No keyboard input. Haven’t chrooted yet but I want to know what the problem is and why it even happened. I mass removed packages from a repo and removed the repo. I got a bunch of errors when trying update-grub or pacman -syyu so I installed stuff it was moaning about and tried the same commands again producing no errors. After reboot, got thrown into this. Fix?
Was running 54 and 419. Computer is amd64 with 440xx.
mega.nz/file/hJNVAYpa#KM9pSEQHI-4a2nX08bhFcDF_s8bxsYPcrl6nM4Qos_A
Hi and welcome to the forum ![]()
I think you just answered it better as anyone can at moment…
It might sound hard, but that’s the only real response you can get, because no one is telepathic to know what you did exactly and what you system is like etc etc…
ugh ffs. Cough cough.
edit: Sorry if I came off as an asshole but it annoys me as you respond like I gave absolutely no information when I have. Just seems like some more elitist crap rather than me just completely failing to ask a question well. Ask for info if you actually require more than I have given. I have said what I did which lead to the problem of not booting and what kernels I use, graphics drivers, 64 bit CPU.
People may not respond to photos (Harder to read in some cases). Please use one of the methods mentioned below:
Because you reply with your own quote so will i with mine…
I just got this output. I don’t know how I could do this when I can’t boot. Only way would be for me to read the image and type out here. Why do that when you could do what I would and just read the image?
edit: My 2nd comment referring to uploading terminal log to pastebin when I can’t even get a tty.
You reply like I said my computer doesn’t show my desktop when I have given a decent amount of information. I understand your quote but what do you even expect me to reply to that with.
My bad. I completely missed the first three words of the OP ![]()
Also tried another kb and a badusb but nothing.
Ok take a breath, i can understand you being in panic.
But this is the current situation:
You call a doctor via phone and tell the doctor “I’m sick, please cure me” and you expect the doctor to tell you to “get medicine x” and cure you…
Do you understand what is happening here?
Only giving info (if you did because i don’t look at photos) about the results at end will not help others to help you solve your problem.
You need to be specific in what you did in detail that caused the result…
To get info about your hardware if you are locked-out of your system is to boot from a Live medium (USB/DVD).
After you have booted in that Live system please see:
Do you have a live usb at hand?
Edit: TriMoon will take it from here
Not really because im off, see my local time ![]()
Nevermind. I cba for this crap. I’ll just chroot and hack around. If I can’t get a fix, I’ll just use my recent deja vup backup of 2 days ago or just move important data elsewhere and clean install. If I need advice on a few things while trying to fix, I’ll get help from others. Goodbye.
Hello @basementdweller1
From what i see on your screenshot, I would say a lib is missing: libargon2.so.1
You could search for this file:
pamac search --files libargon2.so.1
/usr/lib/libargon2.so.1 is owned by argon2
ok good. This file is owned by argon2. That is this package:
$ LANG=C pamac info argon2
Version : 20190702-3
Description : A password-hashing function (reference C implementation)
URL : https://github.com/P-H-C/phc-winner-argon2
Licenses : Apache custom:CC0
Repository : core
Installed Size : 116.2 kB
Depends On : glibc
Provides : libargon2.so=1-64
Packager : Christian Hesse <arch@eworm.de>
Build Date : 05/07/20
Install Date : 06/06/20
Install Reason : Installed as a dependency for another package
Signatures : Yes
The fix could be just chrooting with manjaro-chroot -a on a live environment and installing this packages again:
pamac install argon2
Good luck
Tried that a while ago already. Not getting the error anymore. Just a black screen.
edit: black screen after the decrypt prompt.
edit1: well not from a live env but from my other disk and not manjaro-chroot but instead standard, manual chroot.
No idea then. Please provide a journal log:
journalctl -b1 | curl -F'file=@-' https://0x0.st
Currently running fine on 419. If I upgrade kernel, it has autismo attack and I have to chroot and remove again. Don’t have a reason but I think systemd is being a lil sh#te. Single file ‘0x0.st/iC2C.txt’. Lists some personal informaiton but nothing crazy. Ask if you need anything else.
-- Logs begin at Sat 2020-10-10 14:48:55 BST, end at Tue 2020-12-22 14:28:32 GMT. --
Oct 10 14:48:55 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:48:56 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:48:56 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/KickoffListView.qml:57:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:48:56 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/SearchView.qml:82:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:48:56 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/SearchView.qml:69:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:48:56 iphone plasmashell[1898]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:482:39: QML StreamListItem: Binding loop detected for property "width"
Oct 10 14:48:56 iphone pipewire[2219]: [E][000000044.895217][bluez5-dbus.c:1455 get_managed_objects_reply()] GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut
Oct 10 14:48:56 iphone pulseaudio[1942]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Oct 10 14:48:56 iphone kded5[1839]: kf.bluezqt: PendingCall Error: "Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)"
Oct 10 14:48:56 iphone dbus-daemon[1766]: [session uid=1000 pid=1766] Activating service name='org.kde.runners.baloo' requested by ':1.22' (uid=1000 pid=1898 comm="/usr/bin/plasmashell " label="unconfined")
Oct 10 14:48:56 iphone dbus-daemon[1766]: [session uid=1000 pid=1766] Successfully activated service 'org.kde.runners.baloo'
Oct 10 14:48:56 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 1 and reason "Playing a game"
Oct 10 14:48:56 iphone org_kde_powerdevil[2036]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
Oct 10 14:48:56 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:48:57 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/BusyIndicatorStyle.qml:26:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:48:57 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:48:57 iphone systemd[1742]: Started app-com.leinardi.gwe-b177ea3b8b4f4cb79b20552d1272bf8f.scope.
Oct 10 14:48:57 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 2 and reason "Playing a game"
Oct 10 14:48:57 iphone org_kde_powerdevil[2036]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
Oct 10 14:48:57 iphone dbus-daemon[1766]: [session uid=1000 pid=1766] Activating via systemd: service name='org.freedesktop.Flatpak' unit='flatpak-session-helper.service' requested by ':1.82' (uid=1000 pid=2950 comm="/usr/bin/flatpak run --branch=stable --arch=x86_64" label="unconfined")
Oct 10 14:48:57 iphone systemd[1742]: Starting flatpak session helper...
Oct 10 14:48:57 iphone dbus-daemon[1766]: [session uid=1000 pid=1766] Successfully activated service 'org.freedesktop.Flatpak'
Oct 10 14:48:57 iphone systemd[1742]: Started flatpak session helper.
Oct 10 14:48:57 iphone systemd[1742]: Started app-flatpak-com.leinardi.gwe-2950.scope.
Oct 10 14:48:57 iphone systemd[1742]: app-com.leinardi.gwe-b177ea3b8b4f4cb79b20552d1272bf8f.scope: Succeeded.
Oct 10 14:48:59 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.86" "/usr/lib/chromium/chromium" with cookie 3 and reason "Playing audio"
Oct 10 14:48:59 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.18" "/usr/lib/chromium/chromium" with cookie 4 and reason "Video Wake Lock"
Oct 10 14:48:59 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.87" "/usr/lib/chromium/chromium" with cookie 5 and reason "Video Wake Lock"
Oct 10 14:48:59 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 4
Oct 10 14:48:59 iphone org_kde_powerdevil[2036]: powerdevil: It was only scheduled for inhibition but not enforced yet, just discarding it
Oct 10 14:48:59 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 5
Oct 10 14:48:59 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 3
Oct 10 14:48:59 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:48:59 iphone kded5[1839]: Registering ":1.89/org/ayatana/NotificationItem/com_leinardi_gwe" to system tray
Oct 10 14:49:01 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:49:03 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.86" "/usr/lib/chromium/chromium" with cookie 3 and reason "Playing audio"
Oct 10 14:49:03 iphone org_kde_powerdevil[2036]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
Oct 10 14:49:04 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "/usr/lib/chromium/chromium" with cookie 4 and reason "Video Wake Lock"
Oct 10 14:49:04 iphone org_kde_powerdevil[2036]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
Oct 10 14:49:04 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.87" "/usr/lib/chromium/chromium" with cookie 5 and reason "Video Wake Lock"
Oct 10 14:49:04 iphone xdg-desktop-portal-kde[2127]: xdp-kde-background: GetAppState called: no parameters
Oct 10 14:49:17 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 6 and reason "Playing a game"
Oct 10 14:49:22 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 6 and reason "Playing a game"
Oct 10 14:49:22 iphone org_kde_powerdevil[2036]: powerdevil: Added change screen settings
Oct 10 14:49:22 iphone org_kde_powerdevil[2036]: powerdevil: Added interrupt session
Oct 10 14:49:22 iphone org_kde_powerdevil[2036]: powerdevil: Disabling DPMS due to inhibition
Oct 10 14:49:22 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:49:23 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:49:23 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.18" "/usr/lib/chromium/chromium" with cookie 7 and reason "Video Wake Lock"
Oct 10 14:49:23 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.92" "/usr/lib/chromium/chromium" with cookie 8 and reason "Video Wake Lock"
Oct 10 14:49:23 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.93" "/usr/lib/chromium/chromium" with cookie 9 and reason "Playing audio"
Oct 10 14:49:23 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 10 and reason "Playing a game"
Oct 10 14:49:26 iphone kwin_x11[1843]: file:///usr/share/kwin/aurorae/MenuButton.qml:22: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
Oct 10 14:49:26 iphone kwin_x11[1843]: QPainter::begin: Paint device returned engine == 0, type: 3
Oct 10 14:49:26 iphone kwin_x11[1843]: QPainter::begin: Paint device returned engine == 0, type: 2
Oct 10 14:49:26 iphone kwin_x11[1843]: QPainter::end: Painter not active, aborted
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48533, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48534, resource id: 14690903, major code: 55 (CreateGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48535, resource id: 14690903, major code: 72 (PutImage), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 48536, resource id: 14690904, major code: 60 (FreeGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 48538, resource id: 14690903, major code: 54 (FreePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48540, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48541, resource id: 14690905, major code: 55 (CreateGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48542, resource id: 14690905, major code: 72 (PutImage), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 48543, resource id: 14690906, major code: 60 (FreeGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 48545, resource id: 14690905, major code: 54 (FreePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48547, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48548, resource id: 14690907, major code: 55 (CreateGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48549, resource id: 14690907, major code: 72 (PutImage), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 48550, resource id: 14690908, major code: 60 (FreeGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 48552, resource id: 14690907, major code: 54 (FreePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48554, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48555, resource id: 14690909, major code: 55 (CreateGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48556, resource id: 14690909, major code: 72 (PutImage), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 48557, resource id: 14690910, major code: 60 (FreeGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 48559, resource id: 14690909, major code: 54 (FreePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48561, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48562, resource id: 14690911, major code: 55 (CreateGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48563, resource id: 14690911, major code: 72 (PutImage), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 48564, resource id: 14690912, major code: 60 (FreeGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 48566, resource id: 14690911, major code: 54 (FreePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48568, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48569, resource id: 14690913, major code: 55 (CreateGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48570, resource id: 14690913, major code: 72 (PutImage), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 48571, resource id: 14690914, major code: 60 (FreeGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 48573, resource id: 14690913, major code: 54 (FreePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48575, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48576, resource id: 14690915, major code: 55 (CreateGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48577, resource id: 14690915, major code: 72 (PutImage), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 48578, resource id: 14690916, major code: 60 (FreeGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 48580, resource id: 14690915, major code: 54 (FreePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48582, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48583, resource id: 14690917, major code: 55 (CreateGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48584, resource id: 14690917, major code: 72 (PutImage), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 48585, resource id: 14690918, major code: 60 (FreeGC), minor code: 0
Oct 10 14:49:26 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 48587, resource id: 14690917, major code: 54 (FreePixmap), minor code: 0
Oct 10 14:49:26 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:49:27 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "/usr/lib/chromium/chromium" with cookie 7 and reason "Video Wake Lock"
Oct 10 14:49:27 iphone org_kde_powerdevil[2036]: powerdevil: Added change screen settings
Oct 10 14:49:27 iphone org_kde_powerdevil[2036]: powerdevil: Added interrupt session
Oct 10 14:49:27 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.92" "/usr/lib/chromium/chromium" with cookie 8 and reason "Video Wake Lock"
Oct 10 14:49:27 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:49:28 iphone kwin_x11[1843]: Could not attach Keys property to: PlasmaQuick::Dialog(0x5623e532e080) is not an Item
Oct 10 14:49:28 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:62:17: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:49:28 iphone kwin_x11[1843]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:49:28 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:70:27: QML MouseArea: Binding loop detected for property "height"
Oct 10 14:49:28 iphone kwin_x11[1843]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:49:28 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.93" "/usr/lib/chromium/chromium" with cookie 9 and reason "Playing audio"
Oct 10 14:49:28 iphone org_kde_powerdevil[2036]: powerdevil: Added interrupt session
Oct 10 14:49:28 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:49:28 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 10 and reason "Playing a game"
Oct 10 14:49:28 iphone org_kde_powerdevil[2036]: powerdevil: Added change screen settings
Oct 10 14:49:28 iphone kwin_x11[1843]: qt.svg: link #g917 is undefined!
Oct 10 14:49:28 iphone kwin_x11[1843]: qt.svg: link #g949 is undefined!
Oct 10 14:49:28 iphone kwin_x11[1843]: qt.svg: link #g969 is undefined!
Oct 10 14:49:30 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 7
Oct 10 14:49:30 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 8
Oct 10 14:49:30 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:49:30 iphone pulseaudio[1942]: E: [alsa-sink-ALC892 Digital] alsa-sink.c: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Oct 10 14:49:30 iphone pulseaudio[1942]: E: [alsa-sink-ALC892 Digital] alsa-sink.c: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Oct 10 14:49:30 iphone pulseaudio[1942]: E: [alsa-sink-ALC892 Digital] alsa-sink.c: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Oct 10 14:49:32 iphone msm_kde_notifier[1938]: "qt5-translations"
Oct 10 14:49:32 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 9
Oct 10 14:49:32 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:49:34 iphone tracker-store[2181]: OK
Oct 10 14:49:34 iphone systemd[1742]: tracker-store.service: Succeeded.
Oct 10 14:49:34 iphone xdg-desktop-portal-kde[2127]: xdp-kde-background: GetAppState called: no parameters
Oct 10 14:49:35 iphone plasmashell[1898]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:482:39: QML StreamListItem: Binding loop detected for property "width"
Oct 10 14:49:37 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:49:41 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:49:41 iphone plasmashell[1898]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:482:39: QML StreamListItem: Binding loop detected for property "width"
Oct 10 14:49:50 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:70:27: QML MouseArea: Binding loop detected for property "height"
Oct 10 14:49:50 iphone kwin_x11[1843]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:49:50 iphone kwin_x11[1843]: file:///usr/share/kwin/aurorae/MenuButton.qml:22: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
Oct 10 14:49:50 iphone kwin_x11[1843]: QPainter::begin: Paint device returned engine == 0, type: 3
Oct 10 14:49:53 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 10
Oct 10 14:49:53 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 11 and reason "Playing a game"
Oct 10 14:49:53 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:49:58 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 11 and reason "Playing a game"
Oct 10 14:49:58 iphone org_kde_powerdevil[2036]: powerdevil: Added change screen settings
Oct 10 14:49:58 iphone org_kde_powerdevil[2036]: powerdevil: Added interrupt session
Oct 10 14:49:58 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:50:04 iphone xdg-desktop-portal-kde[2127]: xdp-kde-background: GetAppState called: no parameters
Oct 10 14:50:06 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:50:21 iphone plasmashell[1898]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:482:39: QML StreamListItem: Binding loop detected for property "width"
Oct 10 14:50:23 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 11
Oct 10 14:50:23 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 12 and reason "Playing a game"
Oct 10 14:50:23 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:50:28 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 12 and reason "Playing a game"
Oct 10 14:50:28 iphone org_kde_powerdevil[2036]: powerdevil: Added change screen settings
Oct 10 14:50:28 iphone org_kde_powerdevil[2036]: powerdevil: Added interrupt session
Oct 10 14:50:28 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:50:34 iphone xdg-desktop-portal-kde[2127]: xdp-kde-background: GetAppState called: no parameters
Oct 10 14:50:50 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:50:53 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 12
Oct 10 14:50:53 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 13 and reason "Playing a game"
Oct 10 14:50:53 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:50:58 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 13 and reason "Playing a game"
Oct 10 14:50:58 iphone org_kde_powerdevil[2036]: powerdevil: Added change screen settings
Oct 10 14:50:58 iphone org_kde_powerdevil[2036]: powerdevil: Added interrupt session
Oct 10 14:50:58 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:51:05 iphone plasmashell[1898]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:482:39: QML StreamListItem: Binding loop detected for property "width"
Oct 10 14:51:24 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 13
Oct 10 14:51:24 iphone org_kde_powerdevil[2036]: powerdevil: Scheduling inhibition from ":1.18" "My SDL application" with cookie 14 and reason "Playing a game"
Oct 10 14:51:24 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:51:29 iphone org_kde_powerdevil[2036]: powerdevil: Enforcing inhibition from ":1.18" "My SDL application" with cookie 14 and reason "Playing a game"
Oct 10 14:51:29 iphone org_kde_powerdevil[2036]: powerdevil: Added change screen settings
Oct 10 14:51:29 iphone org_kde_powerdevil[2036]: powerdevil: Added interrupt session
Oct 10 14:51:29 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:51:32 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:51:32 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/KickoffListView.qml:57:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:51:32 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:51:32 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/ApplicationsView.qml:75:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:51:32 iphone plasmashell[1898]: file:///usr/lib/qt/qml/org/kde/plasma/components/ButtonRow.qml:46: ReferenceError: PlasmaCore is not defined
Oct 10 14:51:32 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/BaseView.qml:49:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:51:33 iphone plasmashell[1898]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:51:33 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/KickoffListView.qml:57:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:51:33 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/BaseView.qml:49:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:51:41 iphone dbus-daemon[1766]: [session uid=1000 pid=1766] Activating service name='org.kde.LogoutPrompt' requested by ':1.18' (uid=1000 pid=1876 comm="/usr/bin/ksmserver " label="unconfined")
Oct 10 14:51:41 iphone dbus-daemon[1766]: [session uid=1000 pid=1766] Successfully activated service 'org.kde.LogoutPrompt'
Oct 10 14:51:42 iphone ksmserver-logout-greeter[3595]: file:///home/dododo/.local/share/plasma/look-and-feel/com.github.vinceliuice.ChromeOS-dark/contents/components/UserDelegate.qml:31: ReferenceError: model is not defined
Oct 10 14:51:42 iphone kwin_x11[1843]: file:///usr/share/kwin/aurorae/MenuButton.qml:22: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
Oct 10 14:51:42 iphone kwin_x11[1843]: QPainter::begin: Paint device returned engine == 0, type: 3
Oct 10 14:51:44 iphone dbus-daemon[1766]: [session uid=1000 pid=1766] Activating service name='org.kde.Shutdown' requested by ':1.18' (uid=1000 pid=1876 comm="/usr/bin/ksmserver " label="unconfined")
Oct 10 14:51:44 iphone dbus-daemon[1766]: [session uid=1000 pid=1766] Successfully activated service 'org.kde.Shutdown'
Oct 10 14:51:44 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2689, resource id: 96469002, major code: 15 (QueryTree), minor code: 0
Oct 10 14:51:44 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2695, resource id: 96469002, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:44 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2770, resource id: 96469014, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:44 iphone plasmashell[1898]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:482:39: QML StreamListItem: Binding loop detected for property "width"
Oct 10 14:51:44 iphone kwin_x11[1843]: DesktopGridConfig::instance called after the first use - ignoring
Oct 10 14:51:44 iphone kwin_x11[1843]: KscreenConfig::instance called after the first use - ignoring
Oct 10 14:51:44 iphone kwin_x11[1843]: PresentWindowsConfig::instance called after the first use - ignoring
Oct 10 14:51:44 iphone kwin_x11[1843]: SlideConfig::instance called after the first use - ignoring
Oct 10 14:51:44 iphone kwin_x11[1843]: SlidingPopupsConfig::instance called after the first use - ignoring
Oct 10 14:51:44 iphone kwin_x11[1843]: ZoomConfig::instance called after the first use - ignoring
Oct 10 14:51:44 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 6
Oct 10 14:51:44 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:51:45 iphone kwin_x11[1843]: qt.svg: link #g917 is undefined!
Oct 10 14:51:45 iphone kwin_x11[1843]: qt.svg: link #g949 is undefined!
Oct 10 14:51:45 iphone kwin_x11[1843]: qt.svg: link #g969 is undefined!
Oct 10 14:51:45 iphone org_kde_powerdevil[2036]: powerdevil: Releasing inhibition with cookie 14
Oct 10 14:51:45 iphone org_kde_powerdevil[2036]: powerdevil: Restoring DPMS features after inhibition release
Oct 10 14:51:45 iphone org_kde_powerdevil[2036]: powerdevil: Can't contact ck
Oct 10 14:51:45 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5366, resource id: 62914700, major code: 15 (QueryTree), minor code: 0
Oct 10 14:51:45 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5371, resource id: 62914700, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:45 iphone plasmashell[1898]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 10 14:51:48 iphone kded5[1839]: Service ":1.77" unregistered
Oct 10 14:51:48 iphone systemd[1742]: app-steam-c5e080704f3e430c994b5548b9aae3b0.scope: Succeeded.
Oct 10 14:51:48 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7159, resource id: 35651773, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:48 iphone msm_kde_notifier[1938]: Shutting down MSM Notifier...
Oct 10 14:51:48 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7169, resource id: 39845893, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:48 iphone polkit-kde-authentication-agent-1[1902]: Destroying listener
Oct 10 14:51:48 iphone polkit-kde-authentication-agent-1[1902]: Removing listener PolkitQt1::Agent::Listener(0x55dd6455ee10)
Oct 10 14:51:48 iphone kded5[1839]: Service ":1.31" unregistered
Oct 10 14:51:48 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7173, resource id: 54525957, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:48 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7177, resource id: 41943045, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:48 iphone systemd[1742]: app-\x2fusr\x2fbin\x2fmsm_kde_notifier-a198ef952fa44bd7a999f17f8fab23b8.scope: Succeeded.
Oct 10 14:51:48 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7181, resource id: 29360133, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:48 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7185, resource id: 31457285, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:48 iphone kwin_x11[1843]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7189, resource id: 23068679, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:51:48 iphone sddm[1757]: kwalletd5: Checking for pam module
Oct 10 14:51:48 iphone sddm[1757]: kwalletd5: Got pam-login param
Oct 10 14:51:48 iphone sddm[1757]: kwalletd5: Waiting for hash on 7-
Oct 10 14:51:48 iphone sddm[1757]: kwalletd5: waitingForEnvironment on: 3
Oct 10 14:51:48 iphone sddm[1757]: kwalletd5: client connected
Oct 10 14:51:48 iphone sddm[1757]: kwalletd5: client disconnected
Oct 10 14:51:49 iphone kwin_x11[1843]: The X11 connection broke (error 1). Did the X11 server die?
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:58: TypeError: Cannot read property 'smallSpacing' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:201: TypeError: Cannot read property 'smallSpacing' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:202: TypeError: Cannot read property 'smallSpacing' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:218: TypeError: Cannot read property 'smallSpacing' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:219: TypeError: Cannot read property 'smallSpacing' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:109: TypeError: Cannot read property 'iconSizes' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:110: TypeError: Cannot read property 'iconSizes' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:105: TypeError: Cannot read property 'smallSpacing' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:86: TypeError: Cannot read property 'smallSpacing' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:87: TypeError: Cannot read property 'smallSpacing' of null
Oct 10 14:51:49 iphone kwin_x11[1843]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:88: TypeError: Cannot read property 'smallSpacing' of null
Oct 10 14:51:49 iphone kactivitymanagerd[1849]: The X11 connection broke (error 1). Did the X11 server die?
Oct 10 14:51:49 iphone kglobalaccel5[1872]: The X11 connection broke (error 1). Did the X11 server die?
Oct 10 14:51:49 iphone kded5[1839]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Oct 10 14:51:49 iphone dbus-daemon[1766]: [session uid=1000 pid=1766] Activating service name='org.kde.kglobalaccel' requested by ':1.12' (uid=1000 pid=1839 comm="/usr/bin/kded5 " label="unconfined")
Oct 10 14:51:49 iphone kded5[1839]: bluedevil: Destroyed
Oct 10 14:51:49 iphone kded5[1839]: The X11 connection broke: I/O error (code 1)
Oct 10 14:51:49 iphone kscreen_backend_launcher[1951]: The X11 connection broke (error 1). Did the X11 server die?
Oct 10 14:51:49 iphone xdg-desktop-portal-kde[2127]: The X11 connection broke (error 1). Did the X11 server die?
Oct 10 14:51:49 iphone at-spi-bus-launcher[2175]: X connection to :0 broken (explicit kill or server shutdown).
Oct 10 14:51:49 iphone baloorunner[2865]: The X11 connection broke (error 1). Did the X11 server die?
Oct 10 14:51:49 iphone systemd[1742]: app-flatpak-com.leinardi.gwe-2950.scope: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopping app-chromium-49e9d839c783430992dfefc0cdb780df.scope.
Oct 10 14:51:49 iphone systemd[1742]: Stopped target Main User Target.
Oct 10 14:51:49 iphone systemd[1742]: Stopping Accessibility services bus...
Oct 10 14:51:49 iphone systemd[1742]: Stopping D-Bus User Message Bus...
Oct 10 14:51:49 iphone systemd[1742]: Stopping flatpak session helper...
Oct 10 14:51:49 iphone systemd[1742]: Stopping Virtual filesystem service - Apple File Conduit monitor...
Oct 10 14:51:49 iphone systemd[1742]: Stopping Virtual filesystem service...
Oct 10 14:51:49 iphone systemd[1742]: Stopping Virtual filesystem service - digital camera monitor...
Oct 10 14:51:49 iphone systemd[1742]: Stopping Virtual filesystem metadata service...
Oct 10 14:51:49 iphone systemd[1742]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Oct 10 14:51:49 iphone systemd[1742]: Stopping Virtual filesystem service - disk device monitor...
Oct 10 14:51:49 iphone systemd[1742]: Stopping Bluetooth OBEX service...
Oct 10 14:51:49 iphone systemd[1742]: Stopping Multimedia Service...
Oct 10 14:51:49 iphone obexd[1952]: Terminating
Oct 10 14:51:49 iphone systemd[1742]: Stopping Sound Service...
Oct 10 14:51:49 iphone systemd[1742]: Stopping Portal service...
Oct 10 14:51:49 iphone systemd[1742]: Stopping flatpak document portal service...
Oct 10 14:51:49 iphone systemd[1742]: Stopping sandboxed app permission store...
Oct 10 14:51:49 iphone systemd[1742]: app-chromium-49e9d839c783430992dfefc0cdb780df.scope: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped app-chromium-49e9d839c783430992dfefc0cdb780df.scope.
Oct 10 14:51:49 iphone systemd[1742]: gvfs-metadata.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Virtual filesystem metadata service.
Oct 10 14:51:49 iphone systemd[1742]: obex.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Bluetooth OBEX service.
Oct 10 14:51:49 iphone systemd[1742]: run-user-1000-gvfs.mount: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: run-user-1000-doc.mount: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Oct 10 14:51:49 iphone systemd[1742]: xdg-document-portal.service: Failed with result 'exit-code'.
Oct 10 14:51:49 iphone systemd[1742]: Stopped flatpak document portal service.
Oct 10 14:51:49 iphone systemd[1742]: xdg-permission-store.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped sandboxed app permission store.
Oct 10 14:51:49 iphone systemd[1742]: gvfs-gphoto2-volume-monitor.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Virtual filesystem service - digital camera monitor.
Oct 10 14:51:49 iphone systemd[1742]: gvfs-mtp-volume-monitor.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Oct 10 14:51:49 iphone systemd[1742]: pipewire.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Multimedia Service.
Oct 10 14:51:49 iphone systemd[1742]: gvfs-daemon.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Virtual filesystem service.
Oct 10 14:51:49 iphone systemd[1742]: Removed slice app.slice.
Oct 10 14:51:49 iphone systemd[1742]: dbus.service: Succeeded.
Oct 10 14:51:49 iphone pulseaudio[1942]: E: [alsa-sink-HDMI 1] alsa-sink.c: Error opening PCM device hdmi:0,1: No such file or directory
Oct 10 14:51:49 iphone systemd[1742]: Stopped D-Bus User Message Bus.
Oct 10 14:51:49 iphone pulseaudio[1942]: E: [alsa-source-USB Audio] alsa-source.c: Error opening PCM device hw:2: No such file or directory
Oct 10 14:51:49 iphone systemd[1742]: xdg-desktop-portal.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Portal service.
Oct 10 14:51:49 iphone systemd[1742]: gvfs-udisks2-volume-monitor.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Virtual filesystem service - disk device monitor.
Oct 10 14:51:49 iphone systemd[1742]: gvfs-afc-volume-monitor.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Virtual filesystem service - Apple File Conduit monitor.
Oct 10 14:51:49 iphone systemd[1742]: flatpak-session-helper.service: Main process exited, code=exited, status=1/FAILURE
Oct 10 14:51:49 iphone systemd[1742]: flatpak-session-helper.service: Failed with result 'exit-code'.
Oct 10 14:51:49 iphone systemd[1742]: Stopped flatpak session helper.
Oct 10 14:51:49 iphone systemd[1742]: pulseaudio.service: Succeeded.
Oct 10 14:51:49 iphone systemd[1742]: Stopped Sound Service.
Oct 10 14:51:53 iphone systemd[1742]: at-spi-dbus-bus.service: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Stopped Accessibility services bus.
Oct 10 14:51:53 iphone systemd[1742]: Stopped target Basic System.
Oct 10 14:51:53 iphone systemd[1742]: Stopped target Paths.
Oct 10 14:51:53 iphone systemd[1742]: Stopped target Sockets.
Oct 10 14:51:53 iphone systemd[1742]: Stopped target Timers.
Oct 10 14:51:53 iphone systemd[1742]: dbus.socket: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Closed D-Bus User Message Bus Socket.
Oct 10 14:51:53 iphone systemd[1742]: dirmngr.socket: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Closed GnuPG network certificate management daemon.
Oct 10 14:51:53 iphone systemd[1742]: gpg-agent-browser.socket: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 10 14:51:53 iphone systemd[1742]: gpg-agent-extra.socket: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Oct 10 14:51:53 iphone systemd[1742]: gpg-agent-ssh.socket: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Oct 10 14:51:53 iphone systemd[1742]: gpg-agent.socket: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Closed GnuPG cryptographic agent and passphrase cache.
Oct 10 14:51:53 iphone systemd[1742]: p11-kit-server.socket: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Closed p11-kit server.
Oct 10 14:51:53 iphone systemd[1742]: pipewire.socket: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Closed Multimedia System.
Oct 10 14:51:53 iphone systemd[1742]: pulseaudio.socket: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Closed Sound System.
Oct 10 14:51:53 iphone systemd[1742]: Reached target Shutdown.
Oct 10 14:51:53 iphone systemd[1742]: systemd-exit.service: Succeeded.
Oct 10 14:51:53 iphone systemd[1742]: Finished Exit the Session.
Oct 10 14:51:53 iphone systemd[1742]: Reached target Exit the Session.
Oct 10 14:51:53 iphone systemd[1743]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[dododo] ruser=[<unknown>] rhost=[<unknown>]
edit: It is mentioning oct 10th which is seems quite old so not sure how this will help you.
@basementdweller1 So your last logged boot was on Oct 10? I guess you disabled the journalctl then somehow or never booted. Then will assume that journalctl -b0 (current boot) will display nothing.
I guess you really messed up and without any information in the log, i could not advice anything than a complete re-installation.
You even didn’t mention which repo and which packages?
That could say more:
cat /var/log/pacman.log
agh nevermind. Thanks for the help. I’m just going to use gentoo. Meaning to switch anyway.
