I am using Manjaro kde and during last update my system crashed.
After restart I couldnt load mabjaro again.
Tried different kernels and nothing helps.
Hi!!
try this
boot on usb iso manjaro
open a terminal
sudo manjaro-chroot -a ( type 1 if only one line 0 appears )
sudo pacman -Syyu
sudo mkinitcpio -P
exit ( quit chroot )
then reboot
I would add to check that there is a kernel before exiting chroot:
mhwd-kernel -li
If not, install one with
mhwd-kernel -i linux54
(You can select other kernel of your choice)
In any case, I would also run update-grub
