Hi, i have problem with shutting down system, since kernel 6.5.7.
It hangs on “waiting for process udev-worker”
inxi:
Kernel: 6.6.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=1c039603-e4dd-41f5-837a-0185d63e15f2 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor udev.log_priority=3 nvidia-drm.modeset=1
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 82N6 v: Legion 7 16ACHg6
serial: <filter> Chassis: type: 10 v: Legion 7 16ACHg6 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: GKCN60WW date: 03/07/2023
ID-1: BAT0 charge: 77.2 Wh (100.0%) condition: 77.2/80.0 Wh (96.5%)
volts: 16.7 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly serial: <filter>
status: full cycles: 28
ID-2: hidpp_battery_1 charge: 93% condition: N/A volts: 4.1 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: discharging
Device-1: hidpp_battery_0 model: Logitech G935 Gaming Headset
serial: <filter> charge: N/A status: N/A
Info: model: AMD Ryzen 7 5800H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 644 high: 1893 min/max: 400/4463 base/boost: 3200/4450
scaling: driver: amd-pstate-epp governor: powersave volts: 1.2 V
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 1456 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 1769 14: 1893 15: 400 16: 400
bogomips: 102246
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: Lenovo driver: nvidia v: 535.129.03 alternate: nouveau,nvidia_drm
non-free: 545.xx+ status: current (as of 2023-11; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:24dc class-ID: 0300
Device-2: IMC Networks [] driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:5 chip-ID: 13d3:56bb
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia
d-rect: 6144x3008 display-ID: 0
Monitor-1: DP-2 pos: primary,top-left res: 4096x1728 size: N/A modes: N/A
Monitor-2: eDP-1 pos: bottom-r res: 2048x1280 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.129.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3080 Laptop GPU/PCIe/SSE2
memory: 15.62 GiB display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3080 Laptop GPU driver: nvidia v: 535.129.03
device-ID: 10de:24dc surfaces: xcb,xlib,wayland
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Logitech [] driver: logitech-hidpp-device,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1:4
chip-ID: 046d:0a87 class-ID: 0300
API: ALSA v: k6.6.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br-b8cda5e92a8c state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-4: virbr0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.75 TiB used: 1.19 TiB (43.3%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 50.9 C scheme: GPT
SMART: yes health: PASSED on: 57d 7h cycles: 1,105
read-units: 182,362,836 [93.3 TB] written-units: 55,399,237 [28.3 TB]
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: MZVLB1T0HBLR-000L2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3L1QEXF7 temp: 44.9 C
scheme: GPT
SMART: yes health: PASSED on: 31d 4h cycles: 1,311
read-units: 27,701,542 [14.1 TB] written-units: 8,454,683 [4.32 TB]
ID-1: / raw-size: 300 GiB size: 300 GiB (100.00%) used: 143.77 GiB (47.9%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:4
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
maj-min: 259:3
ID-3: /home raw-size: 1.53 TiB size: 1.5 TiB (98.36%)
used: 1.05 TiB (70.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:2
ID-4: /var/log raw-size: 300 GiB size: 300 GiB (100.00%)
used: 143.77 GiB (47.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:4
System Temperatures: cpu: 73.9 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 473 Uptime: 1h 0m wakeups: 0 Memory: total: 64 GiB
available: 62.65 GiB used: 10.82 GiB (17.3%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: 2001 pm: pacman pkgs: 1973 libs: 498 tools: pamac,yay
pm: flatpak pkgs: 15 pm: snap pkgs: 13 Shell: Bash (su) v: 5.2.15
running-in: konsole inxi: 3.3.31
journalctl -b-1 -p4 --no-pager
lis 06 10:32:37 lenovo-arch kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
lis 06 10:32:37 lenovo-arch kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
lis 06 10:32:37 lenovo-arch kernel: TSC synchronization [CPU#0 -> CPU#2]:
lis 06 10:32:37 lenovo-arch kernel: Measured 10738451402 cycles TSC warp between CPUs, turning off TSC clock.
lis 06 10:32:37 lenovo-arch kernel: #1 #3 #5 #7 #9 #11 #13 #15
lis 06 10:32:37 lenovo-arch kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.PB2], AE_NOT_FOUND (20230628/dswload2-162)
lis 06 10:32:37 lenovo-arch kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
lis 06 10:32:37 lenovo-arch kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
lis 06 10:32:37 lenovo-arch kernel: pci 0000:00:00.2: PCI INT A: not connected
lis 06 10:32:37 lenovo-arch kernel: tpm tpm0: tpm_read_log_acpi: Failed to map ACPI memory
lis 06 10:32:37 lenovo-arch kernel: integrity: Problem loading X.509 certificate -65
lis 06 10:32:37 lenovo-arch kernel: Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
lis 06 10:32:37 lenovo-arch kernel: nvidia: loading out-of-tree module taints kernel.
lis 06 10:32:37 lenovo-arch kernel: nvidia: module license 'NVIDIA' taints kernel.
lis 06 10:32:37 lenovo-arch kernel: Disabling lock debugging due to kernel taint
lis 06 10:32:37 lenovo-arch kernel: nvidia: module license taints kernel.
lis 06 10:32:37 lenovo-arch kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 535.129.03 Thu Oct 19 18:56:32 UTC 2023
lis 06 10:32:37 lenovo-arch kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
lis 06 10:32:37 lenovo-arch kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
lis 06 10:32:37 lenovo-arch kernel: ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
lis 06 10:32:37 lenovo-arch kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
lis 06 10:32:37 lenovo-arch kernel: nvme nvme0: missing or invalid SUBNQN field.
lis 06 10:32:37 lenovo-arch kernel: nvme nvme1: missing or invalid SUBNQN field.
lis 06 10:32:37 lenovo-arch kernel: VBoxNetAdp: Successfully started.
lis 06 10:32:37 lenovo-arch kernel: VBoxNetFlt: Successfully started.
lis 06 10:32:37 lenovo-arch kernel: usb: port power management may be unreliable
lis 06 10:32:38 lenovo-arch systemd-vconsole-setup[585]: /usr/bin/setfont failed with exit status 71.
lis 06 10:32:38 lenovo-arch kernel: BUG: kernel NULL pointer dereference, address: 0000000000000000
lis 06 10:32:38 lenovo-arch kernel: #PF: supervisor read access in kernel mode
lis 06 10:32:38 lenovo-arch kernel: #PF: error_code(0x0000) - not-present page
lis 06 10:32:38 lenovo-arch kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
lis 06 10:32:38 lenovo-arch kernel: CPU: 12 PID: 500 Comm: (udev-worker) Tainted: P OE 6.6.0-1-MANJARO #1 3dc4a4a6ba876de190ca2fd82f9af30616aeb92e
lis 06 10:32:38 lenovo-arch kernel: Hardware name: LENOVO 82N6/LNVNB161216, BIOS GKCN60WW 03/07/2023
lis 06 10:32:38 lenovo-arch kernel: RIP: 0010:strcmp+0x10/0x30
lis 06 10:32:38 lenovo-arch kernel: Code: 84 00 00 00 00 00 0f 1f 40 00 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 31 c0 eb 08 48 83 c0 01 84 d2 74 13 <0f> b6 14 07 3a 14 06 74 ef 19 c0 83 c8 01 e9 4d f7 02 00 31 c0 e9
lis 06 10:32:38 lenovo-arch kernel: RSP: 0018:ffffbcaf0a0a7b08 EFLAGS: 00010246
lis 06 10:32:38 lenovo-arch kernel: RAX: 0000000000000000 RBX: ffff994d456dfa28 RCX: 00000000008f000c
lis 06 10:32:38 lenovo-arch kernel: RDX: 0000000000000000 RSI: ffffffffc4fc30ea RDI: 0000000000000000
lis 06 10:32:38 lenovo-arch kernel: RBP: ffff994d41d96c10 R08: 0000000000000000 R09: 0000000000039060
lis 06 10:32:38 lenovo-arch kernel: R10: 0000000000150000 R11: 0000000000000000 R12: ffffffffc4ada0d8
lis 06 10:32:38 lenovo-arch kernel: R13: 0000000000000040 R14: ffffffffc4ada0d8 R15: ffff994d41d1c010
lis 06 10:32:38 lenovo-arch kernel: FS: 00007f1ec15cf480(0000) GS:ffff995c2e100000(0000) knlGS:0000000000000000
lis 06 10:32:38 lenovo-arch kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
lis 06 10:32:38 lenovo-arch kernel: CR2: 0000000000000000 CR3: 00000001063e2000 CR4: 0000000000750ee0
lis 06 10:32:38 lenovo-arch kernel: PKRU: 55555554
lis 06 10:32:38 lenovo-arch kernel: Call Trace:
lis 06 10:32:38 lenovo-arch kernel: <TASK>
lis 06 10:32:38 lenovo-arch kernel: ? __die+0x23/0x70
lis 06 10:32:38 lenovo-arch kernel: ? page_fault_oops+0x171/0x4e0
lis 06 10:32:38 lenovo-arch kernel: ? exc_page_fault+0x7f/0x180
lis 06 10:32:38 lenovo-arch kernel: ? asm_exc_page_fault+0x26/0x30
lis 06 10:32:38 lenovo-arch kernel: ? strcmp+0x10/0x30
lis 06 10:32:38 lenovo-arch kernel: ? srso_alias_return_thunk+0x5/0x7f
lis 06 10:32:38 lenovo-arch kernel: lenovo_legion_no_acpi+0x90/0xf0 [snd_hda_scodec_cs35l41 18ec2a604f396eb18e74caec38853e8e16f0fbaa]
lis 06 10:32:38 lenovo-arch kernel: cs35l41_hda_probe+0x124/0xa90 [snd_hda_scodec_cs35l41 18ec2a604f396eb18e74caec38853e8e16f0fbaa]
lis 06 10:32:38 lenovo-arch kernel: ? __devm_regmap_init+0x85/0xb0
lis 06 10:32:38 lenovo-arch kernel: i2c_device_probe+0x136/0x2e0
lis 06 10:32:38 lenovo-arch kernel: really_probe+0x19e/0x3e0
lis 06 10:32:38 lenovo-arch kernel: ? __pfx___driver_attach+0x10/0x10
lis 06 10:32:38 lenovo-arch kernel: __driver_probe_device+0x78/0x160
lis 06 10:32:38 lenovo-arch kernel: driver_probe_device+0x1f/0x90
lis 06 10:32:38 lenovo-arch kernel: __driver_attach+0xd2/0x1c0
lis 06 10:32:38 lenovo-arch kernel: bus_for_each_dev+0x88/0xd0
lis 06 10:32:38 lenovo-arch kernel: bus_add_driver+0x116/0x220
lis 06 10:32:38 lenovo-arch kernel: driver_register+0x59/0x100
lis 06 10:32:38 lenovo-arch kernel: i2c_register_driver+0x45/0xb0
lis 06 10:32:38 lenovo-arch kernel: ? __pfx_cs35l41_i2c_driver_init+0x10/0x10 [snd_hda_scodec_cs35l41_i2c ac047fe5d6c6873db41810bd8f212e2cdaacd62f]
lis 06 10:32:38 lenovo-arch kernel: do_one_initcall+0x5d/0x320
lis 06 10:32:38 lenovo-arch kernel: do_init_module+0x60/0x240
lis 06 10:32:38 lenovo-arch kernel: init_module_from_file+0x89/0xe0
lis 06 10:32:38 lenovo-arch kernel: idempotent_init_module+0x120/0x2b0
lis 06 10:32:38 lenovo-arch kernel: __x64_sys_finit_module+0x5e/0xb0
lis 06 10:32:38 lenovo-arch kernel: do_syscall_64+0x60/0x90
lis 06 10:32:38 lenovo-arch kernel: ? syscall_exit_to_user_mode+0x2b/0x40
lis 06 10:32:38 lenovo-arch kernel: ? do_syscall_64+0x6c/0x90
lis 06 10:32:38 lenovo-arch kernel: entry_SYSCALL_64_after_hwframe+0x6e/0xd8
lis 06 10:32:38 lenovo-arch kernel: RIP: 0033:0x7f1ec10b173d
lis 06 10:32:38 lenovo-arch kernel: Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c3 95 0c 00 f7 d8 64 89 01 48
lis 06 10:32:38 lenovo-arch kernel: RSP: 002b:00007ffc88a24688 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
lis 06 10:32:38 lenovo-arch kernel: RAX: ffffffffffffffda RBX: 0000555b8b540aa0 RCX: 00007f1ec10b173d
lis 06 10:32:38 lenovo-arch kernel: RDX: 0000000000000004 RSI: 00007f1ec11be376 RDI: 0000000000000014
lis 06 10:32:38 lenovo-arch kernel: RBP: 00007f1ec11be376 R08: 0000000000000001 R09: fffffffffffffe90
lis 06 10:32:38 lenovo-arch kernel: R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
lis 06 10:32:38 lenovo-arch kernel: R13: 0000555b8b6e5970 R14: 0000000000000000 R15: 0000555b8b6c7d60
lis 06 10:32:38 lenovo-arch kernel: </TASK>
lis 06 10:32:38 lenovo-arch kernel: Modules linked in: snd_hda_scodec_cs35l41_i2c(+) polyval_generic snd_hda_core snd_hda_scodec_cs35l41 gf128mul snd_hwdep ghash_clmulni_intel snd_hda_cs_dsp_ctls snd_pcm cfg80211 cs_dsp sha512_ssse3 r8169 snd_timer aesni_intel snd_soc_cs35l41_lib realtek ucsi_acpi(+) snd cm32181 typec_ucsi crypto_simd mdio_devres sp5100_tco cryptd hid_multitouch(+) rapl wdat_wdt pcspkr wmi_bmof typec libphy soundcore rfkill i2c_piix4 k10temp roles industrialio i2c_hid_acpi serial_multi_instantiate i2c_hid mac_hid squashfs uinput pkcs8_key_parser dm_multipath overlay vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) i2c_dev sg crypto_user fuse loop dm_mod bpf_preload ip_tables x_tables btrfs blake2b_generic libcrc32c crc32c_generic xor raid6_pq nvme crc32c_intel nvme_core xhci_pci xhci_pci_renesas nvme_common serio_raw atkbd libps2 vivaldi_fmap i8042 serio nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE) video wmi nvidia(POE)
lis 06 10:32:38 lenovo-arch kernel: ---[ end trace 0000000000000000 ]---
lis 06 10:32:38 lenovo-arch kernel: iwlwifi 0000:04:00.0: api flags index 2 larger than supported by driver
lis 06 10:32:38 lenovo-arch kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
lis 06 10:32:39 lenovo-arch systemd-tmpfiles[902]: Detected autofs mount point /home during canonicalization of home.
lis 06 10:32:39 lenovo-arch systemd[1]: Cannot find unit for notify message of PID 1050, ignoring.
lis 06 10:32:39 lenovo-arch systemd[1]: Cannot find unit for notify message of PID 1055, ignoring.
lis 06 10:32:39 lenovo-arch systemd[1]: Cannot find unit for notify message of PID 1091, ignoring.
lis 06 10:32:39 lenovo-arch systemd[1]: Cannot find unit for notify message of PID 1092, ignoring.
lis 06 10:32:39 lenovo-arch systemd[1]: snapd.service: Got notification message from PID 1279, but reception only permitted for main PID 1039
lis 06 10:32:39 lenovo-arch systemd[1]: snapd.service: Got notification message from PID 1310, but reception only permitted for main PID 1039
lis 06 10:32:39 lenovo-arch systemd[1]: snapd.service: Got notification message from PID 1311, but reception only permitted for main PID 1039
lis 06 10:32:39 lenovo-arch systemd[1]: snapd.service: Got notification message from PID 1312, but reception only permitted for main PID 1039
lis 06 10:32:39 lenovo-arch systemd[1]: snapd.service: Got notification message from PID 1313, but reception only permitted for main PID 1039
lis 06 10:32:39 lenovo-arch systemd[1]: snapd.service: Got notification message from PID 1314, but reception only permitted for main PID 1039
lis 06 10:32:39 lenovo-arch systemd[1]: snapd.service: Got notification message from PID 1315, but reception only permitted for main PID 1039
lis 06 10:32:39 lenovo-arch systemd[1]: snapd.service: Got notification message from PID 1317, but reception only permitted for main PID 1039
lis 06 10:32:39 lenovo-arch (uetoothd)[1319]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
lis 06 10:32:39 lenovo-arch systemd[1]: Cannot find unit for notify message of PID 1318, ignoring.
lis 06 10:32:39 lenovo-arch systemd[1]: Cannot find unit for notify message of PID 1321, ignoring.
lis 06 10:32:39 lenovo-arch systemd[1]: Cannot find unit for notify message of PID 1323, ignoring.
lis 06 10:32:39 lenovo-arch systemd[1]: Cannot find unit for notify message of PID 1326, ignoring.
lis 06 10:32:39 lenovo-arch systemd[1]: Cannot find unit for notify message of PID 1329, ignoring.
lis 06 10:32:39 lenovo-arch bluetoothd[1319]: src/plugin.c:plugin_init() System does not support csip plugin
lis 06 10:32:39 lenovo-arch bluetoothd[1319]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
lis 06 10:32:39 lenovo-arch bluetoothd[1319]: src/plugin.c:plugin_init() System does not support micp plugin
lis 06 10:32:39 lenovo-arch bluetoothd[1319]: src/plugin.c:plugin_init() System does not support vcp plugin
lis 06 10:32:39 lenovo-arch bluetoothd[1319]: src/plugin.c:plugin_init() System does not support mcp plugin
lis 06 10:32:39 lenovo-arch bluetoothd[1319]: src/plugin.c:plugin_init() System does not support bass plugin
lis 06 10:32:39 lenovo-arch bluetoothd[1319]: src/plugin.c:plugin_init() System does not support bap plugin
lis 06 10:32:40 lenovo-arch systemd[1]: snapd.service: Got notification message from PID 1330, but reception only permitted for main PID 1039
lis 06 10:32:41 lenovo-arch kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
lis 06 10:32:41 lenovo-arch kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
lis 06 10:32:41 lenovo-arch bluetoothd[1319]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
lis 06 10:32:41 lenovo-arch bluetoothd[1319]: Failed to clear UUIDs: Failed (0x03)
lis 06 10:32:41 lenovo-arch bluetoothd[1319]: Failed to add UUID: Failed (0x03)
lis 06 10:32:41 lenovo-arch bluetoothd[1319]: Failed to set mode: Failed (0x03)
lis 06 10:32:42 lenovo-arch kernel: Xorg[1452]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
lis 06 10:32:43 lenovo-arch NetworkManager[1171]: <warn> [1699263163.5216] device (wlan0): no secrets: No agents were available for this request.
lis 06 10:32:43 lenovo-arch NetworkManager[1171]: <warn> [1699263163.5219] device (wlan0): Activation: failed for connection 'fuksy'
lis 06 10:32:43 lenovo-arch nmbd[1585]: [2023/11/06 10:32:43.760200, 0] ../../source3/nmbd/nmbd.c:901(main)
lis 06 10:32:43 lenovo-arch kernel: kauditd_printk_skb: 73 callbacks suppressed
lis 06 10:32:43 lenovo-arch nmbd[1585]: main: nmbd version 4.19.2 started.
lis 06 10:32:43 lenovo-arch nmbd[1585]: Copyright Andrew Tridgell and the Samba Team 1992-2023
lis 06 10:32:43 lenovo-arch smbd[1616]: [2023/11/06 10:32:43.850265, 0] ../../source3/smbd/server.c:1746(main)
lis 06 10:32:43 lenovo-arch smbd[1616]: smbd version 4.19.2 started.
lis 06 10:32:43 lenovo-arch smbd[1616]: Copyright Andrew Tridgell and the Samba Team 1992-2023
lis 06 10:32:46 lenovo-arch kwin_wayland[1967]: No backend specified, automatically choosing drm
lis 06 10:32:46 lenovo-arch kwin_wayland[1967]: kf.globalaccel.kglobalacceld: No desktop file found for service "wow retail.desktop"
lis 06 10:32:48 lenovo-arch kwin_wayland[1967]: kwin_wayland_drm: Failed to create gamma blob! Invalid argument
lis 06 10:32:48 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:32:48 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:32:48 lenovo-arch ksplashqml[1970]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
lis 06 10:32:48 lenovo-arch ksplashqml[1970]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
lis 06 10:32:48 lenovo-arch kernel: warning: `kded5' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
lis 06 10:32:48 lenovo-arch ksmserver[2036]: Qt: Session management error: networkIdsList argument is NULL
lis 06 10:32:48 lenovo-arch plasmashell[2068]: Checking screens: available: (QScreen(0x562c569c9c90, name="DP-2"), QScreen(0x562c5699f860, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x562c569c9c90, name="DP-2"), QScreen(0x562c5699f860, name="eDP-1"))
lis 06 10:32:48 lenovo-arch plasmashell[2068]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
lis 06 10:32:48 lenovo-arch plasmashell[2068]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
lis 06 10:32:48 lenovo-arch kded5[2044]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
lis 06 10:32:48 lenovo-arch bluetoothd[1319]: Failed to add UUID: Failed (0x03)
lis 06 10:32:48 lenovo-arch kded5[2044]: kscreen.kded: UPower not available, lid detection won't work
lis 06 10:32:48 lenovo-arch kded5[2044]: kscreen.kded: PowerDevil SuspendSession action not available!
lis 06 10:32:48 lenovo-arch polkit-kde-authentication-agent-1[2115]: KXMessages used on non-X11 platform! This is an application bug.
lis 06 10:32:48 lenovo-arch wireplumber[2184]: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
lis 06 10:32:49 lenovo-arch plasmashell[2068]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:32:49 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:32:49 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:32:49 lenovo-arch kded5[2044]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
lis 06 10:32:49 lenovo-arch org_kde_powerdevil[2116]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
lis 06 10:32:49 lenovo-arch plasmashell[2068]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
lis 06 10:32:49 lenovo-arch plasmashell[2068]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:41: TypeError: Cannot read property 'length' of undefined
lis 06 10:32:49 lenovo-arch plasmashell[2068]: org.kde.plasma.kicker: DragHelper is deprecated and will be removed in Plasma 6. Use Qt Quick Drag instead.
lis 06 10:32:49 lenovo-arch plasmashell[2068]: org.kde.plasma.kicker: Kicker.WindowSystem is deprecated and will be removed in Plasma 6. Use KWindowSystem/KX11Extras instead.
lis 06 10:32:49 lenovo-arch ksystemstats[2138]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Voltage %1" msgid_plural: "" msgctxt: "@title %1 is a number"
lis 06 10:32:49 lenovo-arch ksystemstats[2138]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Temperature %1" msgid_plural: "" msgctxt: "@title %1 is a number"
lis 06 10:32:49 lenovo-arch ksystemstats[2138]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.48'
lis 06 10:32:49 lenovo-arch plasmashell[2068]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/CompactRepresentation.qml:22:1: QML CompactRepresentation: Binding loop detected for property "implicitHeight"
lis 06 10:32:49 lenovo-arch xdg-desktop-por[1973]: A backend call failed: No such method 'CreateMonitor' in interface 'org.freedesktop.impl.portal.Inhibit' at object path '/org/freedesktop/portal/desktop' (signature 'ooss')
lis 06 10:32:49 lenovo-arch xdg-desktop-por[1973]: Failed to close session implementation: GDBus.Error:org.freedesktop.DBus.Error.UnknownObject: No such object path '/org/freedesktop/portal/desktop/session/1_79/tdesktop1896227803'
lis 06 10:32:49 lenovo-arch plasmashell[2068]: file:///usr/share/plasma/plasmoids/org.kde.kscreen/contents/ui/main.qml:30:5: Unable to assign [undefined] to bool
lis 06 10:32:49 lenovo-arch kalendarac[2366]: kf.config.core: "\"Occurrence\" - conversion of \"0,0,0,-1,-1,-1.001\" to QDateTime failed"
lis 06 10:32:50 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:32:50 lenovo-arch akonadi_control[2632]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
lis 06 10:32:50 lenovo-arch xdg-desktop-portal-kde[2117]: xdp-kde-settings: Namespace "org.gnome.desktop.wm.preferences" is not supported
lis 06 10:32:50 lenovo-arch bluetoothd[1319]: Failed to add UUID: Failed (0x03)
lis 06 10:32:50 lenovo-arch plasmashell[2068]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
lis 06 10:32:50 lenovo-arch plasmashell[2068]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
lis 06 10:32:50 lenovo-arch telegram-desktop[2351]: qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "stateChanged"
lis 06 10:32:50 lenovo-arch telegram-desktop[2351]: qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "connectivityChanged"
lis 06 10:32:50 lenovo-arch telegram-desktop[2351]: qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "deviceTypeChanged"
lis 06 10:32:50 lenovo-arch telegram-desktop[2351]: qt.dbus.integration: Could not connect "org.freedesktop.NetworkManager" to "meteredChanged"
lis 06 10:32:50 lenovo-arch plasmashell[2068]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
lis 06 10:32:50 lenovo-arch telegram-desktop[2351]: QPainter::begin: Paint device returned engine == 0, type: 2
lis 06 10:32:50 lenovo-arch telegram-desktop[2351]: QWidget::render: Cannot render with an inactive painter
lis 06 10:32:50 lenovo-arch rambox[2345]: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
lis 06 10:32:50 lenovo-arch rambox[2345]: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
lis 06 10:32:50 lenovo-arch rambox[2345]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
lis 06 10:32:50 lenovo-arch plasmashell[2068]: file:///usr/share/plasma/plasmoids/org.kde.kscreen/contents/ui/main.qml:30:5: Unable to assign [undefined] to bool
lis 06 10:32:50 lenovo-arch plasmashell[2068]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:32:50 lenovo-arch telegram-desktop[2351]: qt.svg: Error while inflating gzip file: SVG format check failed
lis 06 10:32:50 lenovo-arch plasmashell[2068]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
lis 06 10:32:50 lenovo-arch wireplumber[2184]: <WpPortalPermissionStorePlugin:0x5614ffbe1c00> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
lis 06 10:32:50 lenovo-arch plasmashell[2068]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
lis 06 10:32:50 lenovo-arch plasmashell[2068]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
lis 06 10:32:51 lenovo-arch plasmashell[2068]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
lis 06 10:32:51 lenovo-arch telegram-desktop[2351]: qt.svg: Error while inflating gzip file: SVG format check failed
lis 06 10:32:51 lenovo-arch telegram-desktop[2351]: qt.gui.imageio.jpeg: Corrupt JPEG data: premature end of data segment
lis 06 10:32:52 lenovo-arch xdg-desktop-portal-kde[2117]: xdp-kde-settings: Namespace "org.gnome.desktop.interface" is not supported
lis 06 10:32:54 lenovo-arch plasmashell[2068]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
lis 06 10:32:54 lenovo-arch plasmashell[2068]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
lis 06 10:32:54 lenovo-arch plasmashell[2068]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:32:55 lenovo-arch akonadiserver[2646]: org.kde.pim.akonadiserver: database server stopped unexpectedly
lis 06 10:32:55 lenovo-arch akonadiserver[2646]: org.kde.pim.akonadiserver: Database process exited unexpectedly during initial connection!
lis 06 10:32:55 lenovo-arch akonadiserver[2646]: org.kde.pim.akonadiserver: executable: "/usr/bin/mysqld"
lis 06 10:32:55 lenovo-arch akonadiserver[2646]: org.kde.pim.akonadiserver: arguments: ("--defaults-file=/home/kudlaty/.local/share/akonadi/mysql.conf", "--datadir=/home/kudlaty/.local/share/akonadi/db_data/", "--socket=/run/user/1000/akonadi/mysql.socket", "--pid-file=/run/user/1000/akonadi/mysql.pid")
lis 06 10:32:55 lenovo-arch akonadiserver[2646]: org.kde.pim.akonadiserver: stdout: ""
lis 06 10:32:55 lenovo-arch akonadiserver[2646]: org.kde.pim.akonadiserver: stderr: "/usr/bin/mysqld: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadbd' instead\n"
lis 06 10:32:55 lenovo-arch akonadiserver[2646]: org.kde.pim.akonadiserver: exit code: 1
lis 06 10:32:55 lenovo-arch akonadiserver[2646]: org.kde.pim.akonadiserver: process error: "Unknown error"
lis 06 10:32:55 lenovo-arch kalendarac[2366]: org.kde.pim.akonadicore: Job error: "" for collection: QVector()
lis 06 10:32:55 lenovo-arch kwin_wayland[1967]: kwin_core: Failed to focus 0x2800004 (error 3)
lis 06 10:32:55 lenovo-arch kwin_wayland[1967]: kwin_core: XCB error: 3 (BadWindow), sequence: 821, resource id: 41943044, major code: 129 (SHAPE), minor code: 6 (Input)
lis 06 10:32:55 lenovo-arch kwin_wayland[1967]: kwin_core: XCB error: 3 (BadWindow), sequence: 822, resource id: 41943044, major code: 129 (SHAPE), minor code: 5 (Extents)
lis 06 10:32:55 lenovo-arch kwin_wayland[1967]: kwin_core: XCB error: 3 (BadWindow), sequence: 846, resource id: 41943044, major code: 129 (SHAPE), minor code: 3 (Combine)
lis 06 10:32:55 lenovo-arch kwin_wayland[1967]: kwin_core: XCB error: 3 (BadWindow), sequence: 847, resource id: 41943044, major code: 129 (SHAPE), minor code: 3 (Combine)
lis 06 10:32:55 lenovo-arch kwin_wayland[1967]: kwin_core: XCB error: 3 (BadWindow), sequence: 862, resource id: 41943044, major code: 129 (SHAPE), minor code: 3 (Combine)
lis 06 10:32:55 lenovo-arch kwin_wayland[1967]: kwin_core: XCB error: 3 (BadWindow), sequence: 863, resource id: 41943044, major code: 129 (SHAPE), minor code: 3 (Combine)
lis 06 10:32:55 lenovo-arch kwin_wayland[1967]: kwin_core: Could not find window with uuid "{0db594f8-9aa5-446c-b6f9-122a7303b8c7}"
lis 06 10:32:56 lenovo-arch plasmashell[2068]: libpng warning: iCCP: known incorrect sRGB profile
lis 06 10:32:56 lenovo-arch plasmashell[2068]: libpng warning: known incorrect sRGB profile
lis 06 10:32:56 lenovo-arch plasmashell[2068]: libpng warning: profile matches sRGB but writing iCCP instead
lis 06 10:32:56 lenovo-arch plasmashell[2068]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:32:56 lenovo-arch plasmashell[2068]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
lis 06 10:32:56 lenovo-arch plasmashell[2068]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/ItemListDialog.qml:73: TypeError: Cannot call method 'hasOwnProperty' of null
lis 06 10:32:58 lenovo-arch plasmashell[2068]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:32:59 lenovo-arch plasmashell[2068]: QString::arg: 2 argument(s) missing in systemsettings
lis 06 10:32:59 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:32:59 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:32:59 lenovo-arch systemsettings[3480]: kf.coreaddons: "Could not load plugin from kcm_fcitx5: The shared library was not found."
lis 06 10:32:59 lenovo-arch systemsettings[3480]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:32:59 lenovo-arch systemsettings[3480]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:33:00 lenovo-arch systemsettings[3480]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
lis 06 10:33:00 lenovo-arch systemsettings[3480]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
lis 06 10:33:00 lenovo-arch systemsettings[3480]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:33:06 lenovo-arch plasmashell[2068]: QString::arg: 2 argument(s) missing in org.kde.konsole
lis 06 10:33:06 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:33:06 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:33:06 lenovo-arch plasmashell[2068]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
lis 06 10:33:13 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:33:13 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:33:15 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:33:15 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:34:44 lenovo-arch plasmashell[2068]: trying to show an empty dialog
lis 06 10:34:46 lenovo-arch plasmashell[2068]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:34:48 lenovo-arch plasmashell[2068]: QString::arg: 2 argument(s) missing in systemsettings
lis 06 10:34:48 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:34:48 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:34:48 lenovo-arch systemsettings[27018]: kf.coreaddons: "Could not load plugin from kcm_fcitx5: The shared library was not found."
lis 06 10:34:48 lenovo-arch systemsettings[27018]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:34:48 lenovo-arch systemsettings[27018]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:34:48 lenovo-arch systemsettings[27018]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
lis 06 10:34:48 lenovo-arch systemsettings[27018]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
lis 06 10:34:48 lenovo-arch systemsettings[27018]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:34:59 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:34:59 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:34:59 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:34:59 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:03 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:03 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:03 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:03 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:13 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:13 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:13 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:13 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:14 lenovo-arch plasmashell[2068]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
lis 06 10:35:14 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:14 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:15 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:15 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:16 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:16 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:16 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:16 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:17 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:17 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:17 lenovo-arch firefox-bin[38217]: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
lis 06 10:35:17 lenovo-arch firefox-bin[38217]: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
lis 06 10:35:17 lenovo-arch firefox-bin[38217]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
lis 06 10:35:17 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:17 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:20 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:20 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:20 lenovo-arch fx_cast_bridge[38882]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:20 lenovo-arch fx_cast_bridge[38882]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:35:20 lenovo-arch fx_cast_bridge[38882]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:35:20 lenovo-arch fx_cast_bridge[38882]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:20 lenovo-arch fx_cast_bridge[39031]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:20 lenovo-arch fx_cast_bridge[39031]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:35:20 lenovo-arch fx_cast_bridge[39031]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:35:20 lenovo-arch fx_cast_bridge[39031]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:20 lenovo-arch fx_cast_bridge[39102]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:20 lenovo-arch fx_cast_bridge[39102]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:35:20 lenovo-arch fx_cast_bridge[39102]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:35:20 lenovo-arch fx_cast_bridge[39102]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:29 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:29 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:29 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:29 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:31 lenovo-arch fx_cast_bridge[39425]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:31 lenovo-arch fx_cast_bridge[39425]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:35:31 lenovo-arch fx_cast_bridge[39425]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:35:31 lenovo-arch fx_cast_bridge[39425]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:31 lenovo-arch fx_cast_bridge[39435]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:31 lenovo-arch fx_cast_bridge[39435]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:35:31 lenovo-arch fx_cast_bridge[39435]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:35:31 lenovo-arch fx_cast_bridge[39435]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:32 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:32 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:32 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:32 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:38 lenovo-arch systemd-udevd[371]: CLSA0100:00: Worker [451] processing SEQNUM=3572 killed
lis 06 10:35:42 lenovo-arch fx_cast_bridge[39957]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:42 lenovo-arch fx_cast_bridge[39957]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:35:42 lenovo-arch fx_cast_bridge[39957]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:35:42 lenovo-arch fx_cast_bridge[39957]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:42 lenovo-arch fx_cast_bridge[39973]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:42 lenovo-arch fx_cast_bridge[39973]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:35:42 lenovo-arch fx_cast_bridge[39973]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:35:42 lenovo-arch fx_cast_bridge[39973]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:44 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:44 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:44 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:44 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:47 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:47 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:47 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:47 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:52 lenovo-arch fx_cast_bridge[40287]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:52 lenovo-arch fx_cast_bridge[40287]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:35:52 lenovo-arch fx_cast_bridge[40287]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:35:52 lenovo-arch fx_cast_bridge[40287]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:53 lenovo-arch fx_cast_bridge[40299]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:53 lenovo-arch fx_cast_bridge[40299]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:35:53 lenovo-arch fx_cast_bridge[40299]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:35:53 lenovo-arch fx_cast_bridge[40299]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:35:59 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:59 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:59 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:35:59 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:02 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:02 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:03 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:03 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:03 lenovo-arch fx_cast_bridge[40607]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:03 lenovo-arch fx_cast_bridge[40607]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:03 lenovo-arch fx_cast_bridge[40607]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:03 lenovo-arch fx_cast_bridge[40607]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:03 lenovo-arch fx_cast_bridge[40624]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:03 lenovo-arch fx_cast_bridge[40624]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:03 lenovo-arch fx_cast_bridge[40624]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:03 lenovo-arch fx_cast_bridge[40624]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:14 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:14 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:14 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:14 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:14 lenovo-arch fx_cast_bridge[41129]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:14 lenovo-arch fx_cast_bridge[41129]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:14 lenovo-arch fx_cast_bridge[41129]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:14 lenovo-arch fx_cast_bridge[41129]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:14 lenovo-arch fx_cast_bridge[41144]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:14 lenovo-arch fx_cast_bridge[41144]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:14 lenovo-arch fx_cast_bridge[41144]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:14 lenovo-arch fx_cast_bridge[41144]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:17 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:17 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:17 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:17 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:25 lenovo-arch fx_cast_bridge[41578]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:25 lenovo-arch fx_cast_bridge[41578]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:25 lenovo-arch fx_cast_bridge[41578]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:25 lenovo-arch fx_cast_bridge[41578]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:25 lenovo-arch fx_cast_bridge[41588]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:25 lenovo-arch fx_cast_bridge[41588]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:25 lenovo-arch fx_cast_bridge[41588]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:25 lenovo-arch fx_cast_bridge[41588]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:29 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:29 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:29 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:29 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:32 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:32 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:32 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:32 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:37 lenovo-arch fx_cast_bridge[41905]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:37 lenovo-arch fx_cast_bridge[41905]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:37 lenovo-arch fx_cast_bridge[41905]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:37 lenovo-arch fx_cast_bridge[41905]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:37 lenovo-arch fx_cast_bridge[41930]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:37 lenovo-arch fx_cast_bridge[41930]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:37 lenovo-arch fx_cast_bridge[41930]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:37 lenovo-arch fx_cast_bridge[41930]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:45 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:45 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:45 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:45 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:48 lenovo-arch fx_cast_bridge[42186]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:48 lenovo-arch fx_cast_bridge[42186]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:48 lenovo-arch fx_cast_bridge[42186]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:48 lenovo-arch fx_cast_bridge[42186]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:48 lenovo-arch fx_cast_bridge[42196]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:48 lenovo-arch fx_cast_bridge[42196]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:48 lenovo-arch fx_cast_bridge[42196]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:48 lenovo-arch fx_cast_bridge[42196]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:50 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:50 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:50 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:50 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:36:58 lenovo-arch fx_cast_bridge[42658]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:58 lenovo-arch fx_cast_bridge[42658]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:58 lenovo-arch fx_cast_bridge[42658]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:58 lenovo-arch fx_cast_bridge[42658]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:58 lenovo-arch fx_cast_bridge[42670]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:36:58 lenovo-arch fx_cast_bridge[42670]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:36:58 lenovo-arch fx_cast_bridge[42670]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:36:58 lenovo-arch fx_cast_bridge[42670]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:01 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:01 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:01 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:01 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:04 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:04 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:05 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:05 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:09 lenovo-arch fx_cast_bridge[42996]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:09 lenovo-arch fx_cast_bridge[42996]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:09 lenovo-arch fx_cast_bridge[42996]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:09 lenovo-arch fx_cast_bridge[42996]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:09 lenovo-arch fx_cast_bridge[43006]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:09 lenovo-arch fx_cast_bridge[43006]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:09 lenovo-arch fx_cast_bridge[43006]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:09 lenovo-arch fx_cast_bridge[43006]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:15 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:15 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:15 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:15 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:18 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:18 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:18 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:18 lenovo-arch plasmashell[2068]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:37:21 lenovo-arch fx_cast_bridge[43312]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:21 lenovo-arch fx_cast_bridge[43312]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:21 lenovo-arch fx_cast_bridge[43312]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:21 lenovo-arch fx_cast_bridge[43312]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:21 lenovo-arch fx_cast_bridge[43322]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:21 lenovo-arch fx_cast_bridge[43322]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:21 lenovo-arch fx_cast_bridge[43322]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:21 lenovo-arch fx_cast_bridge[43322]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:31 lenovo-arch fx_cast_bridge[43543]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:31 lenovo-arch fx_cast_bridge[43543]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:31 lenovo-arch fx_cast_bridge[43543]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:31 lenovo-arch fx_cast_bridge[43543]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:31 lenovo-arch fx_cast_bridge[43553]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:31 lenovo-arch fx_cast_bridge[43553]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:31 lenovo-arch fx_cast_bridge[43553]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:31 lenovo-arch fx_cast_bridge[43553]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:42 lenovo-arch fx_cast_bridge[43576]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:42 lenovo-arch fx_cast_bridge[43576]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:42 lenovo-arch fx_cast_bridge[43576]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:42 lenovo-arch fx_cast_bridge[43576]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:42 lenovo-arch fx_cast_bridge[43586]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:42 lenovo-arch fx_cast_bridge[43586]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:42 lenovo-arch fx_cast_bridge[43586]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:42 lenovo-arch fx_cast_bridge[43586]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:52 lenovo-arch fx_cast_bridge[43612]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:52 lenovo-arch fx_cast_bridge[43612]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:52 lenovo-arch fx_cast_bridge[43612]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:52 lenovo-arch fx_cast_bridge[43612]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:52 lenovo-arch fx_cast_bridge[43622]: *** WARNING *** The program 'fx_cast_bridge' uses the Apple Bonjour compatibility layer of Avahi.
lis 06 10:37:52 lenovo-arch fx_cast_bridge[43622]: *** WARNING *** Please fix your application to use the native API of Avahi!
lis 06 10:37:52 lenovo-arch fx_cast_bridge[43622]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
lis 06 10:37:52 lenovo-arch fx_cast_bridge[43622]: *** WARNING *** The program 'fx_cast_bridge' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
lis 06 10:38:22 lenovo-arch kwin_wayland[1967]: This plugin does not support raise()
lis 06 10:38:32 lenovo-arch plasmashell[2068]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:38:33 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but has no Exec field.
lis 06 10:38:33 lenovo-arch kwin_wayland[1967]: kf.service.services: The desktop entry file "/usr/share/applications/org.freedesktop.Xwayland.desktop" has Type= "Application" but has no Exec field.
lis 06 10:38:33 lenovo-arch ksmserver-logout-greeter[45594]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
lis 06 10:38:41 lenovo-arch plasmashell[2068]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:125: TypeError: Cannot read property 'compactRepresentationItem' of null
lis 06 10:38:42 lenovo-arch pipewire[2183]: mod.x11-bell: X11 I/O error handler called on display :1
lis 06 10:38:42 lenovo-arch pipewire[2183]: mod.x11-bell: X11 display (:1) has encountered a fatal I/O error
lis 06 10:38:42 lenovo-arch kaccess[2358]: The X11 connection broke (error 1). Did the X11 server die?
lis 06 10:38:42 lenovo-arch systemd[1586]: app-kaccess@autostart.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch sddm[1436]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
lis 06 10:38:42 lenovo-arch sddm[1436]: Auth: sddm-helper (--socket /tmp/sddm-auth-dd814e2e-40c7-4ae8-9614-676deb1fb36e --id 1 --start /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland --user kudlaty --autologin) crashed (exit code 1)
lis 06 10:38:42 lenovo-arch sddm[1436]: Auth: sddm-helper exited with 1
lis 06 10:38:42 lenovo-arch kwin_wayland[1967]: QtDBus: cannot relay signals from parent QObject(0x556335051b70 "") unless they are emitted in the object's thread QThread(0x556334ef7c38 "libinput-connection"). Current thread is QThread(0x556334ea4d90 "").
lis 06 10:38:42 lenovo-arch kded5[2044]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch plasmashell[2068]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch kactivitymanagerd[2112]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch polkit-kde-authentication-agent-1[2115]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch org_kde_powerdevil[2116]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch xdg-desktop-portal-kde[2117]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch kwalletd5[2221]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch msm_kde_notifier[2329]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch kdeconnectd[2335]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch pamac-tray-plasma[2373]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch yakuake[2336]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch kalendarac[2366]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch fcitx5-plasma-theme-generator[2541]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch telegram-desktop[2351]: The Wayland connection broke. Did the Wayland compositor die?
lis 06 10:38:42 lenovo-arch systemd[1586]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: plasma-kded.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: plasma-powerdevil.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: app-org.kde.kdeconnect.daemon@autostart.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: app-org.kde.yakuake@autostart.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: app-org.kde.kalendarac@autostart.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: plasma-polkit-agent.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch sddm[1436]: Signal received: SIGTERM
lis 06 10:38:42 lenovo-arch systemd[1586]: plasma-plasmashell.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: app-telegramdesktop@autostart.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch systemd[1586]: obex.service: Failed with result 'exit-code'.
lis 06 10:38:42 lenovo-arch nmbd[1585]: [2023/11/06 10:38:42.954997, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
lis 06 10:38:42 lenovo-arch nmbd[1585]: Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
lis 06 10:38:42 lenovo-arch nmbd[1585]: [2023/11/06 10:38:42.955230, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
strange part is that i cannot see output form photo in journalctl…
pls help
