I’ve install Manjaro on my PC, and most time it works fine. But there’s several times when I use mouse move to trigger a wake up from the suspend state, the monitor light up but with black screen, no matter what I press on keyboard or click with mouse, there’s no response. And I’ve read the REISUB guide, which only works when the system running normal. When the system frozen, the magic SysRq key not working too. Every time it end up by long pressing the power key to shut it down.
I can’t find what cause the freeze, and most of the time when it works fine when wake up from suspend.
Here’s some information of my system
Kernel: 5.15.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d7979963-91a3-48f3-afce-65b1c515e1a1 rw quiet
resume=UUID=5303de4c-57ac-41ae-a929-8a6b37b7e0a3 udev.log_priority=3
sysrq_always_enabled=1
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop System: ASUS product: N/A v: N/A serial:
Mobo: ASUSTeK model: TUF GAMING B660M-PLUS WIFI v: Rev 1.xx
serial: UEFI: American Megatrends v: 2012
date: 10/11/2022
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 31.09 GiB used: 4.47 GiB (14.4%)
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x10E
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 867 high: 1102 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 1101 3: 1101
4: 1101 5: 1100 6: 1100 7: 1101 8: 1101 9: 1100 10: 1100 11: 1100 12: 1101
13: 1101 14: 1100 15: 1102 16: 1100 17: 400 18: 400 19: 400 20: 400 21: 400
22: 400 23: 400 24: 400 bogomips: 164088
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:2216 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.00x22.52")
s-diag: 1166mm (45.9")
Monitor-1: DP-2 res: 3840x2160 hz: 60 dpi: 140
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX
3080/PCIe/SSE2 direct-render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:1aef class-ID: 0403
Sound API: ALSA v: k5.15.94-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
IF: wlo1 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
broadcast:
Message: Output throttled. IPs: 4; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-1: docker0 state: down mac:
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
WAN IP:
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: N/A v: N/A port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 1.82 TiB used: 504.36 GiB (27.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: EXCERIA PRO SSD
lanes: 4 type: SSD serial: rev: EIFA10.1 temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial:
rev: 731030WD temp: 32.9 C scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 35.76 GiB (73.1%)
fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:8 label: N/A
uuid: d7979963-91a3-48f3-afce-65b1c515e1a1
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
label: NO_LABEL uuid: 8F4A-93C4
ID-3: /home raw-size: 849.02 GiB size: 834.62 GiB (98.30%)
used: 468.6 GiB (56.1%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:9
label: N/A uuid: 3afff1ed-8f37-46d0-b0d0-767be9c957e2
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p2 maj-min: 259:7 label: N/A
uuid: 5303de4c-57ac-41ae-a929-8a6b37b7e0a3
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: C698-5737
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs:
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 930.82 GiB fs: ntfs label: N/A
uuid: EA14A23014A20025
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 591 MiB fs: ntfs label: N/A
uuid: 46C40C78C40C6D0D
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:2 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:19af class-ID: 0300 serial:
Hub-2: 1-10:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-14:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 9 rev: 3.1 speed: 20 Gb/s
Hub-4: 2-9:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 3-1:2 info: Texas Instruments ports: 6 rev: 2.1 speed: 480 Mb/s
chip-ID: 0451:8442 class-ID: 0900
Device-1: 3-1.2:3 info: STMicro 87EC-XRGB type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 0483:5131 class-ID: 0300 serial:
Device-2: 3-1.4:4 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c53f class-ID: 0300
Device-3: 3-1.5:5 info: Texas Instruments type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 0451:82ff class-ID: 0300 serial:
Hub-7: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 4-1:2 info: Texas Instruments ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 0451:8440 class-ID: 0900
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 33 C
Processes: 438 Uptime: 40m wakeups: 7 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 alt: 11 clang: 15.0.7 Packages:
pm: pacman pkgs: 1199 libs: 346 tools: gnome-software,pamac,yay pm: pkg
pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.25
journalctl --system --boot=-1 | tail --lines=50
3月 07 15:43:44 pc-mj bluetoothd[804]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to F8:5C:7E:2A:0D:E8: Host is down (112)
3月 07 15:43:44 pc-mj bluetooth-autoconnect[803]: error connecting to device /org/bluez/hci0/dev_F8_5C_7E_2A_0D_E8: br-connection-page-timeout
3月 07 15:43:45 pc-mj systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
3月 07 15:43:45 pc-mj audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
3月 07 15:43:45 pc-mj kernel: audit: type=1131 audit(1678175025.213:5731): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
3月 07 15:43:45 pc-mj kernel: iwlwifi 0000:00:14.3: Got NSS = 4 - trimming to 2
3月 07 15:43:47 pc-mj bluetooth-autoconnect[803]: successfully connected to device /org/bluez/hci0/dev_B8_D5_0B_E4_A5_D8
3月 07 15:43:48 pc-mj kernel: input: JBL Charge 3 (AVRCP) as /devices/virtual/input/input166
3月 07 15:43:48 pc-mj systemd-logind[808]: Watching system buttons on /dev/input/event26 (JBL Charge 3 (AVRCP))
3月 07 15:43:50 pc-mj bluetoothd[804]: /org/bluez/hci0/dev_B8_D5_0B_E4_A5_D8/sep1/fd37: fd(29) ready
3月 07 15:43:50 pc-mj rtkit-daemon[993]: Supervising 5 threads of 4 processes of 1 users.
3月 07 15:43:50 pc-mj rtkit-daemon[993]: Successfully made thread 676687 of process 1650 owned by ‘1000’ RT at priority 5.
3月 07 15:43:50 pc-mj rtkit-daemon[993]: Supervising 6 threads of 4 processes of 1 users.
3月 07 15:43:51 pc-mj kernel: logitech-hidpp-device 0003:046D:4074.0087: HID++ 4.2 device connected.
3月 07 15:43:54 pc-mj bluetooth-autoconnect[803]: error connecting to device /org/bluez/hci0/dev_80_C3_BA_2A_3C_55: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
3月 07 15:44:36 pc-mj audit: BPF prog-id=2406 op=UNLOAD
3月 07 15:44:36 pc-mj kernel: audit: type=1334 audit(1678175076.980:5732): prog-id=2406 op=UNLOAD
3月 07 15:44:37 pc-mj audit: BPF prog-id=2407 op=UNLOAD
3月 07 15:44:37 pc-mj kernel: audit: type=1334 audit(1678175077.103:5733): prog-id=2407 op=UNLOAD
3月 07 15:44:54 pc-mj audit: BPF prog-id=2408 op=LOAD
3月 07 15:44:54 pc-mj audit[811]: SYSCALL arch=c000003e syscall=321 success=yes exit=27 a0=5 a1=7ffd6005e440 a2=90 a3=22 items=0 ppid=1 pid=811 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm=“NetworkManager” exe=“/usr/bin/NetworkManager” key=(null)
3月 07 15:44:54 pc-mj audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
3月 07 15:44:54 pc-mj kernel: audit: type=1334 audit(1678175094.517:5734): prog-id=2408 op=LOAD
3月 07 15:44:54 pc-mj kernel: audit: type=1300 audit(1678175094.517:5734): arch=c000003e syscall=321 success=yes exit=27 a0=5 a1=7ffd6005e440 a2=90 a3=22 items=0 ppid=1 pid=811 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm=“NetworkManager” exe=“/usr/bin/NetworkManager” key=(null)
3月 07 15:44:54 pc-mj kernel: audit: type=1327 audit(1678175094.517:5734): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
3月 07 15:45:02 pc-mj kernel: sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) show-blocked-tasks(w) dump-ftrace-buffer(z)
3月 07 15:45:04 pc-mj audit: BPF prog-id=2409 op=LOAD
3月 07 15:45:04 pc-mj kernel: audit: type=1334 audit(1678175104.090:5735): prog-id=2409 op=LOAD
3月 07 15:45:04 pc-mj kernel: audit: type=1300 audit(1678175104.090:5735): arch=c000003e syscall=321 success=yes exit=38 a0=5 a1=7ffd6005e440 a2=90 a3=eb items=0 ppid=1 pid=811 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm=“NetworkManager” exe=“/usr/bin/NetworkManager” key=(null)
3月 07 15:45:04 pc-mj kernel: audit: type=1327 audit(1678175104.090:5735): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
3月 07 15:45:04 pc-mj audit[811]: SYSCALL arch=c000003e syscall=321 success=yes exit=38 a0=5 a1=7ffd6005e440 a2=90 a3=eb items=0 ppid=1 pid=811 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm=“NetworkManager” exe=“/usr/bin/NetworkManager” key=(null)
3月 07 15:45:04 pc-mj audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
3月 07 15:45:37 pc-mj audit: BPF prog-id=2408 op=UNLOAD
3月 07 15:45:37 pc-mj kernel: audit: type=1334 audit(1678175137.973:5736): prog-id=2408 op=UNLOAD
3月 07 15:45:48 pc-mj audit: BPF prog-id=2410 op=LOAD
3月 07 15:45:48 pc-mj kernel: audit: type=1334 audit(1678175148.973:5737): prog-id=2410 op=LOAD
3月 07 15:45:48 pc-mj kernel: audit: type=1300 audit(1678175148.973:5737): arch=c000003e syscall=321 success=yes exit=34 a0=5 a1=7ffd6005e440 a2=90 a3=22 items=0 ppid=1 pid=811 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm=“NetworkManager” exe=“/usr/bin/NetworkManager” key=(null)
3月 07 15:45:48 pc-mj kernel: audit: type=1327 audit(1678175148.973:5737): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
3月 07 15:45:48 pc-mj audit[811]: SYSCALL arch=c000003e syscall=321 success=yes exit=34 a0=5 a1=7ffd6005e440 a2=90 a3=22 items=0 ppid=1 pid=811 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm=“NetworkManager” exe=“/usr/bin/NetworkManager” key=(null)
3月 07 15:45:48 pc-mj audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
3月 07 15:47:44 pc-mj audit: BPF prog-id=2410 op=UNLOAD
3月 07 15:47:44 pc-mj kernel: audit: type=1334 audit(1678175264.980:5738): prog-id=2410 op=UNLOAD
3月 07 15:48:03 pc-mj audit: BPF prog-id=2411 op=LOAD
3月 07 15:48:03 pc-mj audit[811]: SYSCALL arch=c000003e syscall=321 success=yes exit=34 a0=5 a1=7ffd6005e440 a2=90 a3=22 items=0 ppid=1 pid=811 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm=“NetworkManager” exe=“/usr/bin/NetworkManager” key=(null)
3月 07 15:48:03 pc-mj audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
3月 07 15:48:03 pc-mj kernel: audit: type=1334 audit(1678175283.550:5739): prog-id=2411 op=LOAD
3月 07 15:48:03 pc-mj kernel: audit: type=1300 audit(1678175283.550:5739): arch=c000003e syscall=321 success=yes exit=34 a0=5 a1=7ffd6005e440 a2=90 a3=22 items=0 ppid=1 pid=811 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm=“NetworkManager” exe=“/usr/bin/NetworkManager” key=(null)
3月 07 15:48:03 pc-mj kernel: audit: type=1327 audit(1678175283.550:5739): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
3月 07 15:48:56 pc-mj systemd-logind[808]: Power key pressed short.
3月 07 15:48:58 pc-mj systemd-logind[808]: Power key pressed short.
