So I installed Manjaro maybe about 4 days ago, and now I have this “bug” (I don’t know what to call it) which shuts down my system without warning. More specifically, I was in the middle of a game then everything froze for a couple seconds, both my monitors went black (but I could still see and move my cursor), then it just shut down. It happened twice today, and I have no clue what’s happening. I’m on KDE if that helps.
could be you run out of ram, or everheating?
post formatted output from:
inxi -Faz
journalctl -b0 -p4 --no-pager
Hello @rimz ![]()
Is it possible that you reach the end of the RAM and have no swap?
Also what @brahma says…
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=f263950e-f23e-43c4-8d92-d92e0fd4e842 rw quiet
resume=UUID=505e90f2-5853-4c7a-84ac-e356ad15e4d2 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 82K1 v: IdeaPad Gaming 3 15IHU6
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IHU6
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: H4CN22WW(V1.07)
date: 11/18/2021
ID-1: BAT1 charge: 24.7 Wh (56.8%) condition: 43.5/45.0 Wh (96.6%)
volts: 11.6 min: 11.5 model: Sunwoda L20D3PC2 type: Li-ion serial: <filter>
status: N/A
Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3056 high: 3937 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 3756 2: 2511 3: 3404
4: 3937 5: 3358 6: 3652 7: 2386 8: 1446 bogomips: 52856
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 bus-ID: 0000:01:00.0 chip-ID: 10de:25a2
class-ID: 0302
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 5986:212b class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right model: Sceptre M27
serial: <filter> built: 2020 res: 1920x1080 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0xd1ed built: 2019
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0
bus-ID: 1-10:7 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 1.37 TiB used: 21.03 GiB (1.5%)
model: MZALQ256HBJD-00BL2 size: 238.47 GiB block-size: physical: 512 B
rev: 5L2QFXM7 temp: 25.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 2E scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 232.97 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 223.87 GiB size: 219.3 GiB (97.96%) used: 21.03 GiB
(9.6%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 30.0 C mobo: N/A
Processes: 263 Uptime: 4m wakeups: 1 Memory: 7.55 GiB used: 2.06 GiB
(27.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1280 lib: 351
flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Aug 20 01:58:31 ethan-manjaro kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Aug 20 01:58:31 ethan-manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Aug 20 01:58:31 ethan-manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C0.TPD0], AE_NOT_FOUND (20210730/dswload2-162)
Aug 20 01:58:31 ethan-manjaro kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
Aug 20 01:58:31 ethan-manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.I2C0.TPL1], AE_NOT_FOUND (20210730/dswload2-162)
Aug 20 01:58:31 ethan-manjaro kernel: pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Aug 20 01:58:31 ethan-manjaro kernel: hpet_acpi_add: no address or irqs in _CRS
Aug 20 01:58:31 ethan-manjaro kernel: pci 10000:e0:06.0: Primary bus is hard wired to 0
Aug 20 01:58:31 ethan-manjaro kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT D
Aug 20 01:58:31 ethan-manjaro kernel: pcieport 10000:e0:06.0: PCI INT D: no GSI
Aug 20 01:58:31 ethan-manjaro kernel: ahci 10000:e0:17.0: can't derive routing for PCI INT A
Aug 20 01:58:31 ethan-manjaro kernel: ahci 10000:e0:17.0: PCI INT A: no GSI
Aug 20 01:58:31 ethan-manjaro kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Aug 20 01:58:31 ethan-manjaro kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT A
Aug 20 01:58:31 ethan-manjaro kernel: nvme 10000:e1:00.0: PCI INT A: not connected
Aug 20 01:58:31 ethan-manjaro kernel: vboxdrv: loading out-of-tree module taints kernel.
Aug 20 01:58:31 ethan-manjaro kernel: VBoxNetAdp: Successfully started.
Aug 20 01:58:31 ethan-manjaro kernel: VBoxNetFlt: Successfully started.
Aug 20 01:58:31 ethan-manjaro systemd-journald[298]: File /var/log/journal/fd9894d25a114accbc6712a9b9cc7d4c/system.journal corrupted or uncleanly shut down, renaming and replacing.
Aug 20 01:58:31 ethan-manjaro kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 20 01:58:31 ethan-manjaro kernel: wmi_bus wmi_bus-PNP0C14:02: WQAE data block query control method not found
Aug 20 01:58:31 ethan-manjaro kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 20 01:58:31 ethan-manjaro kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 20 01:58:31 ethan-manjaro kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 20 01:58:32 ethan-manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Aug 20 01:58:32 ethan-manjaro kernel: Disabling lock debugging due to kernel taint
Aug 20 01:58:32 ethan-manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
Aug 20 01:58:32 ethan-manjaro kernel: ------------[ cut here ]------------
Aug 20 01:58:32 ethan-manjaro kernel: i915 0000:00:02.0: drm_WARN_ON(val == 0xffffffff)
Aug 20 01:58:32 ethan-manjaro kernel: WARNING: CPU: 2 PID: 309 at drivers/gpu/drm/i915/display/intel_tc.c:762 intel_tc_port_init+0x1e7/0x1f0 [i915]
Aug 20 01:58:32 ethan-manjaro kernel: Modules linked in: snd pcspkr pcc_cpufreq(-) btusb(+) i2c_i801 mdio_devres btrtl mtd libphy soundcore nvidia_modeset(POE) i2c_smbus mc cfg80211 i915(+) btbcm processor_thermal_device_pci_legacy intel_lpss_pci mei_me btintel processor_thermal_device intel_lpss mei idma64 bluetooth processor_thermal_rfim processor_thermal_mbox vfat processor_thermal_rapl ecdh_generic nvidia(POE) fat joydev mousedev intel_rapl_common ttm intel_pmt intel_gtt igen6_edac intel_soc_dts_iosf mac_hid i2c_hid_acpi i2c_hid ideapad_laptop platform_profile rfkill wmi video tpm_crb tpm_tis int3400_thermal intel_hid tpm_tis_core acpi_thermal_rel int3403_thermal tpm int340x_thermal_zone sparse_keymap rng_core acpi_pad vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 uas usb_storage usbhid serio_raw atkbd libps2 i8042 crc32c_intel xhci_pci vmd serio
Aug 20 01:58:32 ethan-manjaro kernel: CPU: 2 PID: 309 Comm: systemd-udevd Tainted: P OE 5.15.60-1-MANJARO #1 cb6dece7f351a33c0ac9650a5b516aad0722dc40
Aug 20 01:58:32 ethan-manjaro kernel: Hardware name: LENOVO 82K1/LNVNB161216, BIOS H4CN22WW(V1.07) 11/18/2021
Aug 20 01:58:32 ethan-manjaro kernel: RIP: 0010:intel_tc_port_init+0x1e7/0x1f0 [i915]
Aug 20 01:58:32 ethan-manjaro kernel: Code: 4c 8b 67 50 4d 85 e4 75 03 4c 8b 27 e8 42 4d 4d d7 48 c7 c1 80 f8 3b c3 4c 89 e2 48 c7 c7 f2 e2 3d c3 48 89 c6 e8 36 c4 8c d7 <0f> 0b e9 3f ff ff ff 66 90 0f 1f 44 00 00 48 8b 17 80 ba c3 06 00
Aug 20 01:58:32 ethan-manjaro kernel: RSP: 0018:ffffad5401dff7f8 EFLAGS: 00010246
Aug 20 01:58:32 ethan-manjaro kernel: RAX: 0000000000000000 RBX: ffff9f63d7b86000 RCX: 0000000000000000
Aug 20 01:58:32 ethan-manjaro kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
Aug 20 01:58:32 ethan-manjaro kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
Aug 20 01:58:32 ethan-manjaro kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f63c188d940
Aug 20 01:58:32 ethan-manjaro kernel: R13: ffff9f63d7b86fa8 R14: 00000000ffffffff R15: 00000000ffffffff
Aug 20 01:58:32 ethan-manjaro kernel: FS: 00007fcd4d37e4c0(0000) GS:ffff9f6567a80000(0000) knlGS:0000000000000000
Aug 20 01:58:32 ethan-manjaro kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug 20 01:58:32 ethan-manjaro kernel: CR2: 000055ca6cbda268 CR3: 000000010bd60001 CR4: 0000000000770ee0
Aug 20 01:58:32 ethan-manjaro kernel: PKRU: 55555554
Aug 20 01:58:32 ethan-manjaro kernel: Call Trace:
Aug 20 01:58:32 ethan-manjaro kernel: <TASK>
Aug 20 01:58:32 ethan-manjaro kernel: intel_ddi_init+0x6fc/0xbb0 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: intel_modeset_init_nogem+0xc1a/0x1500 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: ? gen12_fwtable_read32+0x94/0x200 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: i915_driver_probe+0x4f6/0xcc0 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: i915_pci_probe+0x52/0x150 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: local_pci_probe+0x3e/0x80
Aug 20 01:58:32 ethan-manjaro kernel: pci_device_probe+0xff/0x1b0
Aug 20 01:58:32 ethan-manjaro kernel: really_probe+0x201/0x3f0
Aug 20 01:58:32 ethan-manjaro kernel: __driver_probe_device+0x113/0x190
Aug 20 01:58:32 ethan-manjaro kernel: driver_probe_device+0x1f/0xa0
Aug 20 01:58:32 ethan-manjaro kernel: __driver_attach+0xc6/0x1a0
Aug 20 01:58:32 ethan-manjaro kernel: ? __device_attach_driver+0xf0/0xf0
Aug 20 01:58:32 ethan-manjaro kernel: bus_for_each_dev+0x84/0xd0
Aug 20 01:58:32 ethan-manjaro kernel: bus_add_driver+0x149/0x210
Aug 20 01:58:32 ethan-manjaro kernel: driver_register+0x89/0xf0
Aug 20 01:58:32 ethan-manjaro kernel: i915_init+0x1f/0x96 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: ? 0xffffffffc2e64000
Aug 20 01:58:32 ethan-manjaro kernel: do_one_initcall+0x56/0x220
Aug 20 01:58:32 ethan-manjaro kernel: do_init_module+0x4a/0x250
Aug 20 01:58:32 ethan-manjaro kernel: load_module+0x273b/0x2800
Aug 20 01:58:32 ethan-manjaro kernel: ? __do_sys_init_module+0x138/0x1c0
Aug 20 01:58:32 ethan-manjaro kernel: __do_sys_init_module+0x138/0x1c0
Aug 20 01:58:32 ethan-manjaro kernel: do_syscall_64+0x58/0x90
Aug 20 01:58:32 ethan-manjaro kernel: ? handle_mm_fault+0xd1/0x2c0
Aug 20 01:58:32 ethan-manjaro kernel: ? do_user_addr_fault+0x1e5/0x6a0
Aug 20 01:58:32 ethan-manjaro kernel: ? exc_page_fault+0x71/0x180
Aug 20 01:58:32 ethan-manjaro kernel: entry_SYSCALL_64_after_hwframe+0x61/0xcb
Aug 20 01:58:32 ethan-manjaro kernel: RIP: 0033:0x7fcd4dd1aace
Aug 20 01:58:32 ethan-manjaro kernel: Code: 48 8b 0d d5 f2 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d a2 f2 0c 00 f7 d8 64 89 01 48
Aug 20 01:58:32 ethan-manjaro kernel: RSP: 002b:00007ffded421d58 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
Aug 20 01:58:32 ethan-manjaro kernel: RAX: ffffffffffffffda RBX: 000055727c880eb0 RCX: 00007fcd4dd1aace
Aug 20 01:58:32 ethan-manjaro kernel: RDX: 00007fcd4de66343 RSI: 00000000006b3bbf RDI: 00007fcd4bc68010
Aug 20 01:58:32 ethan-manjaro kernel: RBP: 00007fcd4de66343 R08: 000055727c79dbd0 R09: 0000000000000000
Aug 20 01:58:32 ethan-manjaro kernel: R10: 0000000000000005 R11: 0000000000000246 R12: 0000000000020000
Aug 20 01:58:32 ethan-manjaro kernel: R13: 000055727c7993a0 R14: 000055727c880eb0 R15: 000055727c88a010
Aug 20 01:58:32 ethan-manjaro kernel: </TASK>
Aug 20 01:58:32 ethan-manjaro kernel: ---[ end trace d463a99b9ab56213 ]---
Aug 20 01:58:32 ethan-manjaro kernel: CPU: 2 PID: 309 Comm: systemd-udevd Tainted: P W OE 5.15.60-1-MANJARO #1 cb6dece7f351a33c0ac9650a5b516aad0722dc40
Aug 20 01:58:32 ethan-manjaro kernel: RAX: 0000000000000000 RBX: ffff9f63cf9ec000 RCX: 0000000000000000
Aug 20 01:58:32 ethan-manjaro kernel: RBP: 0000000000000001 R08: 0000000000000000 R09: 0000000000000000
Aug 20 01:58:32 ethan-manjaro kernel: R13: ffff9f63cf9ecfa8 R14: 00000000ffffffff R15: 00000000ffffffff
Aug 20 01:58:32 ethan-manjaro kernel: intel_modeset_init_nogem+0xc27/0x1500 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: ---[ end trace d463a99b9ab56214 ]---
Aug 20 01:58:32 ethan-manjaro kernel: i915 0000:00:02.0: drm_WARN_ON(!tc_phy_status_complete(dig_port))
Aug 20 01:58:32 ethan-manjaro kernel: WARNING: CPU: 2 PID: 309 at drivers/gpu/drm/i915/display/intel_tc.c:532 intel_tc_port_sanitize+0x30c/0x360 [i915]
Aug 20 01:58:32 ethan-manjaro kernel: RIP: 0010:intel_tc_port_sanitize+0x30c/0x360 [i915]
Aug 20 01:58:32 ethan-manjaro kernel: Code: 4c 8b 77 50 4d 85 f6 75 03 4c 8b 37 e8 ad 51 4d d7 48 c7 c1 70 f7 3b c3 4c 89 f2 48 c7 c7 f2 e2 3d c3 48 89 c6 e8 a1 c8 8c d7 <0f> 0b 31 c0 e9 4b fd ff ff 48 8b 03 48 8b 78 08 48 8b 57 50 48 85
Aug 20 01:58:32 ethan-manjaro kernel: RSP: 0018:ffffad5401dff750 EFLAGS: 00010246
Aug 20 01:58:32 ethan-manjaro kernel: RBP: 00000000ffffffff R08: 0000000000000000 R09: 0000000000000000
Aug 20 01:58:32 ethan-manjaro kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f63cf9a0000
Aug 20 01:58:32 ethan-manjaro kernel: R13: ffff9f63d7b86fa8 R14: ffff9f63c188d940 R15: ffff9f63cf9a0000
Aug 20 01:58:32 ethan-manjaro kernel: intel_ddi_sync_state+0x3f/0x90 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: intel_modeset_setup_hw_state+0x439/0x1b10 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: ? drm_modeset_lock_all_ctx+0x135/0x390
Aug 20 01:58:32 ethan-manjaro kernel: intel_modeset_init_nogem+0x402/0x1500 [i915 ee6d49916f2bfbd3e58bc48101cbbc01a20c4e57]
Aug 20 01:58:32 ethan-manjaro kernel: ---[ end trace d463a99b9ab56215 ]---
Aug 20 01:58:32 ethan-manjaro kernel: R13: ffff9f63cf9ecfa8 R14: ffff9f63c188d940 R15: ffff9f63cf9a0000
Aug 20 01:58:32 ethan-manjaro kernel: ---[ end trace d463a99b9ab56216 ]---
Aug 20 01:58:32 ethan-manjaro kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:04 [mem 0xfedc0000-0xfedc7fff]
Aug 20 01:58:32 ethan-manjaro kernel: caller tgl_uncore_imc_freerunning_init_box+0xba/0x110 [intel_uncore] mapping multiple BARs
Aug 20 01:58:32 ethan-manjaro kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Aug 20 01:58:34 ethan-manjaro kernel: mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x800000
Aug 20 01:58:35 ethan-manjaro kernel: thermal thermal_zone8: failed to read out thermal zone (-61)
Aug 20 01:58:35 ethan-manjaro kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Aug 20 01:58:36 ethan-manjaro kernel: kauditd_printk_skb: 4 callbacks suppressed
Aug 20 01:58:36 ethan-manjaro systemd[603]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Aug 20 01:58:36 ethan-manjaro kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
Aug 20 01:58:36 ethan-manjaro kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: warn: topology ABI is more recent than kernel
Aug 20 01:58:36 ethan-manjaro bluetoothd[603]: Failed to set mode: Blocked through rfkill (0x12)
Aug 20 01:58:36 ethan-manjaro kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
Aug 20 01:58:36 ethan-manjaro kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
Aug 20 01:58:36 ethan-manjaro kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
Aug 20 01:58:36 ethan-manjaro kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
Aug 20 01:58:36 ethan-manjaro kernel: snd_hda_codec_hdmi ehdaudio0D2: Monitor plugged-in, Failed to power up codec ret=[-13]
Aug 20 01:58:40 ethan-manjaro kernel: ACPI Warning: \_SB.PC00.RP05.PXSX._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Aug 20 01:58:40 ethan-manjaro kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Aug 20 01:58:43 ethan-manjaro kernel: kauditd_printk_skb: 18 callbacks suppressed
Aug 20 01:58:43 ethan-manjaro systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Aug 20 01:58:43 ethan-manjaro systemd[1]: Failed to start pkgfile database update.
Aug 20 01:58:46 ethan-manjaro systemd[718]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Aug 20 01:58:46 ethan-manjaro systemd[718]: Failed to start Update XDG user dir configuration.
Aug 20 01:58:47 ethan-manjaro sddm-greeter[727]: QFont::fromString: Invalid description '(empty)'
Aug 20 01:58:47 ethan-manjaro sddm-greeter[727]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd14b445d0), parent's thread is QThread(0x558797500490), current thread is QThread(0x55879768f960)
Aug 20 01:58:47 ethan-manjaro sddm-greeter[727]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Aug 20 01:58:48 ethan-manjaro kernel: kauditd_printk_skb: 11 callbacks suppressed
Aug 20 01:58:49 ethan-manjaro sddm-greeter[727]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Aug 20 01:58:49 ethan-manjaro sddm-greeter[727]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Aug 20 01:58:49 ethan-manjaro sddm-greeter[727]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Aug 20 01:58:49 ethan-manjaro sddm-greeter[727]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Aug 20 01:58:49 ethan-manjaro sddm-greeter[727]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Aug 20 01:58:49 ethan-manjaro sddm-greeter[727]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.19'
Aug 20 01:59:21 ethan-manjaro systemd-journald[298]: File /var/log/journal/fd9894d25a114accbc6712a9b9cc7d4c/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Aug 20 01:59:22 ethan-manjaro ksplashqml[818]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Aug 20 01:59:22 ethan-manjaro ksplashqml[818]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Aug 20 01:59:22 ethan-manjaro klauncher[848]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Aug 20 01:59:22 ethan-manjaro kcminit_startup[856]: QDBusConnection: error: could not send signal to service "" path "//home/ethan/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/ethan/.kde4/share/config/kdeglobals
Aug 20 01:59:23 ethan-manjaro kwin_x11[867]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Aug 20 01:59:24 ethan-manjaro kwin_x11[867]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Aug 20 01:59:24 ethan-manjaro kwin_x11[867]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Aug 20 01:59:24 ethan-manjaro ksmserver[899]: Qt: Session management error: networkIdsList argument is NULL
Aug 20 01:59:25 ethan-manjaro kded5[864]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.12'
Aug 20 01:59:25 ethan-manjaro plasmashell[925]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Aug 20 01:59:25 ethan-manjaro plasmashell[925]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Aug 20 01:59:25 ethan-manjaro org_kde_powerdevil[928]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Aug 20 01:59:25 ethan-manjaro org_kde_powerdevil[928]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Aug 20 01:59:26 ethan-manjaro pulseaudio[944]: stat('/etc/pulse/default.pa.d'): No such file or directory
Aug 20 01:59:27 ethan-manjaro kded5[864]: kf.bluezqt: PendingCall Error: ""
Aug 20 01:59:27 ethan-manjaro kwin_x11[867]: kwin_core: XCB error: 10 (BadAccess), sequence: 858, resource id: 2425, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Aug 20 01:59:27 ethan-manjaro plasmashell[925]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Aug 20 01:59:27 ethan-manjaro plasmashell[925]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Aug 20 01:59:28 ethan-manjaro plasmashell[925]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 20 01:59:29 ethan-manjaro plasmashell[925]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Aug 20 01:59:29 ethan-manjaro plasmashell[925]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Aug 20 01:59:29 ethan-manjaro plasmashell[925]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Aug 20 01:59:30 ethan-manjaro plasmashell[925]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Aug 20 01:59:30 ethan-manjaro plasmashell[925]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Aug 20 01:59:30 ethan-manjaro plasmashell[925]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Aug 20 01:59:30 ethan-manjaro plasmashell[925]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Aug 20 01:59:30 ethan-manjaro plasmashell[925]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Aug 20 01:59:31 ethan-manjaro plasmashell[925]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Aug 20 01:59:31 ethan-manjaro kwin_x11[867]: kwin_core: XCB error: 152 (BadDamage), sequence: 4402, resource id: 18874411, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Aug 20 01:59:31 ethan-manjaro kwin_x11[867]: kwin_core: XCB error: 152 (BadDamage), sequence: 4433, resource id: 18874412, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Aug 20 01:59:31 ethan-manjaro kwin_x11[867]: kwin_core: XCB error: 3 (BadWindow), sequence: 4434, resource id: 4194340, major code: 129 (SHAPE), minor code: 6 (Input)
Aug 20 01:59:31 ethan-manjaro kwin_x11[867]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4435, resource id: 4194340, major code: 2 (ChangeWindowAttributes), minor code: 0
Aug 20 01:59:31 ethan-manjaro kwin_x11[867]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4440, resource id: 4194376, major code: 18 (ChangeProperty), minor code: 0
Aug 20 01:59:31 ethan-manjaro kernel: kauditd_printk_skb: 16 callbacks suppressed
Aug 20 01:59:31 ethan-manjaro plasmashell[925]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Aug 20 01:59:33 ethan-manjaro plasmashell[925]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 20 01:59:33 ethan-manjaro plasmashell[925]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 20 01:59:35 ethan-manjaro plasmashell[925]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 20 01:59:35 ethan-manjaro plasmashell[925]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 20 01:59:36 ethan-manjaro plasmashell[925]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 20 01:59:36 ethan-manjaro plasmashell[925]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 20 01:59:37 ethan-manjaro plasmashell[925]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 20 01:59:37 ethan-manjaro plasmashell[925]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 20 01:59:38 ethan-manjaro plasmashell[925]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Aug 20 01:59:38 ethan-manjaro plasmashell[925]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Aug 20 02:00:30 ethan-manjaro plasmashell[925]: trying to show an empty dialog
Aug 20 02:00:31 ethan-manjaro gnome-keyring-daemon[1227]: discover_other_daemon: 1
Aug 20 02:00:44 ethan-manjaro kwin_x11[867]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10383, resource id: 4194407, major code: 15 (QueryTree), minor code: 0
Aug 20 02:00:47 ethan-manjaro kwin_x11[867]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11652, resource id: 46137509, major code: 18 (ChangeProperty), minor code: 0
Aug 20 02:00:47 ethan-manjaro plasmashell[925]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Aug 20 02:00:49 ethan-manjaro kwin_x11[867]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13782, resource id: 18875555, major code: 3 (GetWindowAttributes), minor code: 0
Aug 20 02:00:49 ethan-manjaro kwin_x11[867]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 13783, resource id: 18875555, major code: 14 (GetGeometry), minor code: 0
Aug 20 02:02:06 ethan-manjaro kwin_x11[867]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43975, resource id: 46137512, major code: 18 (ChangeProperty), minor code: 0
Aug 20 02:02:06 ethan-manjaro plasmashell[925]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
So I just experienced the crash again and had bpytop open and it said I was only using 3 GB of ram at the time of the crash. This time Firefox crashed, then Steam wouldn’t load any images, and when I tried to open a new Konsole tab it said “No shell to interact with”. After that the system froze and shut down, and I don’t think it’s related to overheating because the laptop felt normal to the touch.
so provide logs from the crashed boot:
journalctl -b-1 -p3 --no-pager
from what i read you are gaming with the intel driver in intel mode and iris-gpu is well known to brake even in windows gaming. change to nvidia
nothing in the crashed boot logs … but in the previous logs there are some kernel issue, so install the 5.18 kernel, reboot, select it in grub and test with it if you have issues
