Hello everyone!!
Since kernel update (to 5.7) in August 12th, I’ve been having this problem: when my machine boots up sometimes it renders 1024x768, but the correct resolution is 1366x768. In order to know what is the problem I typed sudo journalctl -p 3 -xb
in the terminal and got:
-- Logs begin at Tue 2020-07-28 08:02:21 -05, end at Tue 2020-10-06 14:52:39 -05. --
oct 06 14:13:21 siwar-pc lightdm[917]: gkr-pam: unable to locate daemon control file
oct 06 14:13:22 siwar-pc ntpd[1018]: bind(21) AF_INET6 fe80::34fb:dafc:9c35:5eca%3#123 flags 0x11 failed: Cannot assign requested addr>
oct 06 14:13:22 siwar-pc ntpd[1018]: unable to create socket on wlp1s0 (5) for fe80::34fb:dafc:9c35:5eca%3#123
oct 06 14:13:36 siwar-pc systemd-coredump[1246]: Process 968 (qtile) of user 1000 dumped core.
I’m relatively new to Linux and I’ve been reading the arch wiki but I still don’t know how to fix the problem.
Fabby
7 October 2020 12:40
2
Welcome to Manjaro!
You posted in English in the Spanish category. No wonder no one looked at your issue. (fixed that for you already)
Please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins 🕑
Likes: 133 ❤
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Thanks!!
As for the command inxi --admin --verbosity=7 --filter --no-host --width
I got the following:
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=6ee4e8c2-2ae3-4139-ac05-07dd7afd835a rw quiet udev.log_priority=3
Desktop: Qtile 0.16.1 dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 14-3467 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 029XY7 v: A00 serial: <filter> UEFI: Dell v: 2.10.0
date: 05/10/2019
RAM: total: 15.51 GiB used: 1.05 GiB (6.8%)
Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: D6
L2 cache: 3072 KiB bogomips: 21607
Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5916
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-5:2 chip ID: 0bda:5769 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel port: f040 bus ID: 01:00.0
chip ID: 168c:0036
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8136
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-8:5
chip ID: 0cf3:e005
Local Storage: total: 931.51 GiB used: 23.85 GiB (2.6%)
ID-1: /dev/sda vendor: Western Digital model: WDS100T2B0A-00SM50
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 00WD scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C1
dev-links: cdrom
ID-1: / raw size: 931.22 GiB size: 915.60 GiB (98.32%)
used: 23.85 GiB (2.6%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 6ee4e8c2-2ae3-4139-ac05-07dd7afd835a
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: 0D64-0D52
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-5:2 info: Realtek Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:5769
serial: <filter>
Device-2: 1-6:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 serial: <filter>
Device-3: 1-8:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 0cf3:e005
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 37.0 C mobo: 33.0 C
Fan Speeds (RPM): cpu: 0
Processes: 151 Uptime: 40m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1333 lib: 338 Shell: Zsh v: 5.8 running in: alacritty
inxi: 3.1.05
From dmesg
[ 17.017716] audit: type=1131 audit(1602081391.045:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="siwar" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'm_permit,pam_time acct="siwar" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'p=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'sg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="siwar" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'=157739] audit: type=1130 audit(1602081398.685:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'95 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="siwar" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'etcred grantors=? acct="siwar" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 52.943534] qtile[963]: segfault at 7f82ca0baca0 ip 00007f82ca0baca0 sp 00007ffdf22ef178 error 14 in libgobject-2.0.so.0.6600.0[7f82ca0fd000+e000]
I searched for it in the arch wiki, but I’m still not sure what this means.
Fabby
7 October 2020 17:56
4
Does this also happen when you create a new user and log in there?
Hi!
I tried doing something different. I enabled auto login and aparently the problem with lightdm and qtile disappeared. My system booted up with correct screen resolution. Here I provide the result of the command sudo journalctl -p 3 -xb
-- Logs begin at Tue 2020-07-28 08:02:21 -05, end at Fri 2020-10-09 19:04:14 -05. --
oct 09 18:58:00 siwar-pc ntpd[852]: bind(21) AF_INET6 fe80::34fb:dafc:9c35:5eca%3#123 flags 0x11 failed: Cannot assign requested address
oct 09 18:58:00 siwar-pc ntpd[852]: unable to create socket on wlp1s0 (5) for fe80::34fb:dafc:9c35:5eca%3#123
Though, I still don’t know if the “solution” is going to be permanent, and also I don’t know what these other problems are about.
