Good day,
I switched from Manjaro Cinnamon to Manjaro Gnome and have a small but annoying problem:
after login my system freezes for about 5 seconds and after that it works normal so far.
of course I looked directly at the journalctl and this happens at the login:
Jun 30 10:25:02 mt-pc gnome-shell[22357]: GNOME Shell started at Fri Jun 30 2023 10:25:00 GMT+0200 (Central European Summer Time)
Jun 30 10:25:02 mt-pc gnome-shell[22357]: Registering session with GDM
Jun 30 10:25:02 mt-pc pulseaudio[21834]: X11 I/O error handler called
Jun 30 10:25:02 mt-pc pulseaudio[21834]: X11 I/O error exit handler called, preparing to tear down X11 modules
Jun 30 10:25:02 mt-pc gnome-session[21762]: gnome-session-binary[21762]: GLib-CRITICAL: g_hash_table_foreach_remove_or_steal: assertion 'version == hash_table->version' failed
Jun 30 10:25:02 mt-pc gnome-session-binary[21762]: GLib-CRITICAL: g_hash_table_foreach_remove_or_steal: assertion 'version == hash_table->version' failed
Jun 30 10:25:02 mt-pc gsd-smartcard[21880]: Error releasing name org.gnome.SettingsDaemon.Smartcard: The connection is closed
Jun 30 10:25:02 mt-pc gsd-print-notif[21878]: Error releasing name org.gnome.SettingsDaemon.PrintNotifications: The connection is closed
Jun 30 10:25:02 mt-pc gnome-shell[21772]: Connection to xwayland lost
Jun 30 10:25:02 mt-pc gnome-shell[21772]: Xwayland terminated, exiting since it was mandatory
Jun 30 10:25:02 mt-pc gnome-shell[21772]: (../mutter/src/core/meta-context.c:501):meta_context_terminate: runtime check failed: (g_main_loop_is_running (priv->main_loop))
Jun 30 10:25:02 mt-pc gsd-datetime[21888]: Error releasing name org.gnome.SettingsDaemon.Datetime: The connection is closed
Jun 30 10:25:02 mt-pc gsd-screensaver[21894]: Error releasing name org.freedesktop.ScreenSaver: The connection is closed
Jun 30 10:25:02 mt-pc gsd-sharing[21859]: Error releasing name org.gnome.SettingsDaemon.Sharing: The connection is closed
Jun 30 10:25:02 mt-pc gnome-shell[21772]: Lost or failed to acquire name org.gnome.Mutter.ServiceChannel
Jun 30 10:25:02 mt-pc systemd[1]: Stopping Session 26 of User gdm...
Jun 30 10:25:02 mt-pc dbus-daemon[22213]: [session uid=1000 pid=22213] Successfully activated service 'org.freedesktop.Tracker3.Miner.Extract'
Jun 30 10:25:02 mt-pc systemd[22191]: Started Tracker metadata extractor.
Jun 30 10:25:02 mt-pc polkitd[544]: Unregistered Authentication Agent for unix-session:26 (system bus name :1.1003, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Jun 30 10:25:02 mt-pc systemd[1]: session-26.scope: Deactivated successfully.
Jun 30 10:25:02 mt-pc systemd[1]: Stopped Session 26 of User gdm.
Jun 30 10:25:02 mt-pc systemd[1]: session-26.scope: Consumed 2.900s CPU time.
Jun 30 10:25:02 mt-pc systemd-logind[545]: Removed session 26.
Jun 30 10:25:02 mt-pc gdm[603]: Gdm: Child process -21755 was already dead.
Jun 30 10:25:03 mt-pc rtkit-daemon[751]: Supervising 9 threads of 3 processes of 2 users.
Jun 30 10:25:03 mt-pc rtkit-daemon[751]: Successfully made thread 23400 of process 22807 owned by '1000' RT at priority 10.
Jun 30 10:25:03 mt-pc rtkit-daemon[751]: Supervising 10 threads of 4 processes of 2 users.
Jun 30 10:25:03 mt-pc thunderbird.desktop[22807]: console.debug: "Found 0 public keys and 0 secret keys (0 protected, 0 unprotected)"
Jun 30 10:25:03 mt-pc steam-native.desktop[22958]: Loaded SDL version 3.0.0-1782-g214d5daa3
Jun 30 10:25:03 mt-pc thunderbird.desktop[22807]: console.warn: services.settings: Failed to load last_modified.json: TypeError: NetworkError when attempting to fetch resource.
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): EDID vendor "HWP", prod id 12931
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Using hsync ranges from config file
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Using vrefresh ranges from config file
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Printing DDC gathered Modelines:
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
Jun 30 10:25:03 mt-pc /usr/lib/gdm-x-session[22217]: (--) AMDGPU(0): HDMI max TMDS frequency 170000KHz
Jun 30 10:25:03 mt-pc steam-native.desktop[22958]: GetWin32Stats: display was not open yet, good
Jun 30 10:25:03 mt-pc steam-native.desktop[23449]: steamwebhelper.sh[23449]: Runtime for steamwebhelper: disabled by environment (this is unsupported)
Jun 30 10:25:03 mt-pc steam-native.desktop[23449]: steamwebhelper.sh[23449]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
Jun 30 10:25:03 mt-pc rtkit-daemon[751]: Successfully made thread 23559 of process 22958 owned by '1000' high priority at nice level -10.
Jun 30 10:25:03 mt-pc rtkit-daemon[751]: Supervising 11 threads of 5 processes of 2 users.
Jun 30 10:25:03 mt-pc rtkit-daemon[751]: Successfully made thread 23560 of process 22958 owned by '1000' high priority at nice level -10.
Jun 30 10:25:03 mt-pc rtkit-daemon[751]: Supervising 12 threads of 5 processes of 2 users.
Jun 30 10:25:03 mt-pc rtkit-daemon[751]: Successfully made thread 23575 of process 22958 owned by '1000' high priority at nice level -10.
Jun 30 10:25:03 mt-pc rtkit-daemon[751]: Supervising 13 threads of 5 processes of 2 users.
Jun 30 10:25:04 mt-pc steam-native.desktop[22958]: CAppInfoCacheReadFromDiskThread took 99 milliseconds to initialize
Jun 30 10:25:04 mt-pc steam-native.desktop[22958]: Failed to init SteamVR because it isn't installed
Jun 30 10:25:04 mt-pc steam[22958]: gtk_disable_setlocale() must be called before gtk_init()
Jun 30 10:25:04 mt-pc steam-native.desktop[22958]: local (potentially out of sync) copy of roaming config loaded - 308 bytes.
Jun 30 10:25:04 mt-pc thunderbird.desktop[22807]: console.debug: "Trying to load /usr/lib/thunderbird/libotr.so"
Jun 30 10:25:04 mt-pc thunderbird.desktop[22807]: console.debug: "Trying to load libotr.so from system's standard library locations"
Jun 30 10:25:04 mt-pc thunderbird.desktop[22807]: console.debug: "Successfully loaded OTR library libotr.so from system's standard library locations"
Jun 30 10:25:05 mt-pc thunderbird.desktop[22807]: JavaScript error: , line 0: uncaught exception: Object
Jun 30 10:25:05 mt-pc steam-native.desktop[22958]: BRefreshApplicationsInLibrary 1: 28ms
Jun 30 10:25:05 mt-pc steam-native.desktop[22958]: roaming config store loaded successfully - 308 bytes.
Jun 30 10:25:05 mt-pc steam-native.desktop[22958]: migrating temporary roaming config store
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): EDID vendor "HWP", prod id 12931
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Using hsync ranges from config file
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Using vrefresh ranges from config file
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Printing DDC gathered Modelines:
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
Jun 30 10:25:05 mt-pc /usr/lib/gdm-x-session[22217]: (--) AMDGPU(0): HDMI max TMDS frequency 170000KHz
Jun 30 10:25:05 mt-pc steam[22958]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Jun 30 10:25:05 mt-pc steam[22958]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Jun 30 10:25:06 mt-pc steam-native.desktop[22958]: System startup time: 4.74 seconds
Jun 30 10:25:06 mt-pc steam-native.desktop[22958]: BuildCompleteAppOverviewChange: 862 apps
Jun 30 10:25:06 mt-pc steam-native.desktop[22958]: RegisterForAppOverview 1: 22ms
Jun 30 10:25:06 mt-pc steam-native.desktop[22958]: RegisterForAppOverview 2: 23ms
Jun 30 10:25:07 mt-pc steam-native.desktop[22958]: ExecCommandLine: "'/home/user/.local/share/Steam/ubuntu12_32/steam'"
Jun 30 10:25:07 mt-pc steam[22958]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Jun 30 10:25:07 mt-pc steam[22958]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Jun 30 10:25:12 mt-pc systemd[1]: Stopping User Manager for UID 120...
Jun 30 10:25:12 mt-pc systemd[21746]: Activating special unit Exit the Session...
Jun 30 10:25:12 mt-pc systemd[21746]: Stopped target Main User Target.
Jun 30 10:25:12 mt-pc systemd[21746]: Stopping D-Bus User Message Bus...
Jun 30 10:25:12 mt-pc systemd[21746]: Stopped D-Bus User Message Bus.
Jun 30 10:25:12 mt-pc systemd[21746]: Removed slice User Core Session Slice.
Jun 30 10:25:12 mt-pc systemd[21746]: Stopped target Basic System.
Jun 30 10:25:12 mt-pc systemd[21746]: Stopped target Paths.
Jun 30 10:25:12 mt-pc systemd[21746]: Stopped target Sockets.
Jun 30 10:25:12 mt-pc systemd[21746]: Stopped target Timers.
Jun 30 10:25:12 mt-pc systemd[21746]: Closed D-Bus User Message Bus Socket.
Jun 30 10:25:12 mt-pc systemd[21746]: Closed GnuPG network certificate management daemon.
Jun 30 10:25:12 mt-pc systemd[21746]: Closed GCR ssh-agent wrapper.
Jun 30 10:25:12 mt-pc systemd[21746]: Closed GNOME Keyring daemon.
Jun 30 10:25:12 mt-pc systemd[21746]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jun 30 10:25:12 mt-pc systemd[21746]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jun 30 10:25:12 mt-pc systemd[21746]: Closed GnuPG cryptographic agent (ssh-agent emulation).
passphrase cache.
Jun 30 10:25:12 mt-pc systemd[21746]: Closed p11-kit server.
Jun 30 10:25:12 mt-pc systemd[21746]: Closed PipeWire Multimedia System Socket.
Jun 30 10:25:12 mt-pc systemd[21746]: Closed Sound System.
Jun 30 10:25:12 mt-pc systemd[21746]: Removed slice User Application Slice.
Jun 30 10:25:12 mt-pc systemd[21746]: Reached target Shutdown.
Jun 30 10:25:12 mt-pc systemd[21746]: Finished Exit the Session.
Jun 30 10:25:12 mt-pc systemd[21746]: Reached target Exit the Session.
Jun 30 10:25:12 mt-pc (sd-pam)[21747]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[gdm] ruser=[<unknown>] rhost=[<unknown>]
Jun 30 10:25:12 mt-pc systemd[1]: user@120.service: Deactivated successfully.
Jun 30 10:25:12 mt-pc systemd[1]: Stopped User Manager for UID 120.
Jun 30 10:25:12 mt-pc systemd[1]: Stopping User Runtime Directory /run/user/120...
Jun 30 10:25:12 mt-pc systemd[1]: run-user-120.mount: Deactivated successfully.
Jun 30 10:25:12 mt-pc systemd[1]: user-runtime-dir@120.service: Deactivated successfully.
Jun 30 10:25:13 mt-pc systemd[1]: Stopped User Runtime Directory /run/user/120.
Jun 30 10:25:13 mt-pc systemd[1]: Removed slice User Slice of UID 120.
Jun 30 10:25:13 mt-pc systemd[1]: user-120.slice: Consumed 3.112s CPU time.
the freeze happens here, between 10:25:07 and 15:25:12:
I can’t really interpret what’s happening there and what could trigger it.
My System:
OS: Manjaro Linux x86_64
Host: X470 AORUS ULTRA GAMING
Kernel: 6.3.5-2-MANJARO
Uptime: 29 mins
Packages: 1773 (pacman), 26 (flatpak)
Shell: zsh 5.9
Resolution: 1920x1080, 2560x1440, 1920x1080
DE: GNOME 44.1
WM: Mutter
WM Theme: CustomAccentColors
Theme: Adw-dark [GTK2/3]
Icons: Papirus-Dark-Maia [GTK2/3]
Terminal: gnome-terminal
CPU: AMD Ryzen 5 5600X (12) @ 3.700GHz
GPU: AMD ATI Radeon RX 5600 OEM/5600 XT / 5700/5700 XT
Memory: 5179MiB / 64245MiB
