grub updated.
→ “clean” boot →
journalctl -b-1 -p4 --no-pager
Sep 21 02:34:56 BVB kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
Sep 21 02:34:56 BVB kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
Sep 21 02:34:56 BVB kernel: #7 #8 #9 #10 #11
Sep 21 02:34:56 BVB kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7._PRW], AE_ALREADY_EXISTS (20210730/dswload2-326)
Sep 21 02:34:56 BVB kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Sep 21 02:34:56 BVB kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP2._PRW], AE_ALREADY_EXISTS (20210730/dswload2-326)
Sep 21 02:34:56 BVB kernel: ACPI BIOS Error (bug): Failure creating named object [\_GPE._L08], AE_ALREADY_EXISTS (20210730/dswload2-326)
Sep 21 02:34:56 BVB kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Sep 21 02:34:56 BVB kernel: pci 0000:15:00.0: Failed to read data
Sep 21 02:34:56 BVB kernel: hub 10-0:1.0: config failed, hub doesn't have any ports! (err -19)
Sep 21 02:34:57 BVB kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.VGA.LCD._BCM.AFN7], AE_NOT_FOUND (20210730/psargs-330)
Sep 21 02:34:57 BVB kernel: ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 21 02:34:57 BVB kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Sep 21 02:34:57 BVB kernel: nvidia: loading out-of-tree module taints kernel.
Sep 21 02:34:57 BVB kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 21 02:34:57 BVB kernel: Disabling lock debugging due to kernel taint
Sep 21 02:34:57 BVB kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20210730/utaddress-204)
Sep 21 02:34:57 BVB kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 535.104.05 Sat Aug 19 01:15:15 UTC 2023
Sep 21 02:34:57 BVB kernel: iwlwifi 0000:0e:00.0: api flags index 2 larger than supported by driver
Sep 21 02:34:57 BVB kernel: kvm: disabled by bios
Sep 21 02:34:57 BVB kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Sep 21 02:34:57 BVB kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Sep 21 02:34:57 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support csip plugin
Sep 21 02:34:57 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support vcp plugin
Sep 21 02:34:57 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support mcp plugin
Sep 21 02:34:57 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support bass plugin
Sep 21 02:34:57 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support bap plugin
Sep 21 02:34:58 BVB kernel: hid-generic 0003:1532:0099.0008: No inputs registered, leaving
Sep 21 02:35:00 BVB sddm-greeter[781]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd0a0dccb0), parent's thread is QThread(0x5562fb9f7ef0), current thread is QThread(0x5562fbb4d990)
Sep 21 02:35:00 BVB sddm-greeter[781]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Sep 21 02:35:01 BVB sddm-greeter[781]: Failed to find a Kirigami platform plugin
Sep 21 02:35:01 BVB sddm-greeter[781]: file:///usr/share/sddm/themes/breeze/components/VirtualKeyboard.qml:12:1: Type InputPanel unavailable
Sep 21 02:35:01 BVB sddm-greeter[781]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Sep 21 02:35:01 BVB sddm-greeter[781]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Sep 21 02:35:01 BVB sddm-greeter[781]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Sep 21 02:35:01 BVB sddm-greeter[781]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.29'
Sep 21 02:35:01 BVB sddm-greeter[781]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.30'
Sep 21 02:35:06 BVB ksplashqml[852]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Sep 21 02:35:06 BVB ksplashqml[852]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Sep 21 02:35:06 BVB ksmserver[904]: Qt: Session management error: networkIdsList argument is NULL
Sep 21 02:35:06 BVB kwin_x11[907]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Sep 21 02:35:06 BVB kwin_x11[907]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Sep 21 02:35:06 BVB ksmserver[904]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
Sep 21 02:35:06 BVB kded5[906]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Sep 21 02:35:06 BVB plasmashell[942]: Checking screens: available: (QScreen(0x562f55f07ff0, name="DP-2"), QScreen(0x562f55f080e0, name="DP-4")) redundant: QHash() fake: QSet() all: (QScreen(0x562f55f07ff0, name="DP-2"), QScreen(0x562f55f080e0, name="DP-4"))
Sep 21 02:35:06 BVB plasmashell[942]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 21 02:35:06 BVB plasmashell[942]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 21 02:35:06 BVB backlighthelper[1014]: org.kde.powerdevil: no kernel backlight interface found
Sep 21 02:35:06 BVB org_kde_powerdevil[980]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 21 02:35:06 BVB org_kde_powerdevil[980]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Sep 21 02:35:07 BVB plasmashell[942]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 21 02:35:07 BVB plasmashell[942]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 21 02:35:07 BVB org_kde_powerdevil[980]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Sep 21 02:35:07 BVB org_kde_powerdevil[980]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Sep 21 02:35:07 BVB org_kde_powerdevil[980]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 21 02:35:07 BVB kded5[906]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Sep 21 02:35:07 BVB pulseaudio[1101]: stat('/etc/pulse/default.pa.d'): No such file or directory
Sep 21 02:35:08 BVB plasmashell[942]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 21 02:35:09 BVB plasmashell[942]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 21 02:35:09 BVB plasmashell[942]: Checking screens: available: (QScreen(0x562f55f080e0, name="DP-4"), QScreen(0x562f55f07ff0, name="DP-2")) redundant: QHash() fake: QSet() all: (QScreen(0x562f55f080e0, name="DP-4"), QScreen(0x562f55f07ff0, name="DP-2"))
Sep 21 02:35:10 BVB kwin_x11[907]: kwin_core: XCB error: 152 (BadDamage), sequence: 2404, resource id: 16777240, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 21 02:35:10 BVB plasmashell[942]: org.kde.plasma.kicker: DragHelper is deprecated and will be removed in Plasma 6. Use Qt Quick Drag instead.
Sep 21 02:35:10 BVB plasmashell[942]: org.kde.plasma.kicker: Kicker.WindowSystem is deprecated and will be removed in Plasma 6. Use KWindowSystem/KX11Extras instead.
Sep 21 02:35:10 BVB plasmashell[942]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Sep 21 02:35:10 BVB plasmashell[942]: org.kde.plasma.kicker: DashboardWindow is deprecated and will be removed in Plasma 6. Use Qt Quick Window instead.
Sep 21 02:35:10 BVB plasmashell[942]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 21 02:35:11 BVB kioslave5[1230]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Sep 21 02:35:11 BVB plasmashell[942]: file:///usr/share/plasma/plasmoids/org.kde.kscreen/contents/ui/main.qml:30:5: Unable to assign [undefined] to bool
Sep 21 02:35:11 BVB plasmashell[942]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Sep 21 02:35:11 BVB plasmashell[942]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Sep 21 02:35:11 BVB plasmashell[942]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
Sep 21 02:35:11 BVB plasmashell[942]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x562f582cac60) QQmlContext(0x562f580a3500) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 21 02:35:11 BVB plasmashell[942]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor"
Sep 21 02:35:12 BVB plasmashell[942]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 21 02:35:13 BVB plasmashell[942]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 21 02:35:14 BVB plasmashell[942]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 21 02:35:15 BVB plasmashell[942]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 21 02:35:23 BVB kstart5[1269]: Omitting both --window and --windowclass arguments is not recommended
Sep 21 02:35:30 BVB plasmashell[942]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x562f582dcca0) QQmlContext(0x562f580a3500) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 21 02:35:34 BVB kate[1319]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 02:35:46 BVB kate[1319]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 02:36:03 BVB kate[1319]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 02:37:12 BVB kate[1319]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 02:37:21 BVB kate[1319]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 02:37:55 BVB kernel: xhci_hcd 0000:15:00.0: xHCI host not responding to stop endpoint command.
Sep 21 02:37:55 BVB kernel: xhci_hcd 0000:15:00.0: USBSTS: 0x00000000
Sep 21 02:37:55 BVB kernel: xhci_hcd 0000:15:00.0: xHCI host controller not responding, assume dead
Sep 21 02:37:55 BVB kernel: xhci_hcd 0000:15:00.0: HC died; cleaning up
Sep 21 02:37:55 BVB kernel: xhci_hcd 0000:12:00.0: xHC error in resume, USBSTS 0x401, Reinit
Sep 21 02:37:55 BVB kernel: xhci_hcd 0000:10:00.0: xHC error in resume, USBSTS 0x401, Reinit
Sep 21 02:37:55 BVB kernel: done.
Sep 21 02:37:55 BVB kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Sep 21 02:37:55 BVB rtkit-daemon[895]: The canary thread is apparently starving. Taking action.
Sep 21 02:37:55 BVB rtkit-daemon[895]: Recovering from system lockup, not allowing further RT threads.
Sep 21 02:37:56 BVB rtkit-daemon[895]: Recovering from system lockup, not allowing further RT threads.
Sep 21 02:37:56 BVB plasmashell[942]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo"
Sep 21 02:37:56 BVB plasmashell[942]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor"
Sep 21 02:37:56 BVB plasmashell[942]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x562f585c8750) QQmlContext(0x562f580a3500) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 21 02:37:57 BVB plasmashell[942]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 21 02:38:01 BVB kwin_x11[907]: kwin_core: XCB error: 152 (BadDamage), sequence: 43428, resource id: 16787413, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 21 02:38:19 BVB kate[1319]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 02:38:25 BVB plasmashell[942]: trying to show an empty dialog
Sep 21 02:38:25 BVB plasmashell[942]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 21 02:38:47 BVB plasmashell[942]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 21 02:38:51 BVB systemsettings[1744]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Sep 21 02:38:51 BVB systemsettings[1744]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Sep 21 02:40:24 BVB plasmashell[942]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo"
Sep 21 02:40:24 BVB plasmashell[942]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor"
Sep 21 02:40:24 BVB plasmashell[942]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_14_00.6.iec958-stereo.monitor"
Sep 21 04:28:34 BVB plasmashell[942]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_14_00.6.iec958-stereo.monitor"
Sep 21 04:28:34 BVB plasmashell[942]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor"
Sep 21 04:28:53 BVB plasmashell[942]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
Sep 21 04:29:33 BVB kate[1319]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:29:53 BVB kate[1319]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:30:11 BVB kate[1319]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:30:20 BVB kded5[906]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Sep 21 04:30:20 BVB sddm[735]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Sep 21 04:30:20 BVB sddm[735]: Auth: sddm-helper (--socket /tmp/sddm-auth-f41a7a5d-a7da-4804-94e6-f93b229cbef7 --id 1 --start /usr/bin/startplasma-x11 --user max) crashed (exit code 1)
Sep 21 04:30:20 BVB sddm[735]: Auth: sddm-helper exited with 1
Sep 21 04:30:20 BVB sddm[735]: Signal received: SIGTERM
Sep 21 04:30:20 BVB dolphin[1272]: The X11 connection broke (error 1). Did the X11 server die?
Sep 21 04:30:20 BVB kwin_x11[907]: The X11 connection broke: I/O error (code 1)
Sep 21 04:30:20 BVB pulseaudio[1101]: Lost I/O connection in module "module-gsettings"
Sep 21 04:30:20 BVB systemd[820]: obex.service: Failed with result 'exit-code'.
Sep 21 04:30:20 BVB systemd-coredump[2538]: Failed to send coredump datagram: Connection reset by peer
Sep 21 04:30:20 BVB kate[1319]: The X11 connection broke (error 1). Did the X11 server die?
Sep 21 04:31:50 BVB systemd[820]: plasma-kwin_x11.service: State 'stop-sigterm' timed out. Killing.
Sep 21 04:31:50 BVB systemd[820]: plasma-kwin_x11.service: Main process exited, code=killed, status=9/KILL
Sep 21 04:31:50 BVB systemd[820]: plasma-kwin_x11.service: Failed with result 'timeout'.
Sep 21 04:31:51 BVB kernel: watchdog: watchdog0: watchdog did not stop!
→ sleep → wake up →
→ freeze → REISUB → “clean” boot →
Sep 21 04:32:39 BVB kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
Sep 21 04:32:39 BVB kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
Sep 21 04:32:39 BVB kernel: #7 #8 #9 #10 #11
Sep 21 04:32:39 BVB kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7._PRW], AE_ALREADY_EXISTS (20210730/dswload2-326)
Sep 21 04:32:39 BVB kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Sep 21 04:32:39 BVB kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP2._PRW], AE_ALREADY_EXISTS (20210730/dswload2-326)
Sep 21 04:32:39 BVB kernel: ACPI BIOS Error (bug): Failure creating named object [\_GPE._L08], AE_ALREADY_EXISTS (20210730/dswload2-326)
Sep 21 04:32:39 BVB kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Sep 21 04:32:39 BVB kernel: pci 0000:15:00.0: Failed to read data
Sep 21 04:32:39 BVB kernel: hub 10-0:1.0: config failed, hub doesn't have any ports! (err -19)
Sep 21 04:32:40 BVB kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Sep 21 04:32:40 BVB kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.VGA.LCD._BCM.AFN7], AE_NOT_FOUND (20210730/psargs-330)
Sep 21 04:32:40 BVB kernel: ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Sep 21 04:32:40 BVB kernel: nvidia: loading out-of-tree module taints kernel.
Sep 21 04:32:40 BVB kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 21 04:32:40 BVB kernel: Disabling lock debugging due to kernel taint
Sep 21 04:32:40 BVB kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20210730/utaddress-204)
Sep 21 04:32:40 BVB kernel: iwlwifi 0000:0e:00.0: api flags index 2 larger than supported by driver
Sep 21 04:32:40 BVB kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 535.104.05 Sat Aug 19 01:15:15 UTC 2023
Sep 21 04:32:40 BVB kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Sep 21 04:32:40 BVB kernel: kvm: disabled by bios
Sep 21 04:32:40 BVB kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Sep 21 04:32:40 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support csip plugin
Sep 21 04:32:40 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support vcp plugin
Sep 21 04:32:40 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support mcp plugin
Sep 21 04:32:40 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support bass plugin
Sep 21 04:32:40 BVB bluetoothd[642]: src/plugin.c:plugin_init() System does not support bap plugin
Sep 21 04:32:41 BVB kernel: hid-generic 0003:1532:0099.0008: No inputs registered, leaving
Sep 21 04:32:43 BVB sddm-greeter[772]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fff7c0f1330), parent's thread is QThread(0x555f49b88ef0), current thread is QThread(0x555f49cde900)
Sep 21 04:32:43 BVB sddm-greeter[772]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Sep 21 04:32:44 BVB sddm-greeter[772]: Failed to find a Kirigami platform plugin
Sep 21 04:32:44 BVB sddm-greeter[772]: file:///usr/share/sddm/themes/breeze/components/VirtualKeyboard.qml:12:1: Type InputPanel unavailable
Sep 21 04:32:44 BVB sddm-greeter[772]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Sep 21 04:32:44 BVB sddm-greeter[772]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Sep 21 04:32:44 BVB sddm-greeter[772]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Sep 21 04:32:44 BVB sddm-greeter[772]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.18'
Sep 21 04:32:44 BVB sddm-greeter[772]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.19'
Sep 21 04:32:49 BVB ksplashqml[843]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Sep 21 04:32:49 BVB ksplashqml[843]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Sep 21 04:32:49 BVB ksmserver[896]: Qt: Session management error: networkIdsList argument is NULL
Sep 21 04:32:49 BVB ksmserver[896]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
Sep 21 04:32:49 BVB kwin_x11[899]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Sep 21 04:32:49 BVB kwin_x11[899]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Sep 21 04:32:50 BVB kded5[898]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Sep 21 04:32:50 BVB plasmashell[933]: Checking screens: available: (QScreen(0x55d0e5a02960, name="DP-2"), QScreen(0x55d0e5a02a50, name="DP-4")) redundant: QHash() fake: QSet() all: (QScreen(0x55d0e5a02960, name="DP-2"), QScreen(0x55d0e5a02a50, name="DP-4"))
Sep 21 04:32:50 BVB plasmashell[933]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 21 04:32:50 BVB plasmashell[933]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 21 04:32:50 BVB backlighthelper[1005]: org.kde.powerdevil: no kernel backlight interface found
Sep 21 04:32:50 BVB org_kde_powerdevil[970]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 21 04:32:50 BVB org_kde_powerdevil[970]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Sep 21 04:32:50 BVB kded5[898]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
Sep 21 04:32:50 BVB org_kde_powerdevil[970]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Sep 21 04:32:50 BVB org_kde_powerdevil[970]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Sep 21 04:32:50 BVB kded5[898]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Sep 21 04:32:51 BVB plasmashell[933]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 21 04:32:51 BVB pulseaudio[1096]: stat('/etc/pulse/default.pa.d'): No such file or directory
Sep 21 04:32:52 BVB plasmashell[933]: Checking screens: available: (QScreen(0x55d0e5a02a50, name="DP-4"), QScreen(0x55d0e5a02960, name="DP-2")) redundant: QHash() fake: QSet() all: (QScreen(0x55d0e5a02a50, name="DP-4"), QScreen(0x55d0e5a02960, name="DP-2"))
Sep 21 04:32:53 BVB kwin_x11[899]: kwin_core: XCB error: 152 (BadDamage), sequence: 2488, resource id: 16777240, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 21 04:32:53 BVB plasmashell[933]: org.kde.plasma.kicker: DragHelper is deprecated and will be removed in Plasma 6. Use Qt Quick Drag instead.
Sep 21 04:32:53 BVB plasmashell[933]: org.kde.plasma.kicker: Kicker.WindowSystem is deprecated and will be removed in Plasma 6. Use KWindowSystem/KX11Extras instead.
Sep 21 04:32:53 BVB plasmashell[933]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Sep 21 04:32:54 BVB plasmashell[933]: org.kde.plasma.kicker: DashboardWindow is deprecated and will be removed in Plasma 6. Use Qt Quick Window instead.
Sep 21 04:32:54 BVB plasmashell[933]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 21 04:32:54 BVB kioslave5[1215]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Sep 21 04:32:54 BVB plasmashell[933]: file:///usr/share/plasma/plasmoids/org.kde.kscreen/contents/ui/main.qml:30:5: Unable to assign [undefined] to bool
Sep 21 04:32:54 BVB plasmashell[933]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Sep 21 04:32:54 BVB plasmashell[933]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Sep 21 04:32:54 BVB plasmashell[933]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
Sep 21 04:32:54 BVB plasmashell[933]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55d0ee2409d0) QQmlContext(0x55d0e6c337c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 21 04:32:54 BVB plasmashell[933]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor"
Sep 21 04:32:55 BVB plasmashell[933]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 21 04:32:56 BVB plasmashell[933]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 21 04:32:58 BVB plasmashell[933]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 21 04:32:59 BVB plasmashell[933]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 21 04:33:10 BVB kstart5[1262]: Omitting both --window and --windowclass arguments is not recommended
Sep 21 04:33:14 BVB plasmashell[933]: trying to show an empty dialog
Sep 21 04:33:21 BVB kstart5[1310]: Omitting both --window and --windowclass arguments is not recommended
Sep 21 04:33:37 BVB kate[1393]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:33:41 BVB kate[1393]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:33:55 BVB kate[1393]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:34:03 BVB kate[1393]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:35:02 BVB kernel: xhci_hcd 0000:15:00.0: xHCI host not responding to stop endpoint command.
Sep 21 04:35:02 BVB kernel: xhci_hcd 0000:15:00.0: USBSTS: 0x00000000
Sep 21 04:35:02 BVB kernel: xhci_hcd 0000:15:00.0: xHCI host controller not responding, assume dead
Sep 21 04:35:02 BVB kernel: xhci_hcd 0000:15:00.0: HC died; cleaning up
Sep 21 04:35:02 BVB kernel: xhci_hcd 0000:12:00.0: xHC error in resume, USBSTS 0x401, Reinit
Sep 21 04:35:02 BVB kernel: xhci_hcd 0000:10:00.0: xHC error in resume, USBSTS 0x401, Reinit
Sep 21 04:35:02 BVB kernel: clocksource: timekeeping watchdog on CPU1: Marking clocksource 'tsc' as unstable because the skew is too large:
Sep 21 04:35:02 BVB kernel: clocksource: 'hpet' wd_nsec: 498115821 wd_now: d0ad6b wd_last: 63d99b mask: ffffffff
Sep 21 04:35:02 BVB kernel: clocksource: 'tsc' cs_nsec: 503339113 cs_now: 4728d4bee cs_last: 3e7028c37 mask: ffffffffffffffff
Sep 21 04:35:02 BVB kernel: clocksource: 'tsc' is current clocksource.
Sep 21 04:35:02 BVB kernel: TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
Sep 21 04:35:02 BVB kernel: clocksource: Checking clocksource tsc synchronization from CPU 8 to CPUs 0,2,10-11.
Sep 21 04:35:02 BVB kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Sep 21 04:35:02 BVB rtkit-daemon[886]: The canary thread is apparently starving. Taking action.
Sep 21 04:35:02 BVB rtkit-daemon[886]: Recovering from system lockup, not allowing further RT threads.
Sep 21 04:35:03 BVB rtkit-daemon[886]: Recovering from system lockup, not allowing further RT threads.
Sep 21 04:35:03 BVB plasmashell[933]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo"
Sep 21 04:35:03 BVB plasmashell[933]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor"
Sep 21 04:35:03 BVB plasmashell[933]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:119: TypeError: Cannot call method 'hasOwnProperty' of undefined
Sep 21 04:35:04 BVB plasmashell[933]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55d0ee7b8390) QQmlContext(0x55d0e6c337c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 21 04:35:04 BVB kernel: igc 0000:0d:00.0 enp13s0: exceed max 2 second
Sep 21 04:35:17 BVB kstart5[1684]: Omitting both --window and --windowclass arguments is not recommended
Sep 21 04:35:33 BVB kate[1393]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:35:41 BVB kate[1393]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:35:55 BVB kate[1393]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Sep 21 04:36:20 BVB kernel: NVRM: GPU at PCI:0000:01:00: GPU-66c614e4-d5bb-2597-cb48-95b6ca4f1f02
Sep 21 04:36:20 BVB kernel: NVRM: Xid (PCI:0000:01:00): 79, pid='<unknown>', name=<unknown>, GPU has fallen off the bus.
Sep 21 04:36:20 BVB kernel: NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
Sep 21 04:36:34 BVB sddm-helper[808]: Signal received: SIGTERM
Sep 21 04:36:34 BVB sddm[725]: Signal received: SIGTERM
Sep 21 04:36:34 BVB kded5[898]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Sep 21 04:36:34 BVB sddm[725]: Auth: sddm-helper exited with 255
Sep 21 04:36:35 BVB systemd[1]: systemd-udevd.service: Main process exited, code=killed, status=9/KILL
Sep 21 04:36:35 BVB systemd[1]: systemd-udevd.service: Failed with result 'signal'.
Sep 21 04:36:35 BVB systemd[1]: cronie.service: Main process exited, code=killed, status=9/KILL
Sep 21 04:36:35 BVB systemd[1]: cronie.service: Failed with result 'signal'.
Sep 21 04:36:35 BVB systemd-journald[1893]: File /var/log/journal/a7f7b4f0f46c436599e420d154df2678/system.journal corrupted or uncleanly shut down, renaming and replacing.
Sep 21 04:36:35 BVB systemd[1]: user@1000.service: Main process exited, code=killed, status=9/KILL
Sep 21 04:36:35 BVB systemd[1]: user@1000.service: Failed with result 'signal'.
Sep 21 04:36:35 BVB systemd[1]: sddm.service: Main process exited, code=killed, status=9/KILL
Sep 21 04:36:35 BVB systemd[1]: cups.service: Main process exited, code=killed, status=9/KILL
Sep 21 04:36:35 BVB systemd[1]: cups.service: Failed with result 'signal'.
Sep 21 04:36:35 BVB systemd[1]: dbus.service: Main process exited, code=killed, status=9/KILL
Sep 21 04:36:35 BVB systemd[1]: dbus.service: Failed with result 'signal'.
Sep 21 04:36:35 BVB systemd[1]: systemd-journald.service: Main process exited, code=killed, status=9/KILL
Sep 21 04:36:35 BVB systemd[1]: systemd-journald.service: Failed with result 'signal'.
Sep 21 04:36:35 BVB systemd[1]: systemd-logind.service: Main process exited, code=killed, status=9/KILL
Sep 21 04:36:35 BVB systemd[1]: systemd-logind.service: Failed with result 'signal'.
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:6:0:0x0000000f
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c77d:0:0:0x0000000f
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:0:0:0x0000000f
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:1:0:0x0000000f
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:2:0:0x0000000f
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:3:0:0x0000000f
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:4:0:0x0000000f
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:5:0:0x0000000f
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:7:0:0x0000000f
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failed detecting connected display devices
Sep 21 04:36:35 BVB kernel: nvidia-modeset: WARNING: GPU:0: Failure processing EDID for display device LG Electronics LG HDR 4K (DP-4).
Sep 21 04:36:35 BVB kernel: nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device LG Electronics LG HDR 4K (DP-4)
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failure reading maximum pixel clock value for display device DP-4.
Sep 21 04:36:35 BVB kernel: nvidia-modeset: WARNING: GPU:0: Failure processing EDID for display device LG Electronics LG ULTRAFINE (DP-2).
Sep 21 04:36:35 BVB kernel: nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device LG Electronics LG ULTRAFINE (DP-2)
Sep 21 04:36:35 BVB kernel: nvidia-modeset: ERROR: GPU:0: Failure reading maximum pixel clock value for display device DP-2.
Sep 21 04:36:35 BVB kernel: ------------[ cut here ]------------
Sep 21 04:36:35 BVB kernel: WARNING: CPU: 6 PID: 752 at /build/linux515-nvidia/src/NVIDIA-Linux-x86_64-535.104.05-no-compat32/kernel/nvidia/nv.c:4769 nvidia_dev_put+0x8c/0x90 [nvidia]
Sep 21 04:36:35 BVB kernel: Modules linked in: rfcomm joydev mousedev qrtr cmac algif_hash algif_skcipher af_alg bnep nvidia_uvm(POE) intel_rapl_msr intel_rapl_common edac_mce_amd snd_hda_codec_realtek snd_hda_codec_generic kvm ledtrig_audio snd_hda_codec_hdmi nvidia_drm(POE) irqbypass wmi_bmof gigabyte_wmi iwlmvm crct10dif_pclmul snd_hda_intel crc32_pclmul ghash_clmulni_intel btusb snd_intel_dspcfg aesni_intel nvidia_modeset(POE) snd_intel_sdw_acpi btrtl mac80211 snd_hda_codec crypto_simd btbcm snd_hda_core btintel libarc4 cryptd rapl pcspkr bluetooth snd_hwdep iwlwifi sp5100_tco snd_pcm ecdh_generic ccp nvidia(POE) i2c_piix4 snd_timer cfg80211 snd vfat igc soundcore wmi ucsi_acpi rfkill video fat tpm_crb typec_ucsi tpm_tis typec tpm_tis_core pinctrl_amd roles acpi_cpufreq mac_hid usbhid crypto_user fuse loop dm_mod tpm rng_core ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci
Sep 21 04:36:35 BVB kernel: CPU: 6 PID: 752 Comm: InputThread Tainted: P OE 5.15.131-1-MANJARO #1 879c86be44cbcfd0bee8b3a5e892c8389adfd5d5
Sep 21 04:36:35 BVB kernel: Hardware name: Gigabyte Technology Co., Ltd. X670E AORUS MASTER/X670E AORUS MASTER, BIOS F13c 08/16/2023
Sep 21 04:36:35 BVB kernel: RIP: 0010:nvidia_dev_put+0x8c/0x90 [nvidia]
Sep 21 04:36:35 BVB kernel: Code: 89 de 4c 89 e7 e8 24 b2 a8 00 85 c0 75 1c 5b 48 89 ef 5d 41 5c e9 14 47 53 cd 5b 48 c7 c7 c0 81 d6 c3 5d 41 5c e9 04 47 53 cd <0f> 0b eb e0 0f 1f 44 00 00 41 57 31 ff 41 56 41 55 41 54 49 89 cc
Sep 21 04:36:35 BVB kernel: RSP: 0018:ffffa4b405673b10 EFLAGS: 00010202
Sep 21 04:36:35 BVB kernel: RAX: 0000000000000026 RBX: ffff88d540b77800 RCX: ffffa4b405673a90
Sep 21 04:36:35 BVB kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffffa4b405673a40
Sep 21 04:36:35 BVB kernel: RBP: ffff88d540b77dc0 R08: 0000000000000000 R09: 0000000000000000
Sep 21 04:36:35 BVB kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff88d56ef23000
Sep 21 04:36:35 BVB kernel: R13: ffff88d55a4b50a0 R14: ffff88d55e22fc08 R15: ffff88d540a35ac0
Sep 21 04:36:35 BVB kernel: FS: 0000000000000000(0000) GS:ffff88dc9d980000(0000) knlGS:0000000000000000
Sep 21 04:36:35 BVB kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Sep 21 04:36:35 BVB kernel: CR2: 0000558f2703e6d8 CR3: 0000000642410000 CR4: 0000000000750ee0
Sep 21 04:36:35 BVB kernel: PKRU: 55555554
Sep 21 04:36:35 BVB kernel: Call Trace:
Sep 21 04:36:35 BVB kernel: <TASK>
Sep 21 04:36:35 BVB kernel: ? __warn+0x81/0x100
Sep 21 04:36:35 BVB kernel: ? nvidia_dev_put+0x8c/0x90 [nvidia 37265c69c94cc977f036899126b3917e1055a962]
Sep 21 04:36:35 BVB kernel: ? report_bug+0xa7/0xd0
Sep 21 04:36:35 BVB kernel: ? handle_bug+0x34/0x90
Sep 21 04:36:35 BVB kernel: ? exc_invalid_op+0x13/0x70
Sep 21 04:36:35 BVB kernel: ? asm_exc_invalid_op+0x16/0x20
Sep 21 04:36:35 BVB kernel: nvkms_close_gpu+0x49/0x80 [nvidia_modeset 2f76fbc890cf4792818a284bebba72114c79c9a4]
Sep 21 04:36:35 BVB kernel: _nv002721kms+0xd5/0x1e0 [nvidia_modeset 2f76fbc890cf4792818a284bebba72114c79c9a4]
Sep 21 04:36:35 BVB kernel: ? _nv002487kms+0xf4/0x140 [nvidia_modeset 2f76fbc890cf4792818a284bebba72114c79c9a4]
Sep 21 04:36:35 BVB kernel: ? _nv000369kms+0x94/0x100 [nvidia_modeset 2f76fbc890cf4792818a284bebba72114c79c9a4]
Sep 21 04:36:35 BVB kernel: ? nvKmsClose+0x88/0x170 [nvidia_modeset 2f76fbc890cf4792818a284bebba72114c79c9a4]
Sep 21 04:36:35 BVB kernel: ? nvkms_close+0x3b/0xc0 [nvidia_modeset 2f76fbc890cf4792818a284bebba72114c79c9a4]
Sep 21 04:36:35 BVB kernel: ? nvidia_frontend_close+0x2a/0x50 [nvidia 37265c69c94cc977f036899126b3917e1055a962]
Sep 21 04:36:35 BVB kernel: ? __fput+0x89/0x250
Sep 21 04:36:35 BVB kernel: ? task_work_run+0x5c/0xa0
Sep 21 04:36:35 BVB kernel: ? do_exit+0x348/0xa90
Sep 21 04:36:35 BVB kernel: ? do_group_exit+0x33/0xa0
Sep 21 04:36:35 BVB kernel: ? get_signal+0xea/0x8d0
Sep 21 04:36:35 BVB kernel: ? arch_do_signal_or_restart+0xdd/0x730
Sep 21 04:36:35 BVB kernel: ? exit_to_user_mode_prepare+0x101/0x190
Sep 21 04:36:35 BVB kernel: ? syscall_exit_to_user_mode+0x23/0x50
Sep 21 04:36:35 BVB kernel: ? do_syscall_64+0x68/0x90
Sep 21 04:36:35 BVB kernel: ? ksys_write+0xdc/0xf0
Sep 21 04:36:35 BVB kernel: ? syscall_exit_to_user_mode+0x31/0x50
Sep 21 04:36:35 BVB kernel: ? entry_SYSCALL_64_after_hwframe+0x62/0xcc
Sep 21 04:36:35 BVB kernel: </TASK>
Sep 21 04:36:35 BVB kernel: ---[ end trace 502b85aa3d22d857 ]---
Sep 21 04:36:35 BVB systemd[1]: sddm.service: Failed with result 'signal'.
Sep 21 04:36:36 BVB kernel: Emergency Sync complete
Sep 21 04:36:36 BVB kernel: NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:762)
Sep 21 04:36:36 BVB kernel: NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
Sep 21 04:36:36 BVB sddm[1934]: Failed to read display number from pipe
Sep 21 04:36:36 BVB sddm[1934]: Attempt 1 starting the Display server on vt 1 failed
