Since the update that brought kernel 6.5, my system freezes after startup when I use the recent kernel. All monitors stop receiving any signal. I can only revive the system via reset button. I had hoped the problem would go away with the next kernel update, but unfortunately I have the same issue with the new kernel 6.6 as well.
With kernel 6.1 the system runs without issues.
To be more precise, my system is configured to start directly into the Xfce4 session without additional login required. Depending on which monitor I use as primary or only monitor (of course I have tried several combinations), I can see the Desktop for half a second or so, but already frozen, before the monitor goes blank and the system won’t react to any input.
System information:
Kernel: 6.1.63-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: PRO Z690-A DDR4(MS-7D25) v: 1.0
serial: 07D2512_M21E518575 UEFI: American Megatrends LLC. v: 1.70
date: 06/23/2022
Info: 6-core 12th Gen Intel Core i5-12400F [MT MCP] speed (MHz): avg: 1166
min/max: 800/5600
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
driver: amdgpu v: kernel
Display: x11 server: X.Org v: 21.1.9 driver: X: loaded: amdgpu
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu resolution: 1: N/A
2: 3440x1440~75Hz
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
renderer: AMD Radeon RX 6700 XT (navi22 LLVM 16.0.6 DRM 3.49
6.1.63-1-MANJARO)
Device-1: Intel Ethernet I225-V driver: igc
Local Storage: total: 2.35 TiB used: 810.6 GiB (33.6%)
very detailed system information
Kernel: 6.1.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=8077cafe-145e-4505-a3f3-703851ac6ebe rw quiet
udev.log_priority=3 ibt=off amdgpu.ppfeaturemask=0xffffffff
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
serial: <filter> UEFI: American Megatrends LLC. v: 1.70 date: 06/23/2022
System RAM: total: 32 GiB available: 31.21 GiB used: 3.62 GiB (11.6%)
Device-1: Controller0-DIMMA1 type: no module installed
Device-2: Controller0-DIMMA2 type: DDR4 detail: synchronous size: 16 GiB
speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: Kingston part-no: 9905743-184.A00G
serial: <filter>
Device-3: Controller1-DIMMB1 type: no module installed
Device-4: Controller1-DIMMB2 type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Info: model: 12th Gen Intel Core i5-12400F socket: U3E1 bits: 64
type: MT MCP arch: Alder Lake gen: core 12 level: v3 note: check
built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151)
stepping: 5 microcode: 0x22
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/5600 base/boost: 2475/4400
scaling: driver: intel_pstate governor: powersave volts: 0.8 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 801 10: 800 11: 800 12: 800 bogomips: 59916
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb
pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep serialize sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 off: DP-3 empty: DP-1,DP-2
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
Display: x11 server: X.Org v: 21.1.9 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-3 mapped: DisplayPort-2 note: disabled
model: EIZO NANAO EV2313W serial: <filter> built: 2011 res: N/A dpi: 96
gamma: 1.2 size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9
modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary
model: Idek Iiyama PL3493WQ serial: <filter> built: 2020 res: 3440x1440
hz: 75 dpi: 109 gamma: 1.2 size: 800x345mm (31.5x13.58")
diag: 871mm (34.3") modes: max: 3440x1440 min: 720x400
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.49 6.1.63-1-MANJARO) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 2 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:73df surfaces: xcb,xlib
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
API: ALSA v: k6.1.63-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.85 status: n/a (root, process) with:
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.1.1:8 chip-ID: 0b05:190e
Local Storage: total: 2.35 TiB used: 811.39 GiB (33.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM800PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.7.F.V temp: 25.9 C
scheme: GPT
SMART: yes health: PASSED on: 12 hrs cycles: 319
read-units: 5,082,775 [2.60 TB] written-units: 4,244,957 [2.17 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
family: Micron Client SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 023 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 289d 3h cycles: 1325
written: 4.51 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500BX100SSD1
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: MU02 temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 83d 23h cycles: 3362
read: 44.1 TiB written: 20.66 TiB
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: M4-CT064M4SSD2
family: Micron RealSSD m4/C400/P400 size: 59.63 GiB block-size:
physical: 512 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 070H scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 209d 7h cycles: 4844
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST3500312CS
family: Pipeline HD 5900.2 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: HDD rpm: 5900
serial: <filter> fw-rev: SC13 temp: 27 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 350d 11h cycles: 3359
Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
Optical-1: /dev/sr0 vendor: PIONEER model: BD-RW BDR-209M rev: 1.34
dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 75.75 GiB (16.6%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: manjaro-root
uuid: 8077cafe-145e-4505-a3f3-703851ac6ebe
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: NO_LABEL uuid: ADF5-12F3
ID-3: /home raw-size: 953.87 GiB size: 937.83 GiB (98.32%)
used: 420.58 GiB (44.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: home uuid: 505d23ae-ddc3-47af-a529-7b5c557e657b
ID-4: /mnt/manual-temp raw-size: 27.62 GiB size: 27.02 GiB (97.82%)
used: 8.64 GiB (32.0%) fs: ext4 block-size: 4096 B dev: /dev/sdc2
maj-min: 8:34 label: manual-temp
uuid: 7d295dc0-702f-4e16-81e0-dc91fafa89c5
ID-5: /mnt/windows/M raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 306.42 GiB (65.8%) fs: ntfs block-size: 2048 B dev: /dev/sdd1
maj-min: 8:49 label: N/A uuid: 100E59CB0E59AA8C
ID-1: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: ext4 label: home
ID-2: /dev/sdc1 maj-min: 8:33 size: 32 GiB fs: swap label: swap
uuid: eaaa48fe-21e2-4d07-bf20-406e9580cb19
Device-1: 1-2:2 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d25 class-ID: 0300
serial: <filter>
Hub-2: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 1-5.1:5 info: Genesys Logic Hub ports: 2 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Device-1: 1-5.1.1:8 info: ASUSTek ASUS USB-BT500 type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Device-2: 1-5.4:7 info: Canon CanoScan LiDE 210 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04a9:190a class-ID: ff00
Device-3: 1-12:4 info: Holtek Keyboard type: keyboard,HID
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
chip-ID: 04d9:1603 class-ID: 0300
Hub-4: 1-13:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-5: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Hub-6: 2-4:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
System Temperatures: cpu: 29.0 C mobo: N/A gpu: amdgpu temp: 30.0 C
mem: 30.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 989
Processes: 325 Uptime: 5m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1932 libs: 497 tools: pamac,yay Shell: Sudo (sudo) v: 1.9.15p2
default: Bash v: 5.2.15 running-in: xfce4-terminal inxi: 3.3.31
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
