My spare laptop has become unstable and freeze up. When this happens, nothing moves on screen. Not even the clock. Even the Caps lock LED responds to input. Last time this happened I was writing a facebook post. Only firefox and mousepad windows were open. Seems to me like the issue is the video driver. Is that correct reading of the logs? What could be done about that?
System was clean reinstalled on April 9th. For the first 4 weeks after reinstall there were no issues at all with the pc. Auto updates are switched off. Manual updates has not been performed since the reinstall as I want eliminate updates as the reason for issues experienced before the reinstall.
Log looks like this:
# journalctl --boot=-1 --priority=7 --no-pager
mai 13 13:40:22 m8440 NetworkManager[481]: <info> [1715600422.8877] dhcp4 (wlo1): state changed new lease, address=192.168.43.211
mai 13 13:40:22 m8440 systemd[1]: Starting Network Manager Script Dispatcher Service...
mai 13 13:40:22 m8440 systemd[1]: Started Network Manager Script Dispatcher Service.
mai 13 13:40:32 m8440 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mai 13 13:51:28 m8440 kernel: nouveau 0000:01:00.0: gr: TRAP_MP_EXEC - TP 0 MP 0: 00000008 [TIMEOUT] at 07e690 warp 2, opcode f6400001 0000c781
mai 13 13:51:28 m8440 kernel: nouveau 0000:01:00.0: gr: TRAP_MP_EXEC - TP 0 MP 1: 00000008 [TIMEOUT] at 07e690 warp 1, opcode f6400001 0000c781
mai 13 13:51:28 m8440 kernel: nouveau 0000:01:00.0: gr: 00200000 [] ch 5 [001f780000 Renderer[3137]] subc 3 class 8597 mthd 15e0 data 00000000
[…] the above lines repeat several times pr second, until this:
mai 13 13:56:54 m8440 kernel: nouveau 0000:01:00.0: gr: 00200000 [] ch 5 [001f780000 Renderer[3137]] subc 3 class 8597 mthd 15e0 data 00000000
mai 13 13:56:54 m8440 kernel: INFO: task kworker/1:0H:71340 blocked for more than 245 seconds.
mai 13 13:56:54 m8440 kernel: Tainted: P OE 6.6.25-1-MANJARO #1
mai 13 13:56:54 m8440 kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
mai 13 13:56:54 m8440 kernel: INFO: task kworker/u16:0:72742 blocked for more than 245 seconds.
mai 13 13:56:54 m8440 kernel: nouveau 0000:01:00.0: gr: TRAP_MP_EXEC - TP 0 MP 0: 00000008 [TIMEOUT] at 07e690 warp 2, opcode f6400001 0000c781
mai 13 13:56:54 m8440 kernel: nouveau 0000:01:00.0: gr: TRAP_MP_EXEC - TP 0 MP 1: 00000008 [TIMEOUT] at 07e690 warp 1, opcode f6400001 0000c781
Inxi output:
# inxi --admin --verbosity=7 --filter --width
Kernel: 6.6.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.6-x86_64
root=UUID=b68a8072-f3c0-4f2e-9606-f869acbca128 rw
GRUB_CMDLINE_LINUX_DEFAULT=sysrq_always_enabled=1 apparmor=1
security=apparmor resume=UUID=dcf04137-619b-41d0-99fe-ef7e77c5534d
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Hewlett-Packard product: HP EliteBook 8440p v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 172B v: KBC Version 30.35 serial: <filter>
part-nu: VQ664EA#ABN uuid: 9c5b917a-c5dc-11df-9cd0-c2011e0d6060
BIOS: Hewlett-Packard v: 68CCU Ver. F.60 date: 11/11/2015
ID-1: BAT0 charge: 35.7 Wh (98.3%) condition: 36.3/36.3 Wh (100.0%)
volts: 12.2 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging
System RAM: total: 6 GiB available: 5.65 GiB used: 2.05 GiB (36.2%)
Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
max-module-size: 4 GiB note: est.
Device-1: Top-Slot 1(top) type: DDR3 detail: synchronous size: 2 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471B5673FH0-CH9 serial: <filter>
Device-2: Top-Slot 2(under) type: DDR3 detail: synchronous size: 4 GiB
manufacturer: Hynix part-no: HMT351S6BFR8C-H9 serial: <filter>
Info: model: Intel Core i7 M 620 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1566 high: 2667 min/max: 1199/2667 boost: enabled
base/boost: 2657/2666 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 133 MHz cores: 1: 1199 2: 1199 3: 1199 4: 2667
bogomips: 21288
Flags: acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flush_l1d fpu
fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc
nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tsc vme xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GT218M [NVS 3100M] vendor: Hewlett-Packard driver: nouveau
v: kernel non-free: series: 340.xx status: legacy (EOL~2019-12-xx) last:
release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
built: 2006-2013 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
active: eDP-1 empty: DP-1,DP-2,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:0a6c
class-ID: 0300 temp: 57.0 C
Device-2: Chicony HP Webcam [2 MP Macro] driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:4
chip-ID: 04f2:b15e class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.12 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x123e built: 2009 res: 1600x900
dpi: 132 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: max: 1600x900 min: 800x600
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 egl: 1.4
drv: nouveau device: 1 drv: swrast gbm: egl: 1.4 drv: nouveau surfaceless:
egl: 1.4 drv: nouveau x11: egl: 1.4 drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NVA8 device-ID: 10de:0a6c
memory: 494.1 MiB unified: no
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Hewlett-Packard 5 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
API: ALSA v: k6.6.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel 82577LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 6020 bus-ID: 00:19.0 chip-ID: 8086:10ea
class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 44:00.0 chip-ID: 8086:4238
class-ID: 0280
IF-ID-1: brfjt state: up speed: -1 duplex: unknown mac: <filter>
IF-ID-2: brlyc state: up speed: -1 duplex: unknown mac: <filter>
IF-ID-3: brprt state: up speed: -1 duplex: unknown mac: <filter>
IF-ID-4: dumfjt state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-5: dumlyc state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-6: dumprt state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: z type: zfs status: ONLINE level: linear raw: size: 193 GiB
free: 127 GiB allocated: 66.2 GiB zfs-fs: size: 192.43 GiB free: 120.79 GiB
Components: Online:
1:
Local Storage: total: raw: 238.47 GiB usable: 430.9 GiB
used: 88.23 GiB (20.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: MTFDBAK256MAG-1G1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0005 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: CDDVDW TS-L633N rev: 0300
dev-links: cdrom
ID-1: / raw-size: 29.2 GiB size: 28.57 GiB (97.85%) used: 16.79 GiB (58.8%)
fs: ext4 block-size: 4096 B dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: b68a8072-f3c0-4f2e-9606-f869acbca128
ID-2: /boot raw-size: 300 MiB size: 271.1 MiB (90.37%)
used: 134.5 MiB (49.6%) fs: ext4 block-size: 1024 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: b888bcfa-ce5b-4d44-9be5-de9f47714adc
ID-3: /com/common raw-size: N/A size: 166.41 GiB used: 45.62 GiB (27.4%)
fs: zfs logical: z/common
ID-4: /com/doc raw-size: N/A size: 122.48 GiB used: 1.69 GiB (1.4%) fs: zfs
logical: z/doc
ID-5: /com/pic raw-size: N/A size: 144.79 GiB used: 24 GiB (16.6%) fs: zfs
logical: z/pic
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: dcf04137-619b-41d0-99fe-ef7e77c5534d
Use of uninitialized value $_ in regexp compilation at /usr/bin/inxi line 28076.
Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0020
Device-1: 1-1.3:3 info: Validity Sensors VFS451 Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
chip-ID: 138a:0007 class-ID: ff00 serial: <filter>
Device-2: 1-1.5:4 info: Chicony HP Webcam [2 MP Macro] type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 98mA chip-ID: 04f2:b15e class-ID: 0e02
Hub-3: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nouveau temp: 57.0 C
Fan Speeds (rpm): N/A
Processes: 308 Power: uptime: 1h 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.25 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1098 libs: 349 tools: pamac Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: Bash (su) v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.33
