Hello. My computer fails to properly shutdown occasionally. I click the shutdown button, but then it seems to hang at the black screen. My system information is below.
The output of journalctl -b-1 -p4 --no-pager:
Jun 03 13:43:55 ulysses kernel: pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Jun 03 13:43:55 ulysses kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jun 03 13:43:55 ulysses kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WQAK data block query control method not found
Jun 03 13:43:55 ulysses kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WQAL data block query control method not found
Jun 03 13:43:55 ulysses kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WMAJ method block execution control method not found
Jun 03 13:43:55 ulysses systemd-vconsole-setup[350]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Jun 03 13:43:55 ulysses systemd-vconsole-setup[350]: Fonts will not be copied to remaining consoles
Jun 03 13:43:55 ulysses kernel: perf uncore: Cannot find matched IMC device.
Jun 03 13:43:55 ulysses systemd-vconsole-setup[476]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Jun 03 13:43:55 ulysses systemd-vconsole-setup[476]: Fonts will not be copied to remaining consoles
Jun 03 13:43:55 ulysses kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Jun 03 13:43:56 ulysses kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
Jun 03 13:43:56 ulysses kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Jun 03 13:43:56 ulysses kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
Jun 03 13:43:56 ulysses kernel: nvidia: loading out-of-tree module taints kernel.
Jun 03 13:43:56 ulysses kernel: nvidia: module license 'NVIDIA' taints kernel.
Jun 03 13:43:56 ulysses kernel: Disabling lock debugging due to kernel taint
Jun 03 13:43:56 ulysses kernel: nvidia: module license taints kernel.
Jun 03 13:43:56 ulysses kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.78 Sun Apr 14 06:35:45 UTC 2024
Jun 03 13:43:56 ulysses kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
Jun 03 13:43:56 ulysses kernel: ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
Jun 03 13:43:57 ulysses kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jun 03 13:43:57 ulysses kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Jun 03 13:43:57 ulysses kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Jun 03 13:43:58 ulysses bluetoothd[618]: src/plugin.c:init_plugin() System does not support bap plugin
Jun 03 13:43:58 ulysses bluetoothd[618]: src/plugin.c:init_plugin() System does not support bass plugin
Jun 03 13:43:58 ulysses bluetoothd[618]: src/plugin.c:init_plugin() System does not support mcp plugin
Jun 03 13:43:58 ulysses bluetoothd[618]: src/plugin.c:init_plugin() System does not support vcp plugin
Jun 03 13:43:58 ulysses bluetoothd[618]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Jun 03 13:43:58 ulysses bluetoothd[618]: src/plugin.c:init_plugin() System does not support micp plugin
Jun 03 13:43:58 ulysses bluetoothd[618]: src/plugin.c:init_plugin() System does not support ccp plugin
Jun 03 13:43:58 ulysses bluetoothd[618]: src/plugin.c:init_plugin() System does not support csip plugin
Jun 03 13:43:58 ulysses bluetoothd[618]: Failed to set mode: Failed (0x03)
Jun 03 13:44:02 ulysses dbus-broker-launch[614]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jun 03 13:44:02 ulysses dbus-broker-launch[730]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jun 03 13:44:02 ulysses dbus-broker-launch[730]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jun 03 13:44:02 ulysses dbus-broker-launch[730]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jun 03 13:44:03 ulysses sddm-greeter-qt6[726]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.19'
Jun 03 13:44:03 ulysses sddm-greeter-qt6[726]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.20'
Jun 03 13:44:07 ulysses sddm-greeter-qt6[726]: file:///usr/share/sddm/themes/breath/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Jun 03 13:44:10 ulysses sddm-helper[763]: [PAM] authenticate: Authentication failure
Jun 03 13:44:10 ulysses sddm[697]: Authentication error: SDDM::Auth::ERROR_AUTHENTICATION "Authentication failure"
Jun 03 13:44:10 ulysses sddm-helper[763]: [PAM] Asked to close the session but it wasn't previously open
Jun 03 13:44:10 ulysses sddm[697]: Auth: sddm-helper exited with 1
Jun 03 13:44:13 ulysses systemd-journald[346]: File /var/log/journal/3e9d9c52480a488fb7d0d91e063172de/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Jun 03 13:44:13 ulysses dbus-broker-launch[795]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jun 03 13:44:13 ulysses dbus-broker-launch[795]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jun 03 13:44:13 ulysses dbus-broker-launch[795]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jun 03 13:44:14 ulysses ksplashqml[799]: Texture 0x76ddd482f2c0 () used with different accesses within the same pass, this is not allowed.
Jun 03 13:44:14 ulysses kded6[857]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Jun 03 13:44:14 ulysses kded6[857]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Jun 03 13:44:14 ulysses kded6[857]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Jun 03 13:44:14 ulysses kconf_update[935]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Jun 03 13:44:14 ulysses kconf_update[935]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Jun 03 13:44:14 ulysses kconf_update[935]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Jun 03 13:44:14 ulysses kconf_update[935]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Jun 03 13:44:14 ulysses kconf_update[935]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Jun 03 13:44:14 ulysses kconf_update[935]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Jun 03 13:44:14 ulysses kconf_update[935]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Jun 03 13:44:14 ulysses plasmashell[892]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jun 03 13:44:14 ulysses plasmashell[892]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jun 03 13:44:14 ulysses kded6[857]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Jun 03 13:44:14 ulysses bluetoothd[618]: Failed to set mode: Failed (0x03)
Jun 03 13:44:14 ulysses kded6[857]: kf.bluezqt: PendingCall Error: "Failed"
Jun 03 13:44:14 ulysses kded6[857]: kscreen.kded: PowerDevil SuspendSession action not available!
Jun 03 13:44:14 ulysses xdg-desktop-por[821]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Jun 03 13:44:14 ulysses xdg-desktop-por[821]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Jun 03 13:44:14 ulysses plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jun 03 13:44:14 ulysses org_kde_powerdevil[932]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jun 03 13:44:15 ulysses kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Jun 03 13:44:15 ulysses kdeconnectd[1059]: 2024-06-03T13:44:15 default: Error sending UDP packet: QAbstractSocket::NetworkError
Jun 03 13:44:15 ulysses kdeconnectd[1059]: 2024-06-03T13:44:15 kdeconnect.core: Failed to open any MDNS client sockets
Jun 03 13:44:15 ulysses kdeconnectd[1059]: 2024-06-03T13:44:15 kdeconnect.core: Failed to open any MDNS server sockets
Jun 03 13:44:15 ulysses plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Jun 03 13:44:15 ulysses plasmashell[892]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Jun 03 13:44:15 ulysses bluetoothd[618]: Failed to set mode: Failed (0x03)
Jun 03 13:44:15 ulysses kded6[857]: kf.bluezqt: PendingCall Error: "Failed"
Jun 03 13:44:15 ulysses plasmashell[892]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1717418655690: Unsupported image format
Jun 03 13:44:15 ulysses plasmashell[892]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jun 03 13:44:17 ulysses plasmashell[892]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jun 03 13:44:29 ulysses xdg-desktop-portal-kde[933]: xdp-kde-settings: Namespace "org.gnome.desktop.interface" is not supported
Jun 03 13:44:29 ulysses kernel: x86/split lock detection: #AC: CJobMgr::m_Work/1954 took a split_lock trap at address: 0xe2b011bf
Jun 03 13:44:30 ulysses kernel: x86/split lock detection: #AC: CJobMgr::m_Work/1968 took a split_lock trap at address: 0xe2b011bf
Jun 03 13:44:31 ulysses xdg-desktop-portal-kde[933]: xdp-kde-settings: Namespace "org.gnome.desktop.interface" is not supported
Jun 03 13:44:31 ulysses kernel: x86/split lock detection: #AC: CJobMgr::m_Work/2230 took a split_lock trap at address: 0xe2b011bf
Jun 03 13:44:41 ulysses kernel: x86/split lock detection: #AC: CJobMgr::m_Work/2599 took a split_lock trap at address: 0xe2b011bf
Jun 03 13:44:41 ulysses kwin_x11[858]: kwin_core: XCB error: 3 (BadWindow), sequence: 36706, resource id: 106954799, major code: 129 (SHAPE), minor code: 3 (Combine)
Jun 03 13:44:41 ulysses kwin_x11[858]: kwin_core: XCB error: 3 (BadWindow), sequence: 36707, resource id: 106954799, major code: 129 (SHAPE), minor code: 3 (Combine)
Jun 03 13:44:46 ulysses baloorunner[1258]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
Jun 03 13:44:46 ulysses baloorunner[1258]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
Jun 03 13:44:46 ulysses kwin_x11[858]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
Jun 03 13:44:46 ulysses kwin_x11[858]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
Jun 03 13:44:49 ulysses systemd[773]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
Jun 03 13:44:50 ulysses kwin_x11[858]: kwin_core: XCB error: 152 (BadDamage), sequence: 44921, resource id: 20975696, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jun 03 13:44:50 ulysses kwin_x11[858]: kwin_core: XCB error: 3 (BadWindow), sequence: 44922, resource id: 96469062, major code: 129 (SHAPE), minor code: 6 (Input)
Jun 03 13:44:52 ulysses plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
Jun 03 13:44:52 ulysses plasmashell[892]: QObject::killTimer: Timers cannot be stopped from another thread
Jun 03 13:44:52 ulysses plasmashell[892]: QObject::~QObject: Timers cannot be stopped from another thread
Jun 03 13:44:52 ulysses plasmashell[892]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
Jun 03 13:44:57 ulysses systemd[773]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Jun 03 14:53:10 ulysses kernel: xhci_hcd 0000:00:0d.0: xHC error in resume, USBSTS 0x401, Reinit
Jun 03 14:53:10 ulysses dbus-broker[615]: A security policy denied :1.3 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.64.
Jun 03 14:53:12 ulysses kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jun 03 14:53:12 ulysses kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Jun 03 14:53:12 ulysses bluetoothd[618]: Failed to set mode: Failed (0x03)
Jun 03 14:53:15 ulysses NetworkManager[616]: <warn> [1717422795.1659] device (wlo1): no secrets: No agents were available for this request.
Jun 03 14:53:15 ulysses NetworkManager[616]: <warn> [1717422795.1670] device (wlo1): Activation: failed for connection 'Ernst Stavro Blofeld'
Jun 03 14:53:20 ulysses kernel: usb 3-4: rtl8192eu_active_to_emu: Disabling MAC timed out
Jun 03 14:53:26 ulysses NetworkManager[616]: <warn> [1717422806.2295] device (wlp0s20f0u8): no secrets: No agents were available for this request.
Jun 03 14:53:26 ulysses NetworkManager[616]: <warn> [1717422806.2297] device (wlp0s20f0u8): Activation: failed for connection 'Ernst Stavro Blofeld'
Jun 03 14:53:30 ulysses sddm[697]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Jun 03 14:53:30 ulysses sddm[697]: Auth: sddm-helper (--socket /tmp/sddm-auth-931f6813-cf0e-4f39-83b3-73176aa57b0d --id 1 --start /usr/bin/startplasma-x11 --user ulysses) crashed (exit code 1)
Jun 03 14:53:30 ulysses sddm[697]: Auth: sddm-helper exited with 1
Jun 03 14:53:30 ulysses dbus-broker[615]: A security policy denied :1.3 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.64.
Jun 03 14:53:30 ulysses sddm[697]: Signal received: SIGTERM
Jun 03 14:53:30 ulysses systemd[773]: dbus-:1.64-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Jun 03 14:53:30 ulysses dbus-broker-launch[614]: Activation request for 'org.bluez' failed.
Jun 03 14:53:31 ulysses dbus-broker-launch[614]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
The output of inxi -Fza:
Kernel: 6.9.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=3f5370bf-cded-405b-a42f-5b7c0402f335 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: Micro-Star product: GF63 Thin 11UC v: REV:1.0
Mobo: Micro-Star model: MS-16R6 v: REV:1.0 serial: <superuser required>
part-nu: 16R6.1 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E16R6IMS.10D date: 06/23/2022
ID-1: BAT1 charge: 27.4 Wh (52.4%) condition: 52.3/51.3 Wh (101.9%)
volts: 11.6 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x50
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 64536
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a68 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a2 class-ID: 0302
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 652x366mm (25.67x14.41")
s-diag: 748mm (29.44")
Monitor-1: eDP-1 mapped: eDP-1-1 model: ChiMei InnoLux 0x1521 built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3050 Laptop
GPU/PCIe/SSE2 memory: 3.91 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3050 Laptop GPU driver: nvidia v: 550.78 device-ID: 10de:25a2
surfaces: xcb,xlib
Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0401
API: ALSA v: k6.9.2-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: TP-Link TL-WN823N v2/v3 [Realtek RTL8192EU] driver: rtl8xxxu
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:2
chip-ID: 2357:0109 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u8 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:3 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 476.94 GiB used: 64.41 GiB (13.5%)
model: MZVL4512HBLU-00BTW size: 476.94 GiB block-size: physical: 512 B
fw-rev: HXC70W1Q temp: 42.9 C scheme: GPT
ID-1: / raw-size: 186.99 GiB size: 182.99 GiB (97.86%)
used: 64.38 GiB (35.2%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 26.7 MiB (27.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 55.0 C mobo: N/A gpu: nvidia temp: 53 C
Fan Speeds (rpm): N/A
Memory: total: 24 GiB note: est. available: 23.18 GiB used: 4.23 GiB (18.2%)
Processes: 349 Power: uptime: 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.24 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1450 libs: 428 tools: pamac Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: yakuake inxi: 3.3.34
Potential solutions I’ve come across have pointed to using wayland (I’m using x11), and watchdog being responsible for this issue (I don’t see that in the journal output). I would aprreciate some direction in this regard please.
