After installing manjaro on brand new SSD 2TB on HP z400 system. Manjaro randomly freezes. I tried to disable the gnome ext’s as per suggestions provided by this forum but still no use. Today while giving an interview it froze completely and i have no other choice except Hard press reboot( i know this was very bad method but no choice). There is no other OS running on it and there is no swap issue at all as i am using whole 2TB for the OS and also i used auto partition during installation.
Here is my inxi -Fazy output:
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d0942261-e115-4c23-84a9-273f812ad8b2 rw quiet splash apparmor=1
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop System: Hewlett-Packard product: HP Z400 Workstation v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Hewlett-Packard model: xxx v: C serial: <superuser required>
BIOS: Hewlett-Packard v: 7xxxxv03.57 date: 07/15/2013
Info: model: Intel Xeon W3520 bits: 64 type: MT MCP arch: Nehalem level: v2
built: 2008-10 process: Intel 45nm family: 6 model-id: 0x1A (26) stepping: 5
microcode: 0x1D
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1620 high: 1765 min/max: 1596/2661 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 1600
3: 1600 4: 1600 5: 1600 6: 1765 7: 1600 8: 1600 bogomips: 42684
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA G96GL [Quadro FX 380] driver: nouveau v: kernel non-free:
series: 340.xx status: legacy (EOL) last: release: 340.108 kernel: 5.4
xorg: 1.20 arch: Tesla process: 40-80nm built: 2006-13 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 ports: active: DVI-I-2 empty: DVI-I-1
bus-ID: 0f:00.0 chip-ID: 10de:0658 class-ID: 0300 temp: 58.0 C
Device-2: Trust HDH Webcam USB type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-4:4 chip-ID: 145f:02ec class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: DVI-I-2 model: Asus VE247 serial: <filter> built: 2013
res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 3.3 Mesa 22.3.1 renderer: NV96 direct render: Yes
Device-1: Intel 82801JI HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel bus-ID: 2-4:4 v: kernel bus-ID: 00:1b.0
chip-ID: 145f:02ec class-ID: 0102 chip-ID: 8086:3a3e class-ID: 0403
serial: <filter>
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe
vendor: Hewlett-Packard driver: tg3 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 14e4:1684 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: d0c0
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 1.82 TiB used: 22.93 GiB (1.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 045 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 22.93 GiB (1.3%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 49.0 C mobo: N/A gpu: nouveau temp: 59.0 C
Fan Speeds (RPM): cpu: 3006 fan-2: 0 fan-3: 0 gpu: nouveau fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: N/A gpu: nouveau mV: 1000.00
Processes: 280 Uptime: 11h 57m wakeups: 1 Memory: 15.61 GiB
used: 6.1 GiB (39.1%) Init: systemd v: 252 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1319
libs: 343 tools: gnome-software,pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.24
… just saying that this is a double non sequitur
because you do not have any swap - so, of course it can’t be an issue …
and because having used auto partition and the whole drive also doesn’t magically prevent any problems
with 16GB RAM and no swap you can very well run into problematic situations
Thank you Nachlese for the reply. Yes after going through the output i too figured out that there is no swap and did create swapfile for 32GB based on swap recommendations from forum [Swap#Do_I_Need_Swap]
I would like to create a separate partition but don’t know how to create. Any help would be appreciable
Paritial inxi output:
AID:
Local Storage: total: 1.82 TiB used: 54.19 GiB (2.9%)
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 54.19 GiB (3.0%)
ID-1: swap-1 type: file size: 31.25 GiB used: 516 KiB (0.0%) priority: -2
file: /swapfile
Can you post fdisk -l and/or blkid ?
brahma
10 January 2023 07:38
5
this is probably one of the reasons for those freezes:
you have old nvidia gpu, which is no longer supported by manjaro and other distros…
you can install older kernels:
sudo mhwd-kernel -i linux54
sudo mhwd-kernel -i linux510
and try with them and see how it works…
or you can install the drivers manually by checking this topic:
Prepare your system for building drivers
you may want to install development tools:sudo pacman -S git base-devel
then you may want to install your proper kernel headers:sudo pacman -S $(mhwd-kernel -li | grep '*' | cut -d ' ' -f5 | awk '{print $0,"-headers"}' | sed s'/ //'g)
340xx (dkms for kernel 5.4 or 5.10 only)
You need to get the sources first:
git clone https://gitlab.manjaro.org/packages/extra/nvidia-340xx-utils.git
git clone https://gitlab.manjaro.org/packages/multilib/lib32-nvi…
another possible reason could be that you are on RAID:
instead of being on AHCI, you can switch to AHCI in bios, but if you are dual booting with windows, you will not be able to boot into windows after switching…
6x12
10 January 2023 08:48
6
In addition to the info @brahma provided, and as someone who’s tried running the same generation of hardware (requiring the 340.108 legacy driver) on open source nouveau, I can say that cinnamon, kde and especially gnome are a definite no-no (Xfce, mate, openbox and awesome editions run ok but temps are generally higher).
My tip would be: pick the right edition (LTS kernels only and ideally starting with the ‘minimal’ versions on open source nouveau), configure desktop to ease load on graphic, then install the above mentioned 340.108 legacy driver.
The swap file that you now have is just as good - no need to invest time in trying to use a partition instead.
It probably does not need to be that big either, equal the RAM size should be plenty.
You can look at something like zramswap, mentioned here:
Improving performance - ArchWiki
to give you more leeway.
I can’t help with the potential graphics issue though.
Lycan
10 January 2023 10:11
8
Just enable zram, it is amazing nobody has suggested this to you. It works like a charm in my SSD, no damage at all and no need for swap file or swap in general
Thank you Lycan. How to enable Zram?
Thank you @brahma , 6x12 for all suggestions. I will try to check the device drivers.
dmt
10 January 2023 15:07
11
308d5aac84e7847d67cf:
How to enable Zram?
Feel free to try but I wouldn’t. zram is for speeding up swap, not for extending RAM.
zswap is already enabled by default, it’s similar to zram but can also be backed by a swapfile/partition, which makes it superior IMO.
zswap - ArchWiki
zram - ArchWiki
I’d stick with your swapfile for now.
Disk /dev/sda: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: CT2000MX500SSD1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x8050eb1d
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 3907024064 3907022017 1.8T 83 Linux
Can you post the output of top ?
You have a swap file.
Wollie
13 January 2023 16:03
14
What programs are running when it freezes?
How much RAM was used at time of freezing?
Have you checked for BIOS updates?
sorry for the delay. I was mainly using for datascience projects and i have dvi-hdmi connection cable. I don’t know how much ram using at the time of freeze. and not sure how to check bios updates? can you please help me with pointers on how to check and upgrade
update: after swap file the frequency went down but still experiencing the freezes once in a while.
Another kernel is easy to test:
Please install 2 kernels (one of them LTS)
Gentle shut down a suddenly hanged PC to minimize a chance of getting a broken filesystem and data loss:
Difficulty: ★★☆☆☆
This tutorial was created because people are using a hard power off during freezes, so this will teach you how to turn off your computer when everything is frozen using softer means.
So whenever you see someone saying they had to “Power Off” or “Hard Reset” their system without doing a REISUB, please send them here!
If you’re reading this in response to a question, please click the green link above this text to bring you to the full unabridged text of the tutorial…
6x12
29 January 2023 20:55
18
Gnome is no longer as heavy as it once was. It has come along way. I have one setup from 2010 and it runs buttery smooth.
