: usb usb1: Manufacturer: Linux 5.9.11-3-MANJARO ehci_hcd
дек 03 11:10:53 _hostname_ kernel: usb usb1: SerialNumber: 0000:00:1a.0
дек 03 11:10:53 _hostname_ kernel: hub 1-0:1.0: USB hub found
дек 03 11:10:53 _hostname_ kernel: hub 1-0:1.0: 2 ports detected
дек 03 11:10:53 _hostname_ kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
дек 03 11:10:53 _hostname_ kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
дек 03 11:10:53 _hostname_ kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
дек 03 11:10:53 _hostname_ kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x000000000000b930
дек 03 11:10:53 _hostname_ kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
дек 03 11:10:53 _hostname_ kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
дек 03 11:10:53 _hostname_ kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
дек 03 11:10:53 _hostname_ kernel: usb usb2: Product: xHCI Host Controller
дек 03 11:10:53 _hostname_ kernel: usb usb2: Manufacturer: Linux 5.9.11-3-MANJARO xhci-hcd
дек 03 11:10:53 _hostname_ kernel: usb usb2: SerialNumber: 0000:00:14.0
дек 03 11:10:53 _hostname_ kernel: hub 2-0:1.0: USB hub found
дек 03 11:10:53 _hostname_ kernel: hub 2-0:1.0: 4 ports detected
дек 03 11:10:53 _hostname_ kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
дек 03 11:10:53 _hostname_ kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
дек 03 11:10:53 _hostname_ kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
дек 03 11:10:53 _hostname_ kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
дек 03 11:10:53 _hostname_ kernel: usb usb3: Product: xHCI Host Controller
дек 03 11:10:53 _hostname_ kernel: usb usb3: Manufacturer: Linux 5.9.11-3-MANJARO xhci-hcd
дек 03 11:10:53 _hostname_ kernel: usb usb3: SerialNumber: 0000:00:14.0
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller
дек 03 11:10:53 _hostname_ kernel: hub 3-0:1.0: USB hub found
дек 03 11:10:53 _hostname_ kernel: hub 3-0:1.0: 4 ports detected
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1d.0: debug port 2
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7e17000
дек 03 11:10:53 _hostname_ kernel: sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
дек 03 11:10:53 _hostname_ kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
дек 03 11:10:53 _hostname_ kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
дек 03 11:10:53 _hostname_ kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
дек 03 11:10:53 _hostname_ kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
дек 03 11:10:53 _hostname_ kernel: usb usb4: Product: EHCI Host Controller
дек 03 11:10:53 _hostname_ kernel: usb usb4: Manufacturer: Linux 5.9.11-3-MANJARO ehci_hcd
дек 03 11:10:53 _hostname_ kernel: usb usb4: SerialNumber: 0000:00:1d.0
дек 03 11:10:53 _hostname_ kernel: hub 4-0:1.0: USB hub found
дек 03 11:10:53 _hostname_ kernel: hub 4-0:1.0: 2 ports detected
дек 03 11:10:53 _hostname_ kernel: sr 2:0:0:0: Attached scsi CD-ROM sr0
дек 03 11:10:53 _hostname_ kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
дек 03 11:10:53 _hostname_ kernel: usb 2-1: new full-speed USB device number 2 using xhci_hcd
дек 03 11:10:53 _hostname_ kernel: usb 4-1: new high-speed USB device number 2 using ehci-pci
дек 03 11:10:53 _hostname_ kernel: usb 2-1: New USB device found, idVendor=0c45, idProduct=8073, bcdDevice= 1.31
дек 03 11:10:53 _hostname_ kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
дек 03 11:10:53 _hostname_ kernel: usb 2-1: Product: USB DEVICE
дек 03 11:10:53 _hostname_ kernel: usb 2-1: Manufacturer: SONiX
дек 03 11:10:53 _hostname_ kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
дек 03 11:10:53 _hostname_ kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
дек 03 11:10:53 _hostname_ kernel: hub 1-1:1.0: USB hub found
дек 03 11:10:53 _hostname_ kernel: hub 1-1:1.0: 6 ports detected
дек 03 11:10:53 _hostname_ kernel: hid: raw HID events driver (C) Jiri Kosina
дек 03 11:10:53 _hostname_ kernel: usbcore: registered new interface driver usbhid
дек 03 11:10:53 _hostname_ kernel: usbhid: USB HID core driver
дек 03 11:10:53 _hostname_ kernel: input: SONiX USB DEVICE as /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.0/0003:0C45:8073.0001/input/input9
дек 03 11:10:53 _hostname_ kernel: usb 4-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
дек 03 11:10:53 _hostname_ kernel: usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
дек 03 11:10:53 _hostname_ kernel: hub 4-1:1.0: USB hub found
дек 03 11:10:53 _hostname_ kernel: hub 4-1:1.0: 6 ports detected
дек 03 11:10:53 _hostname_ kernel: hid-generic 0003:0C45:8073.0001: input,hidraw0: USB HID v1.11 Keyboard [SONiX USB DEVICE] on usb-0000:00:14.0-1/input0
дек 03 11:10:53 _hostname_ kernel: input: SONiX USB DEVICE Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.1/0003:0C45:8073.0002/input/input10
дек 03 11:10:53 _hostname_ kernel: usb 2-2: new full-speed USB device number 3 using xhci_hcd
дек 03 11:10:53 _hostname_ kernel: input: SONiX USB DEVICE System Control as /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.1/0003:0C45:8073.0002/input/input11
дек 03 11:10:53 _hostname_ kernel: input: SONiX USB DEVICE Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.1/0003:0C45:8073.0002/input/input12
дек 03 11:10:53 _hostname_ kernel: hid-generic 0003:0C45:8073.0002: input,hidraw1: USB HID v1.11 Keyboard [SONiX USB DEVICE] on usb-0000:00:14.0-1/input1
дек 03 11:10:53 _hostname_ kernel: PM: Image not found (code -22)
дек 03 11:10:53 _hostname_ kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
дек 03 11:10:53 _hostname_ kernel: random: fast init done
дек 03 11:10:53 _hostname_ kernel: usb 2-2: New USB device found, idVendor=09da, idProduct=3210, bcdDevice=8b.42
дек 03 11:10:53 _hostname_ kernel: usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
дек 03 11:10:53 _hostname_ kernel: usb 2-2: Product: USB Device
дек 03 11:10:53 _hostname_ kernel: usb 2-2: Manufacturer: COMPANY
дек 03 11:10:53 _hostname_ kernel: input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:09DA:3210.0003/input/input13
дек 03 11:10:53 _hostname_ kernel: hid-generic 0003:09DA:3210.0003: input,hidraw2: USB HID v1.11 Keyboard [COMPANY USB Device] on usb-0000:00:14.0-2/input0
дек 03 11:10:53 _hostname_ kernel: input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:09DA:3210.0004/input/input14
дек 03 11:10:53 _hostname_ kernel: hid-generic 0003:09DA:3210.0004: input,hidraw3: USB HID v1.11 Mouse [COMPANY USB Device] on usb-0000:00:14.0-2/input1
дек 03 11:10:53 _hostname_ kernel: input: COMPANY USB Device Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.2/0003:09DA:3210.0005/input/input15
дек 03 11:10:53 _hostname_ systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
дек 03 11:10:53 _hostname_ systemd[1]: Detected architecture x86-64.
дек 03 11:10:53 _hostname_ kernel: input: COMPANY USB Device System Control as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.2/0003:09DA:3210.0005/input/input16
дек 03 11:10:53 _hostname_ kernel: input: COMPANY USB Device Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.2/0003:09DA:3210.0005/input/input17
дек 03 11:10:53 _hostname_ kernel: input: COMPANY USB Device as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.2/0003:09DA:3210.0005/input/input18
дек 03 11:10:53 _hostname_ kernel: hid-generic 0003:09DA:3210.0005: input,hiddev0,hidraw4: USB HID v1.11 Keyboard [COMPANY USB Device] on usb-0000:00:14.0-2/input2
дек 03 11:10:53 _hostname_ systemd[1]: Set hostname to <_hostname_>.
дек 03 11:10:53 _hostname_ kernel: usb 2-3: new full-speed USB device number 4 using xhci_hcd
дек 03 11:10:53 _hostname_ systemd[1]: Queued start job for default target Graphical Interface.
дек 03 11:10:53 _hostname_ kernel: random: systemd: uninitialized urandom read (16 bytes read)
дек 03 11:10:53 _hostname_ systemd[1]: Created slice system-getty.slice.
дек 03 11:10:53 _hostname_ systemd[1]: Created slice system-modprobe.slice.
дек 03 11:10:53 _hostname_ systemd[1]: Created slice User and Session Slice.
дек 03 11:10:53 _hostname_ systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
дек 03 11:10:53 _hostname_ systemd[1]: Started Forward Password Requests to Wall Directory Watch.
дек 03 11:10:53 _hostname_ systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
дек 03 11:10:53 _hostname_ systemd[1]: Reached target Local Encrypted Volumes.
дек 03 11:10:53 _hostname_ systemd[1]: Reached target Login Prompts.
дек 03 11:10:53 _hostname_ systemd[1]: Reached target Paths.
дек 03 11:10:53 _hostname_ systemd[1]: Reached target Remote File Systems.
дек 03 11:10:53 _hostname_ systemd[1]: Reached target Slices.
дек 03 11:10:53 _hostname_ systemd[1]: Listening on Device-mapper event daemon FIFOs.
дек 03 11:10:53 _hostname_ systemd[1]: Listening on LVM2 metadata daemon socket.
дек 03 11:10:53 _hostname_ systemd[1]: Listening on LVM2 poll daemon socket.
дек 03 11:10:53 _hostname_ systemd[1]: Listening on Process Core Dump Socket.
дек 03 11:10:53 _hostname_ systemd[1]: Listening on Journal Audit Socket.
дек 03 11:10:53 _hostname_ systemd[1]: Listening on Journal Socket (/dev/log).
дек 03 11:10:53 _hostname_ systemd[1]: Listening on Journal Socket.
дек 03 11:10:53 _hostname_ systemd[1]: Listening on udev Control Socket.
дек 03 11:10:53 _hostname_ systemd[1]: Listening on udev Kernel Socket.
дек 03 11:10:53 _hostname_ systemd[1]: Mounting Huge Pages File System...
дек 03 11:10:53 _hostname_ systemd[1]: Mounting POSIX Message Queue File System...
дек 03 11:10:53 _hostname_ systemd[1]: Mounting Kernel Debug File System...
дек 03 11:10:53 _hostname_ systemd[1]: Mounting Kernel Trace File System...
дек 03 11:10:53 _hostname_ systemd[1]: Starting Create list of static device nodes for the current kernel...
дек 03 11:10:53 _hostname_ systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
дек 03 11:10:53 _hostname_ systemd[1]: Starting Load Kernel Module drm...
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Starting Journal Service...
дек 03 11:10:53 _hostname_ systemd[1]: Starting Load Kernel Modules...
дек 03 11:10:53 _hostname_ systemd[1]: Starting Remount Root and Kernel File Systems...
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Starting Coldplug All udev Devices...
дек 03 11:10:53 _hostname_ systemd[1]: Mounted Huge Pages File System.
дек 03 11:10:53 _hostname_ systemd[1]: Mounted POSIX Message Queue File System.
дек 03 11:10:53 _hostname_ systemd[1]: Mounted Kernel Debug File System.
дек 03 11:10:53 _hostname_ systemd[1]: Mounted Kernel Trace File System.
дек 03 11:10:53 _hostname_ systemd[1]: Finished Create list of static device nodes for the current kernel.
дек 03 11:10:53 _hostname_ kernel: Linux agpgart interface v0.103
дек 03 11:10:53 _hostname_ kernel: EXT4-fs (sda1): re-mounted. Opts: (null)
дек 03 11:10:53 _hostname_ systemd[1]: Finished Load Kernel Modules.
дек 03 11:10:53 _hostname_ systemd[1]: Finished Remount Root and Kernel File Systems.
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in FUSE Control File System being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Mounting Kernel Configuration File System...
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in First Boot Wizard being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Starting Load/Save Random Seed...
дек 03 11:10:53 _hostname_ systemd[1]: Starting Apply Kernel Variables...
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in Create System Users being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Starting Create Static Device Nodes in /dev...
дек 03 11:10:53 _hostname_ systemd[1]: Mounted Kernel Configuration File System.
дек 03 11:10:53 _hostname_ systemd[1]: Finished Apply Kernel Variables.
дек 03 11:10:53 _hostname_ systemd[1]: Finished Create Static Device Nodes in /dev.
дек 03 11:10:53 _hostname_ kernel: usb 2-3: New USB device found, idVendor=0bda, idProduct=8723, bcdDevice= 2.00
дек 03 11:10:53 _hostname_ kernel: usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
дек 03 11:10:53 _hostname_ kernel: usb 2-3: Product: RT Bluetooth Radio
дек 03 11:10:53 _hostname_ kernel: usb 2-3: Manufacturer: Realtek
дек 03 11:10:53 _hostname_ kernel: usb 2-3: SerialNumber: 00e04c000001
дек 03 11:10:53 _hostname_ systemd[1]: Starting Rule-based Manager for Device Events and Files...
дек 03 11:10:53 _hostname_ systemd[1]: modprobe@drm.service: Succeeded.
дек 03 11:10:53 _hostname_ systemd[1]: Finished Load Kernel Module drm.
дек 03 11:10:53 _hostname_ systemd[1]: Finished Coldplug All udev Devices.
дек 03 11:10:53 _hostname_ kernel: usb 2-4: new high-speed USB device number 5 using xhci_hcd
дек 03 11:10:53 _hostname_ systemd-journald[225]: Journal started
дек 03 11:10:53 _hostname_ systemd-journald[225]: Runtime Journal (/run/log/journal/38fad117791748f7982ad1133140b439) is 8.0M, max 191.3M, 183.3M free.
дек 03 11:10:53 _hostname_ systemd-modules-load[226]: Inserted module 'crypto_user'
дек 03 11:10:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ systemd-sysctl[232]: Not setting net/ipv4/conf/all/rp_filter (explicit setting exists).
дек 03 11:10:53 _hostname_ systemd-sysctl[232]: Not setting net/ipv4/conf/default/rp_filter (explicit setting exists).
дек 03 11:10:53 _hostname_ systemd-sysctl[232]: Not setting net/ipv4/conf/all/accept_source_route (explicit setting exists).
дек 03 11:10:53 _hostname_ systemd-sysctl[232]: Not setting net/ipv4/conf/default/accept_source_route (explicit setting exists).
дек 03 11:10:53 _hostname_ systemd-sysctl[232]: Not setting net/ipv4/conf/all/promote_secondaries (explicit setting exists).
дек 03 11:10:53 _hostname_ systemd-sysctl[232]: Not setting net/ipv4/conf/default/promote_secondaries (explicit setting exists).
дек 03 11:10:53 _hostname_ systemd-random-seed[231]: Kernel entropy pool is not initialized yet, waiting until it is.
дек 03 11:10:53 _hostname_ systemd[1]: Starting Flush Journal to Persistent Storage...
дек 03 11:10:53 _hostname_ systemd[1]: Started Journal Service.
дек 03 11:10:53 _hostname_ kernel: audit: type=1130 audit(1606983053.274:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ systemd-journald[225]: Time spent on flushing to /var/log/journal/38fad117791748f7982ad1133140b439 is 76.278ms for 793 entries.
дек 03 11:10:53 _hostname_ systemd-journald[225]: System Journal (/var/log/journal/38fad117791748f7982ad1133140b439) is 304.1M, max 4.0G, 3.7G free.
дек 03 11:10:53 _hostname_ kernel: usb 2-4: New USB device found, idVendor=5986, idProduct=0401, bcdDevice= 6.06
дек 03 11:10:53 _hostname_ kernel: usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
дек 03 11:10:53 _hostname_ kernel: usb 2-4: Product: BisonCam, NB Pro
дек 03 11:10:53 _hostname_ kernel: usb 2-4: Manufacturer: Bison
дек 03 11:10:53 _hostname_ kernel: audit: type=1130 audit(1606983053.381:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ kernel: audit: type=1130 audit(1606983053.381:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ systemd[1]: Started Rule-based Manager for Device Events and Files.
дек 03 11:10:53 _hostname_ systemd[1]: Started LVM2 metadata daemon.
дек 03 11:10:53 _hostname_ systemd[1]: Finished Flush Journal to Persistent Storage.
дек 03 11:10:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ kernel: audit: type=1130 audit(1606983053.417:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ kernel: battery: ACPI: Battery Slot [BAT0] (battery absent)
дек 03 11:10:53 _hostname_ kernel: ACPI: AC Adapter [AC] (on-line)
дек 03 11:10:53 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200717/utaddress-204)
дек 03 11:10:53 _hostname_ kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
дек 03 11:10:53 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200717/utaddress-204)
дек 03 11:10:53 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200717/utaddress-204)
дек 03 11:10:53 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200717/utaddress-204)
дек 03 11:10:53 _hostname_ kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
дек 03 11:10:53 _hostname_ systemd[1]: Found device SATA_SSD 2.
дек 03 11:10:53 _hostname_ systemd[1]: Activating swap /dev/disk/by-uuid/1c035312-8349-4225-9744-79fff163f918...
дек 03 11:10:53 _hostname_ kernel: Adding 8621268k swap on /dev/sda2. Priority:-2 extents:1 across:8621268k SSFS
дек 03 11:10:53 _hostname_ systemd[1]: Activated swap /dev/disk/by-uuid/1c035312-8349-4225-9744-79fff163f918.
дек 03 11:10:53 _hostname_ systemd[1]: Reached target Swap.
дек 03 11:10:53 _hostname_ systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
дек 03 11:10:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ systemd[1]: Reached target Local File Systems (Pre).
дек 03 11:10:53 _hostname_ kernel: audit: type=1130 audit(1606983053.744:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ systemd[1]: Mounting /tmp...
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Mounted /tmp.
дек 03 11:10:53 _hostname_ systemd[1]: Reached target Local File Systems.
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Starting Create Volatile Files and Directories...
дек 03 11:10:53 _hostname_ kernel: i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
дек 03 11:10:53 _hostname_ kernel: i2c i2c-0: 1/2 memory slots populated (from DMI)
дек 03 11:10:53 _hostname_ systemd[1]: Finished Create Volatile Files and Directories.
дек 03 11:10:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
дек 03 11:10:53 _hostname_ kernel: audit: type=1130 audit(1606983053.787:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ systemd[1]: Starting Network Time Synchronization...
дек 03 11:10:53 _hostname_ systemd[1]: Condition check resulted in Update is Completed being skipped.
дек 03 11:10:53 _hostname_ systemd[1]: Starting Update UTMP about System Boot/Shutdown...
дек 03 11:10:53 _hostname_ audit[311]: SYSTEM_BOOT pid=311 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ kernel: audit: type=1127 audit(1606983053.807:8): pid=311 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ kernel: libphy: Fixed MDIO Bus: probed
дек 03 11:10:53 _hostname_ systemd[1]: Finished Update UTMP about System Boot/Shutdown.
дек 03 11:10:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ kernel: audit: type=1130 audit(1606983053.814:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:53 _hostname_ kernel: input: PC Speaker as /devices/platform/pcspkr/input/input20
дек 03 11:10:53 _hostname_ kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
дек 03 11:10:53 _hostname_ kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
дек 03 11:10:54 _hostname_ kernel: RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
дек 03 11:10:54 _hostname_ kernel: RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
дек 03 11:10:54 _hostname_ kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
дек 03 11:10:54 _hostname_ kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
дек 03 11:10:54 _hostname_ kernel: r8169 0000:03:00.2: can't disable ASPM; OS doesn't have ASPM control
дек 03 11:10:54 _hostname_ kernel: cryptd: max_cpu_qlen set to 1000
дек 03 11:10:54 _hostname_ kernel: libphy: r8169: probed
дек 03 11:10:54 _hostname_ kernel: r8169 0000:03:00.2 eth0: RTL8411, 00:90:f5:e8:26:64, XID 488, IRQ 31
дек 03 11:10:54 _hostname_ kernel: r8169 0000:03:00.2 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
дек 03 11:10:54 _hostname_ systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
дек 03 11:10:54 _hostname_ kernel: iTCO_vendor_support: vendor-support=0
дек 03 11:10:54 _hostname_ kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
дек 03 11:10:54 _hostname_ kernel: iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
дек 03 11:10:54 _hostname_ kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
дек 03 11:10:54 _hostname_ kernel: r8169 0000:03:00.2 enp3s0f2: renamed from eth0
дек 03 11:10:54 _hostname_ kernel: checking generic (e0000000 410000) vs hw (f7800000 400000)
дек 03 11:10:54 _hostname_ kernel: checking generic (e0000000 410000) vs hw (e0000000 10000000)
дек 03 11:10:54 _hostname_ kernel: fb0: switching to inteldrmfb from VESA VGA
дек 03 11:10:54 _hostname_ kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
дек 03 11:10:54 _hostname_ kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
дек 03 11:10:54 _hostname_ kernel: [drm] Initialized i915 1.6.0 20200715 for 0000:00:02.0 on minor 0
дек 03 11:10:54 _hostname_ kernel: ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
дек 03 11:10:54 _hostname_ kernel: acpi device:3f: registered as cooling_device4
дек 03 11:10:54 _hostname_ kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input22
дек 03 11:10:54 _hostname_ kernel: snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
дек 03 11:10:54 _hostname_ systemd[1]: Started Network Time Synchronization.
дек 03 11:10:54 _hostname_ systemd[1]: Reached target System Initialization.
дек 03 11:10:54 _hostname_ systemd[1]: Started Daily Cleanup of Temporary Directories.
дек 03 11:10:54 _hostname_ systemd[1]: Reached target System Time Set.
дек 03 11:10:54 _hostname_ systemd[1]: Reached target System Time Synchronized.
дек 03 11:10:54 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:54 _hostname_ systemd[1]: Started Daily rotation of log files.
дек 03 11:10:54 _hostname_ systemd[1]: Started Daily man-db regeneration.
дек 03 11:10:54 _hostname_ systemd[1]: Started Monthly clean packages cache.
дек 03 11:10:54 _hostname_ systemd[1]: Started Generate mirrorlist weekly.
дек 03 11:10:54 _hostname_ systemd[1]: Started pkgfile database update timer.
дек 03 11:10:54 _hostname_ systemd[1]: Started Daily verification of password and group files.
дек 03 11:10:54 _hostname_ systemd[1]: Reached target Timers.
дек 03 11:10:54 _hostname_ kernel: audit: type=1130 audit(1606983054.901:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:54 _hostname_ systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
дек 03 11:10:54 _hostname_ systemd[1]: Listening on D-Bus System Message Bus Socket.
дек 03 11:10:54 _hostname_ kernel: audit: type=1130 audit(1606983054.907:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:54 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:54 _hostname_ systemd[1]: Reached target Sockets.
дек 03 11:10:54 _hostname_ systemd[1]: Reached target Basic System.
дек 03 11:10:54 _hostname_ systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
дек 03 11:10:54 _hostname_ systemd[1]: Started Periodic Command Scheduler.
дек 03 11:10:54 _hostname_ crond[401]: (CRON) STARTUP (1.5.5)
дек 03 11:10:54 _hostname_ crond[401]: (CRON) INFO (Syslog will be used instead of sendmail.)
дек 03 11:10:54 _hostname_ systemd[1]: Started D-Bus System Message Bus.
дек 03 11:10:54 _hostname_ crond[401]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 34% if used.)
дек 03 11:10:54 _hostname_ crond[401]: (CRON) INFO (running with inotify support)
дек 03 11:10:54 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:54 _hostname_ systemd[1]: Starting Network Manager...
дек 03 11:10:54 _hostname_ kernel: audit: type=1130 audit(1606983054.917:12): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:54 _hostname_ systemd[1]: Starting Authorization Manager...
дек 03 11:10:54 _hostname_ avahi-daemon[399]: Found user 'avahi' (UID 974) and group 'avahi' (GID 974).
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.0016] NetworkManager (version 1.26.4-1) is starting... (for the first time)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.0035] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
дек 03 11:10:55 _hostname_ audit: BPF prog-id=7 op=LOAD
дек 03 11:10:55 _hostname_ audit: BPF prog-id=8 op=LOAD
дек 03 11:10:55 _hostname_ kernel: fbcon: i915drmfb (fb0) is primary device
дек 03 11:10:55 _hostname_ kernel: fbcon: Deferring console take-over
дек 03 11:10:55 _hostname_ kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
дек 03 11:10:55 _hostname_ kernel: audit: type=1334 audit(1606983055.007:13): prog-id=7 op=LOAD
дек 03 11:10:55 _hostname_ kernel: audit: type=1334 audit(1606983055.007:14): prog-id=8 op=LOAD
дек 03 11:10:55 _hostname_ systemd[1]: Starting User Login Management...
дек 03 11:10:55 _hostname_ avahi-daemon[399]: Successfully dropped root privileges.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: avahi-daemon 0.8 starting up.
дек 03 11:10:55 _hostname_ polkitd[404]: Started polkitd version 0.118
дек 03 11:10:55 _hostname_ kernel: psmouse serio2: synaptics: queried max coordinates: x [..5692], y [..4680]
дек 03 11:10:55 _hostname_ kernel: random: crng init done
дек 03 11:10:55 _hostname_ kernel: random: 7 urandom warning(s) missed due to ratelimiting
дек 03 11:10:55 _hostname_ systemd[1]: Finished Load/Save Random Seed.
дек 03 11:10:55 _hostname_ systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ kernel: audit: type=1130 audit(1606983055.127:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ avahi-daemon[399]: Successfully called chroot().
дек 03 11:10:55 _hostname_ systemd[1]: Started Avahi mDNS/DNS-SD Stack.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: Successfully dropped remaining capabilities.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: No service file found in /etc/avahi/services.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ avahi-daemon[399]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: New relevant interface lo.IPv6 for mDNS.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: New relevant interface lo.IPv4 for mDNS.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: Network interface enumeration completed.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: Registering new address record for ::1 on lo.*.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: Registering new address record for 127.0.0.1 on lo.IPv4.
дек 03 11:10:55 _hostname_ avahi-daemon[399]: Failed to parse address 'fe80::8226:89ff:fe67:c57f%enp3s0f2', ignoring.
дек 03 11:10:55 _hostname_ kernel: audit: type=1130 audit(1606983055.131:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ kernel: audit: type=1130 audit(1606983055.134:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ systemd[1]: Started Network Manager.
дек 03 11:10:55 _hostname_ systemd[1]: Reached target Network.
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.1396] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
дек 03 11:10:55 _hostname_ systemd[1]: Starting Permit User Sessions...
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.1495] manager[0x5601f514a030]: monitoring kernel firmware directory '/lib/firmware'.
дек 03 11:10:55 _hostname_ systemd[1]: Finished Permit User Sessions.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ kernel: audit: type=1130 audit(1606983055.147:18): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.4' (uid=0 pid=403 comm="/usr/bin/NetworkManager --no-daemon ")
дек 03 11:10:55 _hostname_ audit: BPF prog-id=9 op=LOAD
дек 03 11:10:55 _hostname_ kernel: audit: type=1334 audit(1606983055.154:19): prog-id=9 op=LOAD
дек 03 11:10:55 _hostname_ audit: BPF prog-id=10 op=LOAD
дек 03 11:10:55 _hostname_ systemd[1]: Starting Hostname Service...
дек 03 11:10:55 _hostname_ polkitd[404]: Loading rules from directory /etc/polkit-1/rules.d
дек 03 11:10:55 _hostname_ polkitd[404]: Loading rules from directory /usr/share/polkit-1/rules.d
дек 03 11:10:55 _hostname_ polkitd[404]: Finished loading, compiling and executing 4 rules
дек 03 11:10:55 _hostname_ systemd[1]: Started Authorization Manager.
дек 03 11:10:55 _hostname_ polkitd[404]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
дек 03 11:10:55 _hostname_ systemd[1]: Created slice system-systemd\x2dbacklight.slice.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ systemd[1]: Starting Modem Manager...
дек 03 11:10:55 _hostname_ systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
дек 03 11:10:55 _hostname_ systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:acpi_video0.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ kernel: psmouse serio2: synaptics: Touchpad model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04731/0xa40000/0xa0000/0x0, board id: 0, fw id: 582762
дек 03 11:10:55 _hostname_ ModemManager[436]: <info> ModemManager (version 1.14.8) starting in system bus...
дек 03 11:10:55 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: autoconfig for VT1802: line_outs=1 (0x24/0x0/0x0/0x0/0x0) type:speaker
дек 03 11:10:55 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
дек 03 11:10:55 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: hp_outs=1 (0x25/0x0/0x0/0x0/0x0)
дек 03 11:10:55 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: mono: mono_out=0x0
дек 03 11:10:55 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: inputs:
дек 03 11:10:55 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: Mic=0x2b
дек 03 11:10:55 _hostname_ kernel: snd_hda_codec_via hdaudioC0D0: Internal Mic=0x29
дек 03 11:10:55 _hostname_ kernel: input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input21
дек 03 11:10:55 _hostname_ systemd[1]: Started Modem Manager.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ kernel: Bluetooth: Core ver 2.22
дек 03 11:10:55 _hostname_ kernel: NET: Registered protocol family 31
дек 03 11:10:55 _hostname_ kernel: Bluetooth: HCI device and connection manager initialized
дек 03 11:10:55 _hostname_ kernel: Bluetooth: HCI socket layer initialized
дек 03 11:10:55 _hostname_ kernel: Bluetooth: L2CAP socket layer initialized
дек 03 11:10:55 _hostname_ kernel: Bluetooth: SCO socket layer initialized
дек 03 11:10:55 _hostname_ kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input23
дек 03 11:10:55 _hostname_ kernel: input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input24
дек 03 11:10:55 _hostname_ kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input27
дек 03 11:10:55 _hostname_ kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input28
дек 03 11:10:55 _hostname_ systemd[1]: Condition check resulted in Save/Restore Sound Card State being skipped.
дек 03 11:10:55 _hostname_ systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
дек 03 11:10:55 _hostname_ systemd[1]: Reached target Sound Card.
дек 03 11:10:55 _hostname_ kernel: mousedev: PS/2 mouse device common for all mice
дек 03 11:10:55 _hostname_ kernel: intel_rapl_common: Found RAPL domain package
дек 03 11:10:55 _hostname_ kernel: intel_rapl_common: Found RAPL domain core
дек 03 11:10:55 _hostname_ kernel: intel_rapl_common: Found RAPL domain uncore
дек 03 11:10:55 _hostname_ kernel: intel_rapl_common: RAPL package-0 domain package locked by BIOS
дек 03 11:10:55 _hostname_ kernel: rtl8723ae: Using firmware rtlwifi/rtl8723fw_B.bin
дек 03 11:10:55 _hostname_ kernel: ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
дек 03 11:10:55 _hostname_ systemd[1]: Starting Load/Save RF Kill Switch Status...
дек 03 11:10:55 _hostname_ kernel: rtlwifi: rtlwifi: wireless switch is on
дек 03 11:10:55 _hostname_ kernel: rtl8723ae 0000:02:00.0 wlp2s0: renamed from wlan0
дек 03 11:10:55 _hostname_ systemd[1]: Started Load/Save RF Kill Switch Status.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ kernel: usbcore: registered new interface driver btusb
дек 03 11:10:55 _hostname_ kernel: Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=1200
дек 03 11:10:55 _hostname_ kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8723a_fw.bin
дек 03 11:10:55 _hostname_ systemd-logind[412]: New seat seat0.
дек 03 11:10:55 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event3 (Power Button)
part 2/2
journalctl -b -1 (zombie boot?)
дек 03 11:10:55 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event0 (Power Button)
дек 03 11:10:55 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event2 (Lid Switch)
дек 03 11:10:55 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event1 (Sleep Button)
дек 03 11:10:55 _hostname_ dbus-daemon[402]: [system] Successfully activated service 'org.freedesktop.hostname1'
дек 03 11:10:55 _hostname_ systemd[1]: Started Hostname Service.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.6857] hostname: hostname: using hostnamed
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.6858] hostname: hostname changed from (none) to "_hostname_"
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.6864] dns-mgr[0x5601f5105220]: init: dns=default,systemd-resolved rc-manager=symlink
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.6874] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0/ieee80211/phy0/rfkill0) (driver rtl8723ae)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.6876] manager[0x5601f514a030]: rfkill: Wi-Fi hardware radio set enabled
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.6876] manager[0x5601f514a030]: rfkill: WWAN hardware radio set enabled
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7026] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-wwan.so)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7040] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-wifi.so)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7058] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-ovs.so)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7089] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-bluetooth.so)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7203] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-team.so)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7216] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-adsl.so)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7220] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7221] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7223] manager: Networking is enabled by state file
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7231] dhcp-init: Using DHCP client 'internal'
дек 03 11:10:55 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=403 comm="/usr/bin/NetworkManager --no-daemon ")
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7240] settings: Loaded settings plugin: keyfile (internal)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7261] device (lo): carrier: link connected
дек 03 11:10:55 _hostname_ systemd[1]: Starting Network Manager Script Dispatcher Service...
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7265] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7278] manager: (enp3s0f2): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7305] settings: (enp3s0f2): created default wired connection 'Wired connection 1'
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.7314] device (enp3s0f2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
дек 03 11:10:55 _hostname_ kernel: RTL8211E Gigabit Ethernet r8169-302:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-302:00, irq=IGNORE)
дек 03 11:10:55 _hostname_ dbus-daemon[402]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ systemd[1]: Started Network Manager Script Dispatcher Service.
дек 03 11:10:55 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event4 (AT Translated Set 2 keyboard)
дек 03 11:10:55 _hostname_ systemd[1]: Started User Login Management.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ systemd[1]: Reached target Multi-User System.
дек 03 11:10:55 _hostname_ systemd[1]: Started Simple Desktop Display Manager.
дек 03 11:10:55 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:55 _hostname_ systemd[1]: Reached target Graphical Interface.
дек 03 11:10:55 _hostname_ systemd[1]: Starting TLP system startup/shutdown...
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.8974] device (wlp2s0): driver supports Access Point (AP) mode
дек 03 11:10:55 _hostname_ kernel: r8169 0000:03:00.2 enp3s0f2: Link is Down
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.8983] manager: (wlp2s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.9048] ovsdb: Could not connect: No such file or directory
дек 03 11:10:55 _hostname_ NetworkManager[403]: <info> [1606983055.9067] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
дек 03 11:10:55 _hostname_ sddm[584]: Initializing...
дек 03 11:10:55 _hostname_ sddm[584]: Starting...
дек 03 11:10:55 _hostname_ sddm[584]: Logind interface found
дек 03 11:10:55 _hostname_ sddm[584]: Adding new display on vt 1 ...
дек 03 11:10:55 _hostname_ sddm[584]: Loading theme configuration from ""
дек 03 11:10:55 _hostname_ sddm[584]: Display server starting...
дек 03 11:10:55 _hostname_ sddm[584]: Adding cookie to "/var/run/sddm/{a06e7ddf-8836-4aeb-a639-e41b543fb9ac}"
дек 03 11:10:55 _hostname_ sddm[584]: Running: /usr/bin/X -nolisten tcp -auth /var/run/sddm/{a06e7ddf-8836-4aeb-a639-e41b543fb9ac} -background none -noreset -displayfd 17 -seat seat0 vt1
дек 03 11:10:56 _hostname_ avahi-daemon[399]: Server startup complete. Host name is _hostname_.local. Local service cookie is 465297432.
дек 03 11:10:56 _hostname_ mtp-probe[640]: checking bus 2, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2"
дек 03 11:10:56 _hostname_ mtp-probe[639]: checking bus 2, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-4"
дек 03 11:10:56 _hostname_ mtp-probe[640]: bus: 2, device: 3 was not an MTP device
дек 03 11:10:56 _hostname_ mtp-probe[639]: bus: 2, device: 5 was not an MTP device
дек 03 11:10:56 _hostname_ mtp-probe[638]: checking bus 2, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1"
дек 03 11:10:56 _hostname_ mtp-probe[638]: bus: 2, device: 2 was not an MTP device
дек 03 11:10:56 _hostname_ NetworkManager[403]: <info> [1606983056.2954] device (wlp2s0): set-hw-addr: set MAC address to 22:C8:8C:F2:E0:6E (scanning)
дек 03 11:10:56 _hostname_ kernel: Bluetooth: hci0: RTL: fw version 0x0e3da5b1
дек 03 11:10:56 _hostname_ tlp[585]: Applying power save settings...done.
дек 03 11:10:56 _hostname_ tlp[585]: Setting battery charge thresholds...done.
дек 03 11:10:56 _hostname_ systemd[1]: Finished TLP system startup/shutdown.
дек 03 11:10:56 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:56 _hostname_ systemd[1]: Startup finished in 3.399s (kernel) + 3.797s (userspace) = 7.197s.
дек 03 11:10:56 _hostname_ kernel: BUG: kernel NULL pointer dereference, address: 0000000000000010
дек 03 11:10:56 _hostname_ kernel: #PF: supervisor read access in kernel mode
дек 03 11:10:56 _hostname_ kernel: #PF: error_code(0x0000) - not-present page
дек 03 11:10:56 _hostname_ kernel: PGD 0 P4D 0
дек 03 11:10:56 _hostname_ kernel: Oops: 0000 [#1] PREEMPT SMP PTI
дек 03 11:10:56 _hostname_ kernel: CPU: 2 PID: 125 Comm: kworker/2:2 Not tainted 5.9.11-3-MANJARO #1
дек 03 11:10:56 _hostname_ kernel: Hardware name: CLEVO CO. W240EU/W250EUQ/W270EUQ /W240EU/W250EUQ/W270EUQ , BIOS 4.6.5 05/09/2013
дек 03 11:10:56 _hostname_ kernel: Workqueue: rtl8723e_pci rtl_fwevt_wq_callback [rtlwifi]
дек 03 11:10:56 _hostname_ kernel: RIP: 0010:rtl_8723e_c2h_command_handle+0x2dc/0x400 [rtl8723ae]
дек 03 11:10:56 _hostname_ kernel: Code: f7 48 c7 c1 00 cc 15 c1 be 02 00 00 00 e8 0c 95 f4 ff 48 8b 04 24 ba 05 00 00 00 4c 89 f7 48 c7 c1 85 e8 15 c1 be 02 00 00 00 <44> 0f b6 00 e8 eb 94 f4 ff 48 8b 44 24 10 c6 05 90 72 01 00 00 c6
дек 03 11:10:56 _hostname_ kernel: RSP: 0018:ffffb505802b7e48 EFLAGS: 00010246
дек 03 11:10:56 _hostname_ kernel: RAX: 0000000000000010 RBX: 0000000000000000 RCX: ffffffffc115e885
дек 03 11:10:56 _hostname_ kernel: RDX: 0000000000000005 RSI: 0000000000000002 RDI: ffff97ad4cbc1ec0
дек 03 11:10:56 _hostname_ kernel: RBP: 0000000000000010 R08: 0000000000000001 R09: 0000000000000000
дек 03 11:10:56 _hostname_ kernel: R10: 0000000000000018 R11: 0000000000000018 R12: 0000000000000010
дек 03 11:10:56 _hostname_ kernel: R13: 0000000000000192 R14: ffff97ad4cbc1ec0 R15: 0000000000000000
дек 03 11:10:56 _hostname_ kernel: FS: 0000000000000000(0000) GS:ffff97ad5b300000(0000) knlGS:0000000000000000
дек 03 11:10:56 _hostname_ kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
дек 03 11:10:56 _hostname_ kernel: CR2: 0000000000000010 CR3: 000000005440e006 CR4: 00000000001706e0
дек 03 11:10:56 _hostname_ kernel: Call Trace:
дек 03 11:10:56 _hostname_ kernel: process_one_work+0x1da/0x3d0
дек 03 11:10:56 _hostname_ kernel: worker_thread+0x4d/0x3d0
дек 03 11:10:56 _hostname_ kernel: ? rescuer_thread+0x410/0x410
дек 03 11:10:56 _hostname_ kernel: kthread+0x142/0x160
дек 03 11:10:56 _hostname_ kernel: ? __kthread_bind_mask+0x60/0x60
дек 03 11:10:56 _hostname_ kernel: ret_from_fork+0x22/0x30
дек 03 11:10:56 _hostname_ kernel: Modules linked in: rtl8723ae btcoexist btusb intel_rapl_msr intel_rapl_common joydev btrtl btbcm btintel mousedev snd_hda_codec_hdmi x86_pkg_temp_thermal intel_powerclamp coretemp rtl8723_common snd_hda_codec_via snd_hda_codec_generic bluetooth kvm_intel ledtrig_audio rtl_pci rtlwifi ecdh_generic kvm ecc mac80211 irqbypass iTCO_wdt intel_pmc_bxt iTCO_vendor_support i915 crct10dif_pclmul crc32_pclmul ghash_clmulni_intel r8169 mei_hdcp cryptd rapl snd_hda_intel realtek intel_cstate snd_intel_dspcfg mdio_devres i2c_algo_bit snd_hda_codec intel_uncore of_mdio cfg80211 drm_kms_helper snd_hda_core pcspkr fixed_phy psmouse i2c_i801 input_leds snd_hwdep i2c_smbus snd_pcm cec rfkill libphy rc_core libarc4 lpc_ich wmi intel_gtt snd_timer syscopyarea mei_me sysfillrect snd mei sysimgblt fb_sys_fops evdev soundcore mac_hid intel_smartconnect ac battery drm crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid hid rtsx_pci_sdmmc mmc_core serio_raw
дек 03 11:10:56 _hostname_ kernel: atkbd libps2 xhci_pci sr_mod crc32c_intel cdrom ehci_pci xhci_hcd ehci_hcd rtsx_pci i8042 serio
дек 03 11:10:56 _hostname_ kernel: ---[ end trace 566e2a951efe980d ]---
дек 03 11:10:56 _hostname_ NetworkManager[403]: <info> [1606983056.6842] modem-manager: ModemManager available
дек 03 11:10:56 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.4' (uid=0 pid=403 comm="/usr/bin/NetworkManager --no-daemon ")
дек 03 11:10:56 _hostname_ systemd[1]: Starting WPA supplicant...
дек 03 11:10:56 _hostname_ dbus-daemon[402]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
дек 03 11:10:56 _hostname_ systemd[1]: Started WPA supplicant.
дек 03 11:10:56 _hostname_ wpa_supplicant[797]: Successfully initialized wpa_supplicant
дек 03 11:10:56 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:56 _hostname_ NetworkManager[403]: <info> [1606983056.7524] device (wlp2s0): supplicant interface state: internal-starting -> disconnected
дек 03 11:10:56 _hostname_ NetworkManager[403]: <info> [1606983056.7525] Wi-Fi P2P device controlled by interface wlp2s0 created
дек 03 11:10:56 _hostname_ NetworkManager[403]: <info> [1606983056.7527] manager: (p2p-dev-wlp2s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
дек 03 11:10:56 _hostname_ NetworkManager[403]: <info> [1606983056.7532] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
дек 03 11:10:56 _hostname_ NetworkManager[403]: <warn> [1606983056.7540] sup-iface[8d53d9e5f0dd971b,0,wlp2s0]: call-p2p-cancel: failed with P2P cancel failed
дек 03 11:10:56 _hostname_ NetworkManager[403]: <info> [1606983056.7542] device (wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
дек 03 11:10:56 _hostname_ NetworkManager[403]: <info> [1606983056.7551] device (p2p-dev-wlp2s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
дек 03 11:10:56 _hostname_ systemd[1]: Starting Bluetooth service...
дек 03 11:10:56 _hostname_ bluetoothd[824]: Bluetooth daemon 5.55
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanType” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanInterval” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanWindow” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanType” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanInterval” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanWindow” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRLinkSupervisionTimeout” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRPageTimeout” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRMinSniffInterval” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “BRMaxSniffInterval” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEMinAdvertisementInterval” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEMaxAdvertisementInterval” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEMultiAdvertisementRotationInterval” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAutoConnect” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAutoConnect” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalSuspend” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowSuspend” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalDiscovery” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowDiscovery” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAdvMonitor” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAdvMonitor” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
дек 03 11:10:56 _hostname_ sddm[584]: Setting default cursor
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
дек 03 11:10:56 _hostname_ bluetoothd[824]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
дек 03 11:10:56 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:56 _hostname_ systemd[1]: Started Bluetooth service.
дек 03 11:10:56 _hostname_ systemd[1]: Reached target Bluetooth.
дек 03 11:10:56 _hostname_ bluetoothd[824]: Starting SDP server
дек 03 11:10:56 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event8 (SONiX USB DEVICE Keyboard)
дек 03 11:10:56 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event7 (SONiX USB DEVICE System Control)
дек 03 11:10:56 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event12 (COMPANY USB Device System Control)
дек 03 11:10:56 _hostname_ kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
дек 03 11:10:56 _hostname_ kernel: Bluetooth: BNEP filters: protocol multicast
дек 03 11:10:56 _hostname_ kernel: Bluetooth: BNEP socket layer initialized
дек 03 11:10:56 _hostname_ bluetoothd[824]: Bluetooth management interface 1.18 initialized
дек 03 11:10:56 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event6 (SONiX USB DEVICE Consumer Control)
дек 03 11:10:56 _hostname_ kernel: NET: Registered protocol family 38
дек 03 11:10:56 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event11 (COMPANY USB Device Keyboard)
дек 03 11:10:56 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event9 (COMPANY USB Device)
дек 03 11:10:56 _hostname_ kernel: mc: Linux media interface: v0.10
дек 03 11:10:56 _hostname_ kernel: videodev: Linux video capture interface: v2.00
дек 03 11:10:56 _hostname_ systemd-logind[412]: Watching system buttons on /dev/input/event13 (COMPANY USB Device Consumer Control)
дек 03 11:10:57 _hostname_ sddm[584]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
дек 03 11:10:57 _hostname_ sddm[584]: Display server started.
дек 03 11:10:57 _hostname_ sddm[584]: Reading from "/usr/share/xsessions/plasma.desktop"
дек 03 11:10:57 _hostname_ sddm[584]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11"
дек 03 11:10:57 _hostname_ kernel: uvcvideo: Found UVC 1.00 device BisonCam, NB Pro (5986:0401)
дек 03 11:10:57 _hostname_ sddm-helper[855]: [PAM] Starting...
дек 03 11:10:57 _hostname_ sddm-helper[855]: [PAM] Authenticating...
дек 03 11:10:57 _hostname_ sddm-helper[855]: gkr-pam: no password is available for user
дек 03 11:10:57 _hostname_ sddm-helper[855]: pam_kwallet5(sddm-autologin:auth): (null): pam_sm_authenticate
дек 03 11:10:57 _hostname_ sddm-helper[855]: [PAM] Preparing to converse...
дек 03 11:10:57 _hostname_ sddm-helper[855]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: Couldn't get password (it is empty)
дек 03 11:10:57 _hostname_ sddm-helper[855]: [PAM] Conversation with 1 messages
дек 03 11:10:57 _hostname_ audit[855]: USER_AUTH pid=855 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="_user_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
дек 03 11:10:57 _hostname_ sddm-helper[855]: [PAM] returning.
дек 03 11:10:57 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.23' (uid=0 pid=855 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-authe")
дек 03 11:10:57 _hostname_ dbus-daemon[402]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
дек 03 11:10:57 _hostname_ sddm-helper[855]: pam_systemd_home(sddm-autologin:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
дек 03 11:10:57 _hostname_ audit[855]: USER_ACCT pid=855 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="_user_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
дек 03 11:10:57 _hostname_ sddm[584]: Authenticated successfully
дек 03 11:10:57 _hostname_ sddm-helper[855]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
дек 03 11:10:57 _hostname_ audit[855]: CRED_ACQ pid=855 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="_user_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
дек 03 11:10:57 _hostname_ sddm-helper[855]: pam_unix(sddm-autologin:session): session opened for user _user_(uid=1000) by (uid=0)
дек 03 11:10:57 _hostname_ systemd[1]: Created slice User Slice of UID 1000.
дек 03 11:10:57 _hostname_ systemd[1]: Starting User Runtime Directory /run/user/1000...
дек 03 11:10:57 _hostname_ kernel: input: BisonCam, NB Pro: BisonCam, NB as /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/input/input29
дек 03 11:10:57 _hostname_ kernel: usbcore: registered new interface driver uvcvideo
дек 03 11:10:57 _hostname_ kernel: USB Video Class driver (1.1.1)
дек 03 11:10:57 _hostname_ systemd-logind[412]: New session 1 of user _user_.
дек 03 11:10:57 _hostname_ mtp-probe[857]: checking bus 2, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-4"
дек 03 11:10:57 _hostname_ mtp-probe[857]: bus: 2, device: 5 was not an MTP device
дек 03 11:10:57 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:57 _hostname_ systemd[1]: Finished User Runtime Directory /run/user/1000.
дек 03 11:10:57 _hostname_ systemd[1]: Starting User Manager for UID 1000...
дек 03 11:10:57 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.25' (uid=0 pid=860 comm="(systemd) ")
дек 03 11:10:57 _hostname_ systemd[860]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
дек 03 11:10:57 _hostname_ audit[860]: USER_ACCT pid=860 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="_user_" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:57 _hostname_ audit[860]: CRED_ACQ pid=860 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="_user_" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
дек 03 11:10:57 _hostname_ systemd[860]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[_user_] ruser=[<unknown>] rhost=[<unknown>]
дек 03 11:10:57 _hostname_ systemd[860]: pam_unix(systemd-user:session): session opened for user _user_(uid=1000) by (uid=0)
дек 03 11:10:57 _hostname_ systemd[860]: pam_env(systemd-user:session): deprecated reading of user environment enabled
дек 03 11:10:57 _hostname_ audit[860]: USER_START pid=860 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="_user_" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:57 _hostname_ audit: BPF prog-id=11 op=LOAD
дек 03 11:10:57 _hostname_ audit: BPF prog-id=11 op=UNLOAD
дек 03 11:10:57 _hostname_ systemd[865]: Configuration file /home/_user_/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
дек 03 11:10:57 _hostname_ systemd[865]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
дек 03 11:10:57 _hostname_ systemd[865]: Configuration file /etc/xdg/autostart/klipper.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
дек 03 11:10:57 _hostname_ systemd[865]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dpkcs11-autostart.service, startup phases are not supported.
дек 03 11:10:57 _hostname_ systemd[865]: Not generating service for XDG autostart app-powerdevil-autostart.service, only Type=Application is supported.
дек 03 11:10:57 _hostname_ systemd[865]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dsecrets-autostart.service, startup phases are not supported.
дек 03 11:10:57 _hostname_ systemd[865]: Not generating service for XDG autostart app-at\x2dspi\x2ddbus\x2dbus-autostart.service, startup phases are not supported.
дек 03 11:10:57 _hostname_ systemd[865]: Not generating service for XDG autostart app-pulseaudio-autostart.service, startup phases are not supported.
дек 03 11:10:57 _hostname_ systemd[865]: Not generating service for XDG autostart app-kaccess-autostart.service, only Type=Application is supported.
дек 03 11:10:57 _hostname_ systemd[865]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dssh-autostart.service, startup phases are not supported.
дек 03 11:10:57 _hostname_ systemd[860]: Queued start job for default target Main User Target.
дек 03 11:10:57 _hostname_ systemd[860]: Reached target Paths.
дек 03 11:10:57 _hostname_ systemd[860]: Reached target Timers.
дек 03 11:10:57 _hostname_ systemd[860]: Starting D-Bus User Message Bus Socket.
дек 03 11:10:57 _hostname_ systemd[860]: Listening on GnuPG network certificate management daemon.
дек 03 11:10:57 _hostname_ systemd[860]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
дек 03 11:10:57 _hostname_ systemd[860]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
дек 03 11:10:57 _hostname_ systemd[860]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
дек 03 11:10:57 _hostname_ systemd[860]: Listening on GnuPG cryptographic agent and passphrase cache.
дек 03 11:10:57 _hostname_ systemd[860]: Listening on p11-kit server.
дек 03 11:10:57 _hostname_ systemd[860]: Listening on Multimedia System.
дек 03 11:10:57 _hostname_ systemd[860]: Listening on Sound System.
дек 03 11:10:57 _hostname_ systemd[860]: Listening on D-Bus User Message Bus Socket.
дек 03 11:10:57 _hostname_ systemd[860]: Reached target Sockets.
дек 03 11:10:57 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:10:57 _hostname_ systemd[860]: Reached target Basic System.
дек 03 11:10:57 _hostname_ systemd[1]: Started User Manager for UID 1000.
дек 03 11:10:57 _hostname_ systemd[1]: Started Session 1 of user _user_.
дек 03 11:10:57 _hostname_ systemd[860]: Starting Update XDG user dir configuration...
дек 03 11:10:57 _hostname_ systemd[860]: xdg-user-dirs-update.service: Succeeded.
дек 03 11:10:57 _hostname_ systemd[860]: Finished Update XDG user dir configuration.
дек 03 11:10:57 _hostname_ systemd[860]: Reached target Main User Target.
дек 03 11:10:57 _hostname_ systemd[860]: Startup finished in 119ms.
дек 03 11:10:57 _hostname_ sddm-helper[855]: pam_env(sddm-autologin:session): deprecated reading of user environment enabled
дек 03 11:10:57 _hostname_ sddm-helper[855]: gkr-pam: gnome-keyring-daemon started properly
дек 03 11:10:57 _hostname_ sddm-helper[855]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_open_session
дек 03 11:10:57 _hostname_ sddm-helper[876]: pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
дек 03 11:10:57 _hostname_ audit[855]: USER_START pid=855 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring,pam_kwallet5 acct="_user_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
дек 03 11:10:57 _hostname_ sddm-helper[855]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
дек 03 11:10:57 _hostname_ sddm-helper[878]: Adding cookie to "/home/_user_/.Xauthority"
дек 03 11:10:57 _hostname_ sddm[584]: Session started
дек 03 11:10:57 _hostname_ systemd[860]: Started D-Bus User Message Bus.
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.5855] device (enp3s0f2): carrier: link connected
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.5859] device (enp3s0f2): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.5868] policy: auto-activating connection 'Wired connection 1' (cf7b54ef-d3e1-3d1d-938d-1e1704cdf620)
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.5874] device (enp3s0f2): Activation: starting connection 'Wired connection 1' (cf7b54ef-d3e1-3d1d-938d-1e1704cdf620)
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.5876] device (enp3s0f2): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
дек 03 11:10:57 _hostname_ kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0f2: link becomes ready
дек 03 11:10:57 _hostname_ kernel: r8169 0000:03:00.2 enp3s0f2: Link is Up - 100Mbps/Full - flow control rx/tx
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.5882] manager: NetworkManager state is now CONNECTING
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.5884] device (enp3s0f2): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.5891] device (enp3s0f2): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.5896] dhcp4 (enp3s0f2): activation: beginning transaction (timeout in 45 seconds)
дек 03 11:10:57 _hostname_ avahi-daemon[399]: Joining mDNS multicast group on interface enp3s0f2.IPv6 with address fe80::2775:1da5:4bee:f431.
дек 03 11:10:57 _hostname_ avahi-daemon[399]: New relevant interface enp3s0f2.IPv6 for mDNS.
дек 03 11:10:57 _hostname_ avahi-daemon[399]: Registering new address record for fe80::2775:1da5:4bee:f431 on enp3s0f2.*.
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6027] dhcp4 (enp3s0f2): option dhcp_lease_time => '86400'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6027] dhcp4 (enp3s0f2): option domain_name => 'Dlink'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option domain_name_servers => '192.168.1.1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option expiry => '1607069457'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option host_name => '_hostname_'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option ip_address => '192.168.1.72'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option next_server => '192.168.1.1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option requested_broadcast_address => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option requested_domain_name => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option requested_domain_name_servers => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option requested_domain_search => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6028] dhcp4 (enp3s0f2): option requested_host_name => '1'
дек 03 11:10:57 _hostname_ avahi-daemon[399]: Joining mDNS multicast group on interface enp3s0f2.IPv4 with address 192.168.1.72.
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_interface_mtu => '1'
дек 03 11:10:57 _hostname_ avahi-daemon[399]: New relevant interface enp3s0f2.IPv4 for mDNS.
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_ms_classless_static_routes => '1'
дек 03 11:10:57 _hostname_ avahi-daemon[399]: Registering new address record for 192.168.1.72 on enp3s0f2.IPv4.
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_nis_domain => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_nis_servers => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_ntp_servers => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_rfc3442_classless_static_routes => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_root_path => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_routers => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_static_routes => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6029] dhcp4 (enp3s0f2): option requested_subnet_mask => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6030] dhcp4 (enp3s0f2): option requested_time_offset => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6030] dhcp4 (enp3s0f2): option requested_wpad => '1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6030] dhcp4 (enp3s0f2): option routers => '192.168.1.1'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6030] dhcp4 (enp3s0f2): option subnet_mask => '255.255.255.0'
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6030] dhcp4 (enp3s0f2): state changed unknown -> bound
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6042] device (enp3s0f2): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6071] device (enp3s0f2): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6074] device (enp3s0f2): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6079] manager: NetworkManager state is now CONNECTED_LOCAL
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6090] manager: NetworkManager state is now CONNECTED_SITE
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6092] policy: set 'Wired connection 1' (enp3s0f2) as default for IPv4 routing and DNS
дек 03 11:10:57 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.4' (uid=0 pid=403 comm="/usr/bin/NetworkManager --no-daemon ")
дек 03 11:10:57 _hostname_ dbus-daemon[402]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.6173] device (enp3s0f2): Activation: successful, device activated.
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.7471] manager: NetworkManager state is now CONNECTED_GLOBAL
дек 03 11:10:57 _hostname_ NetworkManager[403]: <info> [1606983057.7737] manager: startup complete
дек 03 11:10:57 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Activating service name='org.kde.KSplash' requested by ':1.2' (uid=1000 pid=878 comm="/usr/bin/startplasma-x11 ")
дек 03 11:10:57 _hostname_ ModemManager[436]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.3/0000:03:00.2': not supported by any plugin
дек 03 11:10:58 _hostname_ ModemManager[436]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
дек 03 11:10:58 _hostname_ klauncher[906]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
дек 03 11:10:58 _hostname_ klauncher[906]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:10:58 _hostname_ klauncher[906]: Icon theme "Mint-X" not found.
дек 03 11:10:58 _hostname_ klauncher[906]: Icon theme "elementary" not found.
дек 03 11:10:58 _hostname_ kcminit_startup[910]: Initializing "kcm_mouse" : "kcminit_mouse"
дек 03 11:10:58 _hostname_ kcminit_startup[910]: Initializing "kcm_style" : "kcminit_style"
дек 03 11:10:58 _hostname_ plasma_session[898]: org.kde.plasma.session: process job "kcminit_startup" finished with exit code 0
дек 03 11:10:58 _hostname_ kwin_x11[922]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:10:58 _hostname_ kwin_x11[922]: Icon theme "Mint-X" not found.
дек 03 11:10:58 _hostname_ kwin_x11[922]: Icon theme "elementary" not found.
дек 03 11:10:58 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Activating service name='org.kde.ActivityManager' requested by ':1.8' (uid=1000 pid=922 comm="/usr/bin/kwin_x11 ")
дек 03 11:10:59 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Successfully activated service 'org.kde.ActivityManager'
дек 03 11:10:59 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Activating via systemd: service name='org.kde.kglobalaccel' unit='plasma-kglobalaccel.service' requested by ':1.9' (uid=1000 pid=927 comm="/usr/lib/kactivitymanagerd ")
дек 03 11:10:59 _hostname_ systemd[860]: Created slice background.slice.
дек 03 11:10:59 _hostname_ systemd[860]: Starting KDE Global Shortcuts Server...
дек 03 11:10:59 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Successfully activated service 'org.kde.kglobalaccel'
дек 03 11:10:59 _hostname_ systemd[860]: Started KDE Global Shortcuts Server.
дек 03 11:10:59 _hostname_ kglobalaccel5[933]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:10:59 _hostname_ kglobalaccel5[933]: Icon theme "Mint-X" not found.
дек 03 11:10:59 _hostname_ kglobalaccel5[933]: Icon theme "elementary" not found.
дек 03 11:10:59 _hostname_ ksmserver[936]: Qt: Session management error: networkIdsList argument is NULL
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/org.kde.plasmashell.desktop" ("/usr/bin/plasmashell")
дек 03 11:10:59 _hostname_ ksmserver[936]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:10:59 _hostname_ ksmserver[936]: Icon theme "Mint-X" not found.
дек 03 11:10:59 _hostname_ ksmserver[936]: Icon theme "elementary" not found.
дек 03 11:10:59 _hostname_ kcminit_startup[910]: Initializing "kded_touchpad" : "kcminit_touchpad"
дек 03 11:10:59 _hostname_ kcminit_startup[910]: kcm_touchpad: Using X11 backend
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pam_kwallet_init.desktop" ("/usr/lib/pam_kwallet_init")
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/kaccess.desktop" ("/usr/bin/kaccess")
дек 03 11:10:59 _hostname_ kcminit_startup[910]: Initializing "kcm_kgamma" : "kcminit_kgamma"
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/xembedsniproxy.desktop" ("/usr/bin/xembedsniproxy")
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/polkit-kde-authentication-agent-1.desktop" ("/usr/lib/polkit-kde-authentication-agent-1")
дек 03 11:10:59 _hostname_ kaccess[947]: Xlib XKB extension major= 1 minor= 0
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/gmenudbusmenuproxy.desktop" ("/usr/bin/gmenudbusmenuproxy")
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/org.kde.kdeconnect.daemon.desktop" ("/usr/lib/kdeconnectd")
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pulseaudio.desktop" ("/usr/bin/start-pulseaudio-x11")
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/msm_kde_notifier.desktop" ("/usr/bin/msm_kde_notifier")
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/geoclue-demo-agent.desktop" ("/usr/lib/geoclue-2.0/demos/agent")
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/dtd-wayland.desktop" ("/usr/bin/dtd-wayland")
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/home/_user_/.config/autostart/org.kde.yakuake.desktop" ("/usr/bin/yakuake")
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pamac-tray-plasma.desktop" ("/usr/bin/pamac-tray-plasma")
дек 03 11:10:59 _hostname_ systemd[860]: Starting Sound Service...
дек 03 11:10:59 _hostname_ plasma_session[898]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/powerdevil.desktop" ("/usr/lib/org_kde_powerdevil")
дек 03 11:10:59 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Activating service name='ca.desrt.dconf' requested by ':1.12' (uid=1000 pid=918 comm="/usr/bin/kded5 ")
дек 03 11:10:59 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Successfully activated service 'ca.desrt.dconf'
дек 03 11:10:59 _hostname_ kwalletd5[877]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:10:59 _hostname_ kwalletd5[877]: Icon theme "Mint-X" not found.
дек 03 11:10:59 _hostname_ kwalletd5[877]: Icon theme "elementary" not found.
дек 03 11:10:59 _hostname_ kaccess[947]: X server XKB extension major= 1 minor= 0
дек 03 11:11:00 _hostname_ kaccess[947]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:11:00 _hostname_ kaccess[947]: Icon theme "Mint-X" not found.
дек 03 11:11:00 _hostname_ kaccess[947]: Icon theme "elementary" not found.
дек 03 11:11:00 _hostname_ plasmashell[941]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:11:00 _hostname_ plasmashell[941]: Icon theme "Mint-X" not found.
дек 03 11:11:00 _hostname_ sddm[877]: kwalletd5: Checking for pam module
дек 03 11:11:00 _hostname_ sddm[877]: kwalletd5: Got pam-login param
дек 03 11:11:00 _hostname_ sddm[877]: kwalletd5: Waiting for hash on 7-
дек 03 11:11:00 _hostname_ sddm[877]: kwalletd5: waitingForEnvironment on: 3
дек 03 11:11:00 _hostname_ sddm[877]: kwalletd5: client connected
дек 03 11:11:00 _hostname_ sddm[877]: kwalletd5: client disconnected
дек 03 11:11:00 _hostname_ plasmashell[941]: Icon theme "elementary" not found.
дек 03 11:11:00 _hostname_ polkit-kde-authentication-agent-1[952]: New PolkitAgentListener 0x55e556655800
дек 03 11:11:00 _hostname_ polkit-kde-authentication-agent-1[952]: Adding new listener PolkitQt1::Agent::Listener(0x55e55666b480) for 0x55e556655800
дек 03 11:11:00 _hostname_ polkit-kde-authentication-agent-1[952]: Listener online
дек 03 11:11:00 _hostname_ polkitd[404]: Registered Authentication Agent for unix-session:1 (system bus name :1.38 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
дек 03 11:11:00 _hostname_ kernel: kauditd_printk_skb: 25 callbacks suppressed
дек 03 11:11:00 _hostname_ kernel: audit: type=1334 audit(1606983060.097:45): prog-id=12 op=LOAD
дек 03 11:11:00 _hostname_ kernel: audit: type=1334 audit(1606983060.101:46): prog-id=13 op=LOAD
дек 03 11:11:00 _hostname_ audit: BPF prog-id=12 op=LOAD
дек 03 11:11:00 _hostname_ audit: BPF prog-id=13 op=LOAD
дек 03 11:11:00 _hostname_ polkit-kde-authentication-agent-1[952]: Authentication agent result: true
дек 03 11:11:00 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.35' (uid=1000 pid=984 comm="/usr/lib/org_kde_powerdevil ")
дек 03 11:11:00 _hostname_ systemd[1]: Starting Daemon for power management...
дек 03 11:11:00 _hostname_ polkit-kde-authentication-agent-1[952]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:11:00 _hostname_ polkit-kde-authentication-agent-1[952]: Icon theme "Mint-X" not found.
дек 03 11:11:00 _hostname_ polkit-kde-authentication-agent-1[952]: Icon theme "elementary" not found.
дек 03 11:11:00 _hostname_ yakuake[979]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:11:00 _hostname_ yakuake[979]: Icon theme "Mint-X" not found.
дек 03 11:11:00 _hostname_ yakuake[979]: Icon theme "elementary" not found.
дек 03 11:11:00 _hostname_ msm_kde_notifier[967]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:11:00 _hostname_ msm_kde_notifier[967]: Icon theme "Mint-X" not found.
дек 03 11:11:00 _hostname_ msm_kde_notifier[967]: Icon theme "elementary" not found.
дек 03 11:11:00 _hostname_ kwin_x11[922]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 646, resource id: 27262981, major code: 18 (ChangeProperty), minor code: 0
дек 03 11:11:00 _hostname_ pamac-tray-plasma[981]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:11:00 _hostname_ pamac-tray-plasma[981]: Icon theme "Mint-X" not found.
дек 03 11:11:00 _hostname_ pamac-tray-plasma[981]: Icon theme "elementary" not found.
дек 03 11:11:00 _hostname_ NetworkManager[403]: <info> [1606983060.2351] dhcp6 (enp3s0f2): activation: beginning transaction (timeout in 45 seconds)
дек 03 11:11:00 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.28' (uid=1000 pid=981 comm="/usr/bin/pamac-tray-plasma ")
дек 03 11:11:00 _hostname_ systemd[860]: Starting Virtual filesystem service...
дек 03 11:11:00 _hostname_ kdeconnectd[959]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:11:00 _hostname_ kdeconnectd[959]: Icon theme "Mint-X" not found.
дек 03 11:11:00 _hostname_ kdeconnectd[959]: Icon theme "elementary" not found.
дек 03 11:11:00 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Successfully activated service 'org.gtk.vfs.Daemon'
дек 03 11:11:00 _hostname_ systemd[860]: Started Virtual filesystem service.
дек 03 11:11:00 _hostname_ kernel: fuse: init (API version 7.31)
дек 03 11:11:00 _hostname_ systemd[1]: Condition check resulted in FUSE Control File System being skipped.
дек 03 11:11:00 _hostname_ kded5[918]: Installing the delayed initialization callback.
дек 03 11:11:00 _hostname_ yakuake[979]: libpng warning: iCCP: known incorrect sRGB profile
дек 03 11:11:00 _hostname_ kded5[918]: Icon theme "ubuntu-mono-dark" not found.
дек 03 11:11:00 _hostname_ kded5[918]: Icon theme "Mint-X" not found.
дек 03 11:11:00 _hostname_ kded5[918]: Icon theme "elementary" not found.
дек 03 11:11:00 _hostname_ plasmashell[941]: kf.plasma.quick: Applet preload policy set to 1
дек 03 11:11:00 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.40' (uid=1000 pid=982 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
дек 03 11:11:00 _hostname_ systemd[1]: Starting RealtimeKit Scheduling Policy Service...
дек 03 11:11:01 _hostname_ dbus-daemon[402]: [system] Successfully activated service 'org.freedesktop.UPower'
дек 03 11:11:01 _hostname_ systemd[1]: Started Daemon for power management.
дек 03 11:11:01 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:11:01 _hostname_ kernel: audit: type=1130 audit(1606983061.387:47): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:11:01 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.35' (uid=1000 pid=984 comm="/usr/lib/org_kde_powerdevil ")
дек 03 11:11:01 _hostname_ systemd[1]: Starting Disk Manager...
дек 03 11:11:01 _hostname_ udisksd[1104]: udisks daemon version 2.9.1 starting
дек 03 11:11:01 _hostname_ dbus-daemon[402]: [system] Successfully activated service 'org.freedesktop.UDisks2'
дек 03 11:11:01 _hostname_ systemd[1]: Started Disk Manager.
дек 03 11:11:01 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:11:01 _hostname_ udisksd[1104]: Acquired the name org.freedesktop.UDisks2 on the system message bus
дек 03 11:11:01 _hostname_ kernel: audit: type=1130 audit(1606983061.627:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:11:01 _hostname_ systemd[1]: systemd-rfkill.service: Succeeded.
дек 03 11:11:01 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:11:01 _hostname_ kernel: audit: type=1131 audit(1606983061.857:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:11:03 _hostname_ plasmashell[941]: Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
дек 03 11:11:04 _hostname_ plasmashell[941]: trying to show an empty dialog
дек 03 11:11:04 _hostname_ plasmashell[941]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
дек 03 11:11:04 _hostname_ plasmashell[941]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Breath2" is a directory. Use addDir!
дек 03 11:11:04 _hostname_ plasmashell[941]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Next" is a directory. Use addDir!
дек 03 11:11:04 _hostname_ plasmashell[941]: kf.coreaddons: KDirWatch: "/home/_user_/.local/share/wallpapers/Sweet-Wallpapers" is a directory. Use addDir!
дек 03 11:11:04 _hostname_ plasmashell[941]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds" is a directory. Use addDir!
дек 03 11:11:04 _hostname_ plasmashell[941]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
дек 03 11:11:04 _hostname_ plasmashell[941]: Loading Calendar plugin AstronomicalEventsPlugin(0x55eb61cf5760)
дек 03 11:11:04 _hostname_ plasmashell[941]: Loading Calendar plugin HolidaysEventsPlugin(0x55eb61cede10)
дек 03 11:11:04 _hostname_ plasmashell[941]: Both point size and pixel size set. Using pixel size.
дек 03 11:11:04 _hostname_ plasmashell[941]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:524:9: QML Label: Binding loop detected for property "height"
дек 03 11:11:04 _hostname_ plasmashell[941]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:483:13: QML Label: Binding loop detected for property "height"
дек 03 11:11:04 _hostname_ plasmashell[941]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
дек 03 11:11:04 _hostname_ plasmashell[941]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:544:5: QML Label: Binding loop detected for property "height"
дек 03 11:11:04 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Activating service name='org.kde.KScreen' requested by ':1.19' (uid=1000 pid=941 comm="/usr/bin/plasmashell ")
дек 03 11:11:04 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Successfully activated service 'org.kde.KScreen'
дек 03 11:11:04 _hostname_ kscreen_backend_launcher[1132]: kscreen.xrandr: Connected output 67 to CRTC 63
дек 03 11:11:04 _hostname_ kscreen_backend_launcher[1132]: kscreen.xrandr: Connected output 69 to CRTC 64
дек 03 11:11:04 _hostname_ kscreen_backend_launcher[1132]: kscreen.xcb.helper: Detected XRandR 1.6
дек 03 11:11:04 _hostname_ kscreen_backend_launcher[1132]: kscreen.xcb.helper: Event Base: 89
дек 03 11:11:04 _hostname_ kscreen_backend_launcher[1132]: kscreen.xcb.helper: Event Error: 147
дек 03 11:11:05 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Activating service name='org.kde.kdeconnect' requested by ':1.19' (uid=1000 pid=941 comm="/usr/bin/plasmashell ")
дек 03 11:11:06 _hostname_ systemd[1]: NetworkManager-dispatcher.service: Succeeded.
дек 03 11:11:06 _hostname_ audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:11:06 _hostname_ kernel: audit: type=1131 audit(1606983066.241:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:11:25 _hostname_ msm_kde_notifier[967]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
дек 03 11:11:25 _hostname_ pamac-tray-plasma[981]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
дек 03 11:11:25 _hostname_ yakuake[979]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
дек 03 11:11:25 _hostname_ systemd-timesyncd[310]: Initial synchronization to time server 185.189.12.50:123 (2.manjaro.pool.ntp.org).
дек 03 11:11:25 _hostname_ dbus-daemon[402]: [system] Failed to activate service 'org.freedesktop.RealtimeKit1': timed out (service_start_timeout=25000ms)
дек 03 11:11:25 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.45' (uid=1000 pid=982 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
дек 03 11:11:30 _hostname_ plasmashell[941]: error activating kdeconnectd: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
дек 03 11:11:50 _hostname_ dbus-daemon[402]: [system] Failed to activate service 'org.freedesktop.RealtimeKit1': timed out (service_start_timeout=25000ms)
дек 03 11:11:50 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.46' (uid=1000 pid=982 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
дек 03 11:11:55 _hostname_ plasmashell[941]: error activating kdeconnectd: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
дек 03 11:11:55 _hostname_ plasmashell[941]: kdeconnect.interfaces: dbus interface not valid
дек 03 11:11:58 _hostname_ plasma_waitforname[899]: org.kde.knotifications: WaitForName: Service was not registered within timeout
дек 03 11:11:58 _hostname_ dbus-daemon[883]: [session uid=1000 pid=883] Activated service 'org.kde.KSplash' failed: Process org.kde.KSplash exited with status 1
дек 03 11:12:00 _hostname_ msm_kde_notifier[967]: "qt5-translations"
дек 03 11:12:15 _hostname_ dbus-daemon[402]: [system] Failed to activate service 'org.freedesktop.RealtimeKit1': timed out (service_start_timeout=25000ms)
дек 03 11:12:15 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.47' (uid=1000 pid=982 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
дек 03 11:12:17 _hostname_ kded5[918]: bluedevil: Created
дек 03 11:12:17 _hostname_ kded5[918]: Failed to load GeolocationProvider: "Cannot load library /usr/lib/qt/plugins/plasma-geolocation-gps.so: (libgps.so.27: cannot open shared object file: No such file or directory)"
дек 03 11:12:17 _hostname_ kded5[918]: "location"
дек 03 11:12:20 _hostname_ plasmashell[941]: error activating kdeconnectd: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
дек 03 11:12:29 _hostname_ systemd[860]: pulseaudio.service: start operation timed out. Terminating.
дек 03 11:12:29 _hostname_ systemd[860]: pulseaudio.service: Failed with result 'timeout'.
дек 03 11:12:29 _hostname_ systemd[860]: Failed to start Sound Service.
дек 03 11:12:29 _hostname_ systemd[860]: pulseaudio.service: Scheduled restart job, restart counter is at 1.
дек 03 11:12:29 _hostname_ systemd[860]: Stopped Sound Service.
дек 03 11:12:29 _hostname_ systemd[860]: Starting Sound Service...
дек 03 11:12:30 _hostname_ systemd[1]: rtkit-daemon.service: start operation timed out. Terminating.
дек 03 11:12:40 _hostname_ dbus-daemon[402]: [system] Failed to activate service 'org.freedesktop.RealtimeKit1': timed out (service_start_timeout=25000ms)
дек 03 11:12:40 _hostname_ dbus-daemon[402]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.49' (uid=1000 pid=1147 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
дек 03 11:12:42 _hostname_ kded5[918]: kcm_touchpad: Using X11 backend
дек 03 11:12:42 _hostname_ kded5[918]: Delayed initialization.
дек 03 11:12:42 _hostname_ kded5[918]: Reloading the khotkeys configuration
дек 03 11:12:42 _hostname_ kded5[918]: Version 2 File!
дек 03 11:12:42 _hostname_ kded5[918]: true
дек 03 11:12:42 _hostname_ kded5[918]: Imported file "/usr/share/khotkeys/defaults.khotkeys"
дек 03 11:12:42 _hostname_ kded5[918]: Imported file "/usr/share/khotkeys/kde32b1.khotkeys"
дек 03 11:12:42 _hostname_ kded5[918]: Imported file "/usr/share/khotkeys/konqueror_gestures_kde321.khotkeys"
дек 03 11:12:42 _hostname_ kded5[918]: Imported file "/usr/share/khotkeys/konsole.khotkeys"
дек 03 11:12:42 _hostname_ org_kde_powerdevil[984]: org.kde.powerdevil: Handle button events action could not check for screen configuration
дек 03 11:12:42 _hostname_ org_kde_powerdevil[984]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.42'
дек 03 11:12:42 _hostname_ dbus-daemon[402]: [system] Activating service name='org.kde.powerdevil.discretegpuhelper' requested by ':1.35' (uid=1000 pid=984 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
дек 03 11:12:42 _hostname_ dbus-daemon[402]: [system] Successfully activated service 'org.kde.powerdevil.discretegpuhelper'
дек 03 11:12:42 _hostname_ dbus-daemon[402]: [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.35' (uid=1000 pid=984 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
дек 03 11:12:42 _hostname_ dbus-daemon[402]: [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
дек 03 11:12:45 _hostname_ plasmashell[941]: error activating kdeconnectd: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
дек 03 11:12:45 _hostname_ plasmashell[941]: kdeconnect.interfaces: dbus interface not valid
дек 03 11:12:45 _hostname_ plasmashell[941]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
What is the output of $echo $HOSTNAME
On working boot
[migo@vault ~]$ echo $HOSTNAME
vault
as expected
I had similar symptoms a while back. Drove me crazy. Turned out it was because I named my Hostname “localhost”. It’s not the case here. I have no further idea.
I have reinstalled the system and this bug appears anyway.
Damn… Hardware failure? Perhaps run RAM and SSD tests.
