I canβt suspend the machine and apparently ignores my request and asks me to log in again (which I can). But once I log in my external HD is no longer accesible.
Linux LTS 6.6.47-1. Manjaro 24.0.8
Please provide some system information, at the very least. As it stands, you have provided no actionable information for others to help with.
inxi --admin --verbosity=8 --filter --no-host --width
Logs may also be useful;
journalctl --boot=-1 --priority=3 --catalog --no-pager
Kernel: 6.6.47-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=0b905aaa-f47a-433c-9c9b-036e6559c3b4 rw quiet apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: Micro-Star model: A320M PRO-M2 V2 (MS-7B84) v: 2.0
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: 3.10 date: 01/30/2019
System RAM: total: 8 GiB available: 5.74 GiB used: 2.45 GiB (42.8%)
Array-1: capacity: 256 GiB note: check slots: 2 modules: 1 EC: None
max-module-size: 128 GiB note: est.
(unregistered) size: 8 GiB speed: spec: 3200 MT/s actual: 1600 MT/s volts:
note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Crucial part-no: BLS8G4D32AESTK.M8FE1 serial: <filter>
Device-2: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
Topology: cpus: 1x cores: 3 smt: <unsupported> cache: L1: 288 KiB
desc: d-3x32 KiB; i-3x64 KiB L2: 1.5 MiB desc: 3x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1710 high: 2260 min/max: 1600/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1429 2: 2260
3: 1442 bogomips: 21007
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: spec_rstack_overflow mitigation: SMT disabled
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 off: DP-2 empty: DP-1,DVI-D-1 bus-ID: 38:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 41.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: xfwm4 v: 4.18.0 driver: X: loaded: amdgpu
unloaded: modesetting,vesa alternate: fbdev dri: radeonsi gpu: amdgpu
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: DP-2 mapped: DisplayPort-1 note: disabled model: DP2VGA V235
built: 2015 res: N/A dpi: 43 gamma: 1.2 chroma: red: x: 0.639 y: 0.349 green:
x: 0.318 y: 0.627 blue: x: 0.145 y: 0.059 white: x: 0.314 y: 0.329
size: 256x192mm (10.08x7.56") diag: 690mm (27.2") ratio: 16:9
modes: 1024x768, 1920x1080, 1600x1200, 1680x1050, 1400x1050, 1600x900,
1280x1024, 1440x900, 1280x960, 1366x768, 1280x720, 800x600, 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary model: IQ24H
serial: <filter> built: 2020 res: 1920x1080 dpi: 94 gamma: 1.2 chroma: red:
x: 0.651 y: 0.337 green: x: 0.282 y: 0.604 blue: x: 0.141 y: 0.071 white:
x: 0.314 y: 0.329 size: 520x300mm (20.47x11.81") diag: 600mm (23.6")
ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024,
1440x900, 1280x960, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (radeonsi
raven LLVM 18.1.8 DRM 3.54 6.6.47-1-MANJARO) device-ID: 1002:15dd
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 24.1.6-arch1.1
device-ID: 1002:15dd surfaces: xcb,xlib
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 38:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 38:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.47-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br10 state: down mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Info: services: NetworkManager, nginx, systemd-timesyncd
Local Storage: total: 223.58 GiB used: 123.49 GiB (55.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS240G2G0A-00JH30
size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0000 scheme: GPT
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS122 F rev: EL9M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 50 GiB size: 48.16 GiB (96.33%) used: 40.29 GiB (83.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 0b905aaa-f47a-433c-9c9b-036e6559c3b4
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: AED9-11AC
ID-3: /run/media/manjaro/40f6c76a-e547-41b1-b34b-2ea459c9eab4/Data
raw-size: 173.28 GiB size: 169.5 GiB (97.82%) used: 83.2 GiB (49.1%) fs: ext4
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 40f6c76a-e547-41b1-b34b-2ea459c9eab4
ID-1: swap-1 type: file size: 4 GiB used: 211.8 MiB (5.2%) priority: -2
file: /run/media/manjaro/40f6c76a-e547-41b1-b34b-2ea459c9eab4/Data/swapfile
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-5:2 info: SiGma Micro Keyboard TRACER Gamma Ivory
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1c4f:0002 class-ID: 0300
Device-2: 1-6:3 info: Logitech Nano Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Device-3: 1-7:4 info: Super Top Elecom MR-K013 Multicard Reader
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 400mA
chip-ID: 14cd:168a class-ID: 0806 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 39.8 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (rpm): N/A
Packages: 2240 pm: pacman pkgs: 2197 libs: 496 tools: pamac,trizen,yay
pm: flatpak pkgs: 24 pm: snap pkgs: 19
Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
1: https://cdn-mirror.chaotic.cx/$repo/$arch
2: https://geo-mirror.chaotic.cx/$repo/$arch
3: https://br-mirror.chaotic.cx/$repo/$arch
4: https://bg-mirror.chaotic.cx/$repo/$arch
5: https://ca-mirror.chaotic.cx/$repo/$arch
6: https://cl-mirror.chaotic.cx/$repo/$arch
7: https://de-2-mirror.chaotic.cx/$repo/$arch
8: https://de-3-mirror.chaotic.cx/$repo/$arch
9: https://de-4-mirror.chaotic.cx/$repo/$arch
10: https://fr-mirror.chaotic.cx/$repo/$arch
11: https://gr-mirror.chaotic.cx/$repo/$arch
12: https://in-mirror.chaotic.cx/$repo/$arch
13: https://in-2-mirror.chaotic.cx/$repo/$arch
14: https://in-3-mirror.chaotic.cx/$repo/$arch
15: https://in-4-mirror.chaotic.cx/$repo/$arch
16: https://kr-mirror.chaotic.cx/$repo/$arch
17: https://es-mirror.chaotic.cx/$repo/$arch
18: https://es-2-mirror.chaotic.cx/$repo/$arch
19: https://us-mi-mirror.chaotic.cx/$repo/$arch
20: https://us-tx-mirror.chaotic.cx/$repo/$arch
21: https://us-ut-mirror.chaotic.cx/$repo/$arch
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
5: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
6: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
7: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
8: https://mirror.easyname.at/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 243
1: cpu: 11.1% command: librewolf pid: 10080 mem: 498.3 MiB (8.4%)
2: cpu: 4.3% command: bash pid: 11852 mem: 9.68 MiB (0.1%)
3: cpu: 3.7% command: librewolf pid: 10236 mem: 320.8 MiB (5.4%)
4: cpu: 3.5% command: librewolf pid: 10488 mem: 63.8 MiB (1.0%)
5: cpu: 2.8% command: librewolf pid: 10359 mem: 228.9 MiB (3.8%)
Memory top: 5 of 243
1: mem: 498.3 MiB (8.4%) command: librewolf pid: 10080 cpu: 11.1%
2: mem: 320.8 MiB (5.4%) command: librewolf pid: 10236 cpu: 3.7%
3: mem: 228.9 MiB (3.8%) command: librewolf pid: 10359 cpu: 2.8%
4: mem: 220.9 MiB (3.7%) command: librewolf pid: 10302 cpu: 1.5%
5: mem: 167.1 MiB (2.8%) command: Xorg pid: 1279 cpu: 2.7%
Processes: 243 Power: uptime: 1h 38m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 2.28 GiB services: upowerd,xfce4-power-manager Init: systemd v: 256
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.32
running-in: xfce4-terminal inxi: 3.3.35 ´´´
journalctl returns:
ββ Subject: Invalid service file
ββ Defined-By: dbus-broker
ββ Support: https://groups.google.com/forum/#!forum/bus1-devel
ββ
ββ A service file is a ini-type configuration file.
ββ
ββ It has one required section
ββ named [D-BUS Service]. The section contains the required key 'Name', which
ββ must be a valid D-Bus name that is unique across all service files. It also
ββ contains at least one of the two optional keys 'SystemdService' and 'Exec',
ββ as well as optionally the key 'User'. Exec must be a valid shell command and
ββ User must be a valid user on the system.
ββ
ββ A service file should be named after the D-Bus name it configures. That is
ββ a file containing Name=org.foo.bar1 should be named org.foo.bar1.service.
ββ For backwards compatibility, we only warn when files do not follow this
ββ convention when run as a user bus. The system bus considers this an error
ββ and ignores the service file.
sep 05 08:41:46 Manjaro ddcutil[1940]: busno=5, sleep-multiplier = 2.00. Testing for supported feature 0x10 returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: EREMOTEIO(10)]
sep 05 08:41:48 Manjaro ddcutil[2022]: busno=5, sleep-multiplier = 2.00. Testing for supported feature 0x10 returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: EREMOTEIO(10)]
sep 05 08:41:49 Manjaro ddcutil[2029]: busno=5, sleep-multiplier = 2.00. Testing for supported feature 0x10 returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: EREMOTEIO(10)]
sep 05 08:41:51 Manjaro ddcutil[2037]: busno=5, sleep-multiplier = 2.00. Testing for supported feature 0x10 returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: EREMOTEIO(10)]
β¦
Please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit: including the formatting of posts.
Place that wall of text in the previous post within ``` backtick characters as described in the link below, thanks.
Once that is done, others will more easily be able to read it.
Chaotic Aur is by the way most definitely unsupported. Just saying, might not have anything with your issue, but adds an unknown variable.
So should I reinstall all my chaotic aur packages to another repository and slide off AUR support on preferences??
Consider updating your BIOS; it seems rather old. An updated BIOS will fix security concerns, add new features, and may solve many issues with your machine.
Neither the AUR or Chaotic AUR is officially supported by Manjaro (or Arch). Your system is then in an unsupported state; no support can be offered; there are too many possible unknowns.
Simply turning it off now will not achieve anything, as any complication as a result of installing from unsupported sources, already exists.
That said, another member may offer a suggestion or two, but itβs also possible a Moderator might just close the thread.
All I can do is wish you luck. Cheers.
Iβll update the bios, I actually downgraded it years ago because of some overclocking capabilities, I think. But I donβt overclock anymore, so Iβll update.
Thank you, I think I underestimated the effects of how old the BIOS was. Now it suspends like it used to. Good day.
