System doesn't shutdown
Hi everyone, after the last update my system just doesn’t shutdown neither by shutdown -h now neither by the shutdown button.(nvidia rtx4060, laptop)
After that, it just goes to a blank screen only with the mouse and some of the opened windows before. Like, firefox doenst turn off, neither discord or some.
journalctl -b: out 06 17:35:49 ricardo-pc kernel: Linux version 6.10.11-2-MANJARO (builduser@fv-az1154-472) (gcc (GCC) 14.2>
out 06 17:35:49 ricardo-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64 root=UUID=09d9c228-506>
out 06 17:35:49 ricardo-pc kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks >
out 06 17:35:49 ricardo-pc kernel: BIOS-provided physical RAM map:
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x0000000000100000-0x000000003d198fff] usable
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x000000003d199000-0x000000003da98fff] reserved
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x000000003da99000-0x000000003f8aefff] usable
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x000000003f8af000-0x000000004194efff] reserved
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x000000004194f000-0x00000000448fefff] ACPI NVS
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x00000000448ff000-0x0000000044afefff] ACPI data
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x0000000044aff000-0x0000000044afffff] usable
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x0000000044b00000-0x00000000493fffff] reserved
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x000000004a000000-0x00000000503fffff] reserved
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
out 06 17:35:49 ricardo-pc kernel: BIOS-e820: [mem 0x0000000100000000-0x00000008afbfffff] usable
out 06 17:35:49 ricardo-pc kernel: NX (Execute Disable) protection: active
out 06 17:35:49 ricardo-pc kernel: APIC: Static calls initialized
out 06 17:35:49 ricardo-pc kernel: e820: update [mem 0x38cb2018-0x38cd6c57] usable ==> usable
out 06 17:35:49 ricardo-pc kernel: extended physical RAM map:
out 06 17:35:49 ricardo-pc kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000009efff] usable
out 06 17:35:49 ricardo-pc kernel: reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
out 06 17:35:49 ricardo-pc kernel: reserve setup_data: [mem 0x0000000000100000-0x0000000038cb2017] usable
This is a KDE bug:
It worked, thanks!
Im glad i could help.
Always look at the second post from stable update… few days after release the community showed Bugfix/Workarounds and/or maintains tipps for a long and good running System.
Im also recommend Timeshift on a external HDD for a additional safety net.
