System hangs in different situations after update
Hi.
As of this week my Manjaro OS is hanging in different moments. I think it’s related to some of the many updates I’ve ran last week since I was able to recover a snapshot from early march that seem to have solved my issues but they started again after I applied the recommended updates again.
The issues includes:
  • Sudo commands take several minutes to show me the prompt asking for password
  • System settings app doesn’t open / stops responding
  • Mounting storage devices take a long time (several minutes)
  • After the screen locks I’m unable to log back in. I’m able to type my password and it show the processing circle spinning like it’s processing, but it doesn’t unlock the screen, and if I click over the password it asks me for the password once more.
  • I’m unable to access TTY terminals. If I press the shortcuts I get a black screen and never get the prompt to login. And I’m unable to change back to Gnome’s login screen, so I have to hard reset.
  • Restart takes a couple of minutes after I press the restart button to show me the window asking me if I’m sure I want to restart the system.
This is the output of inxi -zv8:
  Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=ed3a5eec-a541-4bbc-9f12-089d4d259970 rw quiet
    cryptdevice=UUID=4b8eb405-1a13-4110-88a5-77f1ff474311:luks-4b8eb405-1a13-4110-88a5-77f1ff474311
    root=/dev/mapper/luks-4b8eb405-1a13-4110-88a5-77f1ff474311 splash
    apparmor=1 security=apparmor
    resume=/dev/mapper/luks-1c5f41b2-171c-43ea-bbce-393055ba5466
    udev.log_priority=3
  Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
    tools: gsd-screensaver-proxy avail: lxlock dm: GDM v: 48.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASRock model: A620M-HDV/M.2 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: 2.10
    date: 03/20/2024
  System RAM: total: 64 GiB available: 61.92 GiB used: 4.39 GiB (7.1%)
  Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 32 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF552C40-32 serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
  Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
    desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 5337 min/max: 400/5733 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 5337 2: 5337 3: 5337
    4: 5337 5: 5337 6: 5337 7: 5337 8: 5337 9: 5337 10: 5337 11: 5337 12: 5337
    13: 5337 14: 5337 15: 5337 16: 5337 17: 5337 18: 5337 19: 5337 20: 5337
    21: 5337 22: 5337 23: 5337 24: 5337 bogomips: 225285
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
    cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
    x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: Gigabyte driver: nvidia
    v: 570.133.07 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
    status: current (as of 2025-01) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    ports: active: none off: HDMI-A-3 empty: DP-4,DP-5,HDMI-A-2
    bus-ID: 01:00.0 chip-ID: 10de:2882 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASRock
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1 bus-ID: 0e:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 52.0 C
  Device-3: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
    chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: nvidia,nvidia-nvswitch display-ID: :0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: HDMI-A-3 model: Samsung LU28R55 serial: <filter> built: 2024
    res: 3840x2160 dpi: 154 gamma: 1.2 chroma: red: x: 0.678 y: 0.314 green:
    x: 0.267 y: 0.620 blue: x: 0.145 y: 0.059 white: x: 0.314 y: 0.329
    size: 632x360mm (24.88x14.17") diag: 727mm (28.6") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
    memory: 7.81 GiB
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop
  Device-1: NVIDIA AD107 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:1640 class-ID: 0403
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0e:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp7s0 state: down mac: <filter>
  Device-2: TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano]
    driver: rtl8821au type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-9:3 chip-ID: 2357:011e class-ID: 0000 serial: <filter>
  IF: wlp11s0u9 state: up mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: luks-8b006311-8a63-42c6-afcf-b4ae4d131151 maj-min: 254:2
    type: LUKS dm: dm-2 size: 2.73 TiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 2.73 TiB
  Device-2: luks-4b8eb405-1a13-4110-88a5-77f1ff474311 maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.8 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.8 TiB
  Device-3: luks-1c5f41b2-171c-43ea-bbce-393055ba5466 maj-min: 254:1
    type: LUKS dm: dm-1 size: 68.11 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 68.11 GiB
  Local Storage: total: 4.59 TiB used: 2.24 TiB (48.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
    model: XPG GAMMIX S70 BLADE size: 1.86 TiB block-size: physical: 512 B
    fw-rev: 3.2.J.JE temp: 51.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000VX015-3CV10G
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: CV10 scheme: GPT
  ID-1: / raw-size: 1.8 TiB size: 1.77 TiB (98.37%) used: 347.29 GiB (19.2%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-4b8eb405-1a13-4110-88a5-77f1ff474311 label: N/A
    uuid: ed3a5eec-a541-4bbc-9f12-089d4d259970
    used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 8462-668E
  ID-3: /mnt/hdinterno01 raw-size: 2.73 TiB size: 2.69 TiB (98.39%)
    used: 1.9 TiB (70.8%) fs: ext4 dev: /dev/dm-2 maj-min: 254:2
    mapped: luks-8b006311-8a63-42c6-afcf-b4ae4d131151 label: HD Interno 1
    uuid: 76efe9ad-8f12-45da-921b-5d8e62e5dfb8
  ID-1: swap-1 type: partition size: 68.11 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-1c5f41b2-171c-43ea-bbce-393055ba5466 label: swap
    uuid: fb220f77-a209-4304-aaf4-ec12a341b2ce
  Device-1: 1-5:2 info: Logitech G403 HERO Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08f class-ID: 0300
    serial: <filter>
  Device-2: 1-9:3 info: TP-Link AC600 wireless Realtek RTL8811AU [Archer
    T2U Nano] type: Network driver: rtl8821au interfaces: 1 rev: 2.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 5-1:2 info: Microdia Webcam Vitade AF type: video,audio
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 7-1:2 info: SiGma Micro Keyboard TRACER Gamma Ivory
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1c4f:0002 class-ID: 0300
  Hub-8: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 75.2 C mobo: 41.8 C
  Fan Speeds (rpm): N/A
  GPU: device: nvidia screen: :0.0 temp: 41 C fan: 0% device: amdgpu
    temp: 52.0 C
  Packages: pm: pacman pkgs: 1490 libs: 385 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    3: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    4: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    6: https://mirror.23m.com/manjaro/stable/$repo/$arch
    7: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    8: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 515
  1: cpu: 92.3% command: @lymouthd pid: 420 mem: 15.4 MiB (0.0%)
  2: cpu: 17.7% command: kdenlive pid: 3340 mem: 1266.2 MiB (1.9%)
  3: cpu: 6.9% command: gnome-shell pid: 2125 mem: 404.6 MiB (0.6%)
  4: cpu: 5.6% command: exe pid: 3869 mem: 414.0 MiB (0.6%)
  5: cpu: 4.4% command: Xorg pid: 2028 mem: 234.0 MiB (0.3%)
  Memory top: 5 of 515
  1: mem: 1266.2 MiB (1.9%) command: kdenlive pid: 3340 cpu: 17.7%
  2: mem: 414.0 MiB (0.6%) command: exe pid: 3869 cpu: 5.6%
  3: mem: 404.6 MiB (0.6%) command: gnome-shell pid: 2125 cpu: 6.9%
  4: mem: 382.4 MiB (0.6%) command: signal-desktop pid: 3760 cpu: 4.4%
  5: mem: 253.4 MiB (0.3%) command: manjaro-hello started-by: python3
    pid: 2366 cpu: 0.9%
  Processes: 515 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.73 GiB services: gsd-power,upowerd
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: gnome-terminal
    inxi: 3.3.37
This is the output of journalctl --boot=-1 --priority=3 --catalog --no-pager
abr 02 08:03:11 xxxx-a620mhdvm2 kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
abr 02 08:03:12 xxxx-a620mhdvm2 kernel:
abr 02 08:03:12 xxxx-a620mhdvm2 kernel: usb 5-1: 3:1: cannot get freq at ep 0x84
abr 02 08:03:40 xxxx-a620mhdvm2 wpa_supplicant[1402]: bgscan simple: Failed to enable signal strength monitoring
abr 02 08:03:47 xxxx-a620mhdvm2 kernel: usb 5-1: 3:1: cannot get freq at ep 0x84
abr 02 08:04:31 xxxx-a620mhdvm2 gdm-password][2002]: gkr-pam: unable to locate daemon control file
abr 02 08:04:33 xxxx-a620mhdvm2 systemd[2013]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A unidade UNIT falhou
░░ Defined-By: systemd
░░ A unidade UNIT falhou.
░░ O resultado é failed.
abr 02 08:04:34 xxxx-a620mhdvm2 systemd[2013]: Failed to start Application launched by gnome-session-binary.
abr 02 08:50:04 xxxx-a620mhdvm2 systemd-logind[1310]: Failed to get load state of suspend.target: Connection timed out
abr 02 08:50:29 xxxx-a620mhdvm2 systemd-logind[1310]: Failed to get load state of poweroff.target: Connection timed out
abr 02 08:50:54 xxxx-a620mhdvm2 systemd-logind[1310]: Failed to get load state of reboot.target: Connection timed out
How do I solve this?
I’m pretty new to Manjaro so please let me know if I should provide more information and how to obtain it. Thanks!
UPDATE 1: I notice the issues aren’t happening as soon as I reboot the system, but they start after a couple of minutes.
Your inxi output is incomplete.
Please edit your previous post and try again.
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Thanks, I edited it. I was able to get the full output of inxi after rebooting the system. The command was hanging also always on the same place.
I’m not sure what you mean by “actionable information”. Sorry, English is not my first language. I tried to provide what I’m trying to do when the system hangs.
Actionable information is information that others can work with; useful information; rather than simply indicating there’s a problem.
The inxi command asks your system directly for information that can help others to discover issues that might contribute to an issue; it also helps to quickly see details without having to ask a lot of questions.
All this is what’s meant by actionable - it’s information that we can do something with. :mag_right:
That information posted was partially pre-prepared and directed mainly toward newer users who might not be familiar with how to ask for support. Often there might be much more posted with it, but only the system information portion was important in your case.
You have made a reasonable attempt to describe your issue. There are many newer members that only write one or two lines, leaving everyone guessing what their problem is.
Most of us don’t have a crystal ball :crystal_ball: :smile_cat:
Thank you for including the full inxi output.
From what I can see, there’s nothing obvious that might be contributing to your issue. I suspect it might be related to the Nvidia driver, as several have experienced similar issues, though, this is only conjecture.
For now, please provide output from the following commands which may also be useful for those who might wish to help.
cat /etc/fstab
…and…
fsblk -f
This portion of your provided logs seems to indicate a likely problem. @linux-aarhus
Quick tip:
If you prefix commands with LC_ALL=C, this will enable command output in English;
for example, if you were performing an update:
LC_ALL=C sudo pacman -Syu
I’m sure someone will help when they are able.
Thanks for your patience and will to help.
Here’s the output of cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=8462-668E                            /boot/efi      vfat    defaults,umask=0077 0 2
/dev/mapper/luks-4b8eb405-1a13-4110-88a5-77f1ff474311 /              ext4    defaults   0 1
/dev/mapper/luks-1c5f41b2-171c-43ea-bbce-393055ba5466 swap           swap    defaults   0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
/dev/disk/by-uuid/76efe9ad-8f12-45da-921b-5d8e62e5dfb8 /mnt/hdinterno01 auto nosuid,nodev,nofail,x-gvfs-show 0 0
And this is the output for lsblk -f:
NAME                            FSTYPE    FSVER LABEL        UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda
└─sda1                          crypto_LU 2                  8b006311-8a63-42c6-afcf-b4ae4d131151
  └─luks-8b006311-8a63-42c6-afcf-b4ae4d131151
                                ext4      1.0   HD Interno 1 76efe9ad-8f12-45da-921b-5d8e62e5dfb8    663G    71% /mnt/hdinterno01
nvme0n1
├─nvme0n1p1                     vfat      FAT32              8462-668E                               299M     0% /boot/efi
├─nvme0n1p2                     crypto_LU 1                  4b8eb405-1a13-4110-88a5-77f1ff474311
│ └─luks-4b8eb405-1a13-4110-88a5-77f1ff474311
│                               ext4      1.0                ed3a5eec-a541-4bbc-9f12-089d4d259970    1,3T    19% /
└─nvme0n1p3                     crypto_LU 1                  1c5f41b2-171c-43ea-bbce-393055ba5466
  └─luks-1c5f41b2-171c-43ea-bbce-393055ba5466
                                swap      1     swap         fb220f77-a209-4304-aaf4-ec12a341b2ce                [SWAP]
I don’t know if this info might help diagnosing the problem but I found out that I don’t face the same issue if I use su instead of sudo.
Well, I found out it’s definetely related to the NVidia driver.
The issues disappeared when I removed linux612-nvidia package and started using video-linux instead and they reappeared when I reinstalled it. The problems are also present with linux612-nvidia-open.
I know what is causing, but I have no solution yet since I need those drivers to use some apps like Kdenlive.
A temporary fix: I restored a snapshot from early march 2025 through Timeshift and then updated the system ignoring the updates related to the NVIDIA driver.
If I keep using Nvidia driver 550.144 instead of updating to 570.133 I have no issues on Manjaro. But for that to work I had to ignore the updates from linux612 6.12.17 to 6.12.20.
This will no doubt place you in an unsupported state.
Ignoring the kernel updates is not advisable. Instead, consider reverting to kernel 6.6 (LTS) and allow updates to continue.
The following items would require you to continue with Nvidia 570 and kernel 612 - not ignored:
  • Did these hangs also occur when using Wayland, or were they limited to X11?
  • A member solved their similar issue by migrating to a new user account. You could create a new account (for diagnostic purposes) and see whether the issues persist.
Note that I’m a KDE Plasma user, without Nvidia; what I can suggest regarding Gnome is somewhat limited.
As soon as I have the time I will try your suggestions. I was also thinking of trying out different Kernels on Manjaro Settings and see how it behaves.
The issues happened both on X11 and Wayland.
I did install Kernel 6.6 (LTS) and even with NVIDIA driver 570 running the issue seems to be solved. It’s maybe and issue with kernel 6.12?
It’s difficult to say. Hangs such as you describe can occur in a variety of situations with different factors contributing.
Manjaro allows several kernels to be installed, and each kernel continues to receive updates regardless of it being active or not.
Having both kernels 6.6 (LTS) and 6.12 (LTS) available in this way means you can switch back to 6.12 at any time (after an update, for example) to see how it performs.
Keep in mind there is (generally) no pressing need to use the latest and greatest kernel. I had 6.1 (LTS) and 6.6 (LTS) installed for a long while without needing to change that.
It’s only recently I decided to move to 6.12 (LTS) and with my hardware combination there have been no obvious issues. In fairness, I should again mention I don’t use Nvidia.
I’d tend to take the win with kernel 6.6 (LTS).
