System Hard Freezing
Manjaro has been hard freezing for me about once a day for some time now. I don’t believe this is necessarily a Manjaro issue per se, but rather a Kernel / Mesa issue. Here are some details about my system…
  Kernel: 6.1.163-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=ffa85be7-68a2-43d4-a58f-a1e3c126eb4b rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.23.0
  Mobo: ASUSTeK model: ROG STRIX X870E-E GAMING WIFI v: Rev 1.xx
    Firmware: UEFI vendor: American Megatrends v: 1003 date: 01/17/2025
  Device-1: hidpp_battery_1 model: Logitech Wireless Keyboard K360
    status: discharging
  System RAM: total: 64 GiB available: 62.44 GiB used: 4.17 GiB (6.7%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 4800 MT/s actual: 3600 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CMH32GX5M2N6400C36 serial: N/A
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
  Device-3: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
    desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3000 min/max: 3000/5734 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 3000 2: 3000 3: 3000
    4: 3000 5: 3000 6: 3000 7: 3000 8: 3000 9: 3000 10: 3000 11: 3000 12: 3000
    13: 3000 14: 3000 15: 3000 16: 3000 17: 3000 18: 3000 19: 3000 20: 3000
    21: 3000 22: 3000 23: 3000 24: 3000 bogomips: 225258
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
    cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibpb_exit_to_user ibrs
    ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse
    mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save
    nx ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
    perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spec_rstack_overflow mitigation: safe RET
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3
    code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1
    bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 6400x3600 display-ID: 0
  Monitor-1: DP-1 pos: bottom-l model: HP P24q G4 serial: <filter>
    built: 2020 res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 123 gamma: 1.2
    chroma: red: x: 0.643 y: 0.329 green: x: 0.302 y: 0.616 blue: x: 0.149
    y: 0.059 white: x: 0.314 y: 0.329 size: 527x296mm (20.75x11.65")
    diag: 604mm (23.8") ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: DP-2 pos: top-right model: LG (GoldStar) HDR 4K
    serial: <filter> built: 2020 res: mode: 3840x2160 hz: 60 scale: 100% (1)
    dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green: x: 0.278
    y: 0.675 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 93 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
    navi31 LLVM 21.1.6 DRM 3.49 6.1.163-1-MANJARO) device-ID: 1002:744c
    memory: 19.53 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 25.3.5-arch1.1
    device-ID: 1002:744c surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
In this capture you’ll see I’m booted into kernel 6.1 as anything newer has the problem much worse.
This is likely related to this thread here…
https://forum.manjaro.org/t/system-freeze-amdgpu-flip-done-timed-out-after-switch-to-kernel-6-12/176608
Only thing that works when it freezes is holding the power button for 10 seconds to kill the machine.
If anyone knows a solution to this other than just waiting for the bugfix/patch, I’m all ears. I will be continuing scouring documentation and other solutions.
Thank you
I’d suggest using REISUB rather than the power button. Two advantages: less chance of data corruption and also it’s possible the journal might get written to before the computer restarts, so you may find some useful diagnostics there (though this isn’t 100% certain, I believe).
:point_down: Your inxi output is incomplete; please correct that:
inxi -zv8 (short-form)
Your privacy is respected
Can you also describe the conditions when these freezes occur? For example, is the machine under heavy load; Which application(s) are you running when the crash occurs; anything else that might possibly be worth mentioning?
If that’s the case, then you will have already seen here that there is a possible fix brewing in mailing list threads, which you could follow.
You might consider checking your UEFI/BIOS settings – improper configuration can potentially contribute to a crash; as can running low on swap space; perhaps check and re-seat your RAM modules and dGPU – but, if you have already ruled out the usual culprits, and you’re still convinced of the issue being the same as the topic you linked to, there may be little to be achieved here.
REISUB/REISUO links per suggestion by @beermad for safer shutdown:
Do i see Plasma 6.5? Have you updated your system?
Plasma 6.5.5 is what we have in the Stable branch at the moment. :wink:
Sorry, i thought it was 6.6. :folded_hands:
No, that’s still in the Unstable branch only right now. :wink:
Here is the complete result of inxi -zv8
    udev.log_priority=3
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
    status: discharging
  System RAM: total: 64 GiB available: 62.44 GiB used: 3.63 GiB (5.8%)
  Speed (MHz): avg: 4700 min/max: 3000/5734 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 4700 2: 4700 3: 4700
    4: 4700 5: 4700 6: 4700 7: 4700 8: 4700 9: 4700 10: 4700 11: 4700 12: 4700
    13: 4700 14: 4700 15: 4700 16: 4700 17: 4700 18: 4700 19: 4700 20: 4700
    21: 4700 22: 4700 23: 4700 24: 4700 bogomips: 225255
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: GN Netcom Jabra Link 380 driver: jabra,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.1:4
    chip-ID: 0b0e:24c7 class-ID: 0300 serial: <filter>
  Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:5
    chip-ID: 0b05:1b9b class-ID: 0300
  API: ALSA v: k6.1.163-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7927 802.11be 320MHz 2x2 PCIe Wireless Network Adapter
    [Filogic 380] vendor: Foxconn driver: N/A pcie: gen: 3 speed: 8 GT/s
    lanes: 1 bus-ID: 0d:00.0 chip-ID: 14c3:7927 class-ID: 0280
  Device-2: Realtek RTL8126 5GbE vendor: ASUSTeK driver: N/A pcie: gen: 3
    speed: 8 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0 chip-ID: 10ec:8126
    class-ID: 0200
  Device-3: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-5.2:5 chip-ID: 0b95:1790
    class-ID: 0a00 serial: <filter>
  IF: enp19s0u5u2c2 state: up speed: 1000 Mbps duplex: half mac: <filter>
  Info: services: mld, NetworkManager, systemd-timesyncd
  Device-1: TP-Link TP-Nmnk Bluetooth USB Adapter driver: btusb v: 0.8
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 9-2:2
    chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
  Local Storage: total: 14.39 TiB used: 2.99 TiB (20.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
    model: T-FORCE TM8FFL002T size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B speed: 126 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 050g050G temp: 49.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: TeamGroup model: TM8FFD002T
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: SN16486 temp: 34.9 C
    scheme: GPT
  ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: TeamGroup model: TM8FFD002T
    lanes: 4 tech: SSD serial: <filter> fw-rev: SN15772 temp: 38.9 C
    scheme: GPT
  ID-4: /dev/nvme3n1 maj-min: 259:5 vendor: TeamGroup model: TM8FFD002T
    scheme: GPT
  ID-5: /dev/nvme4n1 maj-min: 259:4 vendor: TeamGroup model: TM8FFD002T
    lanes: 4 tech: SSD serial: <filter> fw-rev: SN16486 temp: 35.9 C
    scheme: GPT
  ID-6: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD5001FZWX-00ZHUA0 size: 4.55 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: GPT
  ID-7: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-8: /dev/sdc maj-min: 8:32 model: USB DISK 3.0 size: 115.45 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP
    scheme: MBR
  Optical-1: /dev/sr0 vendor: PIONEER model: BD-RW BDR-S13U rev: 1.03
    dev-links: cdrom
  Features: speed: 125 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 766.82 GiB (41.8%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: ffa85be7-68a2-43d4-a58f-a1e3c126eb4b
    used: 5.5 MiB (1.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 2D82-58A1
  ID-3: /mnt/BigDrive raw-size: 4.55 TiB size: 4.55 TiB (100.00%)
    used: 2.24 TiB (49.4%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: BigDrive
    uuid: 12EC614DEC612C63
  ID-1: /dev/nvme1n1p1 maj-min: 259:16 size: 1024 MiB fs: vfat label: N/A
    uuid: 5016-4792
  ID-2: /dev/nvme1n1p2 maj-min: 259:17 size: 1.86 TiB fs: ext4
    label: endeavouros uuid: 07d492d1-09b2-4403-9904-8c93c26e676c
  ID-3: /dev/nvme2n1p1 maj-min: 259:7 size: 1022 MiB fs: vfat label: N/A
    uuid: ED62-488F
  ID-4: /dev/nvme2n1p2 maj-min: 259:8 size: 4 GiB fs: vfat label: N/A
    uuid: ED62-4974
  ID-5: /dev/nvme2n1p3 maj-min: 259:9 size: 1.85 TiB fs: ext4 label: N/A
    uuid: c1c4949f-d8a6-47eb-8460-8a970504f675
  ID-6: /dev/nvme2n1p4 maj-min: 259:10 size: 4 GiB fs: swap label: N/A
    uuid: d99b5b8c-650f-4ef4-83ed-44d9b4d14804
  ID-7: /dev/nvme3n1p1 maj-min: 259:13 size: 600 MiB fs: vfat label: N/A
    uuid: 6A12-7D23
  ID-8: /dev/nvme3n1p2 maj-min: 259:14 size: 2 GiB fs: ext4 label: N/A
    uuid: e01826d0-84dc-4d66-abda-91f4377fb4ae
  ID-9: /dev/nvme3n1p3 maj-min: 259:15 size: 1.86 TiB fs: btrfs
    label: fedora uuid: 7db43e45-1c91-4102-ad68-edf83f81d225
  ID-10: /dev/nvme4n1p1 maj-min: 259:11 size: 512 MiB fs: vfat label: N/A
    uuid: C395-BD88
  ID-11: /dev/nvme4n1p2 maj-min: 259:12 size: 1.86 TiB fs: ext4 label: N/A
    uuid: c61a5bb1-5c02-446c-90e0-fbc79a8a324f
  ID-12: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-13: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: ntfs
    label: System Reserved uuid: 8A9625029624F07D
  ID-14: /dev/sdb2 maj-min: 8:18 size: 465.14 GiB fs: ntfs label: N/A
    uuid: 9A8A26AA8A2682BD
  ID-15: /dev/sdb3 maj-min: 8:19 size: 531 MiB fs: ntfs label: N/A
    uuid: E874D77074D7404C
  ID-16: /dev/sdc1 maj-min: 8:33 size: 115.42 GiB fs: exfat label: Ventoy
    uuid: 31CE-AB75
  ID-17: /dev/sdc2 maj-min: 8:34 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: 223C-F3F8
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-2:2 info: Cambridge Silicon Radio Mpow HC5 Headset in charging
    mode - USB Hub ports: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 0a12:4010 class-ID: 0900
  Device-1: 1-2.1:4 info: GN Netcom Jabra Link 380 type: audio,HID
    driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0b0e:24c7
  Device-2: 1-3:3 info: Shenzhen Riitek Mouse type: mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1997:2452 class-ID: 0301
  Hub-3: 1-4:5 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-4.2:6 info: Logitech Logi Bolt Receiver
    type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 98mA chip-ID: 046d:c548 class-ID: 0300
  Device-2: 1-4.3:7 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-3: 1-4.4:8 info: MosArt USB 2.4G Keyboard type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:38b3 class-ID: 0301
  Hub-4: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-5: 2-4:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Dell RT7D50 Keyboard type: keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 413c:2005 class-ID: 0301
  Hub-7: 3-4:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Hub-8: 3-5:4 info: ASMedia ASMT2307 ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 174c:2174
  Device-1: 3-6:5 info: ASUSTek USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-2: 3-7:6 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1aa6 class-ID: 0300
    serial: <filter>
  Device-3: 3-12:7 info: NZXT Kraken Elite type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 1e71:300c class-ID: 0300 serial: <filter>
  Hub-9: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-10: 4-4:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-11: 4-5:3 info: ASMedia ASMT2307 ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 174c:3174
  Device-1: 4-5.1:4 info: Phison USB DISK 3.0 type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 504mA chip-ID: 13fe:6700 class-ID: 0806
    serial: <filter>
  Device-2: 4-5.2:5 info: ASIX AX88179 Gigabit Ethernet
    type: communication,CDC-data driver: cdc_ncm interfaces: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 184mA
    chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
  Hub-12: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-13: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-14: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-15: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-16: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 9-2:2 info: TP-Link TP-Nmnk Bluetooth USB Adapter
    type: bluetooth driver: btusb interfaces: 2 rev: 1.1
  Hub-17: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-18: 11-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-19: 12-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 48.9 C mobo: N/A gpu: amdgpu temp: 48.0 C
    mem: 56.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 2147 pm: pacman pkgs: 2095 libs: 539 tools: pamac,yay pm: flatpak
    pkgs: 52
    1: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    4: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    5: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    6: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    7: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    8: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 427
  1: cpu: 3.3% command: firefox pid: 3525 mem: 593.7 MiB (0.9%)
  2: cpu: 2.5% command: kwin_wayland pid: 1462 mem: 274.8 MiB (0.4%)
  3: cpu: 1.6% command: konsole pid: 5072 mem: 235.1 MiB (0.3%)
  4: cpu: 1.4% command: firefox pid: 4131 mem: 314.0 MiB (0.4%)
  5: cpu: 0.8% command: zsh pid: 5094 mem: 8.87 MiB (0.0%)
  Memory top: 5 of 427
  1: mem: 593.7 MiB (0.9%) command: firefox pid: 3525 cpu: 3.3%
  2: mem: 461.1 MiB (0.7%) command: plasmashell pid: 1703 cpu: 0.7%
  3: mem: 314.0 MiB (0.4%) command: firefox pid: 4131 cpu: 1.4%
  4: mem: 285.2 MiB (0.4%) command: firefox pid: 4124 cpu: 0.3%
  5: mem: 274.8 MiB (0.4%) command: kwin_wayland pid: 1462 cpu: 2.5%
  Processes: 427 Power: uptime: 11m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.95 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.9 running-in: konsole inxi: 3.3.40
The freezes happen mostly when watching a Youtube video either in Firefox, Brave, or FreeTube.
I also have run the machine over night without any applications running (other than the KDE Plasma desktop environment, but no applications) and have found the machine frozen when I use it in the morning.
Holy cow! Thank you for the REISUB procedure. I continue to be amazed by 2 things…
  1. Linux (try gracefully rebooting a blue screened Windows machine [which i no longer use BTW])
  2. You people!!! (the knowledge and willingness to help is absolutely humbling)
It took me a little bit to figure it out, but now I almost can’t wait for the next freeze! :rofl:
Thank you to all who replied!!! You folks are just the best.
Just a suggestion: it might be an idea to set up swap as that may alleviate future issues.
Once the system runs out of RAM and has no-where else to store it, it has to dump stuff. This can lead to the system locking up, depending on what processes are affected. :wink:
One example of setting up swap:
… although, personally, I prefer to set up a swap partition.
Why are you using such an old kernel?
You may have missed this:
Though, from a troubleshooting perspective, it does make better sense to be on the latest LTS kernel, where possible.
I missed the most obvious thing too. But I had all this typed!
So if the problem still exists after you move to a supported kernel..
The most useful information is the logs leading up to the freeze. That makes this much easier to track down, since you can filter logs by each boot.
To see your boot IDs, type:
journalctl --list-boots
Boot ID 0 is your current session, still logging entries until you shutdown (or it freezes). If it froze the last time you started your computer, then the boot ID would be -1.
If you remember roughly when it froze, you can find the corresponding boot ID. The --list-boots output shows when each boot started and when the last log entry occurred, so it should be fairly easy to identify.
Once you find that boot ID, use it in the following command (using -1 as an example):
journalctl --boot=-1
# or journalctl -b -1
That will show logs starting from boot. To find where it froze, it’s easier to view them in reverse.
So once you’ve identified where it froze, use something like this (we may as well include more detail by allowing up to INFO level entries):
Also, when copy/pasting (or piping) from journalctl, make sure to use the --no-pager option. (When viewing logs, omit it.)
journalctl --boot=-1 --reverse --priority 6 --no-pager
# journalctl -b -1 -r -p6 --no-pager
Find where the freeze occurs, then paste the logs leading up to it. They’re timestamped, so include everything around that time and post it here.
I was able to boot into a live USB, resize my root partition to make room for a swap partition. I did a 48GB swap since I have 64GB RAM and I don’t hibernate this machine.
Here is the result of “free -h”
               total        used        free      shared  buff/cache   available
Mem:            62Gi       3.3Gi        57Gi       113Mi       1.9Gi        59Gi
Swap:           47Mi          0B        47Mi
I will resume running the latest Kernel (6.19 or 6.18 LTS) and see if any improvements.
Also, thank you to Molski for the instructions on reviewing logs. I will do that if it freezes again (after doing the REISUB procedure to gracefully shutdown a frozen system). Dang! I love learning.
Thank you to all. Will keep you posted.
This is a 47MB swap. :face_with_peeking_eye:
Stickler for detail! I like it. :grinning_face:
I’m not sure if we’re on the same page or not.
You have a 0.047GB swap.
Normal recommendation would be something in between. I think 4 or 8 GB should be fine without hibernation.
@oe36
Your defined swap space is so ridiculously small that it serves no purpose whatsoever – it is only 47 MiB – you might think it’s sized in the GigaByte range, but it is not, as your own system shows above.
It is virtually without much doubt that this fact contributes toward your system crashing, especially, if you have it set to sleep/hibernate; Hibernation requires sufficient swap space to hold whatever data is in RAM. To avoid this, you might need to choose another :Suspend To RAM (STR) sleep state, rather than hibernation. Even with 64 GiB of RAM, a functional amount of swap space – whether it be a swap partition or a swap file – is still generally recommended.
47 MiB would be barely enough to hold my favourite ebooks. :wink:
I used to have a similar problem with my setup, I had swap set to 6 GB as is recommended for my 32 GB of ram in my system without hibernation as I never use it.
The problem was that every time my system went to sleep it was a coin flip if it would freeze or sleep as anyone would expect. The solution was to allocate 38 GB for swap even if I don’t use hibernation.
I’m telling this because if your problem is the same as mine 48 GB of swap might not be enough for your 64 GB of ram.
And 47 MiB certainly isn’t.
Informational
For hibernation, the recommendation is to have a swap partition (preferred) sized at least equal to system RAM – for 64 GiB RAM, 65 GiB of swap would be ideal.
Without hibernation, less space needs to be reserved for swap, however, the general recommendation is half of the above but can be adjusted according to individual needs.
Hibernation and swap allocation can be defined via Calamares during Manjaro installation, though many new(er) users seem to have difficulty understanding the option, and ignore it, which can often lead to inconveniences later.
