Ok guys, I have an ACEPC AK1, the installation goes beautifully no fail. Manjaro works flawless. The problem starts when I am prompted to install updates with the UI. I will be applying every single fix I can find across the whole internet until manjaro goes downhill and cannot be used again. I have installed this for the 5th time today and I have it fresh. I cannot believe manjaro is broken right from the installer. Is there a way to install these updates without crashing into stuff and breaking the whole OS? I remember using manjaro for 4 years and my computer died last year. Manjaro was the best to go to distro for me but I am just having pure bad luck with it right now. Any help is truly appreciated.
We are supposed to know the configuration of every hardware manufacturer just by reading the name of it?
This is a must read:
How to provide good information
If the first time failed, did you try the update from TTY ? Was mentioned quite a lot in the forum.
Neither do i as i did quite a few new installs with updates and are still working. We need to know more about the issue you are facing, the error you get … you know, the usual and useful technical information.
I apologize guys my bad. You must know when like everything on your day goes bad, you lose your civilized ways lol. I just did an hwinfo in my system. I have never been on these forums, so I am kind of new here. Not sure what you guys need but look, I just re-installed the latest version of KDE plasma and I have not done anything to it yet, the hwinfo yielded this info, let me know if you need anything else
SubVendor: pci 0x8086 "Intel Corporation"
SubDevice: pci 0x7270
Revision: 0x0b
Module Alias: "pci:v00008086d00005AF0sv00008086sd00007270bc06sc00i00"
Config Status: cfg=new, avail=yes, need=no, active=unknown
30: PCI 12.0: 0106 SATA controller (AHCI 1.0)
[Created at pci.386]
Unique ID: CLZK.YldYpy_LFu9
SysFS ID: /devices/pci0000:00/0000:00:12.0
SysFS BusID: 0000:00:12.0
Hardware Class: storage
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series SATA AHCI Controller"
Device: pci 0x5ae3 "Celeron N3350/Pentium N4200/Atom E3900 Series SATA AHCI Controller"
Revision: 0x0b
Driver: "ahci"
Driver Modules: "ahci"
Memory Range: 0x9231c000-0x9231dfff (rw,non-prefetchable)
Memory Range: 0x92344000-0x923440ff (rw,non-prefetchable)
I/O Ports: 0xf090-0xf097 (rw)
I/O Ports: 0xf080-0xf083 (rw)
I/O Ports: 0xf060-0xf07f (rw)
Memory Range: 0x92343000-0x923437ff (rw,non-prefetchable)
IRQ: 122 (961 events)
Module Alias: "pci:v00008086d00005AE3sv00008086sd00007270bc01sc06i01"
31: PCI 03.0: 0480 Multimedia controller
Unique ID: 3hqH.f+VjhBABJ62
SysFS ID: /devices/pci0000:00/0000:00:03.0
SysFS BusID: 0000:00:03.0
Hardware Class: unknown
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series Imaging Unit"
Device: pci 0x5a88 "Celeron N3350/Pentium N4200/Atom E3900 Series Imaging Unit"
Revision: 0x0b
Memory Range: 0x90000000-0x90ffffff (rw,non-prefetchable,disabled)
IRQ: 21 (no events)
Module Alias: "pci:v00008086d00005A88sv00000000sd00000000bc04sc80i00"
32: PCI 1f.1: 0c05 SMBus
Unique ID: 3p2J.STm5Fkodlf0
SysFS ID: /devices/pci0000:00/0000:00:1f.1
SysFS BusID: 0000:00:1f.1
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series SMBus Controller"
Device: pci 0x5ad4 "Celeron N3350/Pentium N4200/Atom E3900 Series SMBus Controller"
Revision: 0x0b
Driver: "i801_smbus"
Driver Modules: "i2c_i801"
Memory Range: 0x9231e000-0x9231e0ff (rw,non-prefetchable)
I/O Ports: 0xf040-0xf05f (rw)
IRQ: 2147483648 (no events)
Module Alias: "pci:v00008086d00005AD4sv00008086sd00007270bc0Csc05i00"
Driver Info #0:
Driver Status: i2c_i801 is active
Driver Activation Cmd: "modprobe i2c_i801"
33: PCI 18.2: 1180 Signal processing controller
Unique ID: OMCs.eat0qaZSfb7
SysFS ID: /devices/pci0000:00/0000:00:18.2
SysFS BusID: 0000:00:18.2
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #3"
Device: pci 0x5ac0 "Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #3"
Revision: 0x0b
Memory Range: 0x92345000-0x92345fff (rw,non-prefetchable)
Memory Range: 0x92346000-0x92346fff (rw,non-prefetchable)
IRQ: 6 (no events)
Module Alias: "pci:v00008086d00005AC0sv00008086sd00007270bc11sc80i00"
Driver Info #0:
Driver Status: intel_lpss_pci is active
Driver Activation Cmd: "modprobe intel_lpss_pci"
34: PCI 15.0: 0c03 USB Controller (XHCI)
Unique ID: Rgik.Uqk_+nLebV6
SysFS ID: /devices/pci0000:00/0000:00:15.0
SysFS BusID: 0000:00:15.0
Hardware Class: usb controller
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series USB xHCI"
Device: pci 0x5aa8 "Celeron N3350/Pentium N4200/Atom E3900 Series USB xHCI"
Revision: 0x0b
Driver: "xhci_hcd"
Driver Modules: "xhci_pci"
Memory Range: 0x92300000-0x9230ffff (rw,non-prefetchable)
IRQ: 123 (84762 events)
Module Alias: "pci:v00008086d00005AA8sv00008086sd00007270bc0Csc03i30"
Driver Info #0:
Driver Status: xhci_pci is active
Driver Activation Cmd: "modprobe xhci_pci"
35: PCI 1a.0: 0c80 Serial bus controller
Unique ID: pwJ7.hTfR5n1sfhD
SysFS ID: /devices/pci0000:00/0000:00:1a.0
SysFS BusID: 0000:00:1a.0
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series PWM Pin Controller"
Device: pci 0x5ac8 "Celeron N3350/Pentium N4200/Atom E3900 Series PWM Pin Controller"
Revision: 0x0b
Driver: "pwm-lpss"
Driver Modules: "pwm_lpss_pci"
Memory Range: 0x92326000-0x92326fff (rw,non-prefetchable)
Memory Range: 0x92325000-0x92325fff (rw,non-prefetchable)
Module Alias: "pci:v00008086d00005AC8sv00008086sd00007270bc0Csc80i00"
Driver Info #0:
Driver Status: pwm_lpss_pci is active
Driver Activation Cmd: "modprobe pwm_lpss_pci"
36: PCI 16.3: 1180 Signal processing controller
Unique ID: 6mDj.QnfX5gZMHf3
SysFS ID: /devices/pci0000:00/0000:00:16.3
SysFS BusID: 0000:00:16.3
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #4"
Device: pci 0x5ab2 "Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #4"
Revision: 0x0b
Driver: "intel-lpss"
Driver Modules: "intel_lpss_pci"
Memory Range: 0x9233c000-0x9233cfff (rw,non-prefetchable)
Memory Range: 0x9233b000-0x9233bfff (rw,non-prefetchable)
IRQ: 30 (no events)
Module Alias: "pci:v00008086d00005AB2sv00008086sd00007270bc11sc80i00"
Driver Info #0:
37: PCI 18.0: 1180 Signal processing controller
Unique ID: fiDB.aw51vI5eY36
SysFS ID: /devices/pci0000:00/0000:00:18.0
SysFS BusID: 0000:00:18.0
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #1"
Device: pci 0x5abc "Celeron N3350/Pentium N4200/Atom E3900 Series HSUART Controller #1"
Revision: 0x0b
Memory Range: 0x92332000-0x92332fff (rw,non-prefetchable)
Memory Range: 0x92331000-0x92331fff (rw,non-prefetchable)
IRQ: 4 (no events)
Module Alias: "pci:v00008086d00005ABCsv00008086sd00007270bc11sc80i00"
Driver Info #0:
38: PCI 0e.0: 0403 Audio device
Unique ID: vuMS.jvkcZtjbV9E
SysFS ID: /devices/pci0000:00/0000:00:0e.0
SysFS BusID: 0000:00:0e.0
Hardware Class: sound
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster"
Device: pci 0x5a98 "Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster"
SubVendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
SubDevice: pci 0x111a
Revision: 0x0b
Driver: "snd_hda_intel"
Driver Modules: "snd_hda_intel"
Memory Range: 0x92318000-0x9231bfff (rw,non-prefetchable)
Memory Range: 0x92000000-0x920fffff (rw,non-prefetchable)
IRQ: 129 (766 events)
Module Alias: "pci:v00008086d00005A98sv000010ECsd0000111Abc04sc03i80"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Driver Info #1:
Driver Status: snd_soc_skl is active
Driver Activation Cmd: "modprobe snd_soc_skl"
Driver Info #2:
Driver Status: snd_sof_pci is active
Driver Activation Cmd: "modprobe snd_sof_pci"
39: PCI 16.1: 1180 Signal processing controller
Unique ID: N6F2.M7uXAO5YA72
SysFS ID: /devices/pci0000:00/0000:00:16.1
SysFS BusID: 0000:00:16.1
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #2"
Device: pci 0x5aae "Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #2"
Revision: 0x0b
Memory Range: 0x92340000-0x92340fff (rw,non-prefetchable)
Memory Range: 0x9233f000-0x9233ffff (rw,non-prefetchable)
IRQ: 28 (no events)
Module Alias: "pci:v00008086d00005AAEsv00008086sd00007270bc11sc80i00"
Driver Info #0:
40: PCI 19.1: 1180 Signal processing controller
Unique ID: b8mU.iEf0ls1Hm79
SysFS ID: /devices/pci0000:00/0000:00:19.1
SysFS BusID: 0000:00:19.1
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series SPI Controller #2"
Device: pci 0x5ac4 "Celeron N3350/Pentium N4200/Atom E3900 Series SPI Controller #2"
Revision: 0x0b
Memory Range: 0x9232a000-0x9232afff (rw,non-prefetchable)
Memory Range: 0x92329000-0x92329fff (rw,non-prefetchable)
IRQ: 36 (no events)
Module Alias: "pci:v00008086d00005AC4sv00008086sd00007270bc11sc80i00"
Driver Info #0:
41: PCI 02.0: 0300 VGA compatible controller (VGA)
Unique ID: _Znp.HEkXa8gIbbE
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Hardware Class: graphics card
Device Name: "Onboard IGD"
Model: "Intel HD Graphics 500"
Device: pci 0x5a85 "HD Graphics 500"
SubDevice: pci 0x2212
Revision: 0x0b
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0x91000000-0x91ffffff (rw,non-prefetchable)
Memory Range: 0x80000000-0x8fffffff (ro,non-prefetchable)
I/O Ports: 0xf000-0xf03f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 128 (2217814 events)
Module Alias: "pci:v00008086d00005A85sv00008086sd00002212bc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
42: PCI 17.2: 1180 Signal processing controller
Unique ID: JF9O.WGK1_0dpRX4
SysFS ID: /devices/pci0000:00/0000:00:17.2
SysFS BusID: 0000:00:17.2
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #7"
Device: pci 0x5ab8 "Celeron N3350/Pentium N4200/Atom E3900 Series I2C Controller #7"
Revision: 0x0b
Memory Range: 0x92336000-0x92336fff (rw,non-prefetchable)
Memory Range: 0x92335000-0x92335fff (rw,non-prefetchable)
IRQ: 33 (no events)
Module Alias: "pci:v00008086d00005AB8sv00008086sd00007270bc11sc80i00"
Driver Info #0:
43: PCI 14.0: 0604 PCI bridge (Normal decode)
Unique ID: MZfG.ESsqsTbHPt9
SysFS ID: /devices/pci0000:00/0000:00:14.0
SysFS BusID: 0000:00:14.0
Hardware Class: bridge
Model: "Intel Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port B #2"
Device: pci 0x5ad7 "Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port B #2"
Revision: 0xfb
Driver: "pcieport"
IRQ: 121 (no events)
Module Alias: "pci:v00008086d00005AD7sv00000000sd00000000bc06sc04i00"
44: PCI 00.1: 1180 Signal processing controller
Unique ID: hgAj.wyUcI1HE9A2
SysFS ID: /devices/pci0000:00/0000:00:00.1
SysFS BusID: 0000:00:00.1
Model: "Intel Signal processing controller"
Device: pci 0x5a8c
Revision: 0x0b
Driver: "proc_thermal"
Driver Modules: "processor_thermal_device"
Memory Range: 0x92310000-0x92317fff (rw,non-prefetchable)
IRQ: 24 (no events)
Module Alias: "pci:v00008086d00005A8Csv00000000sd00000000bc11sc80i00"
Driver Info #0:
Driver Status: processor_thermal_device is active
Driver Activation Cmd: "modprobe processor_thermal_device"
45: MMC 01.0: 11700 MMC Controller
[Created at pci.1903]
Unique ID: MgRO.TzQFl_vZhO4
SysFS ID: /devices/pci0000:00/0000:00:1c.0/mmc_host/mmc1/mmc1:0001
SysFS BusID: mmc1:0001
Model: "MMC Controller"
Vendor: int 0x6015
Device: int 0x0000 "MMC Controller"
Driver: "mmcblk"
46: None 00.0: 10002 LCD Monitor
[Created at monitor.125]
Unique ID: rdCR.Fw7thEynuH2
Parent ID: _Znp.HEkXa8gIbbE
Hardware Class: monitor
Model: "M658-G1"
Vendor: VIZ
Device: eisa 0x1035 "M658-G1"
Resolution: 720x400@70Hz
Resolution: 640x480@60Hz
Resolution: 640x480@75Hz
Resolution: 800x600@60Hz
Resolution: 800x600@72Hz
Resolution: 800x600@75Hz
Resolution: 1024x768@60Hz
Resolution: 1024x768@70Hz
Resolution: 1024x768@75Hz
Resolution: 1920x1080@60Hz
Resolution: 3840x2160@60Hz
Year of Manufacture: 2019
Week of Manufacture: 0
Detailed Timings #0:
Horizontal: 3840 4016 4104 4400 (+176 +264 +560) +hsync
Vertical: 2160 2168 2178 2250 (+8 +18 +90) +vsync
Frequencies: 297.00 MHz, 67.50 kHz, 30.00 Hz
Detailed Timings #1:
Horizontal: 1920 2008 2052 2200 (+88 +132 +280) +hsync
Vertical: 1080 1084 1089 1125 (+4 +9 +45) +vsync
Frequencies: 148.50 MHz, 67.50 kHz, 60.00 Hz
Driver Info #0:
Max. Resolution: 3840x2160
Vert. Sync Range: 23-76 Hz
Hor. Sync Range: 15-140 kHz
Bandwidth: 297 MHz
Attached to: #41 (VGA compatible controller)
47: SCSI 200.0: 10600 Disk
[Created at block.245]
Unique ID: Zj8l.TuzdwIEMdU8
Parent ID: Rgik.Uqk_+nLebV6
SysFS ID: /class/block/sdb
SysFS BusID: 2:0:0:0
SysFS Device Link: /devices/pci0000:00/0000:00:15.0/usb2/2-4/2-4:1.0/host2/target2:0:0/2:0:0:0
Hardware Class: disk
Model: "WD Elements 2620"
Vendor: usb 0x1058 "WD"
Device: usb 0x2620 "Elements 2620"
Revision: "1018"
Serial ID: "57583732444130325631524C"
Driver: "usb-storage", "sd"
Driver Modules: "usb_storage"
Device File: /dev/sdb (/dev/sg1)
Device Files: /dev/sdb, /dev/disk/by-id/usb-WD_Elements_2620_57583732444130325631524C-0:0, /dev/disk/by-path/pci-0000:00:15.0-usb-0:4:1.0-scsi-0:0:0:0
Device Number: block 8:16-8:31 (char 21:1)
Module Alias: "usb:v1058p2620d1018dc00dsc00dp00ic08isc06ip50in00"
Driver Info #0:
Driver Status: uas is active
Driver Activation Cmd: "modprobe uas"
Driver Info #1:
Driver Status: usb_storage is active
Driver Activation Cmd: "modprobe usb_storage"
Drive status: no medium
Attached to: #34 (USB Controller)
48: None 00.0: 11300 Partition
[Created at block.434]
Unique ID: h4pj.SE1wIdpsiiC
Parent ID: Zj8l.TuzdwIEMdU8
SysFS ID: /class/block/sdb/sdb1
Hardware Class: partition
Model: "Partition"
Device File: /dev/sdb1
Device Files: /dev/sdb1, /dev/disk/by-partuuid/b77c7b44-70ff-4362-aaa2-0be79d7376aa, /dev/disk/by-partlabel/Microsoft\x20reserved\x20partition, /dev/disk/by-id/usb-WD_Elements_2620_57583732444130325631524C-0:0-part1, /dev/disk/by-path/pci-0000:00:15.0-usb-0:4:1.0-scsi-0:0:0:0-part1
Attached to: #47 (Disk)
49: None 00.0: 11300 Partition
Unique ID: 8G3o.SE1wIdpsiiC
SysFS ID: /class/block/sdb/sdb2
Model: "Partition"
Device File: /dev/sdb2
Device Files: /dev/sdb2, /dev/disk/by-uuid/5638-E842, /dev/disk/by-id/usb-WD_Elements_2620_57583732444130325631524C-0:0-part2, /dev/disk/by-partuuid/147eb010-6690-4fe4-a7f2-1b5337cb04fc, /dev/disk/by-partlabel/Basic\x20data\x20partition, /dev/disk/by-label/5TB, /dev/disk/by-path/pci-0000:00:15.0-usb-0:4:1.0-scsi-0:0:0:0-part2
50: None 00.0: 10600 Disk
Unique ID: kLao.Fxp0d3BezAE
Parent ID: MgRO.TzQFl_vZhO4
SysFS ID: /class/block/mmcblk1
SysFS Device Link: /devices/pci0000:00/0000:00:1c.0/mmc_host/mmc1/mmc1:0001
Model: "Disk"
Driver: "sdhci-pci", "mmcblk"
Driver Modules: "sdhci_pci"
Device File: /dev/mmcblk1
Device Files: /dev/mmcblk1, /dev/disk/by-id/mmc-CKTM4R_0xb5024cf7
Device Number: block 179:0-179:7
Attached to: #45 (MMC Controller)
51: None 00.0: 11300 Partition
Unique ID: 685D.SE1wIdpsiiC
Parent ID: kLao.Fxp0d3BezAE
SysFS ID: /class/block/mmcblk1/mmcblk1p1
Model: "Partition"
Device File: /dev/mmcblk1p1
Device Files: /dev/mmcblk1p1, /dev/disk/by-partuuid/89761b63-e0f5-2b42-929d-d1e9834a5f11, /dev/disk/by-label/NO_LABEL, /dev/disk/by-id/mmc-CKTM4R_0xb5024cf7-part1, /dev/disk/by-uuid/2C1D-E76A
Attached to: #50 (Disk)
52: None 00.0: 11300 Partition
Unique ID: ZJLH.SE1wIdpsiiC
SysFS ID: /class/block/mmcblk1/mmcblk1p2
Model: "Partition"
Device File: /dev/mmcblk1p2
Device Files: /dev/mmcblk1p2, /dev/disk/by-uuid/0875a082-6e68-49e1-8669-4297661c3205, /dev/disk/by-partuuid/77ef6e4d-f99f-b649-ba62-8ee4c08e7263, /dev/disk/by-id/mmc-CKTM4R_0xb5024cf7-part2
53: None 00.0: 11300 Partition
Unique ID: 0VbL.SE1wIdpsiiC
SysFS ID: /class/block/mmcblk1/mmcblk1p3
Model: "Partition"
Device File: /dev/mmcblk1p3
Device Files: /dev/mmcblk1p3, /dev/disk/by-partuuid/112128f0-fca9-b44c-b3e7-ab4b15e40018, /dev/disk/by-uuid/f518b4a6-74a2-438a-9edc-9bcbbd8d962f, /dev/disk/by-id/mmc-CKTM4R_0xb5024cf7-part3
54: IDE 100.0: 10600 Disk
Unique ID: 3OOL.+T6uhGJacq2
Parent ID: CLZK.YldYpy_LFu9
SysFS ID: /class/block/sda
SysFS BusID: 1:0:0:0
SysFS Device Link: /devices/pci0000:00/0000:00:12.0/ata2/host1/target1:0:0/1:0:0:0
Model: "WDC WDS100T2G0A-"
Vendor: "WDC"
Device: "WDS100T2G0A-"
Revision: "0000"
Driver: "ahci", "sd"
Device File: /dev/sda
Device Files: /dev/sda, /dev/disk/by-path/pci-0000:00:12.0-ata-2, /dev/disk/by-id/wwn-0x5001b448bb30b055, /dev/disk/by-id/ata-WDC_WDS100T2G0A-00JH30_20464E802307, /dev/disk/by-path/pci-0000:00:12.0-ata-2.0
Device Number: block 8:0-8:15
Attached to: #30 (SATA controller)
55: None 00.0: 11300 Partition
Unique ID: bdUI.SE1wIdpsiiC
Parent ID: 3OOL.+T6uhGJacq2
SysFS ID: /class/block/sda/sda1
Model: "Partition"
Device File: /dev/sda1
Device Files: /dev/sda1, /dev/disk/by-partuuid/cdf65c12-249b-4b07-84d8-ce8482cfd51e, /dev/disk/by-partlabel/EFI\x20system\x20partition, /dev/disk/by-id/wwn-0x5001b448bb30b055-part1, /dev/disk/by-uuid/8449-27E9, /dev/disk/by-id/ata-WDC_WDS100T2G0A-00JH30_20464E802307-part1, /dev/disk/by-path/pci-0000:00:12.0-ata-2.0-part1, /dev/disk/by-path/pci-0000:00:12.0-ata-2-part1
Attached to: #54 (Disk)
56: None 00.0: 11300 Partition
Unique ID: 2pkM.SE1wIdpsiiC
SysFS ID: /class/block/sda/sda2
Model: "Partition"
Device File: /dev/sda2
Device Files: /dev/sda2, /dev/disk/by-partuuid/9d58e0d7-9313-4346-a3d2-d29f9b89ae7d, /dev/disk/by-id/ata-WDC_WDS100T2G0A-00JH30_20464E802307-part2, /dev/disk/by-id/wwn-0x5001b448bb30b055-part2, /dev/disk/by-path/pci-0000:00:12.0-ata-2.0-part2, /dev/disk/by-path/pci-0000:00:12.0-ata-2-part2
57: None 00.0: 11300 Partition
Unique ID: W__Q.SE1wIdpsiiC
SysFS ID: /class/block/sda/sda3
Model: "Partition"
Device File: /dev/sda3
Device Files: /dev/sda3, /dev/disk/by-uuid/7A74B3A974B36693, /dev/disk/by-id/wwn-0x5001b448bb30b055-part3, /dev/disk/by-path/pci-0000:00:12.0-ata-2.0-part3, /dev/disk/by-partuuid/79f4f31c-47d0-42f1-aa5b-1f6cfdd9bfea, /dev/disk/by-id/ata-WDC_WDS100T2G0A-00JH30_20464E802307-part3, /dev/disk/by-path/pci-0000:00:12.0-ata-2-part3
59: USB 00.2: 10503 USB Mouse
[Created at usb.122]
Unique ID: WiL4.upWULkxBoj5
Parent ID: k4bc.ZEYWNM3UrzF
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.2
SysFS BusID: 1-2:1.2
Hardware Class: mouse
Model: "Razer Huntsman Mini"
Hotplug: USB
Vendor: usb 0x1532 "Razer USA, Ltd"
Device: usb 0x0257 "Razer Huntsman Mini"
Revision: "2.00"
Serial ID: "00000000001A"
Compatible to: int 0x0210 0x0025
Driver: "usbhid"
Driver Modules: "usbhid"
Device File: /dev/input/mice (/dev/input/mouse1)
Device Files: /dev/input/mice, /dev/input/mouse1, /dev/input/event16, /dev/input/by-id/usb-Razer_Razer_Huntsman_Mini_00000000001A-if02-event-mouse, /dev/input/by-path/pci-0000:00:15.0-usb-0:2:1.2-event-mouse, /dev/input/by-id/usb-Razer_Razer_Huntsman_Mini_00000000001A-if02-mouse, /dev/input/by-path/pci-0000:00:15.0-usb-0:2:1.2-mouse
Device Number: char 13:63 (char 13:33)
Speed: 12 Mbps
Module Alias: "usb:v1532p0257d0200dc00dsc00dp00ic03isc00ip02in02"
Driver Info #0:
Buttons: 5
Wheels: 2
XFree86 Protocol: explorerps/2
GPM Protocol: exps2
Attached to: #69 (Hub)
60: USB 00.3: 0000 Unclassified device
Unique ID: KoeX.Rpc2Hp6bk7B
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb1/1-8/1-8:1.3
SysFS BusID: 1-8:1.3
Model: "C-Media Electronics Audio Adapter (Unitek Y-247A)"
Hotplug: USB
Vendor: usb 0x0d8c "C-Media Electronics, Inc."
Device: usb 0x0014 "Audio Adapter (Unitek Y-247A)"
Revision: "1.00"
Driver: "usbhid"
Device File: /dev/input/event12
Device Files: /dev/input/event12, /dev/input/by-id/usb-C-Media_Electronics_Inc._USB_Audio_Device-event-if03, /dev/input/by-path/pci-0000:00:15.0-usb-0:8:1.3-event
Device Number: char 13:76
Speed: 12 Mbps
Module Alias: "usb:v0D8Cp0014d0100dc00dsc00dp00ic03isc00ip00in03"
Driver Info #0:
Driver Status: usbhid is active
Driver Activation Cmd: "modprobe usbhid"
61: USB 00.0: 10800 Keyboard
Unique ID: cLrx.XoA0EArn++0
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb1/1-2/1-2:1.0
SysFS BusID: 1-2:1.0
Hardware Class: keyboard
Hotplug: USB
Revision: "2.00"
Driver: "usbhid"
Device File: /dev/input/event4
Device Files: /dev/input/event4, /dev/input/by-id/usb-Razer_Razer_Huntsman_Mini_00000000001A-event-kbd, /dev/input/by-path/pci-0000:00:15.0-usb-0:2:1.0-event-kbd
Device Number: char 13:68
Speed: 12 Mbps
Module Alias: "usb:v1532p0257d0200dc00dsc00dp00ic03isc01ip01in00"
Driver Info #0:
XkbRules: xfree86
XkbModel: pc104
62: USB 00.1: 0401 Multimedia audio controller
Unique ID: QR8P.0zGQ5BCeC13
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb1/1-8/1-8:1.1
SysFS BusID: 1-8:1.1
Hotplug: USB
Revision: "1.00"
Driver: "snd-usb-audio"
Driver Modules: "snd_usb_audio"
Speed: 12 Mbps
Module Alias: "usb:v0D8Cp0014d0100dc00dsc00dp00ic01isc02ip00in01"
63: USB 00.2: 0000 Unclassified device
Unique ID: yqzE.dzCpQEuL0F2
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb1/1-3/1-3:1.2
SysFS BusID: 1-3:1.2
Model: "Razer Mamba 2018 (Wireless)"
Hotplug: USB
Device: usb 0x0072 "Mamba 2018 (Wireless)"
Revision: "2.00"
Driver: "usbhid"
Device File: /dev/input/event11
Device Files: /dev/input/event11, /dev/input/by-id/usb-Razer_Razer_Mamba_Wireless_Receiver-if02-event-kbd, /dev/input/by-path/pci-0000:00:15.0-usb-0:3:1.2-event-kbd
Device Number: char 13:75
Speed: 12 Mbps
Module Alias: "usb:v1532p0072d0200dc00dsc00dp00ic03isc00ip01in02"
Driver Info #0:
64: USB 00.0: 10503 USB Mouse
Unique ID: 2UT6.dbdIbwWsxH7
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb1/1-3/1-3:1.0
SysFS BusID: 1-3:1.0
Hotplug: USB
Revision: "2.00"
Driver: "usbhid"
Device File: /dev/input/mice (/dev/input/mouse0)
Device Files: /dev/input/mice, /dev/input/mouse0, /dev/input/event6, /dev/input/by-path/pci-0000:00:15.0-usb-0:3:1.0-event-mouse, /dev/input/by-id/usb-Razer_Razer_Mamba_Wireless_Receiver-event-mouse, /dev/input/by-id/usb-Razer_Razer_Mamba_Wireless_Receiver-mouse, /dev/input/by-path/pci-0000:00:15.0-usb-0:3:1.0-mouse
Device Number: char 13:63 (char 13:32)
Speed: 12 Mbps
Module Alias: "usb:v1532p0072d0200dc00dsc00dp00ic03isc01ip02in00"
Driver Info #0:
Buttons: 5
Wheels: 2
GPM Protocol: exps2
65: USB 00.0: 11500 Bluetooth Device
Unique ID: X7GA.l148Ao7nQK1
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb1/1-7/1-7:1.0
SysFS BusID: 1-7:1.0
Hardware Class: bluetooth
Model: "Intel Bluetooth wireless interface"
Hotplug: USB
Vendor: usb 0x8087 "Intel Corp."
Device: usb 0x0a2a "Bluetooth wireless interface"
Revision: "0.01"
Driver: "btusb"
Driver Modules: "btusb"
Speed: 12 Mbps
Module Alias: "usb:v8087p0A2Ad0001dcE0dsc01dp01icE0isc01ip01in00"
Driver Info #0:
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
69: USB 00.0: 10a00 Hub
Unique ID: k4bc.ZEYWNM3UrzF
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb1/1-0:1.0
SysFS BusID: 1-0:1.0
Hardware Class: hub
Model: "Linux Foundation 2.0 root hub"
Hotplug: USB
Vendor: usb 0x1d6b "Linux Foundation"
Device: usb 0x0002 "2.0 root hub"
Revision: "5.10"
Serial ID: "0000:00:15.0"
Driver: "hub"
Driver Modules: "usbcore"
Speed: 480 Mbps
Module Alias: "usb:v1D6Bp0002d0510dc09dsc00dp01ic09isc00ip00in00"
73: USB 00.0: 10a00 Hub
Unique ID: pBe4.SagjpJr9nB9
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb2/2-0:1.0
SysFS BusID: 2-0:1.0
Hardware Class: hub
Model: "Linux Foundation 3.0 root hub"
Hotplug: USB
Device: usb 0x0003 "3.0 root hub"
Revision: "5.10"
Driver: "hub"
Module Alias: "usb:v1D6Bp0003d0510dc09dsc00dp03ic09isc00ip00in00"
74: USB 00.0: 0000 Unclassified device
Unique ID: wkjR.jlWSV9fCQK4
SysFS ID: /devices/pci0000:00/0000:00:15.0/usb1/1-5/1-5:1.0
SysFS BusID: 1-5:1.0
Model: "Realtek RTS5129 Card Reader Controller"
Hotplug: USB
Vendor: usb 0x0bda "Realtek Semiconductor Corp."
Device: usb 0x0129 "RTS5129 Card Reader Controller"
Revision: "39.60"
Serial ID: "20100201396000000"
Driver: "rtsx_usb"
Driver Modules: "rtsx_usb"
Speed: 480 Mbps
Module Alias: "usb:v0BDAp0129d3960dcFFdscFFdpFFicFFisc06ip50in00"
Driver Info #0:
Driver Status: rtsx_usb is active
Driver Activation Cmd: "modprobe rtsx_usb"
75: None 00.0: 10103 CPU
[Created at cpu.462]
Unique ID: rdCR.j8NaKXDZtZ6
Hardware Class: cpu
Arch: X86-64
Vendor: "GenuineIntel"
Model: 6.92.9 "Intel(R) Celeron(R) CPU J3455 @ 1.50GHz"
Features: fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,pse36,clflush,dts,acpi,mmx,fxsr,sse,sse2,ss,ht,tm,pbe,syscall,nx,pdpe1gb,rdtscp,lm,constant_tsc,art,arch_perfmon,pebs,bts,rep_good,nopl,xtopology,tsc_reliable,nonstop_tsc,cpuid,aperfmperf,tsc_known_freq,pni,pclmulqdq,dtes64,monitor,ds_cpl,vmx,est,tm2,ssse3,sdbg,cx16,xtpr,pdcm,sse4_1,sse4_2,x2apic,movbe,popcnt,tsc_deadline_timer,aes,xsave,rdrand,lahf_lm,3dnowprefetch,cpuid_fault,cat_l2,ibrs,ibpb,stibp,tpr_shadow,vnmi,flexpriority,ept,vpid,ept_ad,fsgsbase,tsc_adjust,smep,erms,mpx,rdt_a,rdseed,smap,clflushopt,intel_pt,sha_ni,xsaveopt,xsavec,xgetbv1,xsaves,dtherm,ida,arat,pln,pts,md_clear,arch_capabilities
Clock: 1880 MHz
BogoMips: 2996.00
Cache: 1024 kb
Units/Processor: 32
76: None 01.0: 10103 CPU
Unique ID: wkFv.j8NaKXDZtZ6
Hardware Class: cpu
Arch: X86-64
Clock: 2108 MHz
BogoMips: 2996.00
Cache: 1024 kb
Units/Processor: 32
77: None 02.0: 10103 CPU
Unique ID: +rIN.j8NaKXDZtZ6
Hardware Class: cpu
Arch: X86-64
Clock: 2100 MHz
BogoMips: 2996.00
Cache: 1024 kb
Units/Processor: 32
78: None 03.0: 10103 CPU
Unique ID: 4zLr.j8NaKXDZtZ6
Hardware Class: cpu
Arch: X86-64
Clock: 2050 MHz
BogoMips: 2996.00
Cache: 1024 kb
Units/Processor: 32
79: None 00.0: 10701 Ethernet
[Created at net.126]
Unique ID: VV91.ndpeucax6V1
Parent ID: qru8.pv1WIYEyt95
SysFS ID: /class/net/wlp2s0
SysFS Device Link: /devices/pci0000:00/0000:00:14.0/0000:02:00.0
Hardware Class: network interface
Model: "Ethernet network interface"
Driver: "iwlwifi"
Driver Modules: "iwlwifi"
Device File: wlp2s0
HW Address: 6e:9a:4a:ba:5c:9e
Permanent HW Address: d8:f2:ca:09:26:9e
Link detected: no
Attached to: #17 (WLAN controller)
80: None 00.0: 10701 Ethernet
Unique ID: QObM.ndpeucax6V1
Parent ID: lkKU.YebYXPmVOt6
SysFS ID: /class/net/enp1s0
SysFS Device Link: /devices/pci0000:00/0000:00:13.0/0000:01:00.0
Driver: "r8169"
Driver Modules: "r8169"
Device File: enp1s0
HW Address: 68:1d:ef:10:cb:5b
Permanent HW Address: 68:1d:ef:10:cb:5b
Link detected: no
Attached to: #22 (Ethernet controller)
81: None 00.0: 10700 Loopback
Unique ID: ZsBS.GQNx7L4uPNA
SysFS ID: /class/net/lo
Model: "Loopback network interface"
Device File: lo
Link detected: yes
[sugarcookie@sugarcookie-defaultstring ~]$ 00 Loopback
Device File: lo
Link detected: yes
Config Status: cfg=new, avail=yes, need=no, active=unknown00 Loopback
Device File: lo
Link detected: yes
A little bit of what I am seeing when I try to update. I am seeing this keyring thing a lot and something about corrupted downloaded files. I start the update process using the UI and everything seems to download fine. When I try to install, everything seems to install well then at the end when the update UI is trying to validate all the downloaded files it will crash or show an error saying the databases are corrupted. I tried following fixes like adding fastest sources, refreshing keychains, and other things I could find in reddit etc but every fix I tried broke the system. I don’t know much about manjaro, I use manjaro just to install Kodi and manage my movie library and have it rolling all day long. I like KDE though because of how easy it was to customize and sure liked it better than windows and any other OS I had. It was quite easy though last year to just install it, update it and set it up for kodi. Right now though it seems like a wreck. Thank you for trying to help me guys even though I posted like a savage.
Another update, someone advised that I installed the updates using the terminal. Here is the output of using the terminal, same issue I got from using the UI.
[sugarcookie@sugarcookie-defaultstring ~]$ sudo pacman -Syu
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for sugarcookie:
core 170.9 KiB 351 KiB/s 00:00 [############] 100%
extra 1924.7 KiB 518 KiB/s 00:04 [############] 100%
community 6.6 MiB 516 KiB/s 00:13 [############] 100%
multilib 178.9 KiB 452 KiB/s 00:00 [############] 100%
:: Some packages should be upgraded first...
resolving dependencies...
Packages (2) archlinux-keyring-20210802-1 manjaro-keyring-20210807-2
Total Download Size: 1.07 MiB
Total Installed Size: 1.50 MiB
Net Upgrade Size: 0.02 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
archlinux-keyrin... 959.1 KiB 493 KiB/s 00:02 [############] 100%
manjaro-keyring-... 139.4 KiB 348 KiB/s 00:00 [############] 100%
(2/2) checking keys in keyring [############] 100%
(2/2) checking package integrity [############] 100%
(2/2) loading package files [############] 100%
(2/2) checking for file conflicts [############] 100%
(2/2) checking available disk space [############] 100%
(1/2) upgrading archlinux-keyring [############] 100%
==> Appending keys from archlinux.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7...
-> Locally signing key DDB867B92AA789C165EEFA799B729B06A680C281...
-> Locally signing key 2AC0A42EFB0B5CBC7A0402ED4DC95B6D7BE9892E...
-> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
-> Locally signing key D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C...
-> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00...
==> Importing owner trust values...
gpg: setting ownertrust to 4
==> Disabling revoked keys in keyring...
-> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
-> Disabling key 684148BB25B49E986A4944C55184252D824B18E8...
-> Disabling key 5357F3B111688D88C1D88119FCF2CB179205AC90...
-> Disabling key 50F33E2E5B0C3D900424ABE89BDCF497A4BBCC7F...
-> Disabling key 39F880E50E49A4D11341E8F939E4F17F295AFBF4...
-> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
-> Disabling key 40440DC037C05620984379A6761FAD69BA06C6A9...
-> Disabling key FB871F0131FEA4FB5A9192B4C8880A6406361833...
-> Disabling key 487EACC08557AD082088DABA1EB2638FF56C0C53...
-> Disabling key 76B4192E902C0A52642C63C273B8ED52F1D357C1...
-> Disabling key F648622B1715468FD654F45CB7310AE5F04569AE...
-> Disabling key 40776A5221EF5AD468A4906D42A1DB15EC133BAD...
-> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
-> Disabling key 07DFD3A0BC213FA12EDC217559B3122E2FA915EC...
-> Disabling key 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5...
-> Disabling key B1F2C889CB2CCB2ADA36D963097D629E437520BD...
-> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
-> Disabling key 44D4A033AC140143927397D47EFD567D4C7EA887...
-> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
-> Disabling key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
-> Disabling key 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD...
-> Disabling key 5A2257D19FF7E1E0E415968CE62F853100F0D0F0...
-> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
-> Disabling key 5E7585ADFF106BFFBBA319DC654B877A0864983E...
-> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
-> Disabling key 5559BC1A32B8F76B3FCCD9555FA5E5544F010D48...
-> Disabling key F3691687D867B81B51CE07D9BBE43771487328A9...
-> Disabling key BFA1ECFEF1524EE4099CDE971F0CD4921ECAA030...
-> Disabling key 4D913AECD81726D9A6C74F0ADA6426DD215B37AD...
-> Disabling key 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA...
-> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
-> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
-> Disabling key 779CD2942629B7FA04AB8F172E89012331361F01...
-> Disabling key D921CABED130A5690EF1896E81AF739EC0711BF1...
-> Disabling key 5696C003B0854206450C8E5BE613C09CB4440678...
-> Disabling key 8CF934E339CAD8ABF342E822E711306E3C4F88BC...
-> Disabling key 1A60DC44245D06FEF90623D6EEEEE2EEEE2EEEEE...
-> Disabling key A5CA9D5515DC2CA73DF748CA5C2E46A0F53A76ED...
-> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
-> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992...
-> Disabling key 65EEFE022108E2B708CBFCF7F9E712E59AF5F22A...
-> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
==> Updating trust database...
gpg: next trustdb check due at 2021-10-12
(2/2) upgrading manjaro-keyring [############] 100%
==> Appending keys from manjaro.gpg...
-> Locally signing key 7C89F4D439B2BFACF425107B62443D89B35859F8...
-> Locally signing key 16DC688DF3EECC72323954237EC47C82A42D53A2...
-> Locally signing key 688E8F82879D0E25CE541426150C200743ED46D8...
-> Locally signing key 04BB537F5BC2D399BFA72F8F17C752B61B2F2E90...
-> Locally signing key 5A97ED6B72418199F0C22B23137C934B5DCB998E...
-> Locally signing key 76C6E477042BFE985CC220BD9C08A255442FAFF0...
-> Locally signing key 2D14560CDCE6A75BB186DB758238651DDF5E0594...
-> Locally signing key A44C644D792767CED7941AFEABB2075D5F310CF8...
-> Locally signing key 74C2F2CC05A0AB7D859839938934292D604F8BA2...
-> Locally signing key 7A443CEE69B6B3777740E258084A7FC0035B1D49...
-> Locally signing key 2C688B52E3FC0144B7484BABE3B3F44AC45EE0AA...
-> Locally signing key 0037505D6C3F595C37F5626AFD847358FF20E35C...
-> Locally signing key 1E7908935AAB9A00D6B47503363DFFFD59152F77...
-> Locally signing key 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
-> Locally signing key F66AD0FF0E57C561615A0901CEE477135C5872B0...
-> Locally signing key 77DC01C9971AC3C39A0626F72C089F09AC97B894...
-> Locally signing key 22C903DE964E6FE321656E318DB9F8C18DF53602...
-> Locally signing key B4663188A692DB1E45A98EE95BD96CC4247B52CC...
-> Locally signing key 75C1B95A4D9514A57EB2DAE71817DC63CD3B5DF5...
-> Locally signing key E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
-> Locally signing key 3B794DE6D4320FCE594F4171279E7CF5D8D56EC8...
-> Disabling key 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
-> Disabling key 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
-> Disabling key FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 27 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 27 signed: 82 trust: 0-, 0q, 0n, 27m, 0f, 0u
gpg: depth: 2 valid: 76 signed: 25 trust: 76-, 0q, 0n, 0m, 0f, 0u
(1/1) Arming ConditionNeedsUpdate...
:: Replace adobe-source-sans-pro-fonts with extra/adobe-source-sans-fonts? [Y/n] y
:: Replace jack with extra/jack2? [Y/n] y
:: Replace pamac-common with extra/libpamac? [Y/n] y
:: Replace pamac-flatpak-plugin with extra/libpamac-flatpak-plugin? [Y/n] y
:: Replace pamac-snap-plugin with extra/libpamac-snap-plugin? [Y/n] y
warning: dependency cycle detected:
warning: rubygems will be installed before its ruby dependency
warning: ruby-irb will be installed before its ruby dependency
Packages (431) adobe-source-sans-fonts-3.046-1
adobe-source-sans-pro-fonts-3.028-1 [removal]
alsa-card-profiles-1:0.3.33-1 alsa-lib-1.2.5.1-3
alsa-topology-conf-1.2.5.1-1 alsa-ucm-conf-1.2.5.1-1
alsa-utils-1.2.5.1-1 android-tools-31.0.2-1
aom-3.1.2-1 appimagelauncher-2.2.0-6
appstream-0.14.4-1 appstream-glib-0.7.18-3
appstream-qt-0.14.4-1
archlinux-appstream-data-20210723-1 ark-21.04.3-1
at-spi2-core-2.40.3-1 attica-5.84.0-1 audit-3.0.3-1
baloo-5.84.0-1 baloo-widgets-21.04.3-1
bluedevil-1:5.22.4-1 bluez-5.60-1 bluez-libs-5.60-1
bluez-qt-5.84.0-1 boost-libs-1.76.0-1
breath2-icon-themes-1.0.18-1
breath2-wallpaper-1.0.18-1 breeze-5.22.4-1
breeze-icons-5.84.0-1 btrfs-progs-5.13-1
ca-certificates-20210603-1
ca-certificates-mozilla-3.68-1
ca-certificates-utils-20210603-1 cdrtools-3.02a09-5
celt-0.11.3-4 ceph-libs-15.2.13-2 cfitsio-1:4.0.0-1
ckbcomp-1.204-1 cpupower-5.13-1
cups-filters-1.28.9-1 curl-7.78.0-1
dbus-python-1.2.18-1 dolphin-21.04.3-1
dolphin-plugins-21.04.3-1 e2fsprogs-1.46.3-3
editorconfig-core-c-0.12.5-1 enchant-2.3.0-1
exiv2-0.27.4-2 f2fs-tools-1.14.0-2 ffmpeg-2:4.4-4
ffmpegthumbs-21.04.3-1 filelight-21.04.3-1
firefox-91.0-0.1 flatpak-1.11.2-1 fluidsynth-2.2.2-1
fmt-8.0.1-1 fontconfig-2:2.13.94-1
frameworkintegration-5.84.0-1 fuse-common-3.10.4-1
fuse3-3.10.4-1 fwupd-1.6.2-1 fwupd-efi-1.1-1
game-devices-udev-0.14-1 gd-2.3.2-4 gdbm-1.20-1
gdk-pixbuf2-2.42.6-2 glib2-2.68.3-1 glslang-11.5.0-1
glu-9.0.2-1 gnupg-2.2.29-1 gnutls-3.7.2-2
gpgme-1.16.0-1 gptfdisk-1.0.8-1 groff-1.22.4-6
gst-plugins-bad-1.18.4-11
gst-plugins-bad-libs-1.18.4-11 gtk3-1:3.24.30-1
gwenview-21.04.3-1 harfbuzz-2.8.2-1
harfbuzz-icu-2.8.2-1 hdparm-9.62-1 hplip-1:3.21.6-1
hwids-20210613-1 hwinfo-21.76-1 hwloc-2.5.0-1
iana-etc-20210624-1 imagemagick-7.1.0.4-2
imath-3.1.2-1 imlib2-1.7.2-1 inetutils-2.1-1
intel-ucode-20210608-1 inxi-3.3.06.1-1
iproute2-5.13.0-1 iputils-20210722-1
jack-0.125.0-9 [removal] jack2-1.9.19-2
jasper-2.0.32-1 js78-78.12.0-1 k3b-1:21.04.3-1
kaccounts-integration-21.04.3-1
kaccounts-providers-21.04.3-1 kactivities-5.84.0-1
kactivities-stats-5.84.0-1 kactivitymanagerd-5.22.4-1
kamera-21.04.3-1 karchive-5.84.0-1 kate-21.04.3-1
kauth-5.84.0-1 kbookmarks-5.84.0-1 kcalc-21.04.3-1
kcmutils-5.84.0-1 kcodecs-5.84.0-1
kcompletion-5.84.0-1 kconfig-5.84.0-1
kconfigwidgets-5.84.0-1 kcontacts-1:5.84.0-1
kcoreaddons-5.84.0-1 kcrash-5.84.0-1
kdbusaddons-5.84.0-1 kde-cli-tools-5.22.4-1
kde-gtk-config-5.22.4-1 kdeclarative-5.84.0-1
kdeconnect-21.04.3-1 kdecoration-5.22.4-1
kded-5.84.0-1 kdegraphics-thumbnailers-21.04.3-1
kdelibs4support-5.84.0-1
kdenetwork-filesharing-21.04.3-1
kdeplasma-addons-5.22.4-1 kdesu-5.84.0-1
kdnssd-5.84.0-1 kdoctools-5.84.0-1 kdsoap-2.0.0-1
kdsoap-ws-discovery-client-git20200927-2
keditbookmarks-21.04.3-1 kemoticons-5.84.0-1
kfilemetadata-5.84.0-1 kfind-21.04.3-1
kgamma5-5.22.4-1 kget-21.04.3-1
kglobalaccel-5.84.0-1 kguiaddons-5.84.0-1
khelpcenter-21.04.3-1 kholidays-1:5.84.0-1
khotkeys-5.22.4-1 khtml-5.84.0-1 ki18n-5.84.0-1
kiconthemes-5.84.0-1 kidletime-5.84.0-1
kimageformats-5.84.0-3 kinfocenter-5.22.4-1
kinit-5.84.0-1 kio-5.84.0-2 kio-extras-21.04.3-2
kio-fuse-5.0.1-1 kirigami2-5.84.0-1
kitemmodels-5.84.0-1 kitemviews-5.84.0-1
kjobwidgets-5.84.0-1 kjs-5.84.0-1 kmenuedit-5.22.4-1
knewstuff-5.84.0-1 knotifications-5.84.0-1
knotifyconfig-5.84.0-1 konsole-21.04.3-1
konversation-21.04.3-1 kpackage-5.84.0-1
kparts-5.84.0-1 kpeople-5.84.0-1 kpmcore-21.04.3-1
kpty-5.84.0-1 kquickcharts-5.84.0-1 krunner-5.84.0-1
kscreen-5.22.4-1 kscreenlocker-5.22.4-1
kservice-5.84.0-1 ksshaskpass-5.22.4-1
ksysguard-5.22.0-1 ksystemlog-21.04.3-1
ksystemstats-5.22.4-1 ktexteditor-5.84.0-1
ktextwidgets-5.84.0-1 kunitconversion-5.84.0-1
kwallet-5.84.0-1 kwallet-pam-5.22.4-1
kwalletmanager-21.04.3-1 kwayland-5.84.0-1
kwayland-integration-5.22.4-1
kwayland-server-5.22.4-1 kwidgetsaddons-5.84.0-1
kwin-5.22.4-1 kwindowsystem-5.84.0-1
kwrited-5.22.4-1 kxmlgui-5.84.0-1
layer-shell-qt-5.22.4-1 ldb-2:2.3.0-1 less-1:590-1
lib32-alsa-lib-1.2.5.1-1 lib32-curl-7.78.0-1
lib32-e2fsprogs-1.46.3-1
lib32-libcanberra-0.30+2+gc0620e4-5
lib32-libcap-2.51-1 lib32-libdrm-2.4.107-1
lib32-libldap-2.4.59-1 lib32-libpulse-15.0-1
lib32-libtasn1-4.17.0-1
lib32-libva-mesa-driver-21.1.6-1
lib32-libxcrypt-4.4.23-1 lib32-libxfixes-6.0.0-1
lib32-llvm-libs-12.0.1-1 lib32-mesa-21.1.6-1
lib32-mesa-vdpau-21.1.6-1 lib32-nspr-4.32-1
lib32-nss-3.68-1 lib32-p11-kit-0.24.0-1
lib32-sqlite-3.36.0-1 lib32-systemd-248.7-1
lib32-tdb-1.4.5-1 lib32-util-linux-2.37.1-1
lib32-vulkan-icd-loader-1.2.184-1
lib32-vulkan-intel-21.1.6-1
lib32-vulkan-radeon-21.1.6-1 libappimage-1.0.3-4
libavif-0.9.2-1 libbytesize-2.6-1
libcanberra-0.30+2+gc0620e4-5 libcap-2.51-1
libcap-ng-0.8.2-3 libdrm-2.4.107-1
libfreeaptx-0.1.1-1 libgit2-1:1.1.1-1
libhandy-1.2.3-1 libidn-1.38-1 libidn2-2.3.2-1
libinput-1.18.1-1 libjcat-0.1.8-1 libkcddb-21.04.3-1
libkdcraw-21.04.3-1 libkexiv2-21.04.3-1
libkipi-21.04.3-1 libksane-21.04.3-1 libksba-1.6.0-1
libkscreen-5.22.4-1 libksysguard-5.22.4-1
libktorrent-21.04.3-1 libldap-2.4.59-2
libmbim-1.26.0-1 libmfx-21.2.3-1 libmm-glib-1.16.8-1
libnghttp2-1.44.0-1 libnm-1.32.6-1
libp11-kit-0.24.0-1 libpamac-11.0.1-3
libpamac-flatpak-plugin-11.0.1-2
libpamac-snap-plugin-11.0.1-2 libpcap-1.10.1-1
libplacebo-3.120.3-2 libpulse-15.0-1
libqalculate-3.20.1-1 libsidplayfp-2.2.1-1
libtorrent-rasterbar-1:1.2.14-1 libva-2.12.0-1
libva-mesa-driver-21.1.6-1 libwacom-1.11-1
libwpe-1.10.1-1 libxcrypt-4.4.23-1 libxfont2-2.0.5-1
libxft-2.3.4-1 libxmlb-0.3.2-1
linux-firmware-20210719.r1990.168452e-1
linux510-5.10.56-1 llvm-libs-12.0.1-2
logrotate-3.18.1-1 man-db-2.9.4-2 man-pages-5.12-2
manjaro-application-utility-1.3.3-5
manjaro-hello-0.6.6-6 manjaro-kde-settings-20210813-1
manjaro-release-21.1.0rc4-1 memtest86+-5.31b-1
mesa-21.1.6-1 mesa-vdpau-21.1.6-1 mhwd-db-0.6.5-15
mhwd-nvidia-470.57.02-1 mhwd-nvidia-390xx-390.144-1
milou-5.22.4-1 mkinitcpio-busybox-1.33.1-1
modemmanager-1.16.8-1 modemmanager-qt-5.84.0-1
mpd-0.22.9-2 mpg123-1.28.2-1 nano-5.8-1
networkmanager-1.32.6-1 networkmanager-qt-5.84.0-1
nfs-utils-2.5.4-1 nfsidmap-2.5.4-1
noto-fonts-emoji-20210625-1 nspr-4.32-1 nss-3.68-1
nss-mdns-0.15.1-1 okular-21.04.3-2 openexr-3.1.1-1
openmpi-4.1.1-2 openvpn-2.5.3-1 ostree-2021.3-1
oxygen-5.22.4-1 oxygen-icons-1:5.84.0-1
p11-kit-0.24.0-1 pacman-6.0.0-2
pacman-mirrors-4.21.5-1 pamac-cli-10.1.3-3
pamac-common-10.0.6-2 [removal]
pamac-flatpak-plugin-10.0.6-2 [removal]
pamac-gtk-10.1.3-3
pamac-snap-plugin-10.0.6-2 [removal] pango-1:1.48.7-1
partitionmanager-21.04.3-1 pcre-8.45-1
pcsclite-1.9.2-2 perl-5.34.0-2
perl-alien-build-2.41-1 perl-file-basedir-0.09-1
perl-http-message-6.33-1 perl-libwww-6.55-1
pipewire-1:0.3.33-1 plasma-desktop-5.22.4-1
plasma-framework-5.84.0-1 plasma-integration-5.22.4-1
plasma-nm-5.22.4-1 plasma-pa-5.22.4-1
plasma-systemmonitor-5.22.4-1
plasma-workspace-5.22.4-2
plasma-workspace-wallpapers-5.22.4-1
plasma5-themes-breath2-1.0.18-2
polkit-kde-agent-5.22.4-1 polkit-qt5-0.114.0-1
poppler-21.08.0-1 poppler-glib-21.08.0-1
poppler-qt5-21.08.0-1 powerdevil-5.22.4-1
print-manager-21.04.3-1 prison-5.84.0-1
protobuf-3.17.3-1 pulseaudio-15.0-1
pulseaudio-bluetooth-15.0-1 pulseaudio-ctl-1.70-1
pulseaudio-equalizer-15.0-1 pulseaudio-jack-15.0-1
pulseaudio-lirc-15.0-1 pulseaudio-rtp-15.0-1
pulseaudio-zeroconf-15.0-1 purpose-5.84.0-1
python-3.9.6-1 python-certifi-2020.12.5-1
python-cffi-1.14.6-1 python-more-itertools-8.8.0-1
python-pep517-0.11.0-1 python-pillow-8.3.1-1
python-pip-20.3.4-1 python-reportlab-3.5.68-2
python-requests-2.26.0-1 python-resolvelib-0.5.5-1
python-setuptools-1:57.4.0-1 python-tomli-1.2.0-1
python-urllib3-1.26.6-1 qbittorrent-4.3.6-1
qgpgme-1.16.0-1 qqc2-desktop-style-5.84.0-1
qt5-base-5.15.2+kde+r210-1
qt5-declarative-5.15.2+kde+r29-1 qt5-script-5.15.5-2
qt5-tools-5.15.2+kde+r17-3
qt5-wayland-5.15.2+kde+r29-1 qt5-webengine-5.15.5-1
re2-1:20210801-1 rpcbind-1.2.6-1 rsync-3.2.3-4
ruby-3.0.2-1 ruby-irb-1.3.6-1 rubygems-3.2.21-1
samba-4.14.6-1 sddm-breath2-theme-1.0.18-1
sddm-kcm-5.22.4-1 shaderc-2021.1-1
signon-kwallet-extension-21.04.3-1 smbclient-4.14.6-1
snapd-2.51.3-2 sof-firmware-1.8-1 solid-5.84.0-1
sonnet-5.84.0-1 spectacle-21.04.3-1 sqlite-3.36.0-1
squashfs-tools-4.5-1 sshfs-3.7.2-1
steam-manjaro-1.0.0.71-1 sudo-1.9.7.p2-1
syndication-5.84.0-1 syntax-highlighting-5.84.0-1
systemd-248.7-1 systemd-libs-248.7-1
systemd-sysvcompat-248.7-1 systemsettings-5.22.4-1
talloc-2.3.3-1 tdb-1.4.5-1 tevent-1:0.11.0-1
texinfo-6.8-1 threadweaver-5.84.0-1
thunderbird-78.13.0-0.1 udisks2-2.9.3-1
upower-0.99.12-2 util-linux-2.37.1-3
util-linux-libs-2.37.1-3 vlc-3.0.16-3
vpnc-1:0.5.3.r496.r153-2 vulkan-icd-loader-1.2.185-1
vulkan-intel-21.1.6-1 vulkan-radeon-21.1.6-1
webkit2gtk-2.32.3-1 wireless-regdb-2021.04.21-1
wpebackend-fdo-1.10.0-1 xapp-2.2.3-2
xdg-desktop-portal-kde-5.22.4-1
xf86-input-libinput-1.1.0-1
xf86-video-amdgpu-21.0.0-1 xfsprogs-5.12.0-1
xkeyboard-config-2.33-1 xorg-server-1.20.13-1
xorg-server-common-1.20.13-1 yakuake-21.04.3-1
zimg-3.0.2-1 zsh-theme-powerlevel10k-1.15.0-2
Total Download Size: 1239.36 MiB
Total Installed Size: 4090.18 MiB
Net Upgrade Size: -21.50 MiB
iana-etc-2021062... 391.1 KiB 458 KiB/s 00:01 [############] 100%
hwids-20210613-1-any 463.8 KiB 323 KiB/s 00:01 [############] 100%
libxcrypt-4.4.23... 88.5 KiB 316 KiB/s 00:00 [############] 100%
libcap-ng-0.8.2-... 41.5 KiB 388 KiB/s 00:00 [############] 100%
util-linux-libs-... 411.9 KiB 453 KiB/s 00:01 [############] 100%
e2fsprogs-1.46.3... 1195.9 KiB 484 KiB/s 00:02 [############] 100%
libldap-2.4.59-2... 303.6 KiB 422 KiB/s 00:01 [############] 100%
audit-3.0.3-1-x86_64 380.2 KiB 460 KiB/s 00:01 [############] 100%
libcap-2.51-1-x86_64 72.8 KiB 547 KiB/s 00:00 [############] 100%
libp11-kit-0.24.... 478.7 KiB 548 KiB/s 00:01 [############] 100%
systemd-libs-248... 749.9 KiB 509 KiB/s 00:01 [############] 100%
libidn2-2.3.2-1-... 140.2 KiB 351 KiB/s 00:00 [############] 100%
util-linux-2.37.... 2.5 MiB 509 KiB/s 00:05 [############] 100%
p11-kit-0.24.0-1... 141.7 KiB 361 KiB/s 00:00 [############] 100%
ca-certificates-... 8.2 KiB 0.00 B/s 00:00 [############] 100%
ca-certificates-... 325.8 KiB 450 KiB/s 00:01 [############] 100%
ca-certificates-... 2028.0 B 0.00 B/s 00:00 [############] 100%
libnghttp2-1.44.... 94.9 KiB 296 KiB/s 00:00 [############] 100%
curl-7.78.0-1-x86_64 1092.6 KiB 527 KiB/s 00:02 [############] 100%
libpcap-1.10.1-1... 276.5 KiB 503 KiB/s 00:01 [############] 100%
systemd-248.7-1-... 8.3 MiB 518 KiB/s 00:17 [############] 100%
pcre-8.45-1-x86_64 983.0 KiB 498 KiB/s 00:02 [############] 100%
glib2-2.68.3-1-x... 2.7 MiB 525 KiB/s 00:05 [############] 100%
sqlite-3.36.0-1-... 1741.8 KiB 515 KiB/s 00:03 [############] 100%
gnutls-3.7.2-2-x... 2.8 MiB 521 KiB/s 00:06 [############] 100%
gdbm-1.20-1-x86_64 220.8 KiB 394 KiB/s 00:01 [############] 100%
perl-5.34.0-2-x86_64 15.4 MiB 522 KiB/s 00:30 [############] 100%
libksba-1.6.0-1-... 137.9 KiB 313 KiB/s 00:00 [############] 100%
gnupg-2.2.29-1-x... 2.4 MiB 528 KiB/s 00:05 [############] 100%
gpgme-1.16.0-1-x... 446.0 KiB 416 KiB/s 00:01 [############] 100%
python-3.9.6-1-x... 11.0 MiB 525 KiB/s 00:21 [############] 100%
pacman-mirrors-4... 173.8 KiB 313 KiB/s 00:01 [############] 100%
pacman-6.0.0-2-x... 926.6 KiB 502 KiB/s 00:02 [############] 100%
btrfs-progs-5.13... 881.4 KiB 475 KiB/s 00:02 [############] 100%
xfsprogs-5.12.0-... 1065.6 KiB 535 KiB/s 00:02 [############] 100%
nspr-4.32-1-x86_64 197.8 KiB 364 KiB/s 00:01 [############] 100%
nss-3.68-1-x86_64 1574.0 KiB 514 KiB/s 00:03 [############] 100%
groff-1.22.4-6-x... 2.1 MiB 514 KiB/s 00:04 [############] 100%
hdparm-9.62-1-x86_64 85.1 KiB 579 KiB/s 00:00 [############] 100%
inetutils-2.1-1-... 349.9 KiB 462 KiB/s 00:01 [############] 100%
iproute2-5.13.0-... 1038.2 KiB 533 KiB/s 00:02 [############] 100%
iputils-20210722... 127.8 KiB 251 KiB/s 00:01 [############] 100%
qgpgme-1.16.0-1-... 251.1 KiB 401 KiB/s 00:01 [############] 100%
less-1:590-1-x86_64 115.1 KiB 393 KiB/s 00:00 [############] 100%
linux-firmware-2... 172.1 MiB 526 KiB/s 05:35 [############] 100%
mkinitcpio-busyb... 269.5 KiB 402 KiB/s 00:01 [############] 100%
linux510-5.10.56... 73.9 MiB 517 KiB/s 02:26 [############] 100%
logrotate-3.18.1... 47.7 KiB 154 KiB/s 00:00 [############] 100%
man-db-2.9.4-2-x... 1059.0 KiB 530 KiB/s 00:02 [############] 100%
man-pages-5.12-2-any 5.8 MiB 532 KiB/s 00:11 [############] 100%
manjaro-release-... 18.5 KiB 185 KiB/s 00:00 [############] 100%
mhwd-nvidia-390x... 2.6 KiB 0.00 B/s 00:00 [############] 100%
mhwd-nvidia-470.... 2.7 KiB 886 KiB/s 00:00 [############] 100%
mhwd-db-0.6.5-15... 27.4 KiB 266 KiB/s 00:00 [############] 100%
nano-5.8-1-x86_64 584.3 KiB 492 KiB/s 00:01 [############] 100%
rpcbind-1.2.6-1-... 38.2 KiB 516 KiB/s 00:00 [############] 100%
nfsidmap-2.5.4-1... 57.9 KiB 197 KiB/s 00:00 [############] 100%
nfs-utils-2.5.4-... 376.3 KiB 511 KiB/s 00:01 [############] 100%
sudo-1.9.7.p2-1-... 1548.7 KiB 493 KiB/s 00:03 [############] 100%
systemd-sysvcomp... 6.2 KiB 0.00 B/s 00:00 [############] 100%
texinfo-6.8-1-x86_64 1418.6 KiB 523 KiB/s 00:03 [############] 100%
wireless-regdb-2... 10.1 KiB 3.27 MiB/s 00:00 [############] 100%
adobe-source-san... 2.5 MiB 506 KiB/s 00:05 [############] 100%
alsa-card-profil... 26.4 KiB 378 KiB/s 00:00 [############] 100%
alsa-topology-co... 13.5 KiB 92.5 KiB/s 00:00 [############] 100%
alsa-ucm-conf-1.... 45.0 KiB 617 KiB/s 00:00 [############] 100%
alsa-lib-1.2.5.1... 471.2 KiB 460 KiB/s 00:01 [############] 100%
alsa-utils-1.2.5... 1156.2 KiB 493 KiB/s 00:02 [############] 100%
protobuf-3.17.3-... 2.1 MiB 502 KiB/s 00:04 [############] 100%
aom-3.1.2-1-x86_64 2.5 MiB 518 KiB/s 00:05 [############] 100%
boost-libs-1.76.... 2.3 MiB 520 KiB/s 00:05 [############] 100%
gdk-pixbuf2-2.42... 518.8 KiB 449 KiB/s 00:01 [############] 100%
harfbuzz-2.8.2-1... 879.3 KiB 502 KiB/s 00:02 [############] 100%
fontconfig-2:2.1... 319.4 KiB 510 KiB/s 00:01 [############] 100%
libxft-2.3.4-1-x... 48.4 KiB 520 KiB/s 00:00 [############] 100%
pango-1:1.48.7-1... 352.7 KiB 432 KiB/s 00:01 [############] 100%
fuse-common-3.10... 2.7 KiB 0.00 B/s 00:00 [############] 100%
libappimage-1.0.... 160.8 KiB 371 KiB/s 00:00 [############] 100%
libdrm-2.4.107-1... 270.0 KiB 488 KiB/s 00:01 [############] 100%
llvm-libs-12.0.1... 24.4 MiB 518 KiB/s 00:48 [############] 100%
vulkan-icd-loade... 109.4 KiB 443 KiB/s 00:00 [############] 100%
mesa-21.1.6-1-x86_64 17.5 MiB 526 KiB/s 00:34 [############] 100%
libwacom-1.11-1-... 101.6 KiB 321 KiB/s 00:00 [############] 100%
libinput-1.18.1-... 285.6 KiB 377 KiB/s 00:01 [############] 100%
xkeyboard-config... 732.2 KiB 481 KiB/s 00:02 [############] 100%
qt5-base-5.15.2+... 13.0 MiB 521 KiB/s 00:26 [############] 100%
appstream-0.14.4... 2.0 MiB 502 KiB/s 00:04 [############] 100%
libpulse-15.0-1-... 405.7 KiB 430 KiB/s 00:01 [############] 100%
tdb-1.4.5-1-x86_64 73.3 KiB 247 KiB/s 00:00 [############] 100%
libcanberra-0.30... 91.6 KiB 280 KiB/s 00:00 [############] 100%
at-spi2-core-2.4... 259.8 KiB 429 KiB/s 00:01 [############] 100%
gtk3-1:3.24.30-1... 7.7 MiB 522 KiB/s 00:15 [############] 100%
python-urllib3-1... 182.6 KiB 301 KiB/s 00:01 [############] 100%
python-requests-... 91.7 KiB 312 KiB/s 00:00 [############] 100%
appstream-glib-0... 482.4 KiB 439 KiB/s 00:01 [############] 100%
appstream-qt-0.1... 80.3 KiB 257 KiB/s 00:00 [############] 100%
archlinux-appstr... 18.4 MiB 525 KiB/s 00:36 [############] 100%
upower-0.99.12-2... 173.9 KiB 370 KiB/s 00:00 [############] 100%
gptfdisk-1.0.8-1... 202.2 KiB 314 KiB/s 00:01 [############] 100%
libbytesize-2.6-... 24.2 KiB 332 KiB/s 00:00 [############] 100%
js78-78.12.0-1-x... 10.5 MiB 517 KiB/s 00:21 [############] 100%
udisks2-2.9.3-1-... 986.1 KiB 491 KiB/s 00:02 [############] 100%
solid-5.84.0-1-x... 856.3 KiB 460 KiB/s 00:02 [############] 100%
kcoreaddons-5.84... 1367.2 KiB 491 KiB/s 00:03 [############] 100%
kwidgetsaddons-5... 5.1 MiB 533 KiB/s 00:10 [############] 100%
kjobwidgets-5.84... 351.3 KiB 379 KiB/s 00:01 [############] 100%
kdbusaddons-5.84... 225.5 KiB 546 KiB/s 00:00 [############] 100%
kconfig-5.84.0-1... 1115.4 KiB 489 KiB/s 00:02 [############] 100%
kwindowsystem-5.... 764.6 KiB 511 KiB/s 00:01 [############] 100%
kcrash-5.84.0-1-... 124.9 KiB 281 KiB/s 00:00 [############] 100%
kglobalaccel-5.8... 248.1 KiB 636 KiB/s 00:00 [############] 100%
polkit-qt5-0.114... 75.9 KiB 123 KiB/s 00:01 [############] 100%
kauth-5.84.0-1-x... 328.7 KiB 452 KiB/s 00:01 [############] 100%
kcodecs-5.84.0-1... 363.1 KiB 400 KiB/s 00:01 [############] 100%
qt5-declarative-... 4.9 MiB 510 KiB/s 00:10 [############] 100%
qt5-wayland-5.15... 1125.9 KiB 488 KiB/s 00:02 [############] 100%
kguiaddons-5.84.... 308.4 KiB 467 KiB/s 00:01 [############] 100%
ki18n-5.84.0-1-x... 1551.6 KiB 500 KiB/s 00:03 [############] 100%
kconfigwidgets-5... 1226.7 KiB 506 KiB/s 00:02 [############] 100%
kitemviews-5.84.... 602.0 KiB 446 KiB/s 00:01 [############] 100%
karchive-5.84.0-... 373.9 KiB 519 KiB/s 00:01 [############] 100%
kiconthemes-5.84... 503.4 KiB 491 KiB/s 00:01 [############] 100%
kxmlgui-5.84.0-1... 1672.0 KiB 528 KiB/s 00:03 [############] 100%
kbookmarks-5.84.... 587.2 KiB 439 KiB/s 00:01 [############] 100%
knotifications-5... 456.9 KiB 423 KiB/s 00:01 [############] 100%
kservice-5.84.0-... 733.3 KiB 469 KiB/s 00:02 [############] 100%
kwallet-5.84.0-1... 509.1 KiB 413 KiB/s 00:01 [############] 100%
kcompletion-5.84... 700.7 KiB 550 KiB/s 00:01 [############] 100%
sonnet-5.84.0-1-... 641.8 KiB 454 KiB/s 00:01 [############] 100%
ktextwidgets-5.8... 852.6 KiB 268 KiB/s 00:03 [############] 100%
kded-5.84.0-1-x86_64 56.3 KiB 228 KiB/s 00:00 [############] 100%
kio-5.84.0-2-x86_64 7.5 MiB 516 KiB/s 00:15 [############] 100%
kparts-5.84.0-1-... 1024.9 KiB 478 KiB/s 00:02 [############] 100%
kpty-5.84.0-1-x86_64 201.0 KiB 353 KiB/s 00:01 [############] 100%
kitemmodels-5.84... 700.1 KiB 506 KiB/s 00:01 [############] 100%
ark-21.04.3-1-x86_64 1412.3 KiB 494 KiB/s 00:03 [############] 100%
attica-5.84.0-1-... 545.1 KiB 474 KiB/s 00:01 [############] 100%
exiv2-0.27.4-2-x... 2040.0 KiB 521 KiB/s 00:04 [############] 100%
poppler-21.08.0-... 1333.4 KiB 509 KiB/s 00:03 [############] 100%
poppler-qt5-21.0... 191.0 KiB 503 KiB/s 00:00 [############] 100%
celt-0.11.3-4-x86_64 73.7 KiB 303 KiB/s 00:00 [############] 100%
jack2-1.9.19-2-x... 588.0 KiB 564 KiB/s 00:01 [############] 100%
libva-2.12.0-1-x... 179.1 KiB 365 KiB/s 00:00 [############] 100%
zimg-3.0.2-1-x86_64 283.1 KiB 366 KiB/s 00:01 [############] 100%
ffmpeg-2:4.4-4-x... 10.4 MiB 507 KiB/s 00:21 [############] 100%
kfilemetadata-5.... 379.7 KiB 414 KiB/s 00:01 [############] 100%
kidletime-5.84.0... 135.5 KiB 320 KiB/s 00:00 [############] 100%
baloo-5.84.0-1-x... 579.0 KiB 458 KiB/s 00:01 [############] 100%
baloo-widgets-21... 119.0 KiB 368 KiB/s 00:00 [############] 100%
bluez-5.60-1-x86_64 873.0 KiB 472 KiB/s 00:02 [############] 100%
bluez-qt-5.84.0-... 907.0 KiB 474 KiB/s 00:02 [############] 100%
kpackage-5.84.0-... 338.3 KiB 414 KiB/s 00:01 [############] 100%
kdeclarative-5.8... 513.8 KiB 491 KiB/s 00:01 [############] 100%
bluedevil-1:5.22... 298.8 KiB 298 KiB/s 00:01 [############] 100%
bluez-libs-5.60-... 91.9 KiB 179 KiB/s 00:01 [############] 100%
syndication-5.84... 1009.0 KiB 467 KiB/s 00:02 [############] 100%
knewstuff-5.84.0... 1947.6 KiB 506 KiB/s 00:04 [############] 100%
frameworkintegra... 1588.1 KiB 499 KiB/s 00:03 [############] 100%
kdecoration-5.22... 73.2 KiB 314 KiB/s 00:00 [############] 100%
breeze-icons-5.8... 6.5 MiB 506 KiB/s 00:13 [############] 100%
kwayland-5.84.0-... 3.0 MiB 522 KiB/s 00:06 [############] 100%
breeze-5.22.4-1-... 31.2 MiB 519 KiB/s 01:02 [############] 100%
fmt-8.0.1-1-x86_64 428.4 KiB 457 KiB/s 00:01 [############] 100%
cfitsio-1:4.0.0-... 553.7 KiB 468 KiB/s 00:01 [############] 100%
ckbcomp-1.204-1-any 50.5 KiB 336 KiB/s 00:00 [############] 100%
imagemagick-7.1.... 2.5 MiB 523 KiB/s 00:05 [############] 100%
cups-filters-1.2... 883.4 KiB 499 KiB/s 00:02 [############] 100%
dbus-python-1.2.... 2.8 MiB 512 KiB/s 00:06 [############] 100%
kdnssd-5.84.0-1-... 311.0 KiB 430 KiB/s 00:01 [############] 100%
talloc-2.3.3-1-x... 48.6 KiB 279 KiB/s 00:00 [############] 100%
tevent-1:0.11.0-... 53.1 KiB 140 KiB/s 00:00 [############] 100%
ldb-2:2.3.0-1-x86_64 215.6 KiB 355 KiB/s 00:01 [############] 100%
smbclient-4.14.6... 6.9 MiB 521 KiB/s 00:13 [############] 100%
syntax-highlight... 1344.7 KiB 494 KiB/s 00:03 [############] 100%
kdsoap-2.0.0-1-x... 489.5 KiB 459 KiB/s 00:01 [############] 100%
kdsoap-ws-discov... 281.0 KiB 344 KiB/s 00:01 [############] 100%
kio-extras-21.04... 1239.3 KiB 506 KiB/s 00:02 [############] 100%
kcmutils-5.84.0-... 633.8 KiB 472 KiB/s 00:01 [############] 100%
kinit-5.84.0-1-x... 137.6 KiB 350 KiB/s 00:00 [############] 100%
kactivities-5.84... 321.8 KiB 447 KiB/s 00:01 [############] 100%
dolphin-21.04.3-... 4.0 MiB 519 KiB/s 00:08 [############] 100%
dolphin-plugins-... 395.8 KiB 412 KiB/s 00:01 [############] 100%
editorconfig-cor... 30.2 KiB 302 KiB/s 00:00 [############] 100%
enchant-2.3.0-1-... 53.4 KiB 232 KiB/s 00:00 [############] 100%
f2fs-tools-1.14.... 192.8 KiB 507 KiB/s 00:00 [############] 100%
ffmpegthumbs-21.... 34.2 KiB 102 KiB/s 00:00 [############] 100%
filelight-21.04.... 755.6 KiB 485 KiB/s 00:02 [############] 100%
firefox-91.0-0.1... 78.4 MiB 524 KiB/s 02:33 [############] 100%
ostree-2021.3-1-... 640.7 KiB 498 KiB/s 00:01 [############] 100%
libfreeaptx-0.1.... 18.6 KiB 0.00 B/s 00:00 [############] 100%
pipewire-1:0.3.3... 1325.5 KiB 490 KiB/s 00:03 [############] 100%
kirigami2-5.84.0... 487.1 KiB 462 KiB/s 00:01 [############] 100%
plasma-framework... 4.0 MiB 520 KiB/s 00:08 [############] 100%
xdg-desktop-port... 215.7 KiB 420 KiB/s 00:01 [############] 100%
libmm-glib-1.16.... 436.5 KiB 412 KiB/s 00:01 [############] 100%
flatpak-1.11.2-1... 1497.8 KiB 484 KiB/s 00:03 [############] 100%
fluidsynth-2.2.2... 259.1 KiB 274 KiB/s 00:01 [############] 100%
fuse3-3.10.4-1-x... 119.7 KiB 249 KiB/s 00:00 [############] 100%
libmbim-1.26.0-1... 347.1 KiB 376 KiB/s 00:01 [############] 100%
gd-2.3.2-4-x86_64 160.7 KiB 426 KiB/s 00:00 [############] 100%
glslang-11.5.0-1... 3.5 MiB 527 KiB/s 00:07 [############] 100%
glu-9.0.2-1-x86_64 142.5 KiB 360 KiB/s 00:00 [############] 100%
gst-plugins-bad-... 2028.2 KiB 504 KiB/s 00:04 [############] 100%
imath-3.1.2-1-x86_64 4.7 MiB 518 KiB/s 00:09 [############] 100%
openexr-3.1.1-1-... 1142.7 KiB 521 KiB/s 00:02 [############] 100%
mpg123-1.28.2-1-... 432.7 KiB 496 KiB/s 00:01 [############] 100%
imlib2-1.7.2-1-x... 532.3 KiB 466 KiB/s 00:01 [############] 100%
hwloc-2.5.0-1-x86_64 514.2 KiB 518 KiB/s 00:01 [############] 100%
openmpi-4.1.1-2-... 3.3 MiB 520 KiB/s 00:06 [############] 100%
gst-plugins-bad-... 1048.0 KiB 502 KiB/s 00:02 [############] 100%
libkipi-21.04.3-... 104.5 KiB 449 KiB/s 00:00 [############] 100%
jasper-2.0.32-1-... 270.1 KiB 406 KiB/s 00:01 [############] 100%
libkdcraw-21.04.... 42.9 KiB 493 KiB/s 00:00 [############] 100%
signon-kwallet-e... 13.4 KiB 0.00 B/s 00:00 [############] 100%
re2-1:20210801-1... 173.1 KiB 339 KiB/s 00:01 [############] 100%
qt5-webengine-5.... 48.6 MiB 516 KiB/s 01:36 [############] 100%
kaccounts-integr... 122.7 KiB 312 KiB/s 00:00 [############] 100%
purpose-5.84.0-1... 323.0 KiB 472 KiB/s 00:01 [############] 100%
gwenview-21.04.3... 6.7 MiB 511 KiB/s 00:13 [############] 100%
harfbuzz-icu-2.8... 7.7 KiB 0.00 B/s 00:00 [############] 100%
perl-alien-build... 329.8 KiB 430 KiB/s 00:01 [############] 100%
libidn-1.38-1-x86_64 220.3 KiB 416 KiB/s 00:01 [############] 100%
python-setuptool... 556.8 KiB 445 KiB/s 00:01 [############] 100%
hplip-1:3.21.6-1... 19.7 MiB 518 KiB/s 00:39 [############] 100%
perl-http-messag... 75.3 KiB 235 KiB/s 00:00 [############] 100%
perl-libwww-6.55... 137.4 KiB 292 KiB/s 00:00 [############] 100%
intel-ucode-2021... 3.7 MiB 506 KiB/s 00:07 [############] 100%
libkcddb-21.04.3... 529.6 KiB 470 KiB/s 00:01 [############] 100%
knotifyconfig-5.... 204.2 KiB 378 KiB/s 00:01 [############] 100%
k3b-1:21.04.3-1-... 11.0 MiB 523 KiB/s 00:22 [############] 100%
kaccounts-provid... 72.5 KiB 141 KiB/s 00:01 [############] 100%
kactivities-stat... 292.6 KiB 418 KiB/s 00:01 [############] 100%
kactivitymanager... 205.6 KiB 250 KiB/s 00:01 [############] 100%
kamera-21.04.3-1... 168.1 KiB 407 KiB/s 00:00 [############] 100%
libgit2-1:1.1.1-... 595.7 KiB 459 KiB/s 00:01 [############] 100%
ktexteditor-5.84... 3.5 MiB 516 KiB/s 00:07 [############] 100%
kate-21.04.3-1-x... 8.1 MiB 520 KiB/s 00:16 [############] 100%
kcalc-21.04.3-1-... 577.6 KiB 500 KiB/s 00:01 [############] 100%
kcontacts-1:5.84... 1001.3 KiB 476 KiB/s 00:02 [############] 100%
kdesu-5.84.0-1-x... 234.4 KiB 429 KiB/s 00:01 [############] 100%
kde-cli-tools-5.... 922.0 KiB 511 KiB/s 00:02 [############] 100%
kde-gtk-config-5... 67.1 KiB 320 KiB/s 00:00 [############] 100%
kpeople-5.84.0-1... 394.8 KiB 455 KiB/s 00:01 [############] 100%
kdeconnect-21.04... 922.5 KiB 512 KiB/s 00:02 [############] 100%
libkexiv2-21.04.... 153.3 KiB 389 KiB/s 00:00 [############] 100%
kdegraphics-thum... 40.1 KiB 550 KiB/s 00:00 [############] 100%
kunitconversion-... 1043.2 KiB 501 KiB/s 00:02 [############] 100%
kemoticons-5.84.... 1857.7 KiB 509 KiB/s 00:04 [############] 100%
kdelibs4support-... 3.5 MiB 510 KiB/s 00:07 [############] 100%
kdenetwork-files... 100.8 KiB 280 KiB/s 00:00 [############] 100%
libksysguard-5.2... 1054.3 KiB 505 KiB/s 00:02 [############] 100%
ksystemstats-5.2... 159.1 KiB 392 KiB/s 00:00 [############] 100%
libqalculate-3.2... 2.2 MiB 511 KiB/s 00:04 [############] 100%
kholidays-1:5.84... 390.9 KiB 422 KiB/s 00:01 [############] 100%
threadweaver-5.8... 445.3 KiB 415 KiB/s 00:01 [############] 100%
krunner-5.84.0-1... 374.2 KiB 404 KiB/s 00:01 [############] 100%
milou-5.22.4-1-x... 87.9 KiB 170 KiB/s 00:01 [############] 100%
prison-5.84.0-1-... 158.2 KiB 410 KiB/s 00:00 [############] 100%
layer-shell-qt-5... 22.6 KiB 282 KiB/s 00:00 [############] 100%
kscreenlocker-5.... 194.8 KiB 375 KiB/s 00:01 [############] 100%
kwayland-server-... 1214.8 KiB 512 KiB/s 00:02 [############] 100%
kwin-5.22.4-1-x86_64 6.8 MiB 521 KiB/s 00:13 [############] 100%
qqc2-desktop-sty... 73.4 KiB 242 KiB/s 00:00 [############] 100%
plasma-integrati... 156.9 KiB 398 KiB/s 00:00 [############] 100%
libkscreen-5.22.... 346.9 KiB 467 KiB/s 00:01 [############] 100%
kquickcharts-5.8... 119.8 KiB 408 KiB/s 00:00 [############] 100%
kio-fuse-5.0.1-1... 68.7 KiB 267 KiB/s 00:00 [############] 100%
plasma-workspace... 10.4 MiB 524 KiB/s 00:20 [############] 100%
kdeplasma-addons... 963.3 KiB 501 KiB/s 00:02 [############] 100%
kdoctools-5.84.0... 595.5 KiB 454 KiB/s 00:01 [############] 100%
keditbookmarks-2... 322.1 KiB 429 KiB/s 00:01 [############] 100%
kfind-21.04.3-1-... 434.1 KiB 411 KiB/s 00:01 [############] 100%
systemsettings-5... 340.3 KiB 493 KiB/s 00:01 [############] 100%
kgamma5-5.22.4-1... 158.9 KiB 336 KiB/s 00:00 [############] 100%
kget-21.04.3-1-x... 5.7 MiB 524 KiB/s 00:11 [############] 100%
kjs-5.84.0-1-x86_64 404.2 KiB 480 KiB/s 00:01 [############] 100%
khtml-5.84.0-1-x... 2.8 MiB 534 KiB/s 00:05 [############] 100%
khelpcenter-21.0... 4.7 MiB 514 KiB/s 00:09 [############] 100%
khotkeys-5.22.4-... 2011.5 KiB 522 KiB/s 00:04 [############] 100%
kimageformats-5.... 132.0 KiB 314 KiB/s 00:00 [############] 100%
kinfocenter-5.22... 1508.4 KiB 501 KiB/s 00:03 [############] 100%
kmenuedit-5.22.4... 1038.3 KiB 493 KiB/s 00:02 [############] 100%
konsole-21.04.3-... 1404.8 KiB 516 KiB/s 00:03 [############] 100%
konversation-21.... 4.7 MiB 517 KiB/s 00:09 [############] 100%
kpmcore-21.04.3-... 661.3 KiB 501 KiB/s 00:01 [############] 100%
kscreen-5.22.4-1... 233.3 KiB 546 KiB/s 00:00 [############] 100%
ksshaskpass-5.22... 27.9 KiB 288 KiB/s 00:00 [############] 100%
ksysguard-5.22.0... 716.8 KiB 572 KiB/s 00:01 [############] 100%
ksystemlog-21.04... 2.1 MiB 534 KiB/s 00:04 [############] 100%
kwallet-pam-5.22... 12.2 KiB 0.00 B/s 00:00 [############] 100%
kwalletmanager-2... 945.2 KiB 533 KiB/s 00:02 [############] 100%
kwayland-integra... 30.6 KiB 71.1 KiB/s 00:00 [############] 100%
kwrited-5.22.4-1... 17.4 KiB 0.00 B/s 00:00 [############] 100%
poppler-glib-21.... 255.8 KiB 477 KiB/s 00:01 [############] 100%
libksane-21.04.3... 178.3 KiB 477 KiB/s 00:00 [############] 100%
libktorrent-21.0... 715.9 KiB 488 KiB/s 00:01 [############] 100%
libnm-1.32.6-1-x... 1065.4 KiB 461 KiB/s 00:02 [############] 100%
shaderc-2021.1-1... 122.6 KiB 299 KiB/s 00:00 [############] 100%
libplacebo-3.120... 295.6 KiB 516 KiB/s 00:01 [############] 100%
libsidplayfp-2.2... 140.5 KiB 346 KiB/s 00:00 [############] 100%
libtorrent-raste... 2.4 MiB 514 KiB/s 00:05 [############] 100%
libva-mesa-drive... 3.0 MiB 476 KiB/s 00:06 [############] 100%
libwpe-1.10.1-1-... 47.8 KiB 319 KiB/s 00:00 [############] 100%
libxfont2-2.0.5-... 116.1 KiB 366 KiB/s 00:00 [############] 100%
libpamac-11.0.1-... 799.3 KiB 501 KiB/s 00:02 [############] 100%
pamac-cli-10.1.3... 64.6 KiB 387 KiB/s 00:00 [############] 100%
libhandy-1.2.3-1... 661.1 KiB 470 KiB/s 00:01 [############] 100%
pamac-gtk-10.1.3... 178.0 KiB 417 KiB/s 00:00 [############] 100%
manjaro-hello-0.... 120.5 KiB 259 KiB/s 00:00 [############] 100%
memtest86+-5.31b... 55.0 KiB 247 KiB/s 00:00 [############] 100%
mesa-vdpau-21.1.... 3.1 MiB 512 KiB/s 00:06 [############] 100%
modemmanager-1.1... 1238.1 KiB 492 KiB/s 00:03 [############] 100%
modemmanager-qt-... 570.5 KiB 470 KiB/s 00:01 [############] 100%
mpd-0.22.9-2-x86_64 863.9 KiB 486 KiB/s 00:02 [############] 100%
networkmanager-1... 3.4 MiB 459 KiB/s 00:08 [############] 100%
networkmanager-q... 1810.0 KiB 498 KiB/s 00:04 [############] 100%
noto-fonts-emoji... 8.4 MiB 516 KiB/s 00:17 [############] 100%
nss-mdns-0.15.1-... 11.1 KiB 0.00 B/s 00:00 [############] 100%
okular-21.04.3-2... 6.5 MiB 526 KiB/s 00:13 [############] 100%
openvpn-2.5.3-1-... 564.5 KiB 473 KiB/s 00:01 [############] 100%
oxygen-5.22.4-1-... 4.6 MiB 507 KiB/s 00:09 [############] 100%
oxygen-icons-1:5... 30.5 MiB 526 KiB/s 00:59 [############] 100%
libpamac-flatpak... 31.3 KiB 377 KiB/s 00:00 [############] 100%
squashfs-tools-4... 150.7 KiB 359 KiB/s 00:00 [############] 100%
snapd-2.51.3-2-x... 10.2 MiB 519 KiB/s 00:20 [############] 100%
libpamac-snap-pl... 28.1 KiB 351 KiB/s 00:00 [############] 100%
partitionmanager... 2.1 MiB 509 KiB/s 00:04 [############] 100%
perl-file-basedi... 14.5 KiB 0.00 B/s 00:00 [############] 100%
polkit-kde-agent... 62.7 KiB 125 KiB/s 00:01 [############] 100%
plasma-desktop-5... 16.6 MiB 525 KiB/s 00:32 [############] 100%
plasma-nm-5.22.4... 1443.5 KiB 487 KiB/s 00:03 [############] 100%
pulseaudio-15.0-... 1192.2 KiB 504 KiB/s 00:02 [############] 100%
plasma-pa-5.22.4... 234.4 KiB 416 KiB/s 00:01 [############] 100%
plasma-systemmon... 199.4 KiB 360 KiB/s 00:01 [############] 100%
plasma-workspace... 49.0 MiB 506 KiB/s 01:39 [############] 100%
powerdevil-5.22.... 844.7 KiB 389 KiB/s 00:02 [############] 100%
print-manager-21... 454.7 KiB 426 KiB/s 00:01 [############] 100%
pulseaudio-bluet... 77.5 KiB 343 KiB/s 00:00 [############] 100%
pulseaudio-equal... 32.4 KiB 112 KiB/s 00:00 [############] 100%
pulseaudio-jack-... 18.9 KiB 189 KiB/s 00:00 [############] 100%
pulseaudio-lirc-... 7.6 KiB 0.00 B/s 00:00 [############] 100%
pulseaudio-rtp-1... 55.6 KiB 260 KiB/s 00:00 [############] 100%
pulseaudio-zeroc... 23.3 KiB 291 KiB/s 00:00 [############] 100%
python-cffi-1.14... 225.6 KiB 412 KiB/s 00:01 [############] 100%
python-tomli-1.2... 19.1 KiB 49.4 KiB/s 00:00 [############] 100%
python-pep517-0.... 31.3 KiB 347 KiB/s 00:00 [############] 100%
python-resolveli... 23.5 KiB 270 KiB/s 00:00 [############] 100%
python-pip-20.3.... 421.2 KiB 461 KiB/s 00:01 [############] 100%
qt5-script-5.15.... 971.4 KiB 351 KiB/s 00:03 [############] 100%
qt5-tools-5.15.2... 5.4 MiB 517 KiB/s 00:11 [############] 100%
rsync-3.2.3-4-x86_64 308.3 KiB 451 KiB/s 00:01 [############] 100%
rubygems-3.2.21-... 226.4 KiB 560 KiB/s 00:00 [############] 100%
ruby-3.0.2-1-x86_64 3.2 MiB 516 KiB/s 00:06 [############] 100%
samba-4.14.6-1-x... 7.8 MiB 484 KiB/s 00:16 [############] 100%
xf86-input-libin... 37.3 KiB 445 KiB/s 00:00 [############] 100%
xorg-server-comm... 28.4 KiB 161 KiB/s 00:00 [############] 100%
xorg-server-1.20... 1426.1 KiB 519 KiB/s 00:03 [############] 100%
sddm-kcm-5.22.4-... 107.2 KiB 403 KiB/s 00:00 [############] 100%
sof-firmware-1.8... 561.7 KiB 465 KiB/s 00:01 [############] 100%
spectacle-21.04.... 1299.5 KiB 497 KiB/s 00:03 [############] 100%
wpebackend-fdo-1... 30.8 KiB 466 KiB/s 00:00 [############] 100%
webkit2gtk-2.32.... 23.0 MiB 523 KiB/s 00:45 [############] 100%
thunderbird-78.1... 57.3 MiB 526 KiB/s 01:52 [############] 100%
vlc-3.0.16-3-x86_64 11.8 MiB 521 KiB/s 00:23 [############] 100%
vpnc-1:0.5.3.r49... 93.1 KiB 412 KiB/s 00:00 [############] 100%
vulkan-intel-21.... 2.2 MiB 510 KiB/s 00:04 [############] 100%
vulkan-radeon-21... 1667.1 KiB 511 KiB/s 00:03 [############] 100%
xf86-video-amdgp... 68.7 KiB 257 KiB/s 00:00 [############] 100%
yakuake-21.04.3-... 403.0 KiB 456 KiB/s 00:01 [############] 100%
android-tools-31... 1787.2 KiB 518 KiB/s 00:03 [############] 100%
appimagelauncher... 532.0 KiB 503 KiB/s 00:01 [############] 100%
python-certifi-2... 139.9 KiB 393 KiB/s 00:00 [############] 100%
libmfx-21.2.3-1-... 53.6 KiB 208 KiB/s 00:00 [############] 100%
breath2-icon-the... 7.1 MiB 524 KiB/s 00:14 [############] 100%
breath2-wallpape... 533.0 KiB 458 KiB/s 00:01 [############] 100%
cdrtools-3.02a09... 901.0 KiB 446 KiB/s 00:02 [############] 100%
ceph-libs-15.2.1... 12.4 MiB 522 KiB/s 00:24 [############] 100%
cpupower-5.13-1-... 157.7 KiB 607 KiB/s 00:00 [############] 100%
libxmlb-0.3.2-1-... 128.0 KiB 533 KiB/s 00:00 [############] 100%
libjcat-0.1.8-1-... 63.5 KiB 170 KiB/s 00:00 [############] 100%
fwupd-efi-1.1-1-... 26.3 KiB 101 KiB/s 00:00 [############] 100%
fwupd-1.6.2-1-x86_64 3.0 MiB 525 KiB/s 00:06 [############] 100%
game-devices-ude... 27.1 KiB 327 KiB/s 00:00 [############] 100%
libavif-0.9.2-1-... 103.9 KiB 422 KiB/s 00:00 [############] 100%
python-more-iter... 62.1 KiB 214 KiB/s 00:00 [############] 100%
hwinfo-21.76-1-x... 985.8 KiB 513 KiB/s 00:02 [############] 100%
inxi-3.3.06.1-1-any 311.0 KiB 527 KiB/s 00:01 [############] 100%
manjaro-applicat... 67.0 KiB 138 KiB/s 00:00 [############] 100%
plasma5-themes-b... 31.1 MiB 520 KiB/s 01:01 [############] 100%
manjaro-kde-sett... 63.7 KiB 277 KiB/s 00:00 [############] 100%
pcsclite-1.9.2-2... 99.3 KiB 273 KiB/s 00:00 [############] 100%
pulseaudio-ctl-1... 9.8 KiB 0.00 B/s 00:00 [############] 100%
python-pillow-8.... 644.6 KiB 492 KiB/s 00:01 [############] 100%
python-reportlab... 2.3 MiB 528 KiB/s 00:04 [############] 100%
qbittorrent-4.3.... 6.2 MiB 518 KiB/s 00:12 [############] 100%
ruby-irb-1.3.6-1-any 63.3 KiB 561 KiB/s 00:00 [############] 100%
sddm-breath2-the... 441.8 KiB 522 KiB/s 00:01 [############] 100%
sshfs-3.7.2-1-x86_64 35.6 KiB 445 KiB/s 00:00 [############] 100%
xapp-2.2.3-2-x86_64 193.6 KiB 461 KiB/s 00:00 [############] 100%
zsh-theme-powerl... 1211.7 KiB 509 KiB/s 00:02 [############] 100%
lib32-alsa-lib-1... 387.3 KiB 472 KiB/s 00:01 [############] 100%
lib32-e2fsprogs-... 233.0 KiB 555 KiB/s 00:00 [############] 100%
lib32-libxcrypt-... 76.2 KiB 635 KiB/s 00:00 [############] 100%
lib32-libldap-2.... 193.0 KiB 486 KiB/s 00:00 [############] 100%
lib32-curl-7.78.... 283.5 KiB 388 KiB/s 00:01 [############] 100%
lib32-libcap-2.5... 24.1 KiB 180 KiB/s 00:00 [############] 100%
lib32-systemd-24... 764.9 KiB 509 KiB/s 00:02 [############] 100%
lib32-util-linux... 440.1 KiB 495 KiB/s 00:01 [############] 100%
lib32-libxfixes-... 10.2 KiB 0.00 B/s 00:00 [############] 100%
lib32-libpulse-1... 282.1 KiB 651 KiB/s 00:00 [############] 100%
lib32-tdb-1.4.5-... 44.9 KiB 408 KiB/s 00:00 [############] 100%
lib32-libcanberr... 65.2 KiB 261 KiB/s 00:00 [############] 100%
lib32-libdrm-2.4... 149.6 KiB 241 KiB/s 00:01 [############] 100%
lib32-libtasn1-4... 39.0 KiB 244 KiB/s 00:00 [############] 100%
lib32-llvm-libs-... 27.3 MiB 511 KiB/s 00:55 [############] 100%
lib32-libva-mesa... 3.0 MiB 508 KiB/s 00:06 [############] 100%
lib32-vulkan-icd... 119.1 KiB 327 KiB/s 00:00 [############] 100%
lib32-mesa-21.1.... 14.3 MiB 528 KiB/s 00:28 [############] 100%
lib32-mesa-vdpau... 3.1 MiB 506 KiB/s 00:06 [############] 100%
lib32-nspr-4.32-... 117.3 KiB 244 KiB/s 00:00 [############] 100%
lib32-sqlite-3.3... 540.9 KiB 451 KiB/s 00:01 [############] 100%
lib32-p11-kit-0.... 389.2 KiB 344 KiB/s 00:01 [############] 100%
lib32-nss-3.68-1... 1148.8 KiB 510 KiB/s 00:02 [############] 100%
lib32-vulkan-int... 2.1 MiB 521 KiB/s 00:04 [############] 100%
lib32-vulkan-rad... 1715.6 KiB 516 KiB/s 00:03 [############] 100%
steam-manjaro-1.... 3.3 MiB 515 KiB/s 00:06 [############] 100%
(426/426) checking keys in keyring [############] 100%
(426/426) checking package integrity [############] 100%
error: llvm-libs: signature from "Jürgen Hötzel (Arch Linux developer key) <juergen@archlinux.org>" is invalid
:: File /var/cache/pacman/pkg/llvm-libs-12.0.1-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: linux-firmware: signature from "Helmut Stult (schinfo) <helmut.stult@schinfo.de>" is invalid
:: File /var/cache/pacman/pkg/linux-firmware-20210719.r1990.168452e-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: thunderbird: signature from "Mark Wagie <mark@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/thunderbird-78.13.0-0.1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
I would try what is suggested here:
It based on an old Arch thread:
https://bbs.archlinux.org/viewtopic.php?id=203168
When I get to the last step I get an error. The computer froze up when I was about to reply to this thread so I took a picture of the error.
EDIT:
This is the error:
[sugarcookie@sugarcookie-defaultstring ~]$ sudo pacman-key --refresh-keys
gpg: refreshing 126 keys from hkps://hkps.pool.sks-keyservers.net
gpg: keyserver refresh failed: No name
==> ERROR: A specified local key could not be updated from a keyserver.
Wow so I just ran some diagnostics on this PC and the memory ram failed a bunch of tests wow! I am returning this PC and getting a different one, I will be back.
