System Hangs Rebooting After Weekly Update 9/29
After installing the updates pushed this week, my system hangs with a blank screen and the cursor visible when rebooting or shutting down. Was able to revert the update using Timeshift and things are back to normal. Attempted the updates a 2nd time and got the same problem. Wanted to see if anyone may know how to resolve this problem with the updates pushed this week.
  Kernel: 6.6.47-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=a3eff9f7-3e26-4eeb-aff5-39f26dca0ceb rw udev.log_priority=3
    amd_pstate.shared_mem=1 amd_pstate=passive
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Mobo: ASUSTeK model: ROG STRIX B550-E GAMING v: Rev X.0x
    UEFI: American Megatrends v: 3002 date: 02/23/2023
  System RAM: total: 16 GiB available: 15.52 GiB used: 6.5 GiB (41.9%)
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: G-Skill
    part-no: F4-3600C16-8GTZR serial: N/A
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
    smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
    desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 882 min/max: 550/5274 boost: enabled scaling:
    driver: amd-pstate governor: schedutil cores: 1: 882 2: 882 3: 882 4: 882
    5: 882 6: 882 7: 882 8: 882 9: 882 10: 882 11: 882 12: 882 13: 882 14: 882
    15: 882 16: 882 17: 882 18: 882 19: 882 20: 882 21: 882 22: 882 23: 882
    24: 882 25: 882 26: 882 27: 882 28: 882 29: 882 30: 882 31: 882 32: 882
    bogomips: 217717
    xsaves
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900M] vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel arch: RDNA-3
    code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1
    bus-ID: 0a:00.0 chip-ID: 1002:744c class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: VG278
    serial: <filter> built: 2019 res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red:
    x: 0.651 y: 0.333 green: x: 0.325 y: 0.620 blue: x: 0.153 y: 0.055 white:
    x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23") diag: 686mm (27")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: Dell P2422H
    serial: <filter> built: 2023 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
    chroma: red: x: 0.671 y: 0.325 green: x: 0.310 y: 0.616 blue: x: 0.145
    y: 0.063 white: x: 0.314 y: 0.329 size: 527x296mm (20.75x11.65")
    diag: 604mm (23.8") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600,
    640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi
    navi31 LLVM 18.1.8 DRM 3.54 6.6.47-1-MANJARO) device-ID: 1002:744c
    memory: 23.44 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.6-arch1.1
    device-ID: 1002:744c surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 0a:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Cambridge Silicon Radio Audioengine 2+
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-4.1:5 chip-ID: 0a12:4006 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.6.47-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 3.18 TiB used: 1.19 TiB (37.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 33.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
    model: WD BLACK SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 711250WD temp: 31.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD Blue SA510 2.5 500GB size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 6100
    scheme: GPT
  ID-1: / raw-size: 73.24 GiB size: 71.54 GiB (97.68%) used: 29.78 GiB (41.6%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: a3eff9f7-3e26-4eeb-aff5-39f26dca0ceb
    used: 27 MiB (9.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 934E-457C
  ID-3: /home raw-size: 1.74 TiB size: 1.71 TiB (98.37%)
    used: 980.83 GiB (56.0%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: home uuid: 36fd63c4-d6bf-4fad-aed1-d188ed64b0e7
  ID-4: /mnt/nvme1n1p1 raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 206.79 GiB (22.6%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:6
    label: N/A uuid: e748f75c-4736-4d3a-af9a-52732a502021
  ID-1: swap-1 type: partition size: 8.8 GiB used: 14 MiB (0.2%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 1e4c35d5-3930-440d-858d-8f8ab918d63a
  ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 465.75 GiB fs: ntfs label: N/A
    uuid: 347A9A3A7A99F8B6
  Device-1: 1-5:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-3: 1-9:5 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 3-1:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Device-1: 3-1.1:4 info: Corsair HARPOON RGB PRO Gaming Mouse
    type: mouse,HID driver: usbfs interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 1b1c:1b75 class-ID: 0300 serial: <filter>
  Device-2: 3-1.3:6 info: Jing-Mold Enterprise USB Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 05af:8277 class-ID: 0301
  Hub-7: 3-4:3 info: Cambridge Silicon Radio Mpow HC5 Headset in charging
    mode - USB Hub ports: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0a12:4010 class-ID: 0900
  Device-1: 3-4.1:5 info: Cambridge Silicon Radio Audioengine 2+
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:4006
  Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-9: 4-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
  System Temperatures: cpu: 35.0 C mobo: 29.0 C gpu: amdgpu temp: 34.0 C
    mem: 48.0 C
  Fan Speeds (rpm): cpu: 851 gpu: amdgpu fan: 1
  Packages: 1617 pm: pacman pkgs: 1605 libs: 497 tools: pamac pm: flatpak
    pkgs: 12
Processes:
  CPU top: 5 of 569
  1: cpu: 19.7% command: C:\Program pid: 2602 mem: 406.9 MiB (2.5%)
  2: cpu: 18.3% command: wineserver pid: 2420 mem: 17.0 MiB (0.1%)
  3: cpu: 16.1% command: chrome pid: 3363 mem: 295.3 MiB (1.8%)
  4: cpu: 14.4% command: konsole pid: 4287 mem: 195.3 MiB (1.2%)
  5: cpu: 13.1% command: zsh pid: 4319 mem: 8.10 MiB (0.0%)
  Memory top: 5 of 569
  1: mem: 1081.6 MiB (6.8%) command: pamac-manager pid: 3956 cpu: 2.0%
  2: mem: 413.7 MiB (2.6%) command: plasmashell pid: 1327 cpu: 2.6%
  3: mem: 406.9 MiB (2.5%) command: C:\Program pid: 2602 cpu: 19.7%
  4: mem: 380.9 MiB (2.3%) command: chrome pid: 2426 cpu: 9.8%
  5: mem: 377.7 MiB (2.3%) command: C:\Program pid: 3453 cpu: 1.7%
  Processes: 569 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.32 running-in: konsole inxi: 3.3.36
Did you miss any of the half dozen other threads? Or are they unrelated?
TY! Will try this out and report back
This resolved my problem. Thank you for helping me.
