System is blocked when leaved unattended (all AMD machine)
Hi all,
sometimes (but not regularly) my system hangs: I see the desktop with the opened applications; but no mouse and no keyboard).
It happens when I leave the machine unattended for more the 15 minutes;but it doesn’t always happen.
From another machine I was able to ssh into the hanged machine to save dmesg output.
From the ssh session I tried to reboot but I was only thrown out and cannot reconnect.
I don’t know what to do.
TL;DR
Some suspicious messages in dmesg:
[32073.498153] INFO: task kworker/u64:4:58582 blocked for more than 245 seconds.
[32073.498155]       Not tainted 6.19.8-1-MANJARO #1
[32073.498157] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[32073.498158] task:kworker/u64:4   state:D stack:0     pid:58582 tgid:58582 ppid:2      task_flags:0x4208060 flags:0x00080000
[32073.498163] Workqueue: amdgpu-reset-dev drm_sched_job_timedout [gpu_sched]
[32073.498170] Call Trace:
[32196.599632] Future hung task reports are suppressed, see sysctl kernel.hung_task_warnings
[32224.284412] INFO: NMI handler (perf_ibs_nmi_handler) took too long to run: 21.892 msecs
[32224.284422] perf: interrupt took too long (172237 > 2500), lowering kernel.perf_event_max_sample_rate to 1000
[34806.968782] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 150000 tries - optc32_disable_crtc line:195
[37003.540330] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 100000 tries - optc32_phantom_crtc_post_enable line:210
[37004.198433] amdgpu 0000:2f:00.0: amdgpu: SMU: response:0xFFFFFFFF for index:42 param:0x00000000 message:PowerUpVcn?
[37004.198438] amdgpu 0000:2f:00.0: amdgpu: Failed to power ungate VCN instance 0!
[37004.198449] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37004.198451] amdgpu 0000:2f:00.0: amdgpu: Failed to disable gfxoff!
[37004.198442] [drm:vcn_v4_0_start [amdgpu]] *ERROR* Dpm enable uvd failed, ret = -121.
[37005.647479] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 10us * 10 tries - mpc3_power_on_ogam_lut line:185
[37005.911020] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37005.911024] amdgpu 0000:2f:00.0: amdgpu: Failed to set workload mask 0x0000000b
[37005.911027] amdgpu 0000:2f:00.0: amdgpu: (-121) failed to enable video power profile mode
[37005.911044] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37005.911045] amdgpu 0000:2f:00.0: amdgpu: Failed to set workload mask 0x0000000b
[37005.911047] amdgpu 0000:2f:00.0: amdgpu: (-121) failed to enable video power profile mode
[37007.388792] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37007.388796] amdgpu 0000:2f:00.0: amdgpu: Failed to disable gfxoff!
[37023.991084] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37023.991089] amdgpu 0000:2f:00.0: amdgpu: Failed to disable gfxoff!
[37025.801442] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37025.801447] amdgpu 0000:2f:00.0: amdgpu: Failed to disable gfxoff!
[37028.470902] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 1000 tries - dcn32_hubp_pg_control line:181
[37028.492852] amdgpu 0000:2f:00.0: amdgpu: Dumping IP State Completed
[37028.492902] amdgpu 0000:2f:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
[37028.492904] amdgpu 0000:2f:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
[37028.492907] amdgpu 0000:2f:00.0: amdgpu: ring vcn_unified_0 timeout, signaled seq=210158, emitted seq=210159
[37028.492909] amdgpu 0000:2f:00.0: amdgpu:  Process RDD Process pid 2736 thread browser 4 :cs0 pid 4827
[37028.492911] amdgpu 0000:2f:00.0: amdgpu: Starting vcn_unified_0 ring reset
[37031.322630] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 10us * 10 tries - mpc3_power_on_ogam_lut line:185
[38920.387579] clocksource: timekeeping watchdog on CPU14: hpet wd-wd read-back delay of 21937494ns
[38920.387586] clocksource: wd-tsc-wd read-back delay of 21937564ns, clock-skew test skipped!
[38934.582417] amdgpu 0000:2f:00.0: amdgpu: Register(0) [regUVD_POWER_STATUS] failed to reach value 0x00000001 != 0x00000002n
Opened applications:
  • zen-browser (with focus)
  • thunderbird
  • virtual machine manager
  • dolphin
  • konsole
My inxi configuration
[mirto@bianco500 ~]$ inxi -Fazi
  Kernel: 6.19.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64
    root=UUID=95b01923-1bed-4694-bb66-72e635384b04 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
  Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84)
    v: 1.0 serial: <superuser required> uuid: <superuser required>
    Firmware: UEFI vendor: American Megatrends LLC. v: 1.H0 date: 07/16/2024
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 1754 min/max: 556/4854 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1754 2: 1754 3: 1754
    4: 1754 5: 1754 6: 1754 7: 1754 8: 1754 9: 1754 10: 1754 11: 1754 12: 1754
    13: 1754 14: 1754 15: 1754 16: 1754 bogomips: 121598
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
    ssse3 svm
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 33 [Radeon RX 7600/7600
    XT/7600M XT/7600S/7700S / PRO W7600] vendor: Sapphire driver: amdgpu
    v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n6 (6nm) built: 2023+
    pcie: gen: 4 speed: 16 GT/s lanes: 8 ports: active: DP-1,HDMI-A-2
    empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 2f:00.0 chip-ID: 1002:7480
    class-ID: 0300
  Device-2: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3.1:3
    chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 5760x2160 display-ID: 0
  Monitor-1: DP-1 pos: primary,left model: LG (GoldStar) HDR 4K
    serial: <filter> built: 2024 res: mode: 3840x2160 hz: 60 scale: 150% (1.5)
    to: 2560x1440 dpi: 139 gamma: 1.2 size: 697x392mm (27.44x15.43")
    diag: 806mm (31.7") ratio: 16:9 modes: max: 3840x2160 min: 640x480
  Monitor-2: HDMI-A-2 pos: right model: Sony TV 00 serial: <filter>
    built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 51 gamma: 1.2
    size: 952x535mm (37.48x21.06") diag: 1092mm (43") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7600 XT (radeonsi
    navi33 ACO DRM 3.64 6.19.8-1-MANJARO) device-ID: 1002:7480
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 2 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7600 XT (RADV NAVI33) driver: mesa radv v: 26.0.2-arch1.1
    device-ID: 1002:7480 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: lact wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 2f:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.19.8-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: e000 bus-ID: 25:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  IF: enp37s0 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 26:00.0
  IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
  IF-ID-2: virbr0 state: down mac: <filter>
  IF-ID-3: virbr1 state: down mac: <filter>
  IF-ID-4: virbr2 state: down mac: <filter>
  Info: services: NetworkManager, nfsd, sshd, systemd-timesyncd,
    wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 20.92 TiB used: 8.95 TiB (42.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 Plus
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT4P1.3 temp: 32.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Sabrent model: Rocket 4.0 Plus
    lanes: 4 tech: SSD serial: <filter> fw-rev: R4PB47.2 temp: 30.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST18000NM000J-2TV103
    size: 16.37 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SC02 scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 191.71 GiB (20.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 45.8 C mobo: 41.5 C gpu: amdgpu temp: 50.0 C
    mem: 66.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 44
  Memory: total: 64 GiB note: est. available: 62.72 GiB used: 4.74 GiB (7.6%)
  Processes: 428 Power: uptime: 12m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.03 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1947 libs: 455 tools: pamac pm: flatpak pkgs: 0
    Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Bash v: 5.3.9
    running-in: konsole inxi: 3.3.40
Copying here the complete dmseg log (I don’t know how to attach a txt file)
[    0.075739] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[    0.075740] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.075753] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64 root=UUID=95b01923-1bed-4694-bb66-72e635384b04 rw quiet splash udev.log_priority=3
[    0.075798] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.075817] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[    0.079936] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[    0.082026] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.082132] software IO TLB: area num 16.
[    0.090098] Fallback order for Node 0: 0
[    0.090102] Built 1 zonelists, mobility grouping on.  Total pages: 16758116
[    0.090103] Policy zone: Normal
[    0.090266] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.171410] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.180613] ftrace: allocating 57821 entries in 228 pages
[    0.180615] ftrace: allocated 228 pages with 4 groups
[    0.180685] Dynamic Preempt: full
[    0.180733] rcu: Preemptible hierarchical RCU implementation.
[    0.180733] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=16.
[    0.180735] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.180735] 	Trampoline variant of Tasks RCU enabled.
[    0.180736] 	Rude variant of Tasks RCU enabled.
[    0.180736] 	Tracing variant of Tasks RCU enabled.
[    0.180737] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.180737] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[    0.180747] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[    0.180749] RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[    0.180751] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[    0.183809] NR_IRQS: 524544, nr_irqs: 1096, preallocated irqs: 16
[    0.183996] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.184105] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.184141] Console: colour dummy device 80x25
[    0.184143] printk: legacy console [tty0] enabled
[    0.184174] ACPI: Core revision 20250807
[    0.184283] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.184304] APIC: Switch to symmetric I/O mode setup
[    0.184606] AMD-Vi: Using global IVHD EFR:0x0, EFR2:0x0
[    0.811122] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.812019] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.816237] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6d8f55c468b, max_idle_ns: 881590565967 ns
[    0.816241] Calibrating delay loop (skipped), value calculated using timer frequency.. 7600.71 BogoMIPS (lpj=3800358)
[    0.816254] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    0.816280] LVT offset 1 assigned for vector 0xf9
[    0.816281] LVT offset 2 assigned for vector 0xf4
[    0.816427] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[    0.816427] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[    0.816432] process: using mwait in idle threads
[    0.816433] mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
[    0.816436] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.816437] Transient Scheduler Attacks: Mitigation: Clear CPU buffers
[    0.816437] Spectre V2 : Mitigation: Retpolines
[    0.816438] Spectre V2 : User space: Mitigation: STIBP always-on protection
[    0.816439] Speculative Return Stack Overflow: Mitigation: Safe RET
[    0.816439] VMSCAPE: Mitigation: IBPB before exit to userspace
[    0.816440] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.816440] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
[    0.816441] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.816442] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.816443] active return thunk: srso_alias_return_thunk
[    0.816450] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.816450] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.816451] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.816451] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[    0.816452] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[    0.816452] x86/fpu: Supporting XSAVE feature 0x1000: 'Control-flow Kernel registers (KVM only)'
[    0.816453] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.816454] x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
[    0.816455] x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
[    0.816455] x86/fpu: xstate_offset[12]:  856, xstate_sizes[12]:   24
[    0.816456] x86/fpu: Enabled xstate features 0x1a07, context size is 880 bytes, using 'compacted' format.
[    0.842287] Freeing SMP alternatives memory: 56K
[    0.842291] pid_max: default: 32768 minimum: 301
[    0.842404] landlock: Up and running.
[    0.842406] Yama: becoming mindful.
[    0.842617] LSM support for eBPF active
[    0.842703] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.842774] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.945556] smpboot: CPU0: AMD Ryzen 7 5800X 8-Core Processor (family: 0x19, model: 0x21, stepping: 0x0)
[    0.945734] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[    0.945740] ... version:                   0
[    0.945741] ... bit width:                 48
[    0.945742] ... generic counters:          6
[    0.945743] ... generic bitmap:            000000000000003f
[    0.945744] ... fixed-purpose counters:    0
[    0.945744] ... fixed-purpose bitmap:      0000000000000000
[    0.945745] ... value mask:                0000ffffffffffff
[    0.945746] ... max period:                00007fffffffffff
[    0.945747] ... global_ctrl mask:          000000000000003f
[    0.945832] signal: max sigframe size: 3376
[    0.945876] rcu: Hierarchical SRCU implementation.
[    0.945877] rcu: 	Max phase no-delay instances is 400.
[    0.945929] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[    0.950493] MCE: In-kernel MCE decoding enabled.
[    0.950530] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.950634] smp: Bringing up secondary CPUs ...
[    0.950716] smpboot: x86: Booting SMP configuration:
[    0.950717] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
[    0.962362] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[    0.970282] smp: Brought up 1 node, 16 CPUs
[    0.970282] smpboot: Total of 16 processors activated (121611.45 BogoMIPS)
[    0.971414] Memory: 65591844K/67032464K available (20511K kernel code, 2967K rwdata, 16748K rodata, 4768K init, 4596K bss, 1417088K reserved, 0K cma-reserved)
[    0.972767] devtmpfs: initialized
[    0.972767] x86/mm: Memory block size: 2048MB
[    0.973843] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20dfff] (57344 bytes)
[    0.973843] ACPI: PM: Registering ACPI NVS region [mem 0xdb4b4000-0xdcbb2fff] (24113152 bytes)
[    0.974251] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.974251] posixtimers hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.974268] futex hash table entries: 4096 (262144 bytes on 1 NUMA nodes, total 256 KiB, linear).
[    0.974447] PM: RTC time: 05:52:12, date: 2026-04-11
[    0.974824] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.975119] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.975322] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.975475] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.975480] audit: initializing netlink subsys (disabled)
[    0.975486] audit: type=2000 audit(1775886731.166:1): state=initialized audit_enabled=0 res=1
[    0.975486] thermal_sys: Registered thermal governor 'fair_share'
[    0.975486] thermal_sys: Registered thermal governor 'bang_bang'
[    0.975486] thermal_sys: Registered thermal governor 'step_wise'
[    0.975486] thermal_sys: Registered thermal governor 'user_space'
[    0.975486] thermal_sys: Registered thermal governor 'power_allocator'
[    0.975486] cpuidle: using governor ladder
[    0.975486] cpuidle: using governor menu
[    0.975486] Detected 1 PCC Subspaces
[    0.975486] Registering PCC driver as Mailbox controller
[    0.978757] efi: Freeing EFI boot services memory: 80004K
[    0.978760] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.978852] PCI: ECAM [mem 0xf0000000-0xf7ffffff] (base 0xf0000000) for domain 0000 [bus 00-7f]
[    0.978860] PCI: Using configuration type 1 for base access
[    0.979002] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.980352] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.980352] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.980352] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.980352] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.980550] raid6: skipped pq benchmark and selected avx2x4
[    0.980552] raid6: using avx2x2 recovery algorithm
[    0.980627] ACPI: Added _OSI(Module Device)
[    0.980629] ACPI: Added _OSI(Processor Device)
[    0.980630] ACPI: Added _OSI(Processor Aggregator Device)
[    0.999240] ACPI: 11 ACPI AML tables successfully acquired and loaded
[    1.001788] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    1.005952] ACPI: Interpreter enabled
[    1.005969] ACPI: PM: (supports S0 S3 S4 S5)
[    1.005971] ACPI: Using IOAPIC for interrupt routing
[    1.007446] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    1.007447] PCI: Ignoring E820 reservations for host bridge windows
[    1.007933] ACPI: Enabled 2 GPEs in block 00 to 1F
[    1.023533] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    1.023538] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    1.023644] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[    1.023837] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    1.023847] acpi PNP0A08:00: [Firmware Info]: ECAM [mem 0xf0000000-0xf7ffffff] for domain 0000 [bus 00-7f] only partially covers this bridge
[    1.024383] PCI host bridge to bus 0000:00
[    1.024387] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    1.024390] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    1.024391] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    1.024393] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    1.024395] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[    1.024396] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfcffffff window]
[    1.024398] pci_bus 0000:00: root bus resource [mem 0x1020000000-0x7fffffffff window]
[    1.024399] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.024415] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000 conventional PCI endpoint
[    1.024561] pci 0000:00:00.2: [1022:1481] type 00 class 0x080600 conventional PCI endpoint
[    1.024699] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[    1.024800] pci 0000:00:01.1: [1022:1483] type 01 class 0x060400 PCIe Root Port
[    1.024822] pci 0000:00:01.1: PCI bridge to [bus 01]
[    1.024829] pci 0000:00:01.1:   bridge window [mem 0xfcf00000-0xfcffffff]
[    1.024913] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[    1.025091] pci 0000:00:01.2: [1022:1483] type 01 class 0x060400 PCIe Root Port
[    1.025113] pci 0000:00:01.2: PCI bridge to [bus 20-2c]
[    1.025118] pci 0000:00:01.2:   bridge window [io  0xd000-0xefff]
[    1.025121] pci 0000:00:01.2:   bridge window [mem 0xfc100000-0xfc8fffff]
[    1.025204] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[    1.025409] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[    1.025507] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[    1.025602] pci 0000:00:03.1: [1022:1483] type 01 class 0x060400 PCIe Root Port
[    1.025624] pci 0000:00:03.1: PCI bridge to [bus 2d-2f]
[    1.025630] pci 0000:00:03.1:   bridge window [io  0xf000-0xffff]
[    1.025633] pci 0000:00:03.1:   bridge window [mem 0xfcc00000-0xfcefffff]
[    1.025641] pci 0000:00:03.1:   bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[    1.025716] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[    1.025892] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[    1.025988] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[    1.026086] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[    1.026181] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400 PCIe Root Port
[    1.026204] pci 0000:00:07.1: PCI bridge to [bus 30]
[    1.026296] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[    1.026473] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000 conventional PCI endpoint
[    1.026570] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400 PCIe Root Port
[    1.026594] pci 0000:00:08.1: PCI bridge to [bus 31]
[    1.026602] pci 0000:00:08.1:   bridge window [mem 0xfc900000-0xfcbfffff]
[    1.026691] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[    1.026900] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500 conventional PCI endpoint
[    1.027043] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100 conventional PCI endpoint
[    1.027197] pci 0000:00:18.0: [1022:1440] type 00 class 0x060000 conventional PCI endpoint
[    1.027238] pci 0000:00:18.1: [1022:1441] type 00 class 0x060000 conventional PCI endpoint
[    1.027280] pci 0000:00:18.2: [1022:1442] type 00 class 0x060000 conventional PCI endpoint
[    1.027320] pci 0000:00:18.3: [1022:1443] type 00 class 0x060000 conventional PCI endpoint
[    1.027360] pci 0000:00:18.4: [1022:1444] type 00 class 0x060000 conventional PCI endpoint
[    1.027399] pci 0000:00:18.5: [1022:1445] type 00 class 0x060000 conventional PCI endpoint
[    1.027440] pci 0000:00:18.6: [1022:1446] type 00 class 0x060000 conventional PCI endpoint
[    1.027480] pci 0000:00:18.7: [1022:1447] type 00 class 0x060000 conventional PCI endpoint
[    1.027616] pci 0000:01:00.0: [1987:5018] type 00 class 0x010802 PCIe Endpoint
[    1.027730] pci 0000:01:00.0: BAR 0 [mem 0xfcf00000-0xfcf03fff 64bit]
[    1.028559] pci 0000:00:01.1: PCI bridge to [bus 01]
[    1.028640] pci 0000:20:00.0: [1022:57ad] type 01 class 0x060400 PCIe Switch Upstream Port
[    1.028684] pci 0000:20:00.0: PCI bridge to [bus 21-2c]
[    1.028694] pci 0000:20:00.0:   bridge window [io  0xd000-0xefff]
[    1.028699] pci 0000:20:00.0:   bridge window [mem 0xfc100000-0xfc8fffff]
[    1.028841] pci 0000:20:00.0: PME# supported from D0 D3hot D3cold
[    1.029010] pci 0000:20:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 126.024 Gb/s with 16.0 GT/s PCIe x8 link)
[    1.029161] pci 0000:00:01.2: PCI bridge to [bus 20-2c]
[    1.029537] pci 0000:21:01.0: [1022:57a3] type 01 class 0x060400 PCIe Switch Downstream Port
[    1.029579] pci 0000:21:01.0: PCI bridge to [bus 23]
[    1.029592] pci 0000:21:01.0:   bridge window [mem 0xfc800000-0xfc8fffff]
[    1.029944] pci 0000:21:01.0: PME# supported from D0 D3hot D3cold
[    1.030508] pci 0000:21:03.0: [1022:57a3] type 01 class 0x060400 PCIe Switch Downstream Port
[    1.030550] pci 0000:21:03.0: PCI bridge to [bus 25]
[    1.030560] pci 0000:21:03.0:   bridge window [io  0xe000-0xefff]
[    1.030565] pci 0000:21:03.0:   bridge window [mem 0xfc700000-0xfc7fffff]
[    1.030917] pci 0000:21:03.0: PME# supported from D0 D3hot D3cold
[    1.031473] pci 0000:21:04.0: [1022:57a3] type 01 class 0x060400 PCIe Switch Downstream Port
[    1.031515] pci 0000:21:04.0: PCI bridge to [bus 26]
[    1.031525] pci 0000:21:04.0:   bridge window [io  0xd000-0xdfff]
[    1.031530] pci 0000:21:04.0:   bridge window [mem 0xfc600000-0xfc6fffff]
[    1.031889] pci 0000:21:04.0: PME# supported from D0 D3hot D3cold
[    1.032457] pci 0000:21:06.0: [1022:57a3] type 01 class 0x060400 PCIe Switch Downstream Port
[    1.032500] pci 0000:21:06.0: PCI bridge to [bus 28]
[    1.032513] pci 0000:21:06.0:   bridge window [mem 0xfc500000-0xfc5fffff]
[    1.032867] pci 0000:21:06.0: PME# supported from D0 D3hot D3cold
[    1.033449] pci 0000:21:08.0: [1022:57a4] type 01 class 0x060400 PCIe Switch Downstream Port
[    1.033493] pci 0000:21:08.0: PCI bridge to [bus 2a]
[    1.033506] pci 0000:21:08.0:   bridge window [mem 0xfc100000-0xfc2fffff]
[    1.033747] pci 0000:21:08.0: PME# supported from D0 D3hot D3cold
[    1.034092] pci 0000:21:09.0: [1022:57a4] type 01 class 0x060400 PCIe Switch Downstream Port
[    1.034136] pci 0000:21:09.0: PCI bridge to [bus 2b]
[    1.034149] pci 0000:21:09.0:   bridge window [mem 0xfc400000-0xfc4fffff]
[    1.034392] pci 0000:21:09.0: PME# supported from D0 D3hot D3cold
[    1.034696] pci 0000:21:0a.0: [1022:57a4] type 01 class 0x060400 PCIe Switch Downstream Port
[    1.034740] pci 0000:21:0a.0: PCI bridge to [bus 2c]
[    1.034753] pci 0000:21:0a.0:   bridge window [mem 0xfc300000-0xfc3fffff]
[    1.035016] pci 0000:21:0a.0: PME# supported from D0 D3hot D3cold
[    1.035328] pci 0000:20:00.0: PCI bridge to [bus 21-2c]
[    1.035496] pci 0000:23:00.0: [1987:5018] type 00 class 0x010802 PCIe Endpoint
[    1.035638] pci 0000:23:00.0: BAR 0 [mem 0xfc800000-0xfc803fff 64bit]
[    1.036719] pci 0000:21:01.0: PCI bridge to [bus 23]
[    1.036873] pci 0000:25:00.0: [10ec:8125] type 00 class 0x020000 PCIe Endpoint
[    1.036956] pci 0000:25:00.0: BAR 0 [io  0xe000-0xe0ff]
[    1.036964] pci 0000:25:00.0: BAR 2 [mem 0xfc700000-0xfc70ffff 64bit]
[    1.036970] pci 0000:25:00.0: BAR 4 [mem 0xfc710000-0xfc713fff 64bit]
[    1.037162] pci 0000:25:00.0: supports D1 D2
[    1.037164] pci 0000:25:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.037594] pci 0000:21:03.0: PCI bridge to [bus 25]
[    1.037747] pci 0000:26:00.0: [10ec:8125] type 00 class 0x020000 PCIe Endpoint
[    1.037829] pci 0000:26:00.0: BAR 0 [io  0xd000-0xd0ff]
[    1.037837] pci 0000:26:00.0: BAR 2 [mem 0xfc600000-0xfc60ffff 64bit]
[    1.037843] pci 0000:26:00.0: BAR 4 [mem 0xfc610000-0xfc613fff 64bit]
[    1.038036] pci 0000:26:00.0: supports D1 D2
[    1.038037] pci 0000:26:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.038465] pci 0000:21:04.0: PCI bridge to [bus 26]
[    1.038629] pci 0000:28:00.0: [8086:2723] type 00 class 0x028000 PCIe Endpoint
[    1.038720] pci 0000:28:00.0: BAR 0 [mem 0xfc500000-0xfc503fff 64bit]
[    1.038888] pci 0000:28:00.0: PME# supported from D0 D3hot D3cold
[    1.039206] pci 0000:21:06.0: PCI bridge to [bus 28]
[    1.039371] pci 0000:2a:00.0: [1022:1485] type 00 class 0x130000 PCIe Endpoint
[    1.039721] pci 0000:2a:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    1.039987] pci 0000:2a:00.1: [1022:149c] type 00 class 0x0c0330 PCIe Endpoint
[    1.040676] pci 0000:2a:00.1: BAR 0 [mem 0xfc200000-0xfc2fffff 64bit]
[    1.041337] pci 0000:2a:00.1: PME# supported from D0 D3hot D3cold
[    1.041919] pci 0000:2a:00.3: [1022:149c] type 00 class 0x0c0330 PCIe Endpoint
[    1.041992] pci 0000:2a:00.3: BAR 0 [mem 0xfc100000-0xfc1fffff 64bit]
[    1.042109] pci 0000:2a:00.3: PME# supported from D0 D3hot D3cold
[    1.042329] pci 0000:21:08.0: PCI bridge to [bus 2a]
[    1.042465] pci 0000:2b:00.0: [1022:7901] type 00 class 0x010601 PCIe Endpoint
[    1.042545] pci 0000:2b:00.0: BAR 5 [mem 0xfc400000-0xfc4007ff]
[    1.042693] pci 0000:2b:00.0: PME# supported from D3hot D3cold
[    1.042845] pci 0000:2b:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    1.042942] pci 0000:21:09.0: PCI bridge to [bus 2b]
[    1.043077] pci 0000:2c:00.0: [1022:7901] type 00 class 0x010601 PCIe Endpoint
[    1.043157] pci 0000:2c:00.0: BAR 5 [mem 0xfc300000-0xfc3007ff]
[    1.043306] pci 0000:2c:00.0: PME# supported from D3hot D3cold
[    1.043458] pci 0000:2c:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    1.043556] pci 0000:21:0a.0: PCI bridge to [bus 2c]
[    1.043724] pci 0000:2d:00.0: [1002:1478] type 01 class 0x060400 PCIe Switch Upstream Port
[    1.043756] pci 0000:2d:00.0: BAR 0 [mem 0xfce00000-0xfce03fff]
[    1.043762] pci 0000:2d:00.0: PCI bridge to [bus 2e-2f]
[    1.043771] pci 0000:2d:00.0:   bridge window [io  0xf000-0xffff]
[    1.043775] pci 0000:2d:00.0:   bridge window [mem 0xfcc00000-0xfcdfffff]
[    1.043788] pci 0000:2d:00.0:   bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[    1.043913] pci 0000:2d:00.0: PME# supported from D0 D3hot D3cold
[    1.044173] pci 0000:00:03.1: PCI bridge to [bus 2d-2f]
[    1.044264] pci 0000:2e:00.0: [1002:1479] type 01 class 0x060400 PCIe Switch Downstream Port
[    1.044301] pci 0000:2e:00.0: PCI bridge to [bus 2f]
[    1.044309] pci 0000:2e:00.0:   bridge window [io  0xf000-0xffff]
[    1.044313] pci 0000:2e:00.0:   bridge window [mem 0xfcc00000-0xfcdfffff]
[    1.044327] pci 0000:2e:00.0:   bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[    1.044458] pci 0000:2e:00.0: PME# supported from D0 D3hot D3cold
[    1.045294] pci 0000:2d:00.0: PCI bridge to [bus 2e-2f]
[    1.045400] pci 0000:2f:00.0: [1002:7480] type 00 class 0x030000 PCIe Legacy Endpoint
[    1.045455] pci 0000:2f:00.0: BAR 0 [mem 0x7800000000-0x7bffffffff 64bit pref]
[    1.045460] pci 0000:2f:00.0: BAR 2 [mem 0x7c00000000-0x7c0fffffff 64bit pref]
[    1.045463] pci 0000:2f:00.0: BAR 4 [io  0xf000-0xf0ff]
[    1.045466] pci 0000:2f:00.0: BAR 5 [mem 0xfcc00000-0xfccfffff]
[    1.045469] pci 0000:2f:00.0: ROM [mem 0xfcd00000-0xfcd1ffff pref]
[    1.045619] pci 0000:2f:00.0: PME# supported from D1 D2 D3hot D3cold
[    1.045947] pci 0000:2f:00.1: [1002:ab30] type 00 class 0x040300 PCIe Legacy Endpoint
[    1.045998] pci 0000:2f:00.1: BAR 0 [mem 0xfcd20000-0xfcd23fff]
[    1.046102] pci 0000:2f:00.1: PME# supported from D1 D2 D3hot D3cold
[    1.046307] pci 0000:2e:00.0: PCI bridge to [bus 2f]
[    1.046403] pci 0000:30:00.0: [1022:148a] type 00 class 0x130000 PCIe Endpoint
[    1.046703] pci 0000:00:07.1: PCI bridge to [bus 30]
[    1.046787] pci 0000:31:00.0: [1022:1485] type 00 class 0x130000 PCIe Endpoint
[    1.047106] pci 0000:31:00.1: [1022:1486] type 00 class 0x108000 PCIe Endpoint
[    1.047150] pci 0000:31:00.1: BAR 2 [mem 0xfca00000-0xfcafffff]
[    1.047155] pci 0000:31:00.1: BAR 5 [mem 0xfcb08000-0xfcb09fff]
[    1.047389] pci 0000:31:00.3: [1022:149c] type 00 class 0x0c0330 PCIe Endpoint
[    1.047434] pci 0000:31:00.3: BAR 0 [mem 0xfc900000-0xfc9fffff 64bit]
[    1.047525] pci 0000:31:00.3: PME# supported from D0 D3hot D3cold
[    1.047713] pci 0000:31:00.4: [1022:1487] type 00 class 0x040300 PCIe Endpoint
[    1.047755] pci 0000:31:00.4: BAR 0 [mem 0xfcb00000-0xfcb07fff]
[    1.047842] pci 0000:31:00.4: PME# supported from D0 D3hot D3cold
[    1.048028] pci 0000:00:08.1: PCI bridge to [bus 31]
[    1.052201] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    1.052268] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    1.052325] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    1.052393] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    1.052455] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    1.052507] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    1.052559] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    1.052611] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    1.053471] iommu: Default domain type: Translated
[    1.053471] iommu: DMA domain TLB invalidation policy: lazy mode
[    1.054389] SCSI subsystem initialized
[    1.054395] libata version 3.00 loaded.
[    1.054395] ACPI: bus type USB registered
[    1.054395] usbcore: registered new interface driver usbfs
[    1.054395] usbcore: registered new interface driver hub
[    1.054395] usbcore: registered new device driver usb
[    1.054395] EDAC MC: Ver: 3.0.0
[    1.054509] efivars: Registered efivars operations
[    1.054509] NetLabel: Initializing
[    1.054509] NetLabel:  domain hash size = 128
[    1.054509] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.054509] NetLabel:  unlabeled traffic allowed by default
[    1.054509] mctp: management component transport protocol core
[    1.054509] NET: Registered PF_MCTP protocol family
[    1.054509] PCI: Using ACPI for IRQ routing
[    1.059421] PCI: pci_cache_line_size set to 64 bytes
[    1.059581] e820: reserve RAM buffer [mem 0x09d82000-0x0bffffff]
[    1.059583] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[    1.059584] e820: reserve RAM buffer [mem 0xd75ff000-0xd7ffffff]
[    1.059585] e820: reserve RAM buffer [mem 0xdb0d0000-0xdbffffff]
[    1.059586] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[    1.059587] e820: reserve RAM buffer [mem 0x101f380000-0x101fffffff]
[    1.060260] pci 0000:2f:00.0: vgaarb: setting as boot VGA device
[    1.060260] pci 0000:2f:00.0: vgaarb: bridge control possible
[    1.060260] pci 0000:2f:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    1.060260] vgaarb: loaded
[    1.060283] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    1.060287] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    1.062302] clocksource: Switched to clocksource tsc-early
[    1.062428] VFS: Disk quotas dquot_6.6.0
[    1.062437] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.062465] pnp: PnP ACPI init
[    1.062552] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[    1.062687] system 00:01: [mem 0xfd200000-0xfd2fffff] has been reserved
[    1.062948] system 00:03: [io  0x0a00-0x0a0f] has been reserved
[    1.062950] system 00:03: [io  0x0a10-0x0a1f] has been reserved
[    1.062952] system 00:03: [io  0x0a20-0x0a2f] has been reserved
[    1.062953] system 00:03: [io  0x0a30-0x0a3f] has been reserved
[    1.063241] pnp 00:04: [dma 0 disabled]
[    1.063511] system 00:05: [io  0x04d0-0x04d1] has been reserved
[    1.063513] system 00:05: [io  0x040b] has been reserved
[    1.063515] system 00:05: [io  0x04d6] has been reserved
[    1.063516] system 00:05: [io  0x0c00-0x0c01] has been reserved
[    1.063518] system 00:05: [io  0x0c14] has been reserved
[    1.063520] system 00:05: [io  0x0c50-0x0c51] has been reserved
[    1.063521] system 00:05: [io  0x0c52] has been reserved
[    1.063523] system 00:05: [io  0x0c6c] has been reserved
[    1.063524] system 00:05: [io  0x0c6f] has been reserved
[    1.063526] system 00:05: [io  0x0cd8-0x0cdf] has been reserved
[    1.063527] system 00:05: [io  0x0800-0x089f] has been reserved
[    1.063529] system 00:05: [io  0x0b00-0x0b0f] has been reserved
[    1.063530] system 00:05: [io  0x0b20-0x0b3f] has been reserved
[    1.063532] system 00:05: [io  0x0900-0x090f] has been reserved
[    1.063533] system 00:05: [io  0x0910-0x091f] has been reserved
[    1.063535] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[    1.063537] system 00:05: [mem 0xfec01000-0xfec01fff] could not be reserved
[    1.063539] system 00:05: [mem 0xfedc0000-0xfedc0fff] has been reserved
[    1.063541] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[    1.063543] system 00:05: [mem 0xfed80000-0xfed8ffff] could not be reserved
[    1.063545] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[    1.063546] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[    1.064179] pnp: PnP ACPI: found 6 devices
[    1.069914] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    1.069979] NET: Registered PF_INET protocol family
[    1.070118] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.081089] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    1.081125] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.081366] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    1.081717] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    1.081794] TCP: Hash tables configured (established 524288 bind 65536)
[    1.081957] MPTCP token hash table entries: 65536 (order: 9, 1572864 bytes, linear)
[    1.082119] UDP hash table entries: 32768 (order: 9, 2097152 bytes, linear)
[    1.082320] UDP-Lite hash table entries: 32768 (order: 9, 2097152 bytes, linear)
[    1.082448] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.082455] NET: Registered PF_XDP protocol family
[    1.082470] pci 0000:00:01.1: PCI bridge to [bus 01]
[    1.082475] pci 0000:00:01.1:   bridge window [mem 0xfcf00000-0xfcffffff]
[    1.082484] pci 0000:21:01.0: PCI bridge to [bus 23]
[    1.082490] pci 0000:21:01.0:   bridge window [mem 0xfc800000-0xfc8fffff]
[    1.082503] pci 0000:21:03.0: PCI bridge to [bus 25]
[    1.082506] pci 0000:21:03.0:   bridge window [io  0xe000-0xefff]
[    1.082513] pci 0000:21:03.0:   bridge window [mem 0xfc700000-0xfc7fffff]
[    1.082525] pci 0000:21:04.0: PCI bridge to [bus 26]
[    1.082528] pci 0000:21:04.0:   bridge window [io  0xd000-0xdfff]
[    1.082534] pci 0000:21:04.0:   bridge window [mem 0xfc600000-0xfc6fffff]
[    1.082546] pci 0000:21:06.0: PCI bridge to [bus 28]
[    1.082553] pci 0000:21:06.0:   bridge window [mem 0xfc500000-0xfc5fffff]
[    1.082565] pci 0000:21:08.0: PCI bridge to [bus 2a]
[    1.082572] pci 0000:21:08.0:   bridge window [mem 0xfc100000-0xfc2fffff]
[    1.082584] pci 0000:21:09.0: PCI bridge to [bus 2b]
[    1.082590] pci 0000:21:09.0:   bridge window [mem 0xfc400000-0xfc4fffff]
[    1.082602] pci 0000:21:0a.0: PCI bridge to [bus 2c]
[    1.082609] pci 0000:21:0a.0:   bridge window [mem 0xfc300000-0xfc3fffff]
[    1.082621] pci 0000:20:00.0: PCI bridge to [bus 21-2c]
[    1.082624] pci 0000:20:00.0:   bridge window [io  0xd000-0xefff]
[    1.082631] pci 0000:20:00.0:   bridge window [mem 0xfc100000-0xfc8fffff]
[    1.082644] pci 0000:00:01.2: PCI bridge to [bus 20-2c]
[    1.082647] pci 0000:00:01.2:   bridge window [io  0xd000-0xefff]
[    1.082651] pci 0000:00:01.2:   bridge window [mem 0xfc100000-0xfc8fffff]
[    1.082658] pci 0000:2e:00.0: PCI bridge to [bus 2f]
[    1.082666] pci 0000:2e:00.0:   bridge window [io  0xf000-0xffff]
[    1.082671] pci 0000:2e:00.0:   bridge window [mem 0xfcc00000-0xfcdfffff]
[    1.082676] pci 0000:2e:00.0:   bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[    1.082683] pci 0000:2d:00.0: PCI bridge to [bus 2e-2f]
[    1.082686] pci 0000:2d:00.0:   bridge window [io  0xf000-0xffff]
[    1.082691] pci 0000:2d:00.0:   bridge window [mem 0xfcc00000-0xfcdfffff]
[    1.082696] pci 0000:2d:00.0:   bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[    1.082703] pci 0000:00:03.1: PCI bridge to [bus 2d-2f]
[    1.082705] pci 0000:00:03.1:   bridge window [io  0xf000-0xffff]
[    1.082709] pci 0000:00:03.1:   bridge window [mem 0xfcc00000-0xfcefffff]
[    1.082712] pci 0000:00:03.1:   bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[    1.082718] pci 0000:00:07.1: PCI bridge to [bus 30]
[    1.082728] pci 0000:00:08.1: PCI bridge to [bus 31]
[    1.082732] pci 0000:00:08.1:   bridge window [mem 0xfc900000-0xfcbfffff]
[    1.082740] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    1.082742] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    1.082743] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    1.082745] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    1.082746] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[    1.082748] pci_bus 0000:00: resource 9 [mem 0xe0000000-0xfcffffff window]
[    1.082749] pci_bus 0000:00: resource 10 [mem 0x1020000000-0x7fffffffff window]
[    1.082751] pci_bus 0000:01: resource 1 [mem 0xfcf00000-0xfcffffff]
[    1.082752] pci_bus 0000:20: resource 0 [io  0xd000-0xefff]
[    1.082754] pci_bus 0000:20: resource 1 [mem 0xfc100000-0xfc8fffff]
[    1.082755] pci_bus 0000:21: resource 0 [io  0xd000-0xefff]
[    1.082757] pci_bus 0000:21: resource 1 [mem 0xfc100000-0xfc8fffff]
[    1.082758] pci_bus 0000:23: resource 1 [mem 0xfc800000-0xfc8fffff]
[    1.082760] pci_bus 0000:25: resource 0 [io  0xe000-0xefff]
[    1.082761] pci_bus 0000:25: resource 1 [mem 0xfc700000-0xfc7fffff]
[    1.082762] pci_bus 0000:26: resource 0 [io  0xd000-0xdfff]
[    1.082764] pci_bus 0000:26: resource 1 [mem 0xfc600000-0xfc6fffff]
[    1.082765] pci_bus 0000:28: resource 1 [mem 0xfc500000-0xfc5fffff]
[    1.082767] pci_bus 0000:2a: resource 1 [mem 0xfc100000-0xfc2fffff]
[    1.082768] pci_bus 0000:2b: resource 1 [mem 0xfc400000-0xfc4fffff]
[    1.082770] pci_bus 0000:2c: resource 1 [mem 0xfc300000-0xfc3fffff]
[    1.082771] pci_bus 0000:2d: resource 0 [io  0xf000-0xffff]
[    1.082772] pci_bus 0000:2d: resource 1 [mem 0xfcc00000-0xfcefffff]
[    1.082774] pci_bus 0000:2d: resource 2 [mem 0x7800000000-0x7c0fffffff 64bit pref]
[    1.082775] pci_bus 0000:2e: resource 0 [io  0xf000-0xffff]
[    1.082777] pci_bus 0000:2e: resource 1 [mem 0xfcc00000-0xfcdfffff]
[    1.082778] pci_bus 0000:2e: resource 2 [mem 0x7800000000-0x7c0fffffff 64bit pref]
[    1.082780] pci_bus 0000:2f: resource 0 [io  0xf000-0xffff]
[    1.082781] pci_bus 0000:2f: resource 1 [mem 0xfcc00000-0xfcdfffff]
[    1.082782] pci_bus 0000:2f: resource 2 [mem 0x7800000000-0x7c0fffffff 64bit pref]
[    1.082784] pci_bus 0000:31: resource 1 [mem 0xfc900000-0xfcbfffff]
[    1.083286] pci 0000:2f:00.1: D0 power state depends on 0000:2f:00.0
[    1.083428] PCI: CLS 64 bytes, default 64
[    1.083450] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[    1.083480] Trying to unpack rootfs image as initramfs...
[    1.083517] pci 0000:00:01.0: Adding to iommu group 0
[    1.083534] pci 0000:00:01.1: Adding to iommu group 1
[    1.083553] pci 0000:00:01.2: Adding to iommu group 2
[    1.083573] pci 0000:00:02.0: Adding to iommu group 3
[    1.083602] pci 0000:00:03.0: Adding to iommu group 4
[    1.083620] pci 0000:00:03.1: Adding to iommu group 5
[    1.083647] pci 0000:00:04.0: Adding to iommu group 6
[    1.083667] pci 0000:00:05.0: Adding to iommu group 7
[    1.083696] pci 0000:00:07.0: Adding to iommu group 8
[    1.083715] pci 0000:00:07.1: Adding to iommu group 9
[    1.083744] pci 0000:00:08.0: Adding to iommu group 10
[    1.083762] pci 0000:00:08.1: Adding to iommu group 11
[    1.083790] pci 0000:00:14.0: Adding to iommu group 12
[    1.083804] pci 0000:00:14.3: Adding to iommu group 12
[    1.083874] pci 0000:00:18.0: Adding to iommu group 13
[    1.083889] pci 0000:00:18.1: Adding to iommu group 13
[    1.083903] pci 0000:00:18.2: Adding to iommu group 13
[    1.083919] pci 0000:00:18.3: Adding to iommu group 13
[    1.083933] pci 0000:00:18.4: Adding to iommu group 13
[    1.083949] pci 0000:00:18.5: Adding to iommu group 13
[    1.083965] pci 0000:00:18.6: Adding to iommu group 13
[    1.083979] pci 0000:00:18.7: Adding to iommu group 13
[    1.083994] pci 0000:01:00.0: Adding to iommu group 14
[    1.084009] pci 0000:20:00.0: Adding to iommu group 15
[    1.084074] pci 0000:21:01.0: Adding to iommu group 16
[    1.084137] pci 0000:21:03.0: Adding to iommu group 17
[    1.084199] pci 0000:21:04.0: Adding to iommu group 18
[    1.084283] pci 0000:21:06.0: Adding to iommu group 19
[    1.084306] pci 0000:21:08.0: Adding to iommu group 20
[    1.084328] pci 0000:21:09.0: Adding to iommu group 21
[    1.084350] pci 0000:21:0a.0: Adding to iommu group 22
[    1.084389] pci 0000:23:00.0: Adding to iommu group 23
[    1.084428] pci 0000:25:00.0: Adding to iommu group 24
[    1.084467] pci 0000:26:00.0: Adding to iommu group 25
[    1.084507] pci 0000:28:00.0: Adding to iommu group 26
[    1.084512] pci 0000:2a:00.0: Adding to iommu group 20
[    1.084518] pci 0000:2a:00.1: Adding to iommu group 20
[    1.084524] pci 0000:2a:00.3: Adding to iommu group 20
[    1.084529] pci 0000:2b:00.0: Adding to iommu group 21
[    1.084535] pci 0000:2c:00.0: Adding to iommu group 22
[    1.084550] pci 0000:2d:00.0: Adding to iommu group 27
[    1.084574] pci 0000:2e:00.0: Adding to iommu group 28
[    1.084603] pci 0000:2f:00.0: Adding to iommu group 29
[    1.084629] pci 0000:2f:00.1: Adding to iommu group 30
[    1.084649] pci 0000:30:00.0: Adding to iommu group 31
[    1.084671] pci 0000:31:00.0: Adding to iommu group 32
[    1.084692] pci 0000:31:00.1: Adding to iommu group 33
[    1.084713] pci 0000:31:00.3: Adding to iommu group 34
[    1.084735] pci 0000:31:00.4: Adding to iommu group 35
[    1.087664] AMD-Vi: Extended features (0x58f77ef22294a5a, 0x0): PPR NX GT IA PC GA_vAPIC
[    1.087671] AMD-Vi: Interrupt remapping enabled
[    1.087758] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.087759] software IO TLB: mapped [mem 0x00000000d34bf000-0x00000000d74bf000] (64MB)
[    1.087810] LVT offset 0 assigned for vector 0x400
[    1.088198] perf: AMD IBS detected (0x000003ff)
[    1.088202] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[    1.106324] Initialise system trusted keyrings
[    1.106334] Key type blacklist registered
[    1.106366] workingset: timestamp_bits=36 max_order=24 bucket_order=0
[    1.106636] fuse: init (API version 7.45)
[    1.106706] integrity: Platform Keyring initialized
[    1.106708] integrity: Machine keyring initialized
[    1.114735] xor: automatically using best checksumming function   avx
[    1.114736] Key type asymmetric registered
[    1.114738] Asymmetric key parser 'x509' registered
[    1.114752] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.114792] io scheduler mq-deadline registered
[    1.114794] io scheduler kyber registered
[    1.114804] io scheduler bfq registered
[    1.116082] ledtrig-cpu: registered to indicate activity on CPUs
[    1.116203] pcieport 0000:00:01.1: PME: Signaling with IRQ 28
[    1.116369] pcieport 0000:00:01.2: PME: Signaling with IRQ 29
[    1.116538] pcieport 0000:00:03.1: PME: Signaling with IRQ 30
[    1.116780] pcieport 0000:00:07.1: PME: Signaling with IRQ 32
[    1.116835] pcieport 0000:00:07.1: AER: enabled with IRQ 32
[    1.116988] pcieport 0000:00:08.1: PME: Signaling with IRQ 33
[    1.117049] pcieport 0000:00:08.1: AER: enabled with IRQ 33
[    1.119896] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    1.119920] ACPI: button: Power Button [PWRB]
[    1.119953] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    1.121568] ACPI: button: Power Button [PWRF]
[    1.122003] Monitor-Mwait will be used to enter C-1 state
[    1.127573] Estimated ratio of average max frequency by base frequency (times 1024): 1165
[    1.127831] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    1.128047] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    1.131049] Non-volatile memory driver v1.3
[    1.131050] Linux agpgart interface v0.103
[    1.139857] Freeing initrd memory: 56524K
[    1.184581] tpm_crb MSFT0101:00: Disabling hwrng
[    1.184814] ACPI: bus type drm_connector registered
[    1.186897] ahci 0000:2b:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    1.186900] ahci 0000:2b:00.0: 2/2 ports implemented (port mask 0xc)
[    1.186902] ahci 0000:2b:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[    1.187232] scsi host0: ahci
[    1.187328] scsi host1: ahci
[    1.187410] scsi host2: ahci
[    1.187489] scsi host3: ahci
[    1.187525] ata1: DUMMY
[    1.187526] ata2: DUMMY
[    1.187529] ata3: SATA max UDMA/133 abar m2048@0xfc400000 port 0xfc400200 irq 47 lpm-pol 3
[    1.187532] ata4: SATA max UDMA/133 abar m2048@0xfc400000 port 0xfc400280 irq 48 lpm-pol 3
[    1.187681] ahci 0000:2c:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    1.187684] ahci 0000:2c:00.0: 1/1 ports implemented (port mask 0x1)
[    1.187685] ahci 0000:2c:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[    1.187826] scsi host4: ahci
[    1.187864] ata5: SATA max UDMA/133 abar m2048@0xfc300000 port 0xfc300100 irq 61 lpm-pol 3
[    1.188065] xhci_hcd 0000:2a:00.1: xHCI Host Controller
[    1.188072] xhci_hcd 0000:2a:00.1: new USB bus registered, assigned bus number 1
[    1.188216] xhci_hcd 0000:2a:00.1: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000010
[    1.188728] xhci_hcd 0000:2a:00.1: xHCI Host Controller
[    1.188730] xhci_hcd 0000:2a:00.1: new USB bus registered, assigned bus number 2
[    1.188733] xhci_hcd 0000:2a:00.1: Host supports USB 3.1 Enhanced SuperSpeed
[    1.188770] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.19
[    1.188772] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.188774] usb usb1: Product: xHCI Host Controller
[    1.188775] usb usb1: Manufacturer: Linux 6.19.8-1-MANJARO xhci-hcd
[    1.188776] usb usb1: SerialNumber: 0000:2a:00.1
[    1.188867] hub 1-0:1.0: USB hub found
[    1.188879] hub 1-0:1.0: 6 ports detected
[    1.189115] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.189134] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.19
[    1.189135] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.189137] usb usb2: Product: xHCI Host Controller
[    1.189138] usb usb2: Manufacturer: Linux 6.19.8-1-MANJARO xhci-hcd
[    1.189139] usb usb2: SerialNumber: 0000:2a:00.1
[    1.189211] hub 2-0:1.0: USB hub found
[    1.189224] hub 2-0:1.0: 4 ports detected
[    1.189437] xhci_hcd 0000:2a:00.3: xHCI Host Controller
[    1.189441] xhci_hcd 0000:2a:00.3: new USB bus registered, assigned bus number 3
[    1.189601] xhci_hcd 0000:2a:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000010
[    1.189946] xhci_hcd 0000:2a:00.3: xHCI Host Controller
[    1.189950] xhci_hcd 0000:2a:00.3: new USB bus registered, assigned bus number 4
[    1.189952] xhci_hcd 0000:2a:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    1.189984] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.19
[    1.189985] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.189987] usb usb3: Product: xHCI Host Controller
[    1.189988] usb usb3: Manufacturer: Linux 6.19.8-1-MANJARO xhci-hcd
[    1.189990] usb usb3: SerialNumber: 0000:2a:00.3
[    1.190073] hub 3-0:1.0: USB hub found
[    1.190086] hub 3-0:1.0: 6 ports detected
[    1.190311] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.190329] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.19
[    1.190331] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.190332] usb usb4: Product: xHCI Host Controller
[    1.190334] usb usb4: Manufacturer: Linux 6.19.8-1-MANJARO xhci-hcd
[    1.190335] usb usb4: SerialNumber: 0000:2a:00.3
[    1.190406] hub 4-0:1.0: USB hub found
[    1.190416] hub 4-0:1.0: 4 ports detected
[    1.190647] xhci_hcd 0000:31:00.3: xHCI Host Controller
[    1.190651] xhci_hcd 0000:31:00.3: new USB bus registered, assigned bus number 5
[    1.190760] xhci_hcd 0000:31:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000010
[    1.191027] xhci_hcd 0000:31:00.3: xHCI Host Controller
[    1.191029] xhci_hcd 0000:31:00.3: new USB bus registered, assigned bus number 6
[    1.191031] xhci_hcd 0000:31:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    1.191062] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.19
[    1.191063] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.191065] usb usb5: Product: xHCI Host Controller
[    1.191066] usb usb5: Manufacturer: Linux 6.19.8-1-MANJARO xhci-hcd
[    1.191067] usb usb5: SerialNumber: 0000:31:00.3
[    1.191145] hub 5-0:1.0: USB hub found
[    1.191152] hub 5-0:1.0: 4 ports detected
[    1.191311] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.191330] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.19
[    1.191331] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.191333] usb usb6: Product: xHCI Host Controller
[    1.191334] usb usb6: Manufacturer: Linux 6.19.8-1-MANJARO xhci-hcd
[    1.191335] usb usb6: SerialNumber: 0000:31:00.3
[    1.191406] hub 6-0:1.0: USB hub found
[    1.191414] hub 6-0:1.0: 4 ports detected
[    1.191608] usbcore: registered new interface driver usbserial_generic
[    1.191613] usbserial: USB Serial support registered for generic
[    1.191655] i8042: PNP: No PS/2 controller found.
[    1.191721] rtc_cmos 00:02: RTC can wake from S4
[    1.191938] rtc_cmos 00:02: registered as rtc0
[    1.191966] rtc_cmos 00:02: setting system clock to 2026-04-11T05:52:12 UTC (1775886732)
[    1.191993] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram
[    1.272117] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[    1.272133] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[    1.275002] fbcon: Deferring console take-over
[    1.275005] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    1.275030] hid: raw HID events driver (C) Jiri Kosina
[    1.275060] usbcore: registered new interface driver usbhid
[    1.275062] usbhid: USB HID core driver
[    1.275165] drop_monitor: Initializing network drop monitor service
[    1.275267] NET: Registered PF_INET6 protocol family
[    1.275504] Segment Routing with IPv6
[    1.275506] RPL Segment Routing with IPv6
[    1.275513] In-situ OAM (IOAM) with IPv6
[    1.275530] NET: Registered PF_PACKET protocol family
[    1.276903] microcode: Current revision: 0x0a20102e
[    1.276906] microcode: Updated early from: 0x0a20102b
[    1.277164] resctrl: L3 allocation detected
[    1.277166] resctrl: MB allocation detected
[    1.277167] resctrl: L3 monitoring detected
[    1.277191] IPI shorthand broadcast: enabled
[    1.280122] sched_clock: Marking stable (654740534, 625207010)->(1305541794, -25594250)
[    1.280308] registered taskstats version 1
[    1.280846] Loading compiled-in X.509 certificates
[    1.285868] Loaded X.509 cert 'Build time autogenerated kernel key: 35dd452506aacc1ad2a9b8ce7dd10f96eddd0e82'
[    1.289365] zswap: loaded using pool zstd
[    1.289411] Demotion targets for Node 0: null
[    1.289534] Key type .fscrypt registered
[    1.289536] Key type fscrypt-provisioning registered
[    1.289817] Btrfs loaded, zoned=yes, fsverity=yes
[    1.289848] Key type big_key registered
[    1.289908] integrity: Loading X.509 certificate: UEFI:db
[    1.289924] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    1.289925] integrity: Loading X.509 certificate: UEFI:db
[    1.289938] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    1.289939] integrity: Loading X.509 certificate: UEFI:db
[    1.289949] integrity: Loaded X.509 cert 'Microsoft Corporation: Windows UEFI CA 2023: aefc5fbbbe055d8f8daa585473499417ab5a5272'
[    1.289950] integrity: Loading X.509 certificate: UEFI:db
[    1.289959] integrity: Loaded X.509 cert 'Microsoft UEFI CA 2023: 81aa6b3244c935bce0d6628af39827421e32497d'
[    1.289960] integrity: Loading X.509 certificate: UEFI:db
[    1.289967] integrity: Loaded X.509 cert 'MSI SHIP DB: ebc30d5be5f35f8041c1c2d9e613eee2'
[    1.291221] PM:   Magic number: 6:680:870
[    1.292098] RAS: Correctable Errors collector initialized.
[    1.295632] clk: Disabling unused clocks
[    1.295634] PM: genpd: Disabling unused power domains
[    1.425257] usb 3-5: new full-speed USB device number 2 using xhci_hcd
[    1.425267] usb 1-4: new full-speed USB device number 2 using xhci_hcd
[    1.425275] usb 5-3: new high-speed USB device number 2 using xhci_hcd
[    1.495035] ata5: SATA link down (SStatus 0 SControl 300)
[    1.567765] usb 5-3: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.36
[    1.567769] usb 5-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.567771] usb 5-3: Product: 4-Port USB 2.0 Hub
[    1.567773] usb 5-3: Manufacturer: Generic
[    1.570954] usb 3-5: New USB device found, idVendor=1462, idProduct=7c84, bcdDevice= 0.01
[    1.570957] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.570959] usb 3-5: Product: MYSTIC LIGHT
[    1.570961] usb 3-5: Manufacturer: MSI
[    1.570962] usb 3-5: SerialNumber: A02021052609
[    1.577734] usb 1-4: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[    1.577737] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.591097] input: MSI MYSTIC LIGHT  as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.3/usb3/3-5/3-5:1.0/0003:1462:7C84.0001/input/input2
[    1.591195] hid-generic 0003:1462:7C84.0001: input,hiddev96,hidraw0: USB HID v1.10 Device [MSI MYSTIC LIGHT ] on usb-0000:2a:00.3-5/input0
[    1.607551] hub 5-3:1.0: USB hub found
[    1.608761] hub 5-3:1.0: 4 ports detected
[    1.657283] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.657573] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.657916] ata4.00: ATA-11: ST18000NM000J-2TV103, SC02, max UDMA/133
[    1.659261] ata3.00: Model 'ST2000DM008-2FR102', rev '0001', applying quirks: nolpm
[    1.671453] usb 6-3: new SuperSpeed USB device number 2 using xhci_hcd
[    1.685768] ata3.00: ATA-10: ST2000DM008-2FR102, 0001, max UDMA/133
[    1.694861] ata3.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.694864] ata3.00: LPM support broken, forcing max_power
[    1.698831] usb 6-3: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.36
[    1.698834] usb 6-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.698836] usb 6-3: Product: 4-Port USB 3.0 Hub
[    1.698838] usb 6-3: Manufacturer: Generic
[    1.702309] ata4.00: 35156656128 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.703261] usb 3-6: new high-speed USB device number 3 using xhci_hcd
[    1.704962] ata4.00: Features: DIPM NCQ-sndrcv
[    1.704994] ata3.00: Features: HIPM DIPM
[    1.722507] hub 6-3:1.0: USB hub found
[    1.723771] hub 6-3:1.0: 4 ports detected
[    1.738196] ata4.00: configured for UDMA/133
[    1.754625] ata3.00: configured for UDMA/133
[    1.774646] scsi 2:0:0:0: Direct-Access     ATA      ST2000DM008-2FR1 0001 PQ: 0 ANSI: 5
[    1.774922] sd 2:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    1.774925] sd 2:0:0:0: [sda] 4096-byte physical blocks
[    1.774934] sd 2:0:0:0: [sda] Write Protect is off
[    1.774936] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.774949] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.774971] sd 2:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[    1.780143] scsi 3:0:0:0: Direct-Access     ATA      ST18000NM000J-2T SC02 PQ: 0 ANSI: 5
[    1.780387] sd 3:0:0:0: [sdb] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[    1.780390] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[    1.780398] sd 3:0:0:0: [sdb] Write Protect is off
[    1.780400] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    1.780412] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.780434] sd 3:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[    1.829296] usb 3-6: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.70
[    1.829299] usb 3-6: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.829301] usb 3-6: Product: USB2.0 Hub
[    1.830619]  sda: sda1
[    1.830671] sd 2:0:0:0: [sda] Attached SCSI disk
[    1.848483]  sdb: sdb1
[    1.848545] sd 3:0:0:0: [sdb] Attached SCSI disk
[    1.849902] Freeing unused decrypted memory: 2028K
[    1.850512] Freeing unused kernel image (initmem) memory: 4768K
[    1.850528] Write protecting the kernel read-only data: 40960k
[    1.851151] Freeing unused kernel image (text/rodata gap) memory: 2016K
[    1.851429] Freeing unused kernel image (rodata/data gap) memory: 1684K
[    1.862322] hub 3-6:1.0: USB hub found
[    1.862917] hub 3-6:1.0: 4 ports detected
[    1.865696] usb: port power management may be unreliable
[    1.890332] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.890335] rodata_test: all tests were successful
[    1.890338] Run /init as init process
[    1.890339]   with arguments:
[    1.890340]     /init
[    1.890341]     splash
[    1.890342]   with environment:
[    1.890343]     HOME=/
[    1.890344]     TERM=linux
[    1.955219] usb 5-3.1: new high-speed USB device number 3 using xhci_hcd
[    2.119145] Key type psk registered
[    2.121232] tsc: Refined TSC clocksource calibration: 3800.001 MHz
[    2.121237] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d8cb0e20f4, max_idle_ns: 881590468932 ns
[    2.121262] clocksource: Switched to clocksource tsc
[    2.130919] nvme nvme0: pci function 0000:01:00.0
[    2.130919] nvme nvme1: pci function 0000:23:00.0
[    2.135372] nvme nvme0: missing or invalid SUBNQN field.
[    2.135382] nvme nvme1: missing or invalid SUBNQN field.
[    2.135403] nvme nvme0: D3 entry latency set to 10 seconds
[    2.135431] nvme nvme1: D3 entry latency set to 10 seconds
[    2.137494] nvme nvme0: 16/0/0 default/read/poll queues
[    2.138337] nvme nvme1: 16/0/0 default/read/poll queues
[    2.139774]  nvme0n1: p1 p2
[    2.141110]  nvme1n1: p1
[    2.448965] usb 5-3.1: New USB device found, idVendor=0c45, idProduct=6366, bcdDevice= 1.00
[    2.448971] usb 5-3.1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[    2.448974] usb 5-3.1: Product: USB  Live camera
[    2.448976] usb 5-3.1: Manufacturer: Sonix Technology Co., Ltd.
[    2.448978] usb 5-3.1: SerialNumber: SN0001
[    2.503466] usb 6-3.4: new SuperSpeed USB device number 3 using xhci_hcd
[    2.528612] usb 6-3.4: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.36
[    2.528615] usb 6-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.528617] usb 6-3.4: Product: 4-Port USB 3.0 Hub
[    2.528619] usb 6-3.4: Manufacturer: Generic
[    2.555474] hub 6-3.4:1.0: USB hub found
[    2.556865] hub 6-3.4:1.0: 4 ports detected
[    2.594216] usb 5-3.4: new high-speed USB device number 4 using xhci_hcd
[    2.697224] usb 5-3.4: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.36
[    2.697227] usb 5-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.697229] usb 5-3.4: Product: 4-Port USB 2.0 Hub
[    2.697231] usb 5-3.4: Manufacturer: Generic
[    2.759631] hub 5-3.4:1.0: USB hub found
[    2.761100] hub 5-3.4:1.0: 4 ports detected
[    3.107226] usb 5-3.4.2: new full-speed USB device number 5 using xhci_hcd
[    3.237997] usb 5-3.4.2: New USB device found, idVendor=04d9, idProduct=fc4d, bcdDevice= 1.52
[    3.238000] usb 5-3.4.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    3.238003] usb 5-3.4.2: Product: USB Gaming Mouse
[    3.350101] input: USB Gaming Mouse as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.4/5-3.4.2/5-3.4.2:1.0/0003:04D9:FC4D.0002/input/input3
[    3.350171] hid-generic 0003:04D9:FC4D.0002: input,hidraw1: USB HID v1.10 Mouse [USB Gaming Mouse] on usb-0000:31:00.3-3.4.2/input0
[    3.361113] input: USB Gaming Mouse as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.4/5-3.4.2/5-3.4.2:1.1/0003:04D9:FC4D.0003/input/input4
[    3.411262] hid-generic 0003:04D9:FC4D.0003: input,hidraw2: USB HID v1.10 Keyboard [USB Gaming Mouse] on usb-0000:31:00.3-3.4.2/input1
[    3.419418] input: USB Gaming Mouse Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.4/5-3.4.2/5-3.4.2:1.2/0003:04D9:FC4D.0004/input/input5
[    3.470275] input: USB Gaming Mouse as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.4/5-3.4.2/5-3.4.2:1.2/0003:04D9:FC4D.0004/input/input6
[    3.470370] hid-generic 0003:04D9:FC4D.0004: input,hiddev97,hidraw3: USB HID v1.10 Device [USB Gaming Mouse] on usb-0000:31:00.3-3.4.2/input2
[    3.544212] usb 5-3.4.3: new full-speed USB device number 6 using xhci_hcd
[    3.649973] usb 5-3.4.3: New USB device found, idVendor=0416, idProduct=a0f8, bcdDevice= 0.00
[    3.649976] usb 5-3.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.649978] usb 5-3.4.3: Product: Drevo keyboard
[    3.649980] usb 5-3.4.3: Manufacturer: Drevo keyboard
[    3.649981] usb 5-3.4.3: SerialNumber: WKNUB-NP87-UK
[    3.760105] input: Drevo keyboard Drevo keyboard as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.4/5-3.4.3/5-3.4.3:1.0/0003:0416:A0F8.0005/input/input7
[    3.870288] hid-generic 0003:0416:A0F8.0005: input,hidraw4: USB HID v1.10 Keyboard [Drevo keyboard Drevo keyboard] on usb-0000:31:00.3-3.4.3/input0
[    3.872163] amdgpu: Virtual CRAT table created for CPU
[    3.872176] amdgpu: Topology: Add CPU node
[    3.872280] amdgpu 0000:2f:00.0: enabling device (0006 -> 0007)
[    3.872322] amdgpu 0000:2f:00.0: amdgpu: initializing kernel modesetting (IP DISCOVERY 0x1002:0x7480 0x1DA2:0xE485 0xC0).
[    3.872332] amdgpu 0000:2f:00.0: amdgpu: register mmio base: 0xFCC00000
[    3.872334] amdgpu 0000:2f:00.0: amdgpu: register mmio size: 1048576
[    3.875608] input: Drevo keyboard Drevo keyboard Keyboard as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.4/5-3.4.3/5-3.4.3:1.1/0003:0416:A0F8.0006/input/input8
[    3.878195] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 0 <common_v1_0_0> (soc21_common)
[    3.878198] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 1 <gmc_v11_0_0> (gmc_v11_0)
[    3.878200] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 2 <ih_v6_0_0> (ih_v6_0)
[    3.878202] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 3 <psp_v13_0_0> (psp)
[    3.878204] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 4 <smu_v13_0_0> (smu)
[    3.878206] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 5 <dce_v1_0_0> (dm)
[    3.878213] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 6 <gfx_v11_0_0> (gfx_v11_0)
[    3.878215] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 7 <sdma_v6_0_0> (sdma_v6_0)
[    3.878218] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 8 <vcn_v4_0_0> (vcn_v4_0)
[    3.878219] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 9 <jpeg_v4_0_0> (jpeg_v4_0)
[    3.878221] amdgpu 0000:2f:00.0: amdgpu: detected ip block number 10 <mes_v11_0_0> (mes_v11_0)
[    3.878235] amdgpu 0000:2f:00.0: amdgpu: Fetched VBIOS from VFCT
[    3.878237] amdgpu: ATOM BIOS: 113-1E4850U-O46
[    3.902435] amdgpu 0000:2f:00.0: amdgpu: CP RS64 enable
[    3.925328] input: Drevo keyboard Drevo keyboard as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.4/5-3.4.3/5-3.4.3:1.1/0003:0416:A0F8.0006/input/input9
[    3.925399] input: Drevo keyboard Drevo keyboard as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.4/5-3.4.3/5-3.4.3:1.1/0003:0416:A0F8.0006/input/input10
[    3.925453] input: Drevo keyboard Drevo keyboard Mouse as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.4/5-3.4.3/5-3.4.3:1.1/0003:0416:A0F8.0006/input/input11
[    3.925553] hid-generic 0003:0416:A0F8.0006: input,hiddev98,hidraw5: USB HID v1.10 Keyboard [Drevo keyboard Drevo keyboard] on usb-0000:31:00.3-3.4.3/input1
[    3.951453] amdgpu 0000:2f:00.0: vgaarb: deactivate vga console
[    3.951457] amdgpu 0000:2f:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[    3.951501] amdgpu 0000:2f:00.0: amdgpu: vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[    3.951510] amdgpu 0000:2f:00.0: amdgpu: VRAM: 16368M 0x0000008000000000 - 0x00000083FEFFFFFF (16368M used)
[    3.951512] amdgpu 0000:2f:00.0: amdgpu: GART: 512M 0x00007FFF00000000 - 0x00007FFF1FFFFFFF
[    3.951527] [drm] Detected VRAM RAM=16368M, BAR=16384M
[    3.951529] [drm] RAM width 128bits GDDR6
[    3.951660] amdgpu 0000:2f:00.0: amdgpu: amdgpu: 16368M of VRAM memory ready
[    3.951663] amdgpu 0000:2f:00.0: amdgpu: amdgpu: 32110M of GTT memory ready.
[    3.951682] [drm] GART: num cpu pages 131072, num gpu pages 131072
[    3.951803] [drm] PCIE GART of 512M enabled (table at 0x00000083FEB00000).
[    3.952284] amdgpu 0000:2f:00.0: amdgpu: [drm] Loading DMUB firmware via PSP: version=0x07002F00
[    3.952499] amdgpu 0000:2f:00.0: amdgpu: [VCN instance 0] Found VCN firmware Version ENC: 1.24 DEC: 9 VEP: 0 Revision: 16
[    4.011279] amdgpu 0000:2f:00.0: amdgpu: reserve 0x1300000 from 0x83fc000000 for PSP TMR
[    4.107588] amdgpu 0000:2f:00.0: amdgpu: RAS: optional ras ta ucode is not available
[    4.115233] amdgpu 0000:2f:00.0: amdgpu: RAP: optional rap ta ucode is not available
[    4.115235] amdgpu 0000:2f:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
[    4.115302] amdgpu 0000:2f:00.0: amdgpu: smu driver if version = 0x00000035, smu fw if version = 0x00000040, smu fw program = 0, smu fw version = 0x00525f00 (82.95.0)
[    4.115305] amdgpu 0000:2f:00.0: amdgpu: SMU driver if version not matched
[    4.174617] amdgpu 0000:2f:00.0: amdgpu: SMU is initialized successfully!
[    4.174983] amdgpu 0000:2f:00.0: amdgpu: [drm] Display Core v3.2.359 initialized on DCN 3.2.1
[    4.174986] amdgpu 0000:2f:00.0: amdgpu: [drm] DP-HDMI FRL PCON supported
[    4.176776] amdgpu 0000:2f:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x07002F00
[    4.392334] amdgpu 0000:2f:00.0: amdgpu: [drm] DP-1: PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[    4.392384] amdgpu 0000:2f:00.0: amdgpu: [drm] DP-2: PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[    4.392429] amdgpu 0000:2f:00.0: amdgpu: [drm] HDMI-A-1: PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[    4.421387] amdgpu 0000:2f:00.0: amdgpu: [drm] HDMI-A-2: PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[    4.512517] amdgpu: HMM registered 16368MB device memory
[    4.513705] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[    4.513722] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[    4.513773] amdgpu: Virtual CRAT table created for GPU
[    4.513904] amdgpu: Topology: Add dGPU node [0x7480:0x1002]
[    4.513906] kfd kfd: amdgpu: added device 1002:7480
[    4.513919] amdgpu 0000:2f:00.0: amdgpu: SE 2, SH per SE 2, CU per SH 8, active_cu_number 32
[    4.513924] amdgpu 0000:2f:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[    4.513926] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[    4.513928] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[    4.513929] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[    4.513930] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[    4.513932] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[    4.513933] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[    4.513935] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[    4.513937] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[    4.513938] amdgpu 0000:2f:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[    4.513939] amdgpu 0000:2f:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
[    4.513941] amdgpu 0000:2f:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[    4.513942] amdgpu 0000:2f:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[    4.513944] amdgpu 0000:2f:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 14 on hub 0
[    4.516575] amdgpu 0000:2f:00.0: amdgpu: Using BACO for runtime pm
[    4.516974] amdgpu 0000:2f:00.0: [drm] Registered 4 planes with drm panic
[    4.526232] [drm] Initialized amdgpu 3.64.0 for 0000:2f:00.0 on minor 1
[    4.534077] fbcon: amdgpudrmfb (fb0) is primary device
[    4.534078] fbcon: Deferring console take-over
[    4.534080] amdgpu 0000:2f:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[    4.635991] [drm] pre_validate_dsc:1667 MST_DSC dsc precompute is not needed
[    4.877870] EXT4-fs (nvme0n1p2): mounted filesystem 95b01923-1bed-4694-bb66-72e635384b04 r/w with ordered data mode. Quota mode: none.
[    5.293900] systemd[1]: systemd 259.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[    5.293911] systemd[1]: Detected architecture x86-64.
[    5.303870] systemd[1]: Hostname set to <bianco500>.
[    5.416972] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    5.594286] systemd[1]: Queued start job for default target Graphical Interface.
[    5.609026] systemd[1]: Created slice Virtual Machine and Container Slice.
[    5.609762] systemd[1]: Created slice CUPS Slice.
[    5.610073] systemd[1]: Created slice Slice /system/dirmngr.
[    5.610393] systemd[1]: Created slice Slice /system/getty.
[    5.610705] systemd[1]: Created slice Slice /system/gpg-agent.
[    5.611016] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    5.611331] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    5.611641] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    5.611957] systemd[1]: Created slice Slice /system/keyboxd.
[    5.612311] systemd[1]: Created slice Slice /system/modprobe.
[    5.612627] systemd[1]: Created slice Slice /system/systemd-fsck.
[    5.612837] systemd[1]: Created slice User and Session Slice.
[    5.612884] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.613025] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.613041] systemd[1]: Expecting device /dev/disk/by-label/BIANCO-COPIA...
[    5.613047] systemd[1]: Expecting device /dev/disk/by-label/BIANCO-SATA1...
[    5.613052] systemd[1]: Expecting device /dev/disk/by-label/BIANCO-SSD2...
[    5.613058] systemd[1]: Expecting device /dev/disk/by-uuid/BD29-5527...
[    5.613069] systemd[1]: Reached target Login Prompts.
[    5.613076] systemd[1]: Reached target Image Downloads.
[    5.613082] systemd[1]: Reached target Local Integrity Protected Volumes.
[    5.613097] systemd[1]: Reached target Host and Network Name Lookups.
[    5.613104] systemd[1]: Reached target Remote File Systems.
[    5.613114] systemd[1]: Reached target Slice Units.
[    5.613128] systemd[1]: Reached target Swaps.
[    5.613142] systemd[1]: Reached target Local Verity Protected Volumes.
[    5.613200] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    5.613283] systemd[1]: Listening on LVM2 poll daemon socket.
[    5.615870] systemd[1]: Listening on RPCbind Server Activation Socket.
[    5.615903] systemd[1]: Reached target RPC Port Mapper.
[    5.616482] systemd[1]: Listening on Query the User Interactively for a Password.
[    5.617206] systemd[1]: Listening on Process Core Dump Socket.
[    5.617667] systemd[1]: Listening on Credential Encryption/Decryption.
[    5.618242] systemd[1]: Listening on Factory Reset Management.
[    5.618310] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.618369] systemd[1]: Listening on Journal Sockets.
[    5.619004] systemd[1]: Listening on Console Output Muting Service Socket.
[    5.619101] systemd[1]: TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[    5.619114] systemd[1]: Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[    5.619561] systemd[1]: Listening on Disk Repartitioning Service Socket.
[    5.619614] systemd[1]: Listening on udev Control Socket.
[    5.619649] systemd[1]: Listening on udev Kernel Socket.
[    5.619692] systemd[1]: Listening on udev Varlink Socket.
[    5.619738] systemd[1]: Listening on User Database Manager Socket.
[    5.620420] systemd[1]: Mounting Huge Pages File System...
[    5.621032] systemd[1]: Mounting POSIX Message Queue File System...
[    5.621690] systemd[1]: Mounting Kernel Debug File System...
[    5.622293] systemd[1]: Mounting Kernel Trace File System...
[    5.622350] systemd[1]: Kernel Module supporting RPCSEC_GSS skipped, unmet condition check ConditionPathExists=/etc/krb5.keytab
[    5.623048] systemd[1]: Starting Create List of Static Device Nodes...
[    5.623731] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    5.623753] systemd[1]: Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[    5.624326] systemd[1]: Mounting Kernel Configuration File System...
[    5.624348] systemd[1]: Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[    5.624370] systemd[1]: Load Kernel Module fuse skipped, unmet condition check ConditionKernelModuleLoaded=!fuse
[    5.625010] systemd[1]: Mounting FUSE Control File System...
[    5.625107] systemd[1]: File System Check on Root Device skipped, unmet condition check ConditionPathIsReadWrite=!/
[    5.625162] systemd[1]: Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[    5.626865] systemd[1]: Starting Journal Service...
[    5.628109] systemd[1]: Starting Load Kernel Modules...
[    5.628123] systemd[1]: TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    5.628152] systemd[1]: TPM NvPCR Product ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    5.628784] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.628824] systemd[1]: Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    5.629467] systemd[1]: Starting Load udev Rules from Credentials...
[    5.630056] systemd[1]: Starting Coldplug All udev Devices...
[    5.630646] systemd[1]: Starting Virtual Console Setup...
[    5.632650] systemd[1]: Mounted Huge Pages File System.
[    5.632729] systemd[1]: Mounted POSIX Message Queue File System.
[    5.632802] systemd[1]: Mounted Kernel Debug File System.
[    5.632873] systemd[1]: Mounted Kernel Trace File System.
[    5.633320] systemd[1]: Finished Create List of Static Device Nodes.
[    5.634942] systemd[1]: Mounted Kernel Configuration File System.
[    5.635033] systemd[1]: Mounted FUSE Control File System.
[    5.635816] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    5.636124] systemd[1]: Finished Virtual Console Setup.
[    5.637225] systemd[1]: Finished Load udev Rules from Credentials.
[    5.638909] systemd-journald[446]: Collecting audit messages is disabled.
[    5.639955] i2c_dev: i2c /dev entries driver
[    5.640393] sd 2:0:0:0: Attached scsi generic sg0 type 0
[    5.640419] sd 3:0:0:0: Attached scsi generic sg1 type 0
[    5.640899] systemd[1]: Finished Load Kernel Modules.
[    5.641624] systemd[1]: Starting Apply Kernel Variables...
[    5.642431] EXT4-fs (nvme0n1p2): re-mounted 95b01923-1bed-4694-bb66-72e635384b04.
[    5.643032] systemd[1]: Finished Remount Root and Kernel File Systems.
[    5.643300] systemd[1]: Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
[    5.643918] systemd[1]: Starting Load/Save OS Random Seed...
[    5.643936] systemd[1]: TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    5.643951] systemd[1]: TPM PCR NvPCR Initialization Separator skipped, unmet condition check ConditionSecurity=measured-uki
[    5.645806] device-mapper: uevent: version 1.0.3
[    5.645877] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[    5.648619] systemd[1]: Finished Apply Kernel Variables.
[    5.650300] systemd[1]: Starting User Database Manager...
[    5.654869] systemd[1]: Finished Load/Save OS Random Seed.
[    5.669340] systemd[1]: Started User Database Manager.
[    5.686934] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[    5.687029] systemd[1]: Create System Users skipped, no trigger condition checks were met.
[    5.688128] systemd[1]: Starting Network Time Synchronization...
[    5.688711] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.706835] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[    5.721272] systemd[1]: Finished Create Static Device Nodes in /dev.
[    5.721343] systemd[1]: Reached target Preparation for Local File Systems.
[    5.721413] systemd[1]: Repartition Root Disk skipped, no trigger condition checks were met.
[    5.722128] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    5.724414] systemd[1]: Started Journal Service.
[    5.729732] systemd-journald[446]: Received client request to flush runtime journal.
[    5.993900] mousedev: PS/2 mouse device common for all mice
[    6.025986] ccp 0000:31:00.1: enabling device (0000 -> 0002)
[    6.026198] ccp 0000:31:00.1: ccp: unable to access the device: you might be running a broken BIOS.
[    6.026309] ccp 0000:31:00.1: psp enabled
[    6.048382] mc: Linux media interface: v0.10
[    6.049324] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.049377] input: PC Speaker as /devices/platform/pcspkr/input/input12
[    6.054714] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.054856] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    6.065542] Bluetooth: Core ver 2.22
[    6.065703] NET: Registered PF_BLUETOOTH protocol family
[    6.065705] Bluetooth: HCI device and connection manager initialized
[    6.065709] Bluetooth: HCI socket layer initialized
[    6.065712] Bluetooth: L2CAP socket layer initialized
[    6.065717] Bluetooth: SCO socket layer initialized
[    6.066014] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[    6.066018] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[    6.066742] i2c i2c-7: Successfully instantiated SPD at 0x50
[    6.066777] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[    6.066779] RAPL PMU: hw unit of domain package 2^-16 Joules
[    6.066780] RAPL PMU: hw unit of domain core 2^-16 Joules
[    6.067267] i2c i2c-7: Successfully instantiated SPD at 0x51
[    6.067849] i2c i2c-7: Successfully instantiated SPD at 0x52
[    6.068274] i2c i2c-7: Successfully instantiated SPD at 0x53
[    6.068366] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[    6.072307] videodev: Linux video capture interface: v2.00
[    6.080024] r8169 0000:25:00.0: enabling device (0000 -> 0003)
[    6.080160] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[    6.083019] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[    6.085657] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[    6.090877] r8169 0000:25:00.0 eth0: RTL8125B, 00:e0:4c:00:64:5f, XID 641, IRQ 120
[    6.090881] r8169 0000:25:00.0 eth0: jumbo features [frames: 16362 bytes, tx checksumming: ko]
[    6.090919] r8169 0000:26:00.0: enabling device (0000 -> 0003)
[    6.091532] iwlwifi 0000:28:00.0: enabling device (0000 -> 0002)
[    6.095222] iwlwifi 0000:28:00.0: Detected crf-id 0x3617, cnv-id 0x100530 wfpm id 0x80000000
[    6.095231] iwlwifi 0000:28:00.0: PCI dev 2723/0084, rev=0x340, rfid=0x10a100
[    6.095234] iwlwifi 0000:28:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz
[    6.097260] r8169 0000:26:00.0 eth1: RTL8125B, d8:bb:c1:4d:5e:b1, XID 641, IRQ 137
[    6.097264] r8169 0000:26:00.0 eth1: jumbo features [frames: 16362 bytes, tx checksumming: ko]
[    6.106769] ee1004 7-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[    6.107445] r8169 0000:26:00.0 enp38s0: renamed from eth1
[    6.108766] ee1004 7-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[    6.110514] r8169 0000:25:00.0 enp37s0: renamed from eth0
[    6.110761] ee1004 7-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
[    6.112765] ee1004 7-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[    6.114093] usbcore: registered new interface driver btusb
[    6.115729] Bluetooth: hci0: Bootloader revision 0.3 build 0 week 24 2017
[    6.117733] Bluetooth: hci0: Device revision is 1
[    6.117735] Bluetooth: hci0: Secure boot is enabled
[    6.117737] Bluetooth: hci0: OTP lock is enabled
[    6.117739] Bluetooth: hci0: API lock is enabled
[    6.117740] Bluetooth: hci0: Debug lock is disabled
[    6.117741] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    6.122788] iwlwifi 0000:28:00.0: loaded firmware version 77.f39cc7f9.0 cc-a0-77.ucode op_mode iwlmvm
[    6.141377] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[    6.141391] Bluetooth: hci0: Boot Address: 0x24800
[    6.141394] Bluetooth: hci0: Firmware Version: 193-33.24
[    6.147501] uvcvideo 5-3.1:1.0: Found UVC 1.00 device USB  Live camera (0c45:6366)
[    6.149465] pps_core: LinuxPPS API ver. 1 registered
[    6.149467] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    6.152746] PTP clock support registered
[    6.154973] kvm_amd: TSC scaling supported
[    6.154975] kvm_amd: Nested Virtualization enabled
[    6.154977] kvm_amd: Nested Paging enabled
[    6.154979] kvm_amd: LBR virtualization supported
[    6.154982] kvm_amd: Virtual VMLOAD VMSAVE supported
[    6.154983] kvm_amd: Virtual GIF supported
[    6.163995] input: USB  Live camera: USB  Live cam as /devices/pci0000:00/0000:00:08.1/0000:31:00.3/usb5/5-3/5-3.1/5-3.1:1.0/input/input13
[    6.164059] usbcore: registered new interface driver uvcvideo
[    6.171263] snd_hda_intel 0000:2f:00.1: enabling device (0000 -> 0002)
[    6.171356] snd_hda_intel 0000:2f:00.1: Handle vga_switcheroo audio client
[    6.171359] snd_hda_intel 0000:2f:00.1: Force to non-snoop mode
[    6.171588] snd_hda_intel 0000:31:00.4: enabling device (0000 -> 0002)
[    6.198670] usb 5-3.1: 3:1: cannot get freq at ep 0x84
[    6.211973] snd_hda_intel 0000:2f:00.1: bound 0000:2f:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[    6.215448] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card1/input14
[    6.215506] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card1/input15
[    6.215551] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card1/input16
[    6.215590] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card1/input17
[    6.216383] snd_hda_codec_alc882 hdaudioC2D0: ALCS1200A: picked fixup  for PCI SSID 1462:0000
[    6.216386] snd_hda_codec_alc882 hdaudioC2D0: ALCS1200A: SKU not ready 0x00000000
[    6.216502] amd_atl: AMD Address Translation Library initialized
[    6.216864] snd_hda_codec_alc882 hdaudioC2D0: autoconfig for ALCS1200A: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    6.216870] snd_hda_codec_alc882 hdaudioC2D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    6.216872] snd_hda_codec_alc882 hdaudioC2D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    6.216875] snd_hda_codec_alc882 hdaudioC2D0:    mono: mono_out=0x0
[    6.216876] snd_hda_codec_alc882 hdaudioC2D0:    dig-out=0x1e/0x0
[    6.216878] snd_hda_codec_alc882 hdaudioC2D0:    inputs:
[    6.216880] snd_hda_codec_alc882 hdaudioC2D0:      Rear Mic=0x18
[    6.216883] snd_hda_codec_alc882 hdaudioC2D0:      Front Mic=0x19
[    6.216885] snd_hda_codec_alc882 hdaudioC2D0:      Line=0x1a
[    6.217254] intel_rapl_common: Found RAPL domain package
[    6.217256] intel_rapl_common: Found RAPL domain core
[    6.230690] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:31:00.4/sound/card2/input18
[    6.230757] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:31:00.4/sound/card2/input19
[    6.230804] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:31:00.4/sound/card2/input20
[    6.230855] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:31:00.4/sound/card2/input21
[    6.230911] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:31:00.4/sound/card2/input22
[    6.230958] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:31:00.4/sound/card2/input23
[    6.231004] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:31:00.4/sound/card2/input24
[    6.279883] usbcore: registered new interface driver snd-usb-audio
[    6.352804] iwlwifi 0000:28:00.0: Detected RF HR B3, rfid=0x10a100
[    6.418367] iwlwifi 0000:28:00.0: base HW address: a4:42:3b:fd:20:23
[    6.450302] iwlwifi 0000:28:00.0 wlo1: renamed from wlan0
[    6.678013] EXT4-fs (nvme1n1p1): mounted filesystem 42c9201d-2d84-4197-b0aa-e45e907be1bd r/w with ordered data mode. Quota mode: none.
[    6.690140] RPC: Registered named UNIX socket transport module.
[    6.690142] RPC: Registered udp transport module.
[    6.690143] RPC: Registered tcp transport module.
[    6.690144] RPC: Registered tcp-with-tls transport module.
[    6.690145] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    6.717100] EXT4-fs (sda1): mounted filesystem 9141152e-23a1-4727-a159-3cca321152cc r/w with ordered data mode. Quota mode: none.
[    6.805398] EXT4-fs (sdb1): mounted filesystem 9d0a6e10-7fee-4f13-8b63-780f10d5eaa8 r/w with ordered data mode. Quota mode: none.
[    6.993034] nct6775: Found NCT6797D or compatible chip at 0x4e:0xa20
[    7.001261] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.001263] Bluetooth: BNEP filters: protocol multicast
[    7.001266] Bluetooth: BNEP socket layer initialized
[    7.064527] NET: Registered PF_QIPCRTR protocol family
[    7.494929] Bluetooth: hci0: Waiting for firmware download to complete
[    7.495721] Bluetooth: hci0: Firmware loaded in 1322597 usecs
[    7.495755] Bluetooth: hci0: Waiting for device to boot
[    7.510724] Bluetooth: hci0: Device booted in 14631 usecs
[    7.511585] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-20-1-3.ddc
[    7.516726] Bluetooth: hci0: Applying Intel DDC parameters completed
[    7.519729] Bluetooth: hci0: Firmware revision 0.3 build 193 week 33 2024
[    7.525737] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[    7.663217] Realtek Internal NBASE-T PHY r8169-0-2500:00: attached PHY driver (mii_bus:phy_addr=r8169-0-2500:00, irq=MAC)
[    7.706007] Bluetooth: MGMT ver 1.23
[    7.710641] NET: Registered PF_ALG protocol family
[    7.820418] r8169 0000:25:00.0 enp37s0: Link is Down
[    7.843217] Realtek Internal NBASE-T PHY r8169-0-2600:00: attached PHY driver (mii_bus:phy_addr=r8169-0-2600:00, irq=MAC)
[    8.000714] r8169 0000:26:00.0 enp38s0: Link is Down
[    8.443804] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    9.704913] u32 classifier
[    9.704916]     Performance counters on
[    9.704917]     input device check on
[    9.704918]     Actions configured
[   10.298350] r8169 0000:26:00.0 enp38s0: Link is Up - 1Gbps/Full - flow control rx/tx
[   10.312047] br0: port 1(enp38s0) entered blocking state
[   10.312050] br0: port 1(enp38s0) entered disabled state
[   10.312059] r8169 0000:26:00.0 enp38s0: entered allmulticast mode
[   10.312202] r8169 0000:26:00.0 enp38s0: entered promiscuous mode
[   10.312305] br0: port 1(enp38s0) entered blocking state
[   10.312308] br0: port 1(enp38s0) entered forwarding state
[   10.903808] r8169 0000:25:00.0: invalid VPD tag 0xff (size 0) at offset 0; assume missing optional EEPROM
[   10.922215] r8169 0000:26:00.0: invalid VPD tag 0x00 (size 0) at offset 0; assume missing optional EEPROM
[   14.284037] RPC: Registered rdma transport module.
[   14.284040] RPC: Registered rdma backchannel transport module.
[   14.396306] NFSD: Using nfsdcld client tracking operations.
[   14.396310] NFSD: no clients to reclaim, skipping NFSv4 grace period (net effffff9)
[   20.630499] HDR SB:01 1a 02 00 f1 84 d8 3c 43 34 82 81 60 1d 89 09
[   20.630504] HDR SB:09 3d 47 40 58 01 e2 0d 58 01 58 01 00 00 00 00
[   20.630678] HDR SB:01 1a 02 00 f1 84 d8 3c 43 34 82 81 60 1d 89 09
[   20.630679] HDR SB:09 3d 47 40 58 01 e2 0d 58 01 58 01 00 00 00 00
[   20.630792] HDR SB:01 1a 02 00 f1 84 d8 3c 43 34 82 81 60 1d 89 09
[   20.630794] HDR SB:09 3d 47 40 58 01 e2 0d 58 01 58 01 00 00 00 00
[   20.630877] HDR SB:01 1a 02 00 f1 84 d8 3c 43 34 82 81 60 1d 89 09
[   20.630879] HDR SB:09 3d 47 40 58 01 e2 0d 58 01 58 01 00 00 00 00
[   20.706011] HDR SB:01 1a 02 00 f1 84 d8 3c 43 34 82 81 60 1d 89 09
[   20.706015] HDR SB:09 3d 47 40 58 01 e2 0d 58 01 58 01 00 00 00 00
[   20.706183] HDR SB:01 1a 02 00 f1 84 d8 3c 43 34 82 81 60 1d 89 09
[   20.706185] HDR SB:09 3d 47 40 58 01 e2 0d 58 01 58 01 00 00 00 00
[   20.917919] usb 5-3.1: 3:1: cannot get freq at ep 0x84
[   20.981543] usb 5-3.1: 3:1: cannot get freq at ep 0x84
[   21.372323] Bluetooth: RFCOMM TTY layer initialized
[   21.372330] Bluetooth: RFCOMM socket layer initialized
[   21.372333] Bluetooth: RFCOMM ver 1.11
[   21.756160] nvme nvme0: using unchecked data buffer
[   22.353488] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[31507.388330] amdgpu 0000:2f:00.0: amdgpu: device lost from bus!
[31507.388336] amdgpu 0000:2f:00.0: amdgpu: SMU: response:0xFFFFFFFF for index:36 param:0x00000001 message:SetWorkloadMask?
[31507.388339] amdgpu 0000:2f:00.0: amdgpu: Failed to set workload mask 0x00000001
[31507.388341] amdgpu 0000:2f:00.0: amdgpu: (-121) failed to disable fullscreen 3D power profile mode
[31704.846844] INFO: task kworker/8:1H:276 blocked for more than 122 seconds.
[31704.846850]       Not tainted 6.19.8-1-MANJARO #1
[31704.846852] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[31704.846853] task:kworker/8:1H    state:D stack:0     pid:276   tgid:276   ppid:2      task_flags:0x4208060 flags:0x00080000
[31704.846858] Workqueue: events_highpri dm_irq_work_func [amdgpu]
[31704.868952] Call Trace:
[31704.868954]  <TASK>
[31704.868956]  __schedule+0x457/0x1720
[31704.868961]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.868966]  schedule+0x27/0xd0
[31704.868968]  schedule_preempt_disabled+0x15/0x30
[31704.868970]  __mutex_lock.constprop.0+0x527/0xa60
[31704.868974]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.868976]  handle_hpd_irq_helper+0x241/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.869186]  process_one_work+0x193/0x350
[31704.869191]  worker_thread+0x1a1/0x310
[31704.869193]  ? __pfx_worker_thread+0x10/0x10
[31704.869196]  kthread+0xfc/0x240
[31704.869199]  ? __pfx_kthread+0x10/0x10
[31704.869201]  ? __pfx_kthread+0x10/0x10
[31704.869203]  ret_from_fork+0x243/0x280
[31704.869206]  ? __pfx_kthread+0x10/0x10
[31704.869209]  ret_from_fork_asm+0x1a/0x30
[31704.869214]  </TASK>
[31704.869237] INFO: task kworker/8:1H:276 is blocked on a mutex likely owned by task kwin_wayland:1282.
[31704.869239] task:kwin_wayland    state:R  running task     stack:0     pid:1282  tgid:1282  ppid:1276   task_flags:0x400100 flags:0x00080800
[31704.869243] Call Trace:
[31704.869244]  <TASK>
[31704.869246]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.869248]  ? __schedule+0xf10/0x1720
[31704.869250]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.869252]  ? sysvec_apic_timer_interrupt+0xe/0x90
[31704.869255]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.869256]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[31704.869259]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.869261]  ? sysvec_apic_timer_interrupt+0xe/0x90
[31704.869263]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.869264]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[31704.869268]  ? amdgpu_device_rreg.part.0+0x38/0xf0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.869406]  ? dm_read_reg_func+0x5c/0xe0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.869613]  ? delay_halt+0x3f/0x70
[31704.869617]  ? generic_reg_wait+0xaa/0x190 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.869814]  ? optc32_disable_crtc+0x159/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.870027]  ? dcn20_reset_back_end_for_pipe+0x1c9/0x330 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.870252]  ? dcn20_reset_hw_ctx_wrap+0xf0/0x150 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.870473]  ? dce110_apply_ctx_to_hw+0x66/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.870698]  ? dc_commit_state_no_check+0x709/0xed0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.870898]  ? dc_commit_streams+0x31b/0x520 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.871089]  ? amdgpu_dm_atomic_commit_tail+0x6b2/0x3900 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.871297]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.871299]  ? optc1_get_crtc_scanoutpos+0x75/0xb0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.871517]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.871520]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.871522]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.871524]  ? ktime_get+0x3b/0xd0
[31704.871528]  ? amdgpu_display_get_crtc_scanoutpos+0xa8/0x1d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.871671]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.871673]  ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.871813]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.871815]  ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x1a6/0x3d0
[31704.871820]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.871822]  ? wait_for_completion_timeout+0x109/0x150
[31704.871824]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.871826]  ? drm_crtc_get_last_vbltimestamp+0x55/0x90
[31704.871831]  ? commit_tail+0xc1/0x150
[31704.871834]  ? drm_atomic_helper_commit+0x13c/0x180
[31704.871837]  ? drm_atomic_commit+0xb1/0xe0
[31704.871840]  ? __pfx___drm_printfn_info+0x10/0x10
[31704.871844]  ? drm_mode_atomic_ioctl+0xaae/0xd20
[31704.871848]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[31704.871850]  ? drm_ioctl_kernel+0xae/0x100
[31704.871854]  ? drm_ioctl+0x29b/0x520
[31704.871856]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[31704.871861]  ? amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.871996]  ? __x64_sys_ioctl+0x97/0xe0
[31704.872000]  ? do_syscall_64+0x81/0x610
[31704.872002]  ? drm_ioctl+0x2d0/0x520
[31704.872005]  ? __pfx_drm_mode_createblob_ioctl+0x10/0x10
[31704.872009]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872011]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872014]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872015]  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31704.872150]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872152]  ? __x64_sys_ioctl+0xb1/0xe0
[31704.872155]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872157]  ? do_syscall_64+0x81/0x610
[31704.872160]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872162]  ? do_syscall_64+0x81/0x610
[31704.872164]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872165]  ? switch_fpu_return+0x4e/0xd0
[31704.872168]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872170]  ? do_syscall_64+0x23b/0x610
[31704.872172]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872174]  ? do_syscall_64+0x81/0x610
[31704.872176]  ? srso_alias_return_thunk+0x5/0xfbef5
[31704.872177]  ? exc_page_fault+0x7e/0x1a0
[31704.872180]  ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
[31704.872184]  </TASK>
[31705.161488] amdgpu 0000:2f:00.0: amdgpu: Dumping IP State
[31827.723502] INFO: task kworker/8:1H:276 blocked for more than 245 seconds.
[31827.723508]       Not tainted 6.19.8-1-MANJARO #1
[31827.723511] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[31827.723512] task:kworker/8:1H    state:D stack:0     pid:276   tgid:276   ppid:2      task_flags:0x4208060 flags:0x00080000
[31827.723518] Workqueue: events_highpri dm_irq_work_func [amdgpu]
[31827.723842] Call Trace:
[31827.723844]  <TASK>
[31827.723847]  __schedule+0x457/0x1720
[31827.723852]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.723858]  schedule+0x27/0xd0
[31827.723861]  schedule_preempt_disabled+0x15/0x30
[31827.723863]  __mutex_lock.constprop.0+0x527/0xa60
[31827.723868]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.723871]  handle_hpd_irq_helper+0x241/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.724138]  process_one_work+0x193/0x350
[31827.724144]  worker_thread+0x1a1/0x310
[31827.724148]  ? __pfx_worker_thread+0x10/0x10
[31827.724151]  kthread+0xfc/0x240
[31827.724154]  ? __pfx_kthread+0x10/0x10
[31827.724157]  ? __pfx_kthread+0x10/0x10
[31827.724160]  ret_from_fork+0x243/0x280
[31827.724163]  ? __pfx_kthread+0x10/0x10
[31827.724166]  ret_from_fork_asm+0x1a/0x30
[31827.724172]  </TASK>
[31827.724197] INFO: task kworker/8:1H:276 is blocked on a mutex likely owned by task kwin_wayland:1282.
[31827.724199] task:kwin_wayland    state:R  running task     stack:0     pid:1282  tgid:1282  ppid:1276   task_flags:0x400100 flags:0x00080800
[31827.724204] Call Trace:
[31827.724205]  <TASK>
[31827.724207]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.724210]  ? __schedule+0xf10/0x1720
[31827.724213]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.724215]  ? sysvec_apic_timer_interrupt+0xe/0x90
[31827.724218]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.724220]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[31827.724224]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.724226]  ? sysvec_apic_timer_interrupt+0xe/0x90
[31827.724228]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.724230]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[31827.724235]  ? amdgpu_device_rreg.part.0+0x38/0xf0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.724408]  ? dm_read_reg_func+0x5c/0xe0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.724676]  ? delay_halt+0x3f/0x70
[31827.724681]  ? generic_reg_wait+0xaa/0x190 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.724930]  ? optc32_disable_crtc+0x159/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.725199]  ? dcn20_reset_back_end_for_pipe+0x1c9/0x330 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.725483]  ? dcn20_reset_hw_ctx_wrap+0xf0/0x150 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.725763]  ? dce110_apply_ctx_to_hw+0x66/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.726040]  ? dc_commit_state_no_check+0x709/0xed0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.726284]  ? dc_commit_streams+0x31b/0x520 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.726530]  ? amdgpu_dm_atomic_commit_tail+0x6b2/0x3900 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.726789]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.726792]  ? optc1_get_crtc_scanoutpos+0x75/0xb0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.727064]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727067]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727070]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727072]  ? ktime_get+0x3b/0xd0
[31827.727076]  ? amdgpu_display_get_crtc_scanoutpos+0xa8/0x1d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.727262]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727264]  ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.727439]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727442]  ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x1a6/0x3d0
[31827.727449]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727451]  ? wait_for_completion_timeout+0x109/0x150
[31827.727454]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727456]  ? drm_crtc_get_last_vbltimestamp+0x55/0x90
[31827.727461]  ? commit_tail+0xc1/0x150
[31827.727465]  ? drm_atomic_helper_commit+0x13c/0x180
[31827.727468]  ? drm_atomic_commit+0xb1/0xe0
[31827.727478]  ? __pfx___drm_printfn_info+0x10/0x10
[31827.727482]  ? drm_mode_atomic_ioctl+0xaae/0xd20
[31827.727488]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[31827.727490]  ? drm_ioctl_kernel+0xae/0x100
[31827.727494]  ? drm_ioctl+0x29b/0x520
[31827.727498]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[31827.727503]  ? amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.727673]  ? __x64_sys_ioctl+0x97/0xe0
[31827.727678]  ? do_syscall_64+0x81/0x610
[31827.727680]  ? drm_ioctl+0x2d0/0x520
[31827.727684]  ? __pfx_drm_mode_createblob_ioctl+0x10/0x10
[31827.727690]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727692]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727695]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727697]  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31827.727866]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727868]  ? __x64_sys_ioctl+0xb1/0xe0
[31827.727872]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727874]  ? do_syscall_64+0x81/0x610
[31827.727878]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727880]  ? do_syscall_64+0x81/0x610
[31827.727882]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727885]  ? switch_fpu_return+0x4e/0xd0
[31827.727888]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727890]  ? do_syscall_64+0x23b/0x610
[31827.727893]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727895]  ? do_syscall_64+0x81/0x610
[31827.727897]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.727900]  ? exc_page_fault+0x7e/0x1a0
[31827.727902]  ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
[31827.727908]  </TASK>
[31827.728112] INFO: task kworker/u65:9:63287 blocked for more than 122 seconds.
[31827.728114]       Not tainted 6.19.8-1-MANJARO #1
[31827.728115] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[31827.728117] task:kworker/u65:9   state:D stack:0     pid:63287 tgid:63287 ppid:2      task_flags:0x4208060 flags:0x00080000
[31827.728121] Workqueue: ttm ttm_bo_delayed_delete [ttm]
[31827.728129] Call Trace:
[31827.728130]  <TASK>
[31827.728133]  __schedule+0x457/0x1720
[31827.728136]  ? srso_alias_return_thunk+0x5/0xfbef5
[31827.728139]  ? update_load_avg+0x7b/0x740
[31827.728144]  schedule+0x27/0xd0
[31827.728146]  schedule_timeout+0xbd/0x100
[31827.728151]  dma_fence_default_wait+0x196/0x270
[31827.728154]  ? __pfx_dma_fence_default_wait_cb+0x10/0x10
[31827.728159]  dma_fence_wait_timeout+0xa2/0x150
[31827.728162]  dma_resv_wait_timeout+0xce/0x1d0
[31827.728166]  ttm_bo_delayed_delete+0x32/0x90 [ttm 64a8a8e673e5d2569262fc1eaf8a2a06a5cc4871]
[31827.728171]  process_one_work+0x193/0x350
[31827.728175]  worker_thread+0x1a1/0x310
[31827.728179]  ? __pfx_worker_thread+0x10/0x10
[31827.728182]  kthread+0xfc/0x240
[31827.728184]  ? __pfx_kthread+0x10/0x10
[31827.728187]  ? __pfx_kthread+0x10/0x10
[31827.728190]  ret_from_fork+0x243/0x280
[31827.728192]  ? __pfx_kthread+0x10/0x10
[31827.728195]  ret_from_fork_asm+0x1a/0x30
[31827.728200]  </TASK>
[31950.604134] INFO: task kworker/8:1H:276 blocked for more than 368 seconds.
[31950.604139]       Not tainted 6.19.8-1-MANJARO #1
[31950.604141] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[31950.604143] task:kworker/8:1H    state:D stack:0     pid:276   tgid:276   ppid:2      task_flags:0x4208060 flags:0x00080000
[31950.604148] Workqueue: events_highpri dm_irq_work_func [amdgpu]
[31950.669958] Call Trace:
[31950.669960]  <TASK>
[31950.669962]  __schedule+0x457/0x1720
[31950.669968]  ? srso_alias_return_thunk+0x5/0xfbef5
[31950.669974]  schedule+0x27/0xd0
[31950.669977]  schedule_preempt_disabled+0x15/0x30
[31950.669979]  __mutex_lock.constprop.0+0x527/0xa60
[31950.669983]  ? srso_alias_return_thunk+0x5/0xfbef5
[31950.669987]  handle_hpd_irq_helper+0x241/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31950.713811]  process_one_work+0x193/0x350
[31950.713818]  worker_thread+0x1a1/0x310
[31950.713821]  ? __pfx_worker_thread+0x10/0x10
[31950.713824]  kthread+0xfc/0x240
[31950.713827]  ? __pfx_kthread+0x10/0x10
[31950.713830]  ? __pfx_kthread+0x10/0x10
[31950.713832]  ret_from_fork+0x243/0x280
[31950.713836]  ? __pfx_kthread+0x10/0x10
[31950.713839]  ret_from_fork_asm+0x1a/0x30
[31950.713845]  </TASK>
[31950.713882] INFO: task kworker/8:1H:276 is blocked on a mutex likely owned by task kwin_wayland:1282.
[31950.713884] task:kwin_wayland    state:R  running task     stack:0     pid:1282  tgid:1282  ppid:1276   task_flags:0x400100 flags:0x00080800
[31950.713888] Call Trace:
[31950.713890]  <TASK>
[31950.713891]  ? srso_alias_return_thunk+0x5/0xfbef5
[31950.713894]  ? __schedule+0xf10/0x1720
[31950.713898]  ? srso_alias_return_thunk+0x5/0xfbef5
[31950.713900]  ? sysvec_apic_timer_interrupt+0xe/0x90
[31950.713903]  ? srso_alias_return_thunk+0x5/0xfbef5
[31950.713905]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[31950.713908]  ? srso_alias_return_thunk+0x5/0xfbef5
[31950.713911]  ? sysvec_apic_timer_interrupt+0xe/0x90
[31950.713913]  ? srso_alias_return_thunk+0x5/0xfbef5
[31950.713915]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[31950.713920]  ? amdgpu_device_rreg.part.0+0x38/0xf0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31950.757692]  ? dm_read_reg_func+0x5c/0xe0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31950.801570]  ? delay_halt+0x3f/0x70
[31950.801575]  ? generic_reg_wait+0xaa/0x190 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31950.845461]  ? optc32_disable_crtc+0x159/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31950.889331]  ? dcn20_reset_back_end_for_pipe+0x1c9/0x330 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31950.933212]  ? dcn20_reset_hw_ctx_wrap+0xf0/0x150 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31950.977091]  ? dce110_apply_ctx_to_hw+0x66/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.020971]  ? dc_commit_state_no_check+0x709/0xed0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.064851]  ? dc_commit_streams+0x31b/0x520 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.108735]  ? amdgpu_dm_atomic_commit_tail+0x6b2/0x3900 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.152609]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.152613]  ? optc1_get_crtc_scanoutpos+0x75/0xb0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.196488]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.196493]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.196495]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.196498]  ? ktime_get+0x3b/0xd0
[31951.196501]  ? amdgpu_display_get_crtc_scanoutpos+0xa8/0x1d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.240369]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.240371]  ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.284249]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.284253]  ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x1a6/0x3d0
[31951.284259]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.284261]  ? wait_for_completion_timeout+0x109/0x150
[31951.284265]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.284267]  ? drm_crtc_get_last_vbltimestamp+0x55/0x90
[31951.284272]  ? commit_tail+0xc1/0x150
[31951.284276]  ? drm_atomic_helper_commit+0x13c/0x180
[31951.284279]  ? drm_atomic_commit+0xb1/0xe0
[31951.284282]  ? __pfx___drm_printfn_info+0x10/0x10
[31951.284286]  ? drm_mode_atomic_ioctl+0xaae/0xd20
[31951.284291]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[31951.284294]  ? drm_ioctl_kernel+0xae/0x100
[31951.284297]  ? drm_ioctl+0x29b/0x520
[31951.284301]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[31951.284306]  ? amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.328129]  ? __x64_sys_ioctl+0x97/0xe0
[31951.328134]  ? do_syscall_64+0x81/0x610
[31951.328137]  ? drm_ioctl+0x2d0/0x520
[31951.328140]  ? __pfx_drm_mode_createblob_ioctl+0x10/0x10
[31951.328146]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.328148]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.328150]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.328153]  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.372009]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.372011]  ? __x64_sys_ioctl+0xb1/0xe0
[31951.372015]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.372017]  ? do_syscall_64+0x81/0x610
[31951.372021]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.372024]  ? do_syscall_64+0x81/0x610
[31951.372026]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.372028]  ? switch_fpu_return+0x4e/0xd0
[31951.372031]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.372034]  ? do_syscall_64+0x23b/0x610
[31951.372036]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.372038]  ? do_syscall_64+0x81/0x610
[31951.372040]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.372042]  ? exc_page_fault+0x7e/0x1a0
[31951.372046]  ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
[31951.372051]  </TASK>
[31951.372280] INFO: task kworker/u64:4:58582 blocked for more than 123 seconds.
[31951.372283]       Not tainted 6.19.8-1-MANJARO #1
[31951.372284] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[31951.372286] task:kworker/u64:4   state:D stack:0     pid:58582 tgid:58582 ppid:2      task_flags:0x4208060 flags:0x00080000
[31951.372290] Workqueue: amdgpu-reset-dev drm_sched_job_timedout [gpu_sched]
[31951.372297] Call Trace:
[31951.372298]  <TASK>
[31951.372300]  __schedule+0x457/0x1720
[31951.372303]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.393951]  schedule+0x27/0xd0
[31951.393953]  schedule_preempt_disabled+0x15/0x30
[31951.393956]  __mutex_lock.constprop.0+0x527/0xa60
[31951.393961]  amdgpu_dpm_set_powergating_by_smu+0x38/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.459794]  amdgpu_gfx_do_off_ctrl.part.0+0xd8/0x130 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.503676]  gfx_v11_ip_dump+0x3d/0x380 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.547558]  amdgpu_job_timedout.cold+0x6a/0x3b2 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.591437]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.591440]  ? __schedule+0x45f/0x1720
[31951.591444]  drm_sched_job_timedout+0x88/0x180 [gpu_sched 792c5c85c7bb0dd50f45deef0512ade489308583]
[31951.591449]  ? queue_delayed_work_on+0x81/0x90
[31951.591453]  process_one_work+0x193/0x350
[31951.591457]  worker_thread+0x1a1/0x310
[31951.591462]  ? __pfx_worker_thread+0x10/0x10
[31951.591465]  kthread+0xfc/0x240
[31951.591468]  ? __pfx_kthread+0x10/0x10
[31951.591471]  ? __pfx_kthread+0x10/0x10
[31951.591473]  ret_from_fork+0x243/0x280
[31951.591477]  ? __pfx_kthread+0x10/0x10
[31951.591479]  ret_from_fork_asm+0x1a/0x30
[31951.591485]  </TASK>
[31951.591694] INFO: task kworker/u64:4:58582 is blocked on a mutex likely owned by task kworker/u64:0:63928.
[31951.591696] task:kworker/u64:0   state:R  running task     stack:0     pid:63928 tgid:63928 ppid:2      task_flags:0x4208060 flags:0x00080000
[31951.591701] Workqueue: vcn_unified_0 drm_sched_run_job_work [gpu_sched]
[31951.591706] Call Trace:
[31951.591707]  <TASK>
[31951.591709]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.591711]  ? __schedule+0x45f/0x1720
[31951.591713]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.591716]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[31951.591720]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.591722]  ? sysvec_apic_timer_interrupt+0xe/0x90
[31951.613375]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.613377]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[31951.613380]  ? __pfx_smu_v13_0_set_vcn_enable+0x10/0x10 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.679196]  ? amdgpu_device_rreg.part.0+0x38/0xf0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.723076]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.723079]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.723081]  ? delay_halt+0x3f/0x70
[31951.723084]  ? smu_cmn_send_smc_msg_with_param+0x141/0x490 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.766956]  ? smu_dpm_set_vcn_enable+0x7c/0xb0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.810836]  ? smu_dpm_set_power_gate+0x115/0x200 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.854716]  ? amdgpu_dpm_set_powergating_by_smu+0xfa/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.898596]  ? amdgpu_dpm_enable_vcn+0x20/0x50 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.942475]  ? vcn_v4_0_start+0x134/0x15f0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31951.986356]  ? srso_alias_return_thunk+0x5/0xfbef5
[31951.986359]  ? enable_work+0x3a/0x100
[31951.986363]  ? vcn_v4_0_set_pg_state+0x50/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31952.030242]  ? amdgpu_vcn_ring_begin_use+0x8b/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31952.074122]  ? amdgpu_ring_alloc+0x43/0x60 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31952.118000]  ? amdgpu_ib_schedule+0x10c/0x760 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31952.161882]  ? amdgpu_job_run+0x8b/0x1a0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[31952.205760]  ? mod_delayed_work_on+0x9f/0xb0
[31952.205766]  ? drm_sched_run_job_work+0x1cb/0x3e0 [gpu_sched 792c5c85c7bb0dd50f45deef0512ade489308583]
[31952.205772]  ? process_one_work+0x193/0x350
[31952.205776]  ? worker_thread+0x1a1/0x310
[31952.205779]  ? __pfx_worker_thread+0x10/0x10
[31952.205782]  ? kthread+0xfc/0x240
[31952.205784]  ? __pfx_kthread+0x10/0x10
[31952.205787]  ? __pfx_kthread+0x10/0x10
[31952.205789]  ? ret_from_fork+0x243/0x280
[31952.205793]  ? __pfx_kthread+0x10/0x10
[31952.205795]  ? ret_from_fork_asm+0x1a/0x30
[31952.205801]  </TASK>
[31952.205812] INFO: task kworker/u65:9:63287 blocked for more than 247 seconds.
[31952.205814]       Not tainted 6.19.8-1-MANJARO #1
[31952.205815] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[31952.205817] task:kworker/u65:9   state:D stack:0     pid:63287 tgid:63287 ppid:2      task_flags:0x4208060 flags:0x00080000
[31952.205821] Workqueue: ttm ttm_bo_delayed_delete [ttm]
[31952.205828] Call Trace:
[31952.205829]  <TASK>
[31952.205831]  __schedule+0x457/0x1720
[31952.205836]  ? srso_alias_return_thunk+0x5/0xfbef5
[31952.205839]  ? update_load_avg+0x7b/0x740
[31952.205843]  schedule+0x27/0xd0
[31952.205846]  schedule_timeout+0xbd/0x100
[31952.205850]  dma_fence_default_wait+0x196/0x270
[31952.205854]  ? __pfx_dma_fence_default_wait_cb+0x10/0x10
[31952.227701]  dma_fence_wait_timeout+0xa2/0x150
[31952.227704]  dma_resv_wait_timeout+0xce/0x1d0
[31952.227708]  ttm_bo_delayed_delete+0x32/0x90 [ttm 64a8a8e673e5d2569262fc1eaf8a2a06a5cc4871]
[31952.227714]  process_one_work+0x193/0x350
[31952.227718]  worker_thread+0x1a1/0x310
[31952.227721]  ? __pfx_worker_thread+0x10/0x10
[31952.227724]  kthread+0xfc/0x240
[31952.227727]  ? __pfx_kthread+0x10/0x10
[31952.227729]  ? __pfx_kthread+0x10/0x10
[31952.227732]  ret_from_fork+0x243/0x280
[31952.227734]  ? __pfx_kthread+0x10/0x10
[31952.227737]  ret_from_fork_asm+0x1a/0x30
[31952.227742]  </TASK>
[32073.490910] INFO: task kworker/8:1H:276 blocked for more than 491 seconds.
[32073.490916]       Not tainted 6.19.8-1-MANJARO #1
[32073.490919] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[32073.490921] task:kworker/8:1H    state:D stack:0     pid:276   tgid:276   ppid:2      task_flags:0x4208060 flags:0x00080000
[32073.490928] Workqueue: events_highpri dm_irq_work_func [amdgpu]
[32073.491381] Call Trace:
[32073.491383]  <TASK>
[32073.491386]  __schedule+0x457/0x1720
[32073.491393]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.491401]  schedule+0x27/0xd0
[32073.491404]  schedule_preempt_disabled+0x15/0x30
[32073.491408]  __mutex_lock.constprop.0+0x527/0xa60
[32073.491414]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.491418]  handle_hpd_irq_helper+0x241/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.491854]  process_one_work+0x193/0x350
[32073.491861]  worker_thread+0x1a1/0x310
[32073.491866]  ? __pfx_worker_thread+0x10/0x10
[32073.491870]  kthread+0xfc/0x240
[32073.491874]  ? __pfx_kthread+0x10/0x10
[32073.491878]  ? __pfx_kthread+0x10/0x10
[32073.491881]  ret_from_fork+0x243/0x280
[32073.491887]  ? __pfx_kthread+0x10/0x10
[32073.491890]  ret_from_fork_asm+0x1a/0x30
[32073.491898]  </TASK>
[32073.491929] INFO: task kworker/8:1H:276 is blocked on a mutex likely owned by task kwin_wayland:1282.
[32073.491932] task:kwin_wayland    state:R  running task     stack:0     pid:1282  tgid:1282  ppid:1276   task_flags:0x400100 flags:0x00080800
[32073.491937] Call Trace:
[32073.491939]  <TASK>
[32073.491941]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.491945]  ? __schedule+0xf10/0x1720
[32073.491949]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.491953]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[32073.491958]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.491961]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.491964]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[32073.491970]  ? amdgpu_device_rreg.part.0+0x38/0xf0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.492306]  ? dm_read_reg_func+0x5c/0xe0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.492736]  ? delay_halt+0x3f/0x70
[32073.492742]  ? generic_reg_wait+0xaa/0x190 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.493151]  ? optc32_disable_crtc+0x159/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.493589]  ? dcn20_reset_back_end_for_pipe+0x1c9/0x330 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.494038]  ? dcn20_reset_hw_ctx_wrap+0xf0/0x150 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.494485]  ? dce110_apply_ctx_to_hw+0x66/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.494932]  ? dc_commit_state_no_check+0x709/0xed0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.495337]  ? dc_commit_streams+0x31b/0x520 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.495747]  ? amdgpu_dm_atomic_commit_tail+0x6b2/0x3900 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.496173]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.496176]  ? optc1_get_crtc_scanoutpos+0x75/0xb0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.496615]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.496620]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.496624]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.496627]  ? ktime_get+0x3b/0xd0
[32073.496632]  ? amdgpu_display_get_crtc_scanoutpos+0xa8/0x1d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.496975]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.496979]  ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.497249]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497252]  ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x1a6/0x3d0
[32073.497259]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497262]  ? wait_for_completion_timeout+0x109/0x150
[32073.497264]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497267]  ? drm_crtc_get_last_vbltimestamp+0x55/0x90
[32073.497272]  ? commit_tail+0xc1/0x150
[32073.497276]  ? drm_atomic_helper_commit+0x13c/0x180
[32073.497280]  ? drm_atomic_commit+0xb1/0xe0
[32073.497283]  ? __pfx___drm_printfn_info+0x10/0x10
[32073.497288]  ? drm_mode_atomic_ioctl+0xaae/0xd20
[32073.497295]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[32073.497297]  ? drm_ioctl_kernel+0xae/0x100
[32073.497302]  ? drm_ioctl+0x29b/0x520
[32073.497305]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[32073.497311]  ? amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.497593]  ? __x64_sys_ioctl+0x97/0xe0
[32073.497598]  ? do_syscall_64+0x81/0x610
[32073.497601]  ? drm_ioctl+0x2d0/0x520
[32073.497605]  ? __pfx_drm_mode_createblob_ioctl+0x10/0x10
[32073.497610]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497613]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497616]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497619]  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.497884]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497887]  ? __x64_sys_ioctl+0xb1/0xe0
[32073.497891]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497893]  ? do_syscall_64+0x81/0x610
[32073.497898]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497900]  ? do_syscall_64+0x81/0x610
[32073.497902]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497905]  ? switch_fpu_return+0x4e/0xd0
[32073.497908]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497911]  ? do_syscall_64+0x23b/0x610
[32073.497914]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497916]  ? do_syscall_64+0x81/0x610
[32073.497919]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.497921]  ? exc_page_fault+0x7e/0x1a0
[32073.497925]  ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
[32073.497930]  </TASK>
[32073.498153] INFO: task kworker/u64:4:58582 blocked for more than 245 seconds.
[32073.498155]       Not tainted 6.19.8-1-MANJARO #1
[32073.498157] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[32073.498158] task:kworker/u64:4   state:D stack:0     pid:58582 tgid:58582 ppid:2      task_flags:0x4208060 flags:0x00080000
[32073.498163] Workqueue: amdgpu-reset-dev drm_sched_job_timedout [gpu_sched]
[32073.498170] Call Trace:
[32073.498171]  <TASK>
[32073.498174]  __schedule+0x457/0x1720
[32073.498177]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.498182]  schedule+0x27/0xd0
[32073.498185]  schedule_preempt_disabled+0x15/0x30
[32073.498187]  __mutex_lock.constprop.0+0x527/0xa60
[32073.498193]  amdgpu_dpm_set_powergating_by_smu+0x38/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.498533]  amdgpu_gfx_do_off_ctrl.part.0+0xd8/0x130 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.498828]  gfx_v11_ip_dump+0x3d/0x380 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.499120]  amdgpu_job_timedout.cold+0x6a/0x3b2 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.499328]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.499330]  ? __schedule+0x45f/0x1720
[32073.499333]  drm_sched_job_timedout+0x88/0x180 [gpu_sched 792c5c85c7bb0dd50f45deef0512ade489308583]
[32073.499338]  ? queue_delayed_work_on+0x81/0x90
[32073.499341]  process_one_work+0x193/0x350
[32073.499344]  worker_thread+0x1a1/0x310
[32073.499347]  ? __pfx_worker_thread+0x10/0x10
[32073.499350]  kthread+0xfc/0x240
[32073.499352]  ? __pfx_kthread+0x10/0x10
[32073.499354]  ? __pfx_kthread+0x10/0x10
[32073.499356]  ret_from_fork+0x243/0x280
[32073.499358]  ? __pfx_kthread+0x10/0x10
[32073.499360]  ret_from_fork_asm+0x1a/0x30
[32073.499365]  </TASK>
[32073.499401] INFO: task kworker/u64:4:58582 is blocked on a mutex likely owned by task kworker/u64:0:63928.
[32073.499402] task:kworker/u64:0   state:R  running task     stack:0     pid:63928 tgid:63928 ppid:2      task_flags:0x4208060 flags:0x00080000
[32073.499406] Workqueue: vcn_unified_0 drm_sched_run_job_work [gpu_sched]
[32073.499409] Call Trace:
[32073.499410]  <TASK>
[32073.499412]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.499414]  ? __schedule+0x45f/0x1720
[32073.499417]  ? early_xen_iret_patch+0xc/0xc
[32073.499420]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.499422]  ? sysvec_apic_timer_interrupt+0xe/0x90
[32073.499424]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.499426]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[32073.499429]  ? __pfx_smu_v13_0_set_vcn_enable+0x10/0x10 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.499634]  ? amdgpu_device_rreg.part.0+0x38/0xf0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.499775]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.499777]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.499779]  ? delay_halt+0x3f/0x70
[32073.499781]  ? smu_cmn_send_smc_msg_with_param+0x141/0x490 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.499979]  ? smu_dpm_set_vcn_enable+0x7c/0xb0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.500176]  ? smu_dpm_set_power_gate+0x115/0x200 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.500371]  ? amdgpu_dpm_set_powergating_by_smu+0xfa/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.500585]  ? amdgpu_dpm_enable_vcn+0x20/0x50 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.500793]  ? vcn_v4_0_start+0x134/0x15f0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.500969]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.500971]  ? enable_work+0x3a/0x100
[32073.500973]  ? vcn_v4_0_set_pg_state+0x50/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.501143]  ? amdgpu_vcn_ring_begin_use+0x8b/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.501312]  ? amdgpu_ring_alloc+0x43/0x60 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.501461]  ? amdgpu_ib_schedule+0x10c/0x760 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.501612]  ? amdgpu_job_run+0x8b/0x1a0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32073.501797]  ? mod_delayed_work_on+0x9f/0xb0
[32073.501800]  ? drm_sched_run_job_work+0x1cb/0x3e0 [gpu_sched 792c5c85c7bb0dd50f45deef0512ade489308583]
[32073.501804]  ? process_one_work+0x193/0x350
[32073.501807]  ? worker_thread+0x1a1/0x310
[32073.501810]  ? __pfx_worker_thread+0x10/0x10
[32073.501812]  ? kthread+0xfc/0x240
[32073.501814]  ? __pfx_kthread+0x10/0x10
[32073.501816]  ? __pfx_kthread+0x10/0x10
[32073.501819]  ? ret_from_fork+0x243/0x280
[32073.501821]  ? __pfx_kthread+0x10/0x10
[32073.501823]  ? ret_from_fork_asm+0x1a/0x30
[32073.501827]  </TASK>
[32073.501831] INFO: task kworker/u65:9:63287 blocked for more than 368 seconds.
[32073.501833]       Not tainted 6.19.8-1-MANJARO #1
[32073.501834] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[32073.501835] task:kworker/u65:9   state:D stack:0     pid:63287 tgid:63287 ppid:2      task_flags:0x4208060 flags:0x00080000
[32073.501838] Workqueue: ttm ttm_bo_delayed_delete [ttm]
[32073.501843] Call Trace:
[32073.501845]  <TASK>
[32073.501847]  __schedule+0x457/0x1720
[32073.501850]  ? srso_alias_return_thunk+0x5/0xfbef5
[32073.501852]  ? update_load_avg+0x7b/0x740
[32073.501857]  schedule+0x27/0xd0
[32073.501859]  schedule_timeout+0xbd/0x100
[32073.501862]  dma_fence_default_wait+0x196/0x270
[32073.501866]  ? __pfx_dma_fence_default_wait_cb+0x10/0x10
[32073.501869]  dma_fence_wait_timeout+0xa2/0x150
[32073.501872]  dma_resv_wait_timeout+0xce/0x1d0
[32073.501875]  ttm_bo_delayed_delete+0x32/0x90 [ttm 64a8a8e673e5d2569262fc1eaf8a2a06a5cc4871]
[32073.501881]  process_one_work+0x193/0x350
[32073.501884]  worker_thread+0x1a1/0x310
[32073.501887]  ? __pfx_worker_thread+0x10/0x10
[32073.501889]  kthread+0xfc/0x240
[32073.501892]  ? __pfx_kthread+0x10/0x10
[32073.501894]  ? __pfx_kthread+0x10/0x10
[32073.501896]  ret_from_fork+0x243/0x280
[32073.501898]  ? __pfx_kthread+0x10/0x10
[32073.501900]  ret_from_fork_asm+0x1a/0x30
[32073.501904]  </TASK>
[32196.376704] INFO: task kworker/8:1H:276 blocked for more than 614 seconds.
[32196.376709]       Not tainted 6.19.8-1-MANJARO #1
[32196.376711] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[32196.376713] task:kworker/8:1H    state:D stack:0     pid:276   tgid:276   ppid:2      task_flags:0x4208060 flags:0x00080000
[32196.376718] Workqueue: events_highpri dm_irq_work_func [amdgpu]
[32196.442507] Call Trace:
[32196.442509]  <TASK>
[32196.442512]  __schedule+0x457/0x1720
[32196.442517]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.442523]  schedule+0x27/0xd0
[32196.442525]  schedule_preempt_disabled+0x15/0x30
[32196.442528]  __mutex_lock.constprop.0+0x527/0xa60
[32196.442533]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.442536]  handle_hpd_irq_helper+0x241/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.486405]  process_one_work+0x193/0x350
[32196.486412]  worker_thread+0x1a1/0x310
[32196.486415]  ? __pfx_worker_thread+0x10/0x10
[32196.486418]  kthread+0xfc/0x240
[32196.486421]  ? __pfx_kthread+0x10/0x10
[32196.486424]  ? __pfx_kthread+0x10/0x10
[32196.486429]  ret_from_fork+0x243/0x280
[32196.486433]  ? __pfx_kthread+0x10/0x10
[32196.486435]  ret_from_fork_asm+0x1a/0x30
[32196.486441]  </TASK>
[32196.486481] INFO: task kworker/8:1H:276 is blocked on a mutex likely owned by task kwin_wayland:1282.
[32196.486483] task:kwin_wayland    state:R  running task     stack:0     pid:1282  tgid:1282  ppid:1276   task_flags:0x400100 flags:0x00080800
[32196.486488] Call Trace:
[32196.486489]  <TASK>
[32196.486491]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.486494]  ? __schedule+0xf10/0x1720
[32196.486498]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.486500]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[32196.486504]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.486506]  ? sysvec_apic_timer_interrupt+0xe/0x90
[32196.486509]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.486511]  ? asm_sysvec_apic_timer_interrupt+0x1a/0x20
[32196.486516]  ? amdgpu_device_rreg.part.0+0x38/0xf0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.552218]  ? dm_read_reg_func+0x5c/0xe0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.596133]  ? delay_halt+0x3f/0x70
[32196.596141]  ? generic_reg_wait+0xaa/0x190 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.596450]  ? optc32_disable_crtc+0x159/0x170 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.596742]  ? dcn20_reset_back_end_for_pipe+0x1c9/0x330 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.597041]  ? dcn20_reset_hw_ctx_wrap+0xf0/0x150 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.597331]  ? dce110_apply_ctx_to_hw+0x66/0x2d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.597632]  ? dc_commit_state_no_check+0x709/0xed0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.597897]  ? dc_commit_streams+0x31b/0x520 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.598162]  ? amdgpu_dm_atomic_commit_tail+0x6b2/0x3900 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.598443]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.598447]  ? optc1_get_crtc_scanoutpos+0x75/0xb0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.598729]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.598732]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.598735]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.598737]  ? ktime_get+0x3b/0xd0
[32196.598741]  ? amdgpu_display_get_crtc_scanoutpos+0xa8/0x1d0 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.598931]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.598934]  ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.599129]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599131]  ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x1a6/0x3d0
[32196.599138]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599140]  ? wait_for_completion_timeout+0x109/0x150
[32196.599144]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599146]  ? drm_crtc_get_last_vbltimestamp+0x55/0x90
[32196.599151]  ? commit_tail+0xc1/0x150
[32196.599155]  ? drm_atomic_helper_commit+0x13c/0x180
[32196.599158]  ? drm_atomic_commit+0xb1/0xe0
[32196.599162]  ? __pfx___drm_printfn_info+0x10/0x10
[32196.599166]  ? drm_mode_atomic_ioctl+0xaae/0xd20
[32196.599172]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[32196.599174]  ? drm_ioctl_kernel+0xae/0x100
[32196.599179]  ? drm_ioctl+0x29b/0x520
[32196.599183]  ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[32196.599188]  ? amdgpu_drm_ioctl+0x4a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.599368]  ? __x64_sys_ioctl+0x97/0xe0
[32196.599373]  ? do_syscall_64+0x81/0x610
[32196.599376]  ? drm_ioctl+0x2d0/0x520
[32196.599379]  ? __pfx_drm_mode_createblob_ioctl+0x10/0x10
[32196.599385]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599387]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599390]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599392]  ? amdgpu_drm_ioctl+0x6a/0x80 [amdgpu 1e3db03648e47fa28df2f985a93a47859a3555d3]
[32196.599586]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599589]  ? __x64_sys_ioctl+0xb1/0xe0
[32196.599593]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599595]  ? do_syscall_64+0x81/0x610
[32196.599599]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599601]  ? do_syscall_64+0x81/0x610
[32196.599603]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599606]  ? switch_fpu_return+0x4e/0xd0
[32196.599610]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599612]  ? do_syscall_64+0x23b/0x610
[32196.599615]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599617]  ? do_syscall_64+0x81/0x610
[32196.599619]  ? srso_alias_return_thunk+0x5/0xfbef5
[32196.599622]  ? exc_page_fault+0x7e/0x1a0
[32196.599625]  ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
[32196.599630]  </TASK>
[32196.599632] Future hung task reports are suppressed, see sysctl kernel.hung_task_warnings
[32224.284412] INFO: NMI handler (perf_ibs_nmi_handler) took too long to run: 21.892 msecs
[32224.284422] perf: interrupt took too long (172237 > 2500), lowering kernel.perf_event_max_sample_rate to 1000
[34806.968782] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 150000 tries - optc32_disable_crtc line:195
[37003.540330] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 100000 tries - optc32_phantom_crtc_post_enable line:210
[37004.198433] amdgpu 0000:2f:00.0: amdgpu: SMU: response:0xFFFFFFFF for index:42 param:0x00000000 message:PowerUpVcn?
[37004.198438] amdgpu 0000:2f:00.0: amdgpu: Failed to power ungate VCN instance 0!
[37004.198449] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37004.198451] amdgpu 0000:2f:00.0: amdgpu: Failed to disable gfxoff!
[37004.198442] [drm:vcn_v4_0_start [amdgpu]] *ERROR* Dpm enable uvd failed, ret = -121.
[37005.647479] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 10us * 10 tries - mpc3_power_on_ogam_lut line:185
[37005.911020] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37005.911024] amdgpu 0000:2f:00.0: amdgpu: Failed to set workload mask 0x0000000b
[37005.911027] amdgpu 0000:2f:00.0: amdgpu: (-121) failed to enable video power profile mode
[37005.911044] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37005.911045] amdgpu 0000:2f:00.0: amdgpu: Failed to set workload mask 0x0000000b
[37005.911047] amdgpu 0000:2f:00.0: amdgpu: (-121) failed to enable video power profile mode
[37007.388792] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37007.388796] amdgpu 0000:2f:00.0: amdgpu: Failed to disable gfxoff!
[37023.991084] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37023.991089] amdgpu 0000:2f:00.0: amdgpu: Failed to disable gfxoff!
[37025.801442] amdgpu 0000:2f:00.0: amdgpu: SMU is in hanged state, failed to send smu message!
[37025.801447] amdgpu 0000:2f:00.0: amdgpu: Failed to disable gfxoff!
[37028.470902] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 1000 tries - dcn32_hubp_pg_control line:181
[37028.492852] amdgpu 0000:2f:00.0: amdgpu: Dumping IP State Completed
[37028.492902] amdgpu 0000:2f:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
[37028.492904] amdgpu 0000:2f:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
[37028.492907] amdgpu 0000:2f:00.0: amdgpu: ring vcn_unified_0 timeout, signaled seq=210158, emitted seq=210159
[37028.492909] amdgpu 0000:2f:00.0: amdgpu:  Process RDD Process pid 2736 thread browser 4 :cs0 pid 4827
[37028.492911] amdgpu 0000:2f:00.0: amdgpu: Starting vcn_unified_0 ring reset
[37031.322630] amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 10us * 10 tries - mpc3_power_on_ogam_lut line:185
[38920.387579] clocksource: timekeeping watchdog on CPU14: hpet wd-wd read-back delay of 21937494ns
[38920.387586] clocksource: wd-tsc-wd read-back delay of 21937564ns, clock-skew test skipped!
[38934.582417] amdgpu 0000:2f:00.0: amdgpu: Register(0) [regUVD_POWER_STATUS] failed to reach value 0x00000001 != 0x00000002n
Did you try with the 6.18 kernel? (It’s the recommended one.)
Hi @jofi I’ll try; but it will takes at least one week to be sure that the problem is solved.
Sitched to:
[mirto@bianco500 ~]$ uname -a
Linux bianco500 6.18.18-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri, 13 Mar 2026 18:47:36 +0000 x86_64 GNU/Linux
Hi @jofi
Well, after three nigth and days with the machine always u and leaved unattened all night and some 3 hour period during the day, the problem didn’ show up.
I think that the LTS kernel is the solution.
Thanks
