Ewsg
8 November 2022 18:20
1
Hi everyone!
i would be very grateful in to count with your help, if possible.
Today I installed Manjaro (I’m coming from Kubuntu). But, the system started presenting strange “lags”. I really don’t know how to explain this, but it seems sometimes the things are doing some “hicups”.
Lags, etc, I don’t know. But, for example, if I try to open Konsole sometimes everything froozes . And this happens with several apps and moments.
I am really lost here, and don’t know even from where to begin to discover where’s the problem.
Below is the output of inxi:
inxi
CPU: quad core Intel Core i7-7700HQ (-MT MCP-)
speed/min/max: 890/800/3800 MHz Kernel: 5.15.60-1-MANJARO x86_64 Up: 23m
Mem: 3569.1/15882.6 MiB (22.5%) Storage: 2.27 TiB (21.9% used) Procs: 251
Shell: Zsh inxi: 3.3.20
Thanks in advance.
can you report
inxi -Fza
sudo pacman -S cpupower
sudo cpupower frequency-info
sudo mhwd-kernel -li
brahma
8 November 2022 18:26
3
since its a fresh install its probably related to baloo indexer, so go to system settings/search/file search and uncheck all the options, delete the index, click apply and see if it helped
Ewsg
8 November 2022 18:29
4
stephane:
inxi -Fza
Thank you! Sure!
inxi -Fza
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=48a23c44-4ccb-44d2-9319-62b3469c0221 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Predator G3-572 v: V1.22
serial: <superuser required>
Mobo: KBL model: Sienta_KLS v: V1.22 serial: <superuser required>
UEFI: Insyde v: 1.22 date: 03/15/2019
ID-1: BAT1 charge: 44.3 Wh (100.0%) condition: 44.3/48.9 Wh (90.4%)
volts: 16.6 min: 15.2 model: LG 004B384234314341 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 843 high: 900 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 875 2: 865 3: 808 4: 801
5: 800 6: 801 7: 900 8: 900 bogomips: 44817
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Acer Incorporated ALI driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:591b
class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Acer
Incorporated ALI driver: nvidia v: 515.65.01
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-07) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.0 chip-ID: 10de:1c20 class-ID: 0300
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 1-9:5
chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171
class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Acer Incorporated
ALI driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.1 chip-ID: 10ec:8168
class-ID: 0200
IF: enp3s0f1 state: down mac: <filter>
bus-ID: 1-7:3 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 2.27 TiB used: 510.92 GiB (21.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
type: HDD rpm: 5400 serial: <filter> rev: ACM1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk
model: Extreme 55AE size: 465.73 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 3001 scheme: GPT
ID-1: / raw-size: 502.18 GiB size: 493.22 GiB (98.22%) used: 12.29 GiB
(2.5%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 57.4 MiB
(59.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 1.23 TiB size: 1.21 TiB (98.35%) used: 258.44 GiB
(20.9%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-1: swap-1 type: partition size: 29.8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 43.0 C pch: 44.0 C mobo: N/A
Processes: 273 Uptime: 29m wakeups: 1 Memory: 15.51 GiB used: 3.53 GiB
(22.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: 1176 pacman: 1167 lib: 314
flatpak: 9 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
analisando o CPU 0:
CPUs que rodam na mesma frequência de hardware: 0
CPUs que precisam ter suas frequências coordenadas por software: 0
maior latência de transição: Cannot determine or is not supported.
limites do hardware: 800 MHz - 3.80 GHz
reguladores do cpufreq disponíveis: performance powersave
política de frequência atual deve estar entre 800 MHz e 3.80 GHz.
O regulador "powersave" deve decidir qual velocidade usar
dentro desse limite.
current CPU frequency: Unable to call hardware
current CPU frequency: 1.29 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
Currently running: 5.15.60-1-MANJARO (linux515)
* linux515
@brahma ,
I’ll try. Many thanks!
can you check
sudo pacman-mirrors -c all
sudo pacman -Syyu
you can also add sensors ( follow uppercase value )
sudo pacman -S lm_sensors
sudo sensors-detect
Ewsg
8 November 2022 18:55
6
Thanks once again.
So, below is the sensors outpub:
sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +42.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +40.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +45.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +40.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +40.0°C (high = +100.0°C, crit = +100.0°C)
BAT1-acpi-0
Adapter: ACPI interface
in0: 16.65 V
curr1: 0.00 A
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +35.0°C
pch_skylake-virtual-0
temp1: +44.0°C
acpitz-acpi-0
temp1: +27.8°C (crit = +119.0°C)
temp2: +29.8°C (crit = +119.0°C)
The sudo pacman-mirrors -c all command returned a series of queries. The only problem (in red - I suppose this was a problem) was wtih Bangladesh (read timeout).
After that, I ran sudo pacman -Syyu, and the system seems to be upgrading without problems. The only thing I am afraid to have done wrong is that I accidentaly answered Yes to a series of questions, as for example the one mentioning “Change at-spi2-atk for extra/at-spi2-core?”.
no it was good always says Y to go forward.
is there any change since reboot ?
Ewsg
8 November 2022 19:23
8
Understood. Thank you.
So, the system is updating right now. I think the total size is around 2GB. I will await it finishes, restart and check.
Ewsg
8 November 2022 20:04
9
Hi again,
Just updating the thread.
I think the problem is solved (or almost solved). And I think that it was solved by the two procedures you’ve suggested me ( @stephane and @brahma ).
I also noticed a lot of work when I acessed system settings ==> searches. That was probably also causing slowness.
Now I’ll finish somethings and reboot the system.
Thank you very much for all the support and kindness.
Ewsg
8 November 2022 22:13
10
Everything is looking very good! Thank you very much!
