tty: ttyname error: No such device
Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDEM_2501 quiet systemd.show_status=1 splash
driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Console: N/A DM: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE v: x.x serial: N/A
uuid: 032e02b4-0499-0560-e106-5a0700080009 Firmware: UEFI-[Legacy] vendor: American Megatrends
v: F30 date: 03/21/2019
System RAM: total: 16 GiB available: 15.56 GiB used: 2.24 GiB (14.4%)
Array-1: capacity: 256 GiB note: check slots: 4 modules: 2 EC: None max-module-size: 64 GiB
note: est.
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered) size: 8 GiB
speed: 2666 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CMK16GX4M2Z3200C16 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered) size: 8 GiB
Slot: 56 type: PCIe status: in use info: J10 length: short volts: 3.3 bus-ID: 00:03.1 children:
1: 07:00.0 class-ID: 0300 type: display 2: 07:00.1 class-ID: 0403 type: audio
Slot: 57 type: PCIe status: available info: J3600 length: short volts: 3.3 bus-ID: 00:1f.7
Slot: 32 type: PCIe status: other info: J3707 length: short volts: 3.3 bus-ID: 00:1f.7
Info: model: AMD Ryzen 7 2700X socket: AM4 bits: 64 type: MT MCP arch: Zen+ gen: 1+ level: v3
note: check built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2200 min/max: 2200/3700 boost: enabled base/boost: 3700/4350 scaling:
driver: acpi-cpufreq governor: schedutil volts: 1.2 V ext-clock: 100 MHz cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200 13: 2200
14: 2200 15: 2200 16: 2200 bogomips: 118220
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush
clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm
lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt
nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor
svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; STIBP: disabled; RSB filling;
Device-1: Advanced Micro Devices [AMD/ATI] RV730 PRO [Radeon HD 4650] vendor: Gigabyte
driver: radeon v: kernel arch: TeraScale code: R6xx/RV6xx/RV7xx process: TSMC 55-65nm
built: 2005-13 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 16 ports: active: none
empty: DVI-I-1,HDMI-A-1,VGA-1 bus-ID: 06:00.0 chip-ID: 1002:9498 class-ID: 0300
Device-2: NVIDIA GF119 [GeForce GT 610] driver: nvidia v: 390.157 non-free: series: 390.xx+
status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0 xorg: 1.21 arch: Fermi
code: GF1xx process: 40/28nm built: 2010-2016 pcie: gen: 2 speed: 5 GT/s lanes: 16 ports:
active: none off: DVI-I-2,HDMI-A-2 empty: VGA-2 bus-ID: 07:00.0 chip-ID: 10de:104a
class-ID: 0300
Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 046d:085b class-ID: 0102
serial:
Display: server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia tty: 80x40
Monitor-1: DVI-I-2 model: BenQ G2750 serial: built: 2011 res: 1920x1080 dpi: 82
gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.282 y: 0.608 blue: x: 0.149 y: 0.071 white:
x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes: 1920x1080,
1680x1050, 1600x900, 1280x1024, 1280x800, 1280x720, 1024x768, 800x600, 640x480
Monitor-2: HDMI-A-2 model: Lenovo L29w-30 serial: built: 2023 res: 2560x1080 dpi: 97
gamma: 1.2 chroma: red: x: 0.651 y: 0.329 green: x: 0.290 y: 0.639 blue: x: 0.149 y: 0.059 white:
x: 0.314 y: 0.329 size: 673x284mm (26.5x11.18") diag: 730mm (28.8") modes: 2560x1080,
1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1366x768, 1280x800, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480
Monitor-3: Unknown-1 size-res: N/A in console modes: 1024x768
API: EGL v: 1.5 hw: drv: amd r600 platforms: gbm: drv: kms_swrast surfaceless: drv: r600
inactive: wayland,x11
API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 25.3.1-arch1.2 note: console (EGL sourced)
renderer: llvmpipe (LLVM 21.1.6 256 bits), AMD RV730 (DRM 2.50.0 / 6.12.25-1-MANJARO LLVM
21.1.6)
Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
gpu: nvidia-settings,nvidia-smi wl: wayland-info x11: xdpyinfo,xprop
Device-1: Advanced Micro Devices [AMD/ATI] RV710/730 HDMI Audio [Radeon HD 4000 series]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max:
lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:aa38 class-ID: 0403
Device-2: NVIDIA GF119 HDMI Audio driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 07:00.1 chip-ID: 10de:0e08 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-4: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
serial:
API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss type: oss-emulator
Server-2: PipeWire v: 1.4.9 status: n/a (root, process) with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
IF: eno1 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 939.05 GiB used: 26.26 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD
serial: fw-rev: 1B2QEXM7 temp: 43.9 C
SMART: yes health: PASSED on: 150d 17h cycles: 4,957 read-units: 31,398,189 [16.0 TB]
written-units: 42,520,393 [21.7 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD5000AAKS-00M9A0
family: Caviar Blue (SATA) size: 465.76 GiB block-size: physical: 512 B logical: 512 B sata: 2.6
speed: 3.0 Gb/s tech: N/A serial: fw-rev: 1D05 temp: 41 C
SMART: yes state: enabled health: FAILED! on: 4y 51d 17h cycles: 15406 Old-Age:
write error rate: 1 threshold: 1 Pre-Fail: reallocated sector: 123 threshold: 140
alert: FAILING_NOW
ID-3: /dev/sdb maj-min: 8:16 model: PEAK III Flash Drive size: 7.53 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD
serial: fw-rev: 0.00
ID-1: / raw-size: 224.42 GiB size: 224.42 GiB (100.00%) used: 26.26 GiB (11.7%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 32ec7167-5189-417e-a77f-f385b87b81c9
ID-2: /home raw-size: 224.42 GiB size: 224.42 GiB (100.00%) used: 26.26 GiB (11.7%) fs: btrfs
ID-3: /var/cache raw-size: 224.42 GiB size: 224.42 GiB (100.00%) used: 26.26 GiB (11.7%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
ID-4: /var/log raw-size: 224.42 GiB size: 224.42 GiB (100.00%) used: 26.26 GiB (11.7%)
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs label: Recovery uuid: D8E2B65FE2B64194
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 99 MiB fs: fat (32 bit) label: N/A uuid: 62B6-D4CB
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 232.58 GiB fs: ntfs label: Windows10
uuid: 2862B82B62B7FF9C
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 8.16 GiB fs: swap label: N/A
uuid: 12735f01-ad7d-4d99-89b6-899b2eee9a51
ID-6: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: fat (32 bit) label: N/A uuid: 63A3-1E8E
ID-7: /dev/sda2 maj-min: 8:2 size: 465.47 GiB fs: btrfs label: N/A
uuid: 6144a301-4acd-49f1-a1b1-f2a698fc38c4
ID-8: /dev/sdb1 maj-min: 8:17 size: 3.5 GiB fs: N/A label: N/A uuid: N/A
ID-9: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: N/A label: MISO_EFI uuid: CB2B-D61E
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-1.2:4 info: Unicomp Unicomp R7_2_10x_Kbrd_v7_48 type: keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 17f6:0862 class-ID: 0301
Device-2: 1-2:3 info: Brother Industries MFC-660CN type: printer,mass storage
driver: usb-storage,usblp interfaces: 4 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 2mA chip-ID: 04f9:01b0 class-ID: 0806 serial:
Device-3: 1-5:5 info: Kensington Orbit Trackball with Scroll Ring type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 047d:2048 class-ID: 0301
Device-4: 1-10:6 info: Cooler Master AMD SR4 lamplight Control type: keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 2516:0051 class-ID: 0300
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
mode: 3.2 gen-2x1 chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
Device-1: 3-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-2: 3-2:3 info: Transcend Information 2GB/4GB/8GB Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 98mA chip-ID: 1307:0165 class-ID: 0806 serial:
Device-3: 3-4:4 info: Logitech Logitech Webcam C925e type: video,audio
driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 046d:085b class-ID: 0102 serial:
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 42.1 C mobo: N/A gpu: radeon temp: 45.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1587 libs: 405 tools: gnome-software,pamac pm: flatpak pkgs: 0
1: https: //manjaro.kurdy.org/stable/$repo/$arch
2: https: //manjaro.mirrors.uk2.net/stable/$repo/$arch
3: https: //www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
4: https: //ask4.mm.fcix.net/manjaro/stable/$repo/$arch
5: https: //mirror.koddos.net/manjaro/stable/$repo/$arch
6: https: //mirror.vinehost.net/manjaro/stable/$repo/$arch
7: https: //mirrors.cicku.me/manjaro/stable/$repo/$arch
8: https: //mirrors2.manjaro.org/stable/$repo/$arch
9: https: //mirror.komelt.dev/manjaro/stable/$repo/$arch
10: https: //mirror.futureweb.be/manjaro/stable/$repo/$arch
11: https: //mirrors.manjaro.org/repo/stable/$repo/$arch
12: https: //manjaro.syxpi.fr/manjaro/stable/$repo/$arch
13: https: //mirror.bouwhuis.network/manjaro/stable/$repo/$arch
14: https: //manjaro.mirrors.lavatech.top/stable/$repo/$arch
15: https: //mirrors.dotsrc.org/manjaro/stable/$repo/$arch
16: https: //mirror.netcologne.de/manjaro/stable/$repo/$arch
17: https: //ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
18: https: //ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
19: https: //mirrors.ft.uam.es/manjaro/stable/$repo/$arch
20: http: //ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
21: https: //mirror.alpix.eu/manjaro/stable/$repo/$arch
22: https: //mirror.23m.com/manjaro/stable/$repo/$arch
23: https: //mirror.init7.net/manjaro/stable/$repo/$arch
24: https: //mirrors.eric.ovh/manjaro/stable/$repo/$arch
25: https: //mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
26: https: //ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
27: https: //ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
28: https: //manjaro.mirror.wearetriple.com/stable/$repo/$arch
29: https: //mirror.alwyzon.net/manjaro/stable/$repo/$arch
30: https: //mirror.dkm.cz/manjaro/stable/$repo/$arch
31: https: //ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
32: https: //ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
33: https: //ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
34: https: //ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
35: https: //manjaro.ynh.ovh/stable/$repo/$arch
36: https: //mirror.easyname.at/manjaro/stable/$repo/$arch
37: https: //mirror1.sox.rs/manjaro/stable/$repo/$arch
38: https: //mirror.telepoint.bg/manjaro/stable/$repo/$arch
39: https: //ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
40: https: //mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
41: https: //ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
42: https: //ftp.linux.org.tr/manjaro/stable/$repo/$arch
43: https: //manjaro.mirror-services.net/pub/stable/$repo/$arch
44: https: //ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
45: https: //ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
46: https: //fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
47: https: //coresite.mm.fcix.net/manjaro/stable/$repo/$arch
48: https: //cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
49: https: //mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
50: https: //ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
51: https: //ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
52: https: //quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
53: https: //southfront.mm.fcix.net/manjaro/stable/$repo/$arch
54: https: //volico.mm.fcix.net/manjaro/stable/$repo/$arch
55: https: //nocix.mm.fcix.net/manjaro/stable/$repo/$arch
56: https: //mirrors.gigenet.com/manjaro/stable/$repo/$arch
57: https: //nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
58: https: //mirror.xenyth.net/manjaro/stable/$repo/$arch
59: https: //manjaro.grena.ge/stable/$repo/$arch
60: https: //muug.ca/mirror/manjaro/stable/$repo/$arch
61: https: //mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
62: https: //mirror.fcix.net/manjaro/stable/$repo/$arch
63: https: //mirror.it4i.cz/manjaro/stable/$repo/$arch
64: https: //irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
65: https: //repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
66: https: //codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
67: https: //mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
68: https: //mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
69: https: //mirror.freedif.org/Manjaro/stable/$repo/$arch
70: https: //edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
71: https: //mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
72: https: //manjarolinux-mirror.cloud.mu/stable/$repo/$arch
73: https: //mirror.hostiko.network/manjaro/stable/$repo/$arch
74: https: //manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
75: https: //mirror.meowsmp.net/manjaro/stable/$repo/$arch
76: https: //mirrors.sonic.net/manjaro/stable/$repo/$arch
77: https: //manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
78: https: //ziply.mm.fcix.net/manjaro/stable/$repo/$arch
79: https: //mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
80: https: //opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
81: https: //mirrors.xtom.jp/manjaro/stable/$repo/$arch
82: https: //ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
83: https: //mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
84: https: //mirror.xeonbd.com/manjaro/stable/$repo/$arch
85: https: //gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
86: https: //mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
87: https: //mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
88: https: //kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
89: https: //manjaro.c3sl.ufpr.br/stable/$repo/$arch
90: https: //ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
91: https: //mirror.2degrees.nz/manjaro/stable/$repo/$arch
92: https: //mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
93: https: //mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
94: https: //mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
95: https: //manjaro.repo.cure.edu.uy/stable/$repo/$arch
96: https: //linorg.usp.br/manjaro/stable/$repo/$arch
97: https: //mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
98: https: //mirrors.up.pt/pub/manjaro/stable/$repo/$arch
99: https: //mirror.dc.uz/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 361
1: cpu: 100% command: ps pid: 4109 mem: 3.52 MiB (0.0%)
2: cpu: 3.3% command: Xorg pid: 1696 mem: 79.0 MiB (0.4%)
3: cpu: 1.7% command: plasmashell pid: 1813 mem: 603.4 MiB (3.7%)
4: cpu: 0.7% command: kwin_x11 pid: 1794 mem: 221.7 MiB (1.3%)
5: cpu: 0.3% command: [kworker/u66:0-btrfs-endio] pid: 117 mem: 0.00 MiB (0.0%)
Memory top: 5 of 361
1: mem: 603.4 MiB (3.7%) command: plasmashell pid: 1813 cpu: 1.7%
2: mem: 221.7 MiB (1.3%) command: kwin_x11 pid: 1794 cpu: 0.7%
3: mem: 100.4 MiB (0.6%) command: yakuake pid: 2087 cpu: 0.1%
4: mem: 100.0 MiB (0.6%) command: konsole pid: 2479 cpu: 0.2%
5: mem: 92.3 MiB (0.5%) command: kded6 pid: 1790 cpu: 0.0%
Processes: 361 Power: uptime: 11m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 6.18 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 258
Compilers: clang: 21.1.6 gcc: 15.2.1 Client: shell wrapper v: 5.3.8-release inxi: 3.3.40
I have fixed this for you (@Nachlese)
