It’s been a while my Wi-Fi is unstable here. Sometimes it suddenly disconnects and I have to restart my laptop. Sometimes even several reboots needed. I am on dual boot with windows 10 which i barely login.
Below is the output of inxi --admin --verbosity=7 --filter --no-host
System: Kernel: 5.4.138-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=eada4dbf-15a3-4e90-9370-d2c84d1e7924 rw
quiet udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <filter> UEFI: American Megatrends v: FX505DT.316
date: 01/28/2021
Battery: ID-1: BAT0 charge: 36.9 Wh (91.3%) condition: 40.4/48.1 Wh (84.1%) volts: 11.9 min: 11.7
model: FX50442 type: Li-ion serial: N/A status: Discharging
Memory: RAM: total: 7.65 GiB used: 1.03 GiB (13.4%)
CPU: Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102 cache: L2: 2 MiB bogomips: 33550
Speed: 1282 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1282 2: 1340 3: 1350
4: 1377 5: 1221 6: 1199 7: 1255 8: 1750
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush
clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold
pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
loaded: amdgpu,ati,modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.35.0 5.4.138-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10fa
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.4.138-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave driver: rtw_pci
v: N/A modules: rtwpci port: d000 bus-ID: 04:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 476.94 GiB used: 11.47 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 002C
scheme: GPT
Partition: ID-1: / raw-size: 80 GiB size: 78.19 GiB (97.74%) used: 9.26 GiB (11.8%) fs: ext4 dev: /dev/nvme0n1p7
maj-min: 259:7 label: N/A uuid: eada4dbf-15a3-4e90-9370-d2c84d1e7924
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 819 KiB (0.3%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: 2508-5075
ID-3: /home raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 2.21 GiB (1.1%) fs: ext4
dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A uuid: 834bd7e9-2d96-41c0-9cd6-0e541001429c
Swap: Alert: No swap data was found.
Unmounted: ID-1: /dev/nvme0n1p10 maj-min: 259:9 size: 850 MiB fs: ntfs label: RECOVERY uuid: D46EBA986EBA733A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 450 MiB fs: ntfs label: Recovery uuid: 58589D35589D133C
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 100 MiB fs: vfat label: N/A uuid: 34A0-FA79
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 83.5 GiB fs: ntfs label: N/A uuid: B8E8273BE826F6F2
ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 111.79 GiB fs: ntfs label: Local Disk
uuid: E88E0EDC8E0EA2E4
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Device-1: 1-4:2 info: IMC Networks Bluetooth Radio type: Bluetooth driver: btusb interfaces: 2
rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Device-1: 3-1:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
Sensors: System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2900
GPU: device: amdgpu temp: 53.0 C device: nouveau temp: 42.0 C
Info: Processes: 233 Uptime: 0m wakeups: 1 Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0
Packages: pacman: 1105 lib: 290 Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.06
