System Event Sounds in KDE 5
I am wondering how to set system event sound in KDE 5. I have looked thought the system settings and did a google search but haven’t found anything. I did find some things for KDE 4 but they were incorrect obviously since we’re now in KDE 5…
So I am wondering how to set system event sounds, like connecting a USB device, or initial login sound, or closing the lid of the laptop, even maybe opening/closing/minimizing windows etc. etc. etc…
I think I read somewhere that this ability was removed but that doesn’t seam reasonable considering the customizability of KDE 5…
Found it:
  • Go to System Settings
  • Notifications
  • Application Settings
  • Plasma Workspace
  • Configure Events
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
