System freezes across multiple kernels and display servers
My computer freezes randomly—sometimes after 1 or 2 hours, sometimes just a few minutes after rebooting. It happens with all the kernels I have installed: 6.1.127-2, 6.6.75-2, 6.12.12-2, and 6.13.1-2. I also updated the BIOS when the problems started last week.
I had more or less the same problem over a year ago. I think I “solved” it by switching to Wayland, but now it’s happening even with Wayland. The last freeze happened while using X11, but it’s occurring with both.
I also ran a RAM test with MemTest86, and everything seems fine.
inxi -zv8
  Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=99d9ca6c-c676-4535-989a-0e728e1e4f29 rw quiet
    udev.log_priority=3 idle=nomwait amdgpu.gpu_recovery-1
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Desktop System: Micro-Star product: MS-7A38 v: 8.0
    serial: <superuser required>
  Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: B.M0 date: 07/25/2024
  Device-1: hidpp_battery_0 model: Logitech K370s/K375s Multi-Device Wireless
    Keyboard serial: <filter> charge: 55% (should be ignored)
    rechargeable: yes status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master
    serial: <filter> charge: 5% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 16 GiB available: 13.57 GiB used: 4.28 GiB (31.5%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK16GX4M2B3000C15 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
    arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
    process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
    microcode: 0x8108109
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1400 min/max: 1400/3600 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
    4: 1400 bogomips: 28808
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: spec_rstack_overflow mitigation: SMT disabled
  Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
    Series / Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 2a:00.0
    chip-ID: 1002:15d8 class-ID: 0300 temp: 32.0 C
  Device-2: KYE Systems (Mouse Systems) PC-LM1E Camera
    driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 5-1:2 chip-ID: 0458:6006 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3360x1080 s-dpi: 96 s-size: 889x285mm (35.00x11.22")
    s-diag: 934mm (36.75")
  Monitor-1: DP-2 mapped: DisplayPort-1 pos: right
    model: Lenovo LT1952p Wide serial: <filter> built: 2014 res: mode: 1440x900
    hz: 60 scale: 100% (1) dpi: 90 gamma: 1.2 chroma: red: x: 0.635 y: 0.341
    green: x: 0.306 y: 0.620 blue: x: 0.157 y: 0.063 white: x: 0.314 y: 0.329
    size: 408x255mm (16.06x10.04") diag: 481mm (18.9") ratio: 16:10
    modes: 1440x900, 1280x1024, 1280x800, 1152x864, 1280x720, 1024x768,
    800x600, 640x480, 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: BenQ GW2480
    serial: <filter> built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 93 gamma: 1.2 chroma: red: x: 0.647 y: 0.341 green: x: 0.322 y: 0.612
    blue: x: 0.153 y: 0.043 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
    (radeonsi raven LLVM 19.1.7 DRM 3.59 6.12.12-2-MANJARO)
    device-ID: 1002:15d8 memory: 1.95 GiB unified: no
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Vega 8 Graphics (RADV RAVEN) driver: N/A device-ID: 1002:15d8
    surfaces: xcb,xlib
    de: kscreen-console,kscreen-doctor gpu: radeontop wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
    Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 2a:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    speed: 8 GT/s lanes: 16 bus-ID: 2a:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-3: KYE Systems (Mouse Systems) PC-LM1E Camera
  API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.48 TiB used: 52.12 GiB (3.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR020 temp: 31.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSNH128GCST
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: N103 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EZEX-08M2NA0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: GPT
  ID-1: / raw-size: 50.78 GiB size: 49.43 GiB (97.34%) used: 33.08 GiB (66.9%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:6 label: N/A
    uuid: 99d9ca6c-c676-4535-989a-0e728e1e4f29
  ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:8
    label: NO_LABEL uuid: 820B-E223
  ID-3: /datos raw-size: N/A size: 2.69 TiB used: 1.87 TiB (69.5%) fs: nfs4
    remote: 192.168.2.104:/datos
  ID-4: /home raw-size: 57.07 GiB size: 56 GiB (98.12%)
    used: 19.03 GiB (34.0%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:7
    label: N/A uuid: 3d33da7b-267f-44f6-b1f0-65784d714a61
  ID-1: swap-1 type: partition size: 15.26 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:5 label: N/A
    uuid: 5a20de02-eaef-4117-9619-4886aa27cdaf
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 90B3-C04B
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 341.18 GiB fs: ntfs label: N/A
    uuid: F66EBECD6EBE85C1
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 513 MiB fs: ntfs label: N/A
    uuid: 0A56C41256C3FC87
  ID-5: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: N/A
    uuid: 6E6032F26032C11F
  Device-1: 1-7:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: KYE Systems (Mouse Systems) PC-LM1E Camera
    type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 256mA
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 31.0 C mobo: 33.0 C gpu: amdgpu temp: 41.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 1146 fan-3: 950 fan-4: 0 fan-5: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.38
  Packages: pm: pacman pkgs: 1604 libs: 439 tools: pamac
  Active pacman repo servers in: /etc/pacman.conf
    1: https://download.sublimetext.com/arch/stable/x86_64
    1: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    2: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    4: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    5: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    6: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    7: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    9: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    10: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    11: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    12: https://manjaro.kurdy.org/stable/$repo/$arch
    13: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    15: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    16: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    17: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    19: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://manjaro.ynh.ovh/stable/$repo/$arch
    24: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    25: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    26: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    27: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    28: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    30: https://mirror.23m.com/manjaro/stable/$repo/$arch
    31: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    32: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    33: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    34: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    35: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    37: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    39: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    40: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    41: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    44: https://mirrors2.manjaro.org/stable/$repo/$arch
    45: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    46: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    47: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    48: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    50: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    51: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    52: https://mirror.init7.net/manjaro/stable/$repo/$arch
    53: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    54: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    55: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    56: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    57: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    58: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    59: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    60: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    62: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    63: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    65: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    66: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    67: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    68: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    69: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    70: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    71: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    72: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 294
  1: cpu: 21.7% command: chrome pid: 1542 mem: 525.0 MiB (3.7%)
  2: cpu: 17.3% command: firefox pid: 2739 mem: 526.5 MiB (3.7%)
  3: cpu: 17.0% command: Logseq pid: 2182 mem: 276.9 MiB (1.9%)
  4: cpu: 12.3% command: konsole pid: 3140 mem: 230.5 MiB (1.6%)
  5: cpu: 8.4% command: chrome pid: 2228 mem: 248.6 MiB (1.7%)
  Memory top: 5 of 294
  1: mem: 526.5 MiB (3.7%) command: firefox pid: 2739 cpu: 17.3%
  2: mem: 525.0 MiB (3.7%) command: chrome pid: 1542 cpu: 21.7%
  3: mem: 387.5 MiB (2.7%) command: plasmashell pid: 841 cpu: 2.9%
  4: mem: 378.8 MiB (2.7%) command: chrome pid: 2403 cpu: 3.6%
  5: mem: 276.9 MiB (1.9%) command: Logseq pid: 2182 cpu: 17.0%
  Processes: 294 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.41 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
mhwd -l -li
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
> 0000:25:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2023.09.12                true            PCI
> 0000:2a:00.0 (0300:1002:15d8) Display controller ATI Technologies Inc:
Also I can provide journalctl --boot -1
With my limited knowledge, I managed to prevent my computer from freezing by disabling hardware acceleration in Chrome and Firefox.
With these two versions of Chrome 133.0.6943.126-1, 133.0.6943.98-1 and Firefox 135.0.1, my computer freezes
