Im trying to run Scrivener, but i get this:
/opt/scrivener/bin/Scrivener: symbol lookup error: /usr/lib/libfontconfig.so.1: undefined symbol: FT_Done_MM_Var
What can i do?
I try this, same error:
LD_PRELOAD=/usr/lib/libfontconfig.so.1 /opt/scrivener/bin/Scrivener 127 ✘
As mentioned in a comment on the AUR page…
The Linux version of this program is essentially aging abandonware
The current version is trialware with no Linux version. How did you install it?
Oh… i dont remember how installed… from the Aur i was getting some problems, but “fixed” (dont remember how), but anyway… dont run. I really dont care that the version is old, because i just need open a file i make time ago with scrivener… Without scrivener cant open the file to extract the info.
Thanks.
