Hi. This is a problem I have since I installed Manjaro (October last year), but I have since ignored it. When my battery reaches 20%, the system slows down horribly making it almost impossible to do anything (write, switch applications, minimize a window …) The screen timeout is almost instantaneous. As soon as I connect the charger it returns to normal, like nothing.
On the one hand, it hadn’t bothered me particularly, because it forces me not to wait for the battery level to reach critical levels. But it is somewhat annoying.
When I arrived in Manjaro (October last year), there were some strange bugs that disabled trim, tlp and other important system components, so I ran in the terminal:
systemctl enable tlp --now
Perhaps I have duplicated this process since then, or is it unlikely? Or maybe the power manager settings are too aggressive? I’m a newbie and I’m afraid of hurting my system by changing values.
Lenovo Yoga 530
GNOME 40
AMD Ryzen 3
Kernel 5.13
Wayland Session
Pleas look into Power Management !
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=69af527d-a0be-49bc-9529-2b857044c8b5 rw quiet splash apparmor=1
security=apparmor resume=UUID=162c35f6-94b7-4858-87df-4243a53b4310
udev.log_priority=3
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Convertible System: LENOVO product: 81H9 v: Lenovo YOGA 530-14ARR
serial: <filter> Chassis: type: 31 v: Lenovo YOGA 530-14ARR serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40679 WIN serial: <filter>
UEFI: LENOVO v: 8MCN58WW date: 03/26/2020
ID-1: BAT0 charge: 36.9 Wh (98.7%) condition: 37.4/45.5 Wh (82.1%)
volts: 8.3 min: 7.7 model: CPT-COS L17C4PB0 type: Li-poly serial: <filter>
status: Discharging
RAM: total: 3.39 GiB used: 1.7 GiB (50.2%)
Info: Dual Core model: AMD Ryzen 3 2200U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: 0 microcode: 810100B cache: L2: 1024 KiB bogomips: 19969
Speed: 1367 MHz min/max: 1600/2500 MHz boost: enabled Core speeds (MHz):
1: 1367 2: 1369 3: 1546 4: 1445
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:15dd
class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 3-2:2
chip-ID: 04f2:b61e class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa display-ID: 0
OpenGL: renderer: AMD RAVEN (DRM 3.41.0 5.13.13-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 2000
bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 119.24 GiB used: 21.94 GiB (18.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM128GDHTNG-8310A
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 80070C00 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 111.34 GiB size: 109.03 GiB (97.93%)
used: 21.94 GiB (20.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 69af527d-a0be-49bc-9529-2b857044c8b5
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: F135-6699
ID-1: swap-1 type: partition size: 7.61 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 162c35f6-94b7-4858-87df-4243a53b4310
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-1:2
info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 1-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 0bda:c024
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-2:2 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b61e
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.6 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 240 Uptime: 2m wakeups: 3 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1301 pacman: 1296 lib: 313 flatpak: 5
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
I am on GNOME. When I go to settings I only see basic controls like screen brightness and other basics. Where could I check/change those power settings?
I can’t hep you with this. I am on XFCE. There it is in “Settings”.
Tip: change the Title of this Thread to “How can i change Power-Management in Gnome” an you will get help
