Hi,
my system update only the aur packages via pamac, but package from other repositories remains blocked to version of first installation.
How to solve?
pacman -Qii | grep -c "Data di installazione :"
1389
pacman -Qii | grep -c "Data di installazione : dom 12 feb 2023"
1163
I try also to doing:
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman-key --refresh-keys
sudo pacman -S archlinux-keyring manjaro-keyring
sudo pacman-mirrors --country all && sudo pacman -Syyu
Pamac repos:
ls -las /var/tmp/pamac/dbs/sync
totale 57272
0 drwxr-xr-x 1 root root 176 20 mar 19.15 .
0 drwxr-xr-x 1 root root 18 20 mar 19.15 ..
7760 -rw-r--r-- 1 root root 7943230 20 mar 15.34 community.db
35644 -rw-r--r-- 1 root root 36496103 20 mar 15.34 community.files
164 -rw-r--r-- 1 root root 167457 18 mar 19.18 core.db
1600 -rw-r--r-- 1 root root 1636292 18 mar 19.18 core.files
1860 -rw-r--r-- 1 root root 1902753 18 mar 19.18 extra.db
9816 -rw-r--r-- 1 root root 10049648 18 mar 19.18 extra.files
172 -rw-r--r-- 1 root root 174667 20 feb 05.29 multilib.db
256 -rw-r--r-- 1 root root 260039 20 feb 05.29 multilib.files
Pacman repos:
ls -las /var/lib/pacman/sync ✔
totale 57272
