Hello, lately I have been having a problem of system constantly hanging up and freezing(from few seconds hang up to freeze that could take over a minute). They are happening very oftenly like 2-3 times in a minute. System is barely useable. The freezes are most common and long when switching from one program to another or performing any other IO heavy task such as installing or updating packages though they constantly happen even while just browsing regularly. During the hang up I ussualy can still move mouse and for example if there are gifs on web page they are still moving not frozen, however it does not respond to mouse clicks or keyboard input untill the hang up passes. Sometimes it freezes completely for a minute or longer when even mouse is frozen. Strangely though I don’t seem to have such freezing problems while playing games(untill I try to switch to any other window).
I recently had a full system update with pacman -Syu I suspect it could have triggered it.
Things I have already tried:
Trying out different kernel versions: linux-zen-6.14.2, linux-zen-6.15.2, linux-6.15.6, linux-6.12.37 did not help.
Running btrfs scrub to look for disk errors. Did not help, no errors found.
Checking out cpu temperature. No overheating.
Checking out if there are any processes that could be consuming unreasonable amount of system usage, no such proceses found.
Setting fstab btrfs options to rw,defaults. Did not help.
I am sending my system information.
inxi -zv8
Kernel: 6.14.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-zen
root=UUID=200ba4ca-a488-49c8-a573-614cfa968825 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.15.0
wm: kwin_wayland tools: avail: budgie-screensaver,lxlock vt: 1 dm: SDDM
Type: Desktop System: Dell product: Precision T5600 v: 01 serial: <filter>
Chassis: type: 7 serial: <filter>
Mobo: Dell model: 0Y56T3 v: A00 serial: <filter>
uuid: 4c4c4544-0036-3710-8035-cac04f365831 BIOS: Dell v: A19
date: 06/30/2019
System RAM: total: 16 GiB available: 15.54 GiB used: 8.13 GiB (52.3%)
Array-1: capacity: 128 GiB slots: 8 modules: 4 EC: Multi-bit ECC
Device-1: DIMM1_CPU1 type: DDR3 detail: registered (buffered) size: 4 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 72
manufacturer: Micron-002C part-no: 18KSF51272PZ-1G4D1 serial: <filter>
Device-2: DIMM3_CPU1 type: DDR3 detail: registered (buffered) size: 4 GiB
Device-3: DIMM2_CPU1 type: DDR3 detail: registered (buffered) size: 4 GiB
manufacturer: Toshiba-0098 part-no: 9965426-087.A00LF serial: <filter>
Device-4: DIMM4_CPU1 type: DDR3 detail: registered (buffered) size: 4 GiB
Device-5: DIMM1_CPU2 type: no module installed
Device-6: DIMM3_CPU2 type: no module installed
Device-7: DIMM2_CPU2 type: no module installed
Device-8: DIMM4_CPU2 type: no module installed
Slot: 1 type: PCIe gen: 2 status: available length: long volts: 3.3
bus-ID: ff:1f.7
Slot: 2 type: PCIe gen: 2 status: in use length: short volts: 3.3
bus-ID: 03:00.0
Slot: 3 type: PCIe gen: 2 status: available length: long volts: 3.3
bus-ID: ff:1f.7
Slot: 4 type: PCIe gen: 2 status: available length: long volts: 3.3
bus-ID: ff:1f.7
Slot: 5 type: PCIe gen: 2 status: in use length: short volts: 3.3
bus-ID: 08:00.0
Slot: 6 type: PCI status: available length: long volts: 3.3
bus-ID: ff:1f.7
Info: model: Intel Xeon E5-2620 0 socket: LGA2011 bits: 64 type: MT MCP SMP
arch: Sandy Bridge level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2D (45) stepping: 7 microcode: 0x71A
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 2x 384 KiB (768 KiB) desc: d-6x32 KiB; i-6x32 KiB
L2: 2x 1.5 MiB (3 MiB) desc: 6x256 KiB L3: 2x 15 MiB (30 MiB)
desc: 1x15 MiB
Speed (MHz): avg: 1383 min/max: 1200/2500 base/boost: 2000/4000 scaling:
driver: intel_cpufreq governor: schedutil volts: 0.2 V ext-clock: 100 MHz
cores: 1: 1383 2: 1383 3: 1383 4: 1383 5: 1383 6: 1383 7: 1383 8: 1383
9: 1383 10: 1383 11: 1383 12: 1383 bogomips: 47887
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdtscp
rep_good sep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:67df
class-ID: 0300 temp: 65.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: BenQ EX3410R serial: <filter> built: 2022 res:
mode: 3440x1440 hz: 144 scale: 114% (1.15) to: 2991x1252 dpi: 110 gamma: 1.2
chroma: red: x: 0.675 y: 0.310 green: x: 0.278 y: 0.651 blue: x: 0.153
y: 0.071 white: x: 0.314 y: 0.329 size: 797x334mm (31.38x13.15")
diag: 864mm (34") modes: 3440x1440, 3840x2160, 2560x1440, 2560x1080,
1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024,
1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 90 2: parse_edid:
unhandled CEA mode 91 3: parse_edid: unhandled CEA mode 92 4: parse_edid:
unhandled CEA mode 93 5: parse_edid: unhandled CEA mode 94 6: parse_edid:
unhandled CEA mode 95 7: parse_edid: unhandled CEA mode 96 8: parse_edid:
unhandled CEA mode 97 9: parse_edid: unknown tag 112
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
polaris10 ACO DRM 3.61 6.14.2-zen1-1-zen) device-ID: 1002:67df
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 2 device: 0 type: discrete-gpu name: AMD
Radeon RX 570 Series (RADV POLARIS10) driver: mesa radv v: 25.1.5-arch1.1
device-ID: 1002:67df surfaces: N/A
Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,
kscreen-doctor, xfce4-display-settings gpu: lact wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel C600/X79 series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
RX 470/480 / 570/580/590] vendor: ASUSTeK driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 03:00.1 chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.14.2-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
IF-ID-1: ztyxaxzvq6 state: unknown speed: 10000 Mbps duplex: full
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
Hardware-1: Broadcom / LSI MegaRAID SAS 2008 [Falcon] driver: megaraid_sas
v: 07.727.03.00-rc1 port: c000 bus-ID: 08:00.0 chip-ID: 1000:0073 rev: N/A
class-ID: 0104
Local Storage: total: 4.56 TiB used: 354.27 GiB (7.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000AAKX-75U6AA0 family: Blue (CMR) size: 465.76 GiB block-size:
physical: 512 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: N/A
serial: <filter> fw-rev: 1H19 temp: 37 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 6y 232d 14h cycles: 4175
read: 17.43 TiB written: 14.42 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU750 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1R29 temp: 54 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 346d 18h cycles: 3959
read: 1.01 GiB written: 386.7 MiB
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40EZRX-00SPEB0 family: Green size: 3.64 TiB block-size:
physical: 4096 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1
mode: 2.0 sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1050 drive-rev: 80.00A80 temp: 43 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 40d 8h cycles: 968 Pre-Fail:
reallocated sector: 189 threshold: 140
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DS-8A8SH rev: KD12
dev-links: cdrom
Features: speed: 62 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 381.66 GiB size: 381.66 GiB (100.00%)
used: 354.27 GiB (92.8%) fs: btrfs block-size: 4096 B dev: /dev/sdb4
maj-min: 8:20 label: Manjaro uuid: 200ba4ca-a488-49c8-a573-614cfa968825
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: zram size: 15.54 GiB used: 229.4 MiB (1.4%)
priority: 100 comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842
max-streams: 12 dev: /dev/zram0
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System Reserved
uuid: 5694A40594A3E5A9
ID-2: /dev/sda2 maj-min: 8:2 size: 465.66 GiB fs: ntfs label: N/A
uuid: 0402A66302A65A06
ID-3: /dev/sdb1 maj-min: 8:17 size: 499 MiB fs: ntfs
label: System Reserved uuid: 1C20DC1220DBF0AE
ID-4: /dev/sdb2 maj-min: 8:18 size: 90.02 GiB fs: ntfs label: Windows
uuid: 5890DCBB90DCA0B4
ID-5: /dev/sdb3 maj-min: 8:19 size: 4.77 GiB fs: ntfs label: Recovery
uuid: C274DD6374DD5AAD
ID-6: /dev/sdc1 maj-min: 8:33 size: 199.34 GiB fs: ext4 label: N/A
uuid: b58fff14-aa79-485e-bb8f-acb6ba3f3277
ID-7: /dev/sdc2 maj-min: 8:34 size: 986.94 GiB fs: ntfs label: N/A
uuid: 078C050E6949AFCD
ID-8: /dev/sdc3 maj-min: 8:35 size: 2.48 TiB fs: btrfs label: N/A
uuid: ab5e5e73-3fe3-460b-aca7-3f7cdcb2bc74
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-2: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 2-1.2:3 info: Western Digital My Book (WDBFJK)
type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 26mA
chip-ID: 1058:1230 class-ID: 0806 serial: <filter>
Device-2: 2-1.3:4 info: USB OPTICAL MOUSE type: mouse,keyboard
chip-ID: 4e53:5407 class-ID: 0301
Hub-4: 3-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-5: 4-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
System Temperatures: cpu: 57.0 C mobo: 28.0 C sodimm: 38.0 C gpu: amdgpu
temp: 65.0 C
Fan Speeds (rpm): cpu: 1014 gpu: amdgpu fan: 1224
Packages: 1677 pm: pacman pkgs: 1665 libs: 496 tools: pamac pm: flatpak
pkgs: 12
Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
1: https://cdn-mirror.chaotic.cx/$repo/$arch
2: https://geo-mirror.chaotic.cx/$repo/$arch
3: https://br-mirror.chaotic.cx/$repo/$arch
4: https://bg-mirror.chaotic.cx/$repo/$arch
5: https://ca-mirror.chaotic.cx/$repo/$arch
6: https://cl-mirror.chaotic.cx/$repo/$arch
7: https://de-2-mirror.chaotic.cx/$repo/$arch
8: https://de-3-mirror.chaotic.cx/$repo/$arch
9: https://de-4-mirror.chaotic.cx/$repo/$arch
10: https://fr-mirror.chaotic.cx/$repo/$arch
11: https://gr-mirror.chaotic.cx/$repo/$arch
12: https://in-mirror.chaotic.cx/$repo/$arch
13: https://in-2-mirror.chaotic.cx/$repo/$arch
14: https://in-3-mirror.chaotic.cx/$repo/$arch
15: https://in-4-mirror.chaotic.cx/$repo/$arch
16: https://kr-mirror.chaotic.cx/$repo/$arch
17: https://es-mirror.chaotic.cx/$repo/$arch
18: https://es-2-mirror.chaotic.cx/$repo/$arch
19: https://us-mi-mirror.chaotic.cx/$repo/$arch
20: https://us-tx-mirror.chaotic.cx/$repo/$arch
21: https://us-ut-mirror.chaotic.cx/$repo/$arch
1: https://mirror.init7.net/manjaro/stable/$repo/$arch
2: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
3: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
4: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
5: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
6: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
7: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 345
1: cpu: 25.8% command: baloo_file_extractor pid: 1310
mem: 1024.7 MiB (6.4%)
2: cpu: 9.8% command: brave pid: 3096 mem: 308.6 MiB (1.9%)
3: cpu: 7.7% command: exe pid: 1670 mem: 372.4 MiB (2.3%)
4: cpu: 5.3% command: brave pid: 1848 mem: 218.1 MiB (1.3%)
5: cpu: 3.3% command: kwin_wayland pid: 790 mem: 318.0 MiB (1.9%)
Memory top: 5 of 345
1: mem: 1024.7 MiB (6.4%) command: baloo_file_extractor pid: 1310
cpu: 25.8%
2: mem: 483.6 MiB (3.0%) command: brave pid: 1763 cpu: 3.1%
3: mem: 474.9 MiB (2.9%) command: plasmashell pid: 1112 cpu: 0.9%
4: mem: 372.4 MiB (2.3%) command: exe pid: 1670 cpu: 7.7%
5: mem: 318.0 MiB (1.9%) command: kwin_wayland pid: 790 cpu: 3.3%
Processes: 345 Power: uptime: 52m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 6.19 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Compilers: clang: 20.1.7 gcc: 15.1.1 alt: 14 Shell: Bash (su) v: 5.2.37
running-in: konsole inxi: 3.3.38
