WARNING: Tried to mix libraries for machines build machine and host machine in target 'intel_clc' This will fail in cross build.
Compiler for C supports link arguments -Wl,-Bsymbolic-functions: YES (cached)
Compiler for C supports link arguments -Wl,-z,relro: YES (cached)
mesa-23.3.1/src/intel/vulkan/grl/meson.build:112:30: ERROR: Index 1 out of bounds of array of size 1.
A full log can be found at /home/test/Development/Manjaro Build/build/mesa/src/build/meson-logs/meson-log.txt
âŚsrc/build/meson-logs/meson-log.txt:
gpu/misc.cl:copy_mock:
gpu/misc.cl:mem_set:
gpu/misc.cl:mem_set_size_ptr:
--- stderr ---
WARNING: no p_error() function is defined
WARNING: Token 'OP' defined, but not used
WARNING: There is 1 unused token
Generating LALR tables
Now I finally installed a VM with Manjaro and I tried to test my method, but I have this error:
==> Verifying source file signatures with gpg...
mesa-23.3.1.tar.xz ... FAILED (unknown public key 8D8E31AFC32428A6)
==> ERROR: One or more PGP signatures could not be verified!
What is the proper workaround for that?
gpg --recv-keys 8D8E31AFC32428A6
On a fresh VM, the build seems ok⌠Now will see on my real systemâŚ
I have compiled on my system, and everything was ok, but when I try to install I have this option and I donât know what to do nextâŚ
makepkg --install î˛ â
==> WARNING: The package group has already been built, installing existing packages...
==> Installing mesa package group with pacman -U...
[sudo] password for xxxxxxx:
loading packages...
resolving dependencies...
:: opencl-clover-mesa and opencl-mesa are in conflict. Remove opencl-mesa? [y/N]
The first one now doesnât exist, and the second one is disabled. So I must add the first one and enable the second one, I guessâŚ
PS: Day by day I realize that open source is not open source, and the people are very cryptic in helping others, or giving info. I hope this will not happen to one of us when we go to a surgeon or a medic and have some health problemsâŚ
