System boot failed after change kernel from 4.19 to 6.1
My system boot stuck forever after change kernel from 4.19 to 6.1.
Here is the ouput puts of journalctl --boot=-1 --priority=3 --no-pager --catalog
sudo journalctl --boot=-1 --priority=3 --no-pager --catalog
Jul 19 09:51:19 jarod-pc kernel: ACPI Error: Needed [Integer/String/Buffer], found [Device] 00000000fa2b89ef (20220331/exresop-388)
Jul 19 09:51:19 jarod-pc kernel: ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Add] (20220331/dswexec-431)
Jul 19 09:52:50 jarod-pc systemd[1]: Failed to mount /boot/efi.
░░ Subject: A start job for unit boot-efi.mount has failed
░░ Defined-By: systemd
░░ A start job for unit boot-efi.mount has finished with a failure.
░░ The job identifier is 19 and the job result is failed.
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:00:15.0: Worker [432] processing SEQNUM=3932 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 05901221-D566-11D1-B2F0-00A0C9062910-3: Worker [389] processing SEQNUM=4503 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 86CCFD48-205E-4A77-9C48-2021CBEDE341: Worker [420] processing SEQNUM=4499 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:00:15.1: Worker [411] processing SEQNUM=3933 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:00:16.0: Worker [438] processing SEQNUM=3936 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:00:19.0: Worker [388] processing SEQNUM=3969 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu11: Worker [384] processing SEQNUM=4061 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 95F24279-4D7B-4334-9387-ACCDC67EF61C: Worker [397] processing SEQNUM=4481 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 05901221-D566-11D1-B2F0-00A0C9062910-1: Worker [429] processing SEQNUM=4476 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 05901221-D566-11D1-B2F0-00A0C9062910: Worker [393] processing SEQNUM=4471 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu6: Worker [400] processing SEQNUM=4070 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu9: Worker [435] processing SEQNUM=4073 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu7: Worker [394] processing SEQNUM=4071 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu8: Worker [437] processing SEQNUM=4072 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu5: Worker [402] processing SEQNUM=4069 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu4: Worker [419] processing SEQNUM=4068 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu3: Worker [415] processing SEQNUM=4067 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu2: Worker [436] processing SEQNUM=4066 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu15: Worker [434] processing SEQNUM=4065 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu14: Worker [403] processing SEQNUM=4064 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu12: Worker [439] processing SEQNUM=4062 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu13: Worker [440] processing SEQNUM=4063 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 05901221-D566-11D1-B2F0-00A0C9062910-2: Worker [390] processing SEQNUM=4484 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu0: Worker [391] processing SEQNUM=4058 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu1: Worker [423] processing SEQNUM=4059 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: cpu10: Worker [410] processing SEQNUM=4060 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: spi0.0: Worker [430] processing SEQNUM=3995 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:00:1f.3: Worker [386] processing SEQNUM=3991 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:00:1f.4: Worker [425] processing SEQNUM=3992 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:02:00.0: Worker [406] processing SEQNUM=3976 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:00:19.1: Worker [401] processing SEQNUM=3970 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:00:15.2: Worker [428] processing SEQNUM=3934 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:01:00.1: Worker [392] processing SEQNUM=3916 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:01:00.0: Worker [409] processing SEQNUM=3915 killed
Jul 19 09:54:19 jarod-pc systemd-udevd[381]: 0000:00:15.3: Worker [433] processing SEQNUM=3935 killed
Jul 19 09:54:20 jarod-pc systemd-udevd[381]: 1-9:1.0: Worker [426] processing SEQNUM=3926 killed
Jul 19 09:54:20 jarod-pc systemd-udevd[381]: 1-1:1.0: Worker [396] processing SEQNUM=3924 killed
Jul 19 09:54:20 jarod-pc systemd-udevd[381]: 1-9:1.1: Worker [385] processing SEQNUM=3927 killed
It seems something to do with ACPI.
And here is my inxi -Fazy
  Kernel: 4.19.288-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
    root=UUID=07c0bd48-c352-458c-87ae-35b223ab700b rw udev.log_priority=3
    udev.log_priority=3
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop System: HP product: HP ZHAN 99 Pro G4 Microtower PC v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: HP model: 885F v: A (SMVB) serial: <superuser required> UEFI: AMI
    v: F.02 date: 04/01/2021
  Info: model: 11th Gen Intel Core i7-11700 bits: 64 type: MT MCP
    arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
    process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
    microcode: 0x58
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1670 high: 3659 min/max: 800/4800:4900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2388 2: 1321 3: 1116
    4: 1235 5: 1757 6: 3659 7: 1433 8: 1123 9: 1257 10: 1124 11: 1025 12: 1164
    13: 1692 14: 2160 15: 2605 16: 1671 bogomips: 79872
  Type: retbleed mitigation: Enhanced IBRS
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: AMD Oland [Radeon HD 8570 / R5 430 OEM R7 240/340 Radeon 520 OEM]
    vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
    arch: GCN-1 code: Southern Islands process: TSMC 28nm built: 2011-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 8 ports: active: DP-1 empty: VGA-1
    bus-ID: 01:00.0 chip-ID: 1002:6611 class-ID: 0300 temp: 36.0 C
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: X: loaded: N/A unloaded: modesetting,radeon
    alternate: fbdev,vesa gpu: radeon display-ID: 0
  Monitor-1: DP-1 model: HP 27qi serial: <filter> built: 2019 res: 2560x1440
    dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: max: 2560x1440 min: 640x480
  API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
  Device-1: Intel Tiger Lake-H HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:43c8
    class-ID: 0403
  Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
    Series] vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aab0
    class-ID: 0403
  API: ALSA v: k4.19.288-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.74 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.05 TiB used: 913.39 GiB (43.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: BC711 HFM256GD3JX013N size: 238.47 GiB block-size: physical: 512 B
    fw-rev: HPS1 scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200
    tech: HDD rpm: 7200 serial: <filter> fw-rev: AC60 scheme: GPT
  ID-1: / raw-size: 238.18 GiB size: 233.38 GiB (97.99%)
    used: 34.99 GiB (15.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 284 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 878.4 GiB (47.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 32.0 C mobo: N/A gpu: radeon temp: 36.0 C
  Processes: 298 Uptime: 15m wakeups: 0 Memory: total: 32 GiB note: est.
  available: 31.2 GiB used: 1.83 GiB (5.9%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1698 libs: 477 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.28
And I also tried kernel 5.4, 5.10, 5.15. Neither of them works.
Any suggestions? Best regards.
Is there any error-message you could find in the logs?
my laptop also had many problems with every newer kernel than 4.19. in my case i could not use my laptop screen, but only my hdmi output. so i keep using 4.19
How did you install a new kernel?
I would recommend sticking to this guide for Manjaro.
Maybe boot from the flash drive and chroot into the system that’s not booting.
Check if the folder /etc/mkinitcpio.d/ contains linux61.preset if you have kernel 6.1 installed.
Then regenerate the initrd for all installed kernels:
$ mkinitcpio -P
Use command sudo mhwd-kernel -i linux61
I tried both the command way and the GUI way. Neither works.
An odd thing is:
The recently release liveusb is base on kernel6.1 and it stucks on booting either.
I used a very old version liveusb(around year 2020), which base on kernel4.19, that works fine.
$ mkinitcpio -P
linux61.preset is exists. And after `mkinitcpio -P’, rebooting into kernel6.1 is still failed.
It always stucks on “A start job is running for XXX”, while XXXs some randomly services.
Just this
Or should I lookup some other logs?
Does you labtop also use AMD Radeon graphic card?
Hmm, that’s kind of strange because according to logs the hardware is quite modern (ok maybe except the gpu), so the newer kernels should work just fine.
Have you tried booting other distros, say, Fedora or Ubuntu?
Oh, yes.
I have tried to install Fedora and Debian. The liveusb images they provided failed too.
BIOS is old. Do the updates.
https://support.hp.com/us-en/drivers/selfservice/hp-zhan-99-pro-g4-microtower-pc/2100616996
Yes!
Got bios updated to lastest: v: F.30 date: 02/08/2023.
Boot kernel6.1 succeefully.
Thank you so much!
