My system has started to freeze occasionally during the recent days. Could you please help me to troubleshoot?
If this happens, I press the power-button, which initiates a shutdown. Since I can see the usual messages on the screen during shutdown, it is obviously not 100% frozen - just stuck.
(base) [dejhost@Workstation ~]$ sudo pacman -Syu
[sudo] password for dejhost:
core is up to date
extra is up to date
community is up to date
multilib is up to date
there is nothing to do
The system froze about 6 times during the last few hours. I was suprised that Manjaro sends notifications, while mouse and keyboard do not react. So when it happend the last time, I pulled the USB-cable and re-inserted it. This helped.
I will re-organize my usb-setup, exchanging cables. Maybe that helps.
Any suggestions what else I could do?
I am a little confused by some of data in the inxi
XFCE desktop
Xwayland
I may be missing something - I didnât know XFCE was capable of using Wayland - which just triggered the thought - what if you logout - do you have an option switch session to Xorg?
Now that I remember CUDA and Nvidia - I am not so sure - as my suggestion relies on the prebuilt nvidia driver modules for the kernel.
Personally I would test it but since you have to ask - I withdraw the suggestion.
Should you want to test if the kernel is somehow flooded with events - you should be able to gather some intel as suggested by @TriMoon.
For information only
You should not do this if you are in any way uncomfortable with the process
My process of troubleshooting by testing the 6.1 kernel would involve the following change to the system
sync the headers for the current kernel from the repo linux60-headers
sync dkms and nvidia-dkms
restart to verify the dkms package works as expected
sync the linux61 kernel and headers linux61-headers
restart to test 6.1
One will have to accept the replacement of the kernel specific nvidia package in favor of the nvidia-dkms package
sudo pacman -Syu linux60-headers dkms nvidia-dkms
Then restart the system - to test the dkms modules.
If the result is as expected continue with
sudo pacman -Syu linux61 linux61-headers
And restart to test 6.1 kernel.
If for any reason this creates issues - one can issue an emergency reboot using REISUB - then hold the shift key while booting to display the GRUB menu â navigate advanced options â select the 6.0 kernel.
First of all. I donât see anything related to the gpu or anything else⌠only your network before you pressed the shutdown button:
Nov 29 10:08:59 nextcloud.nextcloud-fixer[60510]: Nextcloud is not installed - only a limited number of commands are available
Nov 29 10:09:00 nextcloud.nextcloud-fixer[60588]: Nextcloud is not installed - only a limited number of commands are available
Nov 29 10:09:01 nextcloud.nextcloud-fixer[60666]: Nextcloud is not installed - only a limited number of commands are available
Nov 29 10:09:02 nextcloud.nextcloud-fixer[60742]: Nextcloud is not installed - only a limited number of commands are available
Nov 29 10:09:02 kernel: [UFW BLOCK] IN=enp34s0 OUT= MAC=01:00:5e:00:00:fb:be:dd:68:9e:4d:c6:08:00 SRC=10.0.4.65 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=9959 PROTO=2
Nov 29 10:09:03 systemd[1]: docker-2bd7636352e76a227672e49942c16600fa97f2c6fe3a7c850cb4392bf7bc2b3b.scope: Deactivated successfully.
Nov 29 10:09:03 systemd[1]: docker-2bd7636352e76a227672e49942c16600fa97f2c6fe3a7c850cb4392bf7bc2b3b.scope: Consumed 2.511s CPU time.
Nov 29 10:09:03 kernel: br-a96c1ef81739: port 2(veth0e2b8da) entered disabled state
Nov 29 10:09:03 kernel: veth9c539e2: renamed from eth0
Nov 29 10:09:03 NetworkManager[1229]: <info> [1669712943.5372] manager: (veth9c539e2): new Veth device (/org/freedesktop/NetworkManager/Devices/69)
Nov 29 10:09:03 avahi-daemon[1214]: Interface veth0e2b8da.IPv6 no longer relevant for mDNS.
Nov 29 10:09:03 avahi-daemon[1214]: Leaving mDNS multicast group on interface veth0e2b8da.IPv6 with address fe80::7ce7:7bff:fe12:c265.
Nov 29 10:09:03 kernel: device veth0e2b8da left promiscuous mode
Nov 29 10:09:03 avahi-daemon[1214]: Withdrawing address record for fe80::7ce7:7bff:fe12:c265 on veth0e2b8da.
Nov 29 10:09:03 nextcloud.nextcloud-fixer[60855]: Nextcloud is not installed - only a limited number of commands are available
Nov 29 10:09:04 systemd-logind[1219]: Power key pressed short.
Nov 29 10:09:04 systemd-logind[1219]: System is powering down.
It looks like the driver is loaded but not by Xorg as you see driver: N/A. There could be a problem somehow.
In your /etc/mkinitcpio.conf is
MODULES=(amdgpu)
mentioned, but it seems you donât one it.
And yeah I guess you saw it:
Nov 29 10:05:19 kernel: usb 1-1.1-port1: cannot disable (err = -71)
Nov 29 10:05:19 kernel: usb 1-1.1-port1: cannot reset (err = -71)
Nov 29 10:05:19 kernel: usb 1-1.1-port1: Cannot enable. Maybe the USB cable is bad?
From the logs I cannot determine what your freeze is caused by.
I would guess it could be an Issue with Cstates of your CPU . So if it goes in deep sleep then it freezes.
Maybe try this: processor.max_cstate=1 to add to the kernel parameter. So it will not be lower than 1, so fixed to C0 C1.
Yes, freeze might be a strong word. I couldnât see any movement on the screen anymore. Mouse and keyboard wouldnât have any impact. Much later, I was surprised to see a manjaro-notification popping up.
When it last happened, htop did not show anything special. It just continued to run as usual.
btw.: CTRL+ALT+F2/3 doesnât open a console on my machine. Do you know the command for the terminal?
I am pretty sure by now, that it has to do with the USB. I am investigating this further. Unplug and replugging one of the usb-cables helps (I added a second one in order to find out which component is cauing the issue.
journalctl -xf tells me many things. For example: Nov 29 11:54:59 Workstation nextcloud.nextcloud-fixer[468851]: Nextcloud is not installed - only a limited number of commands are available
Nextcloud is running just fine. Should I ignore this? Reinstall?
