Hello
Issue: Sometimes upon waking the monitor(by interacting with mouse or kb), the system will freeze completely, the screen will show a frozen screen of the desktop.
This has happened numerous times the past 2 weeks I would say. I have no idea what I could really do about this.
Energy Saving settings in KDE:
- Screen Energy Saving: Switch off after 10mins.
- I don’t use sleep/hibernate/suspend, these are disabled manually with conf.d files.
The only notable changes to my system have been:
- a gpu upgrade about 2 months ago(AMD Vega64 to AMD 7900XT)
- BIOS tweaks, mainly power saving related.
Providing logs below, if there’s anymore info that could be useful, please let me know!
Thanks in advance!
inxi --admin --verbosity=7 --filter-all --width
Kernel: 6.2.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-x86_64 root=UUID=<filter> rw quiet
amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: ASUS product: All Series v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: RAMPAGE V EXTREME v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3902
date: 03/21/2018
RAM: total: 15.54 GiB used: 5.2 GiB (33.5%)
Info: model: Intel Core i7-5820K bits: 64 type: MT MCP arch: Haswell
gen: core 5 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3F (63) stepping: 2 microcode: 0x49
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 1433 high: 4000 min/max: 1200/4000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 4000 2: 1200 3: 1200
4: 1200 5: 1199 6: 1200 7: 1200 8: 1200 9: 1200 10: 1199 11: 1200 12: 1200
bogomips: 79186
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cqm cqm_llc cqm_occup_llc
cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma
fpu fsgsbase fxsr ht ibpb ibrs ida intel_ppin invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
pti pts rdrand rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme
x2apic xsave xsaveopt xtopology xtpr
Vulnerabilities: <filter>
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: Tul / PowerColor
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting unloaded: radeon alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-1 model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2016
res: 3440x1440 hz: 60 dpi: 109 gamma: 1.2 size: 800x335mm (31.5x13.19")
diag: 867mm (34.1") modes: max: 3440x1440 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon RX 7900 XT (gfx1100
LLVM 15.0.7 DRM 3.49 6.2.12-1-MANJARO) direct-render: Yes
Device-1: Intel C610/X99 series HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
class-ID: 0403
Device-2: AMD driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:ab30
class-ID: 0403
API: ALSA v: k6.2.12-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel
port: f000 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
IF-ID-1: br-c4334ff312b3 state: down mac: <filter>
IF-ID-2: <filter> state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> scope: link
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth28ef9ed state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: veth331bc3c state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: veth85c514d state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: veth9fbe4e8 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-8: vethc1cbb65 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-9: vethffbd045 state: up speed: 10000 Mbps duplex: full mac: <filter>
Local Storage: total: 22.54 TiB used: 17.75 TiB (78.8%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD40EFRX-68WT0N0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A82 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD120EMFZ-11A6JA0 size: 10.91 TiB block-size: physical: 4096 B
rev: 0A81 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD80EZAZ-11TDBA0 size: 7.28 TiB block-size: physical: 4096 B
rev: 0A83 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 249.8 GiB size: 244.83 GiB (98.01%)
used: 184.52 GiB (75.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: <filter> uuid: <filter>
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 62.5 MiB (6.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /disk/12 raw-size: 10.91 TiB size: 10.91 TiB (100.00%)
used: 7.7 TiB (70.5%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: <filter>
uuid: <filter>
ID-4: /disk/4 raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 3.34 TiB (91.7%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: <filter>
uuid: <filter>
ID-5: /disk/8 raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
used: 6.54 TiB (89.9%) fs: ntfs dev: /dev/sdd1 maj-min: 8:49 label: <filter>
uuid: <filter>
ID-1: swap-1 type: partition size: 8 GiB used: 2.2 MiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: <filter>
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 100 GiB fs: ntfs label: <filter>
uuid: <filter>
ID-3: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: ntfs label: <filter>
uuid: <filter>
ID-4: /dev/sda2 maj-min: 8:2 size: 299 MiB fs: vfat label: <filter>
uuid: <filter>
ID-5: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required>
ID-6: /dev/sda4 maj-min: 8:4 size: 231.58 GiB fs: ntfs label: <filter>
uuid: <filter>
ID-7: /dev/sda5 maj-min: 8:5 size: 606 MiB fs: ntfs label: N/A
uuid: <filter>
ID-8: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
ID-9: /dev/sde1 maj-min: 8:65 size: 3.29 GiB fs: iso9660
ID-10: /dev/sde2 maj-min: 8:66 size: 4 MiB fs: vfat label: <filter>
uuid: <filter>
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Hub ports: 6 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:800a class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel 8 channel internal hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8002 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 15 rev: 2.0
Device-1: 3-5:2 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
type: Keyboard,HID driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1b1c:1b2d class-ID: 0300 serial: <filter>
Device-2: 3-8:3 info: NZXT Smart Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 1e71:1714 class-ID: 0300 serial: <filter>
Hub-6: 3-9:4 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Hub-7: 3-10:5 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
Device-1: 3-11:7 info: Corsair H100i Platinum type: Keyboard
chip-ID: 1b1c:0c18 class-ID: 0300
Device-2: 3-14:8 info: Logitech G403 Prodigy Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c083 class-ID: 0300 serial: <filter>
Hub-8: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-9: 4-5:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Device-1: 4-5.1:4 info: SanDisk Ultra Flair type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 0781:5591 class-ID: 0806 serial: <filter>
Hub-10: 4-6:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
Hub-11: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-12: 6-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 28.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
mem: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 583
Processes: 392 Uptime: 1h 14m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1502 pm: pacman pkgs: 1496 libs: 407 tools: pamac,yay pm: flatpak
pkgs: 6 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.26
journalctl -b -1 --priority=4 --no-hostname --utc
apr 29 03:35:41 kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
apr 29 03:35:41 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
apr 29 03:35:41 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
apr 29 03:35:41 kernel: #7 #8 #9 #10 #11
apr 29 03:35:41 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
apr 29 03:35:41 kernel: pmd_set_huge: Cannot satisfy [mem 0xc0000000-0xc0200000] with a huge-page mapping due to MTRR override.
apr 29 03:35:41 kernel: ata1.00: supports DRM functions and may not be fully accessible
apr 29 03:35:41 kernel: ata1.00: NCQ Send/Recv Log not supported
apr 29 03:35:41 kernel: ata4.00: supports DRM functions and may not be fully accessible
apr 29 03:35:41 kernel: nvme nvme0: missing or invalid SUBNQN field.
apr 29 03:35:41 systemd-journald[355]: File /var/log/journal/f7e0cfa0e1cc42f1ad1e8a567a167f3c/system.journal corrupted or uncleanly shut down, renaming and replacing.
apr 29 03:35:41 kernel: i2c i2c-0: Systems with more than 4 memory slots not supported yet, not instantiating SPD
apr 29 03:35:41 (udev-worker)[408]: event9: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
apr 29 03:35:42 kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
apr 29 03:35:42 kernel: EDAC sbridge: Couldn't find mci handler
apr 29 03:35:42 kernel: EDAC sbridge: Failed to register device with error -19.
apr 29 03:35:43 kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
apr 29 03:35:44 kernel: ACPI Warning: SystemIO range 0x0000000000000295-0x0000000000000296 conflicts with OpRegion 0x0000000000000290-0x0000000000000299 (\_GPE.HWM) (20221020/utaddress-204)
apr 29 03:35:46 kernel: kauditd_printk_skb: 111 callbacks suppressed
apr 29 03:35:46 sddm-helper[1279]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'alias drun='sudo docker run -it --network=host --device=/dev/kfd --device=/dev/dri --group-add=video --ipc=host --cap-add=SYS_PTRACE --security-opt seccomp=unconfined -v $HOME/dockerx:/dockerx'' in /etc/environment', ignoring
apr 29 03:35:46 (systemd)[1281]: pam_env(systemd-user:session): non-alphanumeric key 'alias drun='sudo docker run -it --network=host --device=/dev/kfd --device=/dev/dri --group-add=video --ipc=host --cap-add=SYS_PTRACE --security-opt seccomp=unconfined -v $HOME/dockerx:/dockerx'' in /etc/environment', ignoring
apr 29 03:35:46 systemd-logind[676]: Configuration file /etc/systemd/sleep.conf.d/no-hibernate.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
apr 29 03:35:46 sddm-greeter[1290]: file:///usr/share/sddm/themes/sugar-candy/Components/VirtualKeyboard.qml:28:1: Type InputPanel unavailable
apr 29 03:35:46 sddm-greeter[1290]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
apr 29 03:35:46 sddm-greeter[1290]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
apr 29 03:35:46 sddm-greeter[1290]: file:///usr/share/sddm/themes/sugar-candy/Components/Input.qml:561:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
apr 29 03:35:46 sddm-greeter[1290]: file:///usr/share/sddm/themes/sugar-candy/Components/SystemButtons.qml:70:13: Unable to assign [undefined] to QQuickItem*
apr 29 03:35:46 sddm-greeter[1290]: file:///usr/share/sddm/themes/sugar-candy/Components/SessionButton.qml:38:5: Unable to assign ComboBox_QMLTYPE_10 to Control_QMLTYPE_16
apr 29 03:35:52 kernel: kauditd_printk_skb: 2 callbacks suppressed
apr 29 03:35:52 sddm-helper[1396]: pam_env(sddm:setcred): non-alphanumeric key 'alias drun='sudo docker run -it --network=host --device=/dev/kfd --device=/dev/dri --group-add=video --ipc=host --cap-add=SYS_PTRACE --security-opt seccomp=unconfined -v $HOME/dockerx:/dockerx'' in /etc/environment', ignoring
apr 29 03:35:52 sddm-helper[1279]: pam_env(sddm-greeter:setcred): non-alphanumeric key 'alias drun='sudo docker run -it --network=host --device=/dev/kfd --device=/dev/dri --group-add=video --ipc=host --cap-add=SYS_PTRACE --security-opt seccomp=unconfined -v $HOME/dockerx:/dockerx'' in /etc/environment', ignoring
apr 29 03:35:53 (systemd)[1554]: pam_env(systemd-user:session): non-alphanumeric key 'alias drun='sudo docker run -it --network=host --device=/dev/kfd --device=/dev/dri --group-add=video --ipc=host --cap-add=SYS_PTRACE --security-opt seccomp=unconfined -v $HOME/dockerx:/dockerx'' in /etc/environment', ignoring
apr 29 03:35:53 systemd-journald[355]: File /var/log/journal/f7e0cfa0e1cc42f1ad1e8a567a167f3c/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
apr 29 03:35:53 systemd-xdg-autostart-generator[1658]: /home/franky/.config/autostart/pulseeffects-service.desktop: not generating unit, error parsing Exec= line: No such file or directory
apr 29 03:35:53 systemd-xdg-autostart-generator[1658]: /home/franky/.config/autostart/easyeffects-service.desktop: not generating unit, error parsing Exec= line: No such file or directory
apr 29 03:35:53 sddm-helper[1396]: pam_env(sddm:session): non-alphanumeric key 'alias drun='sudo docker run -it --network=host --device=/dev/kfd --device=/dev/dri --group-add=video --ipc=host --cap-add=SYS_PTRACE --security-opt seccomp=unconfined -v $HOME/dockerx:/dockerx'' in /etc/environment', ignoring
apr 29 03:35:53 ksplashqml[1906]: file:///home/franky/.local/share/plasma/look-and-feel/com.github.vinceliuice.Qogir-dark/contents/splash/Splash.qml:89: ReferenceError: bottomRect is not defined
apr 29 03:35:53 ksplashqml[1906]: file:///home/franky/.local/share/plasma/look-and-feel/com.github.vinceliuice.Qogir-dark/contents/splash/Splash.qml:88: ReferenceError: bottomRect is not defined
apr 29 03:35:53 systemd-xdg-autostart-generator[2111]: /home/franky/.config/autostart/pulseeffects-service.desktop: not generating unit, error parsing Exec= line: No such file or directory
apr 29 03:35:53 systemd-xdg-autostart-generator[2111]: /home/franky/.config/autostart/easyeffects-service.desktop: not generating unit, error parsing Exec= line: No such file or directory
apr 29 03:35:54 ksmserver[2465]: Qt: Session management error: networkIdsList argument is NULL
apr 29 03:35:54 kwin_x11[2473]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
apr 29 03:35:54 kwin_x11[2473]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
apr 29 03:35:54 ksmserver[2465]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
apr 29 03:35:54 baloo_file[2249]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.36'
apr 29 03:35:54 kded5[2469]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
apr 29 03:35:54 kded5[2469]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
apr 29 03:35:54 backlighthelper[3266]: org.kde.powerdevil: no kernel backlight interface found
apr 29 03:35:55 org_kde_powerdevil[3157]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
apr 29 03:35:55 org_kde_powerdevil[3157]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
apr 29 03:35:55 pipewire-media-session[3286]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
apr 29 03:35:55 pipewire-media-session[3286]: mod.rt: found session bus but no portal
apr 29 03:35:55 pipewire[3284]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
apr 29 03:35:55 pipewire[3284]: mod.rt: found session bus but no portal
apr 29 03:35:55 systemd-logind[676]: Configuration file /etc/systemd/sleep.conf.d/no-hibernate.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
apr 29 03:35:55 kded5[2469]: kscreen.kded: PowerDevil SuspendSession action not available!
apr 29 03:35:55 plasmashell[2896]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
apr 29 03:35:55 plasmashell[2896]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
apr 29 03:35:55 plasmashell[2896]: Checking screens: available: (QScreen(0x55c5346cbdb0, name="DP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x55c5346cbdb0, name="DP-1"))
apr 29 03:35:55 org_kde_powerdevil[3157]: org.kde.powerdevil: Handle button events action could not check for screen configuration
apr 29 03:35:55 org_kde_powerdevil[3157]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
apr 29 03:35:55 ksystemstats[3384]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Fan %1" msgid_plural: "" msgctxt: "@title %1 is a number"
apr 29 03:35:55 kioslave5[3808]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
apr 29 03:35:55 ckb-next[3328]: QObject::startTimer: Timers cannot have negative intervals
apr 29 03:35:56 kwin_x11[2473]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
apr 29 03:35:56 plasmashell[2896]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
apr 29 03:35:56 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.milou/contents/ui/main.qml:47:17: Unable to assign double to QQuickAnchorLine
apr 29 03:35:56 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
apr 29 03:35:56 pulseaudio[4411]: stat('/etc/pulse/default.pa.d'): No such file or directory
apr 29 03:35:56 plasmashell[2896]: file:///home/franky/.local/share/plasma/plasmoids/com.github.davide-sd.ipaddress/contents/ui/main.qml:321: TypeError: Cannot read property 'country' of undefined
apr 29 03:35:56 plasmashell[2896]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.textonly/contents/ui/CompactRepresentation.qml:21:1: QML CompactRepresentation (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "maximumWidth"
apr 29 03:35:57 plasmashell[2896]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
apr 29 03:35:57 plasmashell[2896]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
apr 29 03:35:57 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
apr 29 03:35:57 plasmashell[2896]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 29 03:35:57 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.milou/contents/ui/main.qml:47:17: Unable to assign double to QQuickAnchorLine
apr 29 03:35:57 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 03:35:58 plasmashell[2896]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 29 03:35:59 plasmashell[2896]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 29 03:35:59 kernel: kauditd_printk_skb: 698 callbacks suppressed
apr 29 03:36:00 plasmashell[2896]: QObject::connect(QQuickWindow, QDeclarativeGeoMap): invalid nullptr parameter
apr 29 03:36:00 plasmashell[2896]: QGeoTileProviderOsm: Tileserver disabled at QUrl("http://maps-redirect.qt.io/osm/5.8/satellite")
apr 29 03:36:00 plasmashell[2896]: QGeoTileFetcherOsm: all providers resolved
apr 29 03:36:01 plasmashell[2896]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
apr 29 03:36:02 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:61:17: Unable to assign [undefined] to int
apr 29 03:36:02 plasmashell[2896]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
apr 29 03:36:03 plasmashell[2896]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55c5385ae6c0) QQmlContext(0x55c535e87970) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
apr 29 03:36:21 systemd[1554]: app-org.corectrl.corectrl@autostart.service: Failed with result 'exit-code'.
apr 29 03:36:21 pulseaudio[4411]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
apr 29 03:38:55 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
apr 29 03:38:57 kioslave5[5437]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 03:38:57 kioslave5[5459]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 03:38:57 kioslave5[5459]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:39:05 kioslave5[5494]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 03:39:11 kioslave5[5525]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:39:11 kioslave5[5525]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:39:12 kioslave5[5544]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:39:13 kioslave5[5559]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:39:13 kioslave5[5573]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:39:22 kioslave5[5675]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:39:30 kioslave5[5675]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:39:37 kioslave5[5755]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:39:56 kioslave5[5870]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:41:56 kioslave5[6665]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:42:01 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
apr 29 03:42:01 konsole[6709]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
apr 29 03:42:01 konsole[6709]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
apr 29 03:46:24 kioslave5[9311]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:46:32 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
apr 29 03:46:32 firefox[9368]: Theme directory 32/emblems of theme Eleven has no size field
apr 29 03:46:32 firefox[9368]: Theme directory 32@2x/emblems of theme Eleven has no size field
apr 29 03:46:32 firefox[9368]: Theme directory 48/emblems of theme Eleven has no size field
apr 29 03:46:32 firefox[9368]: Theme directory 48@2x/emblems of theme Eleven has no size field
apr 29 03:47:00 kioslave5[10623]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:03 kioslave5[10688]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:27 kioslave5[10824]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:31 kioslave5[10857]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:37 kioslave5[10912]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:37 kioslave5[10912]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:47:38 kioslave5[10912]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:39 kioslave5[10945]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:40 dolphin[5391]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:47:45 kioslave5[10945]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:47 baloo_filemetadata_temp_extractor[11017]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:47:47 baloo_filemetadata_temp_extractor[11017]: libpng warning: iCCP: cHRM chunk does not match sRGB
apr 29 03:47:47 kioslave5[10945]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:47:47 kioslave5[10945]: libpng warning: iCCP: cHRM chunk does not match sRGB
apr 29 03:47:48 kioslave5[11024]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:55 kioslave5[11035]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:55 kioslave5[11035]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:47:56 kioslave5[11086]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:47:56 kioslave5[11086]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:47:59 kioslave5[11086]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:48:00 kioslave5[11118]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:48:01 kioslave5[11118]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:48:01 kioslave5[11118]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:48:02 kioslave5[11118]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 03:49:14 kernel: kauditd_printk_skb: 2 callbacks suppressed
apr 29 03:57:12 kioslave5[13954]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:13 kioslave5[13954]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:14 kioslave5[13978]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:14 kioslave5[13978]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 03:57:15 kioslave5[13978]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:15 kioslave5[13978]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:57:16 kioslave5[13978]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/gsthumbnail.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/gsthumbnail.so'"
apr 29 03:57:16 kioslave5[14023]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:17 kioslave5[14023]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 03:57:17 kioslave5[14023]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:18 kioslave5[14023]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:24 kioslave5[14023]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:24 kioslave5[14023]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:57:26 kioslave5[14084]: libpng warning: iCCP: known incorrect sRGB profile
apr 29 03:57:26 kioslave5[14084]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:28 kioslave5[14125]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 03:57:35 kioslave5[14147]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:05:49 kioslave5[15914]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:07:36 kioslave5[16340]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:07:39 kioslave5[16358]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:12:20 kioslave5[17381]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:13:26 kioslave5[17758]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:13:26 kioslave5[17758]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 04:13:26 kioslave5[17791]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:13:27 kioslave5[17791]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 04:13:27 dolphin[5391]: QObject::disconnect: Unexpected nullptr parameter
apr 29 04:13:27 kioslave5[17791]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:13:30 kioslave5[17845]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:13:38 kioslave5[17895]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:19:26 kioslave5[19738]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:30:54 dolphin[5391]: QObject::disconnect: Unexpected nullptr parameter
apr 29 04:30:57 kioslave5[22329]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:30:59 kioslave5[22366]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:31:18 kioslave5[22493]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:31:20 kioslave5[22537]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:31:59 kioslave5[22698]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:32:00 kioslave5[22738]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:32:05 kioslave5[22768]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:32:45 kioslave5[23000]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 04:57:02 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 04:59:42 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 04:59:42 kwin_x11[2473]: kwin_core: Parse error in tiles configuration for monitor "5b7a5ba4-43cc-5910-8e98-f358f9d54b43" : "illegal value" Creating default setup
apr 29 04:59:43 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 04:59:44 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 04:59:44 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 04:59:45 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 05:00:54 kioslave5[29922]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 05:02:15 kioslave5[30606]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 05:02:38 kioslave5[30724]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 05:02:38 kioslave5[30724]: Not a JPEG file: starts with 0x89 0x50
apr 29 05:02:38 kioslave5[30748]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 05:02:38 kioslave5[30748]: Not a JPEG file: starts with 0x89 0x50
apr 29 05:02:38 kioslave5[30748]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:15:12 kioslave5[35203]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 05:15:12 kioslave5[35203]: Not a JPEG file: starts with 0x89 0x50
apr 29 05:15:12 kioslave5[35216]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 05:15:12 kioslave5[35216]: Not a JPEG file: starts with 0x89 0x50
apr 29 05:15:13 kioslave5[35216]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:15:33 kwin_x11[2473]: kwin_core: XCB error: 152 (BadDamage), sequence: 49994, resource id: 16946566, major code: 143 (DAMAGE), minor code: 3 (Subtract)
apr 29 05:15:35 kioslave5[35403]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
apr 29 05:15:35 kioslave5[35403]: Not a JPEG file: starts with 0x89 0x50
apr 29 05:15:43 kioslave5[35424]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:15:43 kioslave5[35457]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:15:45 kioslave5[35477]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:15:47 kioslave5[35495]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:16:07 vlc[35530]: uint DBusMenuExporterDBus::GetLayout(int, int, const QStringList&, DBusMenuLayoutItem&): Condition failed: menu
apr 29 05:16:08 kioslave5[35703]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:16:08 kioslave5[35727]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:16:31 kioslave5[35886]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:17:13 vlc[35757]: uint DBusMenuExporterDBus::GetLayout(int, int, const QStringList&, DBusMenuLayoutItem&): Condition failed: menu
apr 29 05:17:18 kioslave5[36084]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:17:18 kioslave5[36099]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:18:44 kioslave5[36492]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:18:45 kioslave5[36506]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
apr 29 05:18:49 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:88:9: QML ScrollView: Binding loop detected for property "implicitWidth"
apr 29 05:18:51 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:88:9: QML ScrollView: Binding loop detected for property "implicitWidth"
apr 29 05:43:31 plasmashell[2896]: trying to show an empty dialog
apr 29 05:43:46 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 29170, resource id: 20971833, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 05:45:03 kwin_x11[2473]: kwin_core: XCB error: 152 (BadDamage), sequence: 2273, resource id: 16987958, major code: 143 (DAMAGE), minor code: 3 (Subtract)
apr 29 06:47:08 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 14:06:26 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 14:06:27 kwin_x11[2473]: kwin_core: Parse error in tiles configuration for monitor "5b7a5ba4-43cc-5910-8e98-f358f9d54b43" : "illegal value" Creating default setup
apr 29 14:06:28 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 14:06:28 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 14:06:29 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 14:16:27 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 14:57:08 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 14:57:09 kwin_x11[2473]: kwin_core: Parse error in tiles configuration for monitor "5b7a5ba4-43cc-5910-8e98-f358f9d54b43" : "illegal value" Creating default setup
apr 29 14:57:10 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 14:57:10 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 14:57:11 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 14:57:11 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 14:58:37 kwin_x11[2473]: kwin_core: XCB error: 152 (BadDamage), sequence: 59531, resource id: 16966749, major code: 143 (DAMAGE), minor code: 3 (Subtract)
apr 29 14:58:46 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
apr 29 14:58:47 konsole[158119]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
apr 29 14:58:47 konsole[158119]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
apr 29 15:02:19 kernel: kauditd_printk_skb: 45 callbacks suppressed
apr 29 15:02:31 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
apr 29 15:07:47 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
apr 29 15:12:12 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 15:13:03 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
apr 29 15:18:03 systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
apr 29 15:18:03 systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
apr 29 15:18:03 systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
apr 29 19:59:35 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 19:59:36 kwin_x11[2473]: kwin_core: Parse error in tiles configuration for monitor "5b7a5ba4-43cc-5910-8e98-f358f9d54b43" : "illegal value" Creating default setup
apr 29 19:59:37 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 19:59:37 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 19:59:38 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 19:59:55 firefox[308399]: Theme directory 32/emblems of theme Eleven has no size field
apr 29 19:59:55 firefox[308399]: Theme directory 32@2x/emblems of theme Eleven has no size field
apr 29 19:59:55 firefox[308399]: Theme directory 48/emblems of theme Eleven has no size field
apr 29 19:59:55 firefox[308399]: Theme directory 48@2x/emblems of theme Eleven has no size field
apr 29 19:59:55 plasmashell[2896]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
apr 29 20:18:26 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 20:59:42 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 20:59:43 kwin_x11[2473]: kwin_core: Parse error in tiles configuration for monitor "5b7a5ba4-43cc-5910-8e98-f358f9d54b43" : "illegal value" Creating default setup
apr 29 20:59:44 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 20:59:44 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 20:59:45 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 20:59:45 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 21:09:43 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 21:13:54 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 21:13:54 kwin_x11[2473]: kwin_core: Parse error in tiles configuration for monitor "5b7a5ba4-43cc-5910-8e98-f358f9d54b43" : "illegal value" Creating default setup
apr 29 21:13:55 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 21:13:56 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 21:13:56 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 29 21:13:57 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 21:21:32 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 46153, resource id: 54525979, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 21:41:06 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 35920, resource id: 54526003, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 21:41:30 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 51836, resource id: 54526005, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 21:41:40 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 56607, resource id: 54526006, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 21:45:39 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 56669, resource id: 54526018, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 21:48:40 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 48411, resource id: 54526020, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 21:52:30 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 27577, resource id: 54526022, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 21:54:16 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 24318, resource id: 54526024, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 22:07:04 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 62911, resource id: 54526030, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 22:07:39 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 17541, resource id: 54526033, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 22:08:18 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 39278, resource id: 54526036, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 22:08:21 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 41487, resource id: 54526037, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 22:08:41 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 52333, resource id: 54526039, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 22:08:52 kwin_x11[2473]: kwin_core: XCB error: 3 (BadWindow), sequence: 58144, resource id: 54526041, major code: 129 (SHAPE), minor code: 6 (Input)
apr 29 22:19:04 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 29 22:35:56 kernel: kauditd_printk_skb: 6 callbacks suppressed
apr 30 01:28:14 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 30 01:28:14 kwin_x11[2473]: kwin_core: Parse error in tiles configuration for monitor "5b7a5ba4-43cc-5910-8e98-f358f9d54b43" : "illegal value" Creating default setup
apr 30 01:28:15 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 30 01:28:15 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 30 01:28:16 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 30 01:28:16 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 30 01:33:23 plasmashell[2896]: kde.systemtray: DBusMenu disabled for this application
apr 30 01:45:51 kwin_x11[2473]: kwin_core: XCB error: 152 (BadDamage), sequence: 11839, resource id: 17086647, major code: 143 (DAMAGE), minor code: 3 (Subtract)
apr 30 01:45:58 kwin_x11[2473]: kwin_core: XCB error: 152 (BadDamage), sequence: 14545, resource id: 17185308, major code: 143 (DAMAGE), minor code: 3 (Subtract)
apr 30 01:46:02 plasmashell[2896]: trying to show an empty dialog
apr 30 01:46:03 plasmashell[2896]: file:///usr/lib/qt/qml/org/kde/plasma/core/private/DefaultToolTip.qml:69:13: QML Label: Binding loop detected for property "verticalAlignment"
apr 30 01:56:05 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 30 04:09:54 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 30 04:09:55 kwin_x11[2473]: kwin_core: Parse error in tiles configuration for monitor "5b7a5ba4-43cc-5910-8e98-f358f9d54b43" : "illegal value" Creating default setup
apr 30 04:09:56 kded5[2469]: kscreen.kded: Config does not have at least one screen enabled, WILL NOT save this config, this is not what user wants.
apr 30 04:09:56 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
apr 30 04:09:57 kernel: general protection fault, probably for non-canonical address 0x100000000000398: 0000 [#1] PREEMPT SMP PTI
apr 30 04:09:57 kernel: CPU: 2 PID: 881 Comm: Xorg Not tainted 6.2.12-1-MANJARO #1 65c3d4b13cb1741ad3f1b151a7c6dadccd1a1003
apr 30 04:09:57 kernel: Hardware name: ASUS All Series/RAMPAGE V EXTREME, BIOS 3902 03/21/2018
apr 30 04:09:57 kernel: RIP: 0010:dc_plane_state_retain+0x15/0x50 [amdgpu]
apr 30 04:09:57 kernel: Code: 00 00 00 00 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 66 0f 1f 00 0f 1f 44 00 00 48 8d 8f 98 03 00 00 b8 01 00 00 00 <f0> 0f c1 87 98 03 00 00 85 c0 74 19 8d 50 01 09 c2 78 05 c3 cc cc
apr 30 04:09:57 kernel: RSP: 0018:ffffac81c350bbf0 EFLAGS: 00010206
apr 30 04:09:57 kernel: RAX: 0000000000000001 RBX: ffff8b2748dbe6c0 RCX: 0100000000000398
apr 30 04:09:57 kernel: RDX: 0000000000000000 RSI: ffff8b2821313818 RDI: 0100000000000000
apr 30 04:09:57 kernel: RBP: ffff8b2748d13c00 R08: 00000000000000c0 R09: ffff8b2748dbe6c0
apr 30 04:09:57 kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff8b2821313780
apr 30 04:09:57 kernel: R13: 0000000000000001 R14: ffff8b275b0cfa00 R15: ffff8b275d1ac800
apr 30 04:09:57 kernel: FS: 00007fd418fad400(0000) GS:ffff8b2a6fa80000(0000) knlGS:0000000000000000
apr 30 04:09:57 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
apr 30 04:09:57 kernel: CR2: 000055b5ad2ee8b4 CR3: 00000001195f6003 CR4: 00000000001706e0
apr 30 04:09:57 kernel: Call Trace:
apr 30 04:09:57 kernel: <TASK>
apr 30 04:09:57 kernel: dm_drm_plane_duplicate_state+0x59/0x70 [amdgpu cc7b74e0a84a6c1a27fb69a563cd786ea6f9003a]
apr 30 04:09:57 kernel: drm_atomic_get_plane_state+0x99/0x180
apr 30 04:09:57 kernel: __drm_atomic_helper_set_config+0x68/0x340
apr 30 04:09:57 kernel: drm_atomic_helper_set_config+0x36/0xb0
apr 30 04:09:57 kernel: drm_mode_setcrtc+0x515/0x7e0
apr 30 04:09:57 kernel: ? __pfx_drm_mode_setcrtc+0x10/0x10
apr 30 04:09:57 kernel: drm_ioctl_kernel+0xcd/0x170
apr 30 04:09:57 kernel: drm_ioctl+0x233/0x410
apr 30 04:09:57 kernel: amdgpu_drm_ioctl+0x4e/0x90 [amdgpu cc7b74e0a84a6c1a27fb69a563cd786ea6f9003a]
apr 30 04:09:57 kernel: __x64_sys_ioctl+0x94/0xd0
apr 30 04:09:57 kernel: do_syscall_64+0x5f/0x90
apr 30 04:09:57 kernel: entry_SYSCALL_64_after_hwframe+0x72/0xdc
apr 30 04:09:57 kernel: RIP: 0033:0x7fd41997e53f
apr 30 04:09:57 kernel: Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 48 2b 04 25 28 00 00
apr 30 04:09:57 kernel: RSP: 002b:00007fffa7a3d290 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
apr 30 04:09:57 kernel: RAX: ffffffffffffffda RBX: 000055aab0364b20 RCX: 00007fd41997e53f
apr 30 04:09:57 kernel: RDX: 00007fffa7a3d320 RSI: 00000000c06864a2 RDI: 0000000000000012
apr 30 04:09:57 kernel: RBP: 00007fffa7a3d320 R08: 0000000000000000 R09: 0000000000000000
apr 30 04:09:57 kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00000000c06864a2
apr 30 04:09:57 kernel: R13: 0000000000000012 R14: 0000000000000000 R15: 000055aab0b124d0
apr 30 04:09:57 kernel: </TASK>
apr 30 04:09:57 kernel: Modules linked in: snd_seq_dummy snd_seq snd_seq_device veth xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptable_filter br_netfilter bridge stp llc joydev mousedev qrtr overlay squashfs nct6775 nct6775_core hwmon_vid uas vfat usb_storage fat amdgpu intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp snd_hda_codec_realtek coretemp snd_hda_codec_generic crct10dif_pclmul snd_hda_codec_hdmi crc32_pclmul polyval_clmulni polyval_generic snd_hda_intel gf128mul snd_intel_dspcfg ghash_clmulni_intel eeepc_wmi sha512_ssse3 asus_wmi snd_intel_sdw_acpi aesni_intel drm_buddy snd_hda_codec crypto_simd ledtrig_audio sparse_keymap gpu_sched cryptd snd_hda_core platform_profile iTCO_wdt rapl rfkill intel_pmc_bxt snd_hwdep drm_ttm_helper i2c_dev video wmi_bmof mxm_wmi intel_wmi_thunderbolt iTCO_vendor_support intel_cstate ttm snd_pcm drm_display_helper mei_me
apr 30 04:09:57 kernel: snd_timer i2c_i801 snd intel_uncore pcspkr cec i2c_smbus e1000e mei lpc_ich soundcore wmi mac_hid uinput sg crypto_user dm_mod loop fuse bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache usbhid jbd2 nvme nvme_core xhci_pci xhci_pci_renesas nvme_common crc32c_intel
apr 30 04:09:57 kernel: ---[ end trace 0000000000000000 ]---
apr 30 04:09:57 plasmashell[2896]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
