I using the computer through RDP . Date & Time is locked and the unlock button is disabled for some reason, even though the user is a “sudo” user. The system time is wrong, so I want synchronise it or enable automatic synchronisation in terminal. Is that possible?
Hi @kingofmanjar0,
I suspect you’re looking for the timedatectl
command.
$ timedatectl --help
timedatectl [OPTIONS...] COMMAND ...
Query or change system time and date settings.
Commands:
status Show current time settings
show Show properties of systemd-timedated
set-time TIME Set system time
set-timezone ZONE Set system time zone
list-timezones Show known time zones
set-local-rtc BOOL Control whether RTC is in local time
set-ntp BOOL Enable or disable network time synchronization
systemd-timesyncd Commands:
timesync-status Show status of systemd-timesyncd
show-timesync Show properties of systemd-timesyncd
Options:
-h --help Show this help message
--version Show package version
--no-pager Do not pipe output into a pager
--no-ask-password Do not prompt for password
-H --host=[USER@]HOST Operate on remote host
-M --machine=CONTAINER Operate on local container
--adjust-system-clock Adjust system clock when changing local RTC mode
--monitor Monitor status of systemd-timesyncd
-p --property=NAME Show only properties by this name
-a --all Show all properties, including empty ones
--value When showing properties, only print the value
See the timedatectl(1) man page for details.
Hope this helps!
Have you tried setting the time from the Manjaro Settings Manager instead?
Manjaro Setting’s time was not disabled and setting it worked (it popped up the sudo dialogue). I wonder why Gnome Setting’s time option was disabled.
