Hi!
A few weeks ago, I noticed that my system isn’t working as expected after a full upgrade.
I have some micro-hangs without any error/warning message.
I suspect it’s related to the windows manager only, because If I have music in background, I still hear it while the system is unresponsive.
I share some hardware details, but maybe you need something else.
I’ve already tried what it’s suggested in the related post “My system is hanging intermittently” but no success.
Thank you.
OS: Manjaro Linux x86_64
Host: G5 5505 1.14.0
Kernel: 5.15.114-2-MANJARO
Uptime: 2 hours, 9 mins
Packages: 1981 (pacman), 8 (flatpak), 7 (snap)
Shell: zsh 5.9
Resolution: 1920x1080
DE: GNOME 44.1
WM: Mutter
WM Theme: CustomAccentColors
Theme: Adwaita-maia-compact [GTK2/3]
Icons: Papirus-Dark-Maia [GTK2/3]
Terminal: gnome-terminal
CPU: AMD Ryzen 5 4600H with Radeon Graphics (12) @ 3.000GHz
GPU: AMD ATI 08:00.0 Renoir
GPU: AMD ATI Radeon RX 5600 OEM/5600 XT / 5700/5700 XT
Memory: 4085MiB / 63671MiB
Host: Kernel: 5.15.114-2-MANJARO arch: x86_64 bits: 64
Desktop: GNOME v: 44.1 Distro: Manjaro Linux
Type: Laptop System: Dell product: G5 5505 v: 1.14.0
Info: 6-core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
driver: amdgpu v: kernel
Device-2: AMD Renoir driver: amdgpu v: kernel
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1 driver: X:
loaded: amdgpu unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
resolution: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.42 5.15.114-2-MANJARO)
There was recently problems with kernels 6+, amd, and mesa …
But I see you are using 5.15 …
Lets just see what update says:
sudo pacman -Syu
That was fast !
The system is fully upgraded.
When I first noticed this behavior, I started to check for updates almost every day just in case a new fix was available.
These are the only packages suggested to upgrade today
brave-browser-1.52.130-1 libpamac-11.5.5-2
libpamac-flatpak-plugin-11.5.5-1 libpamac-snap-plugin-11.5.5-1
But what is the output of the command?
(please use pacman as typed, not pamac)
Some packages were rolled back recently.
Ok.
This is the result
$ sudo pacman -Syu
:: Sincronizando las bases de datos de los paquetes...
core está actualizado
extra está actualizado
community está actualizado
multilib está actualizado
:: Iniciando actualización completa del sistema...
advertencia: manjaro-hello: la versión instalada (0.7.0-6) es más nueva que extra (0.7.0-5)
...el sistema ya está actualizado.
OK … what I said sorta applies to hello … but its not the source of your problem.
(you can fix it by pointing at it: sudo pacman -Syu manjaro-hello)
Can you please give a full inxi:
inxi -Fazy
I did the trick with manjaro-hello to avoid the message, thank you.
This is the full output
$ inxi -Fazy [18:43:12]
Kernel: 5.15.114-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=f326045c-416b-4bac-aa3f-2b6b2c00bd39 rw quiet apparmor=1
security=apparmor udev.log_priority=3 radeon.si_support=0
amdgpu.si_support=1 amdgpu.ppfeaturemask=0xffffffff amdgpu.runpm=1
amdgpu.dpm=1 ec_sys.write_support=1
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
serial: <superuser required> Chassis: type: 10 v: 1.14.0
Mobo: Dell model: 0DM13D v: A00 serial: <superuser required> UEFI: Dell
v: 1.14.0 date: 11/30/2022
ID-1: BAT0 charge: 39.7 Wh (100.0%) condition: 39.7/51.0 Wh (77.9%)
volts: 12.5 min: 11.4 model: SMP-ATL4.49 DELL PN1VN06 type: Li-poly
serial: <filter> status: full
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2070 high: 2946 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1739 2: 2232
3: 1718 4: 1886 5: 2492 6: 2666 7: 1552 8: 1633 9: 1753 10: 1659 11: 2946
12: 2574 bogomips: 71901
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
vendor: Dell driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:731f
class-ID: 0380
Device-2: AMD Renoir vendor: Dell driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-2
bus-ID: 08:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 62.0 C
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 0c45:671f
class-ID: 0e02
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0035 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
15.0.7 DRM 3.42 5.15.114-2-MANJARO) direct-render: Yes
Device-1: AMD Navi 10 HDMI Audio vendor: Dell driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Dell
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 08:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k5.15.114-2-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off with: a2jmidid status: off
tools: cadence,jack_control,qjackctl
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3.1:4 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 1.14 TiB used: 729.48 GiB (62.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 11004101 temp: 54.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211210WD temp: 47.9 C scheme: MBR
ID-1: / raw-size: 195.36 GiB size: 191.24 GiB (97.89%)
used: 126.31 GiB (66.1%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 150 MiB size: 146 MiB (97.33%)
used: 93 MiB (63.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 59.0 C mobo: 43.0 C
Fan Speeds (RPM): cpu: 1959
GPU: device: amdgpu temp: 62.0 C device: amdgpu temp: 61.0 C mem: 64.0 C
fan: 65535 watts: 12.00
Processes: 386 Uptime: 4h 19m wakeups: 2 Memory: available: 62.18 GiB
used: 5.05 GiB (8.1%) Init: systemd v: 253 default: graphical tool: systemctl
Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1996 pm: pacman pkgs: 1981
libs: 510 tools: gnome-software,octopi,pamac,yay pm: flatpak pkgs: 8 pm: snap
pkgs: 7 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
I’m rather doubtful any of these things are the culprit, but I’ll mention them nonetheless
You may want to create some SWAP.
Heres a quick guide for a swapfile:
A rule used to be ‘equal to RAM’ … though that is really only necessary if you want to use hibernation.
If you use something like systemd-swap it will just make some on the fly as needed.
If you want a set size … you might make use of a swapfile … that way you dont need to mess with partitions. Heres an example … (we will go with 8 gigs, edit as you like):
To start we will create the file at a proper place:
cd / && sudo dd if=/dev/zero of=/swapfile bs=1M count=8192 status=progress
Then we s…
I think you have BIOS updates.
I’ll try the BIOS update and I’ll come back with the results!
But about the SWAP, I think it isn’t required having 64GB of RAM. Or maybe I’m wrong?
cscs
9 July 2023 22:05
11
Ostensibly it shoudnt really be needed if you never reach the limit of your memory … but with software like gnome its possible it expects it in some way.
Hi again and thank you for the support.
I’ve created a small 4GB Swap just in case, and updated the BIOS to 1.16.0.
But today I still experience these small hangs.
What else could be causing this issue?
After disabling some Gnome extensions, the problem got solved (climate, etc.).
I found it because gnome-shell was consuming too much RAM.
Thank you.
system
Closed
21 August 2023 16:14
14
