System freeze while playing games
Hello there dear Manjaro community,
I’ve changed to this amazing Distro about a month or so ago since I was getting stuck up by Windows and since they are removing Win10 support might as well change right?
Quite the joy to learn this system even when I don’t understand coding all that well.
I’ll provide some details on what happens, as I said I am new to Linux and by extension Manjaro, so bear with me as I might need extra explanations but am more than willing to try and understand!
Ever since I have downloaded this OS it seems that playing games for a prolonged time completely freezes up my PC, it used to be that it would take hours before I would start feeling stutters but now it happens way more frequently and faster.
I play my games on Steam and have Discord open on the background almost always, Librewolf is my go to internet browser which is either playing music or just idling in the background till I need it. Telegram (The messaging app) usually runs in the background too.
Below I’ll provide some details on my system from the info centre with a crash report using the “journalctl -p 3 -xb -1” command, found this in another thread and might be relevant;
KDE Plasma ver.: 6.3.3
KDE Framework ver.: 6.11.0
Kernel ver.: 6.12.19-1-MANJARO (64-bit)
Graphics platfrom: X11
Processors: 12 x AMD Ryzen 5 1600 Hexa Core
Memory: 15,5 GiB DDR4
Graphics Processor: Nvidia Geforce GTX 1660 (unsure of version, suspected OC variant)
journalctl -p 3 -xb -1         ✔
mrt 21 00:56:05 Damwab-Linux-HomePc kernel:
mrt 21 00:56:06 Damwab-Linux-HomePc kernel: nvidia-gpu 0000:08:00.3: i2c timeout error e0000000
mrt 21 00:56:06 Damwab-Linux-HomePc kernel: ucsi_ccg 0-0008: i2c_transfer failed -110
mrt 21 00:56:06 Damwab-Linux-HomePc kernel: ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
mrt 21 00:56:06 Damwab-Linux-HomePc kernel: ucsi_ccg 0-0008: probe with driver ucsi_ccg failed with error -110
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]: Failed to find connector name for /dev/i2c-8, set_connector_for_businfo_using_edid at line 1236 in file i2c_bus_core.c.
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    I2C_Bus_Info at: 0x5b01c39b8960
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    Flags:                   I2C_BUS_EXISTS | I2C_BUS_ACCESSIBLE | I2C_BUS_PROBED | I2C_BUS_X50_EDID
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    Bus /dev/i2c-8 found:   true
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    Bus /dev/i2c-8 probed:  true
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    errno for open:          OK(0): success
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    drm_connector_found_by:  DRM_CONNECTOR_NOT_CHECKED (0)
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    last_checked_asleep:       false
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    Display connectors reported by /sys:
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    Connector:    card0-Unknown-1
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       i2c_busno:    -1
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       connector_id: 36
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       name:         (null)
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       enabled:      enabled
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       status:       connected
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       edid:         None
mrt 21 00:56:06 Damwab-Linux-HomePc kernel: ucsi_ccg 0-0008: probe with driver ucsi_ccg failed with er>
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]: Failed to find connector name for /dev/i2>
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    Flags:                   I2C_BUS_EXIST>
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    drm_connector_found_by:  DRM_CONNECTOR>
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    Connector:    card1-HDMI-A-1
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       connector_id: 97
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       enabled:      disabled
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       status:       disconnected
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:    Connector:    card1-DP-1
mrt 21 00:56:40 Damwab-Linux-HomePc org_kde_powerdevil[973]:       connector_id: 89
Welcome to the Manjaro community @damwab
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) is often useful (and this or similar will usually be asked for in Support threads):
inxi -zv8
This gives some (privacy-filtered) information about your system.
Be prepared to provide more information and outputs from other commands when asked.
The information you have provided might be fine for someone wishing to buy your computer, but for Support purposes it’s best to ask your system directly, and produce more useful system information.
Please use the inxi command as demonstrated by @scotty65 and post the output as preformatted text.
Thank you very much for welcoming me and providing the links towards the information regarding these posts, I’ll make sure to go through them after writing this reply.
I have since between now and when the post was made used the Timeshift program to revert back to an earlier state, which so far has also reverted the amount of time it takes to freeze up.
Regarding the information provided by the command, this I will post right underneath this message to give both you and @soundofthunder the info required;
*Edit due to having hopefully added a Swap partition
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=4458c082-9d51-479b-85b9-06ff00bc3167 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x
    UEFI: American Megatrends v: 4604 date: 03/22/2024
  System RAM: total: 16 GiB available: 15.53 GiB used: 3.13 GiB (20.2%)
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK16GX4M2E3200C16 serial: N/A
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001138
    smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 2352 min/max: 1550/3200 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2352 2: 2352 3: 2352
    4: 2352 5: 2352 6: 2352 7: 2352 8: 2352 9: 2352 10: 2352 11: 2352 12: 2352
    bogomips: 76827
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a
    ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: Micro-Star MSI
    driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: DP-3
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 08:00.0 chip-ID: 10de:2184
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 97 s-size: 503x283mm (19.80x11.14")
    s-diag: 577mm (22.72")
  Monitor-1: DP-5 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96
    size: 509x286mm (20.04x11.26") diag: 584mm (22.99") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 550.144.03 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.4.304 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1660 driver: N/A device-ID: 10de:2184
    surfaces: xcb,xlib
  Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 08:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK
    bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: HP HyperX Cloud Alpha Wireless
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:5 chip-ID: 03f0:098d
    class-ID: 0a00 serial: <filter>
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter
    vendor: ASUSTeK PCE-N10 driver: rtl8192ce v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8176
    class-ID: 0280
  IF: wlp5s0 state: down mac: <filter>
  Local Storage: total: 2.73 TiB used: 271.27 GiB (9.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC47 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 1TB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-1: / raw-size: 883.64 GiB size: 883.64 GiB (100.00%)
    used: 271.23 GiB (30.7%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: 4458c082-9d51-479b-85b9-06ff00bc3167
  ID-2: /boot/efi raw-size: 100 MiB size: 100 MiB (100.00%)
    used: 38.8 MiB (38.8%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: Door
    systeem gereserveerd uuid: 1EE46CBDDB250925
  ID-3: /home raw-size: 883.64 GiB size: 883.64 GiB (100.00%)
  ID-4: /var/cache raw-size: 883.64 GiB size: 883.64 GiB (100.00%)
  ID-5: /var/log raw-size: 883.64 GiB size: 883.64 GiB (100.00%)
  ID-1: swap-1 type: partition size: 46.87 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdc3 maj-min: 8:35 label: N/A
    uuid: 129946c3-4a70-4f92-b35a-4b0d3b2bdab5
  ID-1: /dev/sda1 maj-min: 8:1 size: 930.94 GiB fs: ntfs label: HDD
    uuid: 04D46F02D46EF578
  ID-2: /dev/sda2 maj-min: 8:2 size: 481 MiB fs: ntfs label: N/A
    uuid: 6A30E69E30E6708D
  ID-3: /dev/sdb2 maj-min: 8:18 size: 930.41 GiB fs: ntfs label: SSD Evo 850
    uuid: 5654E90E54E8F223
  ID-4: /dev/sdb3 maj-min: 8:19 size: 541 MiB fs: ntfs label: N/A
    uuid: 940CCD530CCD30D2
  ID-5: /dev/sdc1 maj-min: 8:33 size: 1024 MiB fs: vfat label: N/A
    uuid: 5AD6-DE8B
  Device-1: 1-1:2 info: SteelSeries ApS Prime Wireless type: mouse,HID
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1038:1840 class-ID: 0300
  Device-2: 1-3:5 info: HP HyperX Cloud Alpha Wireless
    type: audio,HID,abstract (modem),CDC-data
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
    chip-ID: 03f0:098d class-ID: 0a00 serial: <filter>
  Device-3: 1-7:3 info: Keychron V1 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0313 class-ID: 0300
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 31.8 C mobo: N/A gpu: nvidia temp: 29 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 46%
  Packages: pm: pacman pkgs: 1227 libs: 339 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    5: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    6: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    7: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 386
  1: cpu: 26.2% command: steamwebhelper pid: 2157 mem: 240.7 MiB (1.5%)
  2: cpu: 25.3% command: steamwebhelper pid: 2112 mem: 606.7 MiB (3.8%)
  3: cpu: 24.8% command: Discord pid: 1609 mem: 423.5 MiB (2.6%)
  4: cpu: 13.0% command: steam pid: 1660 mem: 173.3 MiB (1.0%)
  5: cpu: 10.5% command: plasmashell pid: 912 mem: 415.7 MiB (2.6%)
  Memory top: 5 of 386
  1: mem: 606.7 MiB (3.8%) command: steamwebhelper pid: 2112 cpu: 25.3%
  2: mem: 423.5 MiB (2.6%) command: Discord pid: 1609 cpu: 24.8%
  3: mem: 415.7 MiB (2.6%) command: plasmashell pid: 912 cpu: 10.5%
  4: mem: 384.2 MiB (2.4%) command: librewolf pid: 1113 cpu: 8.5%
  5: mem: 352.4 MiB (2.2%) command: ./steamwebhelper pid: 2028 cpu: 9.0%
  Processes: 386 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
Kind Regards.
Please sync/update your system;
Support for a so-called rolling release distribution such as Manjaro or Arch is generally only relevant for updated systems.
Once that is done, edit your previous post with the fresh output of;
inxi --filter --verbosity=8
Accurate and updated information is always a requirement for those who might wish to help.
I note that you have no swap space defined. This can potentially be an issue when running resource-intensive applications such as games (along with underpinning requirements of WINE, etc).
Info:- If wishing to hibernate a system, swap should be slightly greater than the amount of physical RAM installed. Without hibernation, half that amount is the default – but this should usually be configured by the User during Manjaro install.
System Information
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
Thanks for your swift response, I have updated said information and system as you have instructed. Now that you mention that I have no swap I find it odd due to remembering that I added a swap partition… If the system does not seem to recognize this I might’ve made a mistake.
I’ll do my best to rectify this problem and hope this might improve the situation, if anything of use comes from the newly acquired system info I’ll be happy to hear it!
Kind Regards.
Let us know if the swap improves things; if not, I’m sure Members will be more than willing to help further.
Swap has been created, gave it about 48 GiB just to be sure it would have enough to sift through. Seems to me that this has indeed solved the issue so far. No crashes, no freezes. Only small hiccups during new sections of games, which is just rendering/caching and perfectly normal.
I wanna thank you for pointing out the problem, you’ve been straight to the point and wonderful!
Wishing you a fine day and hope I can bring contributions to this community in the future.
Kind Regards.
