Hello,
I am just discovering Manjaro & Kde Plasma and I am just wondering if it it possible the sync all plasma config. I guess it’s not as simple as that to do. Jute a question
Thanks
Christophe
Hello,
Thanks
Christophe
Hello, @cscs has written this tool (for user config)
Hi!
If with “sync” you mean theming there’s a widget to do so
Plasma Customization saver
Also if you want to “sync” the applications config, you can copy the .config folder in your home and use it in other plasma system.
With both options you gonna need to install all applications,themes,icons,etc in the new system
