Hi.
Please I’m looking for software for Manjaro. I need the software to be able to sync files to my hard drive automatically. The files are located in /home/mkey/hdd2 and I want to automatically copy them to a portable hard drive. This means that if a change occurs automatically, it will also.
This not for Manjaro in general (it can run on any distro), but i have a good experience with osync. It can synchronize folders bidirectional and you can run it as daemon in background. If the --on-changes option has been set, then it will sync on every change you make in each folder.
