Synchronizing package databases... unable to lock database Failed to synchronize databases
I have 2 different PC’s with Manjaro.
About 50% of the time I when running pamac updates I get the message in the subject.
The existing posts seem to about 6 months old and the recommended remedies don’t seem to fix the issue.
The updates seem to progress normally, but, I do wonder if there is some trick I’ve not found.
Not sure what to do next.
KDE Plasma Version: 5.24.6
KDE Frameworks Version: 5.96.0
Qt Version: 5.15.5
Kernel Version: 5.19.1-3-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 × AMD Athlon 3000G with Radeon Vega Graphics
Memory: 7.7 GiB of RAM
Graphics Processor: GeForce GT 610/PCIe/SSE2
Remove the database lock:
sudo rm /var/lib/pacman/db.lck
If you get: cannot remove ‘/var/lib/pacman/db.lck’: No such file or directory; use this:
sudo rm /var/tmp/pamac/dbs/db.lck
Yes, one of the previously recommended solutions.
I have tried it.
It works for about two or three updates then the error starts again.
But, I’ll try it again.
Edit: neither file exists.
Its also possible that you have corrupted database files.
sudo rm /var/lib/pacman/sync/*.*
will remove them, then refresh the database’s to replace them.
Could be.
But, why would it be fine sometimes and not others?
Not sure, but removing and replacing the databases is a first step to see if it fixes the issue. Its possible your mirror list has you occasionally connecting to a mirror with issues.
Thank you, that did the trick for me
