Synchronize Microsoft 365 work calendar with GNOME Calendar
Hello everybody,
I am trying to synchronize my calendars with the system/GNOME calendar and it works for all calendars but for my MS 365 work calendar. I already added the account to the online accounts as “Microsoft 365” and checked calendar - but it won’t appear in the calendars. To add the account via “Microsoft Exchange” is “not supported”.
Any ideas?
Thanks,
Thorsten
Moderator edit: Topic title edited to use actual words instead of invented abbreviations to improve search results
Hi @haitifox,
I don’t know anything about it and Gnome, as such, but can advise you, if it’s available, to try Caldav.
I think you answered your own question?
From a search gnome sync office 365 calendar it seems you are not the only one.
I didn’t dive into the results but I don’t think Exchange Active Sync is, if at all, supported on Linux.
Have you tried linking using (OWA) outlook web access?
Evolution can sync M365 calendars.
However, I don’t know how to integrate into Gnome.
There is package in the extra repository, apparently for this very thing:
$ pamac search evolution
evolution-ews  3.54.2-1        extra
MS Exchange integration through Exchange Web Services
So you could try that:
pamac install evolution-ews
…and see if that helps.
Also see:
https://www.reddit.com/r/gnome/comments/wrw3l9/comment/il529tn
works with evolution-ews - thanks a lot
