System hangs and abnormal RAM usage by simple apps
I’ll just leave this here:
https://www.linuxatemyram.com/
https://linux.oneandoneis2.org/LNW.htm
And remember:
Things change. That’s the way of a healthy life. Something that might have worked previously is not guaranteed to work today. Or tomorrow for that matter.
Already stated that disabling Autostart applications would not resolve issues with applications in use after boot.
On my system RAM was upgraded from 4 GB to 8 GB a few years ago and 8 GB to 16 GB last year
I observed a small increase in the amount of RAM used after boot
But the RAM used by individual applications and number of processes did not increase
So I suspect upgrading RAM would not help to resolve issue
Additional processes may or may not relate to issue with applications
dmidecode would show more information about all processes
I’ve talked about swap in general, not discussing practical examples. BTW, if I need swap, usually I reserve an amount of space required to complete the needed task.
I don’t get the point. The abnormal RAM usage by some apps/processes (especially the simple ones) doesn’t depend on the existence of configured swap in the system.
Sorry, could you explain what you mean, exactly (the part highlighted in bold)?
The abnormal behavior relates the amount of memory that Linux pre-allocates at least for some applications, which in my installation (suddenly) is more than double compared to any other installation, for no reason at all.
@Mirdarthos, based on what https://www.linuxatemyram.com/ says, I’m not complaining about free memory (which is not near to zero), I’m just complaining about used memory (*). BTW, free + buff/cache doesn’t match amount of available (and it doesn’t prevent hangs due to amount of used memory):
available memory (or “free + buffers/cache”) has enough room (let’s say, 20%+ of total)
The 2nd linked page (Linux is NOT Windows, which includes some mistakes too) mentions issues/topics other than the one I introduced at the beginning of the thread.
The birth of the issue I showed is not connected to changes over time, also considering that this behavior suddenly started to affect only my installation, while the other current manjaro installations (which are also updated) are immune to that (as pointed out by data shown in this thread too).
               total        used        free      shared  buff/cache   available
Mem:           3,3Gi       3,0Gi       202Mi        19Mi       360Mi       328Mi
@nikgnomic, thanks for your reply. I’ve run sudo dmidecode in a live session and in the current installation for comparing them but I don’t understand where the output returns info about processes (I’ve also read dmidecode help and man, without success). Could you explain what you mean, exactly? Thanks in advance.
Well, this is becoming a contextual swamp.
I’ll simply wish you luck.
Cheers.
Data from dmidecode shows RAM used by hardware devices and should be similar on Live ISO and Installed OS if this is only a software/configuration issue
Previous suggestion was to boot a Live ISO and check RAM usage and number of processes
If abnormal RAM usage is not visible in Task Manager and number of processes are not as high as installed OS, issue is probably from a recent change or user misconfiguration
To check more information about RAM usage on installed OS I suggest using htop
howtogeek.com - how to use linux htop command
check values for process priority (PRI) and process niceness (NI)
and kill additional processes that are not running on other installed OS
Memory nodes from sudo dmidecode output show only hardware properties of installed DIMM module (and cache memory data). A diff result shows (of course) no differences for these ones.
It seems so. A comparison with Live ISO shows that such processes eat half the amount of RAM (as it should be) and overall there is not an abnormal RAM usage (as expected).
I read that how-to (which is useful) in past and I’ve also done some tests with htop (BTW, when I turn NI up for a process by pressing F8 - turning that down has no effects - PRI value increases too).
Hello,
This also happened to me this week. XFCE was using double the RAM, no matter the kernel. Compared on two machines with the live-CD: same usage on both.
I didn’t want to bother searching for the culprit so I just did a fresh install. And now, XFCE uses the usual 1 GB of RAM as intended. But this is really strange…
Oh, and yeah, swap saved me big time, but this wasn’t supposed to happen.
This thread is over 5 months old. It is unlikely that the problem or the solutions are the same, considering Manjaro’s rolling-release nature.
Furthermore, this post doesn’t add anything constructive to the thread.
Taking all this into consideration, I’ve closed the topic.
