System frequently crashing after GPU drivers update
I am using kernel 5.13 rc1 and recently upgraded to 5.13 rc4. I started with the linux-firmware 20210315, which was rock solid and works with 4k 60Hz.
Today, I upgraded to the recent linux-firmware 20210518.r1928.f846292. In Journalctl the amdgpu error logs returned. However, they but stopped entirely crashing my lenovo e485/ e585. Instead, they only resulted in ~2 second lasting hangs, which is a huge improvement for me.
However, the problem is only fixed, when downgrading to 20210315 or earlier.
The problem is back after the latest update!!!
@lolz I can confirm. With kernel 5.13rc4 and newest linux-firmware 20210518.r1928.f846292, but also 20210315.3568f96 the crashes occur (for me). As workaround, I am downgrading to linux-firmware 20210208.
Here is some error log from kernel kernel 5.13rc4 with linux-firmware 20210518 on ryzen 2500u on lenovo e485/e585 generated by journalctl -b -1 --no-hostname:
Yep, things are going to hell again.
Inxi:
System:    Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=a1b30750-c69c-48f7-8140-e5e6da952d8b rw quiet
           cryptdevice=UUID=5adf3423-73bc-4b74-89e4-d4f7230a8fcb:luks-5adf3423-73bc-4b74-89e4-d4f7230a8fcb
           root=/dev/mapper/luks-5adf3423-73bc-4b74-89e4-d4f7230a8fcb apparmor=1 security=apparmor
           resume=/dev/mapper/luks-bed3ba14-517d-49f8-983e-861cdc13a51d udev.log_priority=3
           Desktop: Cinnamon 4.8.6 tk: GTK 3.24.29 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x serial: <filter> UEFI: American Megatrends v: 2008
           date: 12/06/2019
Battery:   Message: No system battery data found. Is one present?
Memory:    RAM: total: 29.38 GiB used: 5.13 GiB (17.5%)
CPU:       Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64 type: MT MCP arch: Zen/Zen+ note: check
           family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109 cache: L2: 2 MiB bogomips: 59119
           Speed: 1858 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz): 1: 1858 2: 1348 3: 1326 4: 1271 5: 2982
           6: 1324 7: 1472 8: 1287
           Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush clflushopt clzero cmov
           cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu
           fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr
           mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
           perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
           sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
           topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
           xsaves
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 09:00.0
           chip-ID: 1002:15d8 class-ID: 0300
           Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
           display-ID: :0 screens: 1
           Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2") s-diag: 1055mm (41.5")
           Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
           Monitor-2: DVI-D-0 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
           OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0 5.12.9-1-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.2
           direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
           driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 1002:15de class-ID: 0403
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus-ID: 09:00.6 chip-ID: 1022:15e3 class-ID: 0403
           Device-3: JOUNIVO JV603 JOUNIVO JV603 type: USB driver: snd-usb-audio bus-ID: 5-1:2 chip-ID: 5678:4434
           class-ID: 0300 serial: <filter>
           Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
           Sound Server-3: PulseAudio v: 14.2 running: no
           Sound Server-4: PipeWire v: 0.3.30 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: f000
           bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
           IF-ID-1: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
           IP v4: <filter> scope: global
           IP v6: <filter> virtual: stable-privacy scope: link
Bluetooth: Message: No bluetooth data found.
Logical:   Permissions: Unable to run lvs. Root privileges required.
RAID:      Message: No RAID data found.
Drives:    Local Storage: total: 2.84 TiB used: 327.41 GiB (11.3%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB block-size:
           physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 2B2QEXE7 scheme: GPT
           ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 2B6Q scheme: GPT
           ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EZRZ-22Z5HB0 size: 1.82 TiB block-size:
           physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0A80
           ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37120G size: 111.79 GiB block-size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 61K1 scheme: MBR
           Optical-1: /dev/sr0 vendor: ATAPI model: iHAS124 B rev: AL0L dev-links: cdrom
           Features: speed: 48 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / raw-size: 456.66 GiB size: 448.49 GiB (98.21%) used: 327.41 GiB (73.0%) fs: ext4 dev: /dev/dm-0
           maj-min: 254:0 mapped: luks-5adf3423-73bc-4b74-89e4-d4f7230a8fcb label: N/A
           uuid: a1b30750-c69c-48f7-8140-e5e6da952d8b
           ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 480 KiB (0.2%) fs: vfat dev: /dev/sda1
           maj-min: 8:1 label: N/A uuid: E6D9-F526
Swap:      Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1 maj-min: 254:1
           mapped: luks-bed3ba14-517d-49f8-983e-861cdc13a51d label: N/A uuid: cb9702b7-cca1-4dc0-9f3a-76f7a724dc67
Unmounted: ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: fat (32 bit) label: N/A uuid: AC7D-5E25
           ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
           ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 465.15 GiB fs: ntfs label: N/A uuid: ECDE7EEEDE7EB086
           ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 505 MiB fs: ntfs label: N/A uuid: F2B8BD2FB8BCF2E9
           ID-5: /dev/sda2 maj-min: 8:2 size: 456.66 GiB fs: <superuser required> label: N/A
           uuid: 5adf3423-73bc-4b74-89e4-d4f7230a8fcb
           ID-6: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: <superuser required> label: N/A
           uuid: bed3ba14-517d-49f8-983e-861cdc13a51d
USB:       Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
           Device-1: 1-1:2 info: QinHeng CH340 serial converter type: <vendor specific> driver: ch341,ch341-uart interfaces: 1
           rev: 1.1 speed: 12 Mb/s power: 96mA chip-ID: 1a86:7523 class-ID: ff00
           Device-2: 1-2:3 info: Logitech M-U0007 [Corded Mouse M500] type: Mouse driver: hid-generic,usbhid interfaces: 1
           rev: 2.0 speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c069 class-ID: 0301
           Device-3: 1-10:4 info: Saitek PLC X45 Flight Controller type: HID driver: hid-generic,usbhid interfaces: 1 rev: 1.0
           speed: 1.5 Mb/s power: 26mA chip-ID: 06a3:053c class-ID: 0300 serial: <filter>
           Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
           Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
           Device-1: 3-4:2 info: IBM NetVista Full Width Keyboard type: Keyboard driver: hid-generic,usbhid interfaces: 1
           rev: 1.1 speed: 1.5 Mb/s power: 100mA chip-ID: 04b3:3025 class-ID: 0301
           Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
           Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
           Device-1: 5-1:2 info: JOUNIVO JV603 JOUNIVO JV603 type: Audio,HID driver: snd-usb-audio interfaces: 3 rev: 1.1
           speed: 12 Mb/s power: 84mA chip-ID: 5678:4434 class-ID: 0300 serial: <filter>
           Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors:   System Temperatures: cpu: 30.5 C mobo: 0 C gpu: amdgpu temp: 30.0 C
Info:      Processes: 372 Uptime: 8m wakeups: 0 Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1808
           pacman: 1794 lib: 491 flatpak: 5 snap: 9 Shell: Bash v: 5.1.8 running-in: terminator inxi: 3.3.04
Journalctl
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:1 pasid:32769, for process Xorg pid 908 thread Xorg:cs0 pid 994)
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f01000 from client 27
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00141051
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:          Faulty UTCL2 client ID: TCP (0x8)
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:          MORE_FAULTS: 0x1
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:          WALKER_ERROR: 0x0
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:          PERMISSION_FAULTS: 0x5
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:          MAPPING_ERROR: 0x0
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:          RW: 0x1
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f02000 from client 27
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f06000 from client 27
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f00000 from client 27
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f03000 from client 27
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f05000 from client 27
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f04000 from client 27
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f08000 from client 27
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f07000 from client 27
Jun 15 01:17:55 desktop kernel: amdgpu 0000:09:00.0: amdgpu:   in page starting at address 0x800113f0a000 from client 27
Jun 15 01:18:00 desktop kernel: [drm:amdgpu_dm_atomic_commit_tail [amdgpu]] *ERROR* Waiting for fences timed out!
Jun 15 01:18:01 desktop dbus-daemon[863]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jun 15 01:18:05 desktop kernel: [drm:amdgpu_dm_atomic_commit_tail [amdgpu]] *ERROR* Waiting for fences timed out!
Jun 15 01:18:05 desktop kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=68242, emitted seq=68244
Jun 15 01:18:05 desktop kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 908 thread Xorg:cs0 pid 994
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: amdgpu: GPU reset begin!
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163a9f40 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163a9f60 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163a9f80 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163a9fa0 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163a9fc0 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163a9fe0 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163aa000 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163aa020 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163aa040 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0000 address=0x1163aa060 flags=0x0070]
Jun 15 01:18:05 desktop kernel: amd_iommu_report_page_fault: 21 callbacks suppressed
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa080 flags=0x0070]
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa0a0 flags=0x0070]
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa0c0 flags=0x0070]
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa0e0 flags=0x0070]
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa100 flags=0x0070]
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa120 flags=0x0070]
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa140 flags=0x0070]
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa160 flags=0x0070]
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa180 flags=0x0070]
Jun 15 01:18:05 desktop kernel: AMD-Vi: Event logged [IO_PAGE_FAULT device=09:00.0 domain=0x0000 address=0x1163aa1a0 flags=0x0070]
Jun 15 01:18:05 desktop kernel: [drm] free PSP TMR buffer
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: amdgpu: MODE2 reset
Jun 15 01:18:05 desktop kernel: mce: [Hardware Error]: Machine check events logged
Jun 15 01:18:05 desktop kernel: [Hardware Error]: Deferred error, no action required.
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: amdgpu: GPU reset succeeded, trying to resume
Jun 15 01:18:05 desktop kernel: [Hardware Error]: CPU:0 (17:18:1) MC20_STATUS[-|-|MiscV|AddrV|-|-|SyndV|UECC|Deferred|-|-]: 0x9c2030000001085b
Jun 15 01:18:05 desktop kernel: [Hardware Error]: Error Addr: 0x00007ffcffffff00
Jun 15 01:18:05 desktop kernel: [Hardware Error]: IPID: 0x0000002e00000000, Syndrome: 0x000000005b240203
Jun 15 01:18:05 desktop kernel: [Hardware Error]: Coherent Slave Ext. Error Code: 1, Address Violation.
Jun 15 01:18:05 desktop kernel: [Hardware Error]: cache level: L3/GEN, mem/io: IO, mem-tx: IRD, part-proc: SRC (no timeout)
Jun 15 01:18:05 desktop kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
Jun 15 01:18:05 desktop kernel: [drm] PSP is resuming...
Jun 15 01:18:05 desktop kernel: [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: amdgpu: RAS: optional ras ta ucode is not available
Jun 15 01:18:05 desktop kernel: amdgpu 0000:09:00.0: amdgpu: RAP: optional rap ta ucode is not available
Jun 15 01:18:05 desktop kernel: [drm] kiq ring mec 2 pipe 1 q 0
Jun 15 01:18:06 desktop kernel: ------------[ cut here ]------------
Jun 15 01:18:06 desktop kernel: WARNING: CPU: 6 PID: 120 at drivers/gpu/drm/amd/amdgpu/../display/dc/core/dc.c:942 dc_commit_state+0x9bb/0xaa0 [amdgpu]
Jun 15 01:18:06 desktop kernel: Modules linked in: xt_tcpudp xt_state xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c tun iptable_filter ip6table_filter ip6_tables snd_seq_dummy snd_hrtimer snd_seq snd_usb_audio snd_usb>
Jun 15 01:18:06 desktop kernel:  mbcache jbd2 dm_crypt cbc encrypted_keys dm_mod trusted tpm usbhid crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel crypto_simd cryptd ccp rng_core sr_mod cdrom xhci_pci
Jun 15 01:18:06 desktop kernel: CPU: 6 PID: 120 Comm: kworker/6:1 Tainted: G           OE     5.12.9-1-MANJARO #1
Jun 15 01:18:06 desktop kernel: Hardware name: System manufacturer System Product Name/PRIME B450-PLUS, BIOS 2008 12/06/2019
Jun 15 01:18:06 desktop kernel: Workqueue: events drm_sched_job_timedout [gpu_sched]
Jun 15 01:18:06 desktop kernel: RIP: 0010:dc_commit_state+0x9bb/0xaa0 [amdgpu]
Jun 15 01:18:06 desktop kernel: Code: 89 f7 e8 88 5b 9b f2 e9 b4 f8 ff ff 0f 1f 44 00 00 e9 7a fd ff ff 31 d2 e9 d7 f7 ff ff 80 b8 80 03 00 00 00 0f 84 10 fd ff ff <0f> 0b e9 09 fd ff ff 48 89 ef e8 06 bd 00 00 48 89 ef e8 4e 5b 9b
Jun 15 01:18:06 desktop kernel: RSP: 0018:ffffb633804dbc38 EFLAGS: 00010202
Jun 15 01:18:06 desktop kernel: RAX: ffff9efe24043c00 RBX: ffff9efed32e06c0 RCX: 0000000000000006
Jun 15 01:18:06 desktop kernel: RDX: 000000000000153f RSI: 0000000000000e6e RDI: 0000015b5fcd3dd5
Jun 15 01:18:06 desktop kernel: RBP: 0000000000000000 R08: ffffb633804dbb8c R09: 0000000000000002
Jun 15 01:18:06 desktop kernel: R10: 0000000000005d28 R11: 0000000000000000 R12: ffff9efd1e660000
Jun 15 01:18:06 desktop kernel: R13: ffff9efed32e1ef8 R14: 0000000000000002 R15: ffff9efed32e0000
Jun 15 01:18:06 desktop kernel: FS:  0000000000000000(0000) GS:ffff9f0400b80000(0000) knlGS:0000000000000000
Jun 15 01:18:06 desktop kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 15 01:18:06 desktop kernel: CR2: 0000018008159004 CR3: 00000002780c2000 CR4: 00000000003506e0
Jun 15 01:18:06 desktop kernel: Call Trace:
Jun 15 01:18:06 desktop kernel:  dm_resume+0x3ce/0x530 [amdgpu]
Jun 15 01:18:06 desktop kernel:  amdgpu_device_ip_resume_phase2+0x52/0xb0 [amdgpu]
Jun 15 01:18:06 desktop kernel:  amdgpu_do_asic_reset+0x256/0x37e [amdgpu]
Jun 15 01:18:06 desktop kernel:  amdgpu_device_gpu_recover.cold+0x7b6/0x9f3 [amdgpu]
Jun 15 01:18:06 desktop kernel:  amdgpu_job_timedout+0x128/0x150 [amdgpu]
Jun 15 01:18:06 desktop kernel:  drm_sched_job_timedout+0x64/0xe0 [gpu_sched]
Jun 15 01:18:06 desktop kernel:  process_one_work+0x214/0x3e0
Jun 15 01:18:06 desktop kernel:  worker_thread+0x4d/0x3d0
Jun 15 01:18:06 desktop kernel:  ? process_one_work+0x3e0/0x3e0
Jun 15 01:18:06 desktop kernel:  kthread+0x133/0x150
Jun 15 01:18:06 desktop kernel:  ? kthread_associate_blkcg+0xc0/0xc0
Jun 15 01:18:06 desktop kernel:  ret_from_fork+0x22/0x30
Jun 15 01:18:06 desktop kernel: ---[ end trace 26d872bd2d2ac0fd ]---
Jun 15 01:18:06 desktop kernel: [drm] VCN decode and encode initialized successfully(under SPG Mode).
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: recover vram bo from shadow start
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: recover vram bo from shadow done
Jun 15 01:18:06 desktop kernel: [drm] Skip scheduling IBs!
Jun 15 01:18:06 desktop kernel: amdgpu 0000:09:00.0: amdgpu: GPU reset(2) succeeded!
Jun 15 01:18:11 desktop kernel: amdgpu_cs_ioctl: 107 callbacks suppressed
Jun 15 01:18:11 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:18:16 desktop kernel: amdgpu_cs_ioctl: 851 callbacks suppressed
Jun 15 01:18:16 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:18:18 desktop systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Jun 15 01:18:18 desktop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 15 01:18:18 desktop audit: BPF prog-id=24 op=UNLOAD
Jun 15 01:18:18 desktop audit: BPF prog-id=23 op=UNLOAD
Jun 15 01:18:18 desktop audit: BPF prog-id=22 op=UNLOAD
Jun 15 01:18:21 desktop kernel: amdgpu_cs_ioctl: 255 callbacks suppressed
Jun 15 01:18:21 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:18:26 desktop audit[3332]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=3332 comm="GpuWatchdog" exe="/app/Signal/signal-desktop" sig=11 res=1
Jun 15 01:18:26 desktop systemd[1]: Created slice system-systemd\x2dcoredump.slice.
Jun 15 01:18:26 desktop audit: BPF prog-id=25 op=LOAD
Jun 15 01:18:26 desktop audit: BPF prog-id=26 op=LOAD
Jun 15 01:18:26 desktop audit: BPF prog-id=27 op=LOAD
Jun 15 01:18:26 desktop systemd[1]: Started Process Core Dump (PID 4441/UID 0).
Jun 15 01:18:26 desktop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-4441-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 15 01:18:26 desktop kernel: amdgpu_cs_ioctl: 302 callbacks suppressed
Jun 15 01:18:26 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:18:26 desktop systemd[1]: systemd-coredump@0-4441-0.service: Deactivated successfully.
Jun 15 01:18:26 desktop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-4441-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 15 01:18:26 desktop kernel: audit: type=1131 audit(1623734306.750:163): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-4441-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? t>
Jun 15 01:18:26 desktop audit: BPF prog-id=27 op=UNLOAD
Jun 15 01:18:26 desktop audit: BPF prog-id=26 op=UNLOAD
Jun 15 01:18:26 desktop audit: BPF prog-id=25 op=UNLOAD
Jun 15 01:18:31 desktop kernel: amdgpu_cs_ioctl: 439 callbacks suppressed
Jun 15 01:18:31 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:18:38 desktop systemd[1]: Started Getty on tty2.
Jun 15 01:18:38 desktop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 15 01:18:38 desktop kernel: kauditd_printk_skb: 80 callbacks suppressed
Jun 15 01:18:38 desktop kernel: audit: type=1130 audit(1623734318.748:167): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=s>
Jun 15 01:18:38 desktop kernel: fbcon: Taking over console
Jun 15 01:18:38 desktop kernel: Console: switching to colour frame buffer device 240x67
Jun 15 01:18:46 desktop audit[4536]: USER_AUTH pid=4536 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="anon" exe="/usr/bin/log>
Jun 15 01:18:46 desktop dbus-daemon[863]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.79' (uid=0 pid=4536 comm="/bin/login -p --      ")
Jun 15 01:18:46 desktop dbus-daemon[863]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jun 15 01:18:46 desktop login[4536]: pam_systemd_home(login:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jun 15 01:18:46 desktop kernel: audit: type=1100 audit(1623734326.670:168): pid=4536 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock >
Jun 15 01:18:46 desktop audit[4536]: USER_ACCT pid=4536 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="anon" exe="/usr/bin/login" hostname=desktop addr=>
Jun 15 01:18:46 desktop audit[4536]: CRED_ACQ pid=4536 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="anon" exe="/usr/bin/login" host>
Jun 15 01:18:46 desktop audit[4536]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffeea722300 a2=4 a3=3e8 items=0 ppid=1 pid=4536 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=4 comm="lo>
Jun 15 01:18:46 desktop kernel: audit: type=1101 audit(1623734326.673:169): pid=4536 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="anon" exe="/usr/bin/>
Jun 15 01:18:46 desktop kernel: audit: type=1103 audit(1623734326.673:170): pid=4536 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="a>
Jun 15 01:18:46 desktop kernel: audit: type=1006 audit(1623734326.673:171): pid=4536 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=4 res=1
Jun 15 01:18:46 desktop kernel: audit: type=1300 audit(1623734326.673:171): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffeea722300 a2=4 a3=3e8 items=0 ppid=1 pid=4536 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 >
Jun 15 01:18:46 desktop kernel: audit: type=1327 audit(1623734326.673:171): proctitle=2F62696E2F6C6F67696E002D70002D2D
Jun 15 01:18:46 desktop audit: PROCTITLE proctitle=2F62696E2F6C6F67696E002D70002D2D
Jun 15 01:18:46 desktop login[4536]: pam_unix(login:session): session opened for user anon(uid=1000) by LOGIN(uid=0)
Jun 15 01:18:46 desktop systemd-logind[868]: New session 4 of user anon.
Jun 15 01:18:46 desktop systemd[1]: Started Session 4 of user anon.
Jun 15 01:18:46 desktop login[4536]: pam_env(login:session): deprecated reading of user environment enabled
Jun 15 01:18:46 desktop audit[4536]: USER_START pid=4536 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="anon" exe="/usr/>
Jun 15 01:18:46 desktop audit[4536]: CRED_REFR pid=4536 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="anon" exe="/usr/bin/login" hostname=desktop a>
Jun 15 01:18:46 desktop login[4536]: LOGIN ON tty2 BY anon
Jun 15 01:18:46 desktop kernel: audit: type=1105 audit(1623734326.693:172): pid=4536 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pa>
Jun 15 01:18:46 desktop kernel: audit: type=1110 audit(1623734326.693:173): pid=4536 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="anon" exe="/usr/>
Jun 15 01:19:11 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:19:16 desktop kernel: amdgpu_cs_ioctl: 1344 callbacks suppressed
Jun 15 01:19:16 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:19:21 desktop kernel: amdgpu_cs_ioctl: 282 callbacks suppressed
Jun 15 01:19:21 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:20:24 desktop kernel: amdgpu_cs_ioctl: 197 callbacks suppressed
Jun 15 01:20:24 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:20:25 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:20:29 desktop kernel: amdgpu_cs_ioctl: 1023 callbacks suppressed
Jun 15 01:20:29 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:20:34 desktop kernel: amdgpu_cs_ioctl: 287 callbacks suppressed
Jun 15 01:20:34 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:19 desktop kernel: amdgpu_cs_ioctl: 144 callbacks suppressed
Jun 15 01:21:19 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:24 desktop kernel: amdgpu_cs_ioctl: 1293 callbacks suppressed
Jun 15 01:21:24 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:25 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:29 desktop kernel: amdgpu_cs_ioctl: 175 callbacks suppressed
Jun 15 01:21:29 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:30 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:34 desktop kernel: amdgpu_cs_ioctl: 174 callbacks suppressed
Jun 15 01:21:34 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:35 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:39 desktop kernel: amdgpu_cs_ioctl: 173 callbacks suppressed
Jun 15 01:21:39 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:40 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:45 desktop kernel: amdgpu_cs_ioctl: 172 callbacks suppressed
Jun 15 01:21:45 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:50 desktop kernel: amdgpu_cs_ioctl: 172 callbacks suppressed
Jun 15 01:21:50 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:21:56 desktop kernel: amdgpu_cs_ioctl: 152 callbacks suppressed
Jun 15 01:21:56 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:22:01 desktop kernel: amdgpu_cs_ioctl: 249 callbacks suppressed
Jun 15 01:22:01 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:22:13 desktop kernel: amdgpu_cs_ioctl: 41 callbacks suppressed
Jun 15 01:22:13 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:22:14 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:22:19 desktop kernel: amdgpu_cs_ioctl: 625 callbacks suppressed
Jun 15 01:22:19 desktop kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jun 15 01:22:30 desktop audit[4757]: USER_AUTH pid=4757 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="anon" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=/>
Jun 15 01:22:30 desktop dbus-daemon[863]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.80' (uid=0 pid=4757 comm="sudo restart ")
Jun 15 01:22:30 desktop kernel: kauditd_printk_skb: 147 callbacks suppressed
Jun 15 01:22:30 desktop kernel: audit: type=1100 audit(1623734550.972:174): pid=4757 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="anon" exe="/usr/bin/sudo" hostn>
Jun 15 01:22:30 desktop kernel: audit: type=1101 audit(1623734550.975:175): pid=4757 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="anon" exe="/usr/bin/sudo" hostname=desktop >
Jun 15 01:22:30 desktop audit[4757]: USER_ACCT pid=4757 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="anon" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=/dev/tty2 res>
Jun 15 01:22:30 desktop dbus-daemon[863]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jun 15 01:22:37 desktop dbus-daemon[863]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.81' (uid=0 pid=4759 comm="sudo shutdown --help ")
Jun 15 01:22:37 desktop dbus-daemon[863]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jun 15 01:22:37 desktop audit[4759]: USER_ACCT pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="anon" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=/dev/tty2 res>
Jun 15 01:22:37 desktop audit[4759]: CRED_REFR pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=>
Jun 15 01:22:37 desktop kernel: audit: type=1101 audit(1623734557.978:176): pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="anon" exe="/usr/bin/sudo" hostname=desktop >
Jun 15 01:22:37 desktop kernel: audit: type=1110 audit(1623734557.978:177): pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" host>
Jun 15 01:22:37 desktop audit[4759]: USER_START pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=/dev/tty>
Jun 15 01:22:37 desktop kernel: audit: type=1105 audit(1623734557.985:178): pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=desk>
Jun 15 01:22:38 desktop audit[4759]: USER_END pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=/dev/tty2>
Jun 15 01:22:38 desktop audit[4759]: CRED_DISP pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=>
Jun 15 01:22:38 desktop kernel: audit: type=1106 audit(1623734558.035:179): pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=des>
Jun 15 01:22:38 desktop kernel: audit: type=1104 audit(1623734558.035:180): pid=4759 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" host>
Jun 15 01:22:43 desktop dbus-daemon[863]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.82' (uid=0 pid=4762 comm="sudo shutdown -r now ")
Jun 15 01:22:43 desktop dbus-daemon[863]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jun 15 01:22:43 desktop audit[4762]: USER_ACCT pid=4762 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="anon" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=/dev/tty2 res>
Jun 15 01:22:43 desktop audit[4762]: CRED_REFR pid=4762 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=>
Jun 15 01:22:43 desktop kernel: audit: type=1101 audit(1623734563.036:181): pid=4762 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="anon" exe="/usr/bin/sudo" hostname=desktop >
Jun 15 01:22:43 desktop kernel: audit: type=1110 audit(1623734563.036:182): pid=4762 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" host>
Jun 15 01:22:43 desktop audit[4762]: USER_START pid=4762 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=desktop addr=? terminal=/dev/tty>
Jun 15 01:22:43 desktop kernel: audit: type=1105 audit(1623734563.039:183): pid=4762 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=desk>
Jun 15 01:22:43 desktop systemd[1]: Stopping Session 2 of user anon.
I have no idea how to downgrade firmwares or stuff like that, i never touch the internals, i need a fix or a baby steps walkthrough
Here are your steps:
  1. pacman -S yay #(or install similar AUR-tool if not already installed)
  2. optional: yay -Syu #(will update your system)
  3. yay -S downgrade #(install downgrade)
  4. sudo downgrade --ala-only linux-firmware
  5. select option from march (36) or earlier
  6. optional: [Y] set linux-firmware on ignore list, to prevent future updates
  7. optional: reboot to immediately apply changes
I’ve been using linux-firmware 20210609, which is available on the testing branch, for two days now; and everything seems to be running fine. Perhaps a few more testers can pitch in.
No new amdgpu-firmware-files since end of April 21 (except for polaris) (see here: kernel/git/firmware/linux-firmware.git - Repository of firmware blobs for use with the Linux kernel), so how could an updated firmwarepackage fix this?
AMD’s dev (or maintainer) Alex asked in their bugtracker for help to find the exact file causing this. So the location of that bug is not yet identified.
I spoke too soon. 20210609 offered its first crash today. One thing I’ve noticed, the crashes only occur when the room temp is hot. When I have the A/C turned on, it’s very rare too see a crash.
Don’t forget to update bios if is possible. Bios updates solved my crash problems too.
Big +1 to @Devastator 's advice! I’m the OP here and I didn’t want to speak to soon for the Nth time since I first wrote this, but I’m happy to state that I haven’t experienced random freezes/crashes for more than a month now.
I don’t know what did the trick, but I’d suggest everyone to use a kernel that has the int-casting fix mentioned earlier here (I’m using the latest image for 5.12 kernel) and update BIOS firmware. I’m also running the latest mesa drivers, but don’t know how stable they are.
Will leave this post open as much as I can, so anybody can post or comment their experiences here and, hopefully, find help on this issue family.
Can you post what kernel and mesa you’re on? I was in on this early and am hesitant to rollback my linux firmware to 202012xx version if I can avoid it. And I don’t want to move to another OS, especially if the problem isn’t Manjaro-related, if that makes sense.
Sure! Sorry for the delay. Here are my specs for what you asked:
mesa 1.2-1
kernel 5.12.9-1-MANJARO
manjaro-firmware 20160419-1
I don’t have a linux-firmware package installed (or at least none than I can list), but I guess manjaro-firmware suffices.
Hi,
I’m still having issues with freezes with my Lenovo E595 which uses a AMD Ryzen 3700U.
My packages:
mesa 21.1.2-1
linux-firmware 20210518.r1928.f846292-1
When I’m fast enough, I’m able to prevent a full freeze by switching to another terminal via Ctrl+Alt+F*.
Kind regards
Well … it is true that the crashes have not been as common as in April, but the truth is that they still persist …
In the last week, I would say that they have happened to me two or three times, be it editing documents, in the browser or working on PSPP. They are still random, and true, it takes a while for them to happen, but this week that I have had to use the laptop more than usual, part of my work has been lost … three times … not so much like in April, but yeah … (sigh)
It’s amazing that it keeps happening because I can’t afford to lose so much work so often. And due to the hardware of my computer and the configurations that I have, I can only wait for it to stabilize completely in the future. I keep hoping it will be soon.
Oh well. I will keep pressing on the stable updates announcements. Does the same thing keep still happening to anyone?
Thanks everyone for your effort. Greetings.
Hi! Did you try downgrade linux-firmware package?
I have been experiencing same problem. I installed linux510 kernel and the system hasn’t crashed till now .
Please try installing linux510 kernel.
I also downgraded from kernel 5.13 to 5.10 (and use linux-firmware-20210208) and my problems are gone on my lenovo e585 ryzen 2500u.
Well, Update: I just got another crash… Maybe this is another issue and related to the USB-C dockingstation?
kernel: NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
Sorry, what are you running to get these outputs? I know I’m running kernel 5.10.42-1
In case https://gitlab.freedesktop.org/mesa/mesa/-/issues/4866 is the identical error, it could be solved in mesa-21.1.4 (or using their patch for earlier mesa versions).
Hello Hans12 thanks for posting this update, looks like they fixed the issue with the indication in the link below.
Posted from John Smith
John Smith @meep · 3 weeks ago
file: src/mesa/main/draw.c
function: validate_draw_arrays
change:
if (count < 0 || numInstances < 0)
into:
if (count <= 0 || numInstances <= 0)
I don’t know how to patch and recompile the Mesa, if anyone could indicate to a noob like me how to do it, I could try this patch and post if it fixes my issue too or not, maybe other mates can try too.
I edited this post to correct the language but also to say that the MESA 21.1.4 was released yesterday, so probably we are close to fix it thought updates, at least I hope so (crossing fingers).
https://mesa3d.org
Mesa 21.1.4 is released - June 30, 2021
