Despite a bunch of searching and following various leads I’ve been unable to get suspend working on my laptop like it used to some months ago.
Here’s the default system info request:
inxi --full --admin --filter --width        ✔
  Kernel: 6.8.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.8-x86_64
    root=UUID=6c741ddc-adf1-4f76-a514-30f51d2ae500 rw rootflags=subvol=@
    nvidia_drm.modeset=1 quiet splash apparmor=1 security=apparmor
    udev.log_priority=3
  Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QM_TUF506QM
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: FA506QM v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: FA506QM.314
    date: 01/07/2023
  ID-1: BAT1 charge: 53.5 Wh (67.4%) condition: 79.4/90.2 Wh (88.0%)
    volts: 15.8 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: not charging
  Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1164 high: 2895 min/max: 400/4463 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2231 2: 400 3: 1737
    4: 2649 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 2894
    14: 2895 15: 2222 16: 400 bogomips: 102241
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    off: DP-1 empty: none bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 off: eDP-1
    empty: none bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 51.0 C
  Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 322e:202c
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: DP-1 model: AOC Q27G2G4 serial: <filter> built: 2020
    res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 640x480
  Monitor-2: HDMI-A-1 model: Sony TV serial: <filter> built: 2010
    res: 1920x1080 dpi: 30 gamma: 1.2 size: 1600x900mm (62.99x35.43")
    diag: 1836mm (72.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Monitor-3: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 16.0.6 DRM 3.57 6.8.5-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: no display-ID: :0.0
  API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Laptop GPU driver: nvidia v: 550.67 device-ID: 10de:2520
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD Radeon
    Graphics (RADV RENOIR) driver: mesa radv v: 24.0.2-manjaro1.1
    device-ID: 1002:1638 surfaces: xcb,xlib,wayland
  Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e
    class-ID: 0403
  Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.8.5-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.3 status: off tools: pw-cli
  Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 13d3:3563
  Local Storage: total: 3.19 TiB used: 1.69 TiB (53.0%)
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung model: MZVLQ512HBLU-00B00
    lanes: 4 tech: SSD serial: <filter> fw-rev: FXM7201Q temp: 33.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EAVS-00D7B1
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 1.75 scheme: MBR
  ID-1: / raw-size: 453.69 GiB size: 453.69 GiB (100.00%)
    used: 99.81 GiB (22.0%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:9
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 28.6 MiB (11.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:7
  ID-3: /home raw-size: 453.69 GiB size: 453.69 GiB (100.00%)
  ID-4: /var/log raw-size: 453.69 GiB size: 453.69 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 64.1 C mobo: 38.0 C gpu: amdgpu temp: 51.0 C
  Fan Speeds (rpm): cpu: 0
  Memory: total: 16 GiB note: est. available: 15.03 GiB used: 6.59 GiB (43.8%)
  Processes: 467 Power: uptime: 4h 11m states: freeze,mem,disk
    suspend: s2idle wakeups: 5 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 5.96 GiB services: gsd-power,
    tool: systemctl
  Packages: 1728 pm: pacman pkgs: 1691 libs: 532 tools: gnome-software,pamac
    pm: flatpak pkgs: 37 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.33
And below is a dmesg where ‘suspend’ appears. You can see a couple sample attempts at suspend @ times 255 and 573.
sudo dmesg | grep suspend
[    0.316981] Low-power S0 idle used by default for system suspend
[    2.909741] nvme 0000:04:00.0: platform quirk: setting simple suspend
[    2.909745] nvme 0000:05:00.0: platform quirk: setting simple suspend
[  255.529080] PM: suspend entry (s2idle)
[  255.653479] printk: Suspending console(s) (use no_console_suspend to debug)
[  255.668234] queueing ieee80211 work while going to suspend
[  258.817967] PM: suspend exit
[  572.930307] PM: suspend entry (s2idle)
[  573.052969] printk: Suspending console(s) (use no_console_suspend to debug)
[  573.062257] queueing ieee80211 work while going to suspend
[  576.838544] PM: suspend exit
Is there any other info/log that would be helpful?
And this is the latest lead I’ve been following (the others have been weeks/months ago so I don’t have them in front of me):
cat /proc/acpi/wakeup        ✔
Device	S-state	  Status   Sysfs node
GPP0	  S4	*enabled pci:0000:00:01.1
GPP1	  S4	*disabled
GP17	  S4	*enabled  pci:0000:00:08.1
Some people had seen success suspending after setting any enabled status to disabled. I had to the two there but changing them to disabled did not help.
