I’m a recent Manjaro convert (from Ubuntu / PopOS). Loving it so far except for one annoying issue that I can’t seem to resolve despite trying other solutions I have found.
After I log back into an XFCE session following resuming from either suspend or even just a locked screen, the whole laptop is freezing for 2-3 seconds.
In these 2-3 second periods, no input is accepted and things such as video playback pause. It is the same behavior whether the laptop is plugged in or on battery power.
What could be causing this?
Here is the output of:
free --human
for szFile in /proc/*/status ; do
awk '/VmSwap|Name/{printf $2 "\t" $3}END{ print "" }' "$szFile"
done | sort --key 2 --numeric --reverse | head --lines=20
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=be05bae9-9227-4ba4-9331-907d401f94ea rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: LENOVO product: 20TK001JUS v: ThinkPad X1 Extreme Gen 3
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20TK001JUS v: SDK0T08861 WIN serial: <filter>
UEFI: LENOVO v: N2VET30W (1.15 ) date: 04/15/2021
ID-1: BAT0 charge: 63.2 Wh (88.5%) condition: 71.4/80.0 Wh (89.2%)
volts: 16.4 min: 15.4 model: Celxpert 5B10X19050 type: Li-poly
serial: <filter> status: Discharging cycles: 185
RAM: total: 31 GiB used: 17.65 GiB (56.9%)
Info: 8-Core model: Intel Core i9-10885H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E6
cache: L2: 16 MiB bogomips: 76816
Speed: 800 MHz min/max: 800/5300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:2
chip-ID: 04f2:b6cb class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:06c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 4000 bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IF-ID-1: br-e5733e6b6a36 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:8
chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 953.87 GiB used: 248.5 GiB (26.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L7
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 5M2QEXF7 temp: 39.9 C
scheme: GPT
ID-1: / raw-size: 359.24 GiB size: 352.54 GiB (98.13%)
used: 14.51 GiB (4.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: be05bae9-9227-4ba4-9331-907d401f94ea
ID-2: /boot/efi raw-size: 498 MiB size: 497 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 5804-DF56
ID-3: /home raw-size: 586.13 GiB size: 575.87 GiB (98.25%)
used: 233.99 GiB (40.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 1af26a92-2dda-48af-8eae-d95e843a93ac
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: e5a334f7-f6b8-43ac-8f5c-c1fc0d4077be
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 4 GiB fs: <superuser required>
label: N/A uuid: 4858-10A4
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-8:2 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6cb
Device-2: 1-9:3 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-3: 1-14:8 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 49.0 C mobo: 48.0 C
Fan Speeds (RPM): cpu: 2780 fan-2: 2526
Processes: 537 Uptime: 10h 03m wakeups: 28 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1150 pacman: 1102 lib: 297
flatpak: 32 snap: 16 Shell: Bash v: 5.1.8 running-in: xfce4-terminal
inxi: 3.3.04
total used free shared buff/cache available
Mem: 30Gi 15Gi 7.5Gi 2.0Gi 8.4Gi 13Gi
Swap: 4.0Gi 0B 4.0Gi
zypak-sandbox 0 kB
zswap-shrink
zswap1
zswap1
ZoomLauncher 0 kB
zoom 0 kB
Xorg 0 kB
xiccd 0 kB
xfwm4 0 kB
xfsettingsd 0 kB
xfdesktop 0 kB
xfconfd 0 kB
xfce4-terminal 0 kB
xfce4-session 0 kB
xfce4-power-man 0 kB
xfce4-panel 0 kB
xfce4-notifyd 0 kB
xfce4-notes 0 kB
xfce4-display-s 0 kB
xfce4-clipman 0 kB
I honestly, didn’t even think to check on this since it seemed like such a mundane device.
