UPDATE: i’m calling this solved - looks like it was a incorrect memory frequency setting in setup/BIOS … how that got changed i don’t know
suddenly i’m experiencing system freezes with no way to recover other than a hard reset - there have been no hardware changes and this fairly new system was stable for many months prior
i’m seeing many of the following in the log…
$ sudo journalctl -p 3 -xb
[sudo] password for atom:
-- Journal begins at Fri 2021-08-20 16:10:31 EDT, ends at Sat 2021-08-21 08:44:23 EDT. --
Aug 21 08:33:15 atompc kernel: __swap_info_get: Bad swap offset entry 3fffffeffffff
Aug 21 08:33:15 atompc kernel: BUG: Bad page map in process plasmashell pte:200000000 pmd:10e51a067
Aug 21 08:33:15 atompc kernel: addr:00007fc868048000 vm_flags:08000071 anon_vma:0000000000000000 mapping:ffffa09e253b9e78 index:d4
Aug 21 08:33:15 atompc kernel: file:libKF5WaylandClient.so.5.85.0 fault:ext4_filemap_fault [ext4] mmap:ext4_file_mmap [ext4] readpage:ext4_readpage [ext4]
Aug 21 08:33:15 atompc kernel: addr:00007fc868049000 vm_flags:08000071 anon_vma:0000000000000000 mapping:ffffa09e253b9e78 index:d5
Aug 21 08:33:15 atompc kernel: __swap_info_get: Bad swap offset entry 3fffff8ffffff
Aug 21 08:33:15 atompc kernel: BUG: Bad page map in process plasmashell pte:e00000000 pmd:10e51a067
Aug 21 08:33:15 atompc kernel: addr:00007fc86804a000 vm_flags:08000071 anon_vma:0000000000000000 mapping:ffffa09e253b9e78 index:d6
Aug 21 08:33:15 atompc kernel: __swap_info_get: Bad swap offset entry 3fffff97fffff
Aug 21 08:33:15 atompc kernel: BUG: Bad page map in process plasmashell pte:d00000000 pmd:10e51a067
Aug 21 08:33:15 atompc kernel: addr:00007fc86804b000 vm_flags:08000071 anon_vma:0000000000000000 mapping:ffffa09e253b9e78 index:d7
Aug 21 08:33:15 atompc kernel: __swap_info_get: Bad swap offset entry 3ffffff7fffff
Aug 21 08:33:15 atompc kernel: BUG: Bad page map in process plasmashell pte:100000000 pmd:10e51a067
Aug 21 08:33:15 atompc kernel: addr:00007fc86804c000 vm_flags:08000070 anon_vma:0000000000000000 mapping:ffffa09e253b9e78 index:d8
Aug 21 08:33:15 atompc kernel: BUG: Bad page map in process plasmashell pte:800000075a370805 pmd:10e51a067
Aug 21 08:33:15 atompc kernel: addr:00007fc86804e000 vm_flags:08100071 anon_vma:ffffa09e0efe4478 mapping:ffffa09e253b9e78 index:d9
Aug 21 08:33:15 atompc kernel: BUG: Bad page map in process plasmashell pte:800000075a371805 pmd:10e51a067
Aug 21 08:33:15 atompc kernel: addr:00007fc86804f000 vm_flags:08100071 anon_vma:ffffa09e0efe4478 mapping:ffffa09e253b9e78 index:da
Aug 21 08:33:15 atompc kernel: BUG: Bad rss-counter state mm:00000000bec5336d type:MM_FILEPAGES val:-1
Aug 21 08:33:15 atompc kernel: BUG: Bad rss-counter state mm:00000000bec5336d type:MM_ANONPAGES val:3
Aug 21 08:33:15 atompc kernel: BUG: Bad rss-counter state mm:00000000bec5336d type:MM_SWAPENTS val:-5
KDE Plasma Version: 5.22.4
KDE Frameworks Version: 5.85.0
Qt Version: 5.15.2
Kernel Version: 5.13.11-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × AMD Ryzen 5 3400G with Radeon Vega Graphics
Memory: 13.6 GiB of RAM
Graphics Processor: AMD Radeon™ Vega 11 Graphics
Thank you for sharing!
