My system froze again. I had to hold the power button until the pc powered off. It’s been a while since last time it has frozen without being related to hibernate. I was running (borg)backup prior to system update when this happened. It’s about 2 weeks since last time I updated the system.
Looking at the log, makes me wonder if something initiated a shutdown some minutes before the freeze. Maybe that could give a clue to why the system froze?
# journalctl -b-1 |tail -84
feb. 09 13:02:20 pl140 dbus-daemon[1325]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
feb. 09 13:02:20 pl140 systemd[1]: Started Network Manager Script Dispatcher Service.
feb. 09 13:02:30 pl140 systemd[1]: NetworkManager-dispatcher.service: Succeeded.
feb. 09 13:02:30 pl140 kernel: audit: type=1131 audit(1612872150.605:3737): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb. 09 13:02:30 pl140 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb. 09 13:12:32 pl140 lightdm[1128951]: gkr-pam: unable to locate daemon control file
feb. 09 13:12:32 pl140 audit[1128951]: USER_AUTH pid=1128951 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="pl" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 kernel: audit: type=1100 audit(1612872752.112:3738): pid=1128951 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="pl" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 kernel: audit: type=1101 audit(1612872752.112:3739): pid=1128951 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="pl" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 audit[1128951]: USER_ACCT pid=1128951 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="pl" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 lightdm[1128951]: gkr-pam: stashed password to try later in open session
feb. 09 13:12:32 pl140 dbus-daemon[1325]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.1688' (uid=0 pid=1128951 comm="lightdm --session-child 13 22 ")
feb. 09 13:12:32 pl140 dbus-daemon[1325]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
feb. 09 13:12:32 pl140 lightdm[1128951]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
feb. 09 13:12:32 pl140 audit[1128951]: CRED_REFR pid=1128951 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="pl" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 kernel: audit: type=1110 audit(1612872752.122:3740): pid=1128951 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="pl" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 systemd[1]: Stopping Session c72 of user lightdm.
feb. 09 13:12:32 pl140 lightdm[1128905]: pam_unix(lightdm-greeter:session): session closed for user lightdm
feb. 09 13:12:32 pl140 audit[1128905]: USER_END pid=1128905 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 audit[1128905]: CRED_DISP pid=1128905 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 systemd[1]: session-c72.scope: Succeeded.
feb. 09 13:12:32 pl140 systemd[1]: Stopped Session c72 of user lightdm.
feb. 09 13:12:32 pl140 kernel: audit: type=1106 audit(1612872752.422:3741): pid=1128905 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 kernel: audit: type=1104 audit(1612872752.422:3742): pid=1128905 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
feb. 09 13:12:32 pl140 systemd-logind[1331]: Removed session c72.
feb. 09 13:12:42 pl140 systemd[1]: Stopping User Manager for UID 969...
feb. 09 13:12:42 pl140 systemd[1128909]: Stopped target Main User Target.
feb. 09 13:12:42 pl140 systemd[1128909]: Stopping Accessibility services bus...
feb. 09 13:12:42 pl140 gvfsd[1128934]: A connection to the bus can't be made
feb. 09 13:12:42 pl140 systemd[1128909]: Stopping D-Bus User Message Bus...
feb. 09 13:12:42 pl140 systemd[1128909]: Stopping Virtual filesystem service...
feb. 09 13:12:42 pl140 systemd[1128909]: dbus.service: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Stopped D-Bus User Message Bus.
feb. 09 13:12:42 pl140 systemd[1128909]: at-spi-dbus-bus.service: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Stopped Accessibility services bus.
feb. 09 13:12:42 pl140 systemd[1751]: run-user-969-gvfs.mount: Succeeded.
feb. 09 13:12:42 pl140 kernel: audit: type=1131 audit(1612872762.502:3743): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb. 09 13:12:42 pl140 kernel: audit: type=1131 audit(1612872762.508:3744): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb. 09 13:12:42 pl140 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb. 09 13:12:42 pl140 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb. 09 13:12:42 pl140 systemd[1128910]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
feb. 09 13:12:42 pl140 systemd[1]: run-user-969-gvfs.mount: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: run-user-969-gvfs.mount: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: gvfs-daemon.service: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Stopped Virtual filesystem service.
feb. 09 13:12:42 pl140 systemd[1128909]: Stopped target Basic System.
feb. 09 13:12:42 pl140 systemd[1128909]: Stopped target Paths.
feb. 09 13:12:42 pl140 systemd[1128909]: Stopped target Sockets.
feb. 09 13:12:42 pl140 systemd[1128909]: Stopped target Timers.
feb. 09 13:12:42 pl140 systemd[1128909]: dbus.socket: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Closed D-Bus User Message Bus Socket.
feb. 09 13:12:42 pl140 systemd[1128909]: dirmngr.socket: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Closed GnuPG network certificate management daemon.
feb. 09 13:12:42 pl140 systemd[1128909]: gpg-agent-browser.socket: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
feb. 09 13:12:42 pl140 systemd[1128909]: gpg-agent-extra.socket: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
feb. 09 13:12:42 pl140 systemd[1128909]: gpg-agent-ssh.socket: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Closed GnuPG cryptographic agent (ssh-agent emulation).
feb. 09 13:12:42 pl140 systemd[1128909]: gpg-agent.socket: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Closed GnuPG cryptographic agent and passphrase cache.
feb. 09 13:12:42 pl140 systemd[1128909]: p11-kit-server.socket: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Closed p11-kit server.
feb. 09 13:12:42 pl140 systemd[1128909]: pipewire.socket: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Closed Multimedia System.
feb. 09 13:12:42 pl140 systemd[1128909]: pulseaudio.socket: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Closed Sound System.
feb. 09 13:12:42 pl140 systemd[1128909]: Removed slice User Application Slice.
feb. 09 13:12:42 pl140 systemd[1128909]: Reached target Shutdown.
feb. 09 13:12:42 pl140 systemd[1128909]: systemd-exit.service: Succeeded.
feb. 09 13:12:42 pl140 systemd[1128909]: Finished Exit the Session.
feb. 09 13:12:42 pl140 systemd[1128909]: Reached target Exit the Session.
feb. 09 13:12:42 pl140 systemd[1]: user@969.service: Succeeded.
feb. 09 13:12:42 pl140 systemd[1]: Stopped User Manager for UID 969.
feb. 09 13:12:42 pl140 systemd[1]: Stopping User Runtime Directory /run/user/969...
feb. 09 13:12:42 pl140 systemd[1751]: run-user-969.mount: Succeeded.
feb. 09 13:12:42 pl140 systemd[1]: run-user-969.mount: Succeeded.
feb. 09 13:12:42 pl140 systemd[1]: user-runtime-dir@969.service: Succeeded.
feb. 09 13:12:42 pl140 systemd[1]: Stopped User Runtime Directory /run/user/969.
feb. 09 13:12:42 pl140 systemd[1]: Removed slice User Slice of UID 969.
feb. 09 13:20:31 pl140 wpa_supplicant[1630]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-65 noise=9999 txrate=351000
feb. 09 13:24:11 pl140 rtkit-daemon[1869]: Supervising 0 threads of 0 processes of 0 users.
feb. 09 13:24:56 pl140 wpa_supplicant[1630]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-68 noise=9999 txrate=390000
