Its been quite a while since i am facing this problem
The problem is, many times system doesnt detect after boot, that if there are earphones (with mic) connected or not. Right now, while posting this i am seeing this at audio settings, but after first boot; its only the upper section without “Recording Devices” section. Although even at that time, earphones speakers do work but not microphone.
And to solve this, I always have to re-plug in earphones, to make this recording section appear; and even with this… some times the current recording device is “Internal microphone” even after i plugged in an earphone. So i have to manually switch it.
Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=86a1b92a-6bb4-40b0-86bc-db4bbe9b12f7 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QM_FA506QM
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FA506QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: FA506QM.314 date: 01/07/2023
ID-1: BAT1 charge: 85.7 Wh (98.4%) condition: 87.1/90.2 Wh (96.5%)
volts: 16.1 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1542 high: 3200 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1281 2: 1257
3: 1336 4: 1915 5: 1200 6: 3200 7: 1460 8: 1200 9: 1200 10: 1915 11: 1481
12: 1200 13: 1916 14: 1721 15: 1200 16: 1200 bogomips: 102255
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 51.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 322e:202c
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2022 res: 1920x1080
hz: 144 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 mapped: eDP pos: right model: Najing CEC Panda 0x004d
built: 2019 res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.44-1-MANJARO) direct-render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.77 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: br-4af5c28dd7d9 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 13d3:3563
Local Storage: total: 2.29 TiB used: 149.38 GiB (6.4%)
model: MZVLQ512HBLU-00B00 size: 476.94 GiB block-size: physical: 512 B
fw-rev: FXM7201Q temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: INIC-3609
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 0217
scheme: GPT
ID-1: / raw-size: 120 GiB size: 117.56 GiB (97.97%) used: 62.39 GiB (53.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 29.5 MiB (5.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 150 GiB size: 146.59 GiB (97.72%)
used: 86.95 GiB (59.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 63.8 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (rpm): cpu: 0
Processes: 410 Uptime: 4h 49m wakeups: 7 Memory: total: 16 GiB note: est.
available: 15.03 GiB used: 11.46 GiB (76.2%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1735 libs: 479 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.29
I recall when i was on a older manjaro version, i didnt had this problem, not my current windows setup has this problem, it automatically switches to earphones for default output and earphones’s mic for default input.
