I get a easily reproducible system freeze when running pcsx2 or dolphin emulators.
I have some stuff from the system log, but no idea what the issue is… GPU or CPU?
25/11/20 9:49 PM kernel ------------[ cut here ]------------
25/11/20 9:49 PM kernel Bogus possible_crtcs: [ENCODER:75:TMDS-75] possible_crtcs=0xf (full crtc mask=0x7)
25/11/20 9:49 PM kernel WARNING: CPU: 3 PID: 277 at drivers/gpu/drm/drm_mode_config.c:617 drm_mode_config_validate+0x178/0x200 [drm]
25/11/20 9:49 PM kernel Modules linked in: rfkill squashfs loop amdgpu(+) nct6775 hwmon_vid edac_mce_amd kvm wmi_bmof ppdev irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd glue_helper rapl snd_hda_codec_realtek pcspkr snd_hda_codec_generic ledtrig_audio k10temp snd_hda_codec_hdmi nls_iso8859_1 nls_cp437 gpu_sched vfat snd_hda_intel ttm fat snd_intel_dspcfg snd_hda_codec drm_kms_helper snd_hda_core snd_hwdep snd_pcm r8169 cec realtek ccp snd_timer rc_core mdio_devres syscopyarea sysfillrect snd sp5100_tco of_mdio fixed_phy sysimgblt igb rng_core fb_sys_fops soundcore i2c_piix4 libphy i2c_algo_bit dca parport_pc wmi parport evdev mac_hid pinctrl_amd gpio_amdpt acpi_cpufreq usbip_host usbip_core drm uinput msr crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 crc32c_intel xhci_pci xhci_hcd
25/11/20 9:49 PM kernel CPU: 3 PID: 277 Comm: systemd-udevd Tainted: G W 5.10.0-1-MANJARO #1
25/11/20 9:49 PM kernel Hardware name: Micro-Star International Co., Ltd MS-7B86/B450-A PRO MAX (MS-7B86), BIOS M.70 06/17/2020
25/11/20 9:49 PM kernel RIP: 0010:drm_mode_config_validate+0x178/0x200 [drm]
25/11/20 9:49 PM kernel Code: 39 d6 75 e6 45 85 c8 74 0a 44 89 c0 f7 d0 44 85 c8 74 19 49 8b 55 38 41 8b 75 18 44 89 c9 48 c7 c7 a0 f1 50 c0 e8 1a ce f2 d6 <0f> 0b 49 8b 45 08 4c 8d 68 f8 49 39 c4 0f 85 ed fe ff ff 5b 5d 41
25/11/20 9:49 PM kernel RSP: 0018:ffffb0d38108fa50 EFLAGS: 00010282
25/11/20 9:49 PM kernel RAX: 0000000000000000 RBX: ffffa1179ba002e0 RCX: 0000000000000000
25/11/20 9:49 PM kernel RDX: 0000000000000001 RSI: ffffffff97d7530f RDI: 00000000ffffffff
25/11/20 9:49 PM kernel RBP: 0000000000000001 R08: 0000000000000000 R09: ffffb0d38108f890
25/11/20 9:49 PM kernel R10: ffffb0d38108f888 R11: ffffa11a9f2ef8a8 R12: ffffa1179ba002e8
25/11/20 9:49 PM kernel R13: ffffa117961e3a00 R14: ffffa1179ba002e8 R15: 000000000000003f
25/11/20 9:49 PM kernel FS: 00007fe99e160440(0000) GS:ffffa11a908c0000(0000) knlGS:0000000000000000
25/11/20 9:49 PM kernel CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
25/11/20 9:49 PM kernel CR2: 000055bf25be875d CR3: 00000001132d6000 CR4: 00000000003506e0
25/11/20 9:49 PM kernel Call Trace:
25/11/20 9:49 PM kernel drm_dev_register+0x158/0x1b0 [drm]
25/11/20 9:49 PM kernel amdgpu_pci_probe+0x13c/0x1b0 [amdgpu]
25/11/20 9:49 PM kernel local_pci_probe+0x42/0x80
25/11/20 9:49 PM kernel ? pci_match_device+0xd7/0x100
25/11/20 9:49 PM kernel pci_device_probe+0xfa/0x1b0
25/11/20 9:49 PM kernel really_probe+0x205/0x460
25/11/20 9:49 PM kernel driver_probe_device+0xe1/0x150
25/11/20 9:49 PM kernel device_driver_attach+0xa1/0xb0
25/11/20 9:49 PM kernel __driver_attach+0x8a/0x150
25/11/20 9:49 PM kernel ? device_driver_attach+0xb0/0xb0
25/11/20 9:49 PM kernel bus_for_each_dev+0x89/0xd0
25/11/20 9:49 PM kernel bus_add_driver+0x12b/0x1e0
25/11/20 9:49 PM kernel driver_register+0x8b/0xe0
25/11/20 9:49 PM kernel ? 0xffffffffc133b000
25/11/20 9:49 PM kernel do_one_initcall+0x57/0x220
25/11/20 9:49 PM kernel do_init_module+0x5c/0x260
25/11/20 9:49 PM kernel load_module+0x23cb/0x25e0
25/11/20 9:49 PM kernel __do_sys_init_module+0x136/0x1b0
25/11/20 9:49 PM kernel do_syscall_64+0x33/0x40
25/11/20 9:49 PM kernel entry_SYSCALL_64_after_hwframe+0x44/0xa9
25/11/20 9:49 PM kernel RIP: 0033:0x7fe99ef14e4e
25/11/20 9:49 PM kernel Code: 48 8b 0d 25 10 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d f2 0f 0c 00 f7 d8 64 89 01 48
25/11/20 9:49 PM kernel RSP: 002b:00007ffeef0b0ae8 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
25/11/20 9:49 PM kernel RAX: ffffffffffffffda RBX: 0000559724012220 RCX: 00007fe99ef14e4e
25/11/20 9:49 PM kernel RDX: 00007fe99f04d95d RSI: 0000000000b31e09 RDI: 00007fe99c300010
25/11/20 9:49 PM kernel RBP: 00007fe99c300010 R08: fffffffffffffff0 R09: 0000000000b31e20
25/11/20 9:49 PM kernel R10: 000055972400a010 R11: 0000000000000246 R12: 00007fe99f04d95d
25/11/20 9:49 PM kernel R13: 0000000000000001 R14: 000055972419b280 R15: 0000559724012220
25/11/20 9:49 PM kernel ---[ end trace 5de4e3b15c72215b ]---
