Here is the log while running those params
Aug 24 23:17:22 arch kernel: pci 0000:05:00.0: Adding to iommu group 16
Aug 24 23:17:22 arch kernel: pci 0000:05:00.1: Adding to iommu group 16
Aug 24 23:17:22 arch kernel: pci 0000:05:00.3: Adding to iommu group 16
Aug 24 23:17:22 arch kernel: pci 0000:06:00.0: Adding to iommu group 17
Aug 24 23:17:22 arch kernel: pci 0000:07:00.0: Adding to iommu group 18
Aug 24 23:17:22 arch kernel: pci 0000:08:00.0: Adding to iommu group 21
Aug 24 23:17:22 arch kernel: pci 0000:08:00.1: Adding to iommu group 21
Aug 24 23:17:22 arch kernel: pci 0000:08:00.2: Adding to iommu group 21
Aug 24 23:17:22 arch kernel: pci 0000:08:00.3: Adding to iommu group 21
Aug 24 23:17:22 arch kernel: pci 0000:09:00.0: Adding to iommu group 22
Aug 24 23:17:22 arch kernel: pci 0000:0a:00.0: Adding to iommu group 23
Aug 24 23:17:22 arch kernel: pci 0000:0a:00.1: Adding to iommu group 24
Aug 24 23:17:22 arch kernel: pci 0000:0a:00.3: Adding to iommu group 25
Aug 24 23:17:22 arch kernel: pci 0000:0a:00.4: Adding to iommu group 26
Aug 24 23:17:22 arch kernel: pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
Aug 24 23:17:22 arch kernel: AMD-Vi: Extended features (0x58f77ef22294a5a): PPR NX GT IA PC GA_vAPIC
Aug 24 23:17:22 arch kernel: AMD-Vi: Interrupt remapping enabled
Aug 24 23:17:22 arch kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Aug 24 23:17:22 arch kernel: software IO TLB: mapped [mem 0x00000000bb153000-0x00000000bf153000] (64MB)
Aug 24 23:17:22 arch kernel: LVT offset 0 assigned for vector 0x400
Aug 24 23:17:22 arch kernel: perf: AMD IBS detected (0x000003ff)
Aug 24 23:17:22 arch kernel: perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
Aug 24 23:17:22 arch kernel: Initialise system trusted keyrings
Aug 24 23:17:22 arch kernel: Key type blacklist registered
Aug 24 23:17:22 arch kernel: workingset: timestamp_bits=41 max_order=22 bucket_order=0
Aug 24 23:17:22 arch kernel: zbud: loaded
Aug 24 23:17:22 arch kernel: Key type asymmetric registered
Aug 24 23:17:22 arch kernel: Asymmetric key parser 'x509' registered
Aug 24 23:17:22 arch kernel: Freeing initrd memory: 8680K
Aug 24 23:17:22 arch kernel: alg: self-tests for CTR-KDF (hmac(sha256)) passed
Aug 24 23:17:22 arch kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
Aug 24 23:17:22 arch kernel: io scheduler mq-deadline registered
Aug 24 23:17:22 arch kernel: io scheduler kyber registered
Aug 24 23:17:22 arch kernel: io scheduler bfq registered
Aug 24 23:17:22 arch kernel: pcieport 0000:00:01.2: AER: enabled with IRQ 27
Aug 24 23:17:22 arch kernel: pcieport 0000:00:03.1: AER: enabled with IRQ 28
Aug 24 23:17:22 arch kernel: pcieport 0000:00:07.1: AER: enabled with IRQ 30
Aug 24 23:17:22 arch kernel: pcieport 0000:00:08.1: AER: enabled with IRQ 31
Aug 24 23:17:22 arch kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Aug 24 23:17:22 arch kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
Aug 24 23:17:22 arch kernel: ACPI: button: Power Button [PWRB]
Aug 24 23:17:22 arch kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
Aug 24 23:17:22 arch kernel: ACPI: button: Power Button [PWRF]
Aug 24 23:17:22 arch kernel: smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1106
Aug 24 23:17:22 arch kernel: Monitor-Mwait will be used to enter C-1 state
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C000: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C002: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C004: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C006: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C008: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C00A: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C001: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C003: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C005: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C007: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C009: Found 2 idle states
Aug 24 23:17:22 arch kernel: ACPI: \_PR_.C00B: Found 2 idle states
Aug 24 23:17:22 arch kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Aug 24 23:17:22 arch kernel: 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
Aug 24 23:17:22 arch kernel: Non-volatile memory driver v1.3
Aug 24 23:17:22 arch kernel: Linux agpgart interface v0.103
Aug 24 23:17:22 arch kernel: AMD-Vi: AMD IOMMUv2 loaded and initialized
Aug 24 23:17:22 arch kernel: ACPI: bus type drm_connector registered
Aug 24 23:17:22 arch kernel: ahci 0000:06:00.0: version 3.0
Aug 24 23:17:22 arch kernel: ahci 0000:06:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
Aug 24 23:17:22 arch kernel: ahci 0000:06:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
Aug 24 23:17:22 arch kernel: scsi host0: ahci
Aug 24 23:17:22 arch kernel: ata1: SATA max UDMA/133 abar m2048@0xfc500000 port 0xfc500100 irq 39
Aug 24 23:17:22 arch kernel: ahci 0000:07:00.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x21 impl SATA mode
Aug 24 23:17:22 arch kernel: ahci 0000:07:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
Aug 24 23:17:22 arch kernel: scsi host1: ahci
Aug 24 23:17:22 arch kernel: scsi host2: ahci
Aug 24 23:17:22 arch kernel: scsi host3: ahci
Aug 24 23:17:22 arch kernel: scsi host4: ahci
Aug 24 23:17:22 arch kernel: scsi host5: ahci
Aug 24 23:17:22 arch kernel: scsi host6: ahci
Aug 24 23:17:22 arch kernel: ata2: SATA max UDMA/133 abar m2048@0xfc400000 port 0xfc400100 irq 40
Aug 24 23:17:22 arch kernel: ata3: DUMMY
Aug 24 23:17:22 arch kernel: ata4: DUMMY
Aug 24 23:17:22 arch kernel: ata5: DUMMY
Aug 24 23:17:22 arch kernel: ata6: DUMMY
Aug 24 23:17:22 arch kernel: ata7: SATA max UDMA/133 abar m2048@0xfc400000 port 0xfc400380 irq 45
Aug 24 23:17:22 arch kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 24 23:17:22 arch kernel: ehci-pci: EHCI PCI platform driver
Aug 24 23:17:22 arch kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 24 23:17:22 arch kernel: ohci-pci: OHCI PCI platform driver
Aug 24 23:17:22 arch kernel: uhci_hcd: USB Universal Host Controller Interface driver
Aug 24 23:17:22 arch kernel: usbcore: registered new interface driver usbserial_generic
Aug 24 23:17:22 arch kernel: usbserial: USB Serial support registered for generic
Aug 24 23:17:22 arch kernel: rtc_cmos 00:02: RTC can wake from S4
Aug 24 23:17:22 arch kernel: rtc_cmos 00:02: registered as rtc0
Aug 24 23:17:22 arch kernel: rtc_cmos 00:02: setting system clock to 2022-08-24T22:17:21 UTC (1661379441)
Aug 24 23:17:22 arch kernel: rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
Aug 24 23:17:22 arch kernel: ledtrig-cpu: registered to indicate activity on CPUs
Aug 24 23:17:22 arch kernel: efifb: probing for efifb
Aug 24 23:17:22 arch kernel: efifb: showing boot graphics
Aug 24 23:17:22 arch kernel: efifb: framebuffer at 0xe1000000, using 8128k, total 8128k
Aug 24 23:17:22 arch kernel: efifb: mode is 1920x1080x32, linelength=7680, pages=1
Aug 24 23:17:22 arch kernel: efifb: scrolling: redraw
Aug 24 23:17:22 arch kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Aug 24 23:17:22 arch kernel: fbcon: Deferring console take-over
Aug 24 23:17:22 arch kernel: fb0: EFI VGA frame buffer device
Aug 24 23:17:22 arch kernel: hid: raw HID events driver (C) Jiri Kosina
Aug 24 23:17:22 arch kernel: drop_monitor: Initializing network drop monitor service
Aug 24 23:17:22 arch kernel: Initializing XFRM netlink socket
Aug 24 23:17:22 arch kernel: NET: Registered PF_INET6 protocol family
Aug 24 23:17:22 arch kernel: Segment Routing with IPv6
Aug 24 23:17:22 arch kernel: RPL Segment Routing with IPv6
Aug 24 23:17:22 arch kernel: In-situ OAM (IOAM) with IPv6
Aug 24 23:17:22 arch kernel: NET: Registered PF_PACKET protocol family
Aug 24 23:17:22 arch kernel: microcode: CPU0: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU1: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU2: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU3: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU4: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU5: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU6: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU7: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU8: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU9: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU10: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: CPU11: patch_level=0x08701021
Aug 24 23:17:22 arch kernel: microcode: Microcode Update Driver: v2.2.
Aug 24 23:17:22 arch kernel: resctrl: L3 allocation detected
Aug 24 23:17:22 arch kernel: resctrl: MB allocation detected
Aug 24 23:17:22 arch kernel: resctrl: L3 monitoring detected
Aug 24 23:17:22 arch kernel: IPI shorthand broadcast: enabled
Aug 24 23:17:22 arch kernel: sched_clock: Marking stable (413609648, 313559016)->(848587493, -121418829)
Aug 24 23:17:22 arch kernel: registered taskstats version 1
Aug 24 23:17:22 arch kernel: Loading compiled-in X.509 certificates
Aug 24 23:17:22 arch kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 3f49d2245ea71c75c9ae3eeea55a6ac9bbf53dc9'
Aug 24 23:17:22 arch kernel: zswap: loaded using pool zstd/z3fold
Aug 24 23:17:22 arch kernel: Key type ._fscrypt registered
Aug 24 23:17:22 arch kernel: Key type .fscrypt registered
Aug 24 23:17:22 arch kernel: Key type fscrypt-provisioning registered
Aug 24 23:17:22 arch kernel: PM: Magic number: 2:870:300
Aug 24 23:17:22 arch kernel: RAS: Correctable Errors collector initialized.
Aug 24 23:17:22 arch kernel: ata1: SATA link down (SStatus 0 SControl 300)
Aug 24 23:17:22 arch kernel: ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug 24 23:17:22 arch kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Aug 24 23:17:22 arch kernel: ata7.00: supports DRM functions and may not be fully accessible
Aug 24 23:17:22 arch kernel: ata7.00: ATA-9: Samsung SSD 850 PRO 256GB, EXM02B6Q, max UDMA/133
Aug 24 23:17:22 arch kernel: ata2.00: supports DRM functions and may not be fully accessible
Aug 24 23:17:22 arch kernel: ata2.00: ATA-9: Samsung SSD 850 EVO 500GB, EMT02B6Q, max UDMA/133
Aug 24 23:17:22 arch kernel: ata2.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
Aug 24 23:17:22 arch kernel: ata2.00: Features: Trust Dev-Sleep NCQ-sndrcv
Aug 24 23:17:22 arch kernel: ata7.00: 500118192 sectors, multi 1: LBA48 NCQ (depth 32), AA
Aug 24 23:17:22 arch kernel: ata2.00: configured for UDMA/133
Aug 24 23:17:22 arch kernel: ata7.00: Features: Trust Dev-Sleep NCQ-sndrcv
Aug 24 23:17:22 arch kernel: scsi 1:0:0:0: Direct-Access ATA Samsung SSD 850 2B6Q PQ: 0 ANSI: 5
Aug 24 23:17:22 arch kernel: sd 1:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
Aug 24 23:17:22 arch kernel: sd 1:0:0:0: [sda] Write Protect is off
Aug 24 23:17:22 arch kernel: sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
Aug 24 23:17:22 arch kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 24 23:17:22 arch kernel: ata7.00: configured for UDMA/133
Aug 24 23:17:22 arch kernel: sda: sda1 sda2 sda3 sda4
Aug 24 23:17:22 arch kernel: scsi 6:0:0:0: Direct-Access ATA Samsung SSD 850 2B6Q PQ: 0 ANSI: 5
Aug 24 23:17:22 arch kernel: sd 6:0:0:0: [sdb] 500118192 512-byte logical blocks: (256 GB/238 GiB)
Aug 24 23:17:22 arch kernel: sd 6:0:0:0: [sdb] Write Protect is off
Aug 24 23:17:22 arch kernel: sd 6:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Aug 24 23:17:22 arch kernel: sd 6:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 24 23:17:22 arch kernel: sd 1:0:0:0: [sda] supports TCG Opal
Aug 24 23:17:22 arch kernel: sd 1:0:0:0: [sda] Attached SCSI disk
Aug 24 23:17:22 arch kernel: sdb: sdb1 sdb2 sdb3
Aug 24 23:17:22 arch kernel: sd 6:0:0:0: [sdb] supports TCG Opal
Aug 24 23:17:22 arch kernel: sd 6:0:0:0: [sdb] Attached SCSI disk
Aug 24 23:17:22 arch kernel: Freeing unused decrypted memory: 2036K
Aug 24 23:17:22 arch kernel: Freeing unused kernel image (initmem) memory: 1868K
Aug 24 23:17:22 arch kernel: Write protecting the kernel read-only data: 28672k
Aug 24 23:17:22 arch kernel: Freeing unused kernel image (text/rodata gap) memory: 2040K
Aug 24 23:17:22 arch kernel: Freeing unused kernel image (rodata/data gap) memory: 1212K
Aug 24 23:17:22 arch kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Aug 24 23:17:22 arch kernel: rodata_test: all tests were successful
Aug 24 23:17:22 arch kernel: Run /init as init process
Aug 24 23:17:22 arch kernel: with arguments:
Aug 24 23:17:22 arch kernel: /init
Aug 24 23:17:22 arch kernel: with environment:
Aug 24 23:17:22 arch kernel: HOME=/
Aug 24 23:17:22 arch kernel: TERM=linux
Aug 24 23:17:22 arch kernel: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.1: xHCI Host Controller
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.1: new USB bus registered, assigned bus number 1
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.1: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.1: new USB bus registered, assigned bus number 2
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.1: Host supports USB 3.1 Enhanced SuperSpeed
Aug 24 23:17:22 arch kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
Aug 24 23:17:22 arch kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 23:17:22 arch kernel: usb usb1: Product: xHCI Host Controller
Aug 24 23:17:22 arch kernel: usb usb1: Manufacturer: Linux 5.18.17-1-MANJARO xhci-hcd
Aug 24 23:17:22 arch kernel: usb usb1: SerialNumber: 0000:05:00.1
Aug 24 23:17:22 arch kernel: hub 1-0:1.0: USB hub found
Aug 24 23:17:22 arch kernel: hub 1-0:1.0: 6 ports detected
Aug 24 23:17:22 arch kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 24 23:17:22 arch kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
Aug 24 23:17:22 arch kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 23:17:22 arch kernel: usb usb2: Product: xHCI Host Controller
Aug 24 23:17:22 arch kernel: usb usb2: Manufacturer: Linux 5.18.17-1-MANJARO xhci-hcd
Aug 24 23:17:22 arch kernel: usb usb2: SerialNumber: 0000:05:00.1
Aug 24 23:17:22 arch kernel: hub 2-0:1.0: USB hub found
Aug 24 23:17:22 arch kernel: hub 2-0:1.0: 4 ports detected
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.3: xHCI Host Controller
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 3
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 4
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:05:00.3: Host supports USB 3.1 Enhanced SuperSpeed
Aug 24 23:17:22 arch kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
Aug 24 23:17:22 arch kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 23:17:22 arch kernel: usb usb3: Product: xHCI Host Controller
Aug 24 23:17:22 arch kernel: usb usb3: Manufacturer: Linux 5.18.17-1-MANJARO xhci-hcd
Aug 24 23:17:22 arch kernel: usb usb3: SerialNumber: 0000:05:00.3
Aug 24 23:17:22 arch kernel: hub 3-0:1.0: USB hub found
Aug 24 23:17:22 arch kernel: hub 3-0:1.0: 6 ports detected
Aug 24 23:17:22 arch kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 24 23:17:22 arch kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
Aug 24 23:17:22 arch kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 23:17:22 arch kernel: usb usb4: Product: xHCI Host Controller
Aug 24 23:17:22 arch kernel: usb usb4: Manufacturer: Linux 5.18.17-1-MANJARO xhci-hcd
Aug 24 23:17:22 arch kernel: usb usb4: SerialNumber: 0000:05:00.3
Aug 24 23:17:22 arch kernel: hub 4-0:1.0: USB hub found
Aug 24 23:17:22 arch kernel: hub 4-0:1.0: 4 ports detected
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:08:00.2: xHCI Host Controller
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:08:00.2: new USB bus registered, assigned bus number 5
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:08:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:08:00.2: new USB bus registered, assigned bus number 6
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:08:00.2: Host supports USB 3.1 Enhanced SuperSpeed
Aug 24 23:17:22 arch kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
Aug 24 23:17:22 arch kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 23:17:22 arch kernel: usb usb5: Product: xHCI Host Controller
Aug 24 23:17:22 arch kernel: usb usb5: Manufacturer: Linux 5.18.17-1-MANJARO xhci-hcd
Aug 24 23:17:22 arch kernel: usb usb5: SerialNumber: 0000:08:00.2
Aug 24 23:17:22 arch kernel: nvme nvme0: pci function 0000:03:00.0
Aug 24 23:17:22 arch kernel: hub 5-0:1.0: USB hub found
Aug 24 23:17:22 arch kernel: hub 5-0:1.0: 2 ports detected
Aug 24 23:17:22 arch kernel: usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 24 23:17:22 arch kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
Aug 24 23:17:22 arch kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 23:17:22 arch kernel: usb usb6: Product: xHCI Host Controller
Aug 24 23:17:22 arch kernel: usb usb6: Manufacturer: Linux 5.18.17-1-MANJARO xhci-hcd
Aug 24 23:17:22 arch kernel: usb usb6: SerialNumber: 0000:08:00.2
Aug 24 23:17:22 arch kernel: hub 6-0:1.0: USB hub found
Aug 24 23:17:22 arch kernel: hub 6-0:1.0: 4 ports detected
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:0a:00.3: xHCI Host Controller
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 7
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:0a:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 8
Aug 24 23:17:22 arch kernel: xhci_hcd 0000:0a:00.3: Host supports USB 3.1 Enhanced SuperSpeed
Aug 24 23:17:22 arch kernel: usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
Aug 24 23:17:22 arch kernel: usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 23:17:22 arch kernel: usb usb7: Product: xHCI Host Controller
Aug 24 23:17:22 arch kernel: usb usb7: Manufacturer: Linux 5.18.17-1-MANJARO xhci-hcd
Aug 24 23:17:22 arch kernel: usb usb7: SerialNumber: 0000:0a:00.3
Aug 24 23:17:22 arch kernel: hub 7-0:1.0: USB hub found
Aug 24 23:17:22 arch kernel: hub 7-0:1.0: 4 ports detected
Aug 24 23:17:22 arch kernel: usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
Aug 24 23:17:22 arch kernel: usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
Aug 24 23:17:22 arch kernel: usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 24 23:17:22 arch kernel: usb usb8: Product: xHCI Host Controller
Aug 24 23:17:22 arch kernel: usb usb8: Manufacturer: Linux 5.18.17-1-MANJARO xhci-hcd
Aug 24 23:17:22 arch kernel: usb usb8: SerialNumber: 0000:0a:00.3
Aug 24 23:17:22 arch kernel: hub 8-0:1.0: USB hub found
Aug 24 23:17:22 arch kernel: hub 8-0:1.0: 4 ports detected
Aug 24 23:17:22 arch kernel: nvme nvme0: missing or invalid SUBNQN field.
Aug 24 23:17:22 arch kernel: nvme nvme0: Shutdown timeout set to 10 seconds
Aug 24 23:17:22 arch kernel: nvme nvme0: 8/0/0 default/read/poll queues
Aug 24 23:17:22 arch kernel: nvme0n1: p1
Aug 24 23:17:22 arch kernel: PM: Image not found (code -22)
Aug 24 23:17:22 arch kernel: fbcon: Taking over console
Aug 24 23:17:22 arch kernel: Console: switching to colour frame buffer device 240x67
Aug 24 23:17:22 arch kernel: EXT4-fs (sdb2): mounted filesystem with ordered data mode. Quota mode: none.
Aug 24 23:17:22 arch kernel: usb 1-1: new high-speed USB device number 2 using xhci_hcd
Aug 24 23:17:22 arch kernel: tsc: Refined TSC clocksource calibration: 3792.866 MHz
Aug 24 23:17:22 arch kernel: usb 3-6: new full-speed USB device number 2 using xhci_hcd
Aug 24 23:17:22 arch kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d580a0eebb, max_idle_ns: 881591138602 ns
Aug 24 23:17:22 arch kernel: clocksource: Switched to clocksource tsc
Aug 24 23:17:22 arch systemd[1]: systemd 251.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
Aug 24 23:17:22 arch systemd[1]: Detected architecture x86-64.
Aug 24 23:17:22 arch systemd[1]: Hostname set to <arch>.
Aug 24 23:17:22 arch kernel: usb 3-6: config 1 has an invalid interface number: 2 but max is 1
Aug 24 23:17:22 arch kernel: usb 3-6: config 1 has no interface number 1
Aug 24 23:17:22 arch kernel: usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.26
Aug 24 23:17:22 arch kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 24 23:17:22 arch kernel: usb 1-1: Product: USB2.0 Hub
Aug 24 23:17:22 arch kernel: usb 1-1: Manufacturer: GenesysLogic
Aug 24 23:17:22 arch kernel: usb 3-6: New USB device found, idVendor=0b05, idProduct=18f3, bcdDevice= 1.00
Aug 24 23:17:22 arch kernel: usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 24 23:17:22 arch kernel: usb 3-6: Product: AURA LED Controller
Aug 24 23:17:22 arch kernel: usb 3-6: Manufacturer: AsusTek Computer Inc.
Aug 24 23:17:22 arch kernel: usb 3-6: SerialNumber: 9876543210
Aug 24 23:17:22 arch systemd[1]: Queued start job for default target Graphical Interface.
Aug 24 23:17:22 arch systemd[1]: Created slice Slice /system/getty.
Aug 24 23:17:22 arch systemd[1]: Created slice Slice /system/modprobe.
Aug 24 23:17:22 arch systemd[1]: Created slice Slice /system/systemd-fsck.
Aug 24 23:17:22 arch systemd[1]: Created slice User and Session Slice.
Aug 24 23:17:22 arch systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Aug 24 23:17:22 arch systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Aug 24 23:17:22 arch systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Aug 24 23:17:22 arch systemd[1]: Reached target Local Encrypted Volumes.
Aug 24 23:17:22 arch systemd[1]: Reached target Login Prompts.
Aug 24 23:17:22 arch systemd[1]: Reached target Local Integrity Protected Volumes.
Aug 24 23:17:22 arch systemd[1]: Reached target Remote File Systems.
Aug 24 23:17:22 arch systemd[1]: Reached target Slice Units.
Aug 24 23:17:22 arch systemd[1]: Reached target Local Verity Protected Volumes.
Aug 24 23:17:22 arch systemd[1]: Listening on Device-mapper event daemon FIFOs.
Aug 24 23:17:22 arch systemd[1]: Listening on LVM2 poll daemon socket.
Aug 24 23:17:22 arch systemd[1]: Listening on Process Core Dump Socket.
Aug 24 23:17:22 arch systemd[1]: Listening on Journal Audit Socket.
Aug 24 23:17:22 arch systemd[1]: Listening on Journal Socket (/dev/log).
Aug 24 23:17:22 arch systemd[1]: Listening on Journal Socket.
Aug 24 23:17:22 arch systemd[1]: Listening on udev Control Socket.
Aug 24 23:17:22 arch systemd[1]: Listening on udev Kernel Socket.
Aug 24 23:17:22 arch systemd[1]: Mounting Huge Pages File System...
Aug 24 23:17:22 arch systemd[1]: Mounting POSIX Message Queue File System...
Aug 24 23:17:22 arch systemd[1]: Mounting Kernel Debug File System...
Aug 24 23:17:22 arch systemd[1]: Mounting Kernel Trace File System...
Aug 24 23:17:22 arch systemd[1]: Starting Create List of Static Device Nodes...
Aug 24 23:17:22 arch systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Aug 24 23:17:22 arch systemd[1]: Starting Load Kernel Module configfs...
Aug 24 23:17:22 arch systemd[1]: Starting Load Kernel Module drm...
Aug 24 23:17:22 arch systemd[1]: Starting Load Kernel Module fuse...
Aug 24 23:17:22 arch systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
Aug 24 23:17:22 arch systemd[1]: Starting Load Kernel Modules...
Aug 24 23:17:22 arch systemd[1]: Starting Remount Root and Kernel File Systems...
Aug 24 23:17:22 arch systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
Aug 24 23:17:22 arch systemd[1]: Starting Coldplug All udev Devices...
Aug 24 23:17:22 arch kernel: hub 1-1:1.0: USB hub found
Aug 24 23:17:22 arch systemd[1]: Mounted Huge Pages File System.
Aug 24 23:17:22 arch systemd[1]: Mounted POSIX Message Queue File System.
Aug 24 23:17:22 arch systemd[1]: Mounted Kernel Debug File System.
Aug 24 23:17:22 arch systemd[1]: Mounted Kernel Trace File System.
Aug 24 23:17:22 arch systemd[1]: Finished Create List of Static Device Nodes.
Aug 24 23:17:22 arch systemd[1]: modprobe@configfs.service: Deactivated successfully.
Aug 24 23:17:22 arch systemd[1]: Finished Load Kernel Module configfs.
Aug 24 23:17:22 arch systemd[1]: modprobe@drm.service: Deactivated successfully.
Aug 24 23:17:22 arch systemd[1]: Finished Load Kernel Module drm.
Aug 24 23:17:22 arch systemd[1]: Mounting Kernel Configuration File System...
Aug 24 23:17:22 arch kernel: EXT4-fs (sdb2): re-mounted. Quota mode: none.
Aug 24 23:17:22 arch systemd[1]: Finished Remount Root and Kernel File Systems.
Aug 24 23:17:22 arch systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
Aug 24 23:17:22 arch systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
Aug 24 23:17:22 arch kernel: hub 1-1:1.0: 4 ports detected
Aug 24 23:17:22 arch systemd[1]: Starting Load/Save Random Seed...
Aug 24 23:17:22 arch systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
Aug 24 23:17:22 arch systemd[1]: Starting Create Static Device Nodes in /dev...
Aug 24 23:17:22 arch systemd[1]: Mounted Kernel Configuration File System.
Aug 24 23:17:22 arch kernel: fuse: init (API version 7.36)
Aug 24 23:17:22 arch systemd[1]: modprobe@fuse.service: Deactivated successfully.
Aug 24 23:17:22 arch systemd[1]: Finished Load Kernel Module fuse.
Aug 24 23:17:22 arch systemd[1]: Mounting FUSE Control File System...
Aug 24 23:17:22 arch systemd[1]: Mounted FUSE Control File System.
Aug 24 23:17:22 arch systemd[1]: Finished Load/Save Random Seed.
Aug 24 23:17:22 arch systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
Aug 24 23:17:22 arch systemd[1]: Finished Create Static Device Nodes in /dev.
Aug 24 23:17:22 arch systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
Aug 24 23:17:22 arch systemd[1]: Starting Journal Service...
Aug 24 23:17:22 arch systemd[1]: Starting Rule-based Manager for Device Events and Files...
Aug 24 23:17:22 arch kernel: usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
Aug 24 23:17:22 arch systemd[1]: Finished Coldplug All udev Devices.
Aug 24 23:17:22 arch kernel: audit: type=1130 audit(1661379442.706:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 24 23:17:22 arch systemd[1]: Started Rule-based Manager for Device Events and Files.
Aug 24 23:17:22 arch kernel: audit: type=1130 audit(1661379442.716:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 24 23:17:22 arch kernel: usb 2-1: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.26
Aug 24 23:17:22 arch kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 24 23:17:22 arch kernel: usb 2-1: Product: USB3.1 Hub
Aug 24 23:17:22 arch kernel: usb 2-1: Manufacturer: GenesysLogic
Aug 24 23:17:22 arch systemd-journald[340]: Journal started
Aug 24 23:17:22 arch systemd-journald[340]: Runtime Journal (/run/log/journal/899b5f4402bc4c029ceeb472d12f172c) is 8.0M, max 795.1M, 787.1M free.
Aug 24 23:17:22 arch audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 24 23:17:22 arch audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 24 23:17:22 arch systemd-modules-load[332]: Inserted module 'crypto_user'
Aug 24 23:17:22 arch audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 24 23:17:22 arch systemd[1]: Started Journal Service.
Aug 24 23:17:22 arch kernel: audit: type=1130 audit(1661379442.729:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 24 23:17:22 arch systemd[1]: Starting Flush Journal to Persistent Storage...
Aug 24 23:17:22 arch systemd-journald[340]: Time spent on flushing to /var/log/journal/899b5f4402bc4c029ceeb472d12f172c is 27.036ms for 1021 entries.
Aug 25 08:26:33 arch kernel: #7 #8 #9 #10 #11
Aug 25 08:26:33 arch kernel: ata7.00: supports DRM functions and may not be fully accessible
Aug 25 08:26:33 arch kernel: ata2.00: supports DRM functions and may not be fully accessible
Aug 25 08:26:33 arch kernel: nvme nvme0: missing or invalid SUBNQN field.
Aug 25 08:26:33 arch kernel: usb 3-6: config 1 has an invalid interface number: 2 but max is 1
Aug 25 08:26:33 arch kernel: usb 3-6: config 1 has no interface number 1
Aug 25 08:26:33 arch systemd-journald[331]: File /var/log/journal/899b5f4402bc4c029ceeb472d12f172c/system.journal corrupted or uncleanly shut down, renaming and replacing.
Aug 25 08:26:33 arch kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 25 08:26:33 arch kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 25 08:26:33 arch kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 25 08:26:33 arch kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 25 08:26:34 arch kernel: kvm: support for 'kvm_amd' disabled by bios
Aug 25 08:26:34 arch kernel: nvidia: loading out-of-tree module taints kernel.
Aug 25 08:26:34 arch kernel: nvidia: module license 'NVIDIA' taints kernel.
Aug 25 08:26:34 arch kernel: Disabling lock debugging due to kernel taint
Aug 25 08:26:34 arch kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
Aug 25 08:26:35 arch kernel: kvm: support for 'kvm_amd' disabled by bios
Aug 25 08:26:35 arch kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Aug 25 08:26:37 arch kernel: kauditd_printk_skb: 27 callbacks suppressed
Aug 25 08:26:37 arch systemd[639]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Aug 25 08:26:37 arch systemd[639]: Failed to start Update XDG user dir configuration.
Aug 25 08:26:37 arch sddm-greeter[648]: QFont::fromString: Invalid description '(empty)'
Aug 25 08:26:37 arch sddm-greeter[648]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fff801bc660), parent's thread is QThread(0x5592a1f344d0), current thread is QThread(0x5592a2083150)
Aug 25 08:26:37 arch sddm-greeter[648]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Aug 25 08:26:38 arch sddm-greeter[648]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Aug 25 08:26:38 arch sddm-greeter[648]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Aug 25 08:26:38 arch sddm-greeter[648]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Aug 25 08:26:38 arch sddm-greeter[648]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Aug 25 08:26:38 arch sddm-greeter[648]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Aug 25 08:26:39 arch sddm-greeter[648]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.21'
Aug 25 08:26:39 arch sddm-greeter[648]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Aug 25 08:26:44 arch kernel: kauditd_printk_skb: 8 callbacks suppressed
Aug 25 08:26:44 arch ksplashqml[719]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Aug 25 08:26:44 arch ksplashqml[719]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Aug 25 08:26:44 arch klauncher[741]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Aug 25 08:26:44 arch kcminit_startup[746]: QDBusConnection: error: could not send signal to service "" path "//home/ferdipret/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/ferdipret/.kde4/share/config/kdeglobals
Aug 25 08:26:45 arch kwin_x11[756]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Aug 25 08:26:45 arch kwin_x11[756]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Aug 25 08:26:45 arch kwin_x11[756]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Aug 25 08:26:45 arch kded5[753]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.9'
Aug 25 08:26:45 arch ksmserver[798]: Qt: Session management error: networkIdsList argument is NULL
Aug 25 08:26:45 arch kded5[753]: kscreen.kded: PowerDevil SuspendSession action not available!
Aug 25 08:26:45 arch backlighthelper[901]: org.kde.powerdevil: no kernel backlight interface found
Aug 25 08:26:45 arch org_kde_powerdevil[811]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Aug 25 08:26:45 arch org_kde_powerdevil[811]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Aug 25 08:26:45 arch plasmashell[820]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Aug 25 08:26:45 arch plasmashell[820]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Aug 25 08:26:45 arch org_kde_powerdevil[811]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Aug 25 08:26:45 arch org_kde_powerdevil[811]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Aug 25 08:26:45 arch kwin_x11[756]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 794, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Aug 25 08:26:45 arch kwin_x11[756]: kwin_core: XCB error: 10 (BadAccess), sequence: 856, resource id: 506, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Aug 25 08:26:46 arch plasmashell[820]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Aug 25 08:26:46 arch plasmashell[820]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Aug 25 08:26:46 arch pulseaudio[835]: stat('/etc/pulse/default.pa.d'): No such file or directory
Aug 25 08:26:46 arch plasmashell[820]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 25 08:26:47 arch plasmashell[820]: Error: cannot change the containment to AppletsLayout
Aug 25 08:26:47 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Aug 25 08:26:47 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Aug 25 08:26:47 arch plasmashell[820]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Aug 25 08:26:47 arch plasmashell[820]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x56349877f500)
Aug 25 08:26:47 arch plasmashell[820]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x56349877c280)
Aug 25 08:26:47 arch plasmashell[820]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x56349877c960)
Aug 25 08:26:47 arch plasmashell[820]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x56349877c280)
Aug 25 08:26:47 arch plasmashell[820]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x563498785300)
Aug 25 08:26:47 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Aug 25 08:26:47 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Aug 25 08:26:48 arch kwin_x11[756]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2238, resource id: 4194343, major code: 18 (ChangeProperty), minor code: 0
Aug 25 08:26:48 arch plasmashell[820]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Aug 25 08:26:48 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Aug 25 08:26:48 arch plasmashell[820]: Both point size and pixel size set. Using pixel size.
Aug 25 08:26:48 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:54:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Aug 25 08:26:48 arch plasmashell[820]: Error: cannot change the containment to AppletsLayout
Aug 25 08:26:48 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:17:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Aug 25 08:26:48 arch plasmashell[820]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Aug 25 08:26:48 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:71:17: Unable to assign [undefined] to int
Aug 25 08:26:48 arch plasmashell[820]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_0a_00.4.iec958-stereo.monitor"
Aug 25 08:26:50 arch plasmashell[820]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 25 08:26:50 arch plasmashell[820]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 25 08:26:51 arch plasmashell[820]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 25 08:26:51 arch plasmashell[820]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 25 08:26:51 arch kwin_x11[756]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4604, resource id: 44040285, major code: 18 (ChangeProperty), minor code: 0
Aug 25 08:26:51 arch kwin_x11[756]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4609, resource id: 44040286, major code: 18 (ChangeProperty), minor code: 0
Aug 25 08:26:51 arch kernel: kauditd_printk_skb: 9 callbacks suppressed
Aug 25 08:26:51 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Aug 25 08:26:52 arch kwin_x11[756]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5533, resource id: 18874670, major code: 3 (GetWindowAttributes), minor code: 0
Aug 25 08:26:52 arch kwin_x11[756]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5534, resource id: 18874670, major code: 14 (GetGeometry), minor code: 0
Aug 25 08:26:52 arch plasmashell[820]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 25 08:26:52 arch plasmashell[820]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 25 08:26:53 arch plasmashell[820]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Aug 25 08:26:53 arch kwin_x11[756]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6293, resource id: 18874722, major code: 3 (GetWindowAttributes), minor code: 0
Aug 25 08:26:53 arch kwin_x11[756]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 6294, resource id: 18874722, major code: 14 (GetGeometry), minor code: 0
Aug 25 08:26:53 arch plasmashell[820]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 25 08:26:53 arch plasmashell[820]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 25 08:26:54 arch plasmashell[820]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 25 08:26:55 arch plasmashell[820]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 25 08:26:55 arch plasmashell[820]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 25 08:26:57 arch kwin_x11[756]: kwin_core: XCB error: 152 (BadDamage), sequence: 10816, resource id: 18874850, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Aug 25 08:27:04 arch kernel: BUG: scheduling while atomic: swapper/0/0/0x00000002
Aug 25 08:27:04 arch kernel: Modules linked in: qrtr nvidia_uvm(POE) nvidia_drm(POE) nvidia_modeset(POE) hid_logitech_hidpp mousedev nvidia(POE) intel_rapl_msr intel_rapl_common snd_hda_codec_realtek edac_mce_amd snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi eeepc_wmi snd_hda_intel asus_wmi sparse_keymap snd_intel_dspcfg hid_logitech_dj joydev platform_profile snd_intel_sdw_acpi kvm snd_hda_codec ucsi_ccg irqbypass snd_hda_core crct10dif_pclmul typec_ucsi rfkill snd_hwdep crc32_pclmul typec vfat ghash_clmulni_intel roles video fat wmi_bmof snd_pcm aesni_intel snd_timer r8169 crypto_simd cryptd sp5100_tco tpm_crb usbhid rapl realtek snd mdio_devres tpm_tis k10temp pcspkr soundcore i2c_piix4 libphy ccp tpm_tis_core i2c_nvidia_gpu tpm rng_core wmi pinctrl_amd mac_hid acpi_cpufreq crypto_user fuse bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 nvme crc32c_intel nvme_core xhci_pci xhci_pci_renesas
Aug 25 08:27:04 arch kernel: CPU: 0 PID: 0 Comm: swapper/0 Tainted: P OE 5.18.17-1-MANJARO #1 b6c607b9920ef45a8786df46f1e5b9603dff70e3
Aug 25 08:27:04 arch kernel: Hardware name: System manufacturer System Product Name/TUF GAMING X570-PLUS, BIOS 4403 04/28/2022
Aug 25 08:27:04 arch kernel: Call Trace:
Aug 25 08:27:04 arch kernel: <TASK>
Aug 25 08:27:04 arch kernel: dump_stack_lvl+0x48/0x60
Aug 25 08:27:04 arch kernel: __schedule_bug.cold+0x4b/0x57
Aug 25 08:27:04 arch kernel: __schedule+0xdf1/0x1200
Aug 25 08:27:04 arch kernel: ? tick_nohz_restart+0x69/0x80
Aug 25 08:27:04 arch kernel: ? tick_nohz_idle_exit+0xa2/0x130
Aug 25 08:27:04 arch kernel: schedule_idle+0x2a/0x40
Aug 25 08:27:04 arch kernel: cpu_startup_entry+0x1d/0x20
Aug 25 08:27:04 arch kernel: rest_init+0xc8/0xd0
Aug 25 08:27:04 arch kernel: arch_call_rest_init+0xe/0x1c
Aug 25 08:27:04 arch kernel: start_kernel+0x971/0x99a
Aug 25 08:27:04 arch kernel: secondary_startup_64_no_verify+0xd5/0xdb
Aug 25 08:27:04 arch kernel: </TASK>
Aug 25 08:27:10 arch kded5[753]: kf.bluezqt: PendingCall Error: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Aug 25 08:27:10 arch pulseaudio[835]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Aug 25 08:27:19 arch kernel: general protection fault, probably for non-canonical address 0x437989ad3a688948: 0000 [#1] PREEMPT SMP NOPTI
Aug 25 08:27:19 arch kernel: CPU: 0 PID: 627 Comm: Xorg Tainted: P W OE 5.18.17-1-MANJARO #1 b6c607b9920ef45a8786df46f1e5b9603dff70e3
Aug 25 08:27:19 arch kernel: Hardware name: System manufacturer System Product Name/TUF GAMING X570-PLUS, BIOS 4403 04/28/2022
Aug 25 08:27:19 arch kernel: RIP: 0010:memcg_slab_post_alloc_hook+0x14d/0x230
Aug 25 08:27:19 arch kernel: Code: d8 48 0f af c2 48 c1 e8 20 29 c3 d3 eb 0f b6 4d 25 01 c3 d3 eb 48 c1 e3 03 e8 bf 64 e2 ff 49 8b 45 00 a8 03 0f 85 9d 00 00 00 <65> 48 ff 00 e8 0a 9f e2 ff 49 8b 47 38 31 d2 4c 89 ef 48 83 e0 fc
Aug 25 08:27:19 arch kernel: RSP: 0018:ffffb6a58309fa90 EFLAGS: 00010246
Aug 25 08:27:19 arch kernel: RAX: 4379e95d5be88948 RBX: 0000000000000008 RCX: 0000000000000008
Aug 25 08:27:19 arch kernel: RDX: ffffa04cc347c080 RSI: ffffffffb6b2da81 RDI: ffffa04cc0043700
Aug 25 08:27:19 arch kernel: RBP: ffffa04cc0043700 R08: ffffb6a58309fae0 R09: ffffa04cc1050200
Aug 25 08:27:19 arch kernel: R10: ffffb6a58309fd68 R11: 0000000000000001 R12: 0000000000000000
Aug 25 08:27:19 arch kernel: R13: ffffffffb6b2da81 R14: ffffb6a58309fae0 R15: ffffe0aec4041400
Aug 25 08:27:19 arch kernel: FS: 00007f224a412980(0000) GS:ffffa04fde800000(0000) knlGS:0000000000000000
Aug 25 08:27:19 arch kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug 25 08:27:19 arch kernel: CR2: 00007f029ed70000 CR3: 0000000104516000 CR4: 0000000000350ef0
Aug 25 08:27:19 arch kernel: Call Trace:
Aug 25 08:27:19 arch kernel: <TASK>
Aug 25 08:27:19 arch kernel: ? get_obj_cgroup_from_current+0xc1/0x160
Aug 25 08:27:19 arch kernel: __kmalloc_node_track_caller+0x1c0/0x3d0
Aug 25 08:27:19 arch kernel: ? alloc_skb_with_frags+0x50/0x1f0
Aug 25 08:27:19 arch kernel: __alloc_skb+0x8a/0x1e0
Aug 25 08:27:19 arch kernel: alloc_skb_with_frags+0x50/0x1f0
Aug 25 08:27:19 arch kernel: sock_alloc_send_pskb+0x203/0x250
Aug 25 08:27:19 arch kernel: unix_stream_sendmsg+0x274/0x660
Aug 25 08:27:19 arch kernel: ? sock_write_iter+0x9b/0x100
Aug 25 08:27:19 arch kernel: sock_sendmsg+0x63/0x70
Aug 25 08:27:19 arch kernel: sock_write_iter+0x9b/0x100
Aug 25 08:27:19 arch kernel: do_iter_readv_writev+0x132/0x190
Aug 25 08:27:19 arch kernel: do_iter_write+0x81/0x1c0
Aug 25 08:27:19 arch kernel: vfs_writev+0xe7/0x1a0
Aug 25 08:27:19 arch kernel: ? __fget_light+0x94/0x100
Aug 25 08:27:19 arch kernel: do_writev+0xfa/0x160
Aug 25 08:27:19 arch kernel: do_syscall_64+0x5f/0x90
Aug 25 08:27:19 arch kernel: ? do_syscall_64+0x6b/0x90
Aug 25 08:27:19 arch kernel: entry_SYSCALL_64_after_hwframe+0x61/0xcb
Aug 25 08:27:19 arch kernel: RIP: 0033:0x7f224ad81b1d
Aug 25 08:27:19 arch kernel: Code: 28 89 54 24 1c 48 89 74 24 10 89 7c 24 08 e8 ea 60 f8 ff 8b 54 24 1c 48 8b 74 24 10 41 89 c0 8b 7c 24 08 b8 14 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 33 44 89 c7 48 89 44 24 08 e8 3e 61 f8 ff 48
Aug 25 08:27:19 arch kernel: RSP: 002b:00007ffcc9755df0 EFLAGS: 00000293 ORIG_RAX: 0000000000000014
Aug 25 08:27:19 arch kernel: RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f224ad81b1d
Aug 25 08:27:19 arch kernel: RDX: 0000000000000001 RSI: 00007ffcc97560e0 RDI: 0000000000000051
Aug 25 08:27:19 arch kernel: RBP: 000055ea8f1c82f0 R08: 0000000000000000 R09: 0000000000000001
Aug 25 08:27:19 arch kernel: R10: 0000000000000000 R11: 0000000000000293 R12: 0000000000000001
Aug 25 08:27:19 arch kernel: R13: 00007ffcc97560e0 R14: 0000000000000000 R15: 0000000000000020
Aug 25 08:27:19 arch kernel: </TASK>
Aug 25 08:27:19 arch kernel: Modules linked in: qrtr nvidia_uvm(POE) nvidia_drm(POE) nvidia_modeset(POE) hid_logitech_hidpp mousedev nvidia(POE) intel_rapl_msr intel_rapl_common snd_hda_codec_realtek edac_mce_amd snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi eeepc_wmi snd_hda_intel asus_wmi sparse_keymap snd_intel_dspcfg hid_logitech_dj joydev platform_profile snd_intel_sdw_acpi kvm snd_hda_codec ucsi_ccg irqbypass snd_hda_core crct10dif_pclmul typec_ucsi rfkill snd_hwdep crc32_pclmul typec vfat ghash_clmulni_intel roles video fat wmi_bmof snd_pcm aesni_intel snd_timer r8169 crypto_simd cryptd sp5100_tco tpm_crb usbhid rapl realtek snd mdio_devres tpm_tis k10temp pcspkr soundcore i2c_piix4 libphy ccp tpm_tis_core i2c_nvidia_gpu tpm rng_core wmi pinctrl_amd mac_hid acpi_cpufreq crypto_user fuse bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 nvme crc32c_intel nvme_core xhci_pci xhci_pci_renesas
Aug 25 08:27:19 arch kernel: ---[ end trace 0000000000000000 ]---
Aug 25 08:27:20 arch systemd-coredump[1715]: Process 756 (kwin_x11) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 3d105929ea675afc827d61a041d58ac9c11adf4e
Module libOpenGL.so.0 with build-id 7f93e82811551958e394b5d6854951acb88907bf
Module libKF5PlasmaQuick.so.5 with build-id 01066a693ac0035f42bc31e52b7e0b8b04eba397
Module libcorebindingsplugin.so with build-id 328a59794db5f286ad5b0cff29c90ecb2881bb9f
Module libwindowplugin.so with build-id 440a96eb46b2bf4eb9109c74efa9303939b2d8f8
Module libQt5QmlWorkerScript.so.5 with build-id 9cdaca95698290d3dd71ea2bff183e421e1612f8
Module libqtquick2plugin.so with build-id 81827b6d5f3d3b1141f3b01ffcf5ffe437a2804e
Module libwebp.so.7 with build-id 96dd01a02a3b0b4dae0d744fc3200fd36f1c2148
Module libwebpdemux.so.2 with build-id 181ecf1a79aa805a45cce672f3f229570eca9f26
Module libwebpmux.so.3 with build-id c987ad73c6cbbfcdb4d632ead20256769852066e
Module libqwebp.so with build-id 1a944252d11823e472a338a67c688ec96ea2c758
Module libqwbmp.so with build-id 42cd72acfc707b80744100ea3033e9361bf57f7f
Module libtiff.so.5 with build-id 5f020a8eb30e12c2e4012d0cb50da9480c7b5d34
Module libqtiff.so with build-id b03372c0ebaa02198621511e00deee38cecded11
Module libqsvg.so with build-id 1ea8dae592b5b30f762efe2794b79f44e735dce5
Module libQt5Pdf.so.5 with build-id d5f89f2a0606639128d32d9d194443e7649a9879
Module libqpdf.so with build-id 3f9760fc8f5a9001f7ed48587e4140077230b634
Module libmng.so.2 with build-id 2de13b8bba73f358ab2e323aa2209c2e2fc886e7
Module libqmng.so with build-id 21da07027c6010c9066669cca0335e36a76f5a09
Module libqjpeg.so with build-id 9c4bed3debf5080c1483666c6d9d590d9007cd0d
Module libjasper.so.6 with build-id 920c93104c2081399a4d6334e239cc0fa14bc4b2
Module libqjp2.so with build-id 9dab5dbb502ccd8f0f7c095a3afed074531146ee
Module libqico.so with build-id 09e8beae999de04e1e49ba9d51dea9323de94b6b
Module libqicns.so with build-id 0a0ca5f9a56ecf5519425488b1f791146bf1e6e7
Module libqgif.so with build-id 51881447eb4f6e9a55bb6a1036b146048a7baa58
Module kimg_xcf.so with build-id 0883db875ac10d3a0c2be333bfe665abebda394d
Module kimg_tga.so with build-id 68c162a8602ebea902de725dd995d2c523f89fd7
Module kimg_rgb.so with build-id 1fef300913aab890b87658ea513d83d8239bb50e
Module kimg_ras.so with build-id 585be4c7aef63f3dff3a5e993a815ad7a25b33fe
Module kimg_psd.so with build-id 1ea7ba8f677bdee56777df594e0462c9950a8871
Module kimg_pic.so with build-id 687ae7a3cb3d9479edb5fcfcc809f319fcbf6fc0
Module kimg_pcx.so with build-id 080e256861761c1854410697b22aaa0b75aa1ab9
Module kimg_ora.so with build-id 875019dd1f4f9a6cb9f51e433f0510fc7ff86e42
Module kimg_kra.so with build-id 06be2de2dd5d3c2c6bf0dd8d1f5948ca955b17e7
Module libmvec.so.1 with build-id 1b5508a5298c324c58e71364ccc609534f836835
Module libx265.so.199 with build-id 4fd2d7155725df753c6b32274c442349fc05e632
Module libde265.so.0 with build-id 459cf009e847aef8f1589ad39b1573351b6a3b22
Module libheif.so.1 with build-id 64bccee060b5f2b512bc5ab529a4030b4f58ea8b
Module kimg_heif.so with build-id 183ad2ad29af158a1954670f04491ddddf189f94
Module kimg_hdr.so with build-id 32effe6231c7afdf8aab86c7b5e490b5500baafc
Module libIlmThread-3_1.so.30 with build-id fb61aaa8abdf748eb68984c0ef25b0ae85a6565f
Module libIex-3_1.so.30 with build-id 5e8a8f33fa7d4b83185155f19d4604501a86cf62
Module libImath-3_1.so.29 with build-id 4e0c4f23770d7ca42aa5341d270678a4303bf504
Module libOpenEXR-3_1.so.30 with build-id 875e7df47bd5ce2de8806bb9fa046061fa43a8ef
Module kimg_exr.so with build-id dcb4cf571f709ffad079068092d81ef51657a379
Module kimg_eps.so with build-id 4fbf8c069243b9704136d0bb7515351762a0f8e6
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libyuv.so with build-id 60a987609f24d8125baf7f8f2a3b288eb465d87e
Module libaom.so.3 with build-id 2b5b58e482957529f8b14aecb5b2acc21362d04d
Module libSvtAv1Enc.so.1 with build-id d95f643a00090915d6f17c27a84a031c45e819f3
Module librav1e.so.0 with build-id 5f8fc2c271f0d96480ab1c71447e038a66aa1c57
Module libdav1d.so.6 with build-id a93560a23a7f1def734a3cf54f09eadd7c3c46e9
Module libavif.so.14 with build-id 7c7c60390f804291a41ed3e75cd75121eda0ed35
Module kimg_avif.so with build-id 9de94a28f9ef68f0abd442c909a2c8855404af4a
Module kimg_ani.so with build-id 607433fb05681f049fa911e3444d50dffa90b387
Module colordintegration.so with build-id 5fc4421db03957737b83b04adeb6e11ee4c230d9
Module libKWinNightColorPlugin.so with build-id 342818134c51bccc4fb93440bbaaa26ce56a7574
Module krunnerintegration.so with build-id 31a7085b052189d638f41d67a9989aff3175baf8
Module libxcb-res.so.0 with build-id cd3dbd6dd9e412a002d1be5ae0ec0d85650542ba
Module KF5WindowSystemX11Plugin.so with build-id 8795255c1e22047118a58f4b5a45c0fa061042ae
Module breezedecoration.so with build-id c82db15ae7b9099761411e5b756f312776734c20
Module libkwinxrenderutils.so.13 with build-id b1ec47ba916c0dd65825b32edac263d90c47b101
Module KWinX11Platform.so with build-id d6c33f377ff5ba16880efadaee2f994575a4d1b3
Module libKF5Style.so.5 with build-id 8e501b6b7b2d020bf7b5725238695896bb8e1417
Module libbreezecommon5.so.5 with build-id 9314a1bac69cdccaa9f2c91534c9d16ab1327fc5
Module breeze.so with build-id 2461dfc4d3eef46074c7d081a92eb0fdba955f80
Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
Module librt.so.1 with build-id 837ea1d121976e9fa94acdf79939b387a32531db
Module libnvidia-glcore.so.515.65.01 with build-id 700e00c48aef68c935d2454b77590128e7553a1b
Module libnvidia-tls.so.515.65.01 with build-id cd91b1c2301080dea911a3cff0d0c0db49d5f575
Module libnvidia-glsi.so.515.65.01 with build-id 5c864cf78fead62c3b603506941dbcdae609fab8
Module libGLX_nvidia.so.0 with build-id 123c88ffaeca50691ed6d4bce3b81417810058ab
Module libqxcb-glx-integration.so with build-id e2c0419868b0bab893535ae4aaff94fc2e27d64a
Module libcomposeplatforminputcontextplugin.so with build-id 0be5cf4dd6f619507419c05cd608577e092c78fb
Module libQt5QuickTemplates2.so.5 with build-id fbb0c5634acacbf0266052e642f417ee166d5348
Module libKF5Bookmarks.so.5 with build-id 56d4fb0963982c6b20871b013fe107e6c4fafb33
Module libQt5QuickControls2.so.5 with build-id 59f3ed84bb93127ee1d0a51902e04dc71eb3585b
Module libKF5WaylandClient.so.5 with build-id 7b303d075325591bf0995ce36562ca88903a3929
Module libKF5KIOFileWidgets.so.5 with build-id ee12b40179dd6564bc359622044ac5347b8ecd15
Module KDEPlasmaPlatformTheme.so with build-id 26b76ca203d5426c38ed5c86b338e159bb4dbf09
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-xinerama.so.0 with build-id 5d2ab2683447d9bb7bcc49c058dfa06bcb65560d
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libQt5XcbQpa.so.5 with build-id 1da0861abb1ff1cdb9de4500133b160b18268ed3
Module libqxcb.so with build-id 70256c011680e7b9f040fad205d64a67e1027b8e
Module libdl.so.2 with build-id 2b416df8fd62af5dc5e987b11d99a5d0f772b440
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libgnutls.so.30 with build-id 816201e11cc13561e1272b96a1c7cdb97ae59997
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libresolv.so.2 with build-id 5c4d9f10ee9ce5e768e5b910e6b430f352a7aae1
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 15f223925ef59dee4379ebbc0fcd14eda9ba81a2
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id cc77a742cb62447a53d98285b41558b8acd92866
Module libkrb5.so.3 with build-id 371cc767dacb17cb42c9c44b88eebbed5ee9a756
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
Module libgudev-1.0.so.0 with build-id 460465b63a086d945124662363191903c0002793
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libGLX.so.0 with build-id 1d664a1f03d6c5c9ac997c4b73f3e8a11424cc74
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libltdl.so.7 with build-id d05fc2173e22a4b5374a1f80b548ae5c0926e079
Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
Module libgssapi_krb5.so.2 with build-id 292f1ce32161c0ecc4a287bc8494d5d7c420a03f
Module libGLdispatch.so.0 with build-id 9901dca23d6ccd49929b5f44c81cd671f1ec6757
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libQt5WaylandClient.so.5 with build-id 4aee845e8b74ebf4c4b5fcca2a29ce9b4b43211b
Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libKF5Completion.so.5 with build-id bb2c042dbacb7b344775ac1e2a23f1dd25a1e208
Module libKF5Solid.so.5 with build-id 52fe2aa12d222fd023c3b326b06b8a38c81eabe2
Module libKF5JobWidgets.so.5 with build-id eb655060c3f5a5f9d05609086f07415277d532f9
Module libKF5KIOCore.so.5 with build-id fc20fdc2fa10b588eaa7397a193a77071839bb9d
Module libKF5ItemViews.so.5 with build-id 2721bfeba3053624db85cbafa1edfa06d7b1a191
Module libQt5PrintSupport.so.5 with build-id eb2a96557be329f4d3d8663b06597c6e02236cad
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpthread.so.0 with build-id b966d4b239433c89ca36c0938381e2d92cd47639
Module libwacom.so.9 with build-id 52b5a9bb54e19f46a2d54b8a8ee3c859ba23170b
Module libevdev.so.2 with build-id 9ded5f5a6c45f3b30cf380d8a505e90b5f85f164
Module libmtdev.so.1 with build-id 862cf8d5b0a0dd4d4d225e17f54be93ab9c3b34e
Module libxcb-image.so.0 with build-id 0e6feae23e34658646dbd63d11f899c92c5d3c79
Module libxcb-render-util.so.0 with build-id 32609134bf1b73183d07a66f6bd65c94b4542460
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libKF5WaylandServer.so.5 with build-id 79c5b8a4ce4ac7bd6b57ba75059ac8301143ea8e
Module libKF5IdleTime.so.5 with build-id ddd17f68c199dcbd566a94df93fa1b148000b1cd
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libpcre2-16.so.0 with build-id 68a5c2d52b45bfa6b1e93d2766e80094f52d9ebf
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
Module libsystemd.so.0 with build-id f53e01cd7b3e5ff8757530ed7a65324ae12df5c8
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libGL.so.1 with build-id a3025d7d2cce51ecb2d47c076bfddefbf7e081f0
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module ld-linux-x86-64.so.2 with build-id 5492655bffbf172ed8a07f285f760ead38f09404
Module libKF5AuthCore.so.5 with build-id 27644829fe09cb075d1a92161b912cd5c2c8d01c
Module libKF5Codecs.so.5 with build-id 4a1602d188fb59da8fac4df7dd2a45a31f181d3d
Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
Module libXtst.so.6 with build-id 35c7f3daf454834acb724e6bd1664b0a2e9a6494
Module libQt5TextToSpeech.so.5 with build-id 31f411307c29623b8c9c8a7c2875de5045366340
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libgcc_s.so.1 with build-id 308aed8b7d7e38f5efa23f75c25601668c1fc009
Module libQt5Network.so.5 with build-id 8633892957a840339bd8c656e91b96397cce67bd
Module libQt5QmlModels.so.5 with build-id 11db7d0f6adbc46e72a1270478848e19bcefdbe7
Module libEGL.so.1 with build-id d4e8037e21617b4005fd99bf9464b3d3f4c3dd35
Module libKF5DBusAddons.so.5 with build-id 3e17ccd62dc88974d6fb2d954c2971ac34b49a7f
Module libQt5Xml.so.5 with build-id 458b4298e549719f0dc0b9fe7e7f589c7131c062
Module libKF5GuiAddons.so.5 with build-id 2cc1af0893cd828a9d7d4d2de86a4fcdc2c56911
Module libKF5Archive.so.5 with build-id 07d4e5dafa9448078b1ed4e2f93e2560ffce4b5e
Module libQt5Svg.so.5 with build-id 1638765a4fe9b14d115a5ca30e949fd90a9ac82c
Module libKF5IconThemes.so.5 with build-id 3c0f7e8d86df93b6b116efdacc805ce22ffce746
Module libKF5KIOGui.so.5 with build-id 530be3479e6f160e8efaf5a3d66a8e7c5e255000
Module libKF5KIOWidgets.so.5 with build-id 7e9f246d5050555202fef57775db4339d536773c
Module libKF5XmlGui.so.5 with build-id ac7570b5ec2d9f47fd127dea757d48b501ff0ee5
Module libKF5Declarative.so.5 with build-id 37945b10ab1b00b0b850f5c20dda9c3e45ee6d26
Module libQt5Sql.so.5 with build-id 9fa40544411b45942872cf216a3dc8c8e1bcdea3
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libwayland-server.so.0 with build-id 4c54fc8a7c0d4eb8adf2a69e44ebf12d16969c74
Module libKF5WidgetsAddons.so.5 with build-id 73415bc475882c11dc4fb8e5e20d0961f55f4127
Module libKF5Package.so.5 with build-id 6bff06bdcc59b68f9e06bc6832badc06c9fb1fbc
Module libKF5Activities.so.5 with build-id be888237edef41af2051f332858c8143176ec387
Module liblcms2.so.2 with build-id c01e5649a38dbf37768d02dc751b52de0dcbd141
Module libinput.so.10 with build-id 9de57b91e0d1d09e53606692e2c51c8b31d3dfe1
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libudev.so.1 with build-id 1c5c93f27f6b1fcbf2af1d56079e945779b8c097
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
Module libxcb-icccm.so.4 with build-id 5eb9288df14c7f50af1e8db26c37e19d78bf0978
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module libxcb-damage.so.0 with build-id d18fa3897f9041bfe25380abd9834332896cda81
Module libxcb-cursor.so.0 with build-id 32639468f86df91bcdccd9e7b11ec4ac7ef2bf35
Module libxcb-composite.so.0 with build-id e8b69e2806d928f66445390cc50ab33a0b98bef0
Module libKScreenLocker.so.5 with build-id e190d2c546c6d49b7444ffcf368cb70e647b6b44
Module libkdecorations2private.so.9 with build-id 9bc4c8fa285dab2eba510fdb6eacc4d3420bbb70
Module libkdecorations2.so.5 with build-id d93cb3ddf0149f800895e3e32eb147dac7049574
Module libKF5GlobalAccelPrivate.so.5 with build-id 1b4058c532c327e7a631e2ab284bec055e3efe11
Module libc.so.6 with build-id 7d4293a9bbe1f068ab7ae807c2d9377395eb5b41
Module libm.so.6 with build-id efeea58692a42176201df89f034aa4295a77ce74
Module libstdc++.so.6 with build-id e0dd3ec5b0a62b122b4141c956c0b33a4d719144
Module libQt5X11Extras.so.5 with build-id ec950f22918930044e4b7cebb233977269559525
Module libQt5DBus.so.5 with build-id cb4975246458c1f3591617bc981289d39c812a1c
Module libKF5CoreAddons.so.5 with build-id 96ecc42f7398b26af574cc89c9bf396cc263f2b5
Module libQt5Widgets.so.5 with build-id f2e89f8898b313ed4df102c6b9d3deb6b35bb574
Module libKF5WindowSystem.so.5 with build-id fd16ca3ebcc30d78f056c3404375a5b054f30f83
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libQt5Core.so.5 with build-id d0b7a28d507dd3904c4566fcb8cbb3b006a93040
Module libQt5Gui.so.5 with build-id ac1161e08a4cd86e4ecf156a8599dcb2cbbb7364
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libKF5I18n.so.5 with build-id c455fb3f1d041e2c3a91b403510d7838f77cb8cc
Module libKF5ConfigCore.so.5 with build-id 6fc159fc563f5fefd5e73131ff5c736f90478144
Module libKF5ConfigGui.so.5 with build-id e2ed1dde6cd3e43cf02f85565e7b99b42f6fc6ae
Module libKF5ConfigWidgets.so.5 with build-id d9ca13b0bb7ccb924944057ee96bb8c6c9560860
Module libKF5GlobalAccel.so.5 with build-id fb6745056eb26a1b661805088cc3206c92903b67
Module libKF5Notifications.so.5 with build-id a28061f5fd10d13a8f9910811bdbaca664c5cdd8
Module libQt5Qml.so.5 with build-id f36f75407363858446bd91ee785afbda52ba5abe
Module libQt5Quick.so.5 with build-id 35261a038f923611ff79ab68fee76dede20997d8
Module libKF5QuickAddons.so.5 with build-id f079b2562a68451792e92c692d960bb05d6a20a5
Module libkwinglutils.so.13 with build-id 37c3cf010bb69e3996edf67d9aee01cbb50c486d
Module libkwineffects.so.13 with build-id 5e7e99a113fc60a1e8f88290ff76b82f5e14524b
Module libKWaylandServer.so.5 with build-id 9d8eb9b36c4c0d92b7fb689304e601d2ccb0eeb4
Module libKF5Service.so.5 with build-id b46215476e2f335d5d812114110484075b0f56d6
Module libKF5Plasma.so.5 with build-id 4b2239d6c3c3ed151a14e90a4aec6cd059c369ff
Module libqaccessibilityclient-qt5.so.0 with build-id 3133e868d77f4c2c6ebd657793baeb6a4e824544
Module libKF5Crash.so.5 with build-id 8c1b7564cbe8bc9e601cdbac4299f548bdbcb754
Module libkwin.so.5 with build-id 725414c48de41535e2c012ba8f4f7eb634e0924a
Module kwin_x11 with build-id 9b0db2c1872480dcd8d5dee5fbbca4df3a520678
Stack trace of thread 756:
#0 0x00007f02fbaa14dc n/a (libc.so.6 + 0x884dc)
#1 0x00007f02fba51998 raise (libc.so.6 + 0x38998)
#2 0x00007f02fe9713a4 _ZN6KCrash19defaultCrashHandlerEi (libKF5Crash.so.5 + 0x73a4)
#3 0x00007f02fba51a40 n/a (libc.so.6 + 0x38a40)
#4 0x00007f02fd1fbd02 _ZN7QRegionD1Ev (libQt5Gui.so.5 + 0x3fbd02)
#5 0x00007f02f4482848 n/a (KWinX11Platform.so + 0x36848)
#6 0x00007f02fe6ca8fe _ZN4KWin11SceneOpenGL5paintEPNS_14AbstractOutputERK7QRegionRK5QListIPNS_8ToplevelEEPNS_10RenderLoopE (libkwin.so.5 + 0x2ca8fe)
#7 0x00007f02fe53beda _ZN4KWin10Compositor9compositeEPNS_10RenderLoopE (libkwin.so.5 + 0x13beda)
#8 0x00007f02fe53c615 _ZN4KWin13X11Compositor9compositeEPNS_10RenderLoopE (libkwin.so.5 + 0x13c615)
#9 0x00007f02fcabd341 n/a (libQt5Core.so.5 + 0x2bd341)
#10 0x00007f02fe4e9f67 _ZN4KWin10RenderLoop14frameRequestedEPS0_ (libkwin.so.5 + 0xe9f67)
#11 0x00007f02fe5ddc98 _ZN4KWin17RenderLoopPrivate8dispatchEv (libkwin.so.5 + 0x1ddc98)
#12 0x00007f02fcabd341 n/a (libQt5Core.so.5 + 0x2bd341)
#13 0x00007f02fcabf6ff _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2bf6ff)
#14 0x00007f02fcab03e6 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b03e6)
#15 0x00007f02fc178b3c _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x178b3c)
#16 0x00007f02fca8cad8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28cad8)
#17 0x00007f02fcad6b73 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6b73)
#18 0x00007f02fcad7022 _ZN20QEventDispatcherUNIX13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d7022)
#19 0x00007f02f6b30a53 n/a (libQt5XcbQpa.so.5 + 0x63a53)
#20 0x00007f02fca8527c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28527c)
#21 0x00007f02fca8fda9 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fda9)
#22 0x0000556c281f0d70 n/a (kwin_x11 + 0x2fd70)
#23 0x00007f02fba3c2d0 n/a (libc.so.6 + 0x232d0)
#24 0x00007f02fba3c38a __libc_start_main (libc.so.6 + 0x2338a)
#25 0x0000556c281f25a5 n/a (kwin_x11 + 0x315a5)
Stack trace of thread 986:
#0 0x00007f02ee8ce776 n/a (libnvidia-glcore.so.515.65.01 + 0xece776)
#1 0x00007f02ee978c2b n/a (libnvidia-glcore.so.515.65.01 + 0xf78c2b)
#2 0x00007f02ee97bf27 n/a (libnvidia-glcore.so.515.65.01 + 0xf7bf27)
#3 0x00007f02ee97c7ab n/a (libnvidia-glcore.so.515.65.01 + 0xf7c7ab)
#4 0x00007f02ee91f5c6 n/a (libnvidia-glcore.so.515.65.01 + 0xf1f5c6)
#5 0x00007f02ee91fe7d n/a (libnvidia-glcore.so.515.65.01 + 0xf1fe7d)
#6 0x00007f02ee9230fc n/a (libnvidia-glcore.so.515.65.01 + 0xf230fc)
#7 0x00007f02ee8bdb14 n/a (libnvidia-glcore.so.515.65.01 + 0xebdb14)
#8 0x00007f02ee8bde2a n/a (libnvidia-glcore.so.515.65.01 + 0xebde2a)
#9 0x00007f02ee8bb72a n/a (libnvidia-glcore.so.515.65.01 + 0xebb72a)
#10 0x00007f02fba9f78d n/a (libc.so.6 + 0x8678d)
#11 0x00007f02fbb208e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 773:
#0 0x00007f02fbb13e9f __poll (libc.so.6 + 0xfae9f)
#1 0x00007f02fda7620b n/a (libxcb.so.1 + 0xd20b)
#2 0x00007f02fda77ccd xcb_wait_for_event (libxcb.so.1 + 0xeccd)
#3 0x00007f02f6b2e652 n/a (libQt5XcbQpa.so.5 + 0x61652)
#4 0x00007f02fc8e42ca n/a (libQt5Core.so.5 + 0xe42ca)
#5 0x00007f02fba9f78d n/a (libc.so.6 + 0x8678d)
#6 0x00007f02fbb208e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 1404:
#0 0x00007f02fba9c346 n/a (libc.so.6 + 0x83346)
#1 0x00007f02fba9eb60 pthread_cond_wait (libc.so.6 + 0x85b60)
#2 0x00007f02fc8eb744 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xeb744)
#3 0x00007f02fddfb0d3 n/a (libQt5Quick.so.5 + 0x1fb0d3)
Stack trace of thread 804:
#0 0x00007f02fbb13f96 ppoll (libc.so.6 + 0xfaf96)
#1 0x00007f02fcad03cb _Z12qt_safe_pollP6pollfdmPK8timespec (libQt5Core.so.5 + 0x2d03cb)
#2 0x00007f02fcad6e70 _ZN20QEventDispatcherUNIX13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d6e70)
#3 0x00007f02fca8527c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28527c)
#4 0x00007f02fc8e749f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
#5 0x00007f02fd8bf780 n/a (libQt5Qml.so.5 + 0x2bf780)
#6 0x00007f02fc8e42ca n/a (libQt5Core.so.5 + 0xe42ca)
#7 0x00007f02fba9f78d n/a (libc.so.6 + 0x8678d)
#8 0x00007f02fbb208e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 792:
#5 0x00007f02fc7a3cba n/a (libQt5DBus.so.5 + 0x23cba)
Stack trace of thread 881:
#5 0x00007f02fc8e42ca n/a (libQt5Core.so.5 + 0xe42ca)
#6 0x00007f02fba9f78d n/a (libc.so.6 + 0x8678d)
#7 0x00007f02fbb208e4 __clone (libc.so.6 + 0x1078e4)
