System Audio bleeding into Mic Input
System Information:
  • hardware: Asus F16 with core 5 210 and 4050
  • OS: Manjaro Linux (GNOME)
  • Audio Server: PipeWire (pipewire-pulse, wireplumber)
  • Hardware: Havit Fuxi-H3 Headset (via 3.5mm TRRS Combo Jack)
  • Audio Codec: Realtek ALC256
The Problem:
I am experiencing a persistent audio leakage (crosstalk) issue where system audio is being captured as microphone input. This happens across various applications (e.g., Discord, WhatsApp Web).
Key Observations (The “Selective” Behavior):
The issue exhibits a specific behavior: audio originating from inside the application itself (e.g., a YouTube video played inside a browser tab while in a Discord call) is not leaked, likely due to internal WebRTC echo cancellation. However, whenever I play audio from an external application (like a standalone music player), that audio immediately leaks into my mic input.
Troubleshooting already performed:
  • pavucontrol: Confirmed no “Monitor” sources are selected for input. The recording apps are pointed directly to the Headset Microphone.
  • alsamixer: Verified all channels. There are no “Loopback” or “Stereo Mix” options enabled, and Mic Boost is set to minimum.
  • Setup: Verified that the headset is correctly recognized as an Analog Stereo Duplex device in GNOME.
What I am looking for:
I suspect this is an impedance/crosstalk issue at the hardware/driver level common to the ALC256 codec. I am reaching out to see if anyone has faced this exact “selective” leakage scenario before:
  1. Has anyone successfully mitigated this specific ALC256 crosstalk issue on Manjaro/Arch using modprobe parameters or specific pin-mapping overrides?
  2. Since this seems to be a hardware-level bleed that bypasses standard software settings, has anyone implemented a global “set-and-forget” echo cancellation in PipeWire that successfully subtracts system output from all input streams?
I have ruled out basic GUI misconfigurations (alsamixer/pavucontrol), so I am specifically looking for kernel-level or advanced PipeWire/WirePlumber configurations to resolve this.
Any insights or recommended model= overrides for the ALC256 would be greatly appreciated.
wpctl status
> wpctl status
PipeWire 'pipewire-0' [1.6.5, gabrigas@cicada2106, cookie:2520646804]
 └─ Clients:
        32. WirePlumber                         [1.6.5, gabrigas@cicada2106, pid:4175]
        37. pipewire                            [1.6.5, gabrigas@cicada2106, pid:4177]
        38. GNOME Volume Control Media Keys     [1.6.5, gabrigas@cicada2106, pid:3993]
        47. WirePlumber [export]                [1.6.5, gabrigas@cicada2106, pid:4175]
        69. gnome-shell                         [1.6.5, gabrigas@cicada2106, pid:3852]
        70. GNOME Shell Volume Control          [1.6.5, gabrigas@cicada2106, pid:3852]
        73. xdg-desktop-portal                  [1.6.5, gabrigas@cicada2106, pid:4190]
        74. Brave input                         [1.6.5, gabrigas@cicada2106, pid:7342]
        75. Mutter                              [1.6.5, gabrigas@cicada2106, pid:3852]
        76. WEBRTC VoiceEngine                  [1.6.5, gabrigas@cicada2106, pid:9049]
        77. WEBRTC VoiceEngine                  [1.6.5, gabrigas@cicada2106, pid:9049]
        78. Chromium input                      [1.6.5, gabrigas@cicada2106, pid:9119]
        90. Chromium input                      [1.6.5, gabrigas@cicada2106, pid:12556]
        93. GNOME Settings                      [1.6.5, gabrigas@cicada2106, pid:12606]
       117. GNOME Settings                      [1.6.5, gabrigas@cicada2106, pid:12606]
       154. wpctl                               [1.6.5, gabrigas@cicada2106, pid:14955]
       162. Brave                               [1.6.5, gabrigas@cicada2106, pid:7342]
Audio
 ├─ Devices:
 │      48. AD107 High Definition Audio Controller [alsa]
 │      50. Built-in Audio                      [alsa]
 ├─ Sinks:
 │  *   45. Built-in Audio Analog Stereo        [vol: 0.68]
 ├─ Sources:
 │  *   44. Built-in Audio Analog Stereo        [vol: 0.42]
 ├─ Filters:
 └─ Streams:
       163. Brave
            164. output_FL       > ALC256 Analog:playback_FL	[active]
            165. output_FR       > ALC256 Analog:playback_FR	[active]
Settings
 └─ Default Configured Devices:
         0. Audio/Sink    bluez_output.00_09_24_56_09_A5.1
         1. Audio/Source  alsa_input.pci-0000_00_1f.3.analog-stereo
Please post more information about audio devices detected in ALSA
sudo alsa-info.sh --upload
User manual for Fuxi-H3 Headset states it can be connected using either:
  • 2.4GHz Wireless Mode (for PC/Laptop/PlayStation)
  • Bluetooth Mode (for Mobile Devices/Laptops with Bluetooth)
  • 3.5mm Wired Mode (for Consoles/Devices with 3.5mm Jack)
    microphone functionality may vary by device.
  • USB-C Wired Mode (for PC/Laptop)
The headset jack might be using a different wiring standard to the laptop jack
Understanding 3.5mm headset compatibility: CTIA vs OMTP standards | Inbertec
this might be resolved by using an adaptor to swap two of the TRRS connections,
or use the USB wired connection that is unlikely to have a similar crosstalk problem.
Thank you for the guidance. Here is the requested ALSA information:
https://alsa-project.org/db/?f=30b1e97ae360e722c9f8ec9266b330b7261c7fc2
Regarding the 3.5mm connection, I am going to test the headset using the USB-C wired connection as you recommended to rule out any potential wiring or crosstalk issues. I will report back once I have tested that configuration.
Sorry, but we need the whole link, otherwise it’s useless.
As you probably can’t yet post full links, as a new member, you could post the URL enclosed with backticks, so it looks like this: link to site.
When you have been more active on the Forum, you will be able to post links, etc. directly. :wink:
ALSA data for ASUS TUF Gaming F16 FX607VUR_FX607VU shows there are 2 jack-retask overrides in place for both audio devices
!!PCI Soundcards installed in the system
0000:00:1f.3 Audio device: Intel Corporation Raptor Lake-P/U/H cAVS
0000:01:00.1 Audio device: NVIDIA Corporation AD107 High Definition Audio Controller
!!ALSA/HDA dmesg
[    5.940587] snd_hda_intel 0000:00:1f.3: Applying patch firmware 'hda-jack-retask.fw'
[    5.943170] snd_hda_intel 0000:01:00.1: Applying patch firmware 'hda-jack-retask.fw'
I suggest you remove these unless they have been added for a specific known reason:
  1. Run hdajackretask with root privileges: sudo hdajackackretask
  2. Click Remove boot override for both audio devices
  3. Shutdown and restart system after a short delay (cold-boot)
  4. Run sudo alsa-info.sh --upload again to check overrides are no longer present
I’ve seen similar behavior caused by monitor audio, USB headsets, or virtual audio devices being selected as inputs without realizing it. It might be worth double-checking the active input source in PulseAudio/PipeWire and testing with a different headset or mic to rule out hardware-related crosstalk.
Original post includes data from wpctl showing pipewire-pulse default sink and source:
Settings
